03-接口管理命令参考
02-以太网接口命令
本章节下载 02-以太网接口命令  (1.02 MB)
02-以太网接口命令
  录
1 以太网接口
1.1 以太网接口通用配置命令
1.1.1 bandwidth
1.1.2 broadcast-suppression
1.1.3 dampening
1.1.4 default
1.1.5 description
1.1.6 display counters
1.1.7 display counters rate
1.1.8 display ethernet statistics
1.1.9 display ifmonitor buffer flow-information
1.1.10 display ifmonitor latency-detection statistics
1.1.11 display interface
1.1.12 display interface link-info
1.1.13 display interface main
1.1.14 display link-flap protection
1.1.15 display link-state-change statistics interface
1.1.16 display packet-drop
1.1.17 display lbn-group status
1.1.18 display slot-monitor
1.1.19 duplex
1.1.20 eee enable
1.1.21 flow-control
1.1.22 flow-control receive enable
1.1.23 flow-interval
1.1.24 group-member interface
1.1.25 ifmonitor buffer mode
1.1.26 ifmonitor crc-error
1.1.27 ifmonitor input-buffer-drop
1.1.28 ifmonitor input-error
1.1.29 ifmonitor input-usage
1.1.30 ifmonitor latency
1.1.31 ifmonitor output-buffer-drop
1.1.32 ifmonitor output-error
1.1.33 ifmonitor output-usage
1.1.34 ifmonitor rx-pause
1.1.35 ifmonitor tx-pause
1.1.36 interface
1.1.37 interface default-description output
1.1.38 jumboframe enable
1.1.39 link-delay
1.1.40 link-flap protect enable
1.1.41 loadbalance ecmp lbn-group enable
1.1.42 loopback
1.1.43 multicast-suppression
1.1.44 port fec mode
1.1.45 port ifmonitor buffer flow-information enable
1.1.46 port ifmonitor buffer queue enable
1.1.47 port ifmonitor buffer usage threshold
1.1.48 port ifmonitor crc-error
1.1.49 port ifmonitor input-buffer-drop
1.1.50 port ifmonitor input-error
1.1.51 port ifmonitor input-usage
1.1.52 port ifmonitor latency-detection enable
1.1.53 port ifmonitor output-buffer-drop
1.1.54 port ifmonitor output-error
1.1.55 port ifmonitor output-usage
1.1.56 port ifmonitor rx-pause
1.1.57 port ifmonitor tx-pause
1.1.58 port link-flap protect enable
1.1.59 port link-mode
1.1.60 port transceiver-power-low trigger
1.1.61 port up-mode
1.1.62 lbn-group
1.1.63 reset counters interface
1.1.64 reset counters mib interface
1.1.65 reset counters slot
1.1.66 reset ethernet statistics
1.1.67 reset link-state-change statistics interface
1.1.68 shutdown
1.1.69 shutdown all-physical-interfaces
1.1.70 shutdown-interval crc-error
1.1.71 shutdown-interval link-flap
1.1.72 shutdown-interval transceiver-power-low
1.1.73 slot-monitor packet-drop
1.1.74 snmp-agent trap enable eth
1.1.75 snmp-agent trap enable ifmonitor
1.1.76 snmp-agent trap enable slot-monitor
1.1.77 speed
1.1.78 traffic-statistic include-interframe
1.1.79 unicast-suppression
1.1.80 using fortygige
1.1.81 using fourhundredgige
1.1.82 using hundredgige
1.1.83 using tengige
1.1.84 using twenty-fivegige
1.1.85 using twohundredgige
1.2 二层以太网接口的配置命令
1.2.1 display storm-constrain
1.2.2 mdix-mode
1.2.3 port bridge enable
1.2.4 speed auto
1.2.5 storm-constrain
1.2.6 storm-constrain control
1.2.7 storm-constrain enable log
1.2.8 storm-constrain enable trap
1.2.9 storm-constrain interval
1.2.10 virtual-cable-test
1.3 三层以太网接口/子接口的配置命令
1.3.1 mac-address
1.3.2 mtu
1.3.3 traffic-statistic enable
1 以太网接口
1.1  以太网接口通用配置命令
1.1.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
以太网接口视图
以太网子接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口Ten-GigabitEthernet3/0/1的期望带宽为1000kbps。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] bandwidth 1000
·     speed
broadcast-suppression命令用来开启端口广播风暴抑制功能,并设置广播风暴抑制阈值。
undo broadcast-suppression命令用来关闭端口广播风暴抑制功能。
所有接口不对广播流量进行抑制。
以太网接口视图
ratio:指定以太网接口允许通过的最大广播流量占该接口带宽的百分比,取值范围为0~100。数值越小,允许通过的广播流量也越小。
pps max-pps:指定以太网接口每秒允许转发的最大广播包数,单位为pps(packets per second,每秒转发的报文数),取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒允许转发的最大广播流量,单位为kbps(kilobits per second,每秒转发的千比特数),取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大广播报文流量。当接口上的广播流量超过用户设置的值后,系统将丢弃超出广播流量限制的报文,从而使接口广播流量所占的比例控制在限定的范围内,以便保证业务的正常运行。
执行broadcast-suppressionstorm-constrain命令都能开启端口的广播风暴抑制功能,storm-constrain命令通过软件对广播报文进行抑制,对设备性能有一定影响,broadcast-suppression通过芯片物理上对广播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置broadcast-suppressionstorm-constrain命令,以免配置冲突,导致抑制效果不确定。
当风暴抑制阈值配置为ppskbps时,设备可能会根据芯片支持的步长,将配置值转换成步长的倍数。请注意查看设备的提示信息。
配置本命令后,端口上风暴抑制实际生效的阈值与display interface命令中显示的抑制阈值会有5%的误差。
# 在以太网接口Ten-GigabitEthernet3/0/1上,每秒最多允许10000kbps广播报文通过,对超出该范围的广播报文进行抑制。
[Sysname-Ten-GigabitEthernet3/0/1] broadcast-suppression kbps 10000
The actual value is 9984 on port Ten-GigabitEthernet3/0/1 currently.
对于SF系列接口板和SG系列接口板,以上信息表示:用户配置的值为10000kbps,端口实际生效的值为9984kbps。用户可根据该提示信息,确认端口实际生效的抑制值。
·     multicast-suppression
·     unicast-suppression
1.1.3  dampening
dampening命令用来开启接口的dampening功能。
undo dampening命令用来恢复缺省情况。
undo dampening
接口的dampening功能处于关闭状态。
以太网接口视图
half-life:半衰期,取值范围为1~120,单位为秒,缺省值为54。
reuse:启用值,取值范围为200~20000,缺省值为750,必须要小于suppress的值。
suppress:抑制门限,取值范围为200~20000,缺省值为2000。
max-suppress-time:最大抑制时间,取值范围为1~255,单位为秒,缺省值为半衰期的3倍,即162。
配置本命令时,各参数之间应满足以下关系,请根据该关系来选择参数的取值:
·     最大惩罚值=2(最大抑制时间/半衰期)×启用值,其中最大惩罚值不可配。
·     抑制值的配置值≤最大惩罚值≤抑制值可配的最大值
以太网接口上不能同时配置本命令、link-delay命令和port link-flap protect enable命令。
本命令对使用shutdown命令手动关闭的接口无效。手工shutdown接口时,dampening的惩罚值恢复为初始值0。
对于使能了RRPP、MSTP或Smart Link的接口不建议使用该命令。
接口在抑制期发生up事件,通过display interface命令方式查看时,该接口的状态仍然为down。
# 按照缺省值开启接口Ten-GigabitEthernet3/0/1的dampening功能。
[Sysname-Ten-GigabitEthernet3/0/1] dampening
# 开启接口Ten-GigabitEthernet3/0/1的dampening功能,配置半衰期为2秒,启用值为800,抑制门限为3000,最大抑制时间为5秒。
[Sysname-Ten-GigabitEthernet3/0/1] dampening 2 800 3000 5
·     display interface
·     link-delay
·     port link-flap protect enable
1.1.4  default
default命令用来恢复当前接口的缺省配置。
default
以太网接口视图
以太网子接口视图
# 将以太网接口Ten-GigabitEthernet3/0/1恢复为缺省配置。
[Sysname-Ten-GigabitEthernet3/0/1] default
1.1.5  description
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“接口名 Interface”,例如:Ten-GigabitEthernet3/0/1 Interface。
以太网接口视图
以太网子接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 设置以太网接口Ten-GigabitEthernet3/0/1的描述信息为“lan-interface”。
[Sysname-Ten-GigabitEthernet3/0/1] description lan-interface
# 设置以太网子接口Ten-GigabitEthernet3/0/1.1的描述信息为“subinterface3/0/1.1”。
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] description subinterface3/0/1.1
display counters命令用来显示接口的流量统计信息。
display counters { inbound | outbound } interface [ interface-type [ interface-number ]  ]
inbound:显示输入报文的流量统计信息。
outbound:显示输出报文的流量统计信息。
interface-type:指定接口类型。
interface-number:指定接口编号。
可通过命令reset counters interface清除以太网接口的统计信息。
如果不指定接口类型,则显示所有可统计的接口的流量统计信息。
如果指定接口类型而不指定接口编号,则显示该类型下所有接口的流量统计信息。
如果同时指定接口类型和接口编号,则显示指定接口的报文流量统计信息。
# 显示接口的报文输入流量统计信息。
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
XGE3/0/1                      100                 100                   0           0
XGE3/0/2                 Overflow            Overflow            Overflow    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
表1-1 display counters命令显示信息描述表
接口名称缩写
Total (pkts)
接口接收或发送报文的总数(单位为包)
Broadcast (pkts)
接口接收或发送广播报文的总数(单位为包)
Multicast (pkts)
接口接收或发送组播报文的总数(单位为包)
Err (pkts)
接口接收或发送错误报文的总数(单位为包)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围:
·     对于Err项,Overflow表示数据的长度超过了7位十进制数
·     对于其它项,Overflow表示数据的长度超过了14位十进制数
--: Not supported.
当某个统计信息的值为“--”时,表示设备不支持该项数据的统计
·     reset counters interface
display counters rate命令用来显示最近一个统计周期内处于up状态的接口的报文速率统计信息。
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ]  ]
inbound:显示报文接收速率统计信息。
outbound:显示报文发送速率统计信息。
如果不指定interface-typeinterface-number,则显示所有可统计的接口类型中最近一个统计周期内处于up状态的接口的报文速率统计信息。
如果指定interface-type而不指定interface-number,则显示该类型下最近一个统计周期内处于up状态接口的报文速率统计信息。
如果同时指定interface-typeinterface-number,则显示指定接口在最近一个统计周期内报文速率统计信息。如果该接口在最近一个统计周期内一直处于down状态,则提示接口不支持该操作。
统计周期可以通过flow-interval命令来配置。
# 显示接口的报文接收速率统计信息。
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
XGE3/0/1                    0             0                --               --
 Overflow: More than 14 digits.
       --: Not supported.
表1-2 display counters rate命令显示信息描述表
接口名称缩写
Usage (%)
在最近一个统计周期内,接口的带宽利用率(单位为百分比)。
分为两种计算方式:
·     普通组网中,接口的带宽利用率计算公式为:本地物理接口带宽/本端所有选中接口带宽总和
·     M-LAG组网中,接口的带宽利用率计算公式为:本端物理接口带宽/(本端所有选中接口带宽+对端所有选中接口带宽)
Total (pps)
在最近一个统计周期内,接口接收或发送所有类型报文的平均速率(单位为包/秒)
Broadcast (pps)
在最近一个统计周期内,接口接收或发送广播报文的平均速率(单位为包/秒)
Multicast (pps)
在最近一个统计周期内,接口接收或发送组播报文的平均速率(单位为包/秒)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了14位十进制数
--: Not supported.
当某个统计信息的值为“--”时,则表示设备不支持该项数据的统计
·     flow-interval
display ethernet statistics命令用来显示以太网软件模块收发报文的统计信息。
(独立运行模式)‌
display ethernet statistics slot slot-number
display ethernet statistics chassis chassis-number slot slot-number
slot slot-number:显示指定单板的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
# 显示指定slot上的以太网软件模块收发报文的统计信息。(独立运行模式)‌
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
表1-3 display ethernet statistics命令显示信息描述表
以太网软件模块接收到的以太网报文的统计信息:
·     Totalnum:接收报文的总个数
·     ETHIINum:接收的ETHII封装格式报文个数
·     SNAPNum:接收的SNAP封装格式报文个数
·     RAWNum:接收的RAW封装格式报文个数
·     LLCNum:接收的LLC封装格式报文个数
·     UnknowNum:接收的未知封装格式报文个数
·     ForwardNum:二层转发或上送CPU的报文个数
·     ARP:接收的ARP报文个数
·     MPLS:接收的MPLS报文个数(暂不支持)‌
·     ISIS:接收的ISIS报文个数‌
·     ISIS2:接收的ISIS2报文个数‌
·     IP:接收的IP报文个数
·     IPv6:接收的IPv6报文个数
以太网软件模块接收错误的以太网报文的统计信息(可能是包本身包含错误或者是接收动作出错了):
·     NullPoint:接收报文时指针为空的报文的个数
·     ErrIfindex:接收报文时接口索引错误的报文个数
·     ErrIfcb:接收报文时接口控制块错误的报文个数
·     IfShut:接收报文时接口shutdown的报文个数
·     ErrAnalyse:接收报文时报文解析错误的报文个数
·     ErrSrcMAC:接收的包含源MAC地址错误的报文个数
·     ErrHdrLen:接收的包含报文头长度错误的报文个数
以太网软件模块发送的以太网报文的统计信息:
·     L3OutNum:通过三层以太网接口发送的报文总个数‌
·     VLANOutNum:通过VLAN接口发送的报文总个数
·     FastOutNum:快速发送的报文总个数
·     L2OutNum:通过二层以太网接口发送的报文总个数
以太网软件模块发送的错误以太网报文的统计信息:
·     MbufRelayNum:透传发送的报文总个数
·     NullMbuf:发送报文时空指针错误的报文个数
·     ErrAdjFwd:发送报文时邻接表错误的报文个数
·     ErrPrepend:发送报文时扩展错误的报文个数
·     ErrHdrLen:发送的包含报文头长度错误的报文个数
·     ErrPad:发送报文时填充错误的报文个数
·     ErrQoSTrs:发送报文时QoS发送失败的报文个数
·     ErrVLANTrs:发送报文时VLAN发送失败的报文个数
·     ErrEncap:发送报文时封装链路头失败的报文个数
·     ErrTagVLAN:发送报文时封装VLAN TAG失败的报文个数
·     IfShut:发送报文时端口shutdown的报文个数
·     IfErr:发送报文时出接口错误的报文个数
·     reset ethernet statistics
display ifmonitor buffer flow-information命令用来显示缓存的流信息采集结果。
display ifmonitor buffer flow-information [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的缓存的流信息采集结果。interface-type为接口类型,interface-number为接口编号。
需要先执行port ifmonitor buffer flow-information enable命令开启缓存的流信息采集功能后,才能使用本命令显示缓存的流信息采集结果。
仅SF系列接口板和SG系列接口板支持本命令。
# 显示Ten-GigabitEthernet3/0/1接口缓存的流信息采集结果。
<Sysname> display ifmonitor buffer flow-information interface ten-gigabitethernet 3/0/1
Interface: Ten-GigabitEthernet3/0/1
SrcIp           DstIp           SrcPort DstPort Protocol Ratio Time
255.255.255.253 255.255.255.252 8000    8000    TCP      30    2023-12-02 23:12:11.390
255.255.255.254 255.255.255.252 8000    8000    UDP      40    2023-12-02 23:12:12.400
表1-4 display ifmonitor buffer flow-information命令显示信息描述表
接口名称
Queue
队列编号
SrcIp
报文的源IP地址
DstIp
报文的目的IP地址
SrcPort
报文的源端口
DstPort
报文的目的端口
Protocol
报文的应用层协议
Ratio
报文在采集样本中的占比,单位为百分比
Time
采集时间
·     port ifmonitor buffer flow-information enable
display ifmonitor latency-detection statistics命令用来显示报文时延检测统计结果。
display ifmonitor latency-detection statistics [ interface interface-type interface-number ]
需要先执行port ifmonitor latency-detection enable命令开启报文时延检测功能后,才能通过本命令查看报文时延检测统计结果。
通过reset counters interface命令可清除报文时延检测统计数据。
# 显示Ten-GigabitEthernet3/0/1接口的报文时延检测统计结果。
<Sysname> display ifmonitor time-delay statistics interface ten-gigabitethernet 3/0/1
Level   Threshold       Packets
0       100             10
1       150             20
2       200             30
3       300             40
4       400             50
5       500             60
6       600             70
7       900             80
表1-5 display ifmonitor latency-detection statistics命令显示信息描述表
接口名称
Level
时延等级
Threshold
时延阈值,单位为纳秒
Packets
时延等级内的报文个数
·     ifmonitor latency
·     port ifmonitor latency-detection enable
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过25个字符,不指定该参数时,只显示描述信息中的前25个字符,超出部分不显示。
如果不指定接口类型和接口编号,则显示所有接口的信息。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看三层以太网接口Ten-GigabitEthernet3/0/1的运行状态和相关信息。
<Sysname> display interface ten-gigabitethernet 3/0/1
Line protocol state: DOWN
Description: Ten-GigabitEthernet3/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Known unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T
Port priority: 2
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: 6 hours 39 minutes 28 seconds
Current system time:2020-08-10 14:56:12
Last time when physical state changed to up:-
Last time when physical state changed to down:2020-08-10 14:55:25
Traffic statistic: Not include Inter-frame Gaps and Preambles
 Peak input rate: 0 bytes/sec, at 2020-07-07 16:07:11
 Peak output rate: 0 bytes/sec, at 2020-07-07 16:07:11
 Last 300 seconds input:  0 packets/sec 0 bytes/sec  0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec  0%
 Input  (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
 Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
 Output  (total): 0 packets, 0 bytes
 Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
IPv4 traffic statistics:
 Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
 Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 0 packets, 0 bytes
 Output: 0 packets, 0 bytes
IPv6 traffic statistics:
# 查看二层以太网接口Ten-GigabitEthernet3/0/1的运行状态和相关信息。
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Allow jumbo frame to pass
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2020
Current system time:2020-08-10 14:58:27
Last time when physical state changed to down:2020-08-10 14:57:58
 Peak input rate: 0 bytes/sec, at 2020-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2020-07-17 22:06:19
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
表1-6 display interface命令显示信息描述表
接口Ten-GigabitEthernet3/0/1的相关信息
Current state
接口的物理状态,状态可能为:
·     Administratively DOWN(Global):表示该接口已经在系统视图下通过shutdown all-physical-interfaces命令被关闭,即管理状态为关闭
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭
·     DOWN ( Monitor-Link uplink down ):Monitor Link联动而导致接口被关闭
·     IRF-link-down:接口属于某MDC时,由于接口所在成员设备上划分到该MDC的所有IRF链路状态为DOWN或ADM,接口被IRF链路检测功能关闭
·     mac-address moving down:由于MAC地址迁移抑制导致接口被关闭
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为MAD ShutDown
·     OFP DOWN:表示接口开启了OpenFlow的关闭接口功能
·     Storm-Constrain:表示端口上因为组播或广播报文中某类报文的流量大于其上限阈值而被关闭
·     STP DOWN:表示接口由于触发了STP BPDU保护而自动关闭
·     M-LAG MAD Shutdown:表示接口在M-LAG系统分裂时被设置为M-LAG MAD DOWN状态
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
·     DOWN:表示数据链路层协议状态为关闭
·     DOWN(protocols):表示接口的数据链路层被一个或者多个协议模块关闭。protocols为OAM、LAGG、BFD的任意组合:
¡     OAM:表示由于以太网OAM模块检测到远端链路故障而关闭接口的数据链路层
¡     LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层
¡     BFD:表示由于BFD模块检测到链路故障而关闭接口的数据链路层
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     Unnumbered:借用其他接口的IP地址
·     MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术配置指导”中的“IRF”
IPv4报文发送帧格式
hardware address
接口的MAC地址
IPv6报文发送帧格式
Media type is
接口的介质类型
Port hardware type is
接口的硬件类型
Port priority
接口优先级
Loopback is set internal
以太网接口正在进行对内环回测试,该显示信息与用户的配置有关
Loopback is set external
对以太网接口进行对外环回测试,该显示信息与用户的配置有关
Loopback is not set
接口上未配置环回测试,该显示信息与用户的配置有关
10Mbps-speed mode
接口速率为10Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
100Mbps-speed mode
接口速率为100Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
1000Mbps-speed mode
接口速率为1000Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
10Gbps-speed mode
接口速率为10Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
Unknown-speed mode
速率未知,可能因为速率协商失败或者接口物理未连通
half-duplex mode
接口工作在半双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
full-duplex mode
接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
unknown-duplex mode
未知双工模式,可能因为双工模式协商失败或者接口物理未连通
当用户配置了speed auto时显示该信息
Link speed type is force link
当用户使用speed命令配置了具体的速率时显示该信息,例如1000M等
当用户配置了duplex auto时显示该信息
link duplex type is force link
当用户使用duplex命令配置了具体的双工模式时显示该信息,例如half或者full
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
接口允许通过的最大以太网帧长度
允许长帧通过
Broadcast max-
广播风暴抑制阈值
Multicast max-
组播风暴抑制阈值
Unicast max-
未知单播风暴抑制阈值
Known-unicast max-
已知单播风暴抑制阈值
PVID
接口所在的缺省VLAN ID
MDI type
网线类型,取值为automdix、mdi或mdix,与用户的配置有关
Dampening enabled
接口的dampening功能处于开启状态
Penalty
惩罚值
Ceiling
最大惩罚值
Reuse
启用值
Suppress
抑制门限
Half-life
半衰期,单位为秒
Max-suppress-time
最大抑制时间,单位为秒
Flap count
接口UP/DOWN状态改变次数
Port link-type
链路类型,取值为access、trunk或hybrid,与用户的配置有关
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
VLAN Passing
该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN)
VLAN permitted
接口允许通过的VLAN报文
Trunk port encapsulation
Trunk接口的封装格式
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
Last hardware down reason
接口最近一次硬件down的原因:
·     PHY line side is down:PHY线路侧down
·     PHY system side is down:PHY系统侧down
·     No optical signal has been received at the optical port:光口未收到光信号
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,当前系统时间后面会追加显示时区的配置,格式为YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
最近一次接口物理状态变为UP的时刻
如果配置了时区,该时间后面会追加显示时区的配置,格式为YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
Last interval seconds input:  0 packets/sec 0 bytes/sec 0%
Last interval seconds output:  0 packets/sec 0 bytes/sec 0%
端口在最近一个统计周期内接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比。统计周期interval可以通过flow-interval命令设置
如果值显示为“-”,则表示不支持该统计项
Traffic statistic
统计接口平均速率时是否包含帧间隙和前导码
·     Include Inter-frame Gaps and Preambles:包含帧间隙和前导码
·     Not include Inter-frame Gaps and Preambles:不包含帧间隙和前导码
Input(total):  0 packets, 0 bytes
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
三层以太网接口暂不支持统计三层组播报文。
Input(normal):  0 packets, 0 bytes
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧
giants
接收到的超大帧的数量
超大帧是指有效长度大于端口允许通过最大报文长度的帧:
·     对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧
·     对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧
throttles
接收到的长度为非整数字节的帧的个数
CRC
接收到的CRC校验错误、长度正常的帧的数量
frame
接收到的CRC校验错误、且长度不是整字节数的帧的数量
overruns
当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃
aborts
接收到的非法报文总数,非法报文包括:
·     报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧
·     jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧
·     符号错误帧:报文中至少包含1个错误的符号
·     操作码未知帧:报文是MAC控制帧,但不是Pause帧
·     长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配
ignored
由于端口接收缓冲区不足等原因而丢弃的报文数量
parity errors
接收到的奇偶校验错误的帧的数量
Output(total): 0 packets, 0 bytes
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
Output(normal): 0 packets, 0 bytes
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
output errors
各种发送错误的报文总数
underruns
当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败
deferred
延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
collisions
冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
late collisions
延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
lost carrier
载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
no carrier
无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
Peak input rate
接口输入流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
Peak output rate
接口输出流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
IPv4报文统计信息
IPv6报文统计信息
# 显示所有接口的概要信息。
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP        Description
XGE3/0/1             DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   UP       --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
Interface            Link Speed     Duplex Type PVID Description
XGE3/0/2             DOWN auto      A      A    1
XGE3/0/3             UP   1G(a)     F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaa
# 显示接口Ten-GigabitEthernet3/0/3的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface ten-gigabitethernet 3/0/3 brief description
Speed: (a) - auto
XGE3/0/3             UP   1G(a)     F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示当前物理状态为down的接口的信息以及down的原因。
XGE3/0/1             DOWN Not connected
Vlan2                DOWN Not connected
XGE3/0/2             DOWN Not connected
表1-7 display interface brief命令显示信息描述表
三层模式下(route)接口的概要信息,即三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口
Protocol: (s) - spoofing
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
接口名称缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层协议状态为开启
·     DOWN:表示接口的数据链路层协议状态为关闭
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会取该值
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Brief information of interfaces in bridge mode:
二层模式下(bridge)的接口概要信息,即二层接口的概要信息
Speed: (a) - auto
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始
如果某接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
当显示为“A”时表示该接口的Duplex属性是通过自动协商获取的,但协商还未开始
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
Speed
接口的速率,单位为bps
Duplex
接口的双工模式,取值为:
·     A:表示双工模式由自动协商结果决定
·     F:表示全双工
·     F(a):表示自由协商的结果为全双工
·     H:表示半双工
·     H(a):表示自由协商的结果为半双工
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     DOWN ( Link-Aggregation interface down ):聚合接口被关闭后,该聚合接口的所有成员端口的状态会显示为DOWN,down的原因会显示为DOWN ( Link-Aggregation interface down )
·     DOWN (Loopback detection down):由于环路检测模块检测到环路而自动关闭接口
·     DOWN ( Monitor-Link uplink down ):由于Monitor Link模块检测到上行链路down而自动关闭接口
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为DOWN,down的原因会显示为MAD ShutDown
·     Not connected:表示没有物理连接(可能没有插网线或者网线故障)
·     STP DOWN:由于触发了STP BPDU保护而自动关闭接口
·     Port Security Disabled:因检测到端口收到非法报文,端口安全的入侵检测机制将端口关闭
·     flow-interval
display interface link-info命令用来显示接口的状态和报文统计等信息。
display interface link-info [ main ]
main:显示除子接口外的所有接口的状态和报文统计等信息。不指定该参数,显示所有接口的状态和报文统计等信息。
# 显示所有接口的状态和报文统计等信息。
<Sysname> display interface link-info
Interface        Link Protocol  InUsage OutUsage         InErrs        OutErrs
XGE3/0/1         UP   UP            10%       0%              0              0
NULL0            UP   UP(s)          0%       0%              0              0
 Overflow: More than 7 digits.
       --: Not supported.
表1-8 display interface link-info命令显示信息描述表
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会具有该属性
接口名简称
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     Stby:表示该接口是一个处于Standby状态的备份接口
Protocol
接口数据链路层协议状态,取值为:
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会取该值
InUsage
接收方向最近一个统计周期的带宽利用率。接口接收方向最近一个统计周期内的带宽利用率=接口接收方向最近一个统计周期内平均速率/接口带宽。统计周期可以通过flow-interval命令进行设置
OutUsage
发送方向最近一个统计周期的带宽利用率。接口发送方向最近一个统计周期内的带宽利用率=接口发送方向最近一个统计周期内平均速率/接口带宽。统计周期可以通过flow-interval命令进行设置
InErrs
接口接收的错误报文总数(单位为包)
OutErrs
接口发送的错误报文总数(单位为包)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围,Overflow表示数据的长度超过了7位十进制数
--: Not supported.
·     flow-interval
display interface main命令用来显示除子接口以外的接口的运行状态和相关信息。
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type:指定接口类型。如果不指定本参数,则显示所有类型接口的信息。
# 查看除子接口以外的接口的运行状态和相关信息。
<Sysname> display interface main
IP packet frame type: Ethernet II, hardware address: 4005-6538-0100
Loopback is not set
PVID: 1
MDI type: Automdix
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 2
Last link flapping: Never
Current system time:2018-04-11 10:20:24
Last time when physical state changed to down:2018-04-11 09:11:09
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
Ten-GigabitEthernet3/0/2
Description: Ten-GigabitEthernet3/0/2 Interface
IP packet frame type: Ethernet II, hardware address: 4005-6538-0107
IPv6 packet frame type: Ethernet II, hardware address: 4005-6538-0107
Last time when physical state changed to down:2018-04-11 09:33:52
# 显示除子接口以外所有接口的概要信息。
<Sysname> display interface brief main
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Speed: (a) - auto
# 显示除子接口以外的接口的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface  brief description main
Speed: (a) - auto
XGE3/0/3             UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示除子接口以外当前物理状态为down的接口的信息以及down的原因。
<Sysname> display interface brief down main
本命令显示信息描述请参见display interface命令。
display link-flap protection命令用来显示接口链路震荡保护功能的相关信息。
display link-flap protection [ interface interface-type [ interface-number ] ]
interface interface-type [ interface-number ]:显示指定接口的链路震荡保护功能信息。其中,interface-type表示接口类型,interface-number表示指定接口编号。如果不指定本参数,则显示所有支持接口的链路震荡保护功能信息。
如果不指定接口编号,则显示所有该类型接口的信息。
# 显示接口链路震荡保护功能的相关信息。
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface            Link-flap  Status      Interval(L1/L2)     Threshold(L1/L2)
XGE3/0/1             Enabled    Down                   10/5                5/60
XGE3/0/2             Disabled   N/A                   --/--               --/--
表1-9 display link-flap protection命令显示信息描述表
全局链路震荡保护功能,取值为:
·     Enabled:表示全局的链路震荡功能处于开启状态
·     Disabled:表示全局的链路震荡功能处于关闭状态
接口名称缩写
Link-flap
接口链路震荡保护功能,取值为:
·     Enabled:表示接口的链路震荡功能处于开启状态
·     Disabled:表示接口的链路震荡功能处于关闭状态
Status
接口状态,取值为:
·     Down:表示接口因为受到链路震荡保护被关闭
·     N/A:表示接口状态未受到链路震荡保护功能影响
Interval(L1/L2)
一级接口链路震荡检查时间间隔/二级接口链路震荡检查时间间隔
Threshold(L1/L2)
一级接口链路震荡次数/二级接口链路震荡次数
·     link-flap protect enable
display link-state-change statistics interface命令用来显示接口物理状态变化的统计信息。
display link-state-change statistics interface [ interface-type [ interface-number ] ]
如果不指定interface-typeinterface-number,则显示所有接口的统计信息;
如果指定interface-type而不指定interface-number,则显示所有该类型接口的统计信息
# 显示所有以太网接口的状态变化统计信息。
<Sysname> display link-state-change statistics interface
Interface              Change-times  Last-change-time     Reset link-state time
                                     Link-flap-begin      Link-flap-end
XGE3/0/1               0             Never                Never
                                     Never                Never
表1-10 display link-state-change statistics interface命令显示信息描述表
接口名称缩写
Change-times
物理状态变换次数
Last-change-time
接口物理状态上一次变化的时间
清除接口的物理状态变化统计信息的时间
Link-flap-begin
最近一次检测到的接口物理状态频繁震荡的开始时间,没有发生频繁震荡时显示为Never
Link-flap-end
最近一次检测到的接口物理状态频繁震荡的结束时间,没有发生频繁震荡时显示为Never
·     reset link-state-change statistics interface
display packet-drop命令用来显示接口丢弃的报文的信息。
(独立运行模式)‌
display packet-drop { interface [ interface-type [ interface-number ] ] | slot [ slot-number ] | summary }
display packet-drop { interface [ interface-type [ interface-number ] ] | chassis [ chassis-number [ slot slot-number ] ] | summary }
interface-type:显示指定类型接口丢弃的报文的信息。
interface-number:显示指定编号接口丢弃的报文的信息。
summary:将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
slot [ slot-number ]:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示所有单板。(独立运行模式)
chassis [ chassis-number [ slot slot-number ] ]:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定chassis-number参数,则表示所有成员设备的所有单板。如果不指定slot参数,则表示所有成员设备。(IRF模式)‌
如果不指定接口类型和接口编号,显示所有支持本命令的接口的丢弃报文的信息。
如果仅指定接口类型,显示该类型所有支持本命令的接口的丢弃报文的信息。
# 显示接口Ten-GigabitEthernet3/0/1丢弃报文的信息。
<Sysname> display packet-drop interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1:
  Packets dropped due to full GBP or insufficient bandwidth: 301
  Packets dropped due to Fast Filter Processor (FFP): 261
  Packets dropped due to STP non-forwarding state: 0
  Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped:0
  Packets of ECN marked: 0
# 将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
<Sysname> display packet-drop summary
All interfaces:
# 显示所有slot的丢弃报文统计信息。(独立运行模式)‌
<Sysname> display packet-drop slot
Slot            Total
0               210
1               210
2               210
# 显示所有chassis上所有slot的丢弃报文统计信息。(IRF模式)
<Sysname> display packet-drop chassis
Chassis         Slot            Total
1               0               210
2               0               210
                1               210
                2               210
表1-11 display packet-drop命令显示信息描述表
由于芯片缓存满或者带宽不够导致的丢包数
由于数据包被过滤所导致的丢包数
由于STP协议状态为discarding导致的丢包数
由于触发WRED(Weighted Random Early Detection,加权随机早期检测)队列门限导致ECN(Explicit Congestion Notification,显示拥塞通知)域被标记为11的报文数,有关WRED、ECN域的详细介绍请参见“ACL和QoS配置指导”中的“QoS”
Slot
Slot编号
Chassis
Chassis编号
Total
丢弃报文统计信息
display lbn-group status命令用来显示LBN组信息。
# 显示LBN组信息。
<System> display lbn-group status
Global lbn-group configuration: Enable
GroupName      GroupIndex    Index       Interface
Leaf1          0             0           Ten-GigabitEthernet3/0/2
Leaf           1             0           Ten-GigabitEthernet3/0/3
                                         Ten-GigabitEthernet3/0/4
表1-12 display lbn-group status命令显示信息描述表
LBN功能的配置状态,取值包括:
·     Disable:表示关闭状态
·     Enable:表示开启状态
GroupName
LBN组名称
GroupIndex
LBN组索引
Index
LBN组内成员索引
LBN组中成员接口的名称
·     group-member interface
display slot-monitor命令用来显示单板告警信息。
(独立运行模式)‌
display slot-monitor slot slot-number
display slot-monitor chassis chassis-number slot slot-number
slot slot-number:指定单板。slot-number为单板所在的槽位号。(独立运行模式)
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。‌‌
slot slot-number:指定成员设备或PEX。slot-number为设备在IRF中的成员编号或者PEX的虚拟槽位号。‌‌
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
# 显示slot 1的单板告警信息。
<Sysname> display slot-monitor slot 1
Slot 1:
  Packet-Drop:
    Trap enable    : Y
    Trigger Action : Reboot
    Alarm status   : N
    High threshold : 1000
    Low threshold  : 100
    Interval       : 10 s
    Value          : 10
    Trigger at     : Never
表1-13 display slot-monitor命令显示信息描述表
Trap enable
告警是否开启:
·     Y:表示开启
·     N:表示关闭
Trigger Action
达到告警阈值后的处理方式:
·     Reboot:重启单板
·     Down:关闭单板下所有接口
Alarm status
告警状态:
·     Y:表示当前处于告警状态
·     N:表示当前未处于告警状态
High threshold
告警上限阈值
Low threshold
告警下限阈值
Interval
告警的收集和比较间隔周期,单位为秒
Value
触发错误报文告警时,表示最近一次统计周期内的错误报文数量
Trigger at
记录最近一次触发告警阈值的时间:
·     [L]YYYY/MM/DD HH:MM:SS:记录最近一次触发告警下限阈值的系统时间
·     [H]YYYY/MM/DD HH:MM:SS:记录最近一次触发告警上限阈值的系统时间
·     Never:未触发告警阈值门限
1.1.19  duplex
duplex命令用来设置以太网接口的双工模式。
undo duplex命令用来恢复缺省情况。
duplex { auto | full | half }
undo duplex
管理用以太网光接口的双工模式为full(全双工)状态,其他以太网接口的双工模式为auto(自协商)状态。
以太网接口视图
auto:接口与对端接口自动协商双工状态。
full:全双工状态,接口在发送数据包的同时可以接收数据包。
half:半双工状态,接口同一时刻只能发送数据包或接收数据包。光口不支持配置参数。
对于同一物理链路两端的以太网接口,双工模式需要配置成一致,否则接口可能不能正常工作。
对于管理用以太网光接口,双工模式仅支持full
# 将以太网接口Ten-GigabitEthernet3/0/1接口设置为全双工状态。
[Sysname-Ten-GigabitEthernet3/0/1] duplex full
1.1.20  eee enable
光口不支持本命令。
eee enable命令用来开启EEE(Energy Efficient Ethernet)节能功能。
undo eee enable命令用来关闭EEE节能功能。
eee enable
undo eee enable
EEE节能功能处于关闭状态。
以太网接口视图
接口开启EEE节能功能后,如果在连续一段时间(由芯片规格决定,不能通过命令行配置)内接口状态始终为up且没有收发任何报文,则接口自动进入低功耗模式;当接口需要收发报文时,接口又自动恢复到正常工作模式,从而达到节能的效果。
eee enableloopback命令互斥,后配置的失败。
# 在Ten-GigabitEthernet3/0/1下开启EEE节能功能。
[Sysname-Ten-GigabitEthernet3/0/1] eee enable
1.1.21  flow-control
flow-control命令用来开启以太网接口的流量控制功能。
undo flow-control命令用来关闭以太网接口流量控制功能。
flow-control
undo flow-control
以太网接口的流量控制功能处于关闭状态。
以太网接口视图
配置flow-control命令后,设备具有发送和接收流量控制报文的能力:
·     当本端发生拥塞时,设备会向对端发送流量控制报文。
·     当本端收到对端的流量控制报文后,会停止报文发送。
只有本端和对端设备都开启了流量控制功能,才能实现对本端以太网接口的流量控制。
# 开启以太网接口Ten-GigabitEthernet3/0/1的流量控制功能。
[Sysname-Ten-GigabitEthernet3/0/1] flow-control
flow-control receive enable命令用来开启以太网接口的接收流量控制功能。
undo flow-control命令用来关闭以太网接口的接收流量控制功能。
undo flow-control
以太网接口的接收流量控制功能处于关闭状态。
以太网接口视图
配置flow-control receive enable命令后,设备具有接收流量控制报文的能力,但不具有发送流量控制报文的能力。
开启以太网接口的接收流量控制功能后:
·     当设备收到对端的流量控制报文,会停止向对端发送报文。
·     当本端发生拥塞时,设备不能向对端发送流量控制报文。
如果要应对单向网络拥塞的情况,可以在一端配置flow-control receive enable,在对端配置flow-control;如果要求本端和对端网络拥塞都能处理,则两端都必须配置flow-control
# 使能以太网接口Ten-GigabitEthernet3/0/1的接收流量控制功能。
[Sysname-Ten-GigabitEthernet3/0/1] flow-control receive enable
【相关配置】
·     flow-control
flow-interval命令用来配置接口统计报文信息的时间间隔。
undo flow-interval命令用来恢复缺省情况。
flow-interval interval
undo flow-interval
接口统计报文信息的时间间隔为300秒。
以太网接口视图
interval:接口统计信息的时间间隔值,系统视图下取值范围为5~300,单位为秒,步长为5(即取值必须为5的整数倍);以太网接口视图下取值范围为1~300,单位为秒,步长为5。
# 设置以太网接口Ten-GigabitEthernet3/0/1的统计信息时间间隔为100秒。
[Sysname-Ten-GigabitEthernet3/0/1] flow-interval 100
group-member interface命令用来将指定的接口添加到LBN组中。
undo group-member interface命令用来将指定的接口从当前LBN组中删除。
group-member interface interface-list
undo group-member interface interface-list
group-member interface interface-type interface-number index index-value
undo group-member interface interface-type interface-number index index-value
LBN组视图
LBN组中未添加接口。
interface-list:表示将指定的接口添加到LBN组中,设备自动为接口分配索引。表示方式为interface-list= { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-n>interface-type interface-number为接口类型和接口编号。&<1-n>表示前面的参数最多可以输入n次,n的取值范围以设备实际情况为准。
interface-type interface-number:表示将指定的接口添加到LBN组中,设备手动为接口分配索引。
index index-value:表示手工为LBN组成员接口指定的索引,通过一定的算法计算流量的入接口和入接口所对应的出接口,从而实现流量负载分担功能。index-value表示索引值,取值范围为0~63。
将接口添加到LBN组时,可以手工指定接口索引,也可以由设备为添加的接口分配索引。手工指定接口索引时,需要使用index参数,一次只能添加一个接口。设备自动为接口分配索引时,不需要使用index参数,一次可以添加一个或多个接口。
当设备自动为接口分配索引时,设备会为命令行配置的第一个端口分配当前最小的索引,随后将配置的剩余端口按端口编号顺序从小到大分配索引。
请保证LBN组成员接口的索引值连续,索引值不连续会导致所对应的流量出接口不连续,负载流量不均衡:
·     不建议手工指定接口的索引值,请在专业人士的指导下手工配置接口的索引值。
·     如果从LBN组中删除接口导致接口索引值不连续,需要重新手动调整索引值使之连续。
本命令仅支持将物理接口添加到LBN组中,且必须是流量进入的接口。
不支持将IRF物理端口添加到LBN组。
同一个接口只能加入一个LBN组。
接口加入LBN组后display ip load-sharing path命令对该接口不生效。
执行本命令时,如果使用to关键字,则to关键字前后的接口类型必须相同。
# 配置将接口XGE3/0/1到XGE3/0/4加入LBN组Leaf1。
[Sysname] lbn-group Leaf1
[Sysname-lbn-group-Leaf1] group-member interface Ten-GigabitEthernet3/0/1 to Ten-GigabitEthernet3/0/4
# 配置将接口XGE3/0/1加入到LBN组Leaf1,并指定接口的索引为3。
[Sysname-lbn-group-Leaf1] group-member interface Ten-GigabitEthernet3/0/1 index 3
ifmonitor buffer mode命令用来配置单板的缓存数据监控模式。
undo ifmonitor buffer mode命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor buffer mode { standard | enhanced } slot slot-number
undo ifmonitor buffer mode slot slot-number
ifmonitor buffer mode { standard | enhanced } chassis chassis-number slot slot-number
undo ifmonitor buffer mode chassis chassis-number slot slot-number
未配置单板的缓存数据监控采集模式。
standard:配置单板的缓存数据监控采集模式为标准模式。
enhanced:配置单板的缓存数据监控采集模式为增强模式。
slot slot-number:配置指定单板,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备上指定单板,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
功能描述
单板的缓存数据监控采集模式有以下两种:
·     标准模式:在标准模式下,单板支持监控采集多个接口的队列缓存数据,数据采集周期可配置为5ms、10ms、20ms、50ms、100ms。
·     增强模式:在增强模式下,单板仅支持监控采集1个接口的队列缓存数据,数据采集周期固定为1ms。
注意事项
如果需要关闭或修改单板的缓存数据监控模式,必须先执undo port ifmonitor buffer queue enable命令。
本命令与配置接口队列数据缓冲区使用门限值互斥,有关配置接口队列数据缓冲区使用门限值的介绍,请参见“ACL和QoS配置指导”中的“数据缓冲区”。
# 配置缓存数据监控模式为标准模式。(独立运行模式)‌
[Sysname] ifmonitor buffer mode standard slot 1
# 配置缓存数据监控模式为标准模式。(IRF模式)
[Sysname] ifmonitor buffer mode standard chassis 1 slot 1
·     port ifmonitor buffer queue enable
·     display ifmonitor buffer status
ifmonitor crc-error命令用来全局配置CRC错误报文告警参数。
undo ifmonitor crc-error命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ down-auto-recovery | shutdown ]
undo ifmonitor crc-error slot slot-number
ifmonitor crc-error chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval [ down-auto-recovery | shutdown ]
undo ifmonitor crc-error chassis chassis-number slot slot-number
CRC错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定CRC错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定CRC错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
down-auto-recovery:表示当接口接收到的CRC错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。端口在到达shutdown-interval crc-error命令配置的端口状态自动恢复时间之后,将自动恢复到真实的物理状态。未指定本参数时,表示当接口接收到的CRC错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
shutdown:表示当接口接收到的CRC错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因CRC错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的CRC错误报文超出上限告警阈值,接口不会被关闭,接口将产生超上限告警,并进入告警状态。当已经触发超上限告警后,如果配置本参数,则接口会被关闭。
slot slot-number:配置指定单板上所有接口的CRC错误报文告警参数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备上指定单板上所有接口的CRC错误报文告警参数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
开启CRC错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的CRC错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的CRC错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置CRC错误报文告警参数。
·     系统视图下的配置对指定slot的所有接口有效,接口视图下的配置只对当前接口有效。
·     对于接口来说,优先采用接口视图下的配置,当该接口未进行配置时,才采用系统视图下的配置。
多次执行本命令,最后一次执行的命令生效。
# 配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。(独立运行模式)‌
[Sysname] ifmonitor crc-error slot 1 high-threshold 5000 low-threshold 400 interval 6
# 配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。(IRF模式)
[Sysname] ifmonitor crc-error chassis 1 slot 1 high-threshold 5000 low-threshold 400 interval 6
·     shutdown-interval crc-error
·     snmp-agent trap enable ifmonitor
ifmonitor input-buffer-drop命令用来全局配置入方向数据缓冲区丢弃报文告警参数。
undo ifmonitor input-buffer-drop命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor input-buffer-drop slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-buffer-drop slot slot-number
ifmonitor input-buffer-drop chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-buffer-drop chassis chassis-number slot slot-number
入方向数据缓冲区丢弃报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定入方向数据缓冲区丢弃报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定入方向数据缓冲区丢弃报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定入方向数据缓冲区丢弃报文的数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的入方向数据缓冲区丢弃报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向数据缓冲区丢弃报文被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向数据缓冲区丢弃报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)‌
开启入方向数据缓冲区丢弃报文告警功能后,当接口处于正常状态,并在指定的时间内接收的入方向数据缓冲区丢弃报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的入方向数据缓冲区丢弃报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向数据缓冲区丢弃报文告警参数。
·     系统视图下的配置对所有接口有效,接口视图下的配置只对当前接口有效。(不支持指定slot的设备)
·     系统视图下的配置对指定slot的所有接口有效,接口视图下的配置只对当前接口有效。(支持指定slot的设备)
# 配置入方向数据缓冲区丢弃报文告警上限阈值为5000,入方向数据缓冲区丢弃报文告警下限阈值为400,入方向数据缓冲区丢弃报文的数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor input-buffer-drop high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-error命令用来全局配置入方向错误报文告警参数。
undo ifmonitor input-error命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
ifmonitor input-error chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error chassis chassis-number slot slot-number
入方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口入方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口入方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口入方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口入方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向错误报文超出上限告警阈值,接口不会被关闭,接口将产生超上限告警,并进入告警状态。当已经触发超上限告警后,如果配置本参数,则接口会被关闭。
slot slot-number:配置指定单板上所有接口的入方向错误报文告警参数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备上指定单板上所有接口的入方向错误报文告警参数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
开启入方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内入方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内入方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向错误报文告警参数。
# 配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。(独立运行模式)‌
[Sysname] ifmonitor input-error slot 1 high-threshold 5000 low-threshold 400 interval 6
# 配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。(IRF模式)
[Sysname] ifmonitor input-error chassis 1 slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage命令用来全局配置入方向带宽利用率的告警参数。
undo ifmonitor input-usage命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
ifmonitor input-usage chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage chassis chassis-number slot slot-number
入方向带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定入方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
slot slot-number:配置指定单板的参数。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备上指定单板的参数。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
当接口处于正常状态,并在最近一个统计周期内入方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内入方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向宽带利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启入方向带宽利用率告警功能后才能生效。
# 配置全局入方向带宽利用率告警上限阈值为95,入方向带宽利用率告警下限阈值为80。(独立运行模式)‌
[Sysname] ifmonitor input-usage slot 1 high-threshold 95 low-threshold 80
# 配置全局入方向带宽利用率告警上限阈值为95,入方向带宽利用率告警下限阈值为80。(IRF模式)
[Sysname] ifmonitor input-usage chassis 1 slot 1 high-threshold 95 low-threshold 80
·     flow-interval
ifmonitor latency命令用来配置报文时延等级阈值。
undo ifmonitor latency命令用来恢复缺省情况。
ifmonitor latency { level0 level0-value | level1 level1-value | level2 level2-number | level3 level3-number | level4 level4-number | level5 level5-number | level6 level6-number | level7 level7-number } *
报文时延0级阈值为200纳秒,报文时延1级阈值为400纳秒,报文时延2级阈值为600纳秒,报文时延3级阈值为800纳秒,报文时延4级阈值为1000纳秒,报文时延5级阈值为5000纳秒,报文时延6级阈值为10000纳秒,报文时延7级阈值为20000000纳秒。
level0 level0-value:指定报文时延0级阈值,取值范围为1~4294967295,单位为纳秒。
level1 level1-value:指定报文时延1级阈值,取值范围为1~4294967295,单位为纳秒。
level2 level2-number:指定报文时延2级阈值,取值范围为1~4294967295,单位为纳秒。
level3 level3-number:指定报文时延3级阈值,取值范围为1~4294967295,单位为纳秒。
level4 level4-number:指定报文时延4级阈值,取值范围为1~4294967295,单位为纳秒。
level5 level5-number:指定报文时延5级阈值,取值范围为1~4294967295,单位为纳秒。
level6 level6-number:指定报文时延6级阈值,取值范围为1~4294967295,单位为纳秒。
level7 level7-number:指定报文时延7级阈值,取值范围为1~4294967295,单位为纳秒。
工作机制
通过本命令可配置报文不同时延等级对应的时延阈值。例如:报文时延低于等级0的阈值,则此报文对应的时延等级为0,报文时延大于等于等级0且小于等级1阈值,则此报文对应的时延等级为1,依次类推。
注意事项
高等级的阈值不能小于低等级的阈值。
# 配置报文时延等级0对应的时延阈值为200纳秒, 等级1对应的时延阈值为1000纳秒,等级2对应的时延阈值为2000纳秒,等级3对应的时延阈值为5000纳秒,等级4对应的时延阈值为9000纳秒,等级5对应的时延阈值为20000纳秒,等级6对应的时延阈值为40000纳秒,等级7对应的时延阈值为100000纳秒。
[Sysname] ifmonitor latency level0 200 level1 1000 level2 2000 level3 5000 level4 9000 level5 20000 level6 40000 level7 100000
·     port ifmonitor buffer latency enable
·     display ifmonitor latency-detection statistics
ifmonitor output-buffer-drop命令用来全局配置出方向数据缓冲区丢弃报文告警参数。
undo ifmonitor output-buffer-drop命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor output-buffer-drop slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-buffer-drop slot slot-number
ifmonitor output-buffer-drop chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-buffer-drop chassis chassis-number slot slot-number
出方向数据缓冲区丢弃报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定出方向数据缓冲区丢弃报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定出方向数据缓冲区丢弃报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定出方向数据缓冲区丢弃报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的出方向数据缓冲区丢弃报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向数据缓冲区丢弃报文被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向数据缓冲区丢弃报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启出方向数据缓冲区丢弃报文告警功能后,当接口处于正常状态,并在指定的时间内接收的出方向数据缓冲区丢弃报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的出方向数据缓冲区丢弃报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向数据缓冲区丢弃报文告警参数。
# 配置出方向数据缓冲区丢弃报文告警上限阈值为5000,出方向数据缓冲区丢弃报文告警下限阈值为400,出方向数据缓冲区丢弃报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor output-buffer-drop high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-error命令用来全局配置出方向错误报文告警参数。
undo ifmonitor output-error命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
ifmonitor output-error chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error chassis chassis-number slot slot-number
出方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口出方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口出方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口出方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口出方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向错误报文超出上限告警阈值,接口不会被关闭,接口将产生超上限告警,并进入告警状态。当已经触发超上限告警后,如果配置本参数,则接口会被关闭。
slot slot-number:配置指定单板上所有接口的出方向错误报文告警参数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备上指定单板上所有接口的出方向错误报文告警参数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)‌
开启出方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内出方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内出方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向错误报文告警参数。
# 配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。(独立运行模式)‌
[Sysname] ifmonitor output-error slot 1 high-threshold 5000 low-threshold 400 interval 6
# 配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。(IRF模式)
[Sysname] ifmonitor output-error chassis 1 slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage命令用来全局配置出方向带宽利用率的告警参数。
undo ifmonitor output-usage命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
ifmonitor output-usage chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage chassis chassis-number slot slot-number
出方向的带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定出方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定出方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内出方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内出方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向宽带利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启出方向带宽利用率告警功能后才能生效。
# 配置全局出方向带宽利用率告警上限阈值为80,出方向带宽利用率告警下限阈值为60。(独立运行模式)‌
[Sysname] ifmonitor output-usage slot 1 high-threshold 80 low-threshold 60
# 配置全局出方向带宽利用率告警上限阈值为80,出方向带宽利用率告警下限阈值为60。(IRF模式)
[Sysname] ifmonitor output-usage chassis 1 slot 1 high-threshold 80 low-threshold 60
·     flow-interval
ifmonitor rx-pause命令用来全局配置接收PAUSE帧告警参数。
undo ifmonitor rx-pause命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
ifmonitor rx-pause chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause chassis chassis-number slot slot-number
接收PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接收PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接收PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内接收PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置接收PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启接收PAUSE帧告警功能后才能生效。
# 配置接收PAUSE帧告警上限阈值为30,接收PAUSE帧告警下限阈值为20,接收PAUSE帧数据收集和比较时间间隔为4秒。(独立运行模式)‌
[Sysname] ifmonitor rx-pause slot 1 high-threshold 30 low-threshold 20 interval 4
# 配置接收PAUSE帧告警上限阈值为30,接收PAUSE帧告警下限阈值为20,接收PAUSE帧数据收集和比较时间间隔为4秒。(IRF模式)
[Sysname] ifmonitor rx-pause chassis 1 slot 1 high-threshold 30 low-threshold 20 interval 4
ifmonitor tx-pause命令用来全局配置发送PAUSE帧告警参数。
undo ifmonitor tx-pause命令用来恢复缺省情况。
(独立运行模式)‌
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor tx-pause slot slot-number
ifmonitor tx-pause chassis chassis-number slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor tx-pause chassis chassis-number slot slot-number
发送PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定发送PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定发送PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口发送PAUSE帧超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因发送PAUSE帧被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口发送PAUSE帧超出上限告警阈值时,接口不会被关闭,接口将产生超上限告警,并进入告警状态。当已经触发超上限告警后,如果配置本参数,则接口会被关闭。
当接口处于正常状态,并在指定的时间内发送PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内发送PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置发送PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启发送PAUSE帧告警功能后才能生效。
# 配置发送PAUSE帧告警上限阈值为20,发送PAUSE帧告警下限阈值为10,发送PAUSE帧数据收集和比较时间间隔为5秒。(独立运行模式)‌
[Sysname] ifmonitor tx-pause slot 1 high-threshold 20 low-threshold 10 interval 5
# 配置发送PAUSE帧告警上限阈值为20,发送PAUSE帧告警下限阈值为10,发送PAUSE帧数据收集和比较时间间隔为5秒。(IRF模式)
[Sysname] ifmonitor tx-pause chassis 1 slot 1 high-threshold 20 low-threshold 10 interval 5
1.1.36  interface
interface命令用来进入接口视图或创建子接口并进入子接口视图。如果指定的子接口已经存在,则直接进入子接口视图。
# 进入以太网接口Ten-GigabitEthernet3/0/1视图。
# 创建以太网子接口Ten-GigabitEthernet3/0/1.1并进入该子接口的视图。
interface default-description output命令用来在显示接口信息时,显示接口缺省的描述信息。
undo interface default-description output命令用来在显示接口信息时,不显示接口缺省的描述信息。
显示接口信息时,会显示接口缺省的描述信息。
本命令仅对物理接口生效。
# 配置显示接口信息时,不显示接口缺省的描述信息。
[Sysname] undo interface default-description output
·     description
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
设备允许长度为13312字节的超长帧通过。
二层以太网接口视图
三层以太网接口视图
在IRF组网中,成员设备间转发的超长帧最大长度为13280字节。
# 允许超长帧通过以太网接口Ten-GigabitEthernet3/0/1。
[Sysname-Ten-GigabitEthernet3/0/1] jumboframe enable
1.1.39  link-delay
link-delay命令用来配置以太网接口物理连接状态抑制功能。
undo link-delay命令用来恢复缺省情况。
undo link-delay { down | up }
系统会将接口状态改变立即上报CPU,即不进行抑制。
以太网接口视图
down:设置以太网接口物理连接down状态抑制功能。
up:设置以太网接口物理连接up状态抑制功能。
msec:表示配置的抑制时间为毫秒级。不指定该参数时,表示配置的抑制时间为秒级。
delay-time:接口物理连接状态抑制时间值,0表示不抑制,即接口状态改变时立即上报CPU。
·     未指定msec参数时,取值范围为0~120,单位为秒。
·     指定msec参数时,取值范围为0~10000,且为100的倍数,单位为毫秒。
使用该命令时,选取的参数不同,抑制效果不同:
·     down:表示接口状态从up变成down时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是down,再上报。
·     up:表示接口状态从down变成up时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是up,再上报。
同一接口下,接口状态从up变成down的抑制时间和接口状态从down变成up的抑制时间可以不同。在同一接口下,多次执行本命令:
·     可以分别配置抑制上报down状态和抑制上报up状态。
·     当配置的是同一状态的抑制时间时,则最新的配置生效。
对于开启了生成树协议、RRPP或Smart Link的端口不推荐使用该命令。
以太网接口上不能同时配置本命令、dampening命令和port link-flap protect enable命令。
# 设置以太网接口物理连接down状态抑制时间为8秒。
[Sysname-Ten-GigabitEthernet3/0/1] link-delay down 8
# 设置以太网接口物理连接up状态抑制时间为800毫秒。
[Sysname-Ten-GigabitEthernet3/0/1] link-delay up msec 800
·     dampening
link-flap protect enable命令用来开启全局链路震荡保护功能。
undo link-flap protect enable命令用来关闭全局链路震荡保护功能。
link-flap protect enable [ down-auto-recovery ]
全局链路震荡功能处于关闭状态。
down-auto-recovery:表示设备检测到接口链路震荡时,该接口将被关闭。在到达shutdown-interval link-flap命令配置的接口状态检测定时器超时时间之后,接口将恢复到真实的物理状态。若不配置该参数,则表示接口DOWN后不会自动恢复UP状态。
链路震荡即接口的物理状态频繁变化时,会导致网络拓扑结构不断变化,给系统带来额外的开销。例如,在主备链路场景中,当主链路的接口物理状态频繁UP/DOWN时,业务将在主备链路之间来回切换,增加了设备的负担。为了解决该问题,设备提供了链路震荡保护功能。
配置本功能后,当接口状态从UP变为DOWN时,系统会启动链路震荡检查。在链路震荡检查时间间隔内,如果该接口状态从UP变为DOWN的次数大于等于链路震荡次数阈值,则关闭该接口。
只有系统视图下和接口视图下同时开启链路震荡保护功能后,接口的链路震荡保护功能才能生效。
只有系统视图下和指定接口视图下同时配置down-auto-recovery参数,指定接口DOWN后才会自动恢复UP状态。
# 全局开启链路震荡保护功能。
[Sysname] link-flap protect enable
loadbalance ecmp lbn-group enable命令用来开启等价路由方式的LBN功能。
undo loadbalance ecmp lbn-group enable命令用来关闭等价路由方式的LBN功能。
等价路由方式的LBN功能处于关闭状态。
本命令需要在配置了等价路由功能的组网中使用,通过LBN功能实现流量负载分担。
对应用lbn-group功能的ecmp出入口进行配置时,入口组成员数是出口组成员数的整倍关系,流量对应出入口的lbn index保持一致。(例如:出入口成员数相同情况下,入口lbn index为0,1,2,3,出口为0,1,2,3;出入口成员数不同情况:入口lbn index为0,1,0,1,出口则为0,1)
# 开启等价路由方式的LBN功能。
[Sysname] loadbalance ecmp lbn-group enable
1.1.42  loopback
开启环回功能后,接口将不能正常转发数据包,请按需配置。
loopback命令用来开启以太网接口的环回功能。
undo loopback命令用来关闭以太网接口的环回功能。
loopback internal
undo loopback
以太网接口的环回功能处于关闭状态。
以太网接口视图
internal:开启以太网接口的内部环回功能。
开启环回功能后,接口将自动切换到全双工模式,关闭环回功能后会自动恢复原有双工模式。
shutdownport up-modeloopback命令互斥,后配置的失败。
# 开启以太网接口Ten-GigabitEthernet3/0/1的内部环回功能。
[Sysname-Ten-GigabitEthernet3/0/1] loopback internal
multicast-suppression命令用来开启端口组播风暴抑制功能,并设置组播风暴抑制阈值。
undo multicast-suppression命令用来关闭端口组播风暴抑制功能。
所有接口不对组播流量进行抑制。
以太网接口视图
ratio:指定以太网接口允许通过的最大组播流量占该接口带宽的百分比。取值范围为0~100。数值越小,则允许通过的组播流量也越小。
pps max-pps:指定以太网接口每秒最多通过的组播包包数,取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒最多通过的组播流量,单位为kbps,取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大组播报文流量。当接口上的组播流量超过用户设置的值后,系统将丢弃超出组播流量限制的报文,从而使接口组播流量所占的比例控制在限定的范围内,以便保证业务的正常运行。
执行multicast-suppressionstorm-constrain命令都能开启端口的组播风暴抑制功能,storm-constrain命令通过软件对组播报文进行抑制,对设备性能有一定影响,multicast-suppression通过芯片物理上对组播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置multicast-suppressionstorm-constrain命令,以免配置冲突,导致抑制效果不确定。
# 在以太网接口Ten-GigabitEthernet3/0/1上,每秒最多允许10000kbps组播报文通过,对超出该范围的组播报文进行抑制。
[Sysname-Ten-GigabitEthernet3/0/1] multicast-suppression kbps 10000
·     broadcast-suppression
port fec mode命令用来配置接口的FEC(Forward Error Correction,前向纠错)模式。
undo port fec mode命令用来恢复缺省情况。
port fec mode { auto | base-r | none | rs-fec }
undo port fec mode
接口的FEC模式处于自协商模式。
25GE接口视图
100GE接口视图
400GE接口视图
auto:表示自适应FEC模式,根据光模块类型自动设置FEC模式或者关闭接口的FEC功能。
base-r:表示BASE-R FEC模式。100GE和400GGE接口不支持本参数。
none:不进行前向纠错。
rs-fec:表示RS-FEC模式。
FEC用于报文纠错,它通过在发送端为数据报文附加纠错信息,在接收端利用纠错信息来纠正数据报文在传输时产生的错误码,以提高传输质量。用户需要根据实际情况来选择FEC模式。
用户需要保证链路两端使用的FEC模式一致。
在接口插入QSFP28 BIDI光模块时,port fec mode命令仅支持将接口的FEC模式配置为autonone
仅SF系列接口板和SG系列接口板上的25G、100G和400G口支持rs-fec参数,部分早期生产的SF系列接口板可能不支持rs-fec参数,命令行下发后设备上会提示不支持。
400G端口配置的速率不同时,FEC模式的支持情况也会不同,具体如下:
·     配置为400G或200G速率时,支持设置FEC模式为RS-FEC和自协商模式,不支持设置为none;
·     配置为100G速率时,支持所有参数。
# 配置以太网接口Twenty-FiveGigE1/0/1的FEC模式为自协商模式。
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] port fec mode auto
# 配置以太网接口HundredGigE1/0/1的FEC模式为自协商模式。
[Sysname-HundredGigE1/0/1] port fec mode auto
# 配置以太网接口FourHundredGigE2/0/1的FEC模式为自协商模式。
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] port fec mode auto
port ifmonitor buffer flow-information enable命令用来开启接口缓存的流信息采集功能。
undo port ifmonitor buffer flow-information enable命令用来恢复缺省情况。
未开启接口缓存的流信息采集功能。
工作机制
开启本功能后,当接口缓存使用率第一次超过上限阈值时,开始采集缓存内的流信息(五元组信息),当接口缓存使用率第一次低于下限阈值时,停止采集,然后将这一时间段内采集到的流信息通过gRPC或NETCONF等上报给分析器。
注意事项
多次执行本命令,可以开启多个接口缓存的流信息采集功能。单板最多可同时采集32个接口。
当接口缓存使用率超过上限阈值10秒以上,或者10秒内接口缓存使用率回落到下限阈值以下,设备会将这一时间段内采集到的流信息上报给GRPC模块。
当接口缓存使用率超过上限阈值10秒以上并上报流信息给GRPC后,如果接口缓存使用率未回落到下限阈值以下,同时流量组成发生变化(五元组信息),发生变化的流信息会累积到下次上报。
IRF接口不支持开启接口缓存的流信息采集功能。
接口缓存的流信息采集功能仅支持监测和统计已知单播报文。
# 开启Ten-GigabitEthernet3/0/1接口缓存的流信息采集功能。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor buffer flow-information enable
·     port ifmonitor buffer usage threshold
·     display ifmonitor buffer flow-information
port ifmonitor buffer queue enable命令用来开启指定队列缓存的监控功能。
undo port ifmonitor buffer queue enable用来恢复缺省情况。
port ifmonitor buffer queue queue-index enable [ interval interval ]
undo port ifmonitor buffer queue queue-index enable
队列未开启缓存的监控采集功能。
queue-index:开启指定队列缓存的监控功能。取值范围为0~7。
interval interval:配置队列缓存数据的监控采集周期,取值范围为5、10、20、50、100,单位为毫秒。当单板缓存数据监控采集模式为默认模式时,缺省值为5;增强模式不支持配置本参数,缓存数据的监控采集周期固定为1毫秒。
工作机制
在接口上配置本功能后,设备将执行以下操作:
·     周期性地采集指定队列缓存数据的统计信息,并以1秒为周期,将1秒内采集的数据通过gRPC或NETCONF等上报给分析器。
·     周期性地监测指定队列的缓存使用率和微突发流量,当发生微突发流量事件时,设备会通过gRPC或NETCONF等把事件上报给分析器。
注意事项
配置本功能前,必须先执行ifmonitor buffer mode命令。
多次执行本命令,可以开启多个队列缓存数据监控采集功能。
对于SG系列接口板,接口队列缓存监控功能仅支持监测和统计已知单播报文。
# 开启Ten-GigabitEthernet3/0/1接口队列1的缓存数据监控采集功能,并设置采集周期为10ms。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor buffer queue 1 enable interval 10
·     ifmonitor buffer mode
1.1.47  port ifmonitor buffer usage threshold
port ifmonitor buffer usage threshold命令用来配置接口缓存使用率阈值。
undo port ifmonitor buffer usage threshold命令用来恢复缺省情况。
port ifmonitor buffer usage threshold high high-percent low low-percent
缓存使用率的上限阈值为80%,缓存使用率的下限阈值为30%。
high high-percent:配置缓存使用率的上限阈值,high-percent的取值范围为1~100,单位为百分比。
low low-percent:配置缓存使用率的下限阈值,low-percent的取值范围为1~100,单位为百分比。
# 配置Ten-GigabitEthernet3/0/1接口缓存使用率的上限阈值为60%,下限阈值为30%。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor buffer usage threshold high 60 low 30
1.1.48  port ifmonitor crc-error
port ifmonitor crc-error命令用来配置CRC错误报文告警参数。
undo port ifmonitor crc-error命令用来恢复缺省情况。
port ifmonitor crc-error [ ratio ] high-threshold high-value low-threshold low-value interval interval [ down-auto-recovery | shutdown ]
接口采用的CRC错误报文告警参数与全局采用的CRC错误报文告警参数一致。
以太网接口视图
ratio:表示以百分比形式配置告警阈值。不指定该参数时,表示配置的是告警阈值的大小。
high-threshold high-value:指定CRC错误报文告警上限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
# 在接口Ten-GigabitEthernet3/0/1上配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
1.1.49  port ifmonitor input-buffer-drop
port ifmonitor input-buffer-drop命令用来配置入方向数据缓冲区丢弃报文告警参数。
undo port ifmonitor input-buffer-drop命令用来恢复缺省情况。
port ifmonitor input-buffer-drop high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的入方向数据缓冲区丢弃报文告警参数与全局采用的入方向数据缓冲区丢弃报文告警参数一致。
以太网接口视图
interval interval:指定入方向数据缓冲区丢弃报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口Ten-GigabitEthernet3/0/1上配置入方向数据缓冲区丢弃报文告警上限阈值为5000,入方向数据缓冲区丢弃报文告警下限阈值为400,入方向数据缓冲区丢弃报文的数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor input-buffer-drop high-threshold 5000 low-threshold 400 interval 6
1.1.50  port ifmonitor input-error
port ifmonitor input-error命令用来配置入方向错误报文告警参数。
undo port ifmonitor input-error命令用来恢复缺省情况。
接口采用的入方向错误报文告警参数与全局采用的入方向错误报文告警参数一致。
以太网接口视图
# 在接口Ten-GigabitEthernet3/0/1上配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
1.1.51  port ifmonitor input-usage
port ifmonitor input-usage命令用来配置入方向带宽利用率的告警参数。
undo port ifmonitor input-usage命令用来恢复缺省情况。
接口采用的入方向带宽利用率告警参数与全局采用的入方向带宽利用率告警参数一致。
high-threshold high-value:指定入方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
# 在接口Ten-GigabitEthernet3/0/1上配置入方向带宽利用率告警上限阈值为80,入方向带宽利用率告警下限阈值为60。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor input-usage high-threshold 80 low-thershold 60
·     flow-interval
1.1.52  port ifmonitor latency-detection enable
port ifmonitor latency-detection enable命令用来开启报文时延检测功能。
undo port ifmonitor latency-detection enable命令用来恢复缺省情况。
未开启报文时延检测功能。
工作机制
开启本功能后,将持续检测从该接口出去的报文在接口所在单板内转发的时延,并进行时延等级的划分。根据报文时延的分布情况可以判断报文的转发质量。
# 开启Ten-GigabitEthernet3/0/1接口报文时延检测功能。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor latency detection enable
·     ifmonitor latency
1.1.53  port ifmonitor output-buffer-drop
port ifmonitor output-buffer-drop命令用来配置出方向数据缓冲区丢弃报文告警参数。
undo port ifmonitor output-buffer-drop命令用来恢复缺省情况。
port ifmonitor output-buffer-drop high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的出方向数据缓冲区丢弃报文告警参数与全局采用的出方向数据缓冲区丢弃报文告警参数一致。
以太网接口视图
interval interval:指定出方向数据缓冲区丢弃报文的数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口Ten-GigabitEthernet3/0/1上配置出方向数据缓冲区丢弃报文告警上限阈值为5000,出方向数据缓冲区丢弃报文告警下限阈值为400,出方向数据缓冲区丢弃报文的数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor output-buffer-drop high-threshold 5000 low-threshold 400 interval 6
1.1.54  port ifmonitor output-error
port ifmonitor output-error命令用来配置出方向错误报文告警参数。
undo port ifmonitor output-error命令用来恢复缺省情况。
接口采用的出方向错误报文告警参数与全局采用的出方向错误报文告警参数一致。
以太网接口视图
# 在接口Ten-GigabitEthernet3/0/1上配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
1.1.55  port ifmonitor output-usage
port ifmonitor output-usage命令用来配置出方向带宽利用率的告警参数。
undo port ifmonitor output-usage命令用来恢复缺省情况。
接口采用的出方向带宽利用率告警参数与全局采用的出方向带宽利用率告警参数一致。
high-threshold high-value:指定接口出方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
high-threshold high-value:指定接口出方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
# 在接口Ten-GigabitEthernet3/0/1上配置出方向带宽利用率告警上限阈值为9,出方向带宽利用率告警下限阈值为7。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1]port ifmonitor output-usage high-threshold 9 low-threshold 7
·     flow-interval
1.1.56  port ifmonitor rx-pause
port ifmonitor rx-pause命令用来配置接口接收PAUSE帧告警参数。
undo port ifmonitor rx-pause命令用来恢复缺省情况。
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的接收PAUSE帧告警参数与全局采用的接收PAUSE帧告警参数一致。
以太网接口视图
high-threshold high-value:指定接口接收PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口接收PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口Ten-GigabitEthernet3/0/1上配置接收PAUSE帧告警上限阈值为90,接收PAUSE帧告警下限阈值为50,接收PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
1.1.57  port ifmonitor tx-pause
port ifmonitor tx-pause命令用来配置接口发送PAUSE帧告警参数。
undo port ifmonitor tx-pause命令用来恢复缺省情况。
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的发送PAUSE帧告警参数与全局采用的发送PAUSE帧告警参数一致。
以太网接口视图
high-threshold high-value:指定接口发送PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口发送PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口Ten-GigabitEthernet3/0/1上配置发送PAUSE帧告警上限阈值为50,发送PAUSE帧告警下限阈值为40,发送PAUSE帧数据收集和比较时间间隔为8秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
1.1.58  port link-flap protect enable
port link-flap protect enable命令用来开启接口链路震荡保护功能。
undo port link-flap protect enable命令用来关闭接口链路震荡保护功能。
port link-flap protect enable [ down-auto-recovery ] [ interval interval | threshold threshold ] * [ second-interval second-interval second-threshold second-threshold ]
undo port link-flap protect enable [ interval | threshold ]
接口的链路震荡功能处于关闭状态。
以太网接口视图
interval interval:一级链路震荡检查时间间隔,取值范围5~86400,单位为秒,缺省值为10秒。
threshold threshold:一级链路震荡次数阈值,取值范围2~1200,缺省值为5次。
second-interval second-interval:二级链路震荡检查时间间隔,取值范围5~86400,单位为秒。
second-threshold second-threshold:二级链路震荡次数阈值,取值范围2~1200。
工作机制
接口下配置本命令后,当接口状态从UP变为DOWN时,系统会启动链路震荡检查。在链路震荡检查时间间隔内,如果该接口状态从UP变为DOWN的次数大于等于链路震荡次数阈值,则关闭该接口。如果同时指定了一级和二级震链路震荡检查参数,则进行链路震荡检查时,只要满足其中之一就会触发链路震荡保护功能,将接口关闭。
本功能支持两种模式:
·     未指定down-auto-recovery参数:表示接口因链路频繁震荡被关闭后,不会自动恢复,需要用户执行undo shutdown命令手工恢复。
·     指定down-auto-recovery参数:表示接口因链路频繁震荡被关闭后,在到达shutdown-interval link-flap命令配置的接口状态检测定时器超时时间之后,接口将恢复到真实的物理状态。
注意事项
只有系统视图下和指定接口视图下同时配置链路震荡保护功能后,指定接口的链路震荡保护功能才能生效。
执行port link-flap protect enable命令时,如果未指定intervalthreshold,表示采用intervalthreshold的缺省值。如果未指定second-interval second-threshold,则仅根据一级链路震荡检查时间间隔和一级链路震荡次数阈值对接口进行震荡检查。
执行undo port link-flap protect enable命令时,如果指定intervalthreshold,表示恢复intervalthreshold的缺省值。
以太网接口上不能同时配置本命令、dampening命令和link-delay命令。
# 开启接口的链路震荡保护功能,链路震荡检查时间间隔为10秒,链路震荡次数阈值为5次。
[Sysname-Ten-GigabitEthernet3/0/1] port link-flap protect enable interval 10 threshold 5
·     dampening
·     link-delay
·     shutdown-interval link-flap
1.1.59  port link-mode
port link-mode命令用来切换以太网接口的工作模式。
undo port link-mode命令用来恢复缺省情况。
undo port link-mode
以太网接口工作在二层模式。
以太网接口视图
bridge:工作在二层模式。
route:工作在三层模式。
接口模式切换后,除了descriptionduplexjumboframe enablespeedshutdownport fec modetransceiver fec mode命令,该以太网接口下的其它所有命令都将恢复到新模式下的缺省情况。
本系列交换机上的接口比较灵活,工作模式可以通过命令行设置。如果将工作模式设置为二层模式(bridge),则作为一个二层以太网接口使用,如果将工作模式设置为三层模式(route),则作为一个三层以太网接口使用。
# 使接口Ten-GigabitEthernet3/0/1工作在二层模式。
[Sysname-Ten-GigabitEthernet3/0/1] port link-mode bridge
The configuration of the interface will be restored to the default. Continue? [Y/N]:y
1.1.60  port transceiver-power-low trigger
port transceiver-power-low trigger命令用来开启端口光功率异常检测功能。
undo port transceiver-power-low trigger命令用来关闭端口光功率异常检测功能。
port transceiver-power-low trigger { down-auto-recovery | error-down }
端口光功率异常检测功能处于关闭状态。
以太网接口视图
down-auto-recovery:表示设备检查到光功率异常时,端口将被关闭。端口在到达shutdown-interval transceiver-power-low命令配置的端口状态检测恢复时间之后,将自动恢复到真实的物理状态。
error-down:表示设备检查到光功率异常时,端口将被关闭,该端口不再转发流量。当光功率恢复正常后,用户需要手工执行undo shutdown命令恢复端口状态。
当设备光功率异常时,会导致业务时断时续等故障。为了不影响业务的正常运行,管理员可以开启本功能,在光模块的光功率异常时将接口关闭,该接口不再收发报文,以便及时切换到其他接口处理业务流量。
配置本命令前,请先执行transceiver monitor enable命令开启光模块监控功能,否则端口光功率异常检测功能将无法生效。有关transceiver monitor enable命令的详细介绍,请参见“基础配置”中的“设备管理”。
端口光功率异常检测功能检测到接口光功率异常并关闭接口后,支持两种恢复接口的方式:
·     自动恢复方式:配置本功能,并选择down-auto-recovery参数时,当光模块的光功率异常时,设备将接口关闭;在到达shutdown-interval transceiver-power-low命令配置的端口状态恢复时间之后,端口将自动恢复到真实的物理状态。
·     手动恢复方式:配置本功能,并选择error-down参数时,当光模块的光功率异常时,设备将接口关闭;当光功率正常后,用户需要在接口下执行手工执行undo shutdown命令对接口进行恢复。
# 开启接口Ten-GigabitEthernet3/0/1的光功率异常检测功能,并选择接口恢复方式为手动方式。
[Sysname-Ten-GigabitEthernet3/0/1] port transceiver-power-low trigger error-down
·     shutdown-interval transceiver-power-low
1.1.61  port up-mode
port up-mode命令用来强制开启光口。
undo port up-mode命令用来恢复缺省情况。
port up-mode
undo port up-mode
没有强制开启光口,光口的物理状态由光纤的物理状态决定。
以太网接口视图
强制开启光口后,不管实际的光纤链路是否连通,甚至没有插入光纤或光模块,光口的物理状态都会变为up。此时,只要光口上有一条光纤链路是连通的,就可以实现报文的单向转发,以达到节约传输链路的效果。
仅GE、10GE、25GE、40GE光口支持强制开启功能,电口不支持该功能。
port up-modeshutdownloopback命令互斥,后配置的失败。
如果接口被关闭(包括手工关闭和被协议关闭),则不能配置本命令。
光口被强制开启后,GE光口插入光电转换模块、100/1000M光模块、100M光模块后,流量不能正常转发。必须取消强制开启光口配置,才能正常转发。
# 强制开启光口Ten-GigabitEthernet3/0/1。
[Sysname-Ten-GigabitEthernet3/0/1] port up-mode
1.1.62  lbn-group
lbn-group命令用来创建LBN组,并进入LBN组视图。
undo lbn-group命令用来删除LBN组。
lbn-group group-name
undo lbn-group group-name
不存在LBN组。
group-name:LBN组的名称,为1~31个字符串,区分大小写。
属于LBN组里的接口才能负载分担,不属于LBN组不能负载分担。LBN负载分担功能是指,通过将设备的不同入接口加入LBN组中,并为这些接口分配索引。设备会根据接口配置的索引值,通过一定的算法,将流量分配到各个接口。从不同入接口进入的流量,会通过不同的出接口转发出去,从而实现流量的负载分担。
本命令用于创建LBN组,在LBN组中可以配置成员接口及索引。
# 创建LBN组test,并进入LBN组视图。
[Sysname] lbn-group test
[Sysname-lbn-group-test]
1.1.63  reset counters interface
reset counters interface命令用来清除接口的统计信息。
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number:指定接口编号。
interface-number.subnumber:指定子接口。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
如果不指定interface-typeinterface-number,则清除所有接口的统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的统计信息。
# 清除以太网接口Ten-GigabitEthernet3/0/1的统计信息。
<Sysname> reset counters interface ten-gigabitethernet 3/0/1
·     display interface
·     display counters interface
·     display counters rate interface
1.1.64  reset counters mib interface
reset counters mib interface命令用来清除MIB上接口的统计信息。
reset counters mib interface [ interface-type [ interface-number | interface-number.subnumber ]]
本命令用来清除fTable和ifXTable表中报文统计相关的MIB节点信息。ifTable和ifXTable表是IF-MIB文件中定义的两个表节点,该表节点下包含了多个叶子节点,用于获取接口的报文统计信息。
在某些情况下,需要在MIB中统计一定时间内某接口的流量,这就需要在统计开始前清除该接口原有的MIB统计信息,重新进行统计。
如果不指定interface-typeinterface-number,则清除除VA接口外所有接口的mib统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的mib统计信息。
# 清除MIB上以太网接口Ten-GigabitEthernet3/0/1的统计信息。
<Sysname> reset counters mib interface ten-gigabitethernet 3/0/1
1.1.65  reset counters slot
reset counters slot命令用来清除单板及单板上接口的统计信息。
(独立运行模式)‌
reset counters slot [ slot-number ]
reset counters chassis [ chassis-number [ slot slot-number ] ]
# 清除slot 1及slot 1上接口的统计信息。
<Sysname> reset counter slot 1
1.1.66  reset ethernet statistics
reset ethernet statistics命令用来清除以太网软件模块收发报文的统计信息。
(独立运行模式)‌
reset ethernet statistics [ slot slot-number ]
reset ethernet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的统计信息,slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)‌
# 清除指定slot上的以太网软件模块收发报文的统计信息。(独立运行模式)‌
<Sysname> reset ethernet statistics slot 1
·     display ethernet statistics
1.1.67  reset link-state-change statistics interface
reset link-state-change statistics interface命令用来清除接口的状态变化统计信息。
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
未清除接口状态变化统计信息。
接口的状态变化统计信息可以通过display link-state-change statistics interface命令查看,使用本命令,可以将接口的状态变化次数统计值清零。
# 清除以太网接口Ten-GigabitEthernet3/0/1的状态变化统计信息。
<Sysname> reset link-state-change statistics interface ten-gigabitethernet 3/0/1
·     display link-state-change statistics interface
1.1.68  shutdown
shutdown命令用来关闭以太网接口/子接口。
undo shutdown命令用来打开以太网接口/子接口。
shutdown
以太网接口/子接口均处于开启状态。
以太网接口视图
以太网子接口视图
执行shutdown命令会导致使用该接口建立的链路中断,不能通信,请谨慎使用。
在某些特殊情况下(例如修改接口的工作参数),接口相关配置不能立即生效,需要关闭再打开接口后,才能生效。
# 关闭以太网接口Ten-GigabitEthernet3/0/1后打开该接口。
[Sysname-Ten-GigabitEthernet3/0/1] shutdown
[Sysname-Ten-GigabitEthernet3/0/1] undo shutdown
1.1.69  shutdown all-physical-interfaces
shutdown all-physical-interfaces命令用来关闭除管理以太网接口外的所有物理接口。
undo shutdown all-physical-interfaces命令用来开启除管理以太网接口外的所有物理接口。
shutdown all-physical-interfaces [ include irf-physical-interface ]
物理接口处于开启状态。
include irf-physical-interface:关闭全部物理接口时包括IRF物理接口。如果未指定本参数,则关闭全部物理接口时不包括IRF物理接口。关闭IRF物理接口会导致IRF分裂,请谨慎使用。
通过配置本命令,可以关闭设备上除管理以太网接口外的所有物理接口,接口状态变为ADM。
在系统视图下执行shutdown all-physical-interfaces命令或在接口视图下执行shutdown命令,接口均会被关闭。
shutdown all-physical-interfaces命令关闭的接口需要执行undo shutdown all-physical-interfaces命令来开启这些接口,被接口视图下shutdown命令关闭的接口需要在在接口视图下执行undo shutdown命令来开启这个接口。
多次执行本命令,只要携带include irf-physical-interface参数,则关闭设备上除管理以太网接口外的所有物理接口。
# 关闭除管理以太网接口和IRF物理接口外的所有物理接口。
[Sysname] shutdown all-physical-interfaces
Executing this command will shut down all physical ports on the device except for the management Ethernet interface and IRF physical interface. The interface status will change to ADM. Continue? [Y/N]:y
# 关闭除管理以太网接口外的所有物理接口。
[Sysname] shutdown all-physical-interfaces include irf-physical-interface
Execute this command to shut down all physical ports on the device except for the management Ethernet interface, the interface status will change to ADM. Continue? [Y/N]:y
# 开启除管理以太网接口外的所有物理接口。
[Sysname] undo shutdown all-physical-interfaces
Execute this command will enable the interfaces that were shut down by the shutdown all-physical-interfaces command. Continue? [Y/N]:y
·     shutdown
1.1.70  shutdown-interval crc-error
shutdown-interval crc-error命令用来配置接口被CRC错误报文告警功能关闭后,端口状态自动恢复的时长。
undo shutdown-interval crc-error命令用来恢复缺省情况。
shutdown-interval [ crc-error ] interval
undo shutdown-interval [ crc-error ]
端口状态自动恢复的时长为30秒。
crc-error:表示由于接口收到的CRC错误报文超出上限告警阈值导致接口被关闭。如果未配置本参数,则表示本命令配置的端口状态自动恢复的时长对所有支持shutdown-interval命令的功能均生效,例如CRC错误报文告警功能。
interval:端口状态自动恢复的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动恢复端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
工作机制
某些功能在特定情况下会自动关闭某个端口,比如CRC错误报文告警功能导致端口被关闭。在自动关闭端口的同时,系统会启动一个自动恢复端口状态的定时器。当定时器超时(即经过time秒之后)后,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
注意事项
ifmonitor crc-error命令需要配置down-auto-recovery参数,本命令才生效。
# 配置接口被CRC错误报文告警功能关闭后,端口状态自动恢复的时长为100秒。
[Sysname] shutdown-interval crc-error 100
·     ifmonitor crc-error
1.1.71  shutdown-interval link-flap
shutdown-interval link-flap命令用来配置接口链路震荡保护功能导致端口被关闭,端口状态自动恢复的时长。
undo shutdown-interval link-flap命令用来恢复缺省情况。
shutdown-interval [ link-flap ] interval
undo shutdown-interval [ link-flap ]
端口状态自动恢复的时长为30秒。
link-flap:表示由于触发了接口链路震荡保护功能导致接口被关闭。如果未配置本参数,则表示本命令配置的端口状态自动恢复的时长对所有支持shutdown-interval命令的功能均生效,例如CRC错误报文告警功能。
工作机制
某些功能在特定情况下会自动关闭某个端口,比如接口链路震荡保护功能导致端口被关闭。在自动关闭端口的同时,系统会启动一个自动恢复端口状态的定时器。当定时器超时(即经过time秒之后)后,系统自动将端口恢复到真实的物理状态。
注意事项
port link-flap protect enable命令需要配置down-auto-recovery参数,本命令才生效。
# 配置接口链路震荡保护功能导致端口被关闭,端口状态自动恢复的时长为100秒。
[Sysname] shutdown-interval link-flap 100
·     port link-flap protect enable
1.1.72  shutdown-interval transceiver-power-low
shutdown-interval transceiver-power-low命令用来配置端口光功率异常检测功能导致端口被关闭,端口状态自动恢复的时长。
undo shutdown-interval transceiver-power-low命令用来恢复缺省情况。
shutdown-interval [ transceiver-power-low ] interval
undo shutdown-interval [ transceiver-power-low ]
端口状态自动恢复的时长为30秒。
transceiver-power-low:表示由于端口光功率异常检测功能导致接口被关闭。如果未配置本参数,则表示本命令配置的端口状态自动恢复的时长对所有支持shutdown-interval命令的功能均生效,例如CRC错误报文告警功能。
工作机制
某些功能在特定情况下会自动关闭某个端口,比如端口光功率异常检测功能导致端口被关闭。在自动关闭端口的同时,系统会启动一个自动恢复端口状态的定时器。当定时器超时(即经过time秒之后)后,系统自动将端口恢复到真实的物理状态。
注意事项
port transceiver-power-low trigger命令需要配置down-auto-recovery参数,本命令才生效。
# 配置端口光功率异常检测功能导致端口被关闭,端口状态自动恢复的时长为100秒。
[Sysname] shutdown-interval transceiver-power-low 100
·     port transceiver-power-low trigger
1.1.73  slot-monitor packet-drop
slot-monitor packet-drop命令用来配置单板丢失报文的告警参数。
undo slot-monitor packet-drop命令用来恢复缺省情况。
(独立运行模式)‌
slot-monitor packet-drop [ slot slot-number ] high-threshold high-threshold-value low-threshold low-threshold-value interval interval [ shutdown | reboot ]
undo slot-monitor packet-drop slot slot-number
slot-monitor packet-drop [ chassis chassis-number slot slot-number ] high-threshold high-threshold-value low-threshold low-threshold-value interval interval [ shutdown | reboot ]
undo slot-monitor packet-drop chassis chassis-number slot slot-number
单板丢失报文的告警上限阈值为1000000,下限阈值为100,数据收集和比较时间间隔为30秒。
high-threshold high-threshold-value:指定单板丢失报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-threshold-value:指定单板丢失报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定单板丢失报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当单板接收到因丢失报文超出上限告警阈值时,关闭单板下所有接口,该单板将停止转发所有报文。因单板告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当单板接收到因丢失报文超出上限告警阈值,单板将产生超上限告警,并进入告警状态。
reboot:表示当单板接收到因丢失报文超出上限告警阈值时,重启单板。未指定本参数时,表示当单板因接收到因丢失报文超出上限告警阈值,单板将产生超上限告警,并进入告警状态。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示所有单板。(IRF模式)‌
开启单板丢失报文告警功能后,当单板处于正常状态,并在指定的时间内接收的丢失报文超出告警上限阈值时,单板将产生超上限告警,并进入告警状态。当单板处于告警状态,且在指定时间间隔内接收的单板丢失报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
如果未指定slot,则本命令对所有slot生效;如果指定了slot,则本命令只对指定的slot生效。如果某个slot同时配置了slot-monitor packet-dropslot-monitor packet-drop slot命令,则该slotslot-monitor packet-drop slot命令的配置为准。
# 配置单板丢失报文告警上限阈值为5000,单板丢失报文告警下限阈值为1000,单板丢失报文数据收集和比较时间间隔为60秒。
[Sysname] slot-monitor packet-drop slot 1 high-threshold 5000 low-threshold 1000 interval 60 shutdown
·     snmp-agent trap enable slot-monitor
1.1.74  snmp-agent trap enable eth
snmp-agent trap enable eth命令用来开启ETH模块的告警功能。
undo snmp-agent trap enable eth命令用来关闭ETH模块的告警功能。
ETH模块的告警功能处于关闭状态。
开启ETH模块的告警功能后,ETH模块会生成告警信息报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启ETH模块的告警功能。
[Sysname] snmp-agent trap enable eth
1.1.75  snmp-agent trap enable ifmonitor
snmp-agent trap enable ifmonitor命令用来开启接口告警功能。
undo snmp-agent trap enable ifmonitor命令用来关闭接口告警功能。
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause | buffer-usage ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause | buffer-usage ] *
接口的所有告警功能处于开启状态。
crc-error:开启接口接收CRC错误报文告警功能。开启CRC错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的CRC错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的CRC错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
giant:开启接口超大帧告警功能。
input-buffer-drop:开启接口入方向数据缓冲区丢弃报文告警功能。
input-error:开启接口接收错误报文告警功能。开启接口接收错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
input-usage:开启接口入方向带宽利用率告警功能。开启接口入方向带宽利用率告警功能后,当接口处于正常状态,并在最近一个统计周期内入方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内入方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
output-buffer-drop:开启接口出方向数据缓冲区丢弃报文告警功能。
output-error:开启接口发送错误报文告警功能。开启接口发送错误报文告警功能后,当接口处于正常状态,并在指定的时间内发送的错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内发送的错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
output-usage:开启接口出方向带宽利用率告警功能。开启接口出方向带宽利用率告警功能后,当接口处于正常状态,并在最近一个统计周期内出方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内出方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
runt:开启接口超小帧告警功能。
rx-pause:开启接口接收PAUSE帧告警功能。开启接口接收PAUSE帧告警功能后,当接口处于正常状态,并在指定的时间内接收PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
tx-pause:开启接口发送PAUSE帧告警功能。开启接口发送PAUSE帧告警功能后,当接口处于正常状态,并在指定的时间内发送PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内发送PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
buffer-usage:开启接口发送拥塞流量告警功能。开启接口发送拥塞流量告警功能后,当接口处于正常状态,并且接口缓存使用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且接口缓存使用率降低至下限阈值时,接口将产生恢复告警,并恢复到正常状态。仅SF系列接口板和SG系列接口板支持本参数。
工作机制
开启接口告警功能后,当接口接收/发送的误码(CRC错误报文、错误报文、PAUSE帧、SDH-B1错误报文、SDH-B2错误报文和SDH错误报文)或带宽使用率达到告警上限阈值或低于下限阈值时会产生告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
配置准备
有关告警阈值的详细介绍,请参见相关命令中的各个命令。
注意事项
执行本命令时,如果未指定任何参数,则表示开启或关闭接口的所有告警功能;如果指定了某参数,则表示仅开启该参数对应的告警功能。
# 开启接口CRC错误报文告警功能。
[Sysname] snmp-agent trap enable ifmonitor crc-error
·     ifmonitor input-error
·     ifmonitor input-usage
·     ifmonitor output-error
·     ifmonitor output-usage
·     ifmonitor rx-pause
·     ifmonitor sdh-b1-error
·     ifmonitor sdh-b2-error
·     ifmonitor sdh-error
·     ifmonitor tx-pause
·     port ifmonitor crc-error
·     port ifmonitor input-error
·     port ifmonitor input-usage
·     port ifmonitor output-error
·     port ifmonitor output-usage
·     port ifmonitor rx-pause
·     port ifmonitor sdh-b1-error
·     port ifmonitor sdh-b2-error
·     port ifmonitor sdh-error
·     port ifmonitor tx-pause
1.1.76  snmp-agent trap enable slot-monitor
snmp-agent trap enable slot-monitor命令用来开启单板告警功能。
undo snmp-agent trap enable slot-monitor命令用来关闭单板告警功能。
snmp-agent trap enable slot-monitor [ packet-drop ]
undo snmp-agent trap enable slot-monitor [ packet-drop ]
单板告警功能处于开启状态。
packet-drop:开启单板丢失报文告警功能。
# 开启单板丢失报文告警功能。
[Sysname] snmp-agent trap enable slot-monitor packet-drop
1.1.77  speed
speed命令用来设置以太网接口的速率。
undo speed命令用来恢复缺省情况。
speed { 10 | 100 | 1000 | 2500 | 5000 | 10000 | 25000 | 40000 | 100000 | 200000 | 400000 | auto }
undo speed
管理用以太网光接口的速率为1000,其他以太网接口的速率为 auto(自协商)状态。
以太网接口视图
10:表示接口速率为10Mbps。
100:表示接口速率为100Mbps。
1000:表示接口速率为1000Mbps。
2500:表示接口速率为2500Mbps。
5000:表示接口速率为5000Mbps。
10000:表示接口速率为10000Mbps。
25000:表示接口速率为25000Mbps。
40000:表示接口速率为40000Mbps。
100000:表示接口速率为100000Mbps。
200000:表示接口速率为200000Mbps。
400000:表示接口速率为400000Mbps。
auto:表示接口速率处于自协商状态。
对于以太网电口来说,使用speed命令设置端口速率,目的是使其与对端进行速率匹配。不同类型的电口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前电口支持该速率。否则,当前电口不支持该速率。
对于光口来说,使用speed命令设置端口速率,目的是使其与可插拔光模块进行速率匹配。不同类型的光口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前光口支持该速率。否则,当前光口不支持该速率。同时需要根据所选用光模块类型,在光口下配置匹配的速率,以便正常使用光模块。如果光口所配置的速率光模块无法支持,则光模块无法使用。例如SFP+口插入SFP千兆光模块时配置speed 10000,或SFP+口插入万兆光模块时配置speed 1000,光模块都无法使用。
仅SE系列接口板和SF系列接口板上的端口支持配置speed 2500
以下接口不支持通过speed命令修改端口速率:
·     100GE和40GE拆分出来的10GE接口。
·     100GE拆分出来的25GE接口。
# 将以太网接口Ten-GigabitEthernet3/0/1的速率设置为自协商获得。
[Sysname-Ten-GigabitEthernet3/0/1] speed auto
·     speed auto
1.1.78  traffic-statistic include-interframe
traffic-statistic include-interframe命令用来配置接口流量统计时对帧间隙和前导码进行统计。
undo traffic-statistic include-interframe命令用来恢复缺省情况。
未配置接口流量统计时对帧间隙和前导码进行统计。
以太网接口视图
用户可执行命令display interface查看以太网接口当前运行状态和接口统计信息。显示信息中的Last 300 seconds input rate或Last 300 seconds output rate字段表示接口在最近300秒内接收和发送报文的平均速率。
缺省情况下,接口流量统计速率=原始报文长度×每秒通过的报文个数。如果用户希望了解接口单位时间内通过的总字节数,即包含报文字节数以及帧间隙和前导码时,可以配置本命令,将包括帧间隙和前导码的流量统计。此时,接口流量统计速率=(原始报文长度+帧间隙+前导码)× 每秒通过的报文个数。
当在聚合接口下配置本命令时,本命令对加入聚合接口的全部以太网接口生效;当以太网接口加入到聚合接口时,以聚合接口下的该命令的配置为准,但当以太网接口退出聚合口时,恢复加入聚合接口之前的配置。
当在以太网接口和聚合接口下配置本命令时,首次下发,系统会清除接口的统计信息,而重复配置本命令不会清除统计信息。当接口加入或退出聚合组时不需要配置本命令,系统会自动清除接口的统计信息。
# 配置对以太网接口Ten-GigabitEthernet3/0/1进行流量统计时对帧间隙和前导码进行统计。
[Sysname-Ten-GigabitEthernet3/0/1] traffic-statistic include-interframe
Set traffic statistic to include Inter-frame Gaps and Preambles, and clear the statistics count. Continue? [Y/N]:y
# 当以太网接口加入聚合组后配置以太网接口Ten-GigabitEthernet3/0/1流量统计时对帧间隙和前导码进行统计。
This configuration takes effect on the port only when the port joins or leaves the aggregation group.
·     display interface
1.1.79  unicast-suppression
unicast-suppression命令用来开启端口未知单播风暴抑制功能,并设置未知单播风暴抑制阈值。
undo unicast-suppression命令用来关闭端口未知单播风暴抑制功能。
所有接口不对未知单播流量进行抑制。
以太网接口视图
ratio:指定以太网接口最大未知单播流量占该接口带宽的百分比。取值范围为0~100。数值越小,则允许通过的未知单播流量也越小。
pps max-pps:指定以太网接口每秒最多通过的未知单播包包数,取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒通过的未知单播流量,单位为kbps,取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大未知单播报文流量。当接口上的未知单播流量超过用户设置的值后,系统将丢弃超出未知单播流量限制的报文,从而使接口未知单播流量所占的比例降低到限定的范围,保证网络业务的正常运行。
执行unicast-suppressionstorm-constrain命令都能开启端口的未知单播风暴抑制功能,storm-constrain命令通过软件对未知单播报文进行抑制,对设备性能有一定影响,unicast-suppression通过芯片物理上对未知单播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置unicast-suppressionstorm-constrain命令,以免配置冲突,导致抑制效果不确定。
当风暴抑制阈值配置为ppskbps时,设备可能会根据芯片支持的步长,将配置值转换成步长的倍数。请注意查看设备的提示信息。
配置本命令后,端口上风暴抑制实际生效的阈值与display interface命令中显示的抑制阈值会有5%的误差。
# 在以太网接口Ten-GigabitEthernet3/0/1上,每秒最多允许10000kbps未知单播报文通过,对超出该范围的未知单播报文进行抑制。
[Sysname-Ten-GigabitEthernet3/0/1] unicast-suppression kbps 10000
The actual value is 9984 on port Ten-GigabitEthernet3/0/1 currently.
对于SF系列接口板和SG系列接口板,以上信息表示:用户配置的值为10000kbps,端口实际生效的值为9984kbps。用户可根据该提示信息,确认端口实际生效的抑制值。
·     multicast-suppression
1.1.80  using fortygige
using fortygige命令用来将从40GE接口拆分的10GE接口合并为一个40GE接口。
undo using fortygige命令用来取消对10GE接口的合并。
仅下列接口板支持本命令:
·     LSXM3CGQ36SF2
·     LSXM3CGQ18SF2
·     LSXM3QGS36SF2
using fortygige
40GE接口作为单个接口使用,未拆分。
10GE拆分接口视图
只有缺省MDC上支持该命令,非缺省MDC上不支持该命令。
如果用户需要更大的带宽,可以将已拆分的10GE接口合并为40GE接口使用。在任何一个10GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
执行本命令后,需要保存配置并重启业务板才能生效。
# 将Ten-GigabitEthernet1/0/1:1~Ten-GigabitEthernet1/0/1:4接口合并。
<System> system-view
[System] interface ten-gigabitethernet1/0/1:1
[System-Ten-GigabitEthernet1/0/1:1] using fortygige
The interfaces Ten-GigabitEthernet1/0/1:1 through Ten-GigabitEthernet1/0/1:4 will be deleted. Continue? [Y/N]:y
·     using tengige
1.1.81  using fourhundredgige
using fourhundredgige命令用来将从400GE接口拆分出来的接口合并为一个400GE接口。
undo using fourhundredgige命令用来取消对拆分接口的合并。
拆分接口单独使用,不会合并。
100GE拆分接口视图
200GE拆分接口视图
如果用户需要更大的带宽,可以将从400GE接口拆分出来的2个200GE接口合并为一个400GE使用。在任何一个200GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
# 将HundredGigE1/0/1:1~HundredGigE1/0/1:4接口合并。
[System] interface hundredgige 1/0/1:1
[System-HundredGigE 1/0/1:1] using fourhundredgige
The interfaces HundredGigE1/0/1:1 through HundredGigE1/0/1:4 will be deleted. Continue? [Y/N]:y
Save the current configuration and reboot device to make the configuration take effect.
# 将TwoHundredGigE1/0/1:1和TwoHundredGigE1/0/1:2接口合并。
[Sysname] interface twohundredgige 1/0/1:1
[Sysname-TwoHundredGigE1/0/1:1] using fourhundredgige
The interfaces TwoHundredGigE1/0/1:1 and TwoHundredGigE1/0/1:2 will be deleted. Continue? [Y/N]:y
Reboot the LPU to make the configuration take effect.
·     using hundredgige
·     using twohundredgige
1.1.82  using hundredgige
using hundredgige命令用来将从100GE接口拆分出来的接口合并为一个100GE接口。
undo using hundredgige命令用来取消对拆分接口的合并。
仅下列接口板支持本命令:
·     LSXM3CGQ36SF2
·     LSXM3CGQ18SF2
using hundredgige
拆分接口单独使用,不会合并。
25GE拆分接口视图
如果用户需要更大的带宽,可以进行如下操作:
将从100GE接口拆分出来的4个25GE接口合并为一个100GE使用。在任何一个25GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
命令配置成功后,需要保存配置并重启业务板才能生效。
# 将Twenty-FiveGigE1/0/1:1~Twenty-FiveGigE1/0/1:4接口合并。
[Sysname] interface twenty-fivegige 1/0/1:1
[Sysname-Twenty-FiveGigE1/0/1:1] using hundredgige
The interfaces Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4 will be deleted. Continue? [Y/N]:y
·     using twenty-fivegige
·     using fourhundredgige
1.1.83  using tengige
using tengige命令用来将一个高带宽的接口拆分成多个10GE接口。
undo using tengige命令用来取消对接口的拆分。
仅下列接口板支持本命令:
·     LSXM3CGQ36SF2
·     LSXM3CGQ18SF2
·     LSXM3QGS36SF2
using tengige
undo using tengige
高带宽的接口单独使用,不拆分。
100GE接口视图
40GE接口视图
为了提高端口密度,减少用户使用成本,增加组网灵活性,设备支持将一个高带宽的接口拆分成多个10GE接口使用。例如:
40GE接口FortyGigE1/0/1可以拆分成四个10GE接口Ten-GigabitEthernet1/0/1:1~Ten-GigabitEthernet1/0/1:4。
拆分出来的10GE接口,接口编号方式和普通10GE物理接口不同,并且不支持通过speed命令修改端口速率。
执行本命令后,需要重启业务板才能生效。
# 将40GE接口FortyGigE1/0/1拆分成四个10GE接口。
[System] interface fortygige 1/0/1
[System-FortyGigE1/0/1] using tengige
The interface FortyGigE1/0/1 will be deleted. Continue? [Y/N]:y
·     using fortygige
1.1.84  using twenty-fivegige
using twenty-fivegige命令用来将一个高带宽的接口拆分成多个25GE接口。
undo using twenty-fivegige命令用来取消对接口的拆分。
仅下列接口板支持本命令:
·     LSXM1CGQ36TE2
·     LSXM1CGQ18TE2
·     LSXM1CGQ18TD2
·     LSXM1CGQ8TD2
·     LSXM3CGQ36SF2
·     LSXM3CGQ18SF2
高带宽的接口单独使用,不拆分。
100GE以太网接口视图
为了提高端口密度,减少用户使用成本,增加组网灵活性,设备支持将一个100GE的接口拆分成4个25GE接口使用。例如:100GE接口HundredGigE1/0/1可以拆分成四个25GE接口Twenty-FiveGigE1/0/1:1~Twenty-FiveGigE1/0/1:4。
拆分出来的25GE接口,接口编号方式和普通25GE物理接口不同,并且不支持通过speed命令修改端口速率。
# 将HundredGigE1/0/1接口拆分成4个25GE接口。
[Sysname-HundredGigE1/0/1] using twenty-fivegige
The interface HundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
·     using hundredgige
1.1.85  using twohundredgige
using twohundredgige命令用来将一个400GE接口拆分成两个200GE接口。
undo using twohundredgige命令用来取消对400GE接口的拆分。
400GE接口单独使用,不拆分。
100GE拆分接口视图
400GE接口视图
如果用户需要更大的带宽,可以将从200GE接口拆分出来的多个10GE/25GE/100GE接口合并为一个200GE接口使用。在任何一个10GE/25GE/100GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
为了提高端口密度,减少用户使用成本,增加组网灵活性,设备支持将一个400GE的接口拆分成两个200GE接口使用。例如,400GE接口FourHundredGigE1/0/1可以拆分成两个200GE接口TwoHundredGigE1/0/1:1和TwoHundredGigE1/0/1:2。
# 将FourHundredGigE1/0/1接口拆分成两个200GE接口。
[System] interface fourhundredgige 1/0/1
[System-FourHundredGigE1/0/1] using twohundredgige
The interface FourHundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
·     using tengige
1.2  二层以太网接口的配置命令
1.2.1  display storm-constrain
display storm-constrain命令用来显示接口流量控制信息。
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast:只显示广播报文流量控制信息。
multicast:只显示组播报文流量控制信息。
unicast:只显示未知单播报文流量控制信息。
interface interface-type interface-number显示指定接口的报文流量控制信息。interface-type interface-number指定接口类型和接口编号。不指定该参数时,显示所有接口报文的流量控制信息。
不指定broadcastmulticastunicast参数时,则显示所有类型报文的流量控制信息。
# 显示系统当前所有接口的流量控制信息。
<Sysname> display storm-constrain
 Abbreviation: BC - broadcast; MC - multicast; UC - unknown unicast;
               KNUC - known unicast; FW - forwarding
 Flow Statistic Interval: 5 (in seconds)
Port          Type Lower     Upper     Unit  Mode     Status   Trap Log StateChg
XGE3/0/1      MC 100       200       kbps  shutdown shutdown off  on  10
表1-14 display storm-constrain命令显示信息描述表
流量统计的时间间隔,单位为秒
Port
接口名称缩写
进行流量阈值控制的报文类型:
·     BC:broadcast,表示广播报文
·     MC:multicast,表示组播报文
·     UC:unknown unicast,表示未知单播报文
·     KUNC:known unicast,表示已知单播报文(暂不支持)
Lower
用户配置的流量控制下限阈值或百分比
Upper
用户配置的流量控制上限阈值或百分比
Unit
用户配置的流量阈值的单位,为pps、kbps或百分比
Mode
用户配置的流量阈值超过上限的控制动作:
·     block表示阻塞方式
·     shutdown表示关闭方式
·     N/A表示未配置控制动作
Status
接口报文转发状态,取值为:
·     FW表示该端口处于正常转发状态
·     shutdown表示端口已被关闭
·     block表示该端口对该类报文直接丢弃
Trap
Trap信息输出开关:
·     on表示打开
·     off表示关闭
Log
Log信息输出开关:
·     on表示打开
·     off表示关闭
StateChg
接口报文转发状态切换次数
当StateChg达到65535次时,会自动跳转到0,重新计数
1.2.2  mdix-mode
光口不支持本命令。
mdix-mode命令用来设置以太网接口的MDIX模式。
undo mdix-mode命令用来恢复缺省情况。
mdix-mode { automdix | mdi| mdix }
undo mdix-mode
以太网接口的MDIX模式为automdix
二层以太网接口视图
automdix:两端设备通过协商来决定引脚1和2是发送还是接收信号,引脚3和6是接收还是发送信号。
mdi:使用引脚1和2发送信号,使用引脚3和6接收信号。
mdix:使用引脚1和2接收信号,使用引脚3和6发送信号。
# 设置以太网接口Ten-GigabitEthernet3/0/1的MDIX模式为automdix
[Sysname-Ten-GigabitEthernet3/0/1] mdix-mode automdix
1.2.3  port bridge enable
port bridge enable命令用来开启接口桥功能。
undo port bridge enable命令用来关闭接口桥功能。
port bridge enable
接口桥功能处于关闭状态。
二层以太接口视图
缺省情况下,设备收到报文后会根据报文特征查找报文出接口,如果该报文出接口和入接口为同一接口,则将报文丢弃。在二层以太网接口上开启本功能后,如果该报文出接口和入接口为同一接口,则从该接口转发报文。
当设备收到未知单播或者广播报文时,会在该报文入接口所属VLAN内的所有接口转发该报文。
开启了本功能的二层以太网接口不建议加入聚合组,避免影响本功能使用。
# 在二层以太网接口Ten-GigabitEthernet3/0/1上开启接口桥功能。
[Sysname-Ten-GigabitEthernet3/0/1] port bridge enable
1.2.4  speed auto
speed auto命令用来设置以太网接口的自协商速率范围。
speed auto { 10 | 100 | 1000 } *
undo speed
未配置接口自协商速率。
百兆或者千兆二层以太网接口视图
10:设置接口自协商速率为10Mbps。
100:设置接口自协商速率为100Mbps。
1000:设置接口自协商速率为1000Mbps。
多次执行speedspeed auto命令,最后一次执行的命令生效。例如:
·     若在接口下先配置了speed auto 100 1000,然后又配置speed 100,则接口的速率强制为100Mbps,不进行协商。
·     若在接口下先配置了speed 100,然后又配置speed auto 100 1000,则接口将与对端协商速率,协商的结果只能为100Mbps或1000Mbps。
速率协商方法为:
·     如果两端设置的接口自协商速率的范围完全不同,例如:一端为speed auto 10 100,另一端为speed auto 1000,此时两端速率协商不成功;
·     如果两端设置的接口自协商速率的范围部分相同,例如:一端为speed auto 10 100,另一端为speed auto 100 1000,此时两端速率协商为双方都有的100 Mbps;
·     如果两端设置的接口自协商速率的范围完全相同,例如:一端为speed auto 100 1000,另一端为speed auto 100 1000,此时两端取速率协商范围内最大速率1000 Mbps。
# 设置接口Ten-GigabitEthernet3/0/1的自协商速率为10Mbps或1000Mbps。
[Sysname-Ten-GigabitEthernet3/0/1] speed auto 10 1000
·     speed
1.2.5  storm-constrain
storm-constrain命令用来开启端口流量阈值控制功能,并设置上限阈值与下限阈值。
undo storm-constrain命令用来关闭端口流量阈值控制功能。
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
端口流量阈值控制功能处于关闭状态,即不对端口的报文流量进行抑制。
二层以太网接口视图
all:取消端口所有类型(未知单播、组播和广播)报文流量阈值配置。
broadcast:设置端口广播报文流量阈值。
multicast:设置端口组播报文流量阈值。
unicast:设置端口未知单播报文流量阈值。
pps:以包每秒为单位统计流量。
kbps:以千比特每秒为单位统计流量。
ratio:以每秒钟报文所占接口物理带宽的百分比来统计流量。
upperlimit:端口报文流量的上限阈值。当和pps一起使用时,该参数的取值范围为1~1.4881×接口带宽;当和kbps一起使用时,该参数的取值范围为1~接口带宽;当和ratio一起使用时,该参数的取值范围为为1~100。
lowerlimit:端口报文流量的下限阈值。当和pps一起使用时,该参数的取值范围为1~1.4881×接口带宽;当和kbps一起使用时,该参数的取值范围为1~接口带宽;当和ratio一起使用时,该参数的取值范围为为1~100。
执行本命令后,设备就会周期性地对接口收到的指定类型的报文进行统计,如果流量超过上限阈值,则采取一定的措施。其中,通过storm-constrain interval命令可以配置统计周期,通过storm-constrain control命令可以配置流量超过上限阈值时采取的控制方式。
执行storm-constrainbroadcast-suppressionmulticast-suppressionunicast-suppression命令都能开启端口的风暴抑制功能。storm-constrain命令通过软件对报文流量进行抑制,对设备性能有一定影响,broadcast-suppressionmulticast-suppressionunicast-suppression通过芯片物理上对报文流量进行抑制,相对storm-constrain来说,对设备性能影响较小。对于某种类型的报文流量,请不要同时配置这两种方式,以免配置冲突,导致抑制效果不确定。
配置时,upperlimit值必须大于lowerlimit值,建议不要配成相等值。
# 对Ten-GigabitEthernet3/0/1端口配置未知单播流量阈值,上限阈值为200pps、下限阈值为150pps。
[Sysname-Ten-GigabitEthernet3/0/1] storm-constrain unicast pps 200 150
# 对Ten-GigabitEthernet3/0/2端口配置广播流量阈值,上限阈值为2000kbps、下限阈值为1500kbps。
[Sysname] interface ten-gigabitethernet 3/0/2
[Sysname-Ten-GigabitEthernet3/0/2] storm-constrain broadcast kbps 2000 1500
# 对Ten-GigabitEthernet3/0/3端口配置组播流量百分比阈值,上限为80%、下限为15%。
[Sysname] interface ten-gigabitethernet 3/0/3
[Sysname-Ten-GigabitEthernet3/0/3] storm-constrain multicast ratio 80 15
·     storm-constrain control
·     storm-constrain interval
1.2.6  storm-constrain control
storm-constrain control命令用来设置端口未知单播、组播或者广播流量超过上限阈值时采取的控制方式。
undo storm-constrain control命令用来恢复缺省情况。
不对端口流量进行控制。
二层以太网接口视图
block:block方式,即:当端口上未知单播、组播或广播报文中某类报文的流量大于其上限阈值时,端口将暂停转发该类报文(其它类型报文照常转发),端口处于阻塞状态,但仍会统计该类报文的流量。当该类报文的流量小于其下限阈值时,端口将自动恢复对此类报文的转发。
shutdown:shutdown方式,即:当端口上未知单播、组播或广播报文中某类报文的流量大于其上限阈值时,端口将被关闭,系统停止转发所有报文。当该类报文的流量小于其下限阈值时,端口状态不会自动恢复,此时可通过执行undo shutdown命令或取消端口上流量阈值的配置来恢复。
# 配置Ten-GigabitEthernet3/0/1端口,当流量超过上限阈值时,采用block方式控制。
[Sysname-Ten-GigabitEthernet3/0/1] storm-constrain control block
·     storm-constrain
1.2.7  storm-constrain enable log
storm-constrain enable log命令用来配置端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
undo storm-constrain enable log命令用来禁止端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
二层以太网接口视图
# 当Ten-GigabitEthernet3/0/1端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
[Sysname-Ten-GigabitEthernet3/0/1] storm-constrain enable log
1.2.8  storm-constrain enable trap
storm-constrain enable trap命令用来配置端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
undo storm-constrain enable trap命令用来禁止端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
二层以太网接口视图
# 当Ten-GigabitEthernet3/0/1端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
[Sysname-Ten-GigabitEthernet3/0/1] storm-constrain enable trap
1.2.9  storm-constrain interval
storm-constrain interval命令用来配置端口流量阈值控制模块流量统计的时间间隔。
undo storm-constrain interval命令用来恢复缺省情况。
storm-constrain interval interval
端口流量统计的时间间隔为10秒。
interval:端口流量统计的时间间隔,取值范围为1~300,单位为秒。为了保持网络状态的稳定,建议设置的时间间隔不低于10秒。
本命令设置的时间间隔专门为storm-constrain命令服务的,不同于flow-interval命令设置的时间间隔。虽然同样是统计端口流量,但是功能是分开的。
# 配置端口流量统计时间间隔为60秒。
[Sysname] storm-constrain interval 60
·     storm-constrain
1.2.10  virtual-cable-test
virtual-cable-test命令用来对以太网接口连接电缆进行一次检测,并显示检测结果。
virtual-cable-test
二层以太网接口视图
在以太网接口上执行本命令会使已经up的链路自动up、down一次。
仅以太网电口支持本命令,光口和光转电模块不支持本命令。
仅接口速率为1000Mbps的电口支持本功能。
检测结果仅供参考,检测到的长度最大误差为10米。
如果显示值为“-”,则表示不支持该项参数的检测。
# 开启系统对以太网电口连接电缆的检测功能。
[Sysname-Ten-GigabitEthernet3/0/1] virtual-cable-test
Cable status:
  Pair A length: 12 meters
  Pair B length: 13 meters
  Pair C length: 14 meters
  Pair D length: 15 meters
  Pair A state: OK
  Pair B state: OK
  Pair C state: OK
  Pair D state: OK
Pair Impedance mismatch: yes
Pair skew: 38 ns
Pair swap: swap
Pair polarity: swap
Insertion loss: 12 db
Return loss: 11 db
Near-end crosstalk: 13 db
表1-15 virtual-cable-test命令显示信息描述表
Cable status
电缆状态
Pair x length
当线对状态为正常时,显示的是线对的总长度
当线对状态非正常时,显示的是本接口到异常位置的长度
Pair x state
线对状态,包括:
·     OK:正常
·     Abnormal:异常
·     Abnormal (open):异常开路
·     Abnormal (short):异常短路
·     Invalid:检测失败
线对阻抗是否匹配,取值为:
·     yes:阻抗匹配
·     no:阻抗不匹配
Pair skew
线对不对称
Pair swap
线对交换
Pair polarity
是否极性交换
Insertion loss
插入信号衰减
Return loss
返回信号衰减
Near-end crosstalk
近端串扰
1.3  三层以太网接口/子接口的配置命令
1.3.1  mac-address
mac-address命令用来配置以太网接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
未配置接口的MAC地址。
三层以太网接口视图
三层以太网子接口视图
mac-address:MAC地址,形式为H-H-H。
# 配置三层以太网接口Ten-GigabitEthernet3/0/1的MAC地址为0001-0001-0001。
[Sysname-Ten-GigabitEthernet3/0/1] mac-address 1-1-1
1.3.2  mtu
mtu命令用来设置三层以太网接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
三层以太网接口/子接口的MTU值为1500字节。
三层以太网接口视图
三层以太网子接口视图
由于QoS队列长度的限制(如FIFO队列的缺省长度为75),MTU太小会造成分片太多,从而被QoS队列丢弃。此时,可适当增大MTU值或QoS队列的长度。以太网接口视图下的命令qos fifo queue-length可以改变QoS队列长度(具体配置请参见“ACL和QoS配置指导”中的“QoS”)。
本命令只对协议报文生效,对转发的数据报文不生效。
# 设置三层以太网接口Ten-GigabitEthernet3/0/1的最大传输单元为1430字节。
[Sysname-Ten-GigabitEthernet3/0/1] mtu 1430
# 设置三层以太网子接口Ten-GigabitEthernet3/0/1.1的最大传输单元为1430字节。
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] mtu 1430
1.3.3  traffic-statistic enable
traffic-statistic enable命令用来开启以太网子接口的报文统计功能。
undo traffic-statistic enable命令用来关闭以太网子接口的报文统计功能。
以太网子接口的报文统计功能处于关闭状态。
三层以太网子接口视图
配置本命令后,可以通过display interface命令的Input和Output字段或者display counters命令查看以太网子接口的统计信息。
系统工作模式为标准模式时,如果流量的入端口和出端口不在同一单板上,则入出端口开启本功能后,不会对出端口的流量进行统计。
# 开启三层以太网子接口Ten-GigabitEthernet3/0/1.1的报文统计功能。
[Sysname-Ten-GigabitEthernet3/0/1.1] traffic-statistic enable
·     display counters
·     display interface
·     flow-interval
