04-二层技术-以太网交换命令参考
05-VLAN命令
本章节下载: 05-VLAN命令  (751.78 KB)
05-VLAN命令
1 VLAN
1.1 VLAN配置命令
1.1.1 bandwidth
1.1.2 broadcast-suppression
1.1.3 control-packet dot1p
1.1.4 default
1.1.5 description
1.1.6 display interface vlan-interface
1.1.7 display vlan
1.1.8 display vlan brief
1.1.9 display vlan statistics
1.1.10 interface vlan-interface
1.1.11 mac-address
1.1.12 mtu
1.1.13 name
1.1.14 port outbound-vlan-tag enable
1.1.15 reset counters interface vlan-interface
1.1.16 reset vlan statistics
1.1.17 service
1.1.18 shutdown
1.1.19 statistics enable
1.1.20 traffic-statistic enable
1.1.21 vlan
1.2 基于端口的VLAN配置命令
1.2.1 display port
1.2.2 port
1.2.3 port access vlan
1.2.4 port hybrid pvid
1.2.5 port hybrid vlan
1.2.6 port link-type
1.2.7 port trunk permit vlan
1.2.8 port trunk pvid
1.3 基于MAC的VLAN配置命令
1.3.1 display mac-vlan
1.3.2 display mac-vlan interface
1.3.3 mac-vlan enable
1.3.4 mac-vlan mac-address
1.3.5 mac-vlan trigger enable
1.3.6 port pvid forbidden
1.4 基于IP子网的VLAN配置命令
1.4.1 display ip-subnet-vlan interface
1.4.2 display ip-subnet-vlan vlan
1.4.3 ip-subnet-vlan
1.4.4 port hybrid ip-subnet-vlan
1.5 基于协议的VLAN配置命令
1.5.1 display protocol-vlan interface
1.5.2 display protocol-vlan vlan
1.5.3 port hybrid protocol-vlan
1.5.4 protocol-vlan
1.6 ARP泛洪抑制配置命令
1.6.1 arp suppression enable
1.6.2 display arp suppression vlan
1.6.3 reset arp suppression vlan
1.7 VLAN组配置命令
1.7.1 display vlan-group
1.7.2 vlan-group
1.7.3 vlan-list
2 Super VLAN
2.1 Super VLAN配置命令
2.1.1 display supervlan
2.1.2 subvlan
2.1.3 supervlan
3 Private VLAN
3.1 Private VLAN配置命令
3.1.1 display private-vlan
3.1.2 port private-vlan host
3.1.3 port private-vlan promiscuous
3.1.4 port private-vlan trunk promiscuous
3.1.5 port private-vlan trunk secondary
3.1.6 private-vlan (VLAN interface view)
3.1.7 private-vlan (VLAN view)
3.1.8 private-vlan community
3.1.9 private-vlan isolated
3.1.10 private-vlan primary
4 Voice VLAN
4.1 Voice VLAN配置命令
4.1.1 display voice-vlan mac-address
4.1.2 display voice-vlan state
4.1.3 voice-vlan acl-resource-mode
4.1.4 voice-vlan aging
4.1.5 voice-vlan enable
4.1.6 voice-vlan mac-address
4.1.7 voice-vlan mode auto
4.1.8 voice-vlan qos
4.1.9 voice-vlan qos trust
4.1.10 voice-vlan security enable
4.1.11 voice-vlan track lldp
1 VLAN
1.1  VLAN配置命令
1.1.1  bandwidth
bandwidth命令用来配置VLAN接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VLAN接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置VLAN接口1的期望带宽为10000kbps。
[Sysname-Vlan-interface1] bandwidth 10000
broadcast-suppression命令用来开启VLAN的广播风暴抑制功能,并设置广播风暴抑制阈值。
undo broadcast-suppression命令用来关闭VLAN的广播风暴抑制功能。
broadcast-suppression kbps max-kbps
不对VLAN下的广播报文进行抑制。
VLAN视图
kbps max-kbps:指定以太网接口每秒最多通过的组播流量,单位为kbps,取值范围为64~
10000000。
当网络中的广播报文增多时,广播报文占用的网络资源将随之增多,进而严重影响了网络业务的正常运行。
执行本命令后,设备将对指定VLAN下的广播报文进行抑制,超过抑制速率的报文将被丢弃。
# 在VLAN 10下开启VLAN的广播风暴抑制功能,并设置广播风暴抑制阈值为1000kbit/s。
[Sysname] vlan 10
[Sysname-vlan10] broadcast-suppression kbps 1000
control-packet dot1p命令用来配置设备发送的协议报文的802.1p优先级。
undo control-packet dot1p命令用来恢复缺省情况。
control-packet dot1p priority
设备发送的协议报文的802.1p优先级为6。
priority:协议报文的802.1p优先级,取值范围为0~7。0级为最低优先级,7级为最高优先级。
缺省情况下,设备发送的协议报文的802.1p优先级为6。但某些设备收到优先级为6的报文后会丢弃或不处理,影响了各类协议在网络中的正常运行。此时需要通过本命令修改本设备发送的协议报文的802.1p优先级。
配置本命令后,会修改设备发送的以下类型协议报文的802.1p优先级:ARP、NTP、OSPF、BGP、PIM、SSH、Telnet和LDP。建议您在执行该命令前,完全了解其对网络产生的影响。
# 配置设备发送的协议报文的802.1p优先级为7。
[Sysname] control-packet dot1p 7
1.1.4  default
default命令用来恢复VLAN接口的缺省配置。
default
VLAN接口视图
接口下的某些配置取消后,会对现有功能产生影响,建议您在执行该命令前,完全了解其对网络产生的影响。
# 将VLAN接口1恢复为缺省配置。
[Sysname-Vlan-interface1] default
1.1.5  description
description命令用来配置VLAN或VLAN接口的描述信息。
undo description命令用来恢复缺省情况。
VLAN的描述信息为“VLAN vlan-id”,其中vlan-id为该VLAN的四位数编号,如果该VLAN的编号不足四位,则会在编号前增加0,补齐四位。例如,VLAN 100的描述信息为“VLAN 0100”;VLAN接口的描述信息为该VLAN接口的接口名,如“Vlan-interface1 Interface”。
VLAN视图
VLAN接口视图
text:VLAN或VLAN接口的描述信息,为1~255个字符的字符串,区分大小写。
用户可以根据功能或者连接情况为VLAN或VLAN接口配置特定的描述信息,以便记忆和管理VLAN或VLAN接口。
# 将VLAN 2的描述信息配置为sales-private。
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# 将VLAN接口2的描述信息配置为linktoPC56。
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
·     display interface vlan-interface
·     display vlan
display interface vlan-interface命令用来显示VLAN接口的相关信息。
display interface [ vlan-interface [ interface-number ] ] [ brief [ description | down ] ]
vlan-interface interface-number:VLAN接口的编号,显示指定VLAN接口的信息。如果不指定vlan-interface参数,将显示设备支持的所有接口的相关信息;如果指定vlan-interface参数,不指定interface-number参数,将显示已创建的所有VLAN接口的信息。
description:用来显示用户配置的接口的全部描述信息。如果不指定该description参数,只显示描述信息中的前25个字符。
# 显示VLAN-interface 10的相关信息。
<Sysname> display interface vlan-interface 10
Vlan-interface10
Current state: UP
Line protocol state: UP
Description: Vlan-interface10 Interface
Bandwidth: 100000 kbps
Internet Address is 192.168.1.54/24 Primary
IP packet frame type: Ethernet II, hardware address: 0023-89b6-d613
IPv6 packet frame type: Ethernet II, hardware address: 0023-89b6-d613
Traffic statistic: Not include Inter-frame Gaps and Preambles
# 显示VLAN-interface 2的概要信息。
<Sysname> display interface vlan-interface 2 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP         Description
Vlan2                DOWN DOWN     --                 aaaaaaaaaaaaaaaaaaaaaaaaa
表1-1 display interface vlan-interface命令显示信息描述表
Vlan-interface2
VLAN接口名
Current state
VLAN接口的物理状态,状态可能为:
·     Administratively DOWN:表示该VLAN接口已经通过shutdown命令被关闭,即管理状态为关闭
·     DOWN:表示该VLAN接口的管理状态为开启,但物理状态为关闭,即该接口对应的VLAN内没有处于UP状态的物理端口(可能因为没有物理连线或者线路故障)
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
VLAN接口的链路层协议状态,状态可能为:
·     DOWN:该VLAN接口的协议状态为关闭
·     UP:该VLAN接口的协议状态为开启
VLAN接口的描述信息
Bandwidth
VLAN接口的期望带宽
VLAN接口允许通过的MTU
Internet protocol processing : Disabled
该接口还不具有处理IP报文的能力,当没有为该接口配置IP地址时会显示该信息
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     Unnumbered:借用其他接口的IP地址
·     MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术配置指导”中的“IRF”
IPv4发送帧格式
hardware address
VLAN接口对应的MAC地址
IPv6发送帧格式
最近一次使用reset counters interface vlan-interface命令清除接口下的统计信息的时间。如果从设备启动一直没有执行reset counters interface vlan-interface命令清除过该接口下的统计信息,则显示Never
Last hardware down reason
接口最近一次硬件down的原因:
·     PHY line side is down:PHY线路侧down
·     PHY system side is down:PHY系统侧down
·     No optical signal has been received at the optical port:光口未收到光信号
·     “-”表示接口最近没有硬件down
Traffic statistic
统计接口平均速率时是否包含帧间隙和前导码
·     Include Inter-frame Gaps and Preambles:包含帧间隙和前导码
·     Not include Inter-frame Gaps and Preambles:不包含帧间隙和前导码
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
接口名称缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上是不通的
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层协议状态为开启
·     DOWN:表示接口的数据链路层协议状态为关闭
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
Primary IP
接口主IP地址
·     reset counters interface vlan-interface
1.1.7  display vlan
display vlan命令用来显示VLAN的相关信息。
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
vlan-id1:显示指定VLAN的信息。vlan-id1为VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:显示ID在指定范围内的VLAN的信息。vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094。vlan-id2的值要大于或等于vlan-id1的值。
all:显示除保留VLAN外的其他VLAN的信息。
dynamic:显示系统动态创建的VLAN的数量和编号。动态VLAN是指通过MVRP协议生成或通过RADIUS服务器下发的VLAN。
reserved:显示系统保留VLAN的信息。保留VLAN是设备根据功能实现的需要预留的VLAN。保留VLAN由协议模块来指定,为协议模块服务,用户不能对保留VLAN进行任何操作。
static:显示系统静态创建的VLAN的数量和VLAN编号。静态VLAN是指通过命令行手工创建的VLAN。
# 显示VLAN 2的信息。
<Sysname> display vlan 2
 VLAN ID: 2
 VLAN type: Static
 Description: VLAN 0002
 Tagged ports:
    None
 Untagged ports:
    Ten-GigabitEthernet1/0/1(U)        Ten-GigabitEthernet1/0/2(U)
    Ten-GigabitEthernet1/0/3(D)
# 显示VLAN 3的信息。
<Sysname> display vlan 3
 VLAN ID: 3
 VLAN type: static
 Route interface: Configured
 IPv4 address: 1.1.1.1
 IPv4 subnet mask: 255.255.255.0
 Description: VLAN 0003
 Tagged ports:
    None
 Untagged ports:
    None
表1-2 display vlan命令显示信息描述表
解释
VLAN ID
VLAN的编号
VLAN type
VLAN的类型:
·     Static:静态VLAN
·     Dynamic:动态VLAN
Route interface
设备上是否创建了对应的VLAN接口:
·     Not configured:未创建
·     Configured:已创建
VLAN的描述信息
Name
VLAN的名称
IP address
VLAN接口的主用IP地址,如果VLAN接口没有配置IP地址,则不显示该字段。如果VLAN接口上还配置了从IP地址,可以使用display interface vlan-interface或者在VLAN接口视图下使用display this命令查看
Subnet mask
VLAN接口的主用IP地址的子网掩码,如果VLAN接口没有配置IP地址,则不显示该字段
Tagged ports
该VLAN报文从哪些端口发送时需要携带Tag标记,以及这些端口的状态信息:
·     (U):表示该端口物理上是连通的
·     (D):表示该端口物理上不通
·     None:表示不存在这样的端口
Untagged ports
该VLAN报文从哪些端口发送时不需要携带Tag标记,以及这些端口的状态信息:
·     (U):表示该端口物理上是连通的
·     (D):表示该端口物理上不通
·     None:表示不存在这样的端口
·     vlan
display vlan brief命令用来显示设备上所有已创建VLAN的概要信息。
display vlan brief
# 显示设备上所有已创建VLAN的概要信息。
<Sysname> display vlan brief
Brief information about all VLANs:
Supported Minimum VLAN ID: 1
Supported Maximum VLAN ID: 4094
Default VLAN ID: 1
VLAN ID   Name                           Port
1         VLAN 0001                      XGE1/0/1(U)  XGE1/0/2(D)  XGE1/0/3(U)
                                         XGE1/0/4(U)  XGE1/0/5(D)  XGE1/0/6(D)
2         VLAN 0002
3         VLAN 0003
表1-3 display vlan brief命令显示信息描述表
所有VLAN的概要信息
系统支持的最小VLAN ID
系统支持的最大VLAN ID
Default VLAN ID
缺省VLAN ID
VLAN ID
VLAN的编号
Name
VLAN的名称
Port
允许该VLAN报文通过的端口,以及这些端口的状态信息:
·     (U):表示该端口物理上是连通的
·     (D):表示该端口物理上不通
display vlan statistics命令用来显示指定VLAN的流量统计信息。
(独立运行模式)‌
display vlan vlan-id statistics [ slot slot-number ]
display vlan vlan-id statistics [ chassis chassis-number slot slot-number ]
vlan-id:VLAN的编号,取值范围为1~4094。
slot slot-number:显示指定单板的VLAN流量统计信息,slot-number表示单板所在的槽位号。如果不指定该参数,将显示所有单板上的VLAN流量统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的VLAN流量统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,将显示所有单板上的VLAN流量统计信息。(IRF模式)‌
# 显示指定slot上VLAN 2的流量统计信息。
<Sysname> display vlan 2 statistics slot 1
Slot 1:
Direction       Total packets        Total bytes
                Rate (pps)           Rate (Bps)
Inbound         5824579              745546112
                0                    0
Outbound        0                    0
                0                    0
Direction       IPv4 packets         IPv4 bytes
                0                    0
Outbound        0                    0
                0                    0
Direction       IPv6 packets         IPv6 bytes
Inbound         0                    0
                0                    0
Outbound        0                    0
                0                    0
# 显示VLAN 2上的流量统计信息。
Slot 1:
                0                    0
Outbound        0                    0
                0                    0
                0                    0
Outbound        0                    0
                0                    0
Inbound         0                    0
                0                    0
Outbound        0                    0
                0                    0
Slot 2:
Inbound         0                    0
                0                    0
Outbound        0                    0
                0                    0
Inbound         0                    0
                0                    0
Outbound        0                    0
                0                    0
Inbound         0                    0
                0                    0
Outbound        0                    0
                0                    0
Total:
                0                    0
Outbound        0                    0
                0                    0
                0                    0
Outbound        0                    0
                0                    0
Inbound         0                    0
                0                    0
Outbound        0                    0
                0                    0
表1-4 display vlan statistics显示信息描述表
Direction
VLAN流量统计方向:
·     Inbound:入方向流量
·     Outbound:出方向流量
Total packets
总包数
Total bytes
总字节数
IPv4 packets
IPv4协议总包数
IPv4 bytes
IPv4协议总字节数
IPv6 packets
IPv6协议总包数
IPv6 bytes
IPv6协议总字节数
Rate (pps)
速率,单位为pps(packets per second)
Rate (Bps)
速率,单位为Bps(bytes per second)
·     statistics enable
·     reset vlan statistics
interface vlan-interface命令用来创建VLAN接口并进入VLAN接口视图。如果该VLAN接口已经存在,则直接进入VLAN接口视图。
undo interface vlan-interface命令用来删除指定的VLAN接口。
undo interface vlan-interface interface-number
不存在VLAN接口。
interface-number:VLAN接口的编号,取值范围为1~4094。
在创建VLAN接口之前,对应的VLAN必须已经存在,否则将不能创建指定的VLAN接口。
# 创建VLAN接口2并进入视图。
[Sysname] vlan 2
1.1.11  mac-address
mac-address命令用来配置VLAN接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
未配置VLAN接口的MAC地址。
VLAN接口视图
mac-address:MAC地址,形式为H-H-H。
# 配置VLAN接口2的MAC地址为0001-0001-0001。
[Sysname-Vlan-interface2] mac-address 1-1-1
1.1.12  mtu
mtu命令用来配置VLAN接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VLAN接口的MTU值为1500字节。
VLAN接口视图
size:表示接口允许通过的MTU(Maximum Transmission Unit,最大传输单元)值的大小,单位为字节。取值范围为46~10240  。
如果当前接口同时配置mtu和ip mtu命令,则设备会以ip mtu命令配置的接口MTU值对报文进行分片,不会再按照mtu命令配置的MTU值对报文进行分片。有关ip mtu命令的详细介绍,请参见“三层技术-IP业务命令参考”中的“IP性能优化”。
# 配置VLAN接口1的MTU值为1492字节。
[Sysname-Vlan-interface1] mtu 1492
1.1.13  name
name命令用来指定当前VLAN的名称。
undo name命令用来恢复缺省情况。
name text
undo name
VLAN的名称为“VLAN vlan-id”,其中vlan-id为该VLAN的四位数编号,如果该VLAN的编号不足四位,则会在编号前增加0,补齐四位。例如,VLAN 100的名称为“VLAN 0100”。
VLAN视图
text:VLAN名称,为1~32个字符的描述信息,区分大小写。
当设备上配置了802.1X或MAC地址认证功能后,可以通过RADIUS服务器来对认证通过的端口下发VLAN。某些RADIUS服务器可以向设备发送需要下发的VLAN编号或者VLAN名称,当VLAN数量很多的时候,使用名称可以更明确的定位VLAN。
# 指定VLAN 2的名称为“test vlan”。
[Sysname] vlan 2
[Sysname-vlan2] name test vlan
·     display vlan
port outbound-vlan-tag enable命令用来开启端口发送协议报文时设置VLAN Tag功能。
undo port outbound-vlan-tag enable命令用来关闭端口发送协议报文时设置VLAN Tag的功能。
端口发送协议报文时设置VLAN Tag功能处于关闭状态。
二层以太网接口视图
开启本功能后,端口接收到LACP或BFD协议报文时,会记录报文携带的VLAN Tag(无论携带了几层VLAN Tag)。当本端口发送相同的协议报文时,设备会将这些报文的VLAN Tag设置为之前记录的VLAN Tag,无论该端口的类型是否允许在发送报文时携带这些VLAN Tag。有关LACP的详细介绍,请参见“二层技术-以太网交换配置指导”中的“以太网链路聚合”;有关BFD的详细介绍,请参见“可靠性配置指导”中的“BFD”。
在端口上执行了port outbound-vlan-tag enable命令后,若再执行undo port outbound-vlan-tag enable命令,会导致该端口上的BFD会话down,请谨慎执行此配置。
聚合组成员端口配置本命令时不对其他成员端口造成影响,也不影响聚合组成员端口的选中状态,若要保持聚合组的配置一致性,请手动在所有成员端口上配置本命令。
# 开启端口Ten-GigabitEthernet1/0/1发送协议报文时设置VLAN Tag功能。
<System> system-view
[System] interface ten-gigabitethernet 1/0/1
[System-Ten-GigabitEthernet1/0/1] port outbound-vlan-tag enable
reset counters interface vlan-interface命令用来清除VLAN接口的统计信息。
reset counters interface [ vlan-interface [ interface-number ] ]
vlan-interface interface-number:VLAN接口的编号,清除指定VLAN接口的统计信息。如果不指定vlan-interface参数,则清除所有接口的统计信息;如果指定vlan-interface参数,不指定interface-number参数,则清除所有VLAN接口的统计信息。
# 清除VLAN接口2的统计信息。
<Sysname> reset counters interface vlan-interface 2
reset vlan statistics命令用来清除指定VLAN的流量统计信息。
(独立运行模式)‌
reset vlan vlan-id statistics [ slot slot-number ]
reset vlan vlan-id statistics [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的VLAN流量统计信息,slot-number表示单板所在的槽位号。如果不指定该参数,将清除所有单板上的VLAN流量统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的VLAN流量统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,将清除所有单板上的VLAN流量统计信息。(IRF模式)‌
# 清除VLAN 2的流量统计信息。
<Sysname> reset vlan 2 statistics
·     statistics enable
·     display vlan statistics
1.1.17  service
service命令用来配置处理当前接口流量的slot。
undo service命令用来恢复缺省情况。
(独立运行模式)‌
service slot slot-number
undo service slot
service chassis chassis-number slot slot-number
undo service chassis
未配置处理当前接口流量的slot,业务处理在接收报文的slot上进行。
VLAN接口视图
slot slot-number:指定单板所在的槽位号。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
当要求同一个VLAN接口的流量必须在同一个slot上进行处理,此时可以在VLAN接口下通过service命令配置处理当前接口流量的slot。
执行本命令前,需要确保指定的slot可用。如果指定的slot不可用,流量不会被处理;如果该slot恢复可用,则流量可以继续在指定slot上进行处理。
# 配置在指定slot上处理VLAN接口2的流量。
[Sysname] vlan 2
[Sysname-Vlan-interface2] service slot 2
1.1.18  shutdown
shutdown命令用来手工关闭VLAN接口。
undo shutdown命令用来手工开启VLAN接口。
shutdown
VLAN接口未手工关闭。
VLAN接口视图
执行本命令会导致使用该VLAN接口建立的链路中断,不能通信,请谨慎使用。
如果未手工关闭VLAN接口,此时VLAN接口状态受VLAN中端口状态的影响,即:
·     当VLAN中所有以太网端口状态均为down时,VLAN接口为down状态,即关闭状态。
·     当VLAN中有一个或一个以上的以太网端口处于up状态时,则VLAN接口处于up状态。
如果手工关闭VLAN接口,则VLAN接口的状态始终为down(Administratively),不受VLAN中端口状态的影响。
配置VLAN接口参数前,为了避免配置过程中对网络造成影响,建议先使用shutdown命令手工关闭接口,之后再配置参数。配置完成后,使用undo shutdown命令取消手工关闭接口,使配置的参数生效。
当VLAN接口出现故障时,可以使用shutdown命令手工关闭接口,然后再使用undo shutdown命令取消手工关闭接口,这样有可能使接口恢复正常。
关闭和打开VLAN接口对于属于这个VLAN的任何一个以太网端口本身都不起作用,以太网端口的状态不随VLAN接口状态的改变而改变。
# 将VLAN接口2关闭后再重新打开。
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
statistics enable命令用来开启VLAN的流量统计功能。
undo statistics enable命令用来关闭VLAN的流量统计功能。
statistics enable
VLAN流量统计功能处于关闭状态。
VLAN视图
当您需要检查网络状况或者处理网络故障时,可以在设备上打开VLAN的流量统计功能,对通过VLAN的流量总数(包括所有单播、组播和广播报文)进行统计。
统计VLAN流量信息会占用一定的系统资源,请在不需要统计信息时及时关闭此功能。
打开VLAN的流量统计功能后,可以执行display vlan statistics命令查看指定VLAN的流量统计信息。
VLAN的流量统计信息是不断累加的,系统不会自动清除。如需清空VLAN的流量统计信息,可执行reset vlan statistics命令清除指定VLAN的统计信息。
# 开启VLAN 2的流量统计功能。
[Sysname] vlan 2
[Sysname-vlan2] statistics enable
traffic-statistic enable命令用来开启VLAN接口的报文统计功能。
undo traffic-statistic enable命令用来关闭VLAN接口的报文统计功能。
VLAN接口的报文统计功能处于关闭状态。
VLAN接口视图
开启VLAN接口报文统计功能后会占用系统硬件资源,在大量接口下开启本功能或者通过flow-interval命令配置的时间间隔较小时会导致系统繁忙,CPU占用率升高。
配置本命令后,可以通过display interface vlan-interface命令的Input和Output字段查看VLAN接口的报文统计值,或者通过display counters rate命令查看VLAN接口的报文统计速率。
本功能暂不支持统计VLAN接口丢弃的报文数。
开启本功能后,不同类型的协议报文的统计情况如下:
·     对于设备本身发送出的协议报文,不统计。
·     对于目的端或者源端是设备本身的ARP、ND、OSPF、OSPFv3、VRRP、STP、DHCP协议报文,在VLAN接口的出方向和入方向上均不统计。
·     对于ICMP、BGP协议报文,只统计VLAN接口入方向上的报文,不统计出方向上的报文。
·     对于BFD协议报文,以硬件转发方式处理时,VLAN接口的出方向和入反向上的报文均统计;以软件转发方式处理时,只统计VLAN接口入方向上的报文。
·     若同时配置traffic-statistic ingress-nodrop enable命令,则ICMP Ping报文和ICMPv6 Ping报文在VLAN接口的入方向上不统计。
# 开启VLAN接口1000的报文统计功能。
[Sysname] vlan 1000
[Sysname-vlan1000] quit
[Sysname] interface vlan-interface 1000
[Sysname-Vlan-interface1000] traffic-statistic enable
·     display counters rate(接口管理命令参考/以太网接口)
·     flow-interval(接口管理命令参考/以太网接口)
1.1.21  vlan
vlan vlan-id命令用来创建VLAN,并进入VLAN视图。如果指定的VLAN已存在,则直接进入该VLAN的视图。
vlan vlan-id-list命令用来批量创建VLAN,保留VLAN除外。
vlan all命令用来批量创建VLAN 1~4094。
undo vlan命令用来删除VLAN。
vlan { vlan-id-list | all }
undo vlan { vlan-id-list | all }
系统只有一个缺省VLAN(VLAN 1)。
vlan-id-list:VLAN列表。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-32>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-32>表示前面的参数最多可以重复输入32次。
all:除保留VLAN外的其他VLAN,当设备允许创建的最大VLAN数小于4094时,不支持该参数。
用户不能创建和删除缺省VLAN(VLAN 1)和保留VLAN。
动态学习到的VLAN,以及被其他应用锁定不让删除的VLAN,都不能使用undo vlan命令直接删除。只有将相关配置删除之后,才能删除相应的VLAN。
# 创建VLAN 2,并进入该VLAN视图。
[Sysname] vlan 2
[Sysname-vlan2]
# 批量创建VLAN 2和VLAN 4~100。
[Sysname] vlan 2 4 to 100
·     display vlan
1.2  基于端口的VLAN配置命令
1.2.1  display port
display port命令用来显示设备上存在的Hybrid或Trunk端口。
hybrid:显示设备当前存在的Hybrid端口。
trunk:显示设备当前存在的Trunk端口。
# 显示当前设备存在的Hybrid端口。
<Sysname> display port hybrid
Interface            PVID  VLAN Passing
XGE1/0/1             100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                                    2555-2558, 3000, 4000
                           Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                                    150-160, 200, 255, 286, 300-302
# 显示当前设备存在的Trunk端口。
<Sysname> display port trunk
XGE1/0/2             2     1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
                           555, 600-611, 1000, 2006-2008
表1-5 display port命令显示信息描述表
接口名称
PVID
该端口的缺省VLAN ID
VLAN Passing
表示该端口实际通过的VLAN(该VLAN已经创建,并且接口允许其通过)
Tagged
表示哪些VLAN的报文通过该端口时必须携带VLAN Tag
Untagged
表示哪些VLAN的报文通过该端口时必须去掉VLAN Tag
1.2.2  port
port命令用来向VLAN中添加一个或一组Access端口。
undo port命令用来从VLAN中删除一个或一组Access端口。
port interface-list
undo port interface-list
系统将所有端口都加入到VLAN 1。
VLAN视图
interface-list:以太网接口列表。表示方式为interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-10>,其中interface-type interface-number为端口类型和端口编号,interface-number2的值要大于或等于interface-number1的值,&<1-10>表示前面的参数最多可以输入10次。
通过本命令只能将Access端口加入到VLAN中,不能将Trunk、Hybrid端口加入到VLAN中,并且不能通过本命令向VLAN 1中添加或删除Access端口。
设备上的所有端口的缺省链路类型都是Access类型,但用户可以自行切换端口类型,具体配置可参考命令port link-type。
# 向VLAN2中添加端口Ten-GigabitEthernet1/0/1~Ten-GigabitEthernet1/0/3。
[Sysname] vlan 2
[Sysname-vlan2] port ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
·     display vlan
port access vlan命令用来将Access端口加入到指定的VLAN中。
undo port access vlan命令用来恢复缺省情况。
port access vlan vlan-id
所有Access端口都属于VLAN 1。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU接口视图
ONU子接口视图
ONU冗余接口视图
vlan-id:指定的VLAN编号,取值范围为1~4094。
缺省情况下所有的Access端口都属于VLAN 1,因此不能通过本命令将Access端口加入VLAN 1。
若需将Access端口所属的VLAN从其他VLAN变更为VLAN 1,请执行undo port access vlan命令。
在将Access端口加入到指定VLAN之前,该VLAN必须已经存在。
# 将Ten-GigabitEthernet1/0/1端口加入到VLAN 3中。
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-Ten-GigabitEthernet1/0/1] port access vlan 3
port hybrid pvid命令用来配置Hybrid端口的缺省VLAN。
undo port hybrid pvid命令用来配置Hybrid端口的缺省VLAN为1。
port hybrid pvid vlan vlan-id
Hybrid端口的缺省VLAN为该端口在链路类型为Access时的所属VLAN。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU接口视图
ONU子接口视图
vlan-id:指定接口的缺省的VLAN ID,取值范围为1~4094。
对Hybrid端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即可以使用已经不存在的VLAN作为缺省VLAN。
建议本机Hybrid端口的缺省VLAN和相连的对端交换机的Hybrid端口的缺省VLAN保持一致。
配置缺省VLAN后,必须使用port hybrid vlan命令配置端口允许缺省VLAN的报文通过,该端口才能转发缺省VLAN的报文。
# 配置端口Ten-GigabitEthernet1/0/1(Hybrid类型)的缺省VLAN为100,并允许VLAN 100通过。
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-Ten-GigabitEthernet1/0/1] port link-type hybrid
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid pvid vlan 100
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid vlan 100 untagged
·     port hybrid vlan
·     port link-type
port hybrid vlan命令用来允许指定的VLAN通过当前Hybrid端口。
undo port hybrid vlan命令用来禁止指定的VLAN通过当前Hybrid端口。
undo port hybrid vlan vlan-id-list
Hybrid端口只允许该端口在链路类型为Access时的所属VLAN的报文以Untagged方式通过。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU子接口视图
vlan-id-list:VLAN列表,Hybrid端口允许通过的VLAN范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-32>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-32>表示前面的参数最多可以重复输入32次。该VLAN必须是设备上已创建的VLAN,否则,该命令执行失败。
untagged:该端口在转发指定的VLAN报文时将去掉VLAN Tag。
Hybrid端口允许多个VLAN通过。如果多次使用port hybrid vlan命令,那么Hybrid端口上允许通过的VLAN是这些vlan-id-list的合集。
# 配置端口Ten-GigabitEthernet1/0/1为Hybrid端口,允许VLAN 2、4、50~VLAN 100通过,并且发送这些VLAN的报文时携带VLAN Tag。
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
·     port link-type
port link-type命令用来配置端口的链路类型。
undo port link-type命令用来恢复缺省情况。
undo port link-type
所有端口的链路类型均为Access类型。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU接口视图
ONU子接口视图
ONU冗余接口视图
access:配置端口的链路类型为Access类型。
hybrid:配置端口的链路类型为Hybrid类型。
trunk:配置端口的链路类型为Trunk类型。
注意事项
Trunk端口和Hybrid端口之间不能直接切换,只能先设为Access端口,再配置为其他类型端口。
# 配置端口Ten-GigabitEthernet1/0/1配置为Trunk端口。
[Sysname-Ten-GigabitEthernet1/0/1] port link-type trunk
port trunk permit vlan命令用来允许指定的VLAN通过当前Trunk端口。
undo port trunk permit vlan命令用来禁止指定的VLAN通过当前Trunk端口。
undo port trunk permit vlan { vlan-id-list | all }
Trunk端口只允许VLAN 1的报文通过。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU接口视图
ONU子接口视图
ONU冗余接口视图
vlan-id-list:VLAN列表,Trunk端口允许通过的VLAN范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-32>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-32>表示前面的参数最多可以重复输入32次。
all:表示允许所有VLAN通过该Trunk端口。建议用户谨慎使用port trunk permit vlan all命令,以防止未授权VLAN的用户通过该端口访问受限资源。
Trunk端口可以允许多个VLAN通过。如果多次执行port trunk permit vlan命令,那么Trunk端口上允许通过的VLAN是这些vlan-id-list的集合。
Trunk端口发送出去的报文,只有缺省VLAN的报文不带VLAN Tag,其他VLAN的报文均会保留VLAN Tag。
# 配置端口Ten-GigabitEthernet1/0/1为Trunk端口,允许VLAN 2、4、50~100通过。
[Sysname-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
·     port link-type
port trunk pvid命令用来配置Trunk端口的缺省VLAN。
undo port trunk pvid命令用来恢复缺省情况。
port trunk pvid vlan vlan-id
Trunk端口的缺省VLAN为VLAN 1。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU接口视图
ONU子接口视图
ONU冗余接口视图
vlan-id:指定接口的缺省VLAN ID,取值范围为1~4094。
对Trunk端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即使用已经不存在的VLAN作为缺省VLAN。
本端设备Trunk端口的缺省VLAN ID和相连的对端设备的Trunk端口的缺省VLAN ID必须一致,否则报文将不能正确传输。
配置缺省VLAN后,必须使用port trunk permit vlan命令配置端口允许缺省VLAN的报文通过,该端口才能转发缺省VLAN的报文。
# 配置端口Ten-GigabitEthernet1/0/1(Trunk类型)的缺省VLAN为VLAN 100,并允许VLAN 100通过。
[Sysname-Ten-GigabitEthernet1/0/1] port trunk pvid vlan 100
[Sysname-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
·     port link-type
·     port trunk permit vlan
1.3  基于MAC的VLAN配置命令
display mac-vlan命令用来显示MAC VLAN表项。
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id }
all:显示所有MAC VLAN表项。
dynamic:显示动态配置的MAC VLAN表项。
mac-address mac-address:显示指定MAC地址对应的MAC VLAN表项,mac-address格式为H-H-H。
mask mac-mask:显示指定范围的MAC VLAN表项。mac-mask为二进制时高位必须为连续1,为十六进制时高位必须为连续f。缺省十六进制值为全f。
static:显示静态配置的MAC VLAN表项。
vlan vlan-id:显示指定VLAN对应的MAC VLAN表项。vlan-id取值范围为1~4094。
# 显示所有MAC VLAN表项。
<Sysname> display mac-vlan all
The following MAC VLAN entries exist:
State: S - Static, D - Dynamic
MAC address        Mask                VLAN ID   Dot1p      State
0008-0001-0000     ffff-ff00-0000      5         3          S
0002-0001-0000     ffff-ffff-ffff      5         3          S&D
Total MAC VLAN entries count: 2
表1-6 display mac-vlan命令显示信息描述表
目前设备上存在以下MAC VLAN表项
S - Static
以下显示信息中,S表示静态配置的MAC VLAN
D - Dynamic
以下显示信息中,D表示动态配置的MAC VLAN
MAC address
MAC地址
Mask
MAC地址对应的掩码
VLAN ID
MAC地址对应的VLAN ID
Dot1p
VLAN对应的802.1p优先级
MAC VLAN表项属性:
·     S:表示该表项是用户静态配置的
·     D:表示该表项是接入认证功能动态下发的
·     S&D:表示该表项既是静态配置的也是动态下发的
·     mac-vlan mac-address
display mac-vlan interface命令用来显示所有开启了MAC VLAN功能的接口。
# 显示所有开启了MAC VLAN功能的接口。
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
Ten-GigabitEthernet1/0/1  Ten-GigabitEthernet1/0/2  Ten-GigabitEthernet1/0/3
·     mac-vlan enable
mac-vlan enable命令用来开启MAC VLAN功能。
undo mac-vlan enable命令用来关闭MAC VLAN功能。
mac-vlan enable
MAC VLAN功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU子接口视图
# 在接口Ten-GigabitEthernet1/0/1上开启MAC VLAN功能。
[Sysname–Ten-GigabitEthernet1/0/1] mac-vlan enable
·     display mac-vlan interface
mac-vlan mac-address命令用来配置MAC VLAN表项,即配置MAC地址与VLAN的关联。
undo mac-vlan命令用来删除指定的MAC VLAN表项。
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ dot1p priority ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
不存在MAC VLAN表项。
mac-address mac-address:MAC地址,mac-address格式为H-H-H,不支持组播MAC地址和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
mask mac-mask:MAC地址的掩码,mac-mask为二进制时高位必须为连续1,为十六进制时高位必须为连续f。缺省十六进制值为全f。
vlan vlan-id:VLAN的编号,取值范围为1~4094。
dot1p priority:802.1p优先级,取值为0~7,缺省值为0。取值越大,802.1p优先级越高。
all:表示删除所有的静态MAC VLAN表项。
为了MAC VLAN的动态触发成功,配置MAC VLAN表项时使用静态VLAN。设备维护两张MAC VLAN表:
·     一张是通过指定mask参数配置的MAC VLAN表,该表里的表项描述的是一类MAC地址和VLAN、802.1p优先级之间的关系。
·     一张是不指定mask参数配置的MAC VLAN表,该表里的表项描述的是单个MAC地址和VLAN、802.1p优先级之间的关系。
根据用户的配置,系统将自动在这两张MAC VLAN表里添加/删除MAC VLAN表项。
# 配置MAC地址0000-0001-0001与VLAN 100关联,并指定该表项中VLAN 100的802.1p优先级为7。
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 dot1p 7
# 配置十六进制前6位为1211-22的MAC地址与VLAN 100关联,并指定该表项中VLAN 100的802.1p优先级为4。
[Sysname] mac-vlan mac-address 1211-2222-3333 mask ffff-ff00-0000 vlan 100 dot1p 4
·     display mac-vlan
mac-vlan trigger enable命令用来开启MAC VLAN的动态触发功能。
undo mac-vlan trigger enable命令用来关闭MAC VLAN的动态触发功能。
MAC VLAN的动态触发功能处于关闭状态。
二层以太网接口视图
OLT端口视图
OLT冗余接口视图
ONU子接口视图
开启MAC VLAN的动态触发功能后,只有端口接收的报文的源MAC地址精确匹配了MAC VLAN表项,才会动态触发该端口加入相应VLAN。
# 在接口Ten-GigabitEthernet1/0/1上开启MAC VLAN的动态触发功能。
[Sysname-Ten-GigabitEthernet1/0/1] mac-vlan trigger enable
·     port pvid forbidden
port pvid forbidden命令用来配置当报文源MAC地址与MAC VLAN表项的MAC地址未精确匹配时,禁止该报文在PVID内转发。
undo port pvid forbidden命令用来恢复缺省情况。
port pvid forbidden
当报文源MAC地址与MAC VLAN表项的MAC地址未精确匹配时,允许该报文在PVID内转发。
二层以太网接口视图
二层聚合接口视图
OLT端口视图
OLT冗余接口视图
ONU子接口视图
该功能仅适用于和MAC VLAN的动态触发功能配合使用。
# 在接口Ten-GigabitEthernet1/0/1上配置当报文源MAC地址不匹配MAC VLAN表项时,禁止该报文在PVID内转发。
[Sysname-Ten-GigabitEthernet1/0/1] port pvid forbidden
·     mac-vlan trigger enable
1.4  基于IP子网的VLAN配置命令
display ip-subnet-vlan interface命令用于显示端口关联的子网VLAN的信息。
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
interface-type interface-number1 to interface-type interface-number2:端口范围。interface-type interface-number1和interface-type interface-number2为端口的类型和编号。interface-number2的值要大于或等于interface-number1的值。
all:显示所有端口关联的子网VLAN的信息。
# 显示端口Ten-GigabitEthernet1/0/1关联的子网VLAN的信息。
<Sysname> display ip-subnet-vlan interface ten-gigabitethernet 1/0/1
  VLAN ID   Subnet index    IP address Subnet mask       Status
  3         0               192.168.1.0      255.255.255.0     Active
  4         N/A             N/A              N/A               Inactive
  4094      65535           172.16.1.1       255.255.0.0       Inactive
表1-7 display ip-subnet-vlan interface命令显示信息描述表
VLAN ID
子网VLAN的编号
Subnet index
IP子网的索引,N/A表示该VLAN下未配置任何子网VLAN
IP address
IP子网的地址,N/A表示该VLAN下未配置子网地址
Subnet mask
IP子网的掩码,N/A表示该VLAN下未配置子网掩码
Status
该子网VLAN在端口的生效情况:
·     Active:表示生效
·     Inactive:表示未生效(如子网VLAN配置未完成或端口未允许子网VLAN通过)
·     display ip-subnet-vlan vlan
·     ip-subnet-vlan
·     port hybrid ip-subnet-vlan
display ip-subnet-vlan vlan命令用于显示指定的或所有子网VLAN的信息。
display ip-subnet-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1:显示指定的子网VLAN的信息,vlan-id1表示VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:显示指定VLAN范围内的子网VLAN的信息。vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值。
all:显示所有子网VLAN的信息。
# 显示所有子网VLAN的信息。
<Sysname> display ip-subnet-vlan vlan all
 VLAN ID: 3
表1-8 display ip-subnet-vlan vlan命令显示信息描述表
VLAN ID
子网VLAN的编号
Subnet index
IP子网的索引
IP address
IP子网的地址(可以是IP地址或网络地址)
Subnet mask
IP子网的掩码
·     display ip-subnet-vlan interface
·     ip-subnet-vlan
ip-subnet-vlan命令用来配置VLAN与指定的IP子网或IP地址关联。
undo ip-subnet-vlan命令用于取消VLAN与IP子网或IP地址的关联。
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
undo ip-subnet-vlan { ip-subnet-index [ to ip-subnet-end ] | all }
VLAN未关联IP子网或IP地址。
VLAN视图
ip-subnet-index:IP子网索引值,取值范围为0~65535。子网索引可以由用户指定,也可由系统根据IP子网或IP地址与VLAN关联的先后顺序自动编号产生。
ip ip-address [ mask ]:作为子网VLAN划分依据的源IP地址或网络地址,ip-address表示源IP地址或网络地址,采用点分十进制格式;mask表示子网掩码,采用点分十进制格式,缺省值为255.255.255.0。
to ip-subnet-end:用来确定IP子网索引的范围。其中ip-subnet-end表示IP子网索引的终止值,取值范围为0~65535,其值必须大于或等于ip-subnet-index的值。
all:取消VLAN与所有IP子网或IP地址的关联。
VLAN关联的IP网段或IP地址不允许是组播网段或组播地址。
# 将VLAN 3配置为基于IP子网的VLAN,与192.168.1.0/24网段进行关联,使得源地址为该网段的报文可以在VLAN 3中传送。
[Sysname] vlan 3
[Sysname-vlan3] ip-subnet-vlan ip 192.168.1.0 255.255.255.0
port hybrid ip-subnet-vlan命令用来配置端口与子网VLAN关联。
undo port hybrid ip-subnet-vlan命令用于取消端口与子网VLAN的关联。
port hybrid ip-subnet-vlan vlan vlan-id
undo port hybrid ip-subnet-vlan { vlan vlan-id | all }
端口未关联子网VLAN。
二层以太网接口视图
二层聚合接口视图
all:所有VLAN。
执行本命令时,需保证当前端口的链路类型为Hybrid,并允许子网VLAN通过,且子网VLAN下存在与IP子网或IP地址关联的配置,该命令才实际生效。
# 将端口Ten-GigabitEthernet1/0/1与子网VLAN 3关联。
[Sysname] vlan 3
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid vlan 3 untagged
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid ip-subnet-vlan vlan 3
# 将二层聚合接口1与子网VLAN 3关联。
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid vlan 3 untagged
[Sysname-Bridge-Aggregation1] port hybrid ip-subnet-vlan vlan 3
·     ip-subnet-vlan
1.5  基于协议的VLAN配置命令
display protocol-vlan interface命令用于显示端口关联的协议VLAN的信息。
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
all:显示所有端口关联的协议VLAN的信息。
# 显示端口Ten-GigabitEthernet1/0/1关联的协议VLAN的信息。
<Sysname> display protocol-vlan interface ten-gigabitethernet 1/0/1
  VLAN ID  Protocol index  Protocol type             Status
  2        0               IPv6                      Active
  2        1               N/A                       Inactive
  4094     65535           IPv4                      Inactive
表1-9 display protocol-vlan interface命令显示信息描述表
VLAN ID
协议VLAN的编号
Protocol index
协议模板索引号
Protocol type
该协议模板指定的协议类型,N/A表示该协议模板未指定协议类型
Status
该协议VLAN在端口的生效情况:
·     Active:表示生效
·     Inactive:表示未生效
·     display protocol-vlan vlan
·     port hybrid protocol-vlan
·     protocol-vlan
display protocol-vlan vlan命令用于显示指定的或所有协议VLAN的信息。
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1:显示指定的协议VLAN的信息,vlan-id1表示VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:显示指定VLAN范围内的协议VLAN的信息。vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值。
all:显示所有协议VLAN的信息。
# 显示所有协议VLAN的信息。
<Sysname> display protocol-vlan vlan all
 VLAN ID: 2
  0               IPv4
  65535           IPv6
 VLAN ID: 3
  0               IPv4
  65535           LLC DSAP 0x11 SSAP 0x22
表1-10 display protocol-vlan vlan命令显示信息描述表
VLAN ID
协议VLAN的编号
Protocol index
协议模板索引号
Protocol type
该协议模板所指定的协议类型或封装格式
·     display protocol-vlan interface
·     protocol-vlan
port hybrid protocol-vlan命令用来配置端口与协议VLAN关联。
undo port hybrid protocol-vlan命令用于取消端口与协议VLAN的关联。
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo port hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
端口未关联协议VLAN。
二层以太网接口视图
二层聚合接口视图
protocol-index:协议模板索引,取值范围为0~65535。
to:协议模板索引的范围。
protocol-end:协议模板索引终止值,取值范围为0~65535,其值必须大于或等于protocol-index的值。
all:所有协议模板。
执行本命令时,需确保当前端口的链路类型为Hybrid,并允许协议VLAN通过,且协议VLAN下存在与协议模板关联的配置,本命令才实际生效。
在执行undo port hybrid protocol-vlan命令时:
·     如果同时指定vlan-id和all,则表示取消当前端口与指定VLAN下绑定的所有协议模板的关联。
·     如果仅指定all,则表示取消当前端口与所有VLAN下绑定的所有协议模板的关联。
# 配置端口Ten-GigabitEthernet1/0/1与协议VLAN 2中的协议模板1关联。
[Sysname] vlan 2
[Sysname-vlan2] protocol-vlan 1 ipv4
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid vlan 2 untagged
[Sysname-Ten-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 2 1
# 配置二层聚合接口1与协议VLAN 2中的协议模板1关联。
[Sysname] vlan 2
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
[Sysname-Bridge-Aggregation1] port hybrid protocol-vlan vlan 2 1
1.5.4  protocol-vlan
protocol-vlan命令用来配置VLAN与指定的协议模板关联。
undo protocol-vlan命令用于取消VLAN与协议模板的关联。
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
VLAN未关联协议模板。
VLAN视图
at:基于AT(AppleTalk,Apple计算机网络协议)协议的VLAN。
ipv4:基于IPv4协议的VLAN。
ipv6:基于IPv6协议的VLAN。
ipx:基于IPX协议的VLAN,可包括ethernetii、llc、raw和snap四种封装类型。
mode:配置自定义协议模板,可包括ethernetii、llc和snap三种封装类型。
ethernetii etype etype-id:匹配Ethernet II封装格式及相应的协议类型值。其中,etype-id表示入报文的协议类型值,取值范围为十六进制数600~ffff(不包括800、86dd、809b和8137)。
llc:匹配LLC封装格式。
dsap dsap-id:目的服务接入点,取值范围为十六进制数0~ff。
ssap ssap-id:源服务接入点,取值范围为十六进制数0~ff。
snap etype etype-id:匹配SNAP封装格式及相应的协议类型值。其中,etype-id表示入报文的以太网类型,取值范围为十六进制数600~ffff(不包括8137)。
protocol-index:协议索引,用来标识与当前VLAN绑定的协议模版,取值范围为0~65535。如果不指定该参数,则系统会自动分配一个索引值。
to protocol-end:用来确定协议索引的范围。其中protocol-end表示协议索引终止值,取值范围为0~65535,其值必须大于或等于protocol-index的值。
all:与当前VLAN绑定的所有协议。
由于IPv4协议与ARP协议关系密切,建议用户将IPv4协议和ARP协议绑定到同一VLAN,并且关联到相同的端口,避免因ARP报文与IPv4报文未划分到同一VLAN,而造成无法正常通信的情况。
使用mode ethernetii etype关键字进行配置时,不允许将etype-id的值配置为800、809b、8137或86dd,因为上述取值分别与IPv4、AppleTalk、IPX和IPv6协议模板相同。
使用mode llc关键字进行配置时,dsap-id和ssap-id的值不允许同时为e0(代表IPX报文的LLC封装格式)、ff(代表IPX报文的raw封装格式)、aa(代表SNAP封装格式);如果只配置了dsap-id和ssap-id中的一个,系统会将另一参数的值自动配置为aa。
使用mode snap etype关键字进行配置时,不允许将etype-id的值配置为8137,因为该值与IPX协议的协议模板相同。当etype-id的值取800、809b或86dd时,其对应的协议模板分别为IPv4、AppleTalk和IPv6。
# 将IPv4报文和采用Ethernet II封装格式的ARP报文(ARP协议的协议代码为0806)划分到VLAN 3中传输。
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan 1 ipv4
[Sysname-vlan3] protocol-vlan 2 mode ethernetii etype 0806
·     port protocol-vlan
1.6  ARP泛洪抑制配置命令
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
ARP泛洪抑制功能处于关闭状态。
VLAN视图
应用场景
在网络中出现过多的ARP报文时,会导致设备CPU负载加重,影响设备正常处理用户的其它业务。为了解决该问题,用户可以在设备上开启ARP泛洪抑制功能,减少泛洪的ARP报文数量,保证整个网络通信的正常运行。
工作机制
开启本功能后,设备能够侦听经过它的ARP报文。当其它设备再次发起ARP解析时,本设备可以对ARP请求报文进行代答,从而可以抑制发起ARP解析时引起的网络泛洪。
# 开启VLAN 1下的ARP泛洪抑制功能。
[Sysname] vlan 1
[Sysname-vlan1] arp suppression enable
display arp suppression vlan命令用来显示ARP泛洪抑制表项。
(独立运行模式)‌
display arp suppression vlan [ vlan-id ] [ slot slot-number ] [ count ]
display arp suppression vlan vlan-id ip ip-address [ slot slot-number ]
display arp suppression vlan [ vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display arp suppression vlan vlan-id ip ip-address [ chassis chassis-number slot slot-number ]
vlan:显示VLAN内的ARP泛洪抑制表项。
vlan-id:显示指定VLAN内的ARP泛洪抑制表项,取值范围为1~4094。如果未指定本参数,则显示所有VLAN下的ARP泛洪抑制表项。
count:显示当前ARP泛洪抑制表项的数目。如果未指定本参数,则显示的是ARP泛洪抑制表项。
ip ip-address:显示VLAN下指定IP地址的ARP泛洪抑制表项。
slot slot-number:显示指定单板上的所有ARP泛洪抑制表项。slot-number表示单板的槽位号。如果未指定本参数,则显示主用主控板上的ARP泛洪抑制表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的所有ARP泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。如果未指定本参数,则显示全局主用主控板上的ARP泛洪抑制表项。(IRF模式)‌
# 显示VLAN 2下的ARP泛洪抑制表项。
<Sysname> display arp suppression vlan 2
IP Address      MAC Address    VLAN ID Interface  Aging       Status
3.3.3.3         0003-0003-0003 2       XGE1/0/1   20          Valid
3.3.3.4         0004-0004-0004 2       XGE1/0/2   5           Invalid
# 显示VLAN 2下IP地址为1.1.1.1的ARP泛洪抑制表项。
<Sysname> display arp suppression vlan 2 ip 1.1.1.1
IP address      MAC address    VLAN ID Interface  Aging       Status
1.1.1.1         001f-e201-0111 2       XGE1/0/1   15          Valid
# 显示VLAN下的ARP泛洪抑制表项个数。
<Sysname> display arp suppression vlan count
Total entries: 3
display arp suppression vlan命令显示信息描述表
IP Address
ARP泛洪抑制表项的IP地址
MAC Address
ARP泛洪抑制表项的MAC地址
VLAN ID
ARP泛洪抑制表项所属的VLAN的编号
ARP泛洪抑制表项所对应的入接口
Aging
ARP泛洪抑制表项的老化时间,单位为分钟。当显示N/A时,表示当前槽位不是创建ARP泛洪抑制表项的端口所在的槽位
Status
ARP泛洪抑制表项的状态,分为以下三种:
·     Valid:有效
·     Invalid:无效
·     Collision:冲突
Total entries
ARP泛洪抑制表项数目
·     reset arp suppression
·     arp suppression enable
reset arp suppression vlan命令用来清除VLAN下的ARP泛洪抑制表项。
reset arp suppression vlan [ vlan-id ip ip-address | vlan-id ]
vlan:清除VLAN内的ARP泛洪抑制表项。
vlan-id:清除指定VLAN的ARP泛洪抑制表项。取值范围为1~4094。如果未指定本参数,则清除所有VLAN下的ARP泛洪抑制表项。
ip ip-address:清除VLAN下指定IP地址的ARP泛洪抑制表项。
# 清除VLAN 2下的ARP泛洪抑制表项。
<Sysname> reset arp suppression vlan 2
# 清除VLAN 2下IP地址为1.1.1.1的ARP泛洪抑制表项。
<Sysname> reset arp suppression vlan 2 ip 1.1.1.1
·     display arp suppression vlan
1.7  VLAN组配置命令
display vlan-group命令用来显示创建的VLAN组及其VLAN成员列表。
display vlan-group [ group-name ]
group-name:VLAN组的名称,为1~31个字符的字符串,区分大小写,首字符必须为字母。若不指定该参数,则表示显示所有VLAN组的信息。
# 显示指定VLAN组test001的信息。
<Sysname> display vlan-group test001
VLAN group: test001
     VLAN list: 2-4 100 200
# 显示所有VLAN组的信息。
VLAN group: test001
VLAN group: rnd
     VLAN list: Null
表1-11 display vlan-group命令显示信息描述表
VLAN group
VLAN组名称
VLAN list
对应的该VLAN组内的VLAN列表
·     vlan-group
·     vlan-list
1.7.2  vlan-group
vlan-group命令用来创建一个VLAN组,并进入VLAN组视图。如果指定的VLAN组已经存在,则直接进入该VLAN组视图。
undo vlan-group命令用来删除指定的VLAN组。
vlan-group group-name
undo vlan-group group-name
不存在VLAN组。
VLAN组是一组VLAN的集合。VLAN组内可以添加多个VLAN列表。
# 创建一个VLAN组,名称为test001,并进入VLAN组视图。
[Sysname] vlan-group test001
[Sysname-vlan-group-test001]
·     vlan-list
1.7.3  vlan-list
vlan-list命令用来在VLAN组内添加VLAN成员。
undo vlan-list命令用来从VLAN组内删除VLAN成员。
vlan-list vlan-id-list
undo vlan-list vlan-id-list
当前VLAN组中不存在VLAN列表。
VLAN组视图
vlan-id-list:VLAN列表。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
# 向VLAN组test001内添加VLAN成员:VLAN 2~VLAN 4、VLAN 100、VLAN 200。
[Sysname-vlan-group-test001] vlan-list 2 to 4 100 200
·     vlan-group
2 Super VLAN
2.1  Super VLAN配置命令
display supervlan命令用来显示Super VLAN及其关联的Sub VLAN的信息。
display supervlan [ supervlan-id ]
supervlan-id:Super VLAN的编号,取值范围为1~4094。如果未指定该参数,则显示设备上所有的Super VLAN及其关联的Sub VLAN的信息。
# 显示Super VLAN 2及其关联的Sub VLAN的信息。
<Sysname> display supervlan 2
 Super VLAN ID: 2
 Sub-VLAN ID: 3-5
 VLAN ID: 2
 VLAN type: Static
 It is a super VLAN.
 IPv4 address: 10.153.17.41
 IPv4 subnet mask: 255.255.252.0
 IPv6 global unicast addresses:
   2001::1, subnet is 2001::/64 [TENTATIVE]
 Tagged ports:   None
 Untagged ports: None
 VLAN ID: 3
 VLAN type: Static
 It is a sub-VLAN.
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 4
 VLAN type: Static
 It is a sub-VLAN.
 Description: VLAN 0004
 Tagged ports:   None
 Untagged ports:
    Ten-GigabitEthernet1/0/4
表2-1 display supervlan命令显示信息描述表
Super VLAN ID
Super VLAN的编号
Sub-VLAN ID
Sub VLAN的编号
VLAN ID
VLAN编号
VLAN type
VLAN类型:
·     Dynamic:动态VLAN
·     Static:静态VLAN
It is a super VLAN
当前VLAN是Super VLAN
It is a sub-VLAN
当前VLAN是Sub VLAN
Route interface
设备上是否创建了对应的VLAN接口:
·     Configured:已创建
IPv4 address
VLAN接口的主用IPv4地址。如果VLAN接口没有配置IPv4地址,则不显示该字段,如果VLAN接口上还配置了从IPv4地址,可以使用display interface vlan-interface命令或者在VLAN接口视图下使用display this命令查看
IPv4 subnet mask
VLAN接口的主用IPv4地址的子网掩码。如果VLAN接口没有配置IPv4地址,则不显示该字段
VLAN接口上配置的全球单播IPv6地址,如果VLAN接口没有配置IPv6地址,则不显示该字段
可能的IPv6地址状态及含义如下:
·     [TENTATIVE]:该状态为地址初始化状态,此时该地址可能正在进行DAD检测或准备进行DAD检测,处于该状态的地址不能作为报文的源地址或者目的地址
·     [DUPLICATE]:该状态表明地址DAD检测已经结束,由于该地址在链路上不唯一,因此不能使用
·     [PREFERRED]:该状态表明地址处于首选生命期以内。该状态的地址可以作为报文的源地址或者目的地址。为该状态时,不显示地址的状态标识
·     [DEPRECATED]:该状态表明地址超过首选生命期,但是在有效生命期以内。该状态地址有效,但不应作为新建连接报文的源地址,目的地址是该地址的报文还可以被正常处理
VLAN的描述信息
Name
VLAN的名称
Tagged ports
该VLAN报文从哪些端口发送需要携带VLAN Tag
Untagged ports
该VLAN报文从哪些端口发送时不需要携带VLAN Tag
·     subvlan
·     supervlan
2.1.2  subvlan
subvlan命令用来建立Super VLAN和Sub VLAN的映射关系。
undo subvlan命令用来解除Super VLAN和Sub VLAN的映射关系。
subvlan vlan-id-list
undo subvlan [ vlan-id-list ]
不存在Super VLAN和Sub VLAN的映射关系。
VLAN视图
vlan-id-list:Sub VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>。其中,vlan-id表示Sub VLAN的VLAN ID,取值范围为1~4094。&<1-10>表示前面的参数最多可以重复输入10次。
建立Super VLAN和Sub VLAN的映射关系前,指定的Sub VLAN必须已经创建。
在建立了Super VLAN和Sub VLAN的映射关系后,仍可以向Sub VLAN中添加和删除接口。
使用undo subvlan命令时:
·     如果不指定vlan-id-list,则解除当前Super VLAN与所有Sub VLAN的映射关系。
·     如果指定vlan-id-list,则解除当前Super VLAN与指定Sub VLAN的映射关系。
# 建立Super VLAN 10和Sub VLAN 3、4、5的映射关系。
[Sysname] vlan 3 to 5
[Sysname] vlan 10
[Sysname-vlan10] supervlan
[Sysname-vlan10] subvlan 3 to 5
·     display supervlan
·     supervlan
2.1.3  supervlan
supervlan命令用来配置VLAN的类型为Super VLAN。
undo supervlan命令用来恢复缺省情况。
supervlan
undo supervlan
VLAN类型不为Super VLAN。
VLAN视图
如果某个VLAN被指定为Super VLAN,则该VLAN不能被指定为某个端口的Guest VLAN/Auth-Fail VLAN/Critical VLAN;同样,如果某个VLAN被指定为某个端口的Guest VLAN/Auth-Fail VLAN/Critical VLAN,则该VLAN不能被指定为Super VLAN。Guest VLAN/Auth-Fail VLAN/Critical VLAN的相关内容请参见“安全配置指导”中的“802.1X”。
在Super VLAN对应的VLAN接口下配置VRRP功能后,会对网络性能造成影响,建议不要这样配置。
在Super VLAN下可以配置二层组播功能,但是由于Super VLAN中没有物理端口,该配置将不会生效。
# 配置VLAN 2为Super VLAN。
[Sysname] vlan 2
[Sysname-vlan2] supervlan
·     display supervlan
·     subvlan
3 Private VLAN
display private-vlan命令用来显示Primary VLAN和其包含的Secondary VLAN的信息。
display private-vlan [ primary-vlan-id ]
primary-vlan-id:Primary VLAN的编号,取值范围为1~4094。如果未指定该参数,则显示所有Primary VLAN和其对应的Secondary VLAN的映射信息。
# 显示所有Primary VLAN和其包含的Secondary VLAN的信息。
<Sysname> display private-vlan
 Primary VLAN ID: 2
 Secondary VLAN ID: 3-4
 VLAN ID: 2
 VLAN type: Static
 Private VLAN type: Primary
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Private VLAN type: Secondary
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 4
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
表3-1 display private-vlan命令显示信息描述表
Primary VLAN ID
Primary VLAN的编号
Secondary VLAN ID
Secondary VLAN的编号
VLAN ID
VLAN编号
VLAN type
VLAN类型:
·     Dynamic:动态VLAN
·     Static:静态VLAN
Private VLAN type
Private VLAN类型:
¡     Primary:表示Primary VLAN
·     Secondary:表示Secondary VLAN
Route interface
设备上是否创建了对应的VLAN接口:
·     Configured:已创建
IPv4 address
VLAN接口的主用IPv4地址,如果VLAN接口没有配置IPv4地址,则不显示该字段,如果VLAN接口上还配置了从IPv4地址,可以使用display interface vlan-interface或者在VLAN接口视图下使用display this命令查看
IPv4 subnet mask
VLAN接口的主用IPv4地址的子网掩码,如果VLAN接口没有配置IPv4地址,则不显示该字段
VLAN接口上配置的全球单播IPv6地址(如果VLAN接口没有配置IPv6地址,则不显示该字段)
可能的IPv6地址状态及含义如下:
VLAN的描述信息
Name
VLAN的名称
Tagged ports
Untagged ports
·     private-vlan (VLAN view)
·     private-vlan primary
port private-vlan host命令用来配置端口工作在host模式。
undo port private-vlan命令用来恢复缺省情况。
端口不工作在host模式。
二层以太网接口视图
端口工作在host模式时,若端口已经加入了Secondary VLAN,则端口也会同步加入和Secondary VLAN有映射关系的Primary VLAN。
在执行port private-vlan host命令后,当端口同步加入Primary VLAN时,端口的链路类型不同,进行的操作不同:
·     若端口的链路类型为Access类型,则会:
¡     配置端口的链路类型为Hybrid类型。
¡     配置缺省VLAN为端口加入的Secondary VLAN。
¡     端口会以Untagged方式加入Primary VLAN。
·     若端口的链路类型为Trunk类型,则端口的链路类型及缺省VLAN不做改变。
·     若端口的链路类型为Hybrid类型,则端口的链路类型及缺省VLAN不做改变,但同步加入Primary VLAN时:
¡     若此前该端口存在以Tagged/Untagged方式加入Primary VLAN的配置,则保持原有配置。
¡     若此前该端口不存在加入Primary VLAN的配置,则该端口会以Untagged方式加入Primary VLAN。
可以在执行完port private-vlan host命令后,再配置端口加入Secondary VLAN,此时,该命令的功能依然生效。
undo port private-vlan命令恢复缺省情况时,端口的VLAN属性(包括端口加入VLAN以及端口的链路类型、端口缺省VLAN)不做改变。
port private-vlan host命令与port private-vlan trunk promiscuous及port private-vlan trunk secondary命令互斥。
VLAN 20的类型为Secondary VLAN,且VLAN 20和Primary VLAN 2关联。
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/1工作在host模式。
[Sysname-Ten-GigabitEthernet1/0/1] port private-vlan host
[Sysname-Ten-GigabitEthernet1/0/1] display this
 port link-mode bridge
return
# 将端口Ten-GigabitEthernet1/0/1加入VLAN 20。
[Sysname-Ten-GigabitEthernet1/0/1] port access vlan 20
# 显示端口Ten-GigabitEthernet1/0/1当前配置。
 undo port hybrid vlan 1
 port hybrid vlan 2 20 untagged
 port hybrid pvid vlan 20
return
可以看出当端口Ten-GigabitEthernet1/0/1工作在host模式,且加入Secondary VLAN 20时,该端口会同步加入关联的Primary VLAN 2,同时修改链路类型及缺省VLAN
·     port private-vlan promiscuous
·     port private-vlan trunk promiscuous
·     port private-vlan trunk secondary
port private-vlan promiscuous命令用来配置端口在指定VLAN中工作在promiscuous模式并加入到该VLAN。
port private-vlan vlan-id promiscuous
端口在指定VLAN中不工作在promiscuous模式。
二层以太网接口视图
vlan-id:VLAN的编号,取值范围为1~4094。其中,VLAN 1虽然在取值范围中,但不能配置。
执行本命令时若指定VLAN的类型为Primary VLAN,且存在和指定VLAN有映射关系的Secondary VLAN,则端口也会同步加入这些Secondary VLAN。
在执行port private-vlan promiscuous命令时,端口的链路类型不同,进行的操作不同:
¡     配置缺省VLAN为指定VLAN。
¡     端口会以Untagged方式加入所有对应VLAN(包括指定VLAN及同步加入的Secondary VLAN)。
·     若端口的链路类型为Hybrid类型,则端口的链路类型及缺省VLAN不做改变。端口加入对应VLAN(包括指定VLAN及同步加入的Secondary VLAN)时:
¡     若端口此前存在以Tagged/Untagged方式加入某些对应VLAN的配置,则在保持原有配置的基础上,端口会以Untagged方式加入其他对应VLAN
¡     若端口此前不存在加入某些对应VLAN的配置,则端口会以Untagged方式加入所有对应VLAN。
如果在promiscuous端口上多次执行port private-vlan promiscuous命令,则最后一次执行的命令生效。
undo port private-vlan命令恢复缺省情况时,端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
在执行undo port private-vlan命令时,若端口已配置在某VLAN中工作在promiscuous模式,则取消端口加入该VLAN的配置。
可以在执行完port private-vlan promiscuous命令后,再配置指定VLAN的类型为Primary VLAN,此时,该命令的功能依然生效。
port private-vlan promiscuous命令与port private-vlan trunk promiscuous及port private-vlan trunk secondary命令互斥。
VLAN 2的类型为Primary VLAN,且VLAN 2和Secondary VLAN 20关联。
return
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/1在VLAN 2中工作在promiscuous模式,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] port private-vlan 2 promiscuous
return
可以看出当该端口在VLAN 2中工作在promiscuous模式时,该端口会加入Primary VLAN 2及关联的Secondary VLAN 20,同时修改端口的链路类型及缺省VLAN。
# 取消端口Ten-GigabitEthernet1/0/1的promiscuous模式配置,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] undo port private-vlan
 port hybrid vlan 20 untagged
return
可以看出该端口退出Primary VLAN 2,但该端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
·     port private-vlan host
port private-vlan trunk promiscuous命令用来配置端口在指定VLAN中工作在trunk promiscuous模式并加入该VLAN。
undo port private-vlan trunk promiscuous命令用来配置端口在指定VLAN退出trunk promiscuous模式。
port private-vlan vlan-id-list trunk promiscuous
undo port private-vlan vlan-id-list trunk promiscuous
端口在指定VLAN中不工作在trunk promiscuous模式。
二层以太网接口视图
vlan-id-list:VLAN列表,Primary VLAN的范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。其中,系统缺省VLAN(VLAN 1)虽然在取值范围中,但不能配置。
在执行port private-vlan trunk promiscuous命令时,端口的链路类型不同,进行的操作不同:
¡     配置端口的链路类型为Hybrid类型,缺省VLAN不做改变。
¡     端口会以Tagged方式加入所有对应VLAN(包括指定VLAN及同步加入的Secondary VLAN)。
¡     若端口此前存在以Tagged/Untagged方式加入某些对应VLAN的配置,则在保持原有配置的基础上,端口会以Tagged方式加入其他对应VLAN。
¡     若端口此前不存在加入某些对应VLAN的配置,则端口会以Tagged方式加入所有对应VLAN。
undo port private-vlan trunk promiscuous命令用来配置端口在指定VLAN中退出trunk promiscuous模式,但端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
在执行undo port private-vlan trunk promiscuous命令时,若已配置端口在vlan-id-list中工作在trunk promiscuous模式,则取消端口加入vlan-id-list的配置。
可以在执行完port private-vlan trunk promiscuous命令后,再配置指定VLAN的类型为Primary VLAN,此时,该命令的功能依然生效。
port private-vlan trunk promiscuous命令与port private-vlan promiscuous、port private-vlan trunk secondary及port private-vlan host命令互斥。
port private-vlan trunk promiscuous命令适用于需要多个Primary VLAN通过上行端口的情况,配置该命令后多个Primary VLAN携带Tag通过上行端口。port private-vlan promiscuous适用于只有一个Primary VLAN通过上行端口的情况,配置该命令后Primary VLAN不带Tag通过上行端口。
VLAN 2、3的类型为Primary VLAN,且VLAN 2和Secondary VLAN 20关联,VLAN 3和Secondary VLAN 30关联。
return
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/1在VLAN 2、3中工作在trunk promiscuous模式,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] port private-vlan 2 3 trunk promiscuous
 port hybrid vlan 2 3 20 30 tagged
 port hybrid vlan 1 untagged
return
可以看出当该端口在VLAN 2、3中工作在trunk promiscuous模式时,该端口会加入Primary VLAN 2、3及关联的Secondary VLAN 20、30,同时修改端口的链路类型。
# 取消端口Ten-GigabitEthernet1/0/1在VLAN 2、3中的trunk promiscuous模式配置,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] undo port private-vlan 2 3 trunk promiscuous
 port hybrid vlan 20 30 tagged
return
可以看出该端口退出Primary VLAN 2、3,但该端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
port private-vlan trunk secondary命令用来配置端口在指定VLAN中工作在trunk secondary模式并加入该VLAN。
undo port private-vlan trunk secondary命令用来配置端口在指定VLAN退出trunk secondary模式。
port private-vlan vlan-id-list trunk secondary
undo port private-vlan vlan-id-list trunk secondary
端口在指定VLAN中不工作在trunk secondary模式。
二层以太网接口视图
vlan-id-list:VLAN列表,Secondary VLAN的范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。其中,系统缺省VLAN(VLAN 1)虽然在取值范围中,但不能配置。
执行本命令时若指定VLAN的类型为Secondary VLAN,且存在和指定VLAN有映射关系的Primary VLAN,则端口也会同步加入这些Primary VLAN。
在执行port private-vlan trunk secondary命令时,当端口同步加入Primary VLAN,
·     若此前端口的链路类型为Access类型,则会:
¡     端口会以Tagged方式加入所有对应VLAN(包括指定VLAN及同步加入的Primary VLAN)。
·     若此前端口的链路类型为Trunk类型,则端口的链路类型及缺省VLAN不做改变。
·     若此前端口的链路类型为Hybrid类型,则端口的链路类型及缺省VLAN不做改变。端口加入对应VLAN(包括指定VLAN及同步加入的Primary VLAN)时:
工作在trunk secondary模式的端口,对于一个Primary VLAN对应的Secondary VLAN,只能加入其中的一个,但可以分别加入多个Primary VLAN对应的多个Secondary VLAN。
undo port private-vlan trunk secondary命令将指定VLAN退出trunk secondary模式,但端口的VLAN关系(包括端口加入Primary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
在执行完port private-vlan trunk secondary命令后,再执行undo port private-vlan trunk secondary命令时:
·     若端口的链路类型为Access类型,则端口加入指定VLAN的配置不做改变。
·     若端口的链路类型为Trunk/Hybrid类型,则取消端口加入指定VLAN的配置。
可以在执行完port private-vlan trunk secondary命令后,再建立指定VLAN与Primary VLAN的映射关系,此时,该命令的功能依然生效。
在执行port private-vlan trunk secondary命令时,若其中vlan-id-list中部分VLAN不满足要求,则本命令只在其他满足要求的VLAN中生效。比如:
·     指定VLAN不存在。
·     指定VLAN的类型为除Secondary VLAN外的其他特殊类型VLAN。
·     本端口已经在指定VLAN对应Primary VLAN下的其他Secondary VLAN中工作在trunk secondary模式。
port private-vlan trunk secondary命令与port private-vlan host、port private-vlan promiscuous及port private-vlan trunk promiscuous命令互斥。
port private-vlan trunk secondary命令适用于需要多个Secondary VLAN(分别对应不同的Primary VLAN)通过下行端口的情况,配置该命令后多个Secondary VLAN携带Tag通过下行端口。port private-vlan host命令适用于只有一个Secondary VLAN通过下行端口的情况,配置该命令后Secondary VLAN不带Tag通过下行端口。
·     VLAN 2、3的类型为Primary VLAN,且VLAN 2和Secondary VLAN 20关联,VLAN 3和Secondary VLAN 30关联。
return
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/1在VLAN 20、30中工作在trunk secondary模式,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] port private-vlan 20 30 trunk secondary
return
可以看出当该端口在VLAN 20、30中工作在trunk secondary模式时,该端口会加入Secondary VLAN 20、30及关联的Primary VLAN 2、3,同时修改链路类型。
# 取消端口Ten-GigabitEthernet1/0/1在VLAN 20、30中的trunk secondary模式配置,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] undo port private-vlan 20 30 trunk secondary
 port hybrid vlan 2 3 tagged
return
可以看出该端口退出Secondary VLAN 20、30,但该端口的VLAN属性(包括端口加入Primary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
·     VLAN 10的类型不为Secondary VLAN。
return
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/1在VLAN 10中工作在trunk secondary模式,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] port private-vlan 10 trunk secondary
 port hybrid vlan 10 tagged
return
可以看出该端口在VLAN 10中工作在trunk secondary模式时,该端口会加入Secondary VLAN 10,同时修改链路类型。
# 取消端口Ten-GigabitEthernet1/0/1在VLAN 10中的trunk secondary模式配置,并显示配置结果。
[Sysname-Ten-GigabitEthernet1/0/1] undo port private-vlan 10 trunk secondary
return
可以看出该端口退出VLAN 10,但该端口的VLAN属性(包括端口的链路类型、缺省VLAN的配置)不做改变。
private-vlan secondary命令用来配置Primary VLAN下指定的Secondary VLAN间三层互通。
undo private-vlan用来取消Primary VLAN下指定的或所有的Secondary VLAN间三层互通。
private-vlan secondary vlan-id-list
undo private-vlan [ secondary vlan-id-list ]
Secondary VLAN间三层不互通。
VLAN接口视图
要使功能生效,执行该命令时,必须满足如下条件:
·     该命令只能在Primary VLAN对应的VLAN接口(Primary VLAN interface)视图下执行。
·     Secondary VLAN必须已经与该对应的Primary VLAN建立了映射关系。
·     Secondary VLAN不能建立对应的VLAN接口。
·     在该三层虚接口上配置IP地址。
·     本地代理ARP/ND功能。
没有配置三层互通的Secondary VLAN可以创建对应的VLAN接口,配置了三层互通的Secondary VLAN不能创建对应的VLAN接口。
在同一Primary VLAN interface下多次执行本命令时,最终生效结果是多次配置的集合。
在执行undo private-vlan命令时:
·     如果不带参数secondary vlan-id-list,就解除所有Secondary VLAN间的三层互通。
·     如果带有该参数,就解除指定的Secondary VLAN间的三层互通。
配置Primary VLAN 2下的Secondary VLAN 3、4三层互通(Ten-GigabitEthernet1/0/2为上行端口,Ten-GigabitEthernet1/0/3、Ten-GigabitEthernet1/0/4为下行端口)。
# 建立Primary VLAN 2和Secondary VLAN 3、4的映射关系。
[Sysname] vlan 3 to 4
[Sysname] vlan 2
[Sysname-vlan2] private-vlan primary
[Sysname-vlan2] private-vlan secondary 3 to 4
# 配置端口Ten-GigabitEthernet1/0/2在VLAN 2中工作在promiscuous模式。
[Sysname-Ten-GigabitEthernet1/0/2] port private-vlan 2 promiscuous
[Sysname-Ten-GigabitEthernet1/0/2] quit
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/3在VLAN 3中工作在host模式,链路类型为Access的端口Ten-GigabitEthernet1/0/4在VLAN 4中工作在host模式。
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] port access vlan 3
[Sysname-Ten-GigabitEthernet1/0/3] port private-vlan host
[Sysname-Ten-GigabitEthernet1/0/3] quit
[Sysname] interface ten-gigabitethernet 1/0/4
[Sysname-Ten-GigabitEthernet1/0/4] port access vlan 4
[Sysname-Ten-GigabitEthernet1/0/4] port private-vlan host
[Sysname-Ten-GigabitEthernet1/0/4] quit
# 配置Primary VLAN 2下的Secondary VLAN 3、4三层互通,同时配置Primary VLAN接口的IP地址及开启本地代理ARP功能。
[Sysname-Vlan-interface2] private-vlan secondary 3 to 4
[Sysname-Vlan-interface2] ip address 192.168.1.1 255.255.255.0
[Sysname-Vlan-interface2] local-proxy-arp enable
private-vlan命令用来建立Primary VLAN和Secondary VLAN的映射关系。
undo private-vlan用来解除Primary VLAN和Secondary VLAN的映射关系。
未建立Primary VLAN和Secondary VLAN的映射关系。
VLAN视图
secondary vlan-id-list:表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。其中,系统缺省VLAN(VLAN 1)虽然在取值范围中,但不能配置。
Primary VLAN可以与多个Secondary VLAN建立映射关系。在同一VLAN视图下多次执行private-vlan命令时,Primary VLAN对应的Secondary VLAN是多次配置的集合。
在执行private-vlan命令时,若满足以下条件,则依据接口配置会触发配置同步。
·     已经配置Primary VLAN。
·     设备上有端口工作在promiscuous模式、trunk promiscuous模式或host模式。
·     如果不带参数secondary vlan-id-list,就解除所有Secondary VLAN和对应Primary VLAN的映射关系。
·     如果带有该参数,就解除参数指定的Secondary VLAN和对应Primary VLAN的映射关系。
[Sysname] vlan 2
·     primary-vlan primary
private-vlan community命令用来配置同一Secondary VLAN内各端口二层互通。
同一Secondary VLAN内的端口二层互通。
VLAN视图
private-vlan community命令实现的功能与undo private-vlan isolated命令相同。
当用户通过save命令保存配置时,private-vlan community命令的配置不会被存入配置文件。
配置Secondary VLAN 4内各端口二层互通(Ten-GigabitEthernet1/0/1工作为promiscuous模式,Ten-GigabitEthernet1/0/2和Ten-GigabitEthernet1/0/3工作在host模式)。完成下述配置后,Secondary VLAN 4内端口Ten-GigabitEthernet1/0/2和Ten-GigabitEthernet1/0/3二层互通。
# 建立Primary VLAN 2和Secondary VLAN 4的映射关系。
[Sysname] vlan 4
[Sysname-vlan4] quit
[Sysname] vlan 2
[Sysname-vlan2] private-vlan secondary 4
# 配置端口Ten-GigabitEthernet1/0/1在VLAN 2中工作在promiscuous模式。
# 配置链路类型为Access的端口Ten-GigabitEthernet1/0/2和Ten-GigabitEthernet1/0/3在VLAN 4中工作在host模式。
[Sysname-Ten-GigabitEthernet1/0/2] port access vlan 4
[Sysname-Ten-GigabitEthernet1/0/2] port private-vlan host
[Sysname-Ten-GigabitEthernet1/0/3] port access vlan 4
# 配置Secondary VLAN 4内各端口二层互通。
[Sysname] vlan 4
[Sysname-vlan4] private-vlan community
·     private-vlan isolated
private-vlan isolated命令用来配置同一Secondary VLAN内各端口二层隔离。
undo private-vlan isolated命令用来恢复缺省情况。
同一Secondary VLAN内的端口能够二层互通。
VLAN视图
配置private-vlan isolated命令时,需满足以下条件,命令才能生效。
·     Primary VLAN与Secondary VLAN建立映射关系。
·     下行端口配置为trunk secondary模式或host模式。
Secondary VLAN隔离与Primary VLAN、Super VLAN和Sub VLAN配置互斥。
配置Secondary VLAN 4内各端口二层隔离(Ten-GigabitEthernet1/0/1工作在promiscuous模式,Ten-GigabitEthernet1/0/2及Ten-GigabitEthernet1/0/3工作在host模式)。完成下述配置后,Secondary VLAN 4内端口Ten-GigabitEthernet1/0/2和Ten-GigabitEthernet1/0/3二层隔离。
[Sysname] vlan 4
[Sysname] vlan 2
# 配置Secondary VLAN 4内各端口二层隔离。
[Sysname] vlan 4
[Sysname-vlan4] private-vlan isolated
·     private-vlan community
private-vlan primary命令用来配置VLAN的类型为Primary VLAN。
undo private-vlan primary命令用来恢复缺省情况。
VLAN的类型不是Primary VLAN。
VLAN视图
配置该命令时,若满足以下条件,则依据接口配置会触发配置同步:
·     已经配置Primary VLAN和Secondary VLAN的映射关系。
·     设备上有端口工作在promiscuous模式、trunk promiscuous模式、trunk secondary模式或host模式。
# 配置VLAN 5为Primary VLAN。
[Sysname] vlan 5
[Sysname-vlan5] private-vlan primary
4 Voice VLAN
4.1  Voice VLAN配置命令
display voice-vlan mac-address命令用来显示Voice VLAN支持的OUI地址。
# 显示Voice VLAN支持的OUI地址。
<Sysname> display voice-vlan mac-address
OUI Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
表4-1 display voice-vlan mac-address命令显示信息描述表
OUI Address
设备当前允许通过的OUI地址
Mask
设备当前允许通过的OUI地址的掩码
设备当前允许通过的OUI地址的描述
·     voice-vlan mac-address
display voice-vlan state命令用来显示Voice VLAN的配置信息。
# 显示Voice VLAN的配置信息。
<Sysname> display voice-vlan state
 Current voice VLANs: 1
 Voice VLAN security mode: Security
 Voice VLAN aging time: 1440 minutes
 Voice VLAN enabled ports and their modes:
 Port                        VLAN        Mode        CoS        DSCP
 XGE1/0/1                    111         Auto        6          46
表4-2 display voice-vlan state命令显示信息描述表
Current Voice VLANs
已创建的Voice VLAN数量
Voice VLAN的安全模式的开启状态:
·     Security:表示当前使用的是安全模式
·     Normal:表示当前使用的是普通模式
Voice VLAN的老化时间,No aging表示不老化
当前开启了Voice VLAN的端口及其工作模式
Port
当前开启了Voice VLAN的端口的简名
VLAN
端口开启的Voice VLAN ID
Mode
端口Voice VLAN的工作模式:
·     Auto:表示自动模式
·     Manual:表示手工模式
CoS
服务级别
DSCP
差分服务编码点优先级
·     voice-vlan aging
·     voice-vlan enable
·     voice-vlan mode auto
·     voice-vlan security enable
voice-vlan acl-resource-mode命令用来配置Voice VLAN占用ACL资源的模式。
undo voice-vlan acl-resource-mode命令用来恢复缺省情况。
voice-vlan acl-resource-mode { global | port }
未配置Voice VLAN占用ACL资源的模式。
global:表示配置Voice VLAN占用ACL资源的模式为全局模式。
port:表示配置Voice VLAN占用ACL资源的模式为端口模式。
端口开启Voice VLAN时,Voice VLAN占用ACL资源的模式可配置为全局模式和端口模式。
·     处于全局模式时,具有相同Voice VLAN编号的端口共用同一份ACL资源。全局模式能极大的节省ACL资源。
·     处于端口模式时,各端口均使用端口独立的ACL资源。
可通过执行本命令切换Voice VLAN占用ACL资源的模式。
# 配置Voice VLAN占用ACL资源的模式为端口模式。
[Sysname] voice-vlan acl-resource-mode port
ACL resource mode successfully switched. The configuration takes effect after you save the configuration and reboot the device.
·     voice-vlan enable
voice-vlan aging命令用来设置Voice VLAN的老化时间。
undo voice-vlan aging命令用来恢复缺省情况。
voice-vlan aging minutes
Voice VLAN的老化时间为1440分钟(24小时)。
minutes:Voice VLAN的老化时间,取值范围为0或5~43200,单位为分钟。0表示不老化。
在自动模式下,当系统将入端口加入Voice VLAN后,老化时间由对应的老化定时器控制。当系统在老化定时器停止前没有从入端口收到任何语音报文时,系统会自动把该端口从Voice VLAN中删除。
Voice VLAN的老化定时器需在对应的MAC地址表项老化之后才能启动,因此Voice VLAN的老化周期为设备上配置的Voice VLAN老化时间与动态MAC地址表项老化时间之和。有关动态MAC地址老化时间的详细介绍,请参见“MAC地址表”。
老化时间只对Voice VLAN工作在自动模式的端口有效,对Voice VLAN工作在手工模式的端口无效。
# 将Voice VLAN的老化时间配置为100分钟。
[Sysname] voice-vlan aging 100
·     display voice-vlan state
voice-vlan vlan-id enable命令用来开启端口的Voice VLAN功能。
undo voice-vlan enable命令用来关闭端口的Voice VLAN功能。
undo voice-vlan [ vlan-id ] enable
端口的Voice VLAN功能处于关闭状态。
二层以太网接口视图
vlan-id:Voice VLAN编号,取值范围为2~4094。
当端口的Voice VLAN工作在自动模式时,只有Trunk或者Hybrid类型端口支持开启Voice VLAN功能。
开启端口的Voice VLAN功能之前,须确保对应的VLAN已存在。
# 开启端口Ten-GigabitEthernet1/0/1的Voice VLAN功能。
[Sysname-Ten-GigabitEthernet1/0/1] voice-vlan 2 enable
voice-vlan mac-address命令用来配置Voice VLAN中可识别的OUI地址。
undo voice-vlan mac-address命令用来删除Voice VLAN中可识别的OUI地址。
voice-vlan mac-address mac-address mask oui-mask [ description text ]
undo voice-vlan mac-address oui
设备已配置有如下表所示的OUI地址。
表4-3 设备缺省的OUI地址
序号
OUI地址
生产厂商
1
0001-e300-0000
Siemens phone
2
0003-6b00-0000
Cisco phone
3
0004-0d00-0000
Avaya phone
4
000f-e200-0000
H3C Aolynk phone
5
0060-b900-0000
Philips/NEC phone
6
00d0-1e00-0000
Pingtel phone
7
00e0-7500-0000
Polycom phone
8
00e0-bb00-0000
3Com phone
mac-address:语音报文的源MAC地址,格式为H-H-H,如:1234-1234-1234。
mask oui-mask:OUI地址的有效长度,用掩码表示,格式为H-H-H。由连续的1和连续的0组成,表示OUI地址的匹配长度。如:ffff-0000-0000,如果要匹配某个设备厂商的语音设备,可以设置为ffff-ff00-0000。
description text:OUI地址的描述字符串,长度为1~30,区分大小写。
oui:指定要删除的OUI地址,格式为H-H-H,如1234-1200-0000。OUI地址不能是广播地址或者组播地址,也不能是全0的地址。OUI地址是mac-address和oui-mask参数相与的结果。
设备缺省的OUI地址可以手工删除,删除之后也可再次手工添加。
# 配置允许来自IP电话PhoneA(MAC地址为1234-1234-1234)的语音流通过Voice VLAN。
[Sysname] voice-vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
·     display voice-vlan mac-address
4.1.7  voice-vlan mode auto
voice-vlan mode auto命令用来配置端口的Voice VLAN工作模式为自动模式。
undo voice-vlan mode auto命令用来配置端口的Voice VLAN工作模式为手工模式。
二层以太网接口视图
当端口开启了Voice VLAN并工作在手工模式时,必须手工将端口加入Voice VLAN,才能保证Voice VLAN功能生效。
# 将端口Ten-GigabitEthernet1/0/1的Voice VLAN的工作模式设置为手工模式。
[Sysname-Ten-GigabitEthernet1/0/1] undo voice-vlan mode auto
4.1.8  voice-vlan qos
voice-vlan qos命令用来配置端口将Voice VLAN内语音报文的CoS和DSCP值修改为指定值。
undo voice-vlan qos命令用来恢复缺省情况。
voice-vlan qos cos-value dscp-value
undo voice-vlan qos
端口将Voice VLAN内语音报文的CoS值修改为6,DSCP值修改为46。
二层以太网接口视图
cos-value:语音报文CoS值,取值范围为0~7。取值越大,优先级越高。
dscp-value:语音报文DSCP值,取值范围为0~63。取值越大,优先级越高。
在Voice VLAN开启的情况下,不允许配置本命令。必须关闭Voice VLAN功能后,才能配置本命令。
如果对于同一端口多次执行voice-vlan qos和voice-vlan qos trust命令,最后一次执行的命令生效。
# 配置端口Ten-GigabitEthernet1/0/1收到Voice VLAN内的语音报文时,将报文的CoS值修改为5,DSCP值修改为45。
[Sysname-Ten-GigabitEthernet1/0/1] voice-vlan qos 5 45
·     voice-vlan qos trust
4.1.9  voice-vlan qos trust
voice-vlan qos trust命令用来配置端口信任Voice VLAN内语音报文的优先级。
undo voice-vlan qos
二层以太网接口视图
执行本命令,端口不会修改Voice VLAN内语音报文自带的CoS和DSCP值。
# 配置端口Ten-GigabitEthernet1/0/1信任语音报文的优先级。端口收到Voice VLAN内语音报文后,报文自带的CoS和DSCP值保持不变。
[Sysname-Ten-GigabitEthernet1/0/1] voice-vlan qos trust
·     voice-vlan qos
4.1.10  voice-vlan security enable
voice-vlan security enable命令用来开启Voice VLAN的安全模式。
undo voice-vlan security enable命令用来关闭Voice VLAN的安全模式。
Voice VLAN的安全模式处于开启状态。
在安全模式下,Voice VLAN中只能有语音流量。用户开启Voice VLAN的安全模式以后,该VLAN的报文都经过过滤,设备会根据报文的源MAC地址是否匹配OUI地址来过滤所有非语音流量,增加安全性保证语音流的优先级,保证通话质量。在普通模式下,Voice VLAN中允许有业务流量和语音流量并存。
# 关闭Voice VLAN的安全模式。
[Sysname] undo voice-vlan security enable
4.1.11  voice-vlan track lldp
voice-vlan track lldp命令用来开启通过LLDP自动发现IP电话功能。
undo voice-vlan track lldp命令用来关闭通过LLDP自动发现IP电话功能。
通过LLDP自动发现IP电话功能处于关闭状态。
# 开启通过LLDP自动发现IP电话功能。
[Sysname] voice-vlan track lldp
