09-负载均衡命令参考
01-出方向链路负载均衡命令
本章节下载: 01-出方向链路负载均衡命令  (4.68 MB)
01-出方向链路负载均衡命令
1 出方向链路负载均衡
1.1 出方向链路负载均衡配置命令
1.1.1 activate
1.1.2 arp-nd interface (virtual server view)
1.1.3 bandwidth busy-protection enable
1.1.4 bandwidth busy-rate
1.1.5 bandwidth interface statistics enable
1.1.6 bandwidth weight
1.1.7 busy-action continue
1.1.8 class
1.1.9 connection-limit max (link group member view)
1.1.10 connection-limit max (link view)
1.1.11 connection-limit max (virtual server view)
1.1.12 connection-sync enable
1.1.13 cost
1.1.14 cost weight
1.1.15 default link-group
1.1.16 default-class action
1.1.17 description
1.1.18 display loadbalance action
1.1.19 display loadbalance alg
1.1.20 display loadbalance class
1.1.21 display loadbalance dns-cache
1.1.22 display loadbalance hot-backup statistics
1.1.23 display loadbalance isp
1.1.24 display loadbalance link
1.1.25 display loadbalance link link-group
1.1.26 display loadbalance link out-interface statistics
1.1.27 display loadbalance link statistics
1.1.28 display loadbalance link statistics link-group
1.1.29 display loadbalance link-group
1.1.30 display loadbalance policy
1.1.31 display loadbalance probe failed-record
1.1.32 display loadbalance probe undetected
1.1.33 display loadbalance proximity
1.1.34 display parameter-profile
1.1.35 display sticky virtual-server
1.1.36 display sticky-group
1.1.37 display virtual-server
1.1.38 display virtual-server statistics
1.1.39 fail-action
1.1.40 fallback-action continue
1.1.41 forward all
1.1.42 inherit vpn-instance disable
1.1.43 ip
1.1.44 ip address (ISP view)
1.1.45 ip mask
1.1.46 ipv6
1.1.47 ipv6 address (ISP view)
1.1.48 ipv6 prefix
1.1.49 lb-policy
1.1.50 link
1.1.51 link-group (LB action view)
1.1.52 link-group (link view)
1.1.53 loadbalance action
1.1.54 loadbalance alg
1.1.55 loadbalance alg all-enable
1.1.56 loadbalance class
1.1.57 loadbalance dns-cache aging-time
1.1.58 loadbalance isp auto-update enable
1.1.59 loadbalance isp auto-update frequency
1.1.60 loadbalance isp auto-update whois-server
1.1.61 loadbalance isp file
1.1.62 loadbalance isp name
1.1.63 loadbalance link
1.1.64 loadbalance link-group
1.1.65 loadbalance log enable bandwidth-busy
1.1.66 loadbalance log enable base
1.1.67 loadbalance log enable link-flow
1.1.68 loadbalance log enable nat
1.1.69 loadbalance proximity
1.1.70 loadbalance probe failed-record enable
1.1.71 loadbalance probe failed-record max-number
1.1.72 loadbalance probe nqa-task-restrict disable
1.1.73 loadbalance policy
1.1.74 loadbalance schedule-test ip
1.1.75 loadbalance schedule-test ipv6
1.1.76 match
1.1.77 match acl
1.1.78 match app-group
1.1.79 match class
1.1.80 match default
1.1.81 match destination
1.1.82 match destination domain-name
1.1.83 match interface
1.1.84 match isp
1.1.85 match user
1.1.86 match user-group
1.1.87 match source
1.1.88 max-bandwidth
1.1.89 max-number
1.1.90 override-limit enable
1.1.91 packet-loss-rate weight
1.1.92 parameter (virtual server view)
1.1.93 parameter-profile
1.1.94 port
1.1.95 predictor (link group view)
1.1.96 priority (link group member view)
1.1.97 priority (link view)
1.1.98 probe (link group member view)
1.1.99 probe (link group view)
1.1.100 probe (link view)
1.1.101 proximity enable (link group view)
1.1.102 rate-limit bandwidth (link view)
1.1.103 rate-limit bandwidth (virtual server view)
1.1.104 rate-limit connection (link group member view)
1.1.105 rate-limit connection (link view)
1.1.106 rate-limit connection (virtual server view)
1.1.107 reset loadbalance connections
1.1.108 reset loadbalance hot-backup statistics
1.1.109 reset loadbalance link statistics
1.1.110 reset loadbalance link statistics
1.1.111 reset loadbalance probe failed-record
1.1.112 reset loadbalance proximity
1.1.113 reset virtual-server statistics
1.1.114 router interface
1.1.115 router ip
1.1.116 router ipv6
1.1.117 rtt weight
1.1.118 selected-link
1.1.119 service enable
1.1.120 set ip tos (LB action view)
1.1.121 set ip tos (parameter profile view)
1.1.122 shutdown (link group member view)
1.1.123 shutdown (link view)
1.1.124 slow-online
1.1.125 slow-shutdown enable (link group member view)
1.1.126 slow-shutdown enable (link view)
1.1.127 snat-pool
1.1.128 snmp-agent trap enable loadbalance
1.1.129 sticky-group
1.1.130 sticky-over-busy enable
1.1.131 sticky-sync enable (virtual server view)
1.1.132 success-criteria (link group member view)
1.1.133 success-criteria (link group view)
1.1.134 success-criteria (link view)
1.1.135 timeout (proximity view)
1.1.136 timeout (sticky group view)
1.1.137 transparent enable
1.1.138 ttl weight
1.1.139 virtual ip address
1.1.140 virtual ipv6 address
1.1.141 virtual-server
1.1.142 vpn-instance (link view)
1.1.143 vpn-instance (virtual server view)
1.1.144 weight (link group member view)
1.1.145 weight (link view)
1.1.146 whois-mntner
1 出方向链路负载均衡
非缺省vSystem不支持本特性的部分命令,具体情况请见本文相关描述。有关vSystem的详细介绍请参见“虚拟化技术配置指导”中的“vSystem”。
1.1  出方向链路负载均衡配置命令
1.1.1  activate
activate命令用来配置链路组的可用条件。
undo activate命令用来恢复缺省情况。
activate lower lower-percentage upper upper-percentage
undo activate
链路组中只要有一个链路可用,该链路组就被认为可用。
链路组视图
context-admin
lower lower-percentage:最小可用百分比,取值范围为1~99。
upper upper-percentage:最大可用百分比,取值范围为1~99,且必须大于等于最小可用百分比。
工作机制
当主用链路组中可用的链路数量占链路总数量的百分比低于最小可用百分比时,该链路组将被认为不可用,从而切换到备用链路组;当主用链路组中可用的链路数量占链路总数量的百分比高于最大可用百分比时,将从备用链路组切换回主用链路组。
注意事项
非缺省vSystem不支持本命令。
当虚服务器上未配置备用链路组时,本配置无效。
# 配置链路组lg的最小可用百分比为20,最大可用百分比为80。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] activate lower 20 upper 80
arp-nd interface命令用来指定发送免费ARP报文或ND报文的接口。
undo arp-nd interface命令用来删除发送免费ARP报文或ND报文的指定接口。
arp-nd interface interface-type interface-number
undo arp-nd interface interface-type interface-number
未指定发送免费ARP报文或者ND报文的接口,即所有接口均不能发送免费ARP报文或者ND报文。
虚服务器视图
context-admin
vsys-admin
interface-type interface-number:发送免费ARP报文或ND报文的接口类型和接口编号。
在同一虚服务器下,可以多次执行本命令,指定多个接口发送免费ARP报文或者ND报文。
若虚服务器的IP地址与设备连接客户端的接口IP地址在同一网段,则必须进行以下配置:
·     配置虚服务器IP地址的IPv4掩码长度为32或IPv6前缀长度为128。
·     执行本命令指定发送免费ARP报文或ND报文的接口。
·     开启虚服务器IP地址发布功能。
反之,若虚服务器的IP地址与设备连接客户端的接口IP地址不在同一网段上,则无需进行上述设置。
当负载均衡功能已完成配置并正常运行时,更改发送免费ARP报文或ND报文的接口,可能会影响现有的负载均衡业务,请勿随意更改。
# 在虚服务器vs3下,指定发送免费ARP报文或ND报文的接口为GigabitEthernet1/0/1。
<Sysname>system-view
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] arp-nd interface gigabitethernet 1/0/1
bandwidth busy-protection enable命令用来开启链路的带宽繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭链路的带宽繁忙保护功能。
链路的带宽繁忙保护功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
工作机制
链路出方向或入方向带宽繁忙就是出方向或入方向流量超过该方向的带宽繁忙比,带宽繁忙保护功能就是对超过链路出方向带宽繁忙比的报文进行限制。当某条链路只有出方向的状态为繁忙时,新建流量(非匹配会话保持的流量)将不再向该链路分发,而原有流量则仍由该链路继续分发;如果只有链路入方向的状态为繁忙,而出方向的状态不为繁忙时,此时新建流量会继续往该链路分担。
某条链路只要一个方向(出方向或入方向)的状态变为繁忙,该条链路状态就会显示为繁忙;只有当两个方向的状态都为正常时,该条链路的状态才会显示为正常。
注意事项
带宽繁忙保护功能仅在链路的接口带宽统计功能开启的情况下生效。
# 在IP类型的虚服务器vs3中开启链路带宽繁忙保护功能。
[Sysname-vs-ip-vs3] bandwidth busy-protection enable
·     bandwidth interface statistics enable
bandwidth busy-rate命令用来配置链路的带宽繁忙比。
undo bandwidth busy-rate命令用来恢复缺省情况。
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
带宽繁忙比例为70。
链路视图
context-admin
inbound:表示入方向的带宽繁忙比。
outbound:表示出方向的带宽繁忙比。
busy-rate-number:链路的带宽繁忙比例,取值范围为1~100。
recovery recovery-rate-number:链路带宽繁忙恢复比例,取值范围为1~100。缺省情况下,当带宽繁忙比例大于10时,带宽繁忙恢复比例为带宽繁忙比例减去10;当带宽繁忙比例小于等于10时,带宽繁忙恢复比例等于带宽繁忙比例。
工作机制
当链路的带宽超过该链路的带宽繁忙比例与最大期望带宽的乘积时,链路进入繁忙状态,不再参与调度。当链路的带宽低于带宽繁忙恢复比例与最大期望带宽的乘积时,链路解除繁忙状态,重新参与调度。
若未指定inbound或outbound关键字,则表示设置链路的总带宽繁忙比例。
带宽繁忙比例为当前链路实际带宽与用户配置最大带宽的百分比值,若最大带宽设置为不受限,则使用其可设置的最大值进行计算。
注意事项
非缺省vSystem不支持本命令。
同一链路的带宽繁忙恢复比例必须小于等于带宽繁忙比例。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置链路lk1的总带宽繁忙比例为90,带宽繁忙恢复比例为85。
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
·     display loadbalance link
·     max-bandwidth(link view)
bandwidth interface statistics enable命令用来开启链路的接口带宽统计功能。
undo bandwidth interface statistics enable命令用来关闭链路的接口带宽统计功能。
接口带宽统计功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
缺省情况下,链路的带宽是由负载均衡模块自行统计,带宽相关的统计直接使用当前LLB自身的链路统计值进行算法计算和限速。开启本命令后,可以使链路的带宽由接口实时统计,接口带宽统计周期通过flow-interval命令来配置。二者相比之下,建议采用链路的接口带宽统计功能,更能精确地体现链路的实时带宽情况。
# 在IP类型的虚服务器vs3上,并开启链路的接口带宽统计功能。
[Sysname-vs-ip-vs3] bandwidth interface statistics enable
·     flow-interval(接口管理命令参考/以太网接口)
bandwidth weight命令用来配置就近性计算的带宽权值。
undo bandwidth weight命令用来恢复缺省情况。
bandwidth { inbound | outbound } weight bandwidth-weight
undo bandwidth { inbound | outbound } weight
就近性计算的出、入方向带宽权值均为100。
就近性视图
context-admin
inbound:表示入方向的带宽权值。
outbound:表示出方向的带宽权值。
bandwidth-weight:就近性计算的带宽权值,取值范围为0~255,数值越大权重越大。
工作机制
链路的剩余带宽涉及就近性的计算。就近性计算涉及到的因素包括:链路的剩余带宽、路由跳数、网络延迟、成本、丢包率等。在复杂多变的网络情况下,通过合理调整就近性因素的权值,以计算出当前网络最优的链路,实现网络流量的最优分配。
注意事项
非缺省vSystem不支持本命令。
# 配置就近性计算的入方向带宽权值为200。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] bandwidth inbound weight 200
# 配置就近性计算的出方向带宽权值为200。
[Sysname-lb-proximity] bandwidth outbound weight 200
busy-action continue命令用来配置负载均衡动作的繁忙处理方式为继续匹配下一条引用规则。
undo busy-action命令用来恢复缺省情况。
undo busy-action
负载均衡动作的繁忙处理方式为强制调度。
链路类型的负载均衡动作视图
DNS类型的负载均衡动作视图
context-admin
工作机制
当配置该命令的动作在负载均衡策略中被引用时,判断当前动作查找链路或DNS服务器全部繁忙时,可继续顺序匹配策略中的下一条引用规则。
注意事项
非缺省vSystem不支持本命令。
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作a1中,配置负载均衡动作的繁忙处理方式为继续匹配下一条引用规则。
[Sysname] loadbalance action a1 type link-generic
[Sysname-lba-link-generic-a1] busy-action continue
# DNS透明代理场景下,在DNS类型的负载均衡动作a2中,配置负载均衡动作的繁忙处理方式为继续匹配下一条引用规则。
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] busy-action continue
1.1.8  class
class命令用来配置负载均衡类对应的负载均衡动作。
undo class命令用来删除指定的负载均衡类。
class class-name [ insert-before before-class-name | insert-after [ after-class-name ] ] action action-name
undo class class-name
未指定负载均衡类对应的负载均衡动作。
负载均衡策略视图
context-admin
vsys-admin
class-name:负载均衡类的名称,为1~255个字符的字符串,不区分大小写。
insert-before:表示插入到指定的负载均衡类之前(该负载均衡类必须已被当前负载均衡策略引用)。
before-class-name:表示用于参照的负载均衡类名称,为1~255个字符的字符串,不区分大小写。
insert-after:表示插入到指定的负载均衡类之后(该负载均衡类必须已被当前负载均衡策略引用)。
after-class-name:表示用于参照的负载均衡类名称,为1~255个字符的字符串,不区分大小写。若未配置本参数,则表示插入到所有负载均衡类之前。
action-name:负载均衡动作的名称,为1~255个字符的字符串,不区分大小写。
工作机制
通过本命令可以为匹配特定负载均衡类的报文指定其执行的负载均衡动作。
配置本命令时,若未指定insert-before和insert-after,则表示将新增负载均衡类插入到所有负载均衡类之后。
不同的负载均衡类可以与同一负载均衡动作组成匹配规则。
用户可以在一个负载均衡策略中指定多个负载均衡类,转发报文时会按照配置顺序来匹配负载均衡类,匹配成功则执行相应的负载均衡动作,不会继续匹配下一条负载均衡类,否则继续匹配下一条负载均衡类。因此,当负载均衡类之间存在包含关系时,建议将更精细的负载均衡类放在前面,宽泛的负载均衡类放在后面。如果所有负载均衡类均未匹配,则执行缺省负载均衡动作。
注意事项
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作;通用类型的负载均衡策略只能引用通用类型的负载均衡类和负载均衡动作;HTTP类型的负载均衡策略则无此限制。
# 服务器负载均衡场景下,在通用类型的负载均衡策略lbp1中,为负载均衡类lbc1指定负载均衡动作为lba1,并将lbc1插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1] class lbc1 insert-before lbc0 action lba1
# 出方向链路负载均衡场景下,在链路类型的负载均衡策略lbp2中,为负载均衡类lbc2指定负载均衡动作为lba2,并将lbc2插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp2 type link-generic
[Sysname-lbp-link-generic-lbp2] class lbc21 insert-before lbc0 action lba2
# DNS透明代理场景下,在DNS类型的负载均衡策略lbp3中,为负载均衡类lbc3指定负载均衡动作为lba3,并将lbc3插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp3 type dns
[Sysname-lbp-dns-lbp3] class lbc3 insert-before lbc0 action lba3
connection-limit max 命令用来配置链路组成员所允许的最大连接数。
undo connection-limit max 命令用来恢复缺省情况。
connection-limit max max-number
链路组成员所允许的最大连接数不受限制。
链路组成员视图
context-admin
max-number:最大连接数,取值范围为0~4294967295,0表示链路组成员所允许的最大连接数不受限制。
功能简介
只要访问链路组成员的连接数超过指定的最大连接数的值,则链路组成员进入繁忙状态。设备不再将用户请求分配给处于繁忙状态的链路组成员,直到判断繁忙状态的连接参数(最大连接数和最大连接速率)全部小于配置的值为止。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组成员lk1所允许的最大连接数为10000。
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] connection-limit max 10000
·     rate-limit connection (link group member view)
connection-limit max命令用来配置链路所允许的最大连接数。
undo connection-limit max命令用来恢复缺省情况。
链路所允许的最大连接数为0,即不受限制。
链路视图
context-admin
max-number:最大连接数,取值范围为0~4294967295,0表示链路所允许的最大连接数不受限制。
功能简介
只要访问链路的连接数超过指定的最大连接数的值,则链路进入繁忙状态。设备不再将用户请求分配给处于繁忙状态的链路,直到判断繁忙状态的连接参数(最大连接数和最大连接速率)全部小于配置的值为止。
注意事项
非缺省vSystem不支持本命令。
# 配置链路的最大连接数为10000。
[Sysname-lb-link-lk] connection-limit max 10000
·     rate-limit connection (link view)
connection-limit max 命令用来配置虚服务器所允许的最大连接数。
虚服务器所允许的最大连接数为0,即不受限制。
虚服务器视图
context-admin
vsys-admin
max-number:最大连接数,取值范围为0~4294967295,0表示虚服务器所允许的最大连接数不受限制。
# 配置IP类型的虚服务器vs3所允许的最大连接数为10000。
[Sysname-vs-ip-vs3] connection-limit max 10000
# 出方向链路负载均衡场景下,配置LINK-IP类型的虚服务器vs2所允许的最大连接数为10000。
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] connection-limit max 10000
connection-sync enable命令用来开启虚服务器的会话扩展信息备份功能。
undo connection-sync enable命令用来关闭虚服务器的会话扩展信息备份功能。
虚服务器的会话扩展信息备份功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
HTTP类型的虚服务器不支持本命令。
# 开启IP类型的虚服务器vs3的会话扩展信息备份功能。
[Sysname-vs-ip-vs3] connection-sync enable
# 在出方向链路负载均衡场景下,开启LINK-IP类型的虚服务器vs2的会话扩展信息备份功能。
[Sysname-vs-link-ip-vs2] connection-sync enable
1.1.13  cost
cost命令用来配置就近性计算的链路成本。
undo cost命令用来恢复缺省情况。
cost cost-value
undo cost
就近性计算的链路成本为0。
链路视图
context-admin
cost-value:就近性计算的链路成本,取值范围为0~10240。
功能简介
链路成本参与就近性的计算,成本越高,链路越不优先被选用。通过本功能可手动配置链路的成本。
例如,当某条链路带宽小、状况较差时,管理员可以通过cost手动提高该链路的成本值,也可以通过cost weight将成本权值调低来规避链路成本的计算影响。
注意事项
非缺省vSystem不支持本命令。
# 在链路lk1中配置就近性计算的链路成本为200。
[Sysname-lb-link-lk1] cost 200
·     cost weight
1.1.14  cost weight
cost weight命令用来配置就近性计算的成本权值。
undo cost weight命令用来恢复缺省情况。
cost weight cost-weight
undo cost weight
就近性计算的成本权值为100。
就近性视图
context-admin
cost-weight:就近性计算的成本权值,取值范围为0~255,数值越大权重越大。
工作机制
链路成本参与就近性的计算,通过合理调整成本的权值,以计算出当前网络最优的链路。例如,当链路带宽小、状况较差时,管理员可以通过cost命令提高该链路的成本值,也可以通过本命令将权值调低来规避链路成本的计算影响。
注意事项
非缺省vSystem不支持本命令。
# 配置就近性计算的费用权值为200。
[Sysname-lb-proximity] cost weight 200
·     cost
default link-group命令用来指定缺省链路组。
undo default link-group命令用来恢复缺省情况。
default link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
未指定缺省的链路组。
Link-IP类型的虚服务器视图
context-admin
link-group-name:主用链路组的名称,为1~255个字符的字符串,不区分大小写。
backup backup-link-group-name:备用链路组的名称,为1~255个字符的字符串,不区分大小写。
sticky sticky-name:会话保持组的名称,为1~255个字符的字符串,不区分大小写。
工作机制
当主用链路组可用(该链路组存在且有可用的链路)时,虚服务器通过主用链路组转发报文;当主用链路组不可用而备用链路组可用时,虚服务器通过备用链路组转发报文。
注意事项
非缺省vSystem不支持本命令。
# 为Link-IP类型的虚服务器vs3指定缺省的主用链路组为link1,备用链路组为link2,会话保持组名称为sg1。
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] default link-group link1 backup link2 sticky sg1
default-class action命令用来配置缺省的负载均衡动作。
undo default-class命令用来恢复缺省情况。
default-class action action-name
undo default-class
未配置缺省的负载均衡动作。
负载均衡策略视图
context-admin
vsys-admin
工作机制
通过本命令可以为未匹配任何负载均衡类的报文指定其执行的缺省动作。
注意事项
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作作为其缺省负载均衡动作;通用类型的负载均衡策略只能用通用类型的负载均衡动作作为其缺省的负载均衡动作;HTTP类型的负载均衡策略则无此限制。
# 服务器负载均衡场景下,在通用类型的负载均衡策略lbp1中,配置缺省的负载均衡动作为lba1。
[Sysname-lbp-generic-lbp1] default-class action lba1
# 出方向链路负载均衡场景下,在链路类型的负载均衡策略lbp2中,配置缺省的负载均衡动作为lba2。
[Sysname-lbp-link-generic-lbp2] default-class action lba2
# DNS透明代理场景下,在DNS类型的负载均衡策略lbp3中,配置缺省的负载均衡动作为lba3。
[Sysname-lbp-dns-lbp3] default-class action lba3
1.1.17  description
description命令用来配置描述信息。
undo description命令用来恢复缺省情况。
未配置描述信息。
虚服务器视图
负载均衡动作视图/负载均衡类视图/负载均衡策略视图
负载均衡探测模板视图
SNAT地址池视图
参数模板视图/会话保持组视图
链路视图/链路组成员视图/链路组视图
ISP视图
context-admin
vsys-admin
text:描述信息,为1~127个字符的字符串,区分大小写。
# 配置链路类型的负载均衡动作lba1的描述信息为“LB action LBA1”。
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba-link-generic-lba1] description LB action LBA1
display loadbalance action命令用来显示负载均衡动作的信息。
display loadbalance action [ name action-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name action-name:显示指定负载均衡动作的信息。action-name为负载均衡动作的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡动作的信息。
设备的实际显示信息与设备型号有关,请以设备实际显示为准。本文中的显示信息仅为示例。
# 显示所有负载均衡动作的信息。
<Sysname> display loadbalance action
LB action: lba1
  Description:
  Type: Generic
  State: Inactive
  Forward type: Drop
  IP ToS:
  Fallback-action: Disabled
  Busy-action: Force
  TCP payload rewrite:
    Value: QMGR.S01
    Replacement: QMGR.S01%[variable]
    Direction: Request
    Value: QMGR.S01_1
    Replacement: QMGR.S01_2
    Direction: Response
    Value: QMGR.S02_2
    Direction: Response
  Reference count: 1
LB action: lba2
  Description:
  Type: HTTP
  State: Active
  Forward type: Server farm
  Server farm: sf (in use)
  Backup server farm: sfb
  Sticky: sg3
  Backup sticky: sg4
  IP ToS: 20
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation:
  Redirect return-code: 302
    URL rewrite:
      Value:
      Replacement:
  Header delete:
    Direction: Request
  Header insert:
    Value: 1234567890123456789012345678901234567890123456789012345678901234567890
    Direction: Both
  Header insert:
    Value: dd
    Direction: Request
  Header rewrite:
    Value: dd
    Replacement: ff
    Direction: Response
  SSL URL rewrite:
    Value: 12
    Clear port: 12
    SSL port: 123
  Location header rewrite:
    Target string: (http://www.example.com): 9080
    Replacement string: %1:80
  Reference count: 1
LB action: lba3
  Description: sina
  Type: Link-generic
  State: Active
  Forward type: link group
  Link group: lg1 (in use)
  Backup link group: lg2
  Sticky:
  IP ToS:
  Fallback-action: None
  Reference count: 1
LB action: lba4
  Description: xx
  Type: DNS
  State: Active
  Forward type: DNS server pool
  DNS server pool: dsp1
  Sticky: st
  IP ToS:
  Busy-action: Force
  Reference count: 1
LB action: lba5
  Description:
  Type: HTTP
  State: Active
  Forward type: Redirect
  IP ToS:
  Fallback-action: Continue
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation: www.example.com
    URL rewrite:
      Value:
      Replacement:
  Reference count: 1
LB action: lba6
  Description:
  Type: HTTP
  State: Active
  Forward type: Response
  IP ToS:
  Fallback-action: Response
    Raw file name: 301.raw
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
    URL rewrite:
      Value: group
      Replacement: csp
  Response file:
    File: index.html
    URL: /index/css
  Response file:
    File name: subsys_intf.js
    URL: /index/subsys
  Response file:
    File name: subsys.js
    URL: /subsys.js
  Response zip file:
    Zip file name: subsys.zip
    Working path: /
  Reference count: 1
LB action: lba7
  Description:
  Type: Diameter
  State: Active
  Backup server farm:
  Sticky: sg3
  SSL client policy:
  TCP parameter profile (client-side): tcp
  Diameter-session parameter profile: dia1
  Reference count: 1
表1-1 display loadbalance action命令显示信息描述表
LB action
负载均衡动作的名称
负载均衡动作的描述信息
负载均衡动作的类型,包括:
·     DNS:表示DNS类型
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
·     Link-generic:表示链路类型
·     RADIUS:表示RADIUS类型
·     Diameter:表示Diameter类型
负载均衡动作的状态,包括:
·     Active:可用
·     Inactive:不可用
Forward type
负载均衡动作中的报文转发模式,包括:
·     Drop:丢弃
·     Drop(FIN-close):通过FIN方式关闭连接(通用\HTTP\Diameter类型的负载均衡动作)
·     Drop(RST-close):通过RST方式关闭连接(通用\HTTP\Diameter类型的负载均衡动作)
·     Forward:正常转发
·     Server farm:通过实服务组指导转发(通用\HTTP\Radius\Diameter类型的负载均衡动作)
·     Link group:链路组(链路类型的负载均衡动作)
·     DNS server pool:通过DNS服务器池指导转发(DNS类型的负载均衡动作)
·     Skip current DNS proxy:跳过当前DNS透明代理(DNS类型的负载均衡动作)
·     Redirect:重定向类型
·     Response:代答
Server farm
指导转发的主用实服务组名称,(in use)表示该实服务组正被使用。只有当报文转发模式为server farm时才会显示本字段
Backup server farm
指导转发的备用实服务组名称,(in use)表示该实服务组正被使用。只有当报文转发模式为server farm时才会显示本字段
Link group
缺省的链路组,如果包含(in use)代表链路组是当前正在使用
Backup link group
备份的链路组,如果包含(in use)代表链路组是当前正在使用
Sticky
指导转发的主用会话保持组名称,只有当报文转发模式为server farm和DNS server pool时才会显示本字段
Backup sticky
备用会话保持组名称,只有当报文转发模式为server farm且负载均衡动作类型为HTTP或RADIUS时才会显示本字段
IP ToS
IP报文的ToS字段值
Fallback-action
负载均衡处理失败时进行的操作,包括:
·     None:不做任何操作
·     Continue:继续匹配下一条引用规则
·     Response:用指定文件进行代答操作(DNS\通用\HTTP\链路\Radius类型的负载均衡动作)
·     FIN-close:FIN方式关闭连接(通用和HTTP类型的负载均衡动作)
·     RST-close:RST方式关闭连接(通用和HTTP类型的负载均衡动作)
Busy-action
负载均衡动作中的繁忙处理方式,包括:
·     Continue:继续匹配策略中的下一条引用规则
·     Force:强制调度
SSL client policy
SSL客户端策略的名称,只有HTTP、Diameter类型的负载均衡动作才会显示本字段
Content rewrite
重写HTTP实体的配置,其中:
·     Value:要被重写的HTTP实体的内容
·     Replacement:重写后的内容
只有HTTP类型的负载均衡动作才会显示本字段
Redirect relocation
重定向的URL,只有HTTP类型的负载均衡动作才会显示本字段
URL rewrite
重写Location首部,其中:
·     Value:要被重写的Location首部的正则表达式
重定向报文中的状态码,只有HTTP类型的负载均衡动作才会显示本字段
Header delete
删除HTTP首部的配置,其中:
·     Name:HTTP报文首部的名称
·     Direction:HTTP报文的方向,包括Both、Request和Response
只有配置了header delete命令才会显示本字段
Header insert
插入HTTP首部的配置,其中:
·     Name:要插入HTTP报文中的首部名称
·     Value:要插入HTTP报文中的首部内容
只有配置了header insert命令才会显示本字段
Header rewrite
重写HTTP首部的配置,其中:
·     Name:HTTP报文首部的名称
·     Value:要被重写的HTTP报文首部的内容
只有配置了header rewrite命令才会显示本字段
SSL URL rewrite
重写服务器发送的HTTP应答报文Location首部的URL的配置,其中:
·     Value:Location首部URL的正则表达式
·     Clear port:原HTTP端口号
·     SSL port:重写后的SSL端口号
只有配置了ssl url rewrite命令才会显示本字段
重写服务器发送的HTTP应答报文Location内容,其中:
·     Target string:要被重写Location首部的正则表达式
·     Replacement string:重写后的Location首部
只有配置了location rewrite replace命令才会显示本字段
DNS server pool
指导转发的DNS服务器池名称,只有当报文转发模式为DNS server pool时才会显示本字段
Response file
用非压缩文件对指定URL的客户端请求进行代答
File name
对客户端请求进行代答的非压缩文件名
URL
用压缩文件对指定URL的客户端请求进行代答,缺省为/filename
Response zip file
对指定URL的客户端请求进行代答
Zip file name
对客户端请求进行代答的压缩文件名
Working path
工作路径,用于匹配URL,缺省为根路径/
Raw file name
负载均衡处理失败时的代答文件
TCP payload rewrite
重写TCP载荷的配置,其中:
·     Value:要被重写的TCP报文载荷的内容
·     Direction:TCP报文的方向,包括Both、Request和Response
只有配置了payload rewrite命令才会显示本字段
Diameter类型负载均衡动作引用的客户端侧TCP类型参数模板,只有配置了客户端侧TCP类型的参数模板才会显示本字段
Diameter类型负载均衡动作引用的Diameter-session类型参数模板,只有引用了Diameter类型的参数模板才会显示本字段
Reference count
被引用次数
display loadbalance alg用来显示所有协议的负载均衡ALG状态。
context-admin
context-operator
vsys-admin
vsys-operator
当虚服务器配置的端口号为非知名端口号时,即使已开启相应协议的负载均衡ALG功能,设备也不会进行负载均衡ALG处理。可通过以下任一方式解决:
·     修改虚服务器端口号为该协议自身的知名端口号。
·     使用port-mapping命令,将虚服务器中配置的端口号与指定协议建立端口映射关系。关于port-mapping命令的详细介绍,请参见“安全命令参考”中的“APR”。
# 显示所有协议的负载均衡ALG状态。
<Sysname> display loadbalance alg
LB ALG:
  DNS         : Enable
  FTP         : Enable
  H323        : Disabled
  ICMP-ERROR  : Enable
  ILS         : Disabled
  MGCP        : Disabled
  NBT         : Disabled
  PPTP        : Enable
  RSH         : Disabled
  RTSP        : Enable
  SCCP        : Disabled
  SIP         : Disabled
  SQLNET      : Disabled
  TFTP        : Disabled
  XDMCP       : Disabled
display loadbalance class命令用来显示负载均衡类的信息。
display loadbalance class [ name class-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name class-name:显示指定负载均衡类的信息。class-name为负载均衡类的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡类的信息。
# 显示所有负载均衡类的信息。
<Sysname> display loadbalance class
LB class: lbc1
  Description:
  Type: HTTP
  Match type: Match-all
  Match rule:
    match 1 source ip address 1.2.3.0 24
    match 2 source ipv6 address 1::2
    match 3 cookie abc value 123
    match 4 header def value 12
    match 5 method ext xde
    match 6 method rfc CONNECT
    match 7 class cla2
    match 8 url 2q3
    match 9 acl ipv4 number 2000
    match 10 acl ipv6 number 2001
    match 11 acl ipv4 name aaa
    match 12 acl ipv6 name bbb
    match 13 isp name isp1
  Reference count: 1
LB class: lbc2
  Description:
  Type: Generic
  Match type: Match-any
  Match rule:
    match 1 class cla2
    match 2 source ip address 1.2.23.0 24
    match 3 source ipv6 address 1::12
    match 4 acl ipv4 number 3000
    match 5 acl ipv6 number 3001
    match 6 acl ipv4 name ccc
    match 7 acl ipv6 name ddd
    match 8 isp name isp2
    match 9 payload orcl
  Reference count: 1
LB class: lbc3
  Description:
  Type: Link-generic
  Match rule:
    match 1 class cla3
    match 2 source ip address 1.2.3.0 24
    match 4 acl ipv4 number 3002
    match 5 acl ipv6 number 3003
    match 9 user u1
    match 10 user-group lb-group
    match 11 interface GE1/0/1
  Reference count: 1
LB class: lbc4
  Description:
  Type: DNS
  Match rule:
    match 1 class cla2
    match 8 destination ip address 1.2.3.0 24
    match 9 destination ipv6 address 1::12
    match 10 domain-name www.example.com
  Reference count: 1
LB class: lbc5
  Description:
  Type: MySQL
  Match rule:
    match 1 class cla2
    match 8 sql select
  Reference count: 1
LB class: lbc6
  Description:
  Type: Diameter
  Match rule:
    match 1 class cla2
    match 2 application-id 5
    match 3 destination-realm a.example.com
  Reference count: 1
表1-2 display loadbalance class命令显示信息描述表
LB class
负载均衡类的名称
负载均衡类的描述信息
负载均衡类的类型,包括:
·     DNS:表示DNS类型
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
·     MySQL:表示MySQL类型
·     RADIUS:表示RADIUS类型
Match type
负载均衡类的匹配类型,包括:
·     Match-all:表示需要匹配所有规则才算匹配该类
·     Match-any:表示只需匹配任一规则就算匹配该类
Match rule
负载均衡类包含的匹配规则
Reference count
被引用次数
display loadbalance dns-cache命令用来显示DNS缓存信息。
display loadbalance dns-cache [ vpn-instance vpn-instance-name ] [ domain-name domain-name ] [ traffic-group traffic-group-id ] [ slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网实例中的DNS缓存的信息。
domain-name domain-name:显示指定域名的DNS缓存信息。domain-name为域名,为1~253个字符的字符串,不区分大小写。如果未指定本参数,将显示所有域名的DNS缓存信息。
traffic-group traffic-group-id:显示指定集群流量组的DNS缓存信息。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示显示所有集群流量组的DNS缓存信息。
slot slot-number:显示指定成员设备上的DNS缓存信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的DNS缓存信息。‌‌
工作机制
DNS缓存信息用于记录域名和IP地址的对应关系。
注意事项
非缺省vSystem不支持本命令。
# 显示所有DNS缓存信息。
<Sysname> display loadbalance dns-cache
Slot 1:
Domain name: www.example.com
Cluster traffic group: 1
Aging time: 20 min
IPv4 addresses: 6.3.5.2
                4.5.6.3
                192.169.41.8
IPv6 addresses: 4:4:4::7
Aging time: 20 min
IPv4 addresses: 5.5.5.5
                3.4.5.9
表1-3 display loadbalance dns-cache命令显示信息描述表
Domain name
域名
集群流量组的编号
Aging time
DNS缓存表项的老化时间,单位为分钟
IPv4 addresses
域名对应的IPv4地址
IPv6 addresses
域名对应的IPv6地址
display loadbalance hot-backup statistics命令用来显示负载均衡热备份的统计信息。
display loadbalance hot-backup statistics [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 显示负载均衡热备份的统计信息。
<Sysname> display loadbalance hot-backup statistics
Slot 2:
               TryAdd    TryDel    AckDel    AckOK     AckNO     NotSpt
  StiSnd       1         0         0         0         0         0
  StiRcv       0         0         0         0         0         0
  StiSndFail   0         0         0         0         0         0
  StiRcvFail   0         0         0         0         0         0
  MsgSnd       1         0         0         0         0         0
  MsgRcv       0         0         0         0         0         0
  MsgSndFail   0         0         0         0         0         0
  MsgRcvFail   0         0         0         0         0         0
  MAllocFail   0         0         0         0         0         0
  SesBkTotal : 0
  SesBkFail  : 0
  SesResTotal: 0
  SesResFail : 0
  SesUpdate  : 0
表1-4 display loadbalance hotbackup statistics命令显示信息描述表
TryAdd
会话保持表项添加消息
TryDel
会话保持表项删除消息
AckDel
会话保持表项确认删除消息
AckOK
会话保持表项可以删除消息
AckNO
会话保持表项不能删除消息
NotSpt
不支持的会话保持表项消息
StiSnd
发送条数
StiRcv
接收条数
StiSndFail
发送失败条数
StiRcvFail
接收失败条数
MsgSnd
报文发送次数
MsgRcv
报文接收次数
MsgSndFail
报文发送失败次数
MsgRcvFail
报文接收失败次数
MAllocFail
内存申请失败次数
SesBkTotal
会话备份次数
SesBkFail
会话备份失败次数
SesResTotal
会话恢复次数
SesResFail
会话恢复失败次数
SesUpdate
会话更新次数
display loadbalance isp命令用来显示ISP的信息。
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
context-admin
context-operator
ip ipv4-address:显示指定IPv4地址所对应ISP的信息。
ipv6 ipv6-address:显示指定IPv6地址所对应ISP的信息。
name isp-name:显示指定名称的ISP的信息,isp-name为1~255个字符的字符串,不区分大小写。
工作机制
如果未指定任何可选参数,将显示所有ISP的信息。
注意事项
非缺省vSystem不支持本命令。
# 显示所有ISP的信息。
<Sysname> display loadbalance isp
(*) - User-defined object
Last successful auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update result: Successful
  ISP update count: 1
LB ISP: isp1
    Description: ISP1
    Whois maintainer object name:
        MAINT-CHINANET
    IPv4 address/Mask length: --
    IPv6 address/Prefix length: --
  Reference count: 1
  Subscription info: --
SR            IPv4
LB ISP: isp2(*)
    Description:
        1.2.3.0/32(*)           1.2.3.4/32              3.3.3.6/32(*)
        192.168.6.131/32(*)     192.168.195.189/32(*)
        1::2/128
        FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
  Reference count: 1
SR            IPv4
SR6           IPv6
# 显示IPv4地址1.2.3.0所对应ISP的信息。
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name            Source                   IPv4 address/Mask length
isp2                user-set                 1.2.3.0/28
isp2                user-set                 1.2.3.0/29
isp2                user-set                 1.2.3.0/30
isp2                file-load                1.2.3.0/31
                    auto-update
isp2                user-set                 1.2.3.0/32
                    file-load
# 显示IPv6地址1::1234所对应ISP的信息。
<Sysname> display loadbalance isp ipv6 1::1234
ISP name            Source                   IPv6 address/Prefix length
isp2                user-set                 1::1234/126
isp2                user-set                 1::1234/127
isp2                file-load                1::1234/128
表1-5 display loadbalance isp命令显示信息描述表
(*)表示该ISP信息仅由用户手动配置而来。如果ISP信息既是手工配置又是文件导入时,不显示(*)
最近一次成功更新的时间
最近一次更新的时间
最近一次更新的状态,包括:
·     Successful:成功
·     Failed to connect to WHOIS server:连接WHOIS服务器失败
·     Connection failed:连接异常
·     Failed to query DNS:发送DNS请求失败
ISP update count
最近一次更新ISP的个数
LB ISP
ISP的名称
ISP的描述信息
WHOIS服务器管理标识
ISP的IPv4地址和掩码长度
ISP的IPv6地址和前缀长度
ISP name
ISP的名称
Source
ISP的来源,包括:
·     user-set:表示由用户手工配置
·     file-load:表示由文件导入
·     auto-update:表示来源于自动更新
Reference count
被引用次数
Subscription info
ISP被订阅信息,如果没有被订阅,则显示--
Module
ISP被订阅的模块名称
IP type
订阅的IP类型,包括:
·     IPv4:IPv4类型,当IPv4地址变更时上报事件
·     IPv6:IPv6类型,当IPv6地址变更时上报事件
·     IPv4&IPv6:IPv4和IPv6类型,当IPv4或IPv6地址变更时上报事件
display loadbalance link命令用来显示链路的信息。
display loadbalance link [ brief | name link-name ]
context-admin
context-operator
brief:显示所有链路的简要信息。如果未指定本参数,将显示链路的详细信息。
name link-name:显示指定链路的详细信息。link-name为链路的名称,为1~255个字符的字符串,不区分大小写。
工作机制
如果未指定任何参数,则表示显示所有链路的详细信息。
注意事项
非缺省vSystem不支持本命令。
# 显示所有链路的简要信息。
<Sysname> display loadbalance link brief
Link         Router IP/Interface    State        VPN instance     Link group
Lk1          192.168.1.1            Busy         --               lg
Lk2          192.168.2.1            Active       --               lg
Lk3          Dialer0                Inactive     --               lg
# 显示链路lk的详细信息。
<Sysname> display loadbalance link name lk
Link: lk
  Description: lk
  State: Busy
  VPN instance: --
  Inherit VPN: Disabled
  Router IP: 1.2.3.4
  Router IPv6: --
  Link-group: lg
  Weight: 100
  Priority: 4
  Cost: 0
  Slow-shutdown: Disabled
  Connection limit: 0
  Rate limit:
    Connections: 10000
    Bandwidth: 10000 kbps
    Inbound bandwidth: 5000 kbps
    Outbound bandwidth: 5000 kbps
  Bandwidth busy:
    Max bandwidth: 10000 kbps
    Max inbound bandwidth: 5000 kbps
    Max outbound bandwidth: 5000 kbps
    Busy rate: 80
    Inbound busy rate: 70
    Outbound busy rate: 60
    Busy recovery rate: 60
    Inbound busy recovery rate: 60
    Outbound busy recovery rate: 60
  Probe information:
    Probe success criteria: All
    Probe method                    State
    t4                              Inactive
  Reference count: 1
Link: lk2
  Description: link2
  State: Inactive
  VPN instance: --
  IPv4 address state: Active
  IPv6 address state: Inactive
  Router interface:Dialer0
  Link group: lg
  Weight: 150
  Priority: 3
  Cost: 100
  Slow shutdown: Enabled
  Connection limit: 10000
  Rate limit:
    Connections: 10000
  Bandwidth busy:
    Busy rate: 80
Probe information:
  Probe method      State
  t4                Inactive
  Reference count: 1
表1-6 display loadbalance link命令显示信息描述表
Link
链路的名称
Router IP/Interface
链路的网关IP地址/链路对应的出接口
Parent state/State
Parent state表示链路的状态,包括:
·     Active:可用
·     Busy:繁忙
·     Inactive:不可用(由于配置不完全、未被引用或虚服务器尚未开启)
·     Probe-failed:健康检测失败
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
·     Unknown:未配置健康检测
VPN instance
链路所属VPN实例的来源,包括
·     Config:手动配置
·     Inherit:继承
Link group
链路所属链路组的名称
链路的描述信息
Inherit VPN
链路所属VPN实例继承功能的状态,包括:
·     Enabled:开启
·     Disabled:关闭
IPv4 address state
链路的IPv4地址状态,包括:
·     Active:可用,即链路对应的出接口已获取到可用的IPv4地址
·     Inactive:不可用,即链路对应的出接口未获取到可用的IPv4地址
仅当配置了链路对应的出接口时,才会显示本字段
IPv6 address state
链路的IPv6地址状态,包括:
·     Active:可用,即链路对应的出接口已获取到可用的IPv6地址
·     Inactive:不可用,即链路对应的出接口未获取到可用的IPv6地址
·     仅当配置了链路对应的出接口时,才会显示本字段
Router IP
链路的网关IPv4地址
Router IPv6
链路的网关IPv6地址
Router interface
链路对应的出接口
Weight
链路的权值
Priority
链路在所属链路组内的优先级
Cost
就近性计算的链路成本
Slow shutdown
链路的慢宕的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Connection limit
链路所允许的最大连接数
Connection rate limit
链路所允许的最大连接速率
Rate limit
链路的速率限制
Connections
链路所允许的最大连接速率
Bandwidth
链路所允许的最大总带宽,单位为kbps
Inbound bandwidth
链路所允许的最大入带宽,单位为kbps
Outbound bandwidth
链路所允许的最大出带宽,单位为kbps
Bandwidth busy
带宽繁忙比例
Max bandwidth
带宽繁忙阈值所允许的最大总带宽,单位为kbps
带宽繁忙阈值所允许的最大入带宽,单位为kbps
带宽繁忙阈值所允许的最大出带宽,单位为kbps
Busy rate
链路的总带宽繁忙比例
Inbound busy rate
链路的入带宽繁忙比例
Outbound busy rate
链路的出带宽繁忙比例
Busy recovery rate
链路的总带宽繁忙恢复比例
入方向链路带宽繁忙恢复比例
出方向链路带宽繁忙恢复比例
Probe information
链路健康检测的详细信息
链路健康检测的成功条件:
·     All:只有全部方法都通过检测才认为健康检测成功
·     At-least:健康检测成功所需通过检测的最少方法数
Probe method
健康检测方法所使用的NQA模板名称
健康检测方法的状态,包括:
·     Failed:健康检测失败
·     In progress:正在进行健康检测
·     Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者实服务器不可用
·     Succeeded:健康检测成功
·     Undetected:由于NQA健康检测速率限制,NQA健康检测未启动
Reference count
被引用次数
display loadbalance link link-group命令用来显示链路组成员的信息。
display loadbalance link link-group link-group-name [ name link-name ]
context-admin
context-operator
link-group link-group-name:显示指定链路组下链路组成员的信息。link-group-name为链路组的名称,为1~255个字符的字符串,不区分大小写。
name link-name:显示指定名称的链路组成员的信息。link-name表示链路组成员的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示指定链路组下所有链路组成员的信息。
工作机制
如果未指定任何参数,则表示显示所有链路组成员的详细信息。
注意事项
非缺省vSystem不支持本命令。
# 显示链路组lg下所有链路组成员的信息。
<Sysname> display loadbalance link link-group lg
Link group: lg
  Link: lk1
    Description: link 1
    Parent state: Inactive
    State: Inactive
    Weight: 2
    Priority: 2
    Slow shutdown: Disabled
    Connection limit: --
    Connection rate limit: --
    Probe information:
      Probe method                       State        InstanceID(IPv4/IPv6)
      icmp                               Failed       1/2
  Link: lk2
    Description: link 2
    State: Inactive
    Weight: 100
    Priority: 4
    Probe information:
      tcp                                Failed       3/4
表1-7 display loadbalance link-group命令显示信息描述表
Link
链路的名称
Router IP/Interface
链路的网关IP地址/链路对应的出接口
Parent state/State
·     Active:可用
·     Busy:繁忙
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
·     Unknown:未配置健康检测
VPN instance
链路所属VPN实例的来源,包括
·     Config:手动配置
·     Inherit:继承
Link group
链路所属链路组的名称
链路的描述信息
Inherit VPN
·     Enabled:开启
·     Disabled:关闭
IPv4 address state
链路的IPv4地址状态,包括:
IPv6 address state
链路的IPv6地址状态,包括:
Router IP
链路的网关IPv4地址
Router IPv6
链路的网关IPv6地址
Router interface
链路对应的出接口
Weight
链路的权值
Priority
链路在所属链路组内的优先级
Cost
就近性计算的链路成本
Slow shutdown
链路的慢宕的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Connection limit
链路所允许的最大连接数
链路所允许的最大连接速率
Rate limit
链路的速率限制
Connections
链路所允许的最大连接速率
Bandwidth
链路所允许的最大总带宽,单位为kbps
Inbound bandwidth
链路所允许的最大入带宽,单位为kbps
Outbound bandwidth
链路所允许的最大出带宽,单位为kbps
Bandwidth busy
带宽繁忙比例
Max bandwidth
Busy rate
链路的总带宽繁忙比例
Inbound busy rate
链路的入带宽繁忙比例
Outbound busy rate
链路的出带宽繁忙比例
Busy recovery rate
链路的总带宽繁忙恢复比例
入方向链路带宽繁忙恢复比例
出方向链路带宽繁忙恢复比例
Probe information
链路健康检测的详细信息
链路健康检测的成功条件:
Probe method
健康检测方法所使用的NQA模板名称
Bandwidth detection upon link probe failure
链路健康检测失败后触发带宽检测功能状态,包括:
·     Disabled:关闭
·     Enabled:开启
Bandwidth threshold
触发带宽检测的阈值,单位为kbps
健康检测方法的状态,包括:
·     Failed:健康检测失败
·     Succeeded:健康检测成功
健康检测实例ID(探测IPv4/IPv6地址)
Reference count
被引用次数
display loadbalance link out-interface statistics显示链路出接口的统计信息。
display loadbalance link out-interface statistics [ name link-name ]
context-admin
context-operator
name link-name:显示指定链路出接口的统计信息。link-name为链路的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有链路出接口的统计信息。
工作机制
当链路出接口为逻辑口时,速率统计信息是利用接口流量自行计算得出。
注意事项
非缺省vSystem不支持本命令。
# 显示链路lk1的出接口统计信息。
<Sysname> display loadbalance link out-interface statistics name lk1
Loadbalance link: lk1
  Input rate: 1524 bps
  Output rate: 90 bps
表1-8 display loadbalance out-interface link statistics命令显示信息描述表
Loadbalance link
链路的名称
Input rate
链路出接口入方向速率,单位为bps
Output rate
链路出接口出方向速率,单位为bps
display loadbalance link statistics显示链路的统计信息。
display loadbalance link statistics [ name link-name ] [ slot slot-number ]
context-admin
context-operator
name link-name:显示指定链路的统计信息。link-name为链路名称,长度为1~255个字符的字符串,不区分大小写。
slot slot-number:显示指定成员设备上的链路统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的链路统计信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 显示链路lk1的统计信息。
<Sysname> display loadbalance link statistics name lk1
  Total connections: 1798
  Active connections: 788
  Max connections: 803
    recorded at 11:02:49 on Tue May 21 2019
  Connections per second: 157
  Max connections per second: 163
  Downstream traffic: 333332 bytes
  Upstream traffic: 472054 bytes
  Throughput: 4396 bps
  Inbound throughput: 1214 bps
  Outbound throughput: 3128 bps
  Max throughput: 4564 bps
  Max inbound throughput: 1214 bps
  Max outbound throughput: 3320 bps
  Received packets: 1798
  Sent packets: 0
  Dropped packets: 0
  Received packets per second: 0
  Sent packets per second: 0
  Packet loss rate: 10
表1-9 display loadbalance link statistics命令显示信息描述表
Loadbalance link
链路的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Downstream traffic
链路的下行流量,LB设备收到的流量,单位为字节
Upstream traffic
链路的上行流量,LB设备发送的流量,单位为字节
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
Received packets
收到的报文数
Sent packets
发出的报文数
Dropped packets
丢弃的报文数
每秒收到的报文数
每秒发出的报文数
Packet loss rate
链路的丢包率
display loadbalance link statistics link-group显示链路组成员的统计信息。
display loadbalance link statistics link-group link-group-name [ name link-name ] [ slot slot-number ]
context-admin
context-operator
link-group link-group-name:显示指定链路组下链路组成员的统计信息。link-group-name表示链路组的名称,为1~255个字符的字符串,不区分大小写。
name link-name:显示指定名称的链路组成员的统计信息。link-name表示链路组成员的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示指定链路组下所有链路组成员的统计信息。
非缺省vSystem不支持本命令。
# 显示链路组lg下所有链路组成员的统计信息。
<Sysname> display loadbalance link statistics link-group lg
Loadbalance link group: lg
    Total connections: 0
    Active connections: 0
    Max connections: 0
    Connections per second: 0
    Max connections per second: 0
    Downstream traffic: 0 bytes
    Upstream traffic: 0 bytes
    Throughput: 0 bps
    Inbound throughput: 0 bps
    Outbound throughput: 0 bps
    Max throughput: 0 bps
    Max inbound throughput: 0 bps
    Max outbound throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
  Loadbalance link: lk2
    Max connections: 0
    Throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
表1-10 display loadbalance link statistics link-group命令显示信息描述表
Loadbalance link
链路的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Downstream traffic
Upstream traffic
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
Received packets
收到的报文数
Sent packets
发出的报文数
Dropped packets
丢弃的报文数
每秒收到的报文数
每秒发出的报文数
Packet loss rate
链路的丢包率
display loadbalance link-group命令用来显示链路组的信息。
display loadbalance link-group [ brief | name link-group-name ]
context-admin
context-operator
brief:显示所有链路组的简要信息。如果未指定本参数,将显示链路组的详细信息。
name link-group-name:显示指定链路组的信息。link-group-name为链路组的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有链路组的信息。
工作机制
如果链路组配置不完整,链路组未被引用或虚服务未开启,则链路状态将显示为不可用,但并不代表该链路本身不可用。
注意事项
非缺省vSystem不支持本命令。
# 显示所有链路组的简要信息。
<Sysname> display loadbalance link-group brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           BW – Bandwidth, MBW – Max bandwidth,
           IBW – Inbound bandwidth, OBW – Outbound bandwidth,
           MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port
NAT/SNAT: Y - Enabled, N - Disabled
Link group       Predictor    NAT   SNAT  Total  Active
lg               RR           Y     N     3      3
# 显示所有链路组的详细信息。
Link group: lg1
  Description:
  Predictor: Hash address
  Proximity: Disabled
  NAT: Enabled
  SNAT pool:
  Failed action: Keep
  Active threshold: Enabled
    Lower: 80
    Upper: 90
  Slow-online: Enabled
  Standby time: 5s
  Ramp-up time: 10s
  Selected link: Enabled
    Min link: 100
    Max link: 600
  Probe information:
    Probe method:
    aaa
    ddd
  Total link: 1
  Active link: 1
  Reference count: 3
  Link list:
  Name             State         VPN instance    Router IP/Interface  Weight    Priority
  Link1            Inactive                      1.2.3.4              4         100
表1-11 display loadbalance link-group命令显示信息描述表
Link group
链路组的名称
链路组的描述信息
Predictor
链路组的调度算法,包括:
·     Round robin:加权轮转算法
·     Random:随机算法
·     Least connection:加权最小连接算法
·     Bandwidth:总带宽算法
·     Inbound bandwidth:入方向带宽算法
·     Outbound bandwidth:出方向带宽算法
·     Max bandwidth:最大总带宽算法
·     Max inbound bandwidth:最大入方向带宽算法
·     Max outbound bandwidth:最大出方向带宽算法
·     Hash address source IP:根据源IP地址进行的哈希算法
·     Hash address source IP-port:根据源IP地址和端口号进行的哈希算法
·     Hash address destination IP:根据目的IP地址进行的哈希算法
Proximity
链路组中就近性功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
NAT
链路组中NAT功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
SNAT pool
链路组引用的SNAT地址池名称
Failed action
链路组的故障处理方式,包括:
·     Keep:保持已有连接
·     Reschedule:重定向连接
·     Reset:断开已有连接
Active threshold
链路组可用条件的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Lower:最小可用百分比
·     Upper:最大可用百分比
Slow-online
链路组中链路温暖上线功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Standby time:准备时间
·     Ramp-up time:爬升时间
Selected link
链路组中可被调度算法调用的链路数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Min link:可被调度算法调用的链路最小数量
·     Max link:可被调度算法调用的链路最大数量
链路组健康检测的成功条件:
·     At least X:健康检测成功所需通过检测的最少方法数为X
Probe method
链路组健康检测方法所使用的NQA模板名称
Total link
包含的链路数量
Active link
活跃的链路数量
Reference count
被引用次数
Link list
链路列表
Name
链路的名称
链路的状态,包括:
·     Active:可用
·     Busy:繁忙(当链路处于Active或Ramp状态,且开启接口获取带宽功能和繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
VPN instance
链路所属的VPN实例
Router IP/Interface
链路的网关IP地址/链路对应的出接口
Weight
链路的权值
Priority
链路的调用优先级
display loadbalance policy命令用来显示负载均衡策略的信息。
display loadbalance policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name policy-name:显示指定负载均衡策略的信息。policy-name为负载均衡策略的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡策略的信息。
# 显示所有负载均衡策略的信息。
<Sysname> display loadbalance policy
LB policy: lbp1
  Description:
  Type: Generic
  Class: lbc1
   Action: lba1
   Status: Enabled
  Default class action: lba0
  Reference count: 1
LB policy: lbp2
  Description:
  Type: HTTP
  Default action:
  Reference count: 1
LB policy: lbp3
  Description:
  Type: Link-generic
  Class: lbc3
   Action: lba3
   Status: Disabled
  Default class action: lba3
  Reference count: 1
LB policy: lbp4
  Description:
  Type: DNS
  Class: lbc4
   Action: lba4
   Status: Enabled
  Default class action: lba4
  Reference count: 1
LB policy: lbp5
  Description:
  Type: MySQL
  Class: lbc5
   Action: lba5
   Status: Enabled
  Default class action: lba5
  Reference count: 1
LB policy: lbp6
  Description:
  Type: Diameter
  Class: lbc6
   Action: lba6
   Status: Enabled
  Default class action: lbc1
  Reference count: 1
表1-12 display loadbalance policy命令显示信息描述表
LB policy
负载均衡策略的名称
负载均衡策略的描述信息
负载均衡策略的类型,包括:
·     DNS:表示DNS类型
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
·     MySQL:表示MySQL类型
·     RADIUS:表示RADIUS类型
Class
负载均衡策略包含的负载均衡类
Action
负载均衡类对应的负载均衡动作
Status
负载均衡策略中负载均衡类的状态,包括:
·     Disabled:禁用
·     Enabled:启用
缺省的负载均衡动作
Reference count
被引用次数
display loadbalance probe failed-record命令用来显示健康检测失败的历史记录。
display loadbalance probe failed-record { real-server | link } [ name name ]
context-admin
context-operator
vsys-admin
vsys-operator
real-server:显示实服务器的健康检测失败记录。
link:显示链路的健康检测失败记录。
name name:显示指定名称实服务器或链路的健康检测失败历史记录。name为实服务器或链路的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器或链路的健康检测失败的历史记录。
查看实服务器健康检测失败的历史记录前,需要通过loadbalance probe failed-record enable命令开启健康检测失败信息的记录功能。
# 显示所有实服务器的健康检测失败信息。
<Sysname> display loadbalance probe failed-record real-server
Template               Server farm    Real server          Address family   Port   Template type   Reason        Failure time
t1                     sf2            rs                   IPv4              30     arp            TimeOut       2023-06-25 17:14:39
t1                     sf1            rs                   IPv6              20     arp           TimeOut        2023-06-25 17:14:39
t1                     -              rs                   IPv4              -      arp            TimeOut       2023-06-25 17:14:38
t1                     -              rs                   IPv6              10     arp            TimeOut       2023-06-25 17:14:37
# 显示所有链路的健康检测失败信息。
<Sysname> display loadbalance probe failed-record link
Template               Link group    Link                 Address family    Template type     Reason         Failure time
t1                     lg            lk                   IPv4              arp               TimeOut        2023-06-25 17:14:39
t1                     lg            lk                   IPv6              arp               TimeOut        2023-06-25 17:14:39
t1                     -             lk                   IPv4              arp               TimeOut        2023-06-25 17:14:38
t1                     -             lk                   IPv6              arp               TimeOut        2023-06-25 17:14:37
表1-13 display virtual-server命令显示信息描述表
Template
健康检测模板的名称
Server farm
健康检测失败的实服务组名称,如果是实服务器,显示为“-”
Real server
实服务器或实服务组成员的名称
Link group
健康检测失败的链路组名称,如果是链路,显示为“-”
Link
链路或链路组成员的名称
Address family
实服务器或链路所属地址族类型,包括IPv4和IPv6,负载均衡自定义探测模板不区分地址族类型,显示为” - ”
Port
实服务器的端口号,” - ”表示使用NQA的端口号
Template type
健康检测模板的类型
Reason
健康检测失败的原因,包括:
·     Timeout:请求超时导致检测失败
·     No Route:没有路由导致检测失败
·     Internal error:内部错误导致检测失败
·     Verify error:校验错误导致检测失败
·     Disconnect:对方强制断开连接导致检测失败
·     No connection:和对方建立连接失败
·     Expect Status error:预期状态错误导致检测失败
·     Other errors:其他错误导致检测失败
Failure time
健康检测失败的时间,按由近到远排序
·     loadbalance probe failed-record enable
·     loadbalance probe failed-record max-number
·     reset loadbalance probe failed-record
display loadbalance probe undetected命令用来显示由于NQA健康检测速率限制而未启动的健康检测任务信息。
display loadbalance probe undetected { dns-server | link | real-server }
context-admin
vsys-admin
dns-server:显示DNS服务器下未启动的NQA健康检测任务信息。
link:显示链路下未启动的NQA健康检测任务信息。
real-server:显示实服务器下未启动的NQA健康检测任务信息。
仅在开启NQA健康检测速率限制功能的情况下,存在因超出速率限制而未能启动的NQA健康检测任务时,系统才会显示相关内容。
# 显示实服务器下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected real-server
Real server: rs
Port: 20
Server farm: sf1
NQA template: t1
Probe type: IPv6
Record time: 2023-06-25 17:14:39
Real server: rs
Port: 20
Server farm: -
NQA template: t2
Probe type: IPv4
Record time: 2023-06-25 17:14:40
# 显示链路下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected link
Link: LK1Link group: lg
NQA template: t3
Probe type: IPv4
Record time: 2023-06-25 17:14:41
Link: LK2
Link group: -
NQA template: t
Probe type: IPv4
Record time: 2023-06-25 17:14:46
# 显示DNS服务器下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected dns-server
DNS server: dns1
Port:2
DNS server pool: dnspool1
NQA template: t
Probe type:IPv4
Record time: 2023-06-25 17:14:42
DNS server: dns2
Port: -
DNS server pool: -
NQA template: t7
Probe type: IPv4
Record time: 2023-06-25 17:14:43
表1-14 display loadbalance probe undetected命令显示信息描述表
Real server
实服务器或实服务组成员的名称
Server farm
未启动NQA健康检测的实服务组名称,如果是实服务器,显示为“-”
Link group
未启动NQA健康检测的链路组名称,如果是链路,显示为“-”
Link
链路或链路组成员的名称
DNS server
DNS服务器或DNS服务池成员的名称
DNS server pool
未启动NQA健康检测的DNS服务池的名称,如果是DNS服务器,显示为“-”
Port
NQA探测任务使用的探测端口,“-”表示使用探测模板配置的端口号探测
NQA template
NQA健康检测模板的名称
Probe type
健康检测类型,包括IPv4、IPv6、Interface
Record time
加入等待启动队列的时间
display loadbalance proximity命令用来显示就近性表项的信息。
display loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ traffic-group traffic-group-id ] [ slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name:指定VPN实例中就近性表项的信息。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网实例中就近性表项的信息。
ip [ ipv4-address ]:显示IPv4就近性表项的信息。如果指定了ipv4-address参数,将显示指定IPv4地址所对应就近性表项的详细信息;如果未指定ipv4-address参数,将显示所有IPv4就近性表项的简要信息。
ipv6 [ ipv6-address ]:显示IPv6就近性表项的信息。如果指定了ipv6-address参数,将显示指定IPv6地址所对应就近性表项的详细信息;如果未指定ipv6-address参数,将显示所有IPv6就近性表项的简要信息。
traffic-group traffic-group-id:显示指定集群流量组的就近性表项信息。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示显示所有集群流量组的就近性表项信息。
工作机制
如果未指定vpn-instance、ip和ipv6关键字,将显示所有IPv4和IPv6就近性表项的简要信息。
注意事项
非缺省vSystem不支持本命令。
# 显示公网实例中所有IPv4和IPv6就近性表项的简要信息。
<Sysname> display loadbalance proximity
(*) – Real server object
Slot :1
  IPv4 address/Mask length       Timeout     Best link  RTT      Dynamic weight
  1.2.3.0/24                     59          lk1        1        170
  1.2.15.0/24                    58          lk2        2        170
  IPv6 address/Prefix length     Timeout     Best link  RTT      Dynamic weight
  11:22::/96                     40          lk1        3        200
# 显示公网实例中,IP地址为1.2.3.1的IPv4就近性表项的详细信息。
<Sysname> display loadbalance proximity ip 1.2.3.1
IPv4 address/Mask length: 1.2.3.0/24
Timeout: 40
Link list/RTT:
  lk1/1
  lk2/3
# 显示公网实例中,IPv6地址为11:22::的IPv6就近性表项的详细信息。
<Sysname> display loadbalance proximity ipv6 11:22::
IPv6 address/Prefix length: 11:22::/96
Timeout: 34
Link list/RTT:
  lk1/2
  lk2/3
表1-15 display loadbalance proximity命令显示信息描述表
(*)表示该链路对应对象是实服务器而非链路
就近性表项的IPv4地址和掩码长度
就近性表项的IPv6地址和前缀长度
Timeout
就近性表项的剩余老化时间,单位为秒
Best link
就近性表项的最优链路
Link list
就近性表项的所有链路列表,优先级依次降低
RTT
就近性链路的网络延迟,单位为毫秒
display parameter-profile命令用来显示参数模板的信息。
display parameter-profile [ name parameter-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name parameter-name:显示指定参数模板的信息。parameter-name为参数模板的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有参数模板的信息。
# 显示所有参数模板的信息。
<Sysname> display parameter-profile
Parameter profile: pp1
  Description:
  Type: IP
  IP ToS: 20
  Reference count: 0
Parameter profile: pp2
  Description:
  Type: TCP
  Exceed MSS: Allow
  TCP window size: 65535
  TCP connection idle-timeout: 10
  Time-wait timeout: 5
  Keepalive idle-timeout: 300
  Keepalive retransmission interval: 3
  Keepalive retransmission count: 5
  Syn retransmission-timeout: 5
  Syn cookie threshold: 10
  Fin-wait1 timeout: 6
  Fin-wait2 timeout: 10
  Src-addr-option:
    Option kind number: 29 (TCP-AO)
    Encoding: string
  TCP option remove:
    Option kind number: 3 (WSopt)
  TCP option remove:
    Option kind number: 5 (SACK)
  TCP option insert-mode: data-packet
  TCP option insert:
    Option kind number:28 (UTO)
    Value: src-ip
    Encoding: string
  TCP option preserve:
    Option kind number: 8 (TSopt)
  TCP Timestamps option: Preserve
  Reference count: 1
Parameter profile: pp3
  Description:
  Type: HTTP
  Rebalance per request: Enabled
  Server connection reuse: Enabled
  Case insensitive: Enabled
  Header modify per request: Enabled
  Content maximum parse length: 8192
  Header maximum parse length: 8192
  Secondary cookie delimiters: !@#$
  Secondary cookie start: ?
  Encrypted cookie name: cookie1
  Header exceed length: Drop
  Reference count: 1
Parameter profile: compress
  Description:
  Type: HTTP compression
  Compression level: 1
  Prefer method: Gzip
  Content length threshold: 1024
  Memory size: 8KB
  Window size: 16KB
  Header Insert: Enabled
  Header Delete: Enabled
  Request version all: Disabled
  Rule 1: Permit url abc
  Reference count: 1
Parameter profile: urlstat
  Description:
  Type: HTTP-statistics
  Node: bank1
    Description:
    rule 1 url url1
    rule 2 url url2
  Node: bank2
    Description:
    rule 1 url url3
    rule 2 url url4
  Object group name:
    ObjGrp1
    ObjGrp2
  Reference count: 1
Parameter profile: pp4
  Description:
  Type: OneConnect
  Max reuse times: 1000
  Idle time: 10000
  IPv4 source mask length: 24
  IPv6 source prefix length: 120
  Reference count: 1
Parameter profile: pp5
  Description:
  Type: TCP-application
  Match-buffer-time: 5
  Match-buffer-size: 4096
  Match-buffer-end: YY
  Reference count: 1
Parameter profile: pp6
  Description:
  Type: MySQL
  Pool size: 2000
  Idle time: 10000 sec
  Reference count: 1
  Description:
  Type: HTTP2
  Concurrent-streams-per-connection: 123
  Recv-window size: 32
  Connection idle-timeout: 300
  Frame size: 1531
  Header-table size: 53241
  Insert-header-field: hx
  Connection close fin
  Reference count: 1
Parameter profile: pp7
  Description:
  Type: Diameter-session
  Origin host: host.example.com
  Origin realm: example.com
  Vendor Id: 25506
  Product name: L5080
  Host ip: 20.0.0.2
  Retransmission: Enabled
  Retransmission timeout: 5
  CE timeout: 20
  Reference count: 1
表1-16 display parameter-profile命令显示信息描述表
Parameter profile
参数模板的名称
参数模板的描述信息
参数模板的类型,包括:
·     IP:表示IP类型
·     HTTP:表示HTTP类型
·     HTTP compression:表示HTTP压缩类型
·     HTTP-statistics:表示HTTP统计类型
·     MySQL:表示MySQL类型
·     OneConnect:表示OneConnect类型
·     TCP:表示TCP类型
·     TCP-application:表示TCP-application类型
·     HTTP2:表示HTTP2.0类型
·     Diameter-session:表示Diameter-session类型
IP ToS
发往服务器的IP报文中的ToS字段
Reference count
被引用次数
Exceed MSS
对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式,包括:
·     Allow:表示允许超出MSS的数据段
·     Drop:表示丢弃超出MSS的数据段
是否开启对每个HTTP请求报文都进行负载均衡的功能,包括:
·     Disabled:关闭
·     Enabled:开启
Pool size
MySQL连接池的大小
是否开启允许负载均衡设备与服务器的连接复用的功能,包括:
·     Disabled:关闭
·     Enabled:开启
是否开启对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作的功能,包括:
·     Disabled:关闭
·     Enabled:开启
Case insensitive
是否开启匹配字符串时对大小写不敏感的功能,包括:
·     Disabled:关闭
·     Enabled:开启
HTTP实体的最大解析长度
HTTP首部的最大解析长度
URL中分隔Secondary Cookie的字符
URL中Secondary Cookie的起始位置标示字符
开启了Cookie加密功能的Cookie名称
当HTTP请求或应答报文首部超出最大长度时的处理方式,包括:
·     Continue:表示继续执行负载均衡操作
·     Drop:表示停止执行负载均衡操作,丢弃该报文并关闭连接
TCP window size
TCP连接中的本地最大窗口值
TCP连接的空闲超时时间,单位为秒
Time-wait timeout
TCP TIME-WAIT状态的超时时间,单位为秒
TCP保活定时器的空闲超时时间,单位为秒
TCP保活报文的重传时间间隔,单位为秒
TCP保活报文的重传次数
TCP SYN报文的重传超时时间,单位为秒
触发SYN Cookie保护功能的门限值,0表示不会触发
Fin-wait1 timeout
TCP FIN-WAIT-1状态的超时时间,单位为秒
Fin-wait2 timeout
TCP FIN-WAIT-2状态的超时时间,单位为秒
Node
统计节点的名称及统计节点视图下配置的所有URL统计匹配规则
Object group name
HTTP统计类型的参数模板引用的IP地址对象组
Max reuse times
TCP连接的最大复用数目
Idle time
TCP连接的空闲超时时间,单位为秒
TCP连接复用客户端的IPv4源地址掩码长度
TCP连接复用客户端的IPv6源地址前缀长度
Match-buffer-time
TCP载荷匹配的缓冲时间,单位为秒
Match-buffer-size
TCP载荷匹配的缓冲数据大小
Match-buffer-end
TCP载荷匹配的缓冲结束符
Src-addr-option
进行SNAT地址转换的TCP Option
Option kind number
TCP选项类型编号
Encoding
TCP Option的编码方式,包括:
·     binary:二进制编码
·     string:字符串编码
TCP选项插入模式,包括:
·     per-packet:插入数据报文以及握手阶段的报文
·     data-packet:只插入数据报文
TCP option insert
在TCP选项中插入内容
Value
插入TCP选项的内容
TCP option remove
清除TCP选项
一条TCP连接的最大并发请求
Recv-window size
HTTP2.0报文使用的接收窗口大小
HTTP2.0请求报文TCP连接的空闲超时时间
Frame size
HTTP2.0报文连接帧大小
Header-table size
HTTP2.0报文头部表大小
Insert-header-field
HTTP2.0请求报文中插入的头部字段
Connection close fin/Connection close rst
关闭设备与实服务器TCP连接方式,包括:
·     fin:表示发送FIN报文方式关闭连接
·     rst:表示发送RST报文方式关闭连接
TCP option preserve
保持TCP选项
TCP option rewrite
重写TCP选项
全局TCP时间戳生效动作,包括:
·     Preserve:保持
·     Rewrite:重写
·     Remove:删除
当动作后有(*)时,表示全局TCP时间戳选项的配置生效,否则表示参数模板下配置的TCP时间戳选项生效
Origin host
源主机名
Origin realm
源域名
Vendor Id
厂商ID
Product name
产品名称
Host ip/Host ipv6
主机IPv4地址或IPv6地址
Retransmission
是否开启Diameter数据报文重传功能,包括:
·     Disabled:关闭
·     Enabled:开启
Diameter数据报文重传超时时间
CE timeout
Diameter协商超时时间
display sticky virtual-server命令用来显示虚服务器的会话保持表项信息。
display sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | client-port port-number | sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ traffic-group traffic-group-id ] [ brief ] [ slot slot-number ]
context-admin
context-operator
virtual-server-name virtual-server-name:显示指定虚服务器的会话保持表项信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定virtual-server-name,将显示所有虚服务器的会话保持表项信息。
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }:显示指定链路的会话保持表项信息。ip ipv4-address表示链路的IPv4地址,ipv6 ipv6-address表示链路的IPv6地址,interface interface-type interface-number表示链路对应的出接口,interface-type为接口类型,interface-number为接口编号,interface-name为接口名称。
link-group link-group-name:显示指定链路组的会话保持表项信息。link-group-name为链路组的名称,为1~255个字符的字符串,不区分大小写。
real-server-addr { ipv4-address | ipv6-address }:显示指定实服务器地址的会话保持表项信息。ipv4-address表示实服务器的IPv4地址,ipv6-address表示实服务器的IPv6地址。
real-server-port port-number:显示指定实服务器端口的会话保持表项信息。port-number为实服务器的端口号,取值范围0~65535。
server-farm server-farm-name:显示指定实服务组的会话保持表项信息。server-farm-name为实服务组的名称,为1~255个字符的字符串,不区分大小写。
text text:显示指定匹配内容的会话保持表项信息。text为会话保持表项的匹配内容,为1~63个字符的字符串,区分大小写。
class { class-name | default-class }:显示指定负载均衡类的会话保持表项信息。class-name为负载均衡类的名称,为1~255个字符的字符串,不区分大小写。default-class表示缺省负载均衡类。
client-addr { ipv4-address | ipv6-address }:显示指定客户端地址的会话保持表项信息。ipv4-address表示客户端的IPv4地址,ipv6-address表示客户端的IPv6地址。
client-port port-number:显示指定客户端端口的会话保持表项信息。port-number为客户端的端口号,取值范围0~65535。
sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }:显示指定类型会话保持组的会话保持表项信息,包括Diameter、地址端口、HTTP实体、HTTP Cookie、HTTP首部、HTTP passive、HTTP/UDP载荷、RADIUS、SIP、SSL、TCP载荷和UDP passive。
key sticky-key:显示指定Key值的会话保持表项。sticky-key为会话保持表项的Key值,为1~127个字符的字符串,区分大小写。若未指定本参数,则表示显示所有Key值的会话保持表项。
traffic-group traffic-group-id:显示指定集群流量组的会话保持表项。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示显示所有集群流量组的会话保持表项。
brief:显示虚服务器会话保持表项的简要信息。如果未指定本参数,将显示虚服务器会话保持表项的详细信息。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 显示所有虚服务器会话保持表项的详细信息。
<Sysname> display sticky virtual-server
  Virtual server name: vs
  Server farm name: sf
  Class: cla
  Sticky type: Address-port
  Sticky method: Source IP
  Sticky key: 3.0.0.13
  Virtual server addr: 33.44.1.1:80
  Real server addr: 7.0.0.7:80
  Client addr: 3.0.0.13
  Timeout: 100 sec
  Expiration time: 58 sec
  Matching sessions: 1
  Virtual server name: vs1
  Server farm name: sf_http
  Class: Default Class
  Sticky type: HTTP header
  Sticky method: HTTP header name
  Sticky key: cb3bae31bb1c443fbf3db8889055f2fe
  Text: a1b2c3d4e5
  Virtual server addr: 33.44.1.2:80
  Timeout: 100 sec
  Virtual server name: vs2
  Link group name: lg
  Class: cl2
  Sticky key: 3.0.0.15
  Virtual server addr: 0.0.0.0:0
  link: 20.1.1.1
  Client addr: 3.0.0.15
  Timeout: 100 sec
# 显示所有虚服务器会话保持表项的简要信息。
<Sysname> display sticky virtual-server brief
Sticky type    Sticky method    Sticky key      Virtual server      Real-server/link
Address-port   Src IP           3.0.0.13        vs                  7.0.0.7:80
Address-port   Src IP           3.0.0.15        vs2                 20.1.1.1
表1-17 display sticky virtual-server命令显示信息描述表
Virtual server name
虚服务器名称
集群流量组的编号
Server farm name
实服务组名称
Sticky group name
生成该会话保持表项的会话保持组名称
Sticky type
会话保持组的类型,包括:
·     Address-port:表示地址端口类型
·     HTTP content:表示HTTP实体类型
·     HTTP cookie:表示HTTP Cookie类型
·     HTTP header:表示HTTP首部类型
·     HTTP passive:表示HTTP Passive类型
·     Payload:表示HTTP载荷或UDP载荷类型
·     RADIUS:表示RADIUS类型
·     SIP:表示SIP类型
·     SSL:表示SSL类型
·     TCP payload:表示TCP载荷类型
·     UDP passive:表示UDP Passive类型
Sticky method
该会话保持表项对应的会话保持方法,包括:
·     Src IP:源IPv4地址会话保持方法
·     Src IPv6:源IPv6地址会话保持方法
·     Src IP port:源IPv4地址+源端口会话保持方法
·     Src IPv6 port:源IPv6地址+源端口会话保持方法
·     Dst IP:目的IPv4地址会话保持方法
·     Dst IPv6:目的IPv6地址会话保持方法
·     Dst IP port:目的IPv4地址+目的端口会话保持方法
·     Dst IPv6 port:目的IPv6地址+目的端口会话保持方法
·     Both IP:源IPv4地址+目的IPv4地址会话保持方法
·     Both IPv6:源IPv6地址+目的IPv6地址会话保持方法
·     Both IP port:源IPv4地址+源端口+目的IPv4地址+目的端口会话保持方法
·     Both IPv6 port:源IPv6地址+源端口+目的IPv6地址+目的端口会话保持方法
·     HTTP URL:基于HTTP URL的会话保持方法
·     Header name:基于HTTP首部名称的会话保持方法
·     HTTP version:基于HTTP版本的会话保持方法
·     HTTP host:基于HTTP主机的会话保持方法
·     HTTP method:基于HTTP Request-Method的会话保持方法
·     HTTP content:HTTP实体会话保持方法
·     Cookie get:HTTP Cookie截取会话保持方法
·     Payload:HTTP载荷或UDP载荷会话保持方法
·     HTTP passive:HTTP被动会话保持方法
·     Payload passive:UDP载荷被动会话保持方法
·     TCP payload:TCP载荷会话保持方法
·     Framed-IP-Address:基于RADIUS报文Framed-IP-Address属性的会话保持方法
·     User-Name:基于RADIUS报文中User-Name属性的会话保持方法
·     Code=attribute-code:基于RADIUS报文中指定属性的会话保持方法,属性编号为attribute-code
·     SIP Call-ID:基于SIP信令报文Call ID的会话保持方法
·     SSL session ID:SSL会话保持方法为基于SSL会话ID
Sticky key
会话保持表项的Key值
Text
会话保持表项的匹配内容
Virtual server addr
虚服务器地址端口
Real server addr
实服务器地址端口
Server farm name
实服务组名称
link
链路下一跳或出接口
Link group name
链路组名称
Class
负载均衡类,包括:
·     负载均衡类名称
·     Default Class:缺省负载均衡类
Client addr
客户端地址
Timeout
会话保持表项的超时时间,单位为秒,indefinite表示不老化
Expiration time
会话保持表项的老化剩余时间,单位为秒
Matching sessions
匹配该会话保持表项的会话数量
HTTP Cookie插入和重写会话保持方法对应的会话保持表项不显示本字段
display sticky-group命令用来显示会话保持组的信息。
display sticky-group [ name group-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name group-name:显示指定会话保持组的信息。group-name为会话保持组的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有会话保持组的信息。
# 显示所有会话保持组的信息。
<Sysname> display sticky-group
Sticky group: sg1
  Description:
  Timeout: 60
  Override limit: Disabled
  Stickiness-over-busyness: Enabled
  Matching across services: Enabled
  Matching across virtual servers: Enabled
  Sticky group type: Address-port
    Method: Both IP and port
      Mask: 32
  Reference count: 1
Sticky group: sg2
  Description:
  Timeout: 60
  Sticky group type: HTTP header
    Method: HTTP header name
      Offset: 4
      Start: gzip
      Length: 10
  Reference count: 1
Sticky group: sg3
  Description:
  Timeout: 60
  Sticky group type: RADIUS
    Method: User-Name
  Reference count: 1
Sticky group: sg4
  Description:
  Timeout: 86400
  Stickiness-over-busyness: Disabled
  Sticky group type: HTTP cookie
    Method: HTTP cookie insert
      Domain: example.com
      Path: /test1
      HttpOnly: Enabled
      Secure: Enabled
  Check all packets: Disabled
  Reference count: 1
Sticky group: sg5
  Description:
  Timeout: 60
  Sticky group type: Diameter
    Method: attribute-code
      Code: 263, Index: 0
      Code: 283, Index: 0
  Reference count: 1
表1-18 display sticky-group命令显示信息描述表
Sticky group
会话保持组的名称
会话保持组的描述信息
Timeout
会话保持表项的超时时间,单位为秒。Indefinite表示会话保持表项不老化
Override limit
匹配会话保持表项的会话不受连接数限制功能的状态,包括:
·     Disabled:关闭,即匹配会话保持表项的会话受连接数限制
·     Enabled:开启,即匹配会话保持表项的会话不受连接数限制
会话保持处理优先于繁忙功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
跨服务匹配会话保持表项功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
跨虚服务器匹配会话保持表项功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Sticky group type
会话保持组的类型,包括:
·     HTTP passive:表示HTTP passive类型
·     RADIUS:表示RADIUS类型
·     SIP:表示SIP类型
·     SSL:表示SSL类型
·     UDP passive:表示UDP passive类型
各类型会话保持组的具体内容,请参见表1-19
Reference count
被引用次数
表1-19 各类型会话保持组的具体内容
会话保持组类型
Address-port
·     Method:会话保持方法,包括:
¡     Source IP:源IPv4地址会话保持方法
¡     Source IPv6:源IPv6地址会话保持方法
¡     Source IP and port:源IPv4地址+源端口会话保持方法
¡     Source IPv6 and port:源IPv6地址+源端口会话保持方法
¡     Destination IP:目的IPv4地址会话保持方法
¡     Destination IPv6:目的IPv6地址会话保持方法
¡     Destination IP and port:目的IPv4地址+目的端口会话保持方法
¡     Destination IPv6 and port:目的IPv6地址+目的端口会话保持方法
¡     Both IP:源IPv4地址+目的IPv4地址会话保持方法
¡     Both IPv6:源IPv6地址+目的IPv6地址会话保持方法
¡     Both IP and port:源IPv4地址+源端口+目的IPv4地址+目的端口会话保持方法
¡     Both IPv6 and port:源IPv6地址+源端口+目的IPv6地址+目的端口会话保持方法
·     Mask:会话保持方法的掩码长度,只有IPv4会话保持方法才会显示本字段
·     Prefix:会话保持方法的前缀长度,只有IPv6会话保持方法才会显示本字段
HTTP content
·     Offset:实体基于HTTP报文起始位置的偏移量
·     Start:实体开始标记的正则表达式
·     End:实体结束标记的正则表达式,不会与Length字段同时显示
·     Length:实体的长度,不会与End字段同时显示
HTTP cookie
·     Method:会话保持方法,包括:
¡     HTTP cookie insert:Cookie截取会话保持方法
¡     HTTP cookie rewrite:Cookie重写会话保持方法
¡     HTTP cookie get:Cookie插入会话保持方法
·     Name:HTTP cookie的名称。只有指定了HTTP Cookie会话保持方法才会显示本字段
·     Domain:HTTP Cookie的作用域域名。只有指定了Cookie插入会话保持方法才会显示本字段。
·     Path:HTTP Cookie的作用路径。只有指定了Cookie插入会话保持方法才会显示本字段。
·     Offset:Cookie基于Cookie值起始位置的偏移量。只有指定了Cookie插入会话保持方法才会显示本字段
·     Start:Cookie开始标记的正则表达式。只有指定了Cookie插入会话保持方法才会显示本字段
·     End:Cookie结束标记的正则表达式,不会与Length字段同时显示。只有指定了Cookie插入会话保持方法才会显示本字段
·     Length:Cookie的长度,不会与End字段同时显示。只有指定了Cookie插入会话保持方法才会显示本字段
·     Cookie secondary name:需在URI中查找的Secondary Cookie名称。只有指定了Cookie插入会话保持方法才会显示本字段
·     HttpOnly:是否配置HttpOnly功能,只有指定了Cookie插入或重写会话保持方法才会显示本字段
¡     Disabled:关闭
¡     Enabled:开启
·     Secure:是否配置Secure功能,只有指定了Cookie插入或重写会话保持方法才会显示本字段
¡     Disabled:关闭
¡     Enabled:开启
·     Check all packets:是否开启检查所有报文的功能,包括:
¡     Disabled:关闭
¡     Enabled:开启
HTTP header
·     Method:会话保持方法,包括:
¡     HTTP host:基于HTTP主机的会话保持方法
¡     HTTP header name:基于HTTP首部名称的会话保持方法
¡     HTTP method:基于HTTP Request-Method的会话保持方法
¡     HTTP URL:基于HTTP URL的会话保持方法
¡     HTTP version:基于HTTP版本的会话保持方法
·     Name:HTTP首部的名称。只有指定了基于HTTP首部名称的会话保持方法才会显示本字段
·     Offset:HTTP首部基于HTTP报文起始位置的偏移量。只有指定了基于HTTP主机或HTTP URL的会话保持方法才会显示本字段
·     Start:HTTP首部开始标记的正则表达式。只有指定了基于HTTP主机或HTTP URL的会话保持方法才会显示本字段
·     End:HTTP首部结束标记的正则表达式,不会与Length字段同时显示。只有指定了基于HTTP主机或HTTP URL的会话保持方法才会显示本字段
·     Length:HTTP首部的长度,不会与End字段同时显示。只有指定了基于HTTP主机或HTTP URL的会话保持方法才会显示本字段
Payload
·     Offset:HTTP载荷或UDP载荷基于报文起始位置的偏移量
·     Start:HTTP载荷或UDP载荷开始标记的正则表达式
·     End:HTTP载荷或UDP载荷结束标记的正则表达式,不会与Length字段同时显示
·     Length:HTTP载荷或UDP载荷的长度,不会与End字段同时显示
RADIUS
·     Method:会话保持方法,包括:
¡     Framed-IP-Address:基于RADIUS报文中Framed-IP-Address属性的会话保持方法
¡     User-Name:基于RADIUS报文中User-Name属性的会话保持方法
¡     Code=attribute-code:基于RADIUS报文中指定属性的会话保持方法,属性编号为attribute-code
SIP
·     Method:会话保持方法,包括:
¡     SIP Call-ID:基于SIP信令报文Call ID的会话保持方法
SSL
·     Method:会话保持方法,包括:
¡     SSL session ID:基于SSL session ID的SSL会话保持方法
HTTP passive
·     Method:会话保持方法,包括:
¡     HTTP header name:基于HTTP首部名称的被动会话保持方法
¡     HTTP URL:基于HTTP URL的被动会话保持方法
¡     HTTP content:基于HTTP实体被动会话保持方法
·     Get:获取HTTP应答报文中的指定字符串
·     Match:获取HTTP请求报文中的指定字符串
UDP passive
·     Get:获取UDP应答报文中的指定字符串
·     Match:获取UDP请求报文中的指定字符串
·     Start:UDP载荷开始标记的正则表达式
·     End:UDP载荷结束标记的正则表达式,不会与Length字段同时显示
·     Length:UDP载荷的长度,不会与End字段同时显示
TCP payload
·     Offset:TCP载荷基于TCP报文起始位置的偏移量
·     Start:TCP载荷开始标记的正则表达式
·     End:TCP载荷结束标记的正则表达式,不会与Length字段同时显示
·     Length:TCP载荷的长度,不会与End字段同时显示
Diameter
·     Method:会话保持方法,当前会话保持方法仅有attribute-code:基于Diameter报文中指定属性的会话保持方法
·     Code:Diameter报文中属性编号
·     Index:AVP序列索引
1.1.37  display virtual-server
display virtual-server命令用来显示虚服务器的信息。
display virtual-server [ brief | name virtual-server-name ]
context-admin
context-operator
vsys-admin
vsys-operator
brief:显示虚服务器的简要信息。如果未指定本参数,将显示虚服务器的详细信息。
name virtual-server-name:显示指定虚服务器的信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的信息。
# 显示所有虚服务器的简要信息。
<Sysname> display virtual-server brief
Virtual server   State    Type      VPN instance     Virtual address     Port
vs1              Inactive IP                         192.168.21.148/32   80
                                    vpn2             192.168.21.149/32   80
                                                     1111:2222:3333:4444
                                                     :5555:6666:7777:888
vs2              Active   HTTP                       61.159.4.100/32     8080
vs3              Active   LINK-IP                    51.139.4.100/32     0
vs4              Active   MySQL                      12.139.5.132/32     3306
vs5              Active   Diameter                   13.139.5.132/32     3868
# 显示所有虚服务器的详细信息。
Virtual server: vs
  Description: Virtual server VS
  Type: HTTP
  State: Active
  VPN instance: vpn1
  Virtual IPv4 address: 1.1.1.1/32
                        1.1.1.2/32(vpn2)
  Virtual IPv6 address: 1001::1/128(vpn3)
                        1001::2/128(vpn4)
  Port: 0 (any port)
  Traffic group: 1
  Primary server farm: sf (in use)
  Primary sticky: sg3
  Backup sticky: sg4
  LB limit-policy:
  TCP parameter profile (client-side): ptc
  TCP parameter profile (server-side): pts
  HTTP parameter profile: pp1
  HTTP2 parameter profile (client-side): h1
  HTTP2 parameter profile (server-side): h2
  HTTP-statistics parameter profile: 1
  OneConnect parameter profile:one
  DPI application profile: profile1
  UDP per-packet: Enabled
  Rate limit:
    Connections: 10000
  SSL server policies with SNI list:
      Server name indication: www.example.com
  SSL server policy: ssl-server
  SSL client policy: ssl-client
  VRRP Info:
    VRRP VRID: 1
  Sticky: test
  Sticky synchronization: Disabled
  Bandwidth busy protection: Disabled
  Interface bandwidth statistics: Disabled
  Route advertisement: Enabled
  ARP/ND interfaces:
    GigabitEthernet1/0/2
  Customlog content: %{is};%{ps}
  Cache policy:
  HTTP protection policy: p1
  Insert xff: Enabled
  External-link proxy: Enabled
  External-link inject URI: proxy
  External-link inject domain suffix: c.example.com
  External-link SNAT pool: spool1
  External-link domain name whitelist:
    a.example.com
    b.example.com
  LB policy: lbp2
    Type: HTTP
Virtual server: vstcp
  Type: TCP
  State: Active
  VPN instance:
  Port: 8080
  Traffic group: 1
  Primary sticky: sg3
  Backup sticky: sg4
  LB limit-policy:
  TCP-Application parameter profile:ptapp
  Rate limit:
    Connections: 10000
  Connection synchronization: Disabled
  Application-Mode: Enabled
  Proxy protocol: Enabled
  Proxy protocol version:V1
  ARP/ND interfaces:
  LB policy: lbp2
    Type: Generic
# 显示出方向链路负载均衡中配置的虚服务器lk的详细信息。
<Sysname> display virtual-server name lk
Virtual server: lk
  Description:
  Type: Link-IP
  State: Active
  VPN instance:
  Port: 0
  Traffic group: 1
  Primary link group: lg1 (in use)
  Sticky: sg3
  LB limit-policy:
  Rate limit:
    Connections: 10000
  Route advertisement: Disabled
  ARP/ND interfaces:
  LB policy: lbp2
    Type: Generic
# 显示虚服务器vs4的详细信息。
<Sysname> display virtual-server name vs4
Virtual server: vs4
  Description: Virtual server VS4
  Type: MySQL
  State: Active
  VPN instance:
  Port: 3306
  Traffic group: 1
  Sticky: sg3
  LB limit-policy:
  MySQL parameter profile: my
  Rate limit:
    Connections: 10000
  ARP/ND interfaces:
  Version: 5.6
  User list:
    Username: wangping
    Username: liqiang
  Read server farm: rd
  Read sticky group: rsg
  Write server farm: wr
  Write sticky group: wsg
  LB policy: lbp2
    Type: Generic
# 显示虚服务器vs5的详细信息。
<Sysname> display virtual-server name vs5
Virtual server: vs5
  Description: Virtual server VS5
  Type: Diameter
  State: Active
  VPN instance: vpn1
  Port: 3868
  Traffic group: 1
  Sticky: dia-sg
  LB limit-policy:
  Rate limit:
    Connections: --
  SSL server policy: ssp
  Diameter-session parameter profile: Dia-para
  LB policy: dia-lbp
    Type: Diameter
表1-20 display virtual-server命令显示信息描述表
Virtual server
虚服务器的名称
虚服务器的状态,包括:
·     Active:可用
·     Inactive:不可用(已安装License并开启了虚服务器功能,仍不可用)
·     Inactive (no license):不可用(由于缺少License)
·     Inactive (disabled):不可用(由于未开启虚服务器功能)
虚服务器的类型,包括Fast HTTP、HTTP、IP、MySQL、RADIUS、TCP、UDP、Link-IP和Diameter
VPN instance
虚服务器所属的VPN实例名称
Virtual address
虚服务器的IPv4地址和掩码
Port
虚服务器的端口号,0表示任意端口号
Traffic group
虚服务器关联的集群流量组的编号
虚服务器的描述信息
虚服务器的IPv4地址和掩码,()中的信息表示此地址所属的VPN实例名称,未指定IPv4地址所属的VPN实例时,此处不显示()以及()内的信息
虚服务器的IPv6地址和前缀,()中的信息表示此地址所属的VPN实例名称,未指定IPv6地址所属的VPN实例时,此处不显示()以及()内的信息
Primary server farm
缺省的主用实服务组名称,(in use)表示该实服务组正被使用
Backup server farm
缺省的备用实服务组名称,(in use)表示该实服务组正被使用
Primary link group
缺省的主用链路组名称,(in use)表示该链路组正被使用
Backup link group
缺省的备用链路组名称,(in use)表示该链路组正被使用
Primary sticky
缺省的主用会话保持组名称
Backup sticky
备用会话保持组名称,只有HTTP和RADIUS类型的虚服务器才会显示本字段
LB policy
虚服务器引用的负载均衡策略
虚服务器引用的HTTP类型参数模板,只有配置了HTTP类型的参数模板才会显示本字段
IP parameter profile
虚服务器引用的IP类型参数模板,只有配置了IP类型的参数模板才会显示本字段
虚服务器引用的TCP类型参数模板,只有配置了TCP类型的参数模板才会显示本字段
虚服务器引用的客户端侧TCP类型参数模板,只有配置了客户端侧TCP类型的参数模板才会显示本字段
虚服务器引用的服务器侧TCP类型参数模板,只有配置了服务器侧TCP类型的参数模板才会显示本字段
虚服务器引用的OneConnect类型参数模板,只有引用了OneConnect类型的参数模板才会显示本字段
虚服务器引用的HTTP统计类型参数模板,只有配置了HTTP统计类型的参数模板才会显示本字段
虚服务器引用的TCP-Application类型参数模板,只有配置了TCP-Application类型参数模板才会显示本字段
虚服务器引用的MySQL类型参数模板,只有引用了MySQL类型的参数模板才会显示本字段
虚服务器引用的客户端侧HTTP2.0类型参数模板,只有配置了HTTP2.0类型的参数模板才会显示本字段
虚服务器引用的服务器侧HTTP2.0类型参数模板,只有配置了HTTP2.0类型的参数模板才会显示本字段
Diameter parameter profile
虚服务器引用的Diameter-session类型参数模板,只有引用了Diameter类型的参数模板才会显示本字段
虚服务器引用的DPI应用profile,只用引用了DPI应用profile才会显示本字段
UDP per-packet
虚服务器UDP强制负载均衡功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
只有UDP类型的虚服务器才会显示本字段
Connection limit
虚服务器所允许的最大连接数
Rate limit
虚服务器的速率限制
Connections
虚服务器所允许的最大连接速率
Bandwidth
虚服务器所允许的最大总带宽,单位为kbps
Inbound bandwidth
虚服务器所允许的最大入带宽,单位为kbps
Outbound bandwidth
虚服务器所允许的最大出带宽,单位为kbps
SSL服务器端策略的SNI列表,只有TCP和HTTP类型的虚服务器才会显示本字段
SSL服务器名称指示,只有TCP和HTTP类型的虚服务器才会显示本字段
SSL server policy
SSL服务器端策略的名称,只有HTTP和Diameter类型的虚服务器才会显示本字段
SSL client policy
SSL客户端策略的名称,只有HTTP类型的虚服务器才会显示本字段
Redirect relocation
重定向的URL,只有HTTP类型的虚服务器才会显示本字段
重定向报文中的状态码,只有HTTP类型的虚服务器才会显示本字段
VRRP VRID
虚服务器绑定的VRRP备份组号
VRRP interface
虚服务器绑定的VRRP备份组的接口
Sticky
虚服务引用的会话保持组,只有HTTP类型的虚服务器才会显示本字段
虚服务器会话扩展信息备份功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
HTTP类型的虚服务器不会显示本字段
虚服务器会话保持表项备份功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
链路的带宽繁忙保护功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
链路的接口带宽统计功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Route advertisement
虚服务器IP地址下发功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Application-Mode
是否开启TCP类型的虚服务器工作在七层,包括:
·     Disabled:关闭
·     Enabled:开启
只有TCP类型的虚服务器才会显示本字段
Proxy protocol
虚服务器的代理协议功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
只有TCP类型虚服务器才会显示本字段
虚服务器的代理协议版本,包括:
·     V1:代理协议版本号为v1
·     V2:代理协议版本号为v2
只有虚服务器的代理协议功能才会显示本字段
ARP/ND interfaces
发送免费ARP报文或者ND报文的接口
Version
MySQL数据库的版本号,只有MySQL类型的虚服务器才会显示本字段
User list
MySQL数据库的登录用户列表,只有MySQL类型的虚服务器才会显示本字段
Username
MySQL数据库的登录用户名,只有MySQL类型的虚服务器才会显示本字段
Read server farm
MySQL虚服务器引用的读实服务组名称,只有MySQL类型的虚服务器才会显示本字段
Read sticky group
读实服务组对应的会话保持组名称,只有MySQL类型的虚服务器才会显示本字段
Write server farm
MySQL虚服务器引用的写实服务组名称,只有MySQL类型的虚服务器才会显示本字段
Write sticky group
写实服务组对应的会话保持组名称,只有MySQL类型的虚服务器才会显示本字段
Customlog content
快速日志输出的内容,只有HTTP类型的虚服务器才会显示本字段
Insert xff
配置发往服务器侧报文插入X-Forwarded-for字段
·     Disabled:关闭
·     Enabled:开启
虚服务器引用的HTTP防护策略
External-link proxy
外链代理功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
外链代理的URI标识
外链代理的域名后缀
外链代理的SNAT地址池
外链代理的白名单
1.1.38  display virtual-server statistics
display virtual-server statistics命令用来显示虚服务器的统计信息。
display virtual-server statistics [ name virtual-server-name ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
name virtual-server-name:显示指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的统计信息。
虚服务器的统计时间间隔为200毫秒,不支持配置。
# 显示虚服务器vs的统计信息。
<Sysname> display virtual-server statistics name vs
Virtual server: vs
  Total connections: 979
  Active connections: 618
  Half Open connections: 0
  Max connections: 661
  Connections per second: 146
  Max connections per second: 156
  Client input: 333332 bytes
  Client output: 472054 bytes
  Throughput: 4088 bps
  Outbound throughput: 2874 bps
  Max throughput: 4368 bps
  Max outbound throughput: 3154 bps
  Received packets: 979
  Sent packets: 0
  Dropped packets: 7
    HTTP packet parse errors: 1
    Schedule real server failed: 1
    Connect real server failed: 1
    No responses: 2
    Incomplete response packets: 1
    Others: 1
  Received requests: 0
  Dropped requests: 0
  Received requests per second: 0
  Max received requests per second: 0
  Sent responses: 0
  Dropped responses: 0
  Authentication permitted requests: 0
  Authentication denied requests: 0
  Redirected requests for login: 4
  Redirected requests for re-authentication: 0
表1-21 display virtual-server statistics命令显示信息描述表
Virtual server
虚服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
半开连接数,只有TCP类型的虚服务器才会显示本字段
Max connections
最大连接数
每秒连接数
最大每秒连接数
Client input
从客户端收到的流量,单位为字节
Client output
向客户端发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
Received packets
收到的报文数
Sent packets
发出的报文数(虚服务器发给客户端的)
Dropped packets
丢弃的报文数
解析HTTP报文出错而丢弃的报文数,只有丢弃的HTTP报文数不为0的HTTP类型的虚服务器才会显示本字段
调度实服务器失败而丢弃的报文数,只有丢弃的HTTP报文数不为0的HTTP类型的虚服务器才会显示本字段
连接实服务器失败而丢弃的报文数,只有丢弃的HTTP报文数不为0的HTTP类型的虚服务器才会显示本字段
No responses
没有收到应答报文而丢弃的报文数,只有丢弃的HTTP报文数不为0的HTTP类型的虚服务器才会显示本字段
收到应答报文不完整而丢弃的报文数,只有丢弃的HTTP报文数不为0的HTTP类型的虚服务器才会显示本字段
Others
因其他情况丢弃的报文数,只有丢弃的HTTP报文数不为0的HTTP类型的虚服务器才会显示本字段
每秒收到的报文数
每秒发出的报文数(虚服务器发给客户端的)
Received requests
收到的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
Dropped requests
丢弃的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
每秒收到的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
每秒收到的HTTP请求报文数量最大值,只有HTTP类型的虚服务器才会显示本字段
Sent responses
发出的HTTP应答报文数量,只有HTTP类型的虚服务器才会显示本字段
Dropped responses
丢弃的HTTP应答报文数量,只有HTTP类型的虚服务器才会显示本字段
鉴权结果为通过的请求数量
鉴权结果为拒绝的请求数量
重定向至登录页面的请求数量
重定向至二次认证页面的请求数量
·     reset virtual-server statistics
1.1.39  fail-action
fail-action命令用来配置链路组中链路的故障处理方式。
undo fail-action命令用来恢复缺省情况。
fail-action { keep | reschedule | reset }
undo fail-action
链路组中链路的故障处理方式为保持已有连接。
链路组视图
context-admin
keep:保持已有连接,即不主动断开与故障链路的连接,连接继续保持还是断开将由协议自身的超时机制决定。
reschedule:重定向连接,即把连接重定向到链路组中其它可用的链路上。
reset:断开已有连接,即主动断开与故障链路的连接。对于TCP报文,将发送RST报文;对于其它类型的报文,将发送ICMP不可达报文。
工作机制
当处理报文的链路发生故障时,负载均衡设备根据配置的故障处理方式来决定报文的处理方式。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组lg中链路的故障处理方式为重定向连接。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] fail-action reschedule
1.1.40  fallback-action continue
fallback-action continue命令用来配置查找可用服务器失败时继续匹配下一条引用规则。
undo fallback-action命令用来恢复缺省情况。
根据当前动作查找可用服务器失败时直接丢弃报文。
负载均衡动作视图
context-admin
vsys-admin
工作机制
当配置该命令的动作在负载均衡策略中被引用时,在转发中根据该配置判断当前动作查找可用服务器失败时,可继续顺序匹配策略中的下一条引用规则。
注意事项
本命令对于SIP类型的虚服务不生效。
# 在HTTP类型的负载均衡动作a1中,开启根据当前动作查找可用实服务器失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a1 type http
[Sysname-lba-http-a1] fallback-action continue
# DNS透明代理场景下,在DNS类型的负载均衡动作a2中,开启根据当前动作查找可用DNS服务器失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作a3中,开启根据当前动作查找可用链路失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a3 type link-generic
[Sysname-lba-link-generic-a3] fallback-action continue
1.1.41  forward all
forward all命令用来配置报文的转发模式为转发。
undo forward命令用来恢复缺省情况。
forward all
undo forward
报文的转发模式为丢弃。
通用/DNS/链路类型的负载均衡动作视图
context-admin
vsys-admin
兼容性说明
在DNS类型的负载均衡动作视图下,本命令与dns-server-pool和skip current-dns-proxy命令互斥;在通用类型的负载均衡动作视图下,本命令与server-farm命令互斥;在链路类型的负载均衡动作视图下,本命令与link-group命令互斥。当配置了其中一条后,另一条的配置将被自动取消。
注意事项
本命令对于SIP类型的虚服务不生效。
# 服务器负载均衡场景下,在通用类型的负载均衡动作lba1中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] forward all
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作lba2中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba2 type link-generic
[Sysname-lba-link-generic-lba2] forward all
# DNS透明代理场景下,在DNS类型的负载均衡动作lba3中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba3 type dns
[Sysname-lba-dns-lba3] forward all
·     server-farm (LB action view)
·     link-group (LB action view)
·     dns-server-pool
1.1.42  inherit vpn-instance disable
inherit vpn-instance disable命令用来关闭链路所属VPN实例的继承功能。
undo inherit vpn-instance disable命令用来开启链路所属VPN实例的继承功能。
链路所属VPN实例的继承功能处于开启状态。
链路视图
context-admin
工作机制
若在链路视图下执行vpn-instance命令指定了链路所属的VPN实例,则链路属于该VPN实例。若未指定链路所属的VPN实例,当链路所属VPN实例的继承功能处于开启状态时,链路所属的VPN实例与虚服务器所属的VPN实例一致;当该功能处于关闭状态时,链路属于公网。
可以通过执行display loadbalance link命令查看链路所属的VPN实例。
推荐配置
若需要指定链路属于某私有网络,建议通过执行链路视图下的vpn-instance命令进行配置。
注意事项
非缺省vSystem不支持本命令。
# 关闭链路lk1所属VPN实例的继承功能。
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] inherit vpn-instance disable
·     display loadbalance link
·     vpn-instance (link view)
1.1.43  ip
ip命令用来配置IPv4会话保持方法。
undo ip命令用来恢复缺省情况。
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
未配置IPv4会话保持方法。
会话保持组视图
context-admin
vsys-admin
port:表示会话保持方法为IPv4地址+端口。如果未指定本参数,表示会话保持方法为IPv4地址。
both:当未指定port参数时,表示会话保持方法为源IPv4地址+目的IPv4地址;当指定了port参数时,表示会话保持方法为源IPv4地址+源端口+目的IPv4地址+目的端口。
destination:当未指定port参数时,表示会话保持方法为目的IPv4地址;当指定了port参数时,表示会话保持方法为目的IPv4地址+目的端口。
source:当未指定port参数时,表示会话保持方法为源IPv4地址;当指定了port参数时,表示会话保持方法为源IPv4地址+源端口。
mask mask-length:会话保持方法的掩码长度。
# 在地址端口类型的会话保持组sg1中,配置会话保持方法为源IPv4地址。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# 在地址端口类型的会话保持组sg1中,配置会话保持方法为源IPv4地址+源端口。
[Sysname-sticky-address-port-sg1] ip port source
·     sticky-group
1.1.44  ip address (ISP view)
ip address命令用来为ISP配置IPv4地址信息。
undo ip address命令用来恢复缺省情况。
ip address ipv4-address { mask-length | mask }
undo ip address ipv4-address { mask-length | mask }
ISP未配置IPv4地址信息。
ISP视图
context-admin
非缺省vSystem不支持本命令。
ipv4-address:ISP的IPv4地址。
mask-length:IPv4地址的掩码长度,取值范围为0~32。
mask:IPv4地址的掩码。
# 为名为isp1的ISP配置IPv4地址信息。
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] ip address 1.1.1.1 24
1.1.45  ip mask
ip mask命令用来配置IPv4就近性表项的掩码长度。
undo ip mask命令用来恢复缺省情况。
ip mask { mask-length | mask }
undo ip mask
IPv4就近性表项的掩码长度为24。
就近性视图
context-admin
mask-length:IPv4就近性表项的掩码长度,取值范围为0~32,其中0表示自然掩码。
mask:IPv4就近性表项的掩码。
非缺省vSystem不支持本命令。
# 配置IPv4就近性表项的掩码长度为30。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] ip mask 30
1.1.46  ipv6
ipv6命令用来配置IPv6会话保持方法。
undo ipv6命令用来恢复缺省情况。
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
未配置IPv6会话保持方法。
会话保持组视图
context-admin
vsys-admin
port:表示会话保持方法为IPv6地址+端口。如果未指定本参数,表示会话保持方法为IPv6地址。
both:表示会话保持方法为源IPv6地址+目的IPv6地址(未指定port参数时),或源IPv6地址+源端口+目的IPv6地址+目的端口(指定port参数时)。
destination:表示会话保持方法为目的IPv6地址(未指定port参数时),或目的IPv6地址+目的端口(指定port参数时)。
source:表示会话保持方法为源IPv6地址(未指定port参数时),或源IPv6地址+源端口(指定port参数时)。
prefix prefix-length:会话保持方法的前缀长度。
# 在地址端口类型的会话保持组sg1中,配置会话保持方法为源IPv6地址。
[Sysname-sticky-address-port-sg1] ipv6 source
# 在地址端口类型的会话保持组sg1中,配置会话保持方法为源IPv6地址+源端口。
[Sysname-sticky-address-port-sg1] ipv6 port source
·     sticky-group
1.1.47  ipv6 address (ISP view)
ipv6 address命令用来为ISP配置IPv6地址信息。
undo ipv6 address命令用来恢复缺省情况。
ipv6 address ipv6-address prefix-length
undo ipv6 address ipv6-address prefix-length
ISP未配置IPv6地址信息。
ISP视图
context-admin
ipv6-address:ISP的IPv6地址。
prefix-length:IPv6地址的前缀长度,取值范围为0~128。
非缺省vSystem不支持本命令。
# 为名为isp1的ISP配置IPv6地址信息。
[Sysname-lbisp-isp1] ipv6 address 200::1 100
1.1.48  ipv6 prefix
ipv6 prefix命令用来配置IPv6就近性表项的前缀长度。
undo ipv6 prefix命令用来恢复缺省情况。
ipv6 prefix prefix-length
undo ipv6 prefix
IPv6就近性表项的前缀长度为96。
就近性视图
context-admin
prefix-length:IPv6就近性表项的前缀长度,取值范围为0~128。
非缺省vSystem不支持本命令。
# 配置IPv6就近性表项的前缀长度为64。
[Sysname-lb-proximity] ipv6 prefix 64
1.1.49  lb-policy
lb-policy命令用来指定虚服务器引用的负载均衡策略。
undo lb-policy命令用来恢复缺省情况。
lb-policy policy-name
undo lb-policy
虚服务器未引用任何负载均衡策略。
虚服务器视图
context-admin
vsys-admin
policy-name:负载均衡策略的名称,为1~255个字符的字符串,不区分大小写。
工作机制
虚服务器引用负载均衡策略,能够细化虚服务器的粒度。根据策略中的匹配规则,使命中虚服务器的报文根据不同的报文内容进行不同的负载均衡处理,从而有效地丰富了负载均衡的负载功能。
注意事项
虚服务器只能引用链路负载均衡策略模板。
# 指定LINK-IP类型的虚服务器vs3引用的负载均衡策略为lbp1。
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] lb-policy lbp1
1.1.50  link
link命令用来创建并添加链路组成员,并进入链路组成员视图。如果指定的链路组成员已经存在,则直接进入链路组成员视图。
undo link命令用来删除指定的链路组成员。
link link-name
undo link link-name
不存在链路组成员。
链路组视图
context-admin
link-name:链路组成员的名称,为1~63个字符的字符串,不区分大小写。
工作机制
设备支持通过两种方式向链路组中添加成员:
·     通过本命令创建链路组成员或添加已存在的链路,推荐使用此种方式进行配置。
·     通过link-group (link view)命令指定链路所属的链路组。
设备不支持同时通过两种方式配置名称相同的链路组成员。
当管理员向链路组中添加链路时,若链路已存在,通过配置本命令可将链路添加为链路组成员;若链路不存在,设备会自动关联创建相同名称的链路。
注意事项
非缺省vSystem不支持本命令。
# 添加链路组成员lk1,并进入链路组成员视图。
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1]
·     link-group (link view)
1.1.51  link-group (LB action view)
link-group命令用来指定指导转发的链路组。
undo link-group命令用来恢复缺省情况。
link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
undo link-group
未指定指导转发的链路组。
负载均衡动作视图
context-admin
link-group-name:主用链路组的名称,为1~63个字符的字符串,不区分大小写。
backup backup-link-group-name:备用链路组的名称,为1~63个字符的字符串,不区分大小写。
sticky sticky-name:链路组所对应会话保持组的名称,为1~63个字符的字符串,不区分大小写。
兼容性说明
本命令与forward all命令互斥,后配置的生效。
工作机制
当主用链路组可用(该链路组存在且有可用的链路)时,使用主链路组指导转发;当主用链路组不可用而备用链路组可用时,使用备用链路组指导转发;而当主、备用链路组都不可用时,则丢弃报文。
注意事项
非缺省vSystem不支持本命令。
# 在link-generic类型的负载均衡动作lba1中,指定指导转发的主用链路组为lg,备用链路组为lgb,会话保持组为sg1。
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba1-link-generic-lba1] link-group lg backup lgb sticky sg1
·     forward all
1.1.52  link-group (link view)
link-group命令用来指定链路所属的链路组。
undo link-group
链路不属于任何链路组。
链路视图
context-admin
link-group-name:链路组的名称,为1~63个字符的字符串,不区分大小写。
工作机制
设备对数据流量进行链路负载分担时,会在该流量所匹配的链路组中选定一条最佳链路进行转发。
推荐配置
不推荐使用本功能指定链路所属的链路组,请进入链路组视图通过link命令添加链路。
注意事项
非缺省vSystem不支持本命令。
# 配置链路lk1所属的链路组为lkg1。
[Sysname-lb-link-lk1] link-group lkg1
·     link
1.1.53  loadbalance action
loadbalance action命令用来创建负载均衡动作,并进入负载均衡动作视图。如果指定的负载均衡动作已经存在,则直接进入负载均衡动作视图。
undo loadbalance action命令用来删除指定的负载均衡动作。
loadbalance action action-name [ type link-generic ]
undo loadbalance action action-name
不存在任何负载均衡动作。
context-admin
vsys-admin
action-name:负载均衡动作的名称,为1~255个字符的字符串,不区分大小写。
type link-generic:链路类型的负载均衡动作。非缺省vSystem不支持本参数。
创建负载均衡动作时必须指定类型参数;而在进入已创建的负载均衡动作视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建链路类型的负载均衡动作lba1,并进入负载均衡动作视图。
[Sysname-lba-link-generic-lba1]
1.1.54  loadbalance alg
loadbalance alg命令用来开启指定协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
undo loadbalance alg命令用来关闭指定协议的负载均衡ALG功能。
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
DNS、FTP、PPTP、ICMP-ERROR和RTSP协议的负载均衡ALG功能均处于开启状态。
context-admin
vsys-admin
dns:DNS协议。
ftp:FTP协议。
h323:H323协议。
icmp-error:ICMP-ERROR协议。
ils:ILS(Internet Locator Service,互联网定位服务)协议。
mgcp:MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议。
nbt:NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议。
pptp:PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议。
rsh:RSH(Remote Shell,远程外壳)协议。
rtsp:RTSP(Real Time Streaming Protocol,实时流协议)协议。
sccp:SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议。
sip:SIP(Session Initiation Protocol,会话初始协议)协议。
sqlnet:SQLNET协议。
tftp:TFTP协议。
xdmcp:XDMCP(X Display Manager Control Protocol,X显示监控)协议。
工作机制
负载均衡ALG功能用于将父、子会话分发到同一条链路上。
注意事项
SIP分片报文不支持负载均衡ALG功能。
当虚服务器配置的端口号为非知名端口号时,即使已开启相应协议的负载均衡ALG功能,设备也不会进行负载均衡ALG处理。可通过以下任一方式解决:
·     修改虚服务器端口号为该协议自身的知名端口号。
·     使用port-mapping命令,将虚服务器中配置的端口号与指定协议建立端口映射关系。关于port-mapping命令的详细介绍,请参见“安全命令参考”中的“APR”。
# 开启TFTP协议的负载均衡ALG功能。
[Sysname] loadbalance alg tftp
1.1.55  loadbalance alg all-enable
loadbalance alg all-enable命令用来开启支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
loadbalance alg all-disable命令用来关闭支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
context-admin
vsys-admin
# 开启所有协议的负载均衡ALG功能。
[Sysname] loadbalance alg all-enable
1.1.56  loadbalance class
loadbalance class命令用来创建负载均衡类,并进入负载均衡类视图。如果指定的负载均衡类已经存在,则直接进入负载均衡类视图。
undo loadbalance class命令用来删除指定的负载均衡类。
loadbalance class class-name [ type link-generic [ match-all | match-any ] ]
undo loadbalance class class-name
不存在任何负载均衡类。
context-admin
vsys-admin
class-name:负载均衡类的名称,为1~255个字符的字符串,不区分大小写。
type link-generic:链路类型的负载均衡类。非缺省vSystem不支持本参数。
[ match-all | match-any ]:match-all表示需要匹配所有规则才算匹配该类,match-any表示只需匹配任一规则就算匹配该类。缺省值为match-all。
创建负载均衡类时必须指定类型参数;而在进入已创建的负载均衡类视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建链路类型的负载均衡类lbc1,并进入负载均衡类视图。
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1]
1.1.57  loadbalance dns-cache aging-time
loadbalance dns-cache aging-time命令用来配置负载均衡DNS缓存表项的老化时间。
undo loadbalance dns-cache  aging-time命令用来恢复缺省情况。
loadbalance dns-cache aging-time aging-time
负载均衡DNS缓存表项的老化时间为60分钟。
context-admin
aging-time:负载均衡DNS缓存表项的老化时间,取值范围为1~1440,单位为分钟。缺省为60。.
功能简介
负载均衡设备会将域名与IP地址的对应关系记录在DNS缓存表中,当业务流量匹配DNS缓存表中的IP地址时,查找出对应的域名。若查找出的域名与match destination domain-name命令创建的匹配规则中的域名一致,则根据匹配规则将匹配不同域名的报文在不同的负载均衡动作流程中处理。
注意事项
非缺省vSystem不支持本命令。
# 配置负载均衡DNS缓存表项的老化时间为100分钟。
[Sysname] loadbalance dns-cache aging-time 100
·     match destination domain-name
1.1.58  loadbalance isp auto-update enable
loadbalance isp auto-update enable命令用来开启ISP自动更新功能。
undo loadbalance isp auto-update enable命令用来关闭ISP自动更新功能。
ISP自动更新功能处于关闭状态。
context-admin
工作机制
开启ISP自动更新功能后,设备会依据运营商的WHOIS服务器管理标识定期向指定的WHOIS服务器查询ISP地址信息。
注意事项
非缺省vSystem不支持本命令。
# 开启ISP自动更新功能。
[Sysname] loadbalance isp auto-update enable
·     loadbalance isp auto-update frequency
·     loadbalance isp auto-update whois-server
1.1.59  loadbalance isp auto-update frequency
loadbalance isp auto-update frequency命令用来配置ISP自动更新的频率。
undo loadbalance isp auto-update frequency命令用来恢复缺省情况。
loadbalance isp auto-update frequency { per-day | per-week | per-month }
ISP自动更新的频率为每周一次。
context-admin
per-day:ISP自动更新的频率为每天一次。
per-week:ISP自动更新的频率为每周一次。
per-month:ISP自动更新的频率为每月一次。
工作机制
自动更新的时刻为系统时间04:00:00左右。如果是首次更新,更新时间为下一个04:00:00。
注意事项
非缺省vSystem不支持本命令。
# 配置ISP自动更新的频率为每天一次。
[Sysname] loadbalance isp auto-update frequency per-day
·     loadbalance isp auto-update enable
1.1.60  loadbalance isp auto-update whois-server
loadbalance isp auto-update whois-server命令用来配置ISP自动更新所查询的WHOIS服务器。
undo loadbalance isp auto-update whois-server命令用来恢复缺省情况。
loadbalance isp auto-update whois-server { domain domain-name | ip ip-address }
未配置ISP自动更新所查询的WHOIS服务器。
context-admin
domain domain-name:ISP自动更新所查询的WHOIS服务器的域名,由“.”分隔的字符串组成(如example.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”。
ip ip-address:ISP自动更新所查询的WHOIS服务器的IP地址。
非缺省vSystem不支持本命令。
# 配置ISP自动更新所查询的WHOIS服务器的IP地址为20.1.1.1。
[Sysname] loadbalance isp auto-update whois-server ip 20.1.1.1
1.1.61  loadbalance isp file
loadbalance isp file命令用来导入ISP文件。
undo loadbalance isp file命令用来删除已经导入的ISP文件。
loadbalance isp file isp-file-name
context-admin
isp-file-name:ISP文件的名称,为1~255个字符的字符串,不区分大小写。
工作机制
不允许删除导入的ISP及其IPv4和IPv6地址,但如果手工配置的ISP与导入的ISP重合,则允许删除手工配置的ISP及其IPv4和IPv6地址。
多次执行本命令,最后一次执行的命令生效。
注意事项
非缺省vSystem不支持本命令。
当导入的文件不存在、文件名不合法或文件解密失败时,系统将维持已有的导入内容不变。
当导入文件解析IP地址失败而退出导入操作时,系统将清空上次导入的内容,只保存本次已导入成功的内容。
# 导入ISP文件isp2。
[Sysname] loadbalance isp file isp2
1.1.62  loadbalance isp name
loadbalance isp name命令用来创建ISP,并进入ISP视图。如果指定的ISP已经存在,则直接进入ISP视图。
undo loadbalance isp name命令用来删除指定的ISP。
loadbalance isp name isp-name
undo loadbalance isp name isp-name
不存在任何ISP。
context-admin
isp-name:ISP的名称,为1~255个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
# 创建名为isp1的ISP,并进入ISP视图。
1.1.63  loadbalance link
loadbalance link命令用来创建链路,并进入链路视图。如果指定的链路已经存在,则直接进入链路视图。
undo loadbalance link命令用来删除链路。
loadbalance link link-name
undo loadbalance link link-name
不存在链路。
context-admin
link-name:链路的名称,为1~255个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
连接外部网络的每条物理链路对应一个链路。
# 创建链路lk1,并进入该链路视图。
1.1.64  loadbalance link-group
loadbalance link-group命令用来创建链路组,并进入链路组视图。如果指定的链路组已经存在,则直接进入链路组视图。
undo loadbalance link-group命令用来删除指定的链路组。
loadbalance link-group link-group-name
undo loadbalance link-group link-group-name
不存在任何链路组。
context-admin
link-group-name:链路组的名称,为1~255个字符的字符串,不区分大小写。
工作机制
为了便于对多条链路进行管理,可以依据这些链路的共有属性划分成不同的组,称为链路组。
注意事项
非缺省vSystem不支持本命令。
# 创建链路组lg,并进入链路组视图。
1.1.65  loadbalance log enable bandwidth-busy
loadbalance log enable bandwidth-busy命令用来开启负载均衡链路带宽繁忙日志功能。
undo loadbalance log enable bandwidth-busy命令用来关闭负载均衡链路带宽繁忙日志功能。
负载均衡链路带宽繁忙日志功能处于关闭状态。
context-admin
工作机制
通过开启负载均衡链路带宽繁忙日志功能,实现对所有链路的繁忙状态进行记录。
注意事项
非缺省vSystem不支持本命令。
# 开启负载均衡链路带宽繁忙日志功能。
[Sysname] loadbalance log enable bandwidth-busy
1.1.66  loadbalance log enable base
loadbalance log enable base命令用来开启负载均衡基本日志功能。
undo loadbalance log enable base命令用来关闭负载均衡基本日志功能。
负载均衡基本日志功能处于开启状态。
context-admin
vsys-admin
通过开启负载均衡基本日志功能,可实现在以下几种情况下输出日志信息:
·     实服务器、实服务组、链路或链路组的状态变化。
·     实服务器或链路的健康检测结果发生变化。
·     实服务器、虚服务器或链路的连接数达到上限或者恢复到正常范围内。
·     实服务器、虚服务器或链路的连接速率达到上限或者恢复到正常范围内。
·     虚服务器引用的缺省实服务器组主备切换。
·     虚服务器引用的缺省链路组主备切换。
·     负载均衡动作引用的实服务器组主备切换。
·     负载均衡动作引用的链路组主备切换。
若链路、实服务器或虚服务器的实际带宽超过配置的最大带宽(命令rate-limit bandwidth)时,不会输出负载均衡基本日志。
# 开启负载均衡基本日志功能。
[Sysname] loadbalance log enable base
·     rate-limit bandwidth (link view)
·     rate-limit bandwidth (real server view)
·     rate-limit bandwidth (virtual server view)
1.1.67  loadbalance log enable link-flow
loadbalance log enable link-flow命令用来开启负载均衡链路流量日志功能。
undo loadbalance log enable link-flow命令用来关闭负载均衡链路流量日志功能。
负载均衡的链路流量日志功能处于关闭状态。
context-admin
工作机制
开启负载均衡链路流量日志功能后,可输出经过链路转发流量的日志信息。
注意事项
非缺省vSystem不支持本命令。
# 开启负载均衡链路流量日志功能。
[Sysname] loadbalance log enable link-flow
1.1.68  loadbalance log enable nat
loadbalance log enable nat命令用来开启负载均衡NAT日志功能。
undo loadbalance log enable nat命令用来关闭负载均衡NAT日志功能。
负载均衡NAT日志功能处于关闭状态。
context-admin
vsys-admin
工作机制
通过开启负载均衡NAT日志功能,可以实现对源或目的地址进行过NAT转换的连接信息进行记录,包括IP地址及端口的转换信息、用户的访问信息等。
注意事项
负载均衡NAT日志通过Flow日志方式进行输出。开启负载均衡NAT日志功能后,必须配置Flow日志的相关功能才能输出负载均衡NAT日志信息。有关Flow日志的详细介绍,请参见“网络管理和监控配置指导”中的“Flow日志”。
# 开启负载均衡NAT日志功能。
[Sysname] loadbalance log enable nat
1.1.69  loadbalance proximity
loadbalance proximity命令用来创建就近性,并进入就近性视图。如果指定的就近性已经存在,则直接进入就近性视图。
undo loadbalance proximity命令用来删除就近性视图及该视图下的所有配置。
undo loadbalance proximity [ vpn-instance vpn-instance-name ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示公网实例。
非缺省vSystem不支持本命令。
# 创建并进入就近性视图。
1.1.70  loadbalance probe failed-record enable
loadbalance probe failed-record enable命令用来开启健康检测失败信息的记录功能。
undo loadbalance probe failed-record enable命令用来恢复缺省情况。
健康检测失败信息的记录功能处于关闭状态。
context-admin
vsys-admin
配置本命令后,设备开始记录实服务器和链路健康检测失败的信息。通过执行display loadbalance probe failed-record命令,可查看健康检测失败的历史记录。
# 开启健康检测失败信息的记录功能。
[Sysname] loadbalance probe failed-record enable
·     display loadbalance probe failed-record
1.1.71  loadbalance probe failed-record max-number
loadbalance probe failed-record max-number命令用来配置可记录的健康检测失败信息的最大条数。
undo loadbalance probe failed-record max-number命令用来恢复缺省情况。
loadbalance probe failed-record max-number max-number
可记录的健康检测失败信息的最大条数为50000条。
context-admin
vsys-admin
max-number:可记录的健康检测失败信息的最大条数,取值范围为100~50000。
# 配置可记录的健康检测失败信息的最大条数为10000条。
[Sysname] loadbalance probe failed-record max-number 10000
1.1.72  loadbalance probe nqa-task-restrict disable
loadbalance probe nqa-task-restrict disable命令用来关闭NQA健康检测速率限制功能。
undo loadbalance probe nqa-task-restrict disable命令用来开启NQA健康检测速率限制功能。
NQA健康检测速率限制功能处于开启状态。
context-admin
工作机制
开启本功能后,设备将对每秒可执行的NQA健康检测任务数进行限制。当新增NQA健康检测任务时,系统会结合当前已启动的所有任务计算设备NQA健康检测速率,并判断是否会超过最大NQA健康检测速率:若未超过,则启动任务;否则,将该任务加入等待队列。
等待队列的任务按以下从高到低的优先级启动(按名称的字典序):
(1)     DNS服务器名称
(2)     链路名称
(3)     实服务器名称
(4)     DNS服务器池成员名称
(5)     链路组成员名称
(6)     实服务组成员名称
而停止任务时则按从低到高的优先级执行。
若设备当前NQA健康检测任务启动速率已经超过最大NQA健康检测速率时,可通过延长健康检测模板的测试间隔或减少检测任务释放出一些资源。
通常情况下,建议开启NQA健康检测速率限制功能,防止任务数过多导致设备资源紧张。而在小型网络或故障排查等无需担心资源争用的场景下,可关闭本功能,以提升健康检测效率。
注意事项
非缺省vSystem不支持本命令。
修改NQA模板的测试间隔时,将首先影响关联该模板的任务启停。
每次启停本功能时,系统都会按照上述原则重新调整所有任务的队列。因此,反复操作可能导致任务队列的顺序变化。
最大NQA健康检测速率与设备型号有关,可以在Probe视图下执行display system internal loadbalance statistics probe命令查看。
# 开启NQA健康检测速率限制功能。
[Sysname] undo loadbalance probe nqa-task-restrict disable
1.1.73  loadbalance policy
loadbalance policy命令用来创建负载均衡策略,并进入负载均衡策略视图。如果指定的负载均衡策略已经存在,则直接进入负载均衡策略视图。
undo loadbalance policy命令用来删除指定的负载均衡策略。
loadbalance policy policy-name [ type link-generic ]
undo loadbalance policy policy-name
不存在任何负载均衡策略。
context-admin
vsys-admin
type link-generic:链路类型的负载均衡策略。非缺省vSystem不支持本参数。
创建负载均衡策略时必须指定类型参数;而在进入已创建的负载均衡策略视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建链路类型的负载均衡策略lbp1,并进入负载均衡策略视图。
[Sysname] loadbalance policy lbp1 type link-generic
[Sysname-lbp-link-generic-lbp1]
1.1.74  loadbalance schedule-test ip
loadbalance schedule-test ip命令用来测试IPv4负载均衡的效果。
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
context-admin
application:测试的应用。
http:应用的类型为HTTP。
message-file file-name:指定HTTP报文内容所在的文件。file-name为文件名,为1~255字符的字符串,不区分大小写。HTTP报文内容所在文件的大小不能大于5000字节。
method:HTTP协议的请求方法。
get:HTTP协议的请求方法为GET。
post:HTTP协议的请求方法为POST。
url url:HTTP报文的URL,为1~255个字符的字符串,区分大小写,可以包含字母、数字、“-”“_”及“.”,不能出现连续“.”,不支持字符“?”。
[ header header ]&<1-10>:HTTP报文首部,为1~127个字符的字符串,区分大小写,不支持字符“?”。&<1-10>表示前面的参数最多可以重复输入10次。
content content-value:HTTP报文体的内容,为1~255个字符的字符串,区分大小写,不支持字符“?”。
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMP(1)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv4地址。
destination-port destination-port:目的端口号,取值范围为0~65535。并非所有协议都支持本参数。
source source-address:源IPv4地址。
source-port source-port:源端口号,取值范围为0~65535。并非所有协议都支持本参数。
slot slot-number:测试指定成员设备,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将测试所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 测试TCP协议IPv4负载均衡的效果。
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
    Matched virtual server: vs2
    Matched default server farm: sf
    Forward type: Forwarding to real server
    Selected real server: rs2
        Scheduling algorithm: Predictor
    Matched default link group: lg
    Forward type: Forwarding to link
    Selected link: link2
表1-22 loadbalance schedule-test ip命令显示信息描述表
匹配的虚服务器名称
No matched virtual servers.
未匹配任何虚服务器
Matched class
匹配的负载均衡类名称
Matched the default class.
匹配了缺省负载均衡动作
匹配的缺省实服务组名称
匹配的缺省链路组名称
Forward type
转发类型,包括:
·     The destination address is not supported. Load balancing is not performed:不支持此目的地址,不进行负载均衡
·     Matching HTTP virtual server is not supported:匹配了HTTP类型的虚服务器,不支持负载均衡
·     Forward all:转发报文
·     Forwarding to real server:将报文转发给实服务器
·     Forwarding to link:将报文转发给链路
·     Drop:丢弃报文
·     Redirect:重定向
·     Waiting:排队等待
Drop reason
丢弃报文的原因,包括:
·     Number of connections or bandwidth for the virtual server exceeded the limit:虚服务器连接数或带宽受限
·     No class matched and no valid default server/link group farm configured:输入的五元组未匹配任何负载均衡类,且未配置有效的缺省实服务器组/链路组
·     No valid real server/link in the server farm/link group:选择的实服务器组/链路组中没有可用的实服务器/链路
·     Action is drop:负载均衡动作为丢弃报文
·     A sticky entry was matched but the number of connections or bandwidth for the real server/link exceeded the limit:匹配的会话保持表项所对应的实服务器/链路连接数或带宽受限
·     A class was matched but no valid server farm/link group exists in the action of the class:匹配的负载均衡类所对应的负载均衡动作中没有可用的实服务组/链路组
·     The HTTP message is not valid:HTTP报文的内容不合法
·     The HTTP request line is not valid:HTTP报文请求行不合法
·     The HTTP header is not valid:HTTP报文首部不合法
·     The chunk HTTP content is not valid:HTTP报文体的chunk编码不合法
·     The server farm is busy:实服务器组繁忙
·     Queue overflow:排队等待的队列长度超出限制
选择的实服务器名称
Selected link
选择的链路名称
选择该实服务器的依据,包括:
·     Predictor:根据调度算法选择了该实服务器/链路
·     Sticky method:根据会话保持方法选择了该实服务器/链路
·     Proximity:根据就近性方法选择了该链路
1.1.75  loadbalance schedule-test ipv6
loadbalance schedule-test ipv6命令用来测试IPv6负载均衡效果。
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
context-admin
application:测试的应用。
http:应用的类型为HTTP。
message-file file-name:指定HTTP报文内容所在的文件。file-name为1~255字符的字符串,不区分大小写。HTTP报文内容所在文件的大小不能大于5000字节。
method:HTTP协议的请求方法。
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMPv6(58)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv6地址。
source source-address:源IPv6地址。
非缺省vSystem不支持本命令。
# 测试ICMPv6协议IPv6负载均衡的效果。
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
表1-23 loadbalance schedule-test ipv6命令显示信息描述表
匹配的虚服务器名称
未匹配任何虚服务器
Matched class
匹配的负载均衡类名称
匹配了缺省负载均衡动作
匹配的缺省实服务组名称
匹配的缺省链路组名称
Forward type
转发类型,包括:
·     Forward all:转发报文
·     Forwarding to real server/link:将报文转发给实服务器/链路
·     Drop:丢弃报文
·     Redirect:重定向
·     Waiting:排队等待
Drop reason
丢弃报文的原因,包括:
·     No class matched and no valid default server farm/link group configured:输入的五元组未匹配任何负载均衡类,且未配置有效的缺省实服务器组/链路组
Selected real server/link
选择的实服务器/链路名称
选择该实服务器/链路的依据,包括:
1.1.76  match
match命令用来为不同类型的报文指定就近性探测方法。
undo match命令用来恢复缺省情况。
match [ match-id ] tcp { lb-probe lb-template | probe nqa-template }
undo match match-id
未指定就近性探测方法。
就近性视图
context-admin
match-id:就近性探测方法的编号,取值范围为1~65535。如果指定编号的就近性探测方法不存在,则创建一个新的就近性探测方法;如果指定编号的就近性探测方法已存在,则对其进行修改。如果未指定本参数,系统将自动分配一个可用的最小编号。
tcp:为TCP类型的报文指定就近性探测方法。
lb-probe lb-template:使用负载均衡探测模板进行探测。lb-template为负载均衡探测模板名称,为1~255个字符的字符串,不区分大小写。
probe nqa-template:使用NQA模板进行探测。nqa-template为NQA模板名称,为1~255个字符的字符串,不区分大小写。
工作机制
配置本命令后,当流量匹配了指定的报文类型,就使用该报文类型所对应的就近性探测方法进行就近性探测。如果流量未匹配任何报文类型,或者未配置本命令,则使用match default命令所指定的默认就近性探测方法进行就近性探测。
每种报文类型只能指定一种就近性探测方法,最后一次执行的生效。
推荐配置
同一就近性视图下,若同时配置本命令和match default命令,则建议均引用NQA模板或均引用负载均衡探测模板,若混合引用则会导致NQA模板引用失效。
注意事项
负载均衡探测模板类型的就近性探测方法不支持对IPv6流量进行就近性探测。
非缺省vSystem不支持本命令。
# 创建ICMP类型的NQA模板t4,并将其指定为TCP类型报文的就近性探测方法。
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-proximity] match tcp probe t4
·     match default
1.1.77  match acl
match acl命令用来创建ACL类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match命令用来删除指定的匹配规则。
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
不存在匹配规则。
负载均衡类视图
context-admin
vsys-admin
match-id:匹配规则的编号,取值范围为1~65535。若未指定本参数,系统将自动分配一个可用的最小编号。
ipv6:表示IPv6 ACL类型。若未指定本参数,表示IPv4 ACL类型。
acl-number:ACL的编号,取值范围为2000~3999。
name acl-name:ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
如果指定编号或名称的ACL不存在,此匹配规则将不参与匹配。
一个负载均衡类中最多允许创建65535条匹配规则。
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc1中,创建ACL类型的匹配规则。
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1] match acl 2000
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc2中,创建ACL类型的匹配规则。
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match acl 2000
# DNS透明代理场景下,在DNS类型的负载均衡类lbc3中,创建ACL类型的匹配规则。
[Sysname] loadbalance class lbc3 type dns
[Sysname-lbc-dns-lbc3] match acl 2000
1.1.78  match app-group
match app-group命令用来创建应用类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match app-group命令用来删除指定的匹配规则。
match [ match-id ] app-group group-name
undo match match-id
负载均衡类中不存在匹配规则。
链路类型的负载均衡类视图
context-admin
app-group group-name:应用组的名称,为1~63个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
如果匹配规则中指定的应用组不存在,则此规则不生效。
# 在链路负载均衡类lbc1中,创建基于应用类型的匹配规则。
[Sysname-lbc-link-generic-lbc1] match app-group http
·     app-group(安全命令参考/APR)
1.1.79  match class
match class命令用来创建嵌套类的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] class class-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
vsys-admin
class-name:要嵌套的负载均衡类名称,为1~255个字符的字符串,不区分大小写。不允许嵌套当前的负载均衡类。
在创建嵌套类的匹配规则时,最多只能嵌套一层。即本命令不能引用已嵌套的负载均衡类。
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc1中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname-lbc-generic-lbc1] match class lbc2
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc3中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname] loadbalance class lbc3 type link-generic
[Sysname-lbc-link-generic-lbc3] match class lbc2
# DNS透明代理场景下,在DNS类型的负载均衡类lbc4中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname] loadbalance class lbc4 type dns
[Sysname-lbc-dns-lbc4] match class lbc2
1.1.80  match default
match default命令用来指定缺省就近性探测方法。
undo match default命令用来恢复缺省情况。
match default { lb-probe lb-template | probe nqa-template }
undo match default
未指定缺省就近性探测方法。
就近性视图
context-admin
工作机制
配置了match命令后,当流量匹配了指定类型的报文,就使用该类型报文所对应的就近性探测方法进行就近性探测。如果流量未匹配任何类型的报文,或者未配置match命令,则使用本命令所指定的默认就近性探测方法进行就近性探测。
推荐配置
同一就近性视图下,若同时配置本命令和match命令,则建议均引用NQA模板或均引用负载均衡探测模板,若混合引用则会导致NQA模板引用失效。
注意事项
非缺省vSystem不支持本命令。
# 创建ICMP类型的NQA模板t4,并将其指定为缺省就近性探测方法。
[Sysname-lb-proximity] match default probe t4
·     loadbalance probe-template
·     match
·     nqa template(网络管理和监控命令参考/NQA)
1.1.81  match destination
match destination命令用来创建目的IP地址类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] destination { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
负载均衡类中不存在匹配规则。
DNS/链路类型的负载均衡类视图
context-admin
ip address ipv4-address:IPv4地址。
mask-length:子网掩码长度,取值范围为0~32,缺省值为32。
mask:子网掩码,缺省值为255.255.255.255。
ipv6 address ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为0~128,缺省值为128。
工作机制
注意事项
非缺省vSystem不支持本命令。
# DNS透明代理场景下,在DNS类型的负载均衡类lbc1中,创建目的IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname] loadbalance class lbc1 type dns
[Sysname-lbc-dns-lbc1] match destination ip address 1.1.1.1
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc2中,创建目的IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-link-generic-lbc2] match destination ip address 1.1.1.1
1.1.82  match destination domain-name
match destination domain-name命令用来创建域名类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] destination domain-name domain-name
undo match match-id
负载均衡类中不存在匹配规则。
链路类型的负载均衡类视图
context-admin
domain-name:域名,为1~253个字符的字符串,不区分大小写。域名由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。域名字符串中可以包含字母、数字、“-”、“_”或“.”。域名支持通配符,允许使用的通配字符包括问号“?”和星号“*”。
工作机制
配置域名时的通配符使用规则如下:
·     问号“?”用于代替域名中的单个字符,域名中的点“.”除外,域名中允许使用多个问号“?”;
·     星号“*”用于代替域名中的多个字符,域名中的点“.”除外,域名中允许使用多个星号“*”;
·     域名中允许同时使用问号“?”和星号“*”
注意事项
非缺省vSystem不支持本命令。
# 在链路类型的负载均衡类lbc1中,创建域名类型的匹配规则:匹配域名www.example.com。
[Sysname-lbc-link-generic-lbc1] match destination domain-name www.example.com
1.1.83  match interface
match interface命令用来创建基于入接口的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] interface interface-type interface-number
undo match match-id
负载均衡类中不存在匹配规则。
通用/链路/HTTP类型的负载均衡类视图
context-admin
interface-type interface-number:指定接口类型和接口编号。接口类型包括三层以太网接口、三层聚合接口。
非缺省vSystem不支持本命令。
如果匹配规则中指定的接口不存在,则此规则不生效。
# 出方向链路负载均衡场景下,在链路负载均衡类lbc1中,创建基于入接口的匹配规则。
[Sysname-lbc-link-generic-lbc1] match interface gigabitethernet 1/0/0
# 服务器负载均衡场景下,在通用负载均衡类lbc2中,创建基于入接口的匹配规则。
[Sysname] loadbalance class lbc2 type generic
[Sysname-lbc-generic-lbc2] match interface gigabitethernet 1/0/0
1.1.84  match isp
match isp命令用来创建ISP类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] isp isp-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
非缺省vSystem不支持本命令。
如果指定名称的ISP不存在或未配置IP网段信息,此匹配规则将不参与匹配。
# 在通用类型的负载均衡类lbc1中,创建ISP类型的匹配规则,匹配名为isp1的ISP。
[Sysname-lbc-generic-lbc1] match isp isp1
1.1.85  match user
match user命令用来创建基于用户的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] [ identity-domain domain-name ] user user-name
undo match match-id
负载均衡类中不存在任何匹配规则。
context-admin
vsys-admin
identity-domain domain-name:表示在指定的身份识别域中匹配此用户。domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括字符“?”。若未指定本参数,则表示在不属于任何身份识别域的用户中匹配此用户。
user-name:用户名,为1~55个字符的字符串,区分大小写。
如果匹配规则中指定的用户不存在,则此规则不生效。
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc1中,创建基于用户的匹配规则为:匹配属于身份识别域domain1的用户u1。
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user u1
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc2中,创建基于用户的匹配规则为:匹配属于身份识别域domain1的用户u1。
[Sysname-lbc-generic-lbc2] match identity-domain domain1 user u1
·     display loadbalance class
1.1.86  match user-group
match user-group命令用来创建基于用户组的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] [ identity-domain domain-name ] user-group user-group-name
undo match match-id
负载均衡类中不存在匹配规则。
context-admin
vsys-admin
identity-domain domain-name:表示在指定的身份识别域中匹配此用户组。domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括字符“?”。若未指定本参数,则表示在不属于任何身份识别域的用户组中匹配此用户组。
user-group-name:用户组名称,为1~200个字符的字符串,不区分大小写。
如果匹配规则中指定的用户组不存在,则此规则不生效。
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc1中,创建基于用户组的匹配规则为:匹配属于身份识别域domain1用户组lb-group。
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user-group lb-group
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc2中,创建基于用户组的匹配规则为:匹配属于身份识别域domain1用户组lb-group。
[Sysname-lbc-generic-lbc2] match identity-domain domain1 user-group lb-group
1.1.87  match source
match source命令用来创建源IP地址类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
vsys-admin
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc1中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-generic-lbc1] match source ip address 1.1.1.1
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc2中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-link-generic-lbc2] match source ip address 1.1.1.1
# DNS透明代理场景下,在DNS类型的负载均衡类lbc3中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-dns-lbc3] match source ip address 1.1.1.1
1.1.88  max-bandwidth
max-bandwidth命令用来配置链路的最大期望带宽。
undo max-bandwidth命令用来恢复缺省情况。
max-bandwidth [ inbound | outbound ] bandwidth-value kbps
undo max-bandwidth [ inbound | outbound ]
链路的最大期望带宽不受限制。
链路视图
context-admin
inbound:配置最大上行期望带宽,即入方向带宽。
outbound:配置最大下行期望带宽,即出方向带宽。
bandwidth-value:最大带宽值,取值范围为1~4294967295,单位为kbps,0表示最大带宽不受限制。
kbps:最大带宽值的单位为kbps。
工作机制
如果未指定inbound和outbound参数,则表示最大总期望带宽,总带宽等于入带宽与出带宽之和。
本命令只在新建会话时生效,对已经存在的会话不生效。
通过本命令配置的最大期望带宽不仅用于带宽繁忙保护功能,还用于带宽算法、最大带宽算法和就近性中剩余带宽的计算。
注意事项
非缺省vSystem不支持本命令。
# 配置链路lk1的最大总期望带宽为1kbps。
[Sysname-lb-link-lk1] max-bandwidth 1 kbps
# 配置链路lk1的最大上行期望带宽为1kbps。
[Sysname-lb-link-lk1] max-bandwidth inbound 1 kbps
# 配置链路lk1的最大下行期望带宽为1kbps。
[Sysname-lb-link-lk1] max-bandwidth outbound 1 kbps
1.1.89  max-number
max-number命令用来配置就近性表项的最大个数。
undo max-number命令用来恢复缺省情况。
max-number number
undo max-number
就近性表项的最大个数为65535。
就近性视图
context-admin
number:就近性表项的最大个数,取值范围为0~10000000,0表示不限制就近性表项的最大个数。
非缺省vSystem不支持本命令。
# 配置就近性表项的最大个数为100。
[Sysname-lb-proximity] max-number 100
1.1.90  override-limit enable
override-limit enable命令用来开启匹配会话保持表项的会话不受连接数限制。
undo override-limit enable命令用来关闭匹配会话保持表项的会话不受连接数限制。
匹配会话保持表项的会话受连接数限制配置的影响。
会话保持组视图
context-admin
vsys-admin
开启该功能后,如果该连接匹配了已有的会话保持表项,将不受实服务器/链路上带宽和连接参数的影响,不受实服务器/链路的带宽繁忙比与最大期望带宽的影响,也不受虚服务器上引用的负载均衡策略连接数限制的影响。
# 配置会话保持组st使其对匹配了该会话保持组生成的会话保持表项的会话不受连接数限制影响。
[Sysname] sticky-group st type address-port
[Sysname-sticky-address-port-st] override-limit enable
1.1.91  packet-loss-rate weight
packet-loss-rate weight命令用来配置就近性计算的丢包率权值。
undo packet-loss-rate weight命令用来恢复缺省情况。
packet-loss-rate weight packet-loss-rate-weight
就近性计算的丢包率权值为0。
就近性视图
context-admin
packet-loss-rate-weight:就近性计算的丢包率权值,取值范围为0~255,数值越大权重越大。
工作机制
通过配置本命令可指定丢包率在计算链路综合开销中的权重。只有开启了就近性功能或配置了链路质量算法,设备才会将丢包率权重作为链路综合开销的计算因素。开启就近性功能与配置链路质量算法互斥。
注意事项
非缺省vSystem不支持本命令。
# 配置就近性计算的丢包率权值为200。
[Sysname-lb-proximity] packet-loss-rate weight 200
·     proximity enable (link group view)
·     predictor (link group view)
1.1.92  parameter (virtual server view)
parameter命令用来指定虚服务器引用的参数模板。
undo parameter命令用来恢复缺省情况。
parameter ip profile-name
undo parameter ip
虚服务器未引用任何参数模板。
虚服务器视图
context-admin
vsys-admin
ip:IP类型的参数模板。
profile-name:参数模板的名称,为1~255个字符的字符串,不区分大小写。
参数模板用来对虚服务器上的流量进行比较深入的解析、处理和优化。虚服务器引用了参数模板后,就要根据该参数模板的配置对匹配流量进行相应的处理。
# 指定LINK-IP类型的虚服务器vs3引用IP类型的参数模板pp2。
[Sysname-vs-link-ip-vs3] parameter ip pp2
1.1.93  parameter-profile
parameter-profile命令用来创建参数模板,并进入参数模板视图。如果指定的参数模板已经存在,则直接进入参数模板视图。
undo parameter-profile命令用来删除指定的参数模板。
parameter-profile profile-name [ type ip ]
undo parameter-profile profile-name
不存在任何参数模板。
context-admin
vsys-admin
type ip:IP类型的参数模板。创建参数模板时必须指定本参数;而在进入已创建的参数模板视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
通过配置参数模板可以进行一些高级参数的配置。这样,当参数模板被虚服务器引用之后,可以对虚服务器的业务流量进行更深入的解析、处理和优化。
# 创建IP类型的参数模板pp2,并进入参数模板视图。
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
1.1.94  port
port命令用来配置虚服务器的端口号。
undo port命令用来恢复缺省情况。
port { port-number [ to port-number ] } &<1-32>
undo port
LINK-IP类型虚服务器的端口号为0(表示任意端口号)。
虚服务器视图
context-admin
vsys-admin
{ port-number [ to port-number ] } &<1-32>:表示一个或多个端口号。其中,port-number为端口号,取值范围为0~65535,0表示任意端口号。&<1-32>表示前面的参数最多可以输入32次。
# 配置LINK-IP类型的虚服务器vs3的端口号为8080。
[Sysname-vs-link-ip-vs3] port 8080
·     ssl-server-policy
1.1.95  predictor (link group view)
predictor命令用来配置链路组的调度算法。
undo predictor命令用来恢复缺省情况。
基于链路:
predictor { least-connection | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
基于链路组成员:
predictor hash address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor { least-connection member | random | round-robin }
undo predictor
链路组的调度算法为加权轮转算法。
链路组视图
context-admin
hash address:根据IP地址进行的哈希算法。
destination:根据目的IP地址进行的哈希算法。
source:根据源IP地址进行的哈希算法。
source-ip-port:根据源IP地址和端口号进行的哈希算法。
mask mask-length: IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
prefix prefix-length:IPv6地址的前缀长度,取值范围为0~128,缺省值为128。
least-connection:基于链路的加权最小连接算法,即总是把新连接分发给加权活动连接数(当前链路在所有链路组中的活动连接总数/权值)最小的链路。该算法中使用的权值为链路视图下配置的权值。
least-connection member:基于链路组成员的加权最小连接算法,即总是将请求分发给加权活动连接数(链路组成员在指定链路组中的活动连接数/权值)最小的链路组成员。该算法中使用的权值为链路组成员视图下配置的权值。
random:随机算法,即把新连接随机分发给每个链路。
round-robin:加权轮转算法,即根据链路权值的大小把新连接依次分发给每个链路,权值越大,分配的新连接越多。该算法中使用的权值为链路组成员视图下配置的权值。
bandwidth:带宽算法,即报文根据链路的权值与剩余带宽乘积后的比例分发到各链路上。例如,对于链路lk1和链路lk2,如果其剩余带宽分别为150kbps和250kbps,而权值分别为5和6,最终lk1和lk2的请求流量分配比例为150×5:250×6,即1:2。该算法中使用的权值为链路视图下配置的权值。
max-bandwidth:最大带宽算法,即报文总是分发给处于空闲状态且带宽最大的链路。例如,对于链路lk1和链路lk2,如果其剩余带宽分别为150kbps和250kbps,两条链路带宽差值为100kbps,此时,当请求流量少于100kbps时,则流量都将分配给lk2;当请求流量大于100kbps时,如130kbps,其中100kbps分配给lk2,其余30kbps流量将平均分配给两条链路。
inbound:根据入方向带宽选择链路。
outbound:根据出方向带宽选择链路。
工作机制
如果未指定inbound和outbound关键字,将根据总带宽来选择链路。
在带宽算法和最大带宽算法中,剩余带宽为链路的最大期望带宽(max-bandwidth)与当前带宽的差值。若未配置最大期望带宽,剩余带宽为链路所允许的最大带宽(rate-limit bandwidth)与当前带宽的差值。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组lg的调度算法为随机算法。
[Sysname-lb-lgroup-lg] predictor random
·     max-bandwidth (link view)
1.1.96  priority (link group member view)
priority命令用来配置链路组成员的调用优先级。
undo priority命令用来恢复缺省情况。
priority priority
undo priority
链路组成员的调度优先级为4。
链路组成员视图
context-admin
priority:链路组成员调用优先级,取值范围为1~8。数值越大,越被优先调用。
工作机制
在链路组范围内,优先级最高的链路组成员参与调度,如果可用链路组成员数量未到达预设的最低门限,则将次高优先级的链路组成员均加入调度,依次类推,直至达到预设的最小参与调度个数或没有可用链路组成员为止。若将某一个优先级的链路组成员均加入调度后,超出了预设的最大参与调度个数,则只加入部分此优先级的链路组成员,此时最终参与调度的可用链路组成员个数将为预设的最大参与调度个数。
注意事项
非缺省vSystem不支持本命令。
本命令与selected-link命令配合使用。
# 配置链路组成员lk1的调用优先级为3。
[Sysname-lb-lgroup-lg-#member#-lk1] priority 3
·     selected-link
1.1.97  priority (link view)
priority命令用来配置链路的调用优先级。
priority priority
undo priority
链路的调用优先级为4。
链路视图
context-admin
priority:优先级。取值范围为1~8,数值越大,优先级越高。
工作机制
通常使用负载分担时,优先使用高优先级的链路处理流量。如果最高优先级链路的个数少于配置的参与调度的最少个数,则在次高优先级中选择链路,达到配置的最少个数。
注意事项
非缺省vSystem不支持本命令。
# 配置链路lk1的调用优先级为3。
[Sysname-lb-link-lk1] priority 3
·     selected-link
1.1.98  probe (link group member view)
probe命令用来指定链路组成员的健康检测方法。
undo probe命令用来恢复缺省情况。
probe template-name
undo probe template-name
未指定链路组成员的健康检测方法。
链路组成员视图
context-admin
template-name:健康检测方法所使用的NQA模板名称,为1~255个字符的字符串,不区分大小写。
工作机制
请使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对链路组成员进行检测,保证其能够提供有效的服务。
用户既可在链路组视图下对组内的所有成员进行配置,也可在链路组成员视图下只对当前链路组成员进行配置,或者在链路视图下只对当前链路进行配置,后两者的配置优先级相同,且高于链路组视图下的健康检测配置。建议优先在链路组视图下配置健康检测。
链路的健康检测结果影响链路组成员的使用,链路组成员的健康检测结果不影响链路的使用。
注意事项
非缺省vSystem不支持本命令。
# 创建ICMP类型的NQA模板t4,并将其指定为链路组成员lk1的健康检测方法。
[Sysname-lb-lgroup-lg-#member#-lk1] probe t4
·     success-criteria (link group member view)
·     probe (link view)
1.1.99  probe (link group view)
probe命令用来指定链路组的健康检测方法。
probe template-name
未指定链路组的健康检测方法。
链路组视图
context-admin
工作机制
链路组采用所引用的NQA模板中定义的链路检测参数来对当前调用的链路进行检测,保证及时发现链路的可用性。
注意事项
非缺省vSystem不支持本命令。
# 创建ICMP类型的NQA模板t4,并将其指定为链路组lg的健康检测方法。
[Sysname-lb-lgroup-lg] probe t4
·     success-criteria(link group view)
·     probe (link view)
1.1.100  probe (link view)
probe命令用来指定链路的健康检测方法。
probe template-name
未指定链路的健康检测方法。
链路视图
context-admin
工作机制
通过配置健康检测方法可以对链路进行检测,保证其能够提供有效的链路,健康检测方法所使用的NQA模板由nqa template命令配置。
同一个链路视图下,可以配置多个链路健康检测方法。系统缺省情况下,只有全部方法通过检测才认为健康检测成功,可通过success-criteria命令配置链路健康检测的成功条件。
注意事项
非缺省vSystem不支持本命令。
# 创建ICMP类型的NQA模板t4,并将其指定为链路lk1的健康检测方法。
[Sysname-lb-link-lk1] probe t4
·     success-criteria (link view)
1.1.101  proximity enable (link group view)
proximity enable命令用来在链路组中开启就近性功能。
undo proximity enable命令用来在链路组中关闭就近性功能。
proximity enable
链路组中的就近性功能处于关闭状态。
链路组视图
context-admin
工作机制
在链路组中开启就近性功能后,负载均衡设备首先按照就近性选择组内的链路,就近性选择失败后再按照调度算法选择链路。
注意事项
非缺省vSystem不支持本命令。
# 在链路组lg中开启就近性功能。
[Sysname-lb-lgroup-lg] proximity enable
1.1.102  rate-limit bandwidth (link view)
rate-limit bandwidth命令用来配置链路所允许的最大带宽。
undo rate-limit bandwidth命令用来恢复缺省情况。
rate-limit bandwidth [ inbound | outbound ] bandwidth-value kbps
undo rate-limit bandwidth [ inbound | outbound ]
链路所允许的最大带宽不受限制。
链路视图
context-admin
inbound:配置最大入带宽。
outbound:配置最大出带宽。
bandwidth-value:最大带宽值,取值范围为0~4294967295,单位为kbps,0表示最大带宽不受限制。
kbps:最大带宽值的单位为kbps。
工作机制
如果未指定inbound和outbound参数,则配置最大总带宽,总带宽等于入带宽与出带宽之和。
本命令不仅在新建会话时生效,对已经存在的会话也生效。
注意事项
非缺省vSystem不支持本命令。
# 配置链路lk1所允许的最大总带宽为1kbps。
[Sysname-lb-link-lk1] rate-limit bandwidth 1 kbps
# 配置链路lk1所允许的最大入带宽为1kbps。
[Sysname-lb-link-lk1] rate-limit bandwidth inbound 1 kbps
# 配置链路lk1所允许的最大出带宽为1kbps。
[Sysname-lb-link-lk1] rate-limit bandwidth outbound 1 kbps
1.1.103  rate-limit bandwidth (virtual server view)
rate-limit bandwidth命令用来配置虚服务器所允许的最大带宽。
虚服务器所允许的最大带宽不受限制。
虚服务器视图
context-admin
vsys-admin
inbound:最大入带宽。
outbound:最大出带宽。
kbps:最大带宽值的单位为kbps。
# 配置IP类型的虚服务器vs3所允许的最大总带宽为1kbps。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] rate-limit bandwidth 1 kbps
# 出方向链路负载均衡场景下,配置LINK-IP类型的虚服务器vs3所允许的最大入带宽为1kbps。
[Sysname-vs-link-ip-vs3] rate-limit bandwidth inbound 1 kbps
1.1.104  rate-limit connection (link group member view)
rate-limit connection命令用来配置链路组成员所允许的最大连接速率。
undo rate-limit connection命令用来恢复缺省情况。
rate-limit connection connection-number
链路组成员所允许的最大连接速率为0。
链路组成员视图
context-admin
connection-number:最大连接速率,取值范围为0~4294967295,单位为个/秒,0表示链路组成员所允许的最大连接速率不受限制。
非缺省vSystem不支持本命令。
# 配置链路组成员lk1所允许的最大连接速率为1000个/秒。
[Sysname-lb-lgroup-lg-#member#-lk1] rate-limit connection 1000
1.1.105  rate-limit connection (link view)
rate-limit connection命令用来配置链路所允许的最大连接速率。
链路所允许的最大连接速率为0。
链路视图
context-admin
connection-number:链路所允许的最大连接速率,取值范围为0~4294967295,0表示链路所允许的最大连接速率不受限制。
非缺省vSystem不支持本命令。
# 配置链路lk1所允许的最大连接速率为10000。
[Sysname-lb-link-lk1] rate-limit connection 10000
1.1.106  rate-limit connection (virtual server view)
rate-limit connection命令用来配置虚服务器所允许的最大连接速率。
虚服务器所允许的最大连接速率为0。
虚服务器视图
context-admin
vsys-admin
connection-number:虚服务器所允许的最大连接速率,取值范围为0~4294967295,0表示虚服务器所允许的最大连接速率不受限制。
# 配置IP类型的虚服务器vs3所允许的最大连接速率为10000。
[Sysname-vs-ip-vs3] rate-limit connection 10000
# 出方向链路负载均衡场景下,配置LINK-IP类型的虚服务器vs2所允许的最大连接速率为10000。
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] rate-limit connection 10000
1.1.107  reset loadbalance connections
reset loadbalance connections命令用来清除负载均衡的应用层连接。
reset loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ slot slot-number ]
context-admin
vsys-admin
client-side:清除客户端的负载均衡连接信息。
server-side:清除服务器端的负载均衡连接信息。
ipv4:IPv4连接。
ipv6:IPv6连接。
cs-client-ip ip-address:指定客户端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
cs-client-port port-number:指定客户端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
ss-client-ip ip-address:指定客户端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
ss-client-port port-number:指定客户端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
cs-server-ip ip-address:指定服务器端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
cs-server-port port-number:指定服务器端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
ss-server-ip ip-address:指定服务器端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
ss-server-port port-number:指定服务器端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
slot slot-number:指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait }:指定TCP连接状态的负载均衡连接信息。若未指定本参数,则清除所有TCP连接状态的负载均衡连接信息。
此命令会将当前所有负载均衡的应用层连接清除,包括连接复用中的空闲连接。
# 清除负载均衡应用层连接。
<Sysname> reset loadbalance connection
1.1.108  reset loadbalance hot-backup statistics
reset loadbalance hot-backup statistics命令用来清除负载均衡热备份的统计信息。
context-admin
vsys-admin
# 清除负载均衡热备份的统计信息。
<Sysname> reset loadbalance hot-backup statistics
1.1.109  reset loadbalance link statistics
reset loadbalance link statistics命令用来清除链路的统计信息。
reset loadbalance link statistics [ link-name ]
context-admin
link-name:链路的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除所有链路的统计信息。
非缺省vSystem不支持本命令。
# 清除所有链路的统计信息。
<Sysname> reset loadbalance link statistics
1.1.110  reset loadbalance link statistics
reset loadbalance link statistics link-group命令用来清除链路组成员的统计信息。
reset loadbalance link statistics link-group link-group-name [ name link-name ]
context-admin
link-group link-group-name:清除指定链路组下链路组成员的统计信息。link-group-name为链路组的名称,为1~255个字符的字符串,不区分大小写。
name link-name:清除指定名称链路组成员的统计信息。link-name为链路组成员的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除指定链路组下所有链路组成员的统计信息。
非缺省vSystem不支持本命令。
# 清除链路组lg下所有链路组成员的统计信息。
<Sysname> reset loadbalance link statistics link-group lg
1.1.111  reset loadbalance probe failed-record
reset loadbalance probe failed-record命令用来清除健康检测失败的历史记录。
reset loadbalance probe failed-record { real-server | link } [ name name ]
context-admin
vsys-admin
real-server:清除实服务器的健康检测失败记录。
link:清除链路的健康检测失败记录。
name name:清除指定名称实服务器或链路的健康检测失败历史记录。为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除所有实服务器或链路的健康检测失败的历史记录。
# 清除所有实服务器记录的健康检测失败信息。
<Sysname> reset loadbalance probe failed-record real-server
1.1.112  reset loadbalance proximity
reset loadbalance proximity命令用来清除就近性表项的信息。
reset loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ traffic-group traffic-group-id ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网实例中的信息。
ip [ ipv4-address ]:清除IPv4就近性表项的信息。如果指定了ipv4-address参数,将清除指定IPv4地址所对应就近性表项的信息;如果未指定ipv4-address参数,将清除所有IPv4就近性表项的信息。
ipv6 [ ipv6-address ]:清除IPv6就近性表项的信息。如果指定了ipv6-address参数,将清除指定IPv6地址所对应就近性表项的信息;如果未指定ipv6-address参数,将清除所有IPv6就近性表项的信息。
traffic-group traffic-group-id:清除指定集群流量组的就近性表项信息。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示清除所有集群流量组的就近性表项信息。
非缺省vSystem不支持本命令。
如果未指定vpn-instance、ip和ipv6关键字,将清除公网实例中所有IPv4和IPv6就近性表项的信息。
# 清除公网实例中所有IPv6就近性表项。
<Sysname> reset loadbalance proximity ipv6
1.1.113  reset virtual-server statistics
reset virtual-server statistics命令用来清除虚服务器的统计信息。
reset virtual-server statistics [ virtual-server-name ]
context-admin
vsys-admin
virtual-server-name:清除指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除所有虚服务器的统计信息。
# 清除所有虚服务器的统计信息。
<Sysname> reset virtual-server statistics
·     display virtual-server statistics
1.1.114  router interface
router interface命令用来配置链路对应的出接口。
undo router interface命令用来删除链路对应的出接口。
router interface interface-type interface-number
未配置链路对应的出接口。
链路视图
context-admin
兼容性说明
本命令与router ip、router ipv6和vpn-instance (link view)命令互斥。
·     配置本命令会覆盖router ip、router ipv6和vpn-instance (link view)命令的配置。
·     配置本命令后,不允许配置vpn-instance (link view)命令。
·     配置router ip或router ipv6命令指定链路通往外网方向的下一跳IP地址后,会覆盖本命令的配置。
应用场景
在出口链路使用PPPoE动态获取IP地址的应用场景下,接口IP地址及其下一跳IP地址都是动态变化的。建议通过配置本命令动态获取IP地址。
工作机制
本命令指定的出接口类型必须为可动态获取IP地址的接口。通过配置本命令,负载均衡设备可通过指定接口动态获取链路通往外网方向的下一跳IP地址。
注意事项
非缺省vSystem不支持本命令。
# 配置链路对应的出接口为Dialer0。
[Sysname] loadbalance link cnc
[Sysname-lb-link-cnc] router interface Dialer0
1.1.115  router ip
router ip命令用来指定链路通往外网方向的下一跳IPv4地址。
undo router ip命令用来恢复缺省情况。
router ip ipv4-address
undo router ip
未配置链路通往外网方向的下一跳IPv4地址。
链路视图
context-admin
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
非缺省vSystem不支持本命令。
一条链路只能配置一个通往外网方向的下一跳IPv4地址。
# 指定链路lk1通往外网方向的下一跳IPv4地址为1.2.3.4。
[Sysname-lb-link-lk1] router ip 1.2.3.4
1.1.116  router ipv6
router ipv6命令用来指定链路通往外网方向的下一跳IPv6地址。
undo router ipv6命令用来恢复缺省情况。
router ipv6 ipv6-address
undo router ipv6
未配置链路通往外网方向的下一跳IPv6地址。
链路视图
context-admin
ipv6-address:IPv6地址信息,不能配置全零地址,组播地址,环回地址,链路本地地址。
非缺省vSystem不支持本命令。
一条链路只能配置一个通往外网方向的下一跳IPv6地址。
# 指定链路lk1通往外网方向的下一跳IPv6地址为8008::8。
[Sysname-lb-link-lk1] router ipv6 8008::8
1.1.117  rtt weight
rtt weight命令用来配置就近性计算的网络延迟权值。
undo rtt weight命令用来恢复缺省情况。
rtt weight rtt-weight
undo rtt weight
就近性计算的网络延迟权值为100。
就近性视图
context-admin
rtt-weight:就近性计算的网络延迟权值,取值范围为0~255,数值越大权重越大。
工作机制
网络延迟参与就近性计算。就近性计算涉及到的因素有:链路的剩余带宽、路由跳数、网络延迟、成本、丢包率等。在复杂多变的网络情况下,通过合理调整就近性因素的权值,以计算出当前网络最优的链路,实现网络流量的最优分配。
注意事项
非缺省vSystem不支持本命令。
# 配置就近性计算的网络延迟权值为200。
[Sysname-lb-proximity] rtt weight 200
1.1.118  selected-link
selected-link命令用来配置链路组中可被调度算法调用的链路数量限制。
undo selected-link命令用来恢复缺省情况。
selected-link min min-number max max-number
undo selected-link
链路组中调用优先级最高的链路全部被调度算法调用。
链路组视图
context-admin
min min-number:可被调度算法调用的链路最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的链路最大数量,取值范围1~1000,且必须大于等于min-number。
工作机制
缺省情况下,一个链路组中调用优先级最高的链路全部可被调度算法调用。通过本命令可以限制可被调度算法调用的链路数量:
·     如果当前调用优先级最高的可用链路数量大于max-number,则只调用其中的max-number条链路。
·     如果当前调用优先级最高的可用链路数量小于min-number,除了调用全部优先级最高的可用链路外,还会调用优先级次高的可用链路,直至调用的可用链路数量达到min-number,或者没有可用的链路可调用为止。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组lg中可被调度算法调用的链路最小数量为20,最大数量为30。
[Sysname-lb-lgroup-lg] selected-link min 20 max 30
·     predictor(link group view)
·     priority(link view)
1.1.119  service enable
service enable命令用来开启虚服务器。
undo service enable命令用来关闭虚服务器。
service enable
undo service enable
虚服务器处于关闭状态。
虚服务器视图
context-admin
vsys-admin
虚服务器是负载均衡功能的关键配置,如果执行undo service enable命令关闭虚服务器功能,会导致匹配此虚服务器的负载均衡业务中断,请谨慎配置。
# 开启IP类型的虚服务器vs3。
[Sysname-vs-ip-vs3] service enable
# 出方向链路负载均衡场景下,开启LINK-IP类型的虚服务器vs2。
[Sysname-vs-link-ip-vs2] service enable
1.1.120  set ip tos (LB action view)
set ip tos命令用来配置发往服务器的IP报文中的ToS字段。
undo set ip tos命令用来恢复缺省情况。
set ip tos tos-number
undo set ip tos
不改变发往服务器的IP报文中的ToS字段。
负载均衡动作视图
context-admin
vsys-admin
tos-number:ToS字段值,取值范围为0~255。
# 在通用类型的负载均衡动作lba1中,配置发往服务器的IP报文中的ToS字段值为20。
[Sysname-lba-generic-lba1] set ip tos 20
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作lba2中,配置发往服务器的IP报文中的ToS字段值为20。
[Sysname-lba-link-generic-lba2] set ip tos 20
# DNS透明代理场景下,在DNS类型的负载均衡动作lba3中,配置发往DNS服务器的IP报文中的ToS字段值为20。
[Sysname-lba-dns-lba3] set ip tos 20
1.1.121  set ip tos (parameter profile view)
set ip tos命令用来配置发往客户端的IP报文中的ToS字段。
undo set ip tos
不改变发往客户端的IP报文中的ToS字段。
参数模板视图
context-admin
vsys-admin
tos-number:ToS字段值,取值范围0~255。
本命令只在IP类型的参数模板视图下支持。
# 在IP类型的参数模板pp2中,配置发往客户端的IP报文中的ToS字段值为20。
[Sysname-para-ip-pp2] set ip tos 20
1.1.122  shutdown (link group member view)
shutdown命令用来关闭链路组成员。
undo shutdown命令用来开启链路组成员。
shutdown
链路组成员处于开启状态。
链路组成员视图
context-admin
非缺省vSystem不支持本命令。
# 关闭链路组成员lk1。
[Sysname-lb-lgroup-lg-#member#-lk1] shutdown
1.1.123  shutdown (link view)
shutdown命令用来关闭当前链路。
undo shutdown命令用来开启当前链路。
shutdown
链路处于开启状态。
链路视图
context-admin
非缺省vSystem不支持本命令。
# 关闭链路lk1。
[Sysname-lb-link-lk1] shutdown
1.1.124  slow-online
slow-online命令用来在链路组中开启链路温暖上线功能。
undo slow-online命令用来在链路组中关闭链路温暖上线功能。
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
链路组中的链路温暖上线功能处于关闭状态。
链路组视图
context-admin
standby-time standby-time:准备时间,取值范围为0~600,单位为秒,缺省值为5秒。
ramp-up-time ramp-up-time:爬升时间,取值范围为3~600,单位为秒,缺省值为5秒。
工作机制
可以通过开启温暖上线功能,解决链路组中新增链路无法立即承担大量业务的问题。当链路组中新增一个可用链路后,在准备时间内,负载均衡设备不会向其分配任何业务;准备时间超时后,负载均衡设备在爬升时间内会逐步增加向其分配的业务量;爬升时间超时后,负载均衡设备开始向其正常分配业务。
注意事项
非缺省vSystem不支持本命令。
# 在链路组lg中开启链路温暖上线功能。
[Sysname-lb-lgroup-lg] slow-online
1.1.125  slow-shutdown enable (link group member view)
slow-shutdown enable命令用来开启链路组成员的慢宕功能。
undo slow-shutdown enable命令用来关闭链路组成员的慢宕功能。
链路组成员的慢宕功能处于关闭状态。
链路组成员视图
context-admin
工作机制
通过shutdown命令可以立即中断链路组成员的已有连接,而慢宕则不会立即中断链路组成员的已有连接,而是让其自然老化,并且不再建立新的连接。
配置准备
本命令需要与shutdown命令配合使用。必须开启了慢宕功能之后再关闭链路组成员,该链路组成员才会开始慢宕。如果先关闭链路组成员,再开启慢宕功能,则慢宕功能不生效,链路组成员处于关闭状态。
注意事项
非缺省vSystem不支持本命令。
# 开启链路组成员lk1的慢宕功能。
[Sysname-lb-lgroup-lg-link-lk1] slow-shutdown enable
·     shutdown (link group member view)
1.1.126  slow-shutdown enable (link view)
slow-shutdown enable 命令用来开启链路的慢宕功能。
undo slow-shutdown enable 命令用来关闭链路的慢宕功能。
链路的慢宕功能处于关闭状态。
链路视图
context-admin
工作机制
通过shutdown命令可以立即中断链路的已有连接,而慢宕则不会立即中断链路的已有连接,而是让其自然老化,并且不再建立新的连接。
配置准备
本命令需要与shutdown命令配合使用。必须开启了慢宕功能之后再关闭链路,该链路才会开始慢宕。如果先关闭链路,再开启慢宕功能,则慢宕功能不生效,链路处于关闭状态。
注意事项
非缺省vSystem不支持本命令。
# 开启链路lk1的慢宕功能。
[Sysname-lb-link-lk1] slow-shutdown enable
·     shutdown(link view)
1.1.127  snat-pool
snat-pool命令用来指定链路组引用的SNAT地址池。
undo snat-pool命令用来恢复缺省情况。
snat-pool pool-name
undo snat-pool
链路组未引用任何SNAT地址池。
链路组视图
context-admin
pool-name:SNAT地址池的名称,为1~255个字符的字符串,不区分大小写。
工作机制
SNAT地址池是一个地址范围,它被链路组引用之后,负载均衡设备将把收到报文的源地址修改为SNAT地址池中的地址后再转发出去。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组lg引用的SNAT地址池为lbsp。
[Sysname-lb-lgroup-lg] snat-pool lbsp
1.1.128  snmp-agent trap enable loadbalance
snmp-agent trap enable loadbalance命令用来开启负载均衡的告警功能。
undo snmp-agent trap enable loadbalance命令用来关闭负载均衡的告警功能。
负载均衡的告警功能处于开启状态。
context-admin
工作机制
开启了负载均衡的告警功能之后,负载均衡会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
注意事项
非缺省vSystem不支持本命令。
# 关闭负载均衡的告警功能。
[Sysname] undo snmp-agent trap enable loadbalance
1.1.129  sticky-group
sticky-group命令用来创建会话保持组,并进入会话保持组视图。如果指定的会话保持组已经存在,则直接进入会话保持组视图。
undo sticky-group命令用来删除指定的会话保持组。
sticky-group group-name [ type address-port ]
undo sticky-group group-name
不存在会话保持组。
context-admin
vsys-admin
group-name:会话保持组的名称,为1~255个字符的字符串,不区分大小写。
type address-port:地址端口类型的会话保持组。创建会话保持组时必须指定本参数;而在进入已创建的会话保持组视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
会话保持组的作用是根据某种会话保持方法将具有一定相关性的会话都分配给同一个链路处理。在一个会话中,当其首包通过会话保持方法选择了链路之后,后续包都会沿用这个选择结果。
# 创建地址端口类型的会话保持组sg1,并进入会话保持组视图。
1.1.130  sticky-over-busy enable
sticky-over-busy enable命令用来开启会话保持处理优先于繁忙功能。
undo sticky-over-busy enable命令用来关闭会话保持处理优先于繁忙功能。
会话保持处理优先于繁忙功能处于关闭状态。
会话保持组视图
context-admin
vsys-admin
若本功能处于开启状态,则在会话保持表项老化之前,无论实服务器是否处于繁忙状态,设备都会依据会话保持表项为其分配流量。
若本功能处于关闭状态,则在会话保持表项老化之前,设备会依据会话保持表项仅为处于正常状态的实服务器分配流量。
# 在地址端口类型的会话保持组sg1中,开启会话保持优先于繁忙功能。
[Sysname-sticky-address-port-sg1] sticky-over-busy enable
1.1.131  sticky-sync enable (virtual server view)
sticky-sync enable命令用来开启虚服务器的会话保持表项全局备份功能。
undo sticky-sync enable命令用来关闭虚服务器的会话保持表项全局备份功能。
sticky-sync enable [ global ]
虚服务器的会话保持表项全局备份功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
global:开启会话保持表项的全局备份功能。无论是否指定本参数,均表示开启会话保持表项的全局备份功能。
工作机制
会话保持表项的全局备份功能用于在所有板卡或设备之间进行备份。
在开启虚服务器的会话保持表项全局备份功能之前,请确保主用和备用设备上均不存在会话保持表项。可以通过先开启会话保持表项全局备份功能,再引用会话保持组,保证备份前设备上不存在会话保持表项。
推荐配置
若设备关闭会话保持表项全局备份功能,则设备会删除当前已有的会话保持表项,后续流量将会重新触发生成新的会话保持表项。
# 开启IP类型的虚服务器vs3的会话保持表项全局备份。
<Sysname>system-view
[Sysname-vs-ip-vs3] sticky-sync enable
# 在出方向链路负载均衡场景下,开启LINK-IP类型的虚服务器vs2的会话保持表项全局备份。
[Sysname-vs-link-ip-vs2] sticky-sync enable
1.1.132  success-criteria (link group member view)
success-criteria命令用来配置链路组成员健康检测的成功条件。
undo success-criteria命令用来恢复缺省情况。
success-criteria { all | at-least min-number }
只有全部方法都通过检测才认为健康检测成功。
链路组成员视图
context-admin
all:只有全部方法都通过检测才认为健康检测成功。
at-least min-number:健康检测成功所需通过检测的最少方法数,取值范围为1~4294967295。
工作机制
当用户指定的最少方法数大于设备上实际存在的方法数量时,系统也将认为健康检测成功。
用户既可在链路组视图下对组内的所有链路组成员进行配置,也可在链路组成员视图下只对当前链路组成员配置,后者的配置优先级高。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组成员lk1的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-lgroup-lg-#member#-lk1] success-criteria at-least 2
1.1.133  success-criteria (link group view)
success-criteria命令用来配置链路组健康检测的成功条件。
链路组视图
context-admin
工作机制
用户既可在链路组视图下对组内的所有链路进行配置,也可在链路视图下只对当前链路进行配置,后者的配置优先级较高。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组lg的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-lgroup-lg] success-criteria at-least 2
·     success-criteria(link view)
1.1.134  success-criteria (link view)
success-criteria命令用来配置链路健康检测的成功条件。
只有全部方法通过检测才认为健康检测成功。
链路视图
context-admin
all:要求链路通过所有方式的健康检测。
at-least min-number:要求链路至少通过指定方式数目的健康检测,取值范围为1~4294967295。
工作机制
当用户指定的最少方法数大于设备上实际存在的方法数量时,只要实际存在的全部方法通过检测,系统就认为健康检测成功。
注意事项
非缺省vSystem不支持本命令。
# 配置链路健康检测的成功条件至少为2个。
[Sysname-lb-link-lk1] success-criteria at-least 2
1.1.135  timeout (proximity view)
timeout命令用来配置就近性表项的老化时间。
undo timeout命令用来恢复缺省情况。
timeout timeout-value
undo timeout
就近性表项的老化时间为60秒。
就近性视图
context-admin
timeout-value:就近性表项的老化时间,取值范围为60~3600,单位为秒。
非缺省vSystem不支持本命令。
# 配置就近性表项的老化时间为80秒。
[Sysname-lb-proximity] timeout 80
1.1.136  timeout (sticky group view)
timeout命令用来配置会话保持表项的超时时间。
timeout { indefinite | timeout-value }
undo timeout
地址端口类型的会话保持表项的超时时间为60秒。
会话保持组视图
context-admin
vsys-admin
indefinite:表示会话保持表项不老化。
timeout-value:超时时间。取值范围为10~604800,单位为秒。
# 在地址端口类型的会话保持组sg1中,配置会话保持表项的超时时间为100秒。
[Sysname-sticky-address-port-sg1] timeout 100
1.1.137  transparent enable
transparent enable命令用来在链路组中关闭NAT功能。
undo transparent enable命令用来在链路组中开启NAT功能。
transparent enable
链路组中的NAT功能处于开启状态。
链路组视图
context-admin
非缺省vSystem不支持本命令。
# 在链路组lg中关闭NAT功能。
[Sysname-lb-lgroup-sinalab] transparent enable
1.1.138  ttl weight
ttl weight命令用来配置就近性计算的路由跳数权值。
undo ttl weight命令用来恢复缺省情况。
ttl weight ttl-weight
undo ttl weight
就近性计算的路由跳数权值为100。
就近性视图
context-admin
ttl-weight:就近性计算的路由跳数权值,取值范围为0~255,数值越大权重越大。
工作机制
网络跳数参与就近性计算。就近性计算涉及到的因素包括:链路的剩余带宽、路由跳数、网络延迟、成本、丢包率等。在复杂多变的网络情况下,通过合理调整就近性因素的权值,以计算出当前网络最优的链路,实现网络流量的最优分配。
例如,在某些网络环境下关键指标为网络跳数,但各链路下的剩余带宽不同,此时可以通过减小带宽的计算权值,提高路由跳数的计算权值,以减少带宽的影响,突出TTL的结果,从而实现更精准的链路选择。
注意事项
非缺省vSystem不支持本命令。
# 配置就近性计算的路由跳数权值为200。
[Sysname-lb-proximity] ttl weight 200
1.1.139  virtual ip address
virtual ip address命令用来配置虚服务器的IPv4地址(即VSIP)。
undo virtual ip address命令用来恢复缺省情况。
virtual ip address ipv4-address [ mask-length | mask ]
未配置虚服务器的IPv4地址。
虚服务器视图
context-admin
vsys-admin
ipv4-address:虚服务器的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X(如果掩码长度不是32,则可以配置0.X.X.X)。
若虚服务器的IP地址与设备连接客户端的接口IP地址在同一网段,则必须配置虚服务器IPv4地址的掩码长度为32位,且必须通过执行arp-nd interface (virtual server view)命令指定发送免费ARP报文或ND报文的接口。否则,无需指定发送免费ARP报文或ND报文的接口。
# 配置LINK-IP类型的虚服务器vs3的IP地址为1.1.1.1/24。
[Sysname-vs-link-ip-vs3] virtual ip address 1.1.1.1 24
·     arp-nd interface (virtual server view)
1.1.140  virtual ipv6 address
virtual ipv6 address命令用来配置虚服务器的IPv6地址(即VSIP)。
undo virtual ipv6 address命令用来恢复缺省情况。
virtual ipv6 address ipv6-address [ prefix-length ]
未配置虚服务器的IPv6地址。
虚服务器视图
context-admin
vsys-admin
ipv6-address:虚服务器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址(如果前缀长度为0,则可以配置全0地址)。
若虚服务器的IP地址与设备连接客户端的接口IP地址在同一网段,则必须配置虚服务器IPv6地址的前缀长度为128位,且必须通过执行arp-nd interface (virtual server view)命令指定发送免费ARP报文或ND报文的接口。否则,无需指定发送免费ARP报文或ND报文的接口。
# 配置LINK-IP类型的虚服务器vs3的IPv6地址为1001::1/64。
[Sysname-vs-link-ip-vs3] virtual ipv6 address 1001::1 64
1.1.141  virtual-server
virtual-server命令用来创建虚服务器,并进入虚服务器视图。如果指定的虚服务器已经存在,则直接进入虚服务器视图。
undo virtual-server命令用来删除指定的虚服务器。
virtual-server virtual-server-name [ type link-ip ]
undo virtual-server virtual-server-name
不存在任何虚服务器。
context-admin
vsys-admin
virtual-server-name:虚服务器的名称,为1~255个字符的字符串,不区分大小写。
type link-ip:LINK-IP类型的虚服务器。创建虚服务器时必须指定本参数;进入已创建的虚服务器视图时可以不指定本参数,若要指定本参数,则必须与创建时的类型一致。
# 创建LINK-IP类型的虚服务器vs3,并进入虚服务器视图。
1.1.142  vpn-instance (link view)
vpn-instance命令用来指定链路所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
链路属于公网。
链路视图
context-admin
vpn-instance-name:MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
配置准备
在执行本命令前,用户需要执行ip vpn-instance命令来创建VPN实例。若指定的VPN实例为未创建的VPN实例,则链路状态为不可用。
注意事项
非缺省vSystem不支持本命令。
# 指定链路lk1所属的VPN实例为vpn1。
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] vpn-instance vpn1
1.1.143  vpn-instance (virtual server view)
vpn-instance命令用来指定虚服务器所属的VPN。
undo vpn-instance
虚服务器属于公网。
虚服务器视图
context-admin
非缺省vSystem不支持本命令。
管理员可以在配置虚服务器IP地址时,为指定虚服务器IP配置所属的VPN实例;也可以通过本命令对未指定VPN实例的虚服务器IP批量配置所属的VPN实例,前者的优先级较高。
虚服务器所属VPN实例发生变化时,现有会话将被删除,已有业务流量可能发生中断。
# 指定IP类型的虚服务器vs3所属的VPN为vpn1。
[Sysname-vs-ip-vs3] vpn-instance vpn1
# 出方向链路负载均衡场景下,指定LINK-IP类型的虚服务器vs3所属的VPN为vpn1。
[Sysname-vs-link-ip-vs2] vpn-instance vpn1
1.1.144  weight (link group member view)
weight命令用来配置链路组成员的权值。
undo weight命令用来恢复缺省情况。
weight weight-value
undo weight
链路组成员的权值为100。
链路组成员视图
context-admin
weight-value:链路组成员的权值,取值范围为1~255。
工作机制
通过本命令配置的权值主要被加权最小连接算法和加权轮转算法使用,该数值越大,对应的链路组成员越被优先调用。
注意事项
非缺省vSystem不支持本命令。
# 配置链路组成员lk1的权值为150。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg-#member#-lk1] weight 150
1.1.145  weight (link view)
weight命令用来配置链路的权值,即加权轮转和加权最小连接这两种调度算法所使用的权值。
weight weight-value
undo weight
链路的权值为100。
链路视图
context-admin
weight-value:权值,取值范围为1~255。在加权轮转和加权最小连接调度时,该数值越大,链路越被优先调用。
非缺省vSystem不支持本命令。
# 配置链路lk1的权值为150。
[Sysname-lb-link-lk1] weight 150
1.1.146  whois-mntner
whois-mntner命令用来配置当前ISP的WHOIS服务器管理标识。
undo whois-mntner命令用来删除当前ISP的指定WHOIS服务器管理标识。
whois-mntner mntner-name
undo whois-mntner mntner-name
未配置当前ISP的WHOIS服务器管理标识。
ISP视图
context-admin
mntner-name:WHOIS服务器管理标识的名称,为1~63个字符的字符串,区分大小写。
工作机制
用户通过配置本命令可以指定WHOIS服务器进行ISP信息更新的区域标识,对指定地理区域的ISP信息进行更新。
在同一ISP视图下,最多允许配置10个WHOIS服务器管理标识。
WHOIS服务器管理标识全局唯一。
注意事项
非缺省vSystem不支持本命令。
# 在ISP视图下,配置当前ISP的WHOIS服务器管理标识为中国电信MAINT-CHINANET。
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] whois-mntner MAINT-CHINANET
