04-三层技术-IP业务命令参考
08-DHCPv6命令
本章节下载 08-DHCPv6命令  (481.44 KB)
08-DHCPv6命令
  录
1 DHCPv6
1.1 DHCPv6公共命令
1.1.1 display ipv6 dhcp duid
1.1.2 ipv6 dhcp advertise pd-route
1.1.3 ipv6 dhcp conflict-ip-address offline
1.1.4 ipv6 dhcp dscp
1.1.5 ipv6 dhcp duid
1.1.6 ipv6 dhcp select
1.1.7 ipv6 dhcp session-mismatch action
1.2 DHCPv6中继配置命令
1.2.1 dhcpv6-relay source-address
1.2.2 display ipv6 dhcp relay client-information address
1.2.3 display ipv6 dhcp relay client-information pd
1.2.4 display ipv6 dhcp relay packet statistics
1.2.5 display ipv6 dhcp relay remote-server-info
1.2.6 display ipv6 dhcp relay server-address
1.2.7 gateway-list
1.2.8 ipv6 dhcp client-detect
1.2.9 ipv6 dhcp relay client-information record
1.2.10 ipv6 dhcp relay client-link-address enable
1.2.11 ipv6 dhcp relay gateway
1.2.12 ipv6 dhcp relay interface-id
1.2.13 ipv6 dhcp relay non-first-hop enable
1.2.14 ipv6 dhcp relay release-agent
1.2.15 ipv6 dhcp relay remote-id duid
1.2.16 ipv6 dhcp relay remote-id enable
1.2.17 ipv6 dhcp relay server-address
1.2.18 ipv6 dhcp relay server-address algorithm
1.2.19 ipv6 dhcp relay subscriber-id enable
1.2.20 ipv6 dhcp relay subscriber-id
1.2.21 ipv6 dhcp relay source-address
1.2.22 ipv6 dhcp remote-server
1.2.23 remote-server
1.2.24 remote-server algorithm
1.2.25 reset ipv6 dhcp relay client-information address
1.2.26 reset ipv6 dhcp relay client-information pd
1.2.27 reset ipv6 dhcp relay packet statistics
1.3 DHCPv6客户端配置命令
1.3.1 display ipv6 dhcp client
1.3.2 display ipv6 dhcp client statistics
1.3.3 ipv6 address dhcp-alloc
1.3.4 ipv6 dhcp client dscp
1.3.5 ipv6 dhcp client duid
1.3.6 ipv6 dhcp client pd
1.3.7 ipv6 dhcp client stateful
1.3.8 ipv6 dhcp client stateless enable
1.3.9 reset ipv6 dhcp client statistics
1 DHCPv6
1.1  DHCPv6公共命令
display ipv6 dhcp duid命令用来显示本设备的DUID。
DUID(DHCP Unique Identifier,DHCP唯一标识符)是一台DHCPv6设备(包括客户端、服务器和中继)的唯一标识。在DHCPv6报文交互过程中,DHCPv6客户端、服务器和中继通过在报文中添加DUID来标识自己。
只有在设备上开启DHCPv6进程,配置本命令才会有显示信息。
# 显示本设备的DUID。
<Sysname> display ipv6 dhcp duid
The DUID of this device: 0003000100e0fc005552.
ipv6 dhcp advertise pd-route命令用来开启DHCPv6服务器或DHCPv6中继发布前缀路由功能。
undo ipv6 dhcp advertise pd-route命令用来恢复缺省情况。
DHCPv6服务器或DHCPv6中继发布前缀路由功能处于关闭状态。
DHCPv6客户端获取到IPv6前缀后,通过该IPv6前缀给下行网络内的主机分配IPv6地址。此时,DHCPv6客户端与网络内的主机不在同一网段,会导致主机无法与外界通信。为了解决这个问题,需要在DHCPv6服务器或DHCPv6中继上开启发布前缀路由功能。需要注意的是:
·     DHCPv6服务器和DHCPv6客户端在同一个链路范围内,需要在DHCPv6服务器上开启发布前缀路由功能;
·     DHCPv6服务器和DHCPv6客户端不在同一个链路范围内,需要在和DHCPv6客户端处于同一个链路范围内的DHCPv6中继上开启发布前缀路由功能。
开启本功能后,DHCPv6服务器和DHCPv6中继会生成一条和DHCPv6客户端获取到IPv6前缀对应的路由条目,并将该路由通告给动态路由协议。DHCPv6客户端通过动态路由协议学到该路由信息后,主机和外界就可以正常通信。
开启DHCPv6中继发布前缀路由功能前,需要先开启DHCPv6中继用户表项记录功能。
开启本功能后,发布的前缀路由的tag值将使用network命令配置的网段路由的tag值。如果在配置network命令时未指定网段路由的tag值,则前缀路由的tag值采用缺省值0
# 开启DHCPv6服务器或DHCPv6中继发布前缀路由功能。
[Sysname] ipv6 dhcp advertise pd-route
ipv6 dhcp conflict-ip-address offline命令用来配置当为新DHCPv6客户端分配的IPv6地址和已在线DHCPv6客户端的IPv6地址发生冲突时,释放已在线DHCPv6客户端的IPv6地址。
undo ipv6 dhcp conflict-ip-address offline命令用来恢复缺省情况。
当为新DHCPv6客户端分配的IPv6地址和已在线DHCPv6客户端的IPv6地址发生冲突时,已在线DHCPv6客户端不受影响。
缺省情况下,当DHCPv6服务器为DHCPv6客户端分配的IPv6地址和中继记录的用户IPv6地址表项冲突,或者接入设备(DHCPv6服务器或DHCPv6中继)上配置的认证授权模块(UCM或AAA模块)分配的IPv6地址和已在线DHCPv6客户端的IPv6地址发生冲突时,已在线的客户端不受影响,新客户端或认证授权用户上线失败。配置本功能后,DHCPv6设备会有以下处理方式:
·     在DHCPv6服务器上配置本功能,当DHCPv6服务器上配置的认证授权模块分配的IPv6地址和已在线DHCPv6客户端的IPv6地址发生冲突时,DHCPv6服务器会释放已在线DHCPv6客户端的IPv6地址,并通知接入模块此IPv6地址冲突不可用。
·     在DHCPv6中继上配置本功能,处理方式如下:
¡     如果是认证授权模块分配的IPv6地址和DHCPv6中继记录的用户IPv6地址表项冲突,则中继向DHCPv6服务器发送Release报文释放冲突IPv6地址,并通知接入模块此地址冲突不可用。
¡     如果DHCPv6服务器发送的应答报文中记录的IPv6地址和DHCPv6中继记录的用户表项冲突,则中继向DHCPv6服务器发送Release报文释放冲突地址,丢弃该应答报文,新DHCPv6客户端无法获取到IPv6地址。
当新客户端或认证授权用户再次发起IPv6地址申请时,可以正常申请到该地址,不会再发生地址冲突问题。
只有开启了DHCPv6中继用户地址表项记录功能后,DHCPv6中继上配置本功能才能生效。
# 配置当DHCPv6服务器或授权地址池为新用户分配的IPv6地址和已在线DHCPv6客户端的IPv6地址发生冲突时,释放已在线DHCPv6客户端的IPv6地址。
[Sysname] ipv6 dhcp conflict-ip-address offline
·     ipv6 dhcp relay client-information record
ipv6 dhcp dscp命令用来配置DHCPv6服务器或DHCPv6中继发送DHCPv6报文的DSCP优先级。
undo ipv6 dhcp dscp命令用来恢复缺省情况。
ipv6 dhcp dscp dscp-value
undo ipv6 dhcp dscp
DHCPv6服务器或DHCPv6中继发送DHCPv6报文的DSCP优先级为56。
dscp-value:IPv6 DHCP报文的DSCP优先级,取值范围为0~63。
# 配置DHCPv6服务器或DHCPv6中继发送的DHCPv6报文的DSCP优先级为30。
[Sysname] ipv6 dhcp dscp 30
ipv6 dhcp duid duid命令用来配置本设备的DUID。
undo ipv6 duid命令用来恢复缺省情况。
ipv6 dhcp duid duid
undo ipv6 duid
设备的DUID为设备生成的缺省值。
duid:设备的DUID,采用十六进制数格式,长度取值范围为8~28之间的偶数。
多次配置本功能,最后一次配置生效。
DHCPv6设备启动的时候会生成缺省的DUID,通过display ipv6 dhcp duid可以查看DHCPv6设备的DUID。
# 配置本设备的DUID为aabbccdd1122334455。
[Sysname] ipv6 dhcp duid aabbccdd1122334455
·     display ipv6 dhcp duid
ipv6 dhcp select命令用来配置接口工作在DHCPv6服务器或DHCPv6中继模式。
undo ipv6 dhcp select命令用来恢复缺省情况。
ipv6 dhcp select { relay | server }
接口未工作在DHCPv6服务器模式,也未工作在DHCPv6中继模式,接口接收到DHCPv6客户端发来的DHCPv6报文后,丢弃该报文。
relay:配置接口工作在DHCPv6中继模式。
server:配置接口工作在DHCPv6服务器模式。
本产品仅支持作为DHCPv6中继使用。
当接口从DHCPv6服务器模式切换到DHCPv6中继模式时,设备不会删除IPv6地址/前缀绑定信息。建议接口从DHCPv6服务器模式切换到DHCPv6中继模式时,先清除已有的IPv6地址/前缀绑定信息。
建议不要在一个接口上同时配置DHCPv6客户端和DHCPv6中继/服务器功能。
# 配置接口Ten-GigabitEthernet2/0/0工作在DHCPv6服务器模式。
[Sysname] interface ten-gigabitethernet 2/0/0
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp select server
# 配置接口Ten-GigabitEthernet2/0/1工作在DHCPv6中继模式。
[Sysname] interface ten-gigabitethernet 2/0/1
[Sysname-Ten-GigabitEthernet2/0/1] ipv6 dhcp select relay
·     display ipv6 dhcp relay server-address
ipv6 dhcp session-mismatch action命令用来配置DHCPv6设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCPv6请求的处理方式。
undo ipv6 dhcp session-mismatch action命令用来恢复缺省情况。
ipv6 dhcp session-mismatch action { fast-renew | roam }
DHCPv6设备收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文时,直接丢弃该DHCPv6请求报文。
fast-renew:首先释放对应MAC地址的地址或前缀租约,然后重新为其分配IPv6地址或IPv6前缀。
roam:使用对应MAC地址的地址或前缀租约应答DHCPv6请求,并刷新该地址或前缀租约的老化时间。本参数仅适用于IPoE组网中用户在属于同一漫游组的接口上漫游的场景。
本功能仅适用于IPoE组网。
当用户的物理接入位置发生变化时,例如无线终端用户漫游时,若需要该用户下线后重新上线,则DHCPv6设备可能会因为未及时收到用户的下线请求,而导致DHCPv6设备认为该终端用户还在线。因为终端用户所在的无线网络发生变化,但MAC地址不变,则DHCPv6设备会认为收到的终端用户重新发送的DHCPv6请求报文是攻击报文,直接丢弃该DHCPv6请求报文。
为了解决以上问题,需要在DHCPv6设备上配置本功能:
·     指定fast-renew参数后,当DHCPv6服务器收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文,先释放将对应MAC地址的已在线租约,再为该用户分配IPv6地址或IPv6前缀。当DHCP中继收到物理位置发生变化,MAC地址不变的上线用户发送的DHCP请求报文,先向服务器发报文释放对应MAC地址的已在线租约,再将请求报文转发给DHCPv6服务器。
·     指定roam参数后,当DHCPv6设备收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文,使用对应MAC地址的地址或前缀租约应答DHCP请求,并刷新该地址或前缀租约的老化时间。这样,可以保证用户继续使用相同的IPv6地址或IPv6前缀上线,避免了重新进行接入认证。当DHCPv6中继收到物理位置发生变化,MAC地址不变的上线用户发送的DHCPv6请求报文,直接将该请求报文转发给DHCPv6服务器。
配置本功能后,可能会导致正常在线的用户掉线。因此,仅在网络中不存在DHCPv6攻击,又需要解决漫游用户的上线问题时,才建议开启本功能。
# 在接口Ten-GigabitEthernet2/0/0上配置DHCPv6设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCPv6请求报文后,先释放将对应MAC地址的已在线租约,再为该用户分配IPv6地址或IPv6前缀。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp session-mismatch action fast-renew
·     ip subscriber roaming enable(二层技术-广域网接入命令参考/IPoE)
1.2  DHCPv6中继配置命令
dhcpv6-relay source-address命令用来指定DHCPv6中继向DHCPv6服务器转发报文的源地址。
undo dhcpv6-relay source-address命令用来恢复缺省情况。
dhcpv6-relay source-address { ipv6-address | gateway | interface interface-type interface-number }
当DHCPv6中继连接服务器的接口和DHCPv6服务器属于同一个VPN时,将DHCPv6中继向DHCPv6服务器转发报文出接口的一个全球单播地址作为报文源地址;当DHCPv6中继连接服务器的接口和DHCPv6服务器不属于同一个VPN时,DHCPv6中继会选择一个中继上和DHCPv6服务器同VPN的最小地址作为报文源地址。
IPv6地址池视图
ipv6-address:使用指定的地址作为向服务器转发报文的源地址。
gateway:使用报文的Link-address字段地址作为向服务器转发报文的源地址。如果Link-address字段为空,则按照缺省情况填充。
interface interface-type interface-number:指定该接口IPv6地址为发送到DHCPv6服务器的报文源地址。interface-type interface-number表示接口类型和接口编号。
在某些组网中,多个DHCPv6中继接口IPv6地址相同或者中继接口IPv6地址到服务器没有可达路由,管理员需要配置本命令选择中继设备上的另一个接口(一般选择的是Loopback口)的IPv6地址作为发送到DHCPv6服务器的DHCPv6请求报文中的源地址。
当中继存在Link-address字段地址到DHCPv6服务器的可达路由时,管理员需要指定gateway参数。
如果在同IPv6地址池视图下重复执行本命令,最后一次执行的命令生效。
# 在IPv6地址池pool1中,配置DHCPv6中继向DHCPv6服务器转发报文的源地址为2001:501:aabb::1/64。
[Sysname] ipv6 pool pool1
[Sysname-ipv6-pool-pool1] dhcpv6-relay source-address 2001:501:aabb::1
display ipv6 dhcp relay client-information address命令用来显示DHCPv6中继用户地址表项信息。
display ipv6 dhcp relay client-information address [ interface interface-type interface-number | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:显示指定接口上的DHCPv6中继用户地址表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的DHCPv6中继用户地址表项信息。对于IPoE个人接入漫游用户,需要指定初始用户上线口,才有显示信息。显示信息是用户的漫游口。IPoE个人接入用户漫游功能的详细介绍,请参见“二层技术—广域网接入配置指导”中的“IPoE”。
ipv6 ipv6-address:显示指定IPv6地址的DHCPv6中继用户地址表项信息。如果未指定本参数,则显示所有IPv6地址的DHCPv6中继用户地址表项信息。
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定公网。
不同类型用户对DHCPv6中继用户表项记录功能的支持情况不同:
·     对于非广域网接入类型(如IPoE和PPPoE)的用户,只有执行ipv6 dhcp relay client-information record命令后,DHCPv6中继才会记录DHCPv6中继用户地址表项。
·     对于通过未配置授权地址池的DHCPv6中继上线的广域网接入类型(如IPoE和PPPoE)的用户,DHCPv6中继用户地址表项记录功能自动开启且无法关闭,DHCPv6中继会一直记录此类接入用户的地址表项信息。
·     对于通过配置了授权地址池的DHCPv6中继上线的广域网接入类型(如IPoE和PPPoE)的用户,DHCPv6中继无法记录DHCPv6中继用户地址表项信息。如果管理员需要查询表项信息,需要在DHCPv6服务器执行display ipv6 dhcp server ip-in-use命令进行查询。
# 显示所有DHCPv6中继用户地址表项信息。
<Sysname> display ipv6 dhcp relay client-information address
1 DHCPv6 relay entries found.
 IPv6 address   IAID         Lease    Status    Interface
 2::1           0x00030001   54       Open      XGE2/0/0
# 显示指定IPv6地址2::1的DHCPv6中继用户地址表项信息。
<Sysname> display ipv6 dhcp relay client-information address ipv6 2::1
IPv6 address: 2::1
DUID: 00030001CA000C180000
IAID: 0x00030001
Port index: N/A
Interface: XGE2/0/0
Outer VLAN: N/A
Inner VLAN: N/A
Status: Open
Access type: CommonV6
PPP index: N/A
Remaining lease time: 54 seconds
Preferred lifetime: 400 seconds
Valid lifetime: 500 seconds
User ID: 0x40000003
表1-1 display ipv6 dhcp relay client-information address命令显示信息描述表
发现一条DHCPv6中继用户表项
IPv6 address
IPv6地址
DUID
DHCPv6客户端的DUID
IAID
DHCPv6客户端的IAID
Port index
DHCPv6中继收到DHCPv6客户端请求报文的二层端口信息。如果报文不从二层端口进入DHCPv6中继,则显示为“N/A”
DHCPv6中继接口。如果DHCPv6中继用户地址表项中未记录接口或接口索引失效,则显示为“N/A”
Outer VLAN
DHCPv6中继用户地址表项的外层VLAN Tag,若不存在,则显示为“N/A”
Inner VLAN
DHCPv6中继用户地址表项的内层VLAN Tag,若不存在,则显示为“N/A”
Status
表项状态,取值包括:
·     Open:DHCPv6客户端从DHCPv6服务器获取或续约地址租约成功
·     SOLICIT:收到DHCPv6客户端发送的携带Rapid标记的SOLICIT报文
·     REQUEST:收到DHCPv6客户端发送的REQUEST报文
·     RELEASE:收到DHCPv6客户端发送的RELEASE报文
·     DECLINE:收到DHCPv6客户端发送的DECLINE报文
·     RENEW:收到DHCPv6客户端发送的RENEW报文
·     REBIND:收到DHCPv6客户端发送的REBIND报文
Access type
接入类型,取值包括:
·     CommonV6:DHCPv6地址申请方式
·     IPoEv6:IPoE接入方式
·     PPPv6:PPP接入方式
PPP index
用户地址表项对应的PPP ID,如果不存在PPP ID,则显示为N/A
地址租约剩余时间,单位为秒
Preferred lifetime
地址的首选生命期,单位为秒
Valid lifetime
地址的有效生命期,单位为秒
User ID
DHCPv6接入用户标识值,为十六进制数
·     reset ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd命令用来显示DHCPv6中继用户前缀表项信息。
display ipv6 dhcp relay client-information pd [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:显示指定接口上的DHCPv6中继用户前缀表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口下的DHCPv6中继用户前缀表项信息。对于IPoE个人接入漫游用户,需要指定初始用户上线口,才有显示信息。显示信息是用户的漫游口。IPoE个人接入用户漫游功能的详细介绍,请参见“二层技术—广域网接入配置指导”中的“IPoE”。
prefix prefix/prefix-len:显示指定IPv6前缀的DHCPv6中继用户前缀表项信息。prefix-len为前缀长度,取值范围为1~128。如果未指定本参数,则显示所有IPv6前缀的DHCPv6中继用户前缀表项信息。
不同类型用户对DHCPv6中继用户前缀表项记录功能的支持情况不同:
·     对于非广域网接入类型(如IPoE和PPPoE)的用户,只有执行ipv6 dhcp relay client-information record命令后,DHCPv6中继才会记录DHCPv6中继用户前缀表项信息。
·     对于通过未配置授权地址池的DHCPv6中继上线的广域网接入类型(如IPoE和PPPoE)的用户,DHCPv6中继用户前缀表项记录功能自动开启且无法关闭,DHCPv6中继会一直记录此类接入用户的前缀表项信息。
·     对于通过配置了授权地址池的DHCPv6中继上线的广域网接入类型(如IPoE和PPPoE)的用户,DHCPv6中继无法记录DHCPv6中继用户前缀表项信息。如果管理员需要查询表项信息,需要在DHCPv6服务器执行display ipv6 dhcp server pd-in-use命令进行查询。
# 显示所有DHCPv6中继用户前缀表项信息。
<Sysname> display ipv6 dhcp relay client-information pd
 Prefix     IAID         Lease    Status   Interface
 2::/64     0x00030001   54       Open     XGE2/0/0
# 显示指定IPv6前缀2::/64的DHCPv6中继用户前缀表项信息。
<Sysname> display ipv6 dhcp relay client-information pd prefix 2::/64
Prefix: 2::/64
IAID: 0x00030001
Port index: N/A
Interface: XGE2/0/0
Outer VLAN: N/A
Inner VLAN: N/A
Status: Open
PPP index: N/A
User ID: 0x40000003
表1-2 display ipv6 dhcp relay client-information pd命令显示信息描述表
发现一条DHCPv6中继用户表项
Prefix
IPv6前缀
DUID
DHCPv6客户端的DUID
IAID
DHCPv6客户端的IAID
Port index
DHCPv6中继收到DHCPv6客户端请求报文的二层端口信息。如果报文不是从二层端口进入DHCPv6中继,则显示为“N/A”
DHCPv6中继接口。如果DHCPv6中继用户前缀表项中未记录接口或接口索引失效,则显示为“N/A”
Outer VLAN
DHCPv6中继用户前缀表项的外层VLAN Tag,若不存在,则显示为“N/A”
Inner VLAN
DHCPv6中继用户前缀表项的内层VLAN Tag,若不存在,则显示为“N/A”
Status
表项状态,取值包括:
·     Open:DHCPv6客户端从DHCPv6服务器获取或续约前缀租约成功
Access type
接入类型,取值包括:
·     IPoEv6:IPoE接入方式
·     PPPv6:PPP接入方式
PPP index
前缀租约剩余时间,单位为秒
Preferred lifetime
前缀的首选生命期,单位为秒
Valid lifetime
前缀的有效生命期,单位为秒
User ID
·     reset ipv6 dhcp relay client-information pd
display ipv6 dhcp relay packet statistics命令用来显示DHCPv6中继的相关报文统计信息。
display ipv6 dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口,interface-type interface-number为接口类型和接口编号。如果不指定本参数,则显示所有接口上DHCPv6中继的相关报文统计信息。
# 显示DHCPv6中继的相关报文统计信息。
<Sysname> display ipv6 dhcp relay packet statistics
Packets dropped               :  4
Packets received              :  14
    Solicit                   :  0
    Request                   :  0
    Confirm                   :  0
    Renew                     :  0
    Rebind                    :  0
    Release                   :  0
    Decline                   :  0
    Information-request       :  7
    Relay-forward             :  0
    Relay-reply               :  7
Packets sent                  :  14
    Advertise                 :  0
    Reconfigure               :  0
    Reply                     :  7
    Relay-forward             :  7
    Relay-reply               :  0
表1-3 display ipv6 dhcp relay packet statistics命令显示信息描述表
Packets dropped
丢弃的报文总数
Packets received
接收到的报文总数
Solicit
接收到的Solicit报文数目
Request
接收到的Request报文数目
Confirm
接收到的Confirm报文数目
Renew
接收到的Renew报文数目
Rebind
接收到的Rebind报文数目
Release
接收到的Release报文数目
Decline
接收到的Decline报文数目
Information-request
接收到的Information-request报文数目
Relay-forward
接收到的Relay-forward报文数目
Relay-reply
接收到的Relay-reply报文数目
Packets sent
发送的报文总数
Advertise
发送的Advertise报文数目
Reconfigure
发送的Reconfigure报文数目
Reply
发送的Reply报文数目
Relay-forward
发送的Relay-forward报文数目
Relay-reply
发送的Relay-reply报文数目
·     reset ipv6 dhcp relay statistics
display ipv6 dhcp relay remote-server-info命令用来显示DHCPv6中继的远端DHCPv6服务器配置和状态信息。
display ipv6 dhcp relay remote-server-info [ vpn-instance vpn-name ] [ slot slot-number ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示DHCPv6中继的远端DHCPv6服务器配置和状态信息。
<Sysname> display ipv6 dhcp relay remote-server-info
Remote server count: 2
Remote server: 100::1 *  Out interface: Ten-GigabitEthernet2/0/3
  RemoteSrvRefCnt: 2  State: Up
  CfgTimeOut: 12(s)  CfgDeadCount: 10  CfgDeadTime: 10(m)
  RunDeadCnt: 0  RunDeadTime: 1968(s)
  Recent state changes:
    Jun 24 17:45:36 2023 Changed to down
    Jun 24 17:45:23 2023 Changed to up
    Jun 24 17:44:23 2023 Changed to down
    Jun 24 17:43:49 2023 Changed to up
    Jun 24 17:40:49 2023 Changed to down
Remote server: 100::2  Out interface: N/A
  RemoteSrvRefCnt: 1  State: Up
  CfgTimeOut: 13(s)  CfgDeadCount: 10  CfgDeadTime: 10(m)
    Jun 24 17:38:52 2023 Changed to down
    Jun 24 17:38:49 2023 Changed to up
    Jun 24 17:38:42 2023 Changed to down
    Jun 24 17:38:39 2023 Changed to up
    Jun 24 17:38:31 2023 Changed to down
表1-4 display ipv6 dhcp relay remote-server-info命令显示信息描述表
Remote server count
远端DHCPv6服务器的个数
Remote server
远端DHCPv6服务器的IPv6地址,*表示指定了对该IPv6地址对应的DHCPv6服务器判断是否可用的条件;否则,则显示为空
Out interface
为DHCPv6中继指定的向DHCPv6服务器转发报文的出接口。若未指定该接口,则显示为N/A
RemoteSrvRefCnt
DHCPv6服务器被中继地址池引用的次数
远端DHCPv6服务器的状态,取值包括:
·     Up:可用
·     Down:不可用
·     UnKnown:未知
CfgTimeOut
配置的DHCPv6中继检查是否收到DHCPv6服务器回复DHCPv6应答报文的时间间隔,单位为秒
CfgDeadCount
配置的DHCPv6服务器连续未回复DHCPv6应答报文的最大次数
CfgDeadTime
配置的DHCPv6中继认为DHCPv6服务器不可用的时长,单位为分钟
RunDeadCnt
DHCPv6服务器连续未回复DHCPv6应答报文的次数
RunDeadTime
DHCPv6中继认为DHCPv6服务器不可用的时长,单位为秒
远端DHCPv6服务器最近5次的状态变化信息
·     ipv6 dhcp remote-server
·     remote-server algorithm
·     remote-server
display ipv6 dhcp relay server-address命令用来显示DHCPv6中继接口上指定的DHCPv6服务器地址信息。
display ipv6 dhcp relay server-address [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上指定的DHCPv6服务器地址信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上指定的DHCPv6服务器地址信息。
# 显示DHCPv6中继所有接口上指定的DHCPv6服务器地址信息。
<Sysname> display ipv6 dhcp relay server-address
Interface: Ten-GigabitEthernet2/0/0
 Server address                             Outgoing Interface              Public/VRF name
 2::3
 3::4                                     Ten-GigabitEthernet2/0/2            Y/--
Interface: Ten-GigabitEthernet2/0/1
 2::3
# 显示接口Ten-GigabitEthernet2/0/0上指定的DHCPv6服务器地址信息。
<Sysname> display ipv6 dhcp relay server-address interface ten-gigabitethernet 2/0/0
 2::3
表1-5 display ipv6 dhcp relay server-address命令显示信息描述表
接口名
Server address
接口上指定的DHCPv6服务器地址
Outgoing Interface
DHCPv6报文的出接口,若未指定出接口,则表明报文将通过路由自动查找出接口
Public/VRF name
DHCPv6服务器所在位置,取值包括:
·     当配置了ipv6 dhcp relay server-address命令时,显示为--/--
·     当配置了ipv6 dhcp relay server-address public命令时,显示为Y/--
·     当配置了ipv6 dhcp relay server-address vpn-instance vpn-instance-name命令时,显示为--/VPN实例名称
·     ipv6 dhcp relay server-address
·     ipv6 dhcp select
1.2.7  gateway-list
gateway-list命令用来指定匹配该地址池的DHCPv6客户端所在的网段的地址。
undo gateway-list命令用来删除指定的匹配该地址池的DHCPv6客户端所在的网段的地址。
gateway-list ipv6-address&<1-8>
undo gateway-list [ ipv6-address&<1-8> ]
未指定匹配该地址池的DHCPv6客户端所在的网段的地址。
IPv6地址池视图
ipv6-address&<1-8>:匹配该地址池的DHCPv6客户端所在的网段IPv6地址。&<1-8>表示最多可以输入8个IPv6地址,每个IPv6地址之间用空格分隔。
应用场景
一台DHCPv6中继的一个接口下可能连接不同类型的用户,当DHCPv6中继转发DHCPv6客户端请求报文给DHCPv6服务器时,不能再以中继接口的IPv6地址作为选择地址池的依据。为了解决这个问题,需要使用gateway-list命令指定某个类型用户所在的网段,并将该地址添加到转发给DHCPv6服务器的报文的Link-address字段中,为DHCPv6服务器选择地址池提供依据。
注意事项
当用户通过本命令配置的网关地址上线后,请勿删除已在线用户正在使用的网关地址,否则将影响用户后续的报文转发。
# 指定匹配该地址池p1的DHCPv6客户端所在的网段的地址为10::1。
[Sysname] ipv6 pool p1
[Sysname-ipv6-pool-p1] gateway-list 10::1
ipv6 dhcp client-detect命令用来开启DHCPv6中继用户下线检测功能。
undo ipv6 dhcp client-detect命令用来关闭DHCPv6中继用户下线检测功能。
DHCPv6中继用户下线检测功能处于关闭状态。
只有配置了设备工作在DHCPv6中继模式,并开启了DHCPv6中继用户表项记录功能后,DHCPv6中继用户下线检测功能才能生效。
# 在接口Ten-GigabitEthernet2/0/0上开启DHCPv6中继用户下线检测功能。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp select relay
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay client-information record
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp client-detect
ipv6 dhcp relay client-information record命令用来开启DHCPv6中继用户地址/前缀表项记录功能。
undo ipv6 dhcp relay client-information record命令用来关闭DHCPv6中继用户地址/前缀表项记录功能。
DHCPv6中继用户地址/前缀表项记录功能处于关闭状态。
执行undo ipv6 dhcp relay client-information record命令后,会删除DHCPv6中继上已记录的所有DHCPv6中继用户地址/前缀表项,且不会再生成新的DHCPv6中继用户地址/前缀表项。
对于广域网接入类型(如IPoE和PPPoE)的用户,本命令不生效:
·     当接入用户通过配置了授权地址池的DHCPv6中继上线时,DHCPv6中继无法记录用户地址/前缀表项。
·     当接入用户通过未配置授权地址池的DHCPv6中继上线时,DHCPv6中继用户地址表项记录功能自动开启且无法关闭,DHCPv6中继会一直记录此类接入用户的地址/前缀表项。
# 在接口Ten-GigabitEthernet2/0/0上开启DHCPv6中继用户地址/前缀表项记录功能。
·     display ipv6 dhcp relay client-information address
·     display ipv6 dhcp relay client-information pd
ipv6 dhcp relay client-link-address enable命令用来开启DHCPv6中继支持添加Option 79选项功能。
undo ipv6 dhcp relay client-link-address enable命令用来关闭DHCPv6中继支持添加Option 79选项功能。
DHCPv6中继支持添加Option 79选项功能处于关闭状态。
某些存在DHCPv6中继的组网中,DHCPv6服务器需要获取到DHCPv6客户端的MAC地址信息,进行DHCPv6客户端合法性认证或为DHCPv6客户端分配和MAC地址对应的IPv6地址、IPv6前缀或其他网络参数。为了满足上述需求,需要在DHCPv6客户端发出请求报文后经过的第一个DHCPv6中继上开启支持添加Option 79选项功能。开启本功能后,当DHCPv6中继收到DHCPv6请求报文时,会学习报文中的DHCPv6客户端的MAC地址。DHCPv6中继生成和请求报文对应的Relay-Forward报文时,会将学到的MAC地址添加到报文的Option 79选项中,再将该报文转发给DHCPv6服务器。
# 在接口Ten-GigabitEthernet2/0/0上开启DHCPv6中继支持添加Option 79选项功能。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay gateway命令用来配置DHCPv6中继为DHCPv6客户端分配的网关地址。
undo ipv6 dhcp relay gateway命令用来恢复缺省情况。
ipv6 dhcp relay gateway ipv6-address
分配接口下第一个IPv6地址作为DHCPv6客户端的网关地址。
ipv6-address:指定作为客户端网关的IPv6地址。该IPv6地址必须属于命令行所在的接口。
在接口视图下配置此命令后,中继会使用此命令配置的地址作为客户端的网关地址。
多次执行本命令,最后一次执行的命令生效。
# 在接口Ten-GigabitEthernet2/0/0上配置为DHCPv6客户端分配的网关地址为10::1。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay gateway 10::1
·     gateway-list
ipv6 dhcp relay interface-id命令用来配置DHCPv6中继支持的Interface ID选项填充模式。
undo ipv6 dhcp relay interface-id命令用来恢复缺省情况。
ipv6 dhcp relay interface-id { bas [ merge ] | cn-telecom | interface | tr-101 }
Interface ID选项的填充模式为接口索引信息。
bas:表示配置Interface ID选项填充模式为BAS模式。填充内容包括接口信息和VLAN信息,封装格式为:interface-type slot/subslot/port vxlan_id.vlan_id.subvlan_id_OLT
merge:表示配置Interface ID选项填充模式为BAS拼接模式。当DHCPv6中继收到DHCP请求报文后,会将请求报文中的OLT标识位填充为请求报文中的OLT信息(OLT连接终端用户的接口,终端用户的MAC地址等)。如果未指定本参数,则OLT标识填为全0。
cn-telecom:表示配置Interface ID选项填充模式为中国电信模式。填充内容为接口信息,接口所在的板号和子板号,接口所在的内层VLAN和外层VLAN信息。
interface:表示配置Interface ID选项填充模式为接口名模式。填充内容为ASCII码格式的接口名和接口所在VLAN的编号。
tr-101:表示配置Interface ID选项填充模式为tr-101模式。填充内容为接口信息,接口所在板号和接口所在VLAN信息。
执行ipv6 dhcp relay interface-id命令之前,如果未配置DHCPv6中继模式,本命令不生效。
在电信组网中,为了保证DHCPv6客户端可以通过接入认证,并获取正确的IPv6前缀或地址,需要在首跳DHCPv6中继上配置Interface ID选项填充模式为BAS拼接模式。
# 在接口Ten-GigabitEthernet2/0/0下配置DHCPv6中继支持的Interface ID选项填充模式为BAS模式。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay interface-id bas
# 在接口Ten-GigabitEthernet2/0/0下配置DHCPv6中继支持的Interface ID选项填充模式为接口名模式。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay interface-id interface
ipv6 dhcp relay non-first-hop enable命令用来开启非首跳DHCPv6中继功能。
undo ipv6 dhcp relay non-first-hop enable命令用来关闭非首跳DHCPv6中继功能。
非首跳DHCPv6中继功能处于关闭状态。
在某些网络环境中,在DHCPv6客户端和DHCPv6服务器之间可能存在多跳DHCPv6中继。缺省情况下,只有连接DHCPv6客户端的第一跳DHCPv6中继处理DHCPv6请求报文,后续的DHCPv6中继只会转发该报文。若需要在非第一跳DHCPv6中继设备上开启接入认证功能,则需要在该DHCPv6中继设备开启本功能,DHCPv6中继收到DHCPv6请求报文后,会将报文发送接入认证模块进行用户的认证、授权等操作。
本命令只适用于接入认证组网环境,普通组网不需要配置本功能。只需要在开启接入认证功能的DHCPv6中继开启本功能,其他中继不需要配置本功能。
只有开启了DHCPv6中继功能后,本功能才生效。
# 在接口Ten-GigabitEthernet2/0/0上开启非首跳DHCPv6中继功能。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay non-first-hop enable
·     ipv6 dhcp select relay
ipv6 dhcp relay release-agent命令用来配置清除用户表项时通知DHCPv6服务器释放租约。
undo ipv6 dhcp relay release-agent命令用来恢复缺省情况。
清除用户表项时不会通知DHCPv6服务器释放租约。
只有配置了设备工作在DHCPv6中继模式,清除用户表项时通知DHCPv6服务器释放租约功能才能生效。
# 在接口Ten-GigabitEthernet2/0/0上配置清除用户表项时通知DHCPv6服务器释放租约。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay release-agent
ipv6 dhcp relay remote-id duid命令用来配置DHCPv6中继封装Option 37选项时使用的DUID。
undo ipv6 dhcp relay remote-id duid命令用来恢复缺省情况。
ipv6 dhcp relay remote-id duid { ascii ascii-string | hex hex-string }
DHCPv6中继使用本设备的DUID封装Option 37选项。
三层以太网接口视图/三层以太网子接口视图
三层聚合接口视图/三层聚合子接口视图
VSI虚接口视图/VSI子接口视图
L3VE接口视图/L3VE子接口视图
以太网冗余接口视图/以太网冗余子接口视图
三层FlexE业务接口视图/三层FlexE业务子接口视图
VLAN接口视图
ascii ascii-string:使用指定ASCII字符串作为DHCPv6中继封装Option 37选项时使用的DUID,为1~128个字符的字符串,区分大小写。
hex hex-string:使用指定的十六进制数作为DHCPv6中继封装Option 37选项时使用的DUID,为1~128个字符的字符串,且长度必须为偶数。
# 在接口Ten-GigabitEthernet2/0/0下配置DHCPv6中继封装Option 37选项时使用的DUID为十六进制数FFFFFFFF。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay remote-id duid hex ffffffff
·     ipv6 dhcp relay remote-id enable
ipv6 dhcp relay remote-id enable命令用来开启DHCPv6中继支持添加Option 37选项功能。
undo ipv6 dhcp relay remote-id enable命令用来关闭DHCPv6中继支持添加Option 37选项功能。
DHCPv6中继支持添加Option 37选项功能处于关闭状态。
三层聚合接口视图/三层聚合子接口视图
VSI虚接口视图/VSI子接口视图
L3VE接口视图/L3VE子接口视图
VLAN接口视图
开启本功能后,当DHCPv6中继向DHCPv6服务器发送Relay-forwad报文时会携带Option 37选项。用户可以使用ipv6 dhcp relay remote-id duid命令配置DHCPv6中继封装Option 37选项时使用的DUID。
Option 37选项中的信息标识了客户端的位置信息,这些信息可以作为DHCPv6服务器分配IPv6地址和网络参数的依据。开启DHCPv6中继支持添加Option 37选项功能后,DHCPv6中继从客户端接收到的DHCPv6请求报文时,在报文中添加Option 37选项,然后再把该报文转发给DHCPv6服务器。支持Option 37功能的DHCPv6服务器接收到DHCPv6请求报文后,可以根据报文中的Option 37信息给DHCPv6客户端分配IPv6地址和其它配置信息。
# 在接口Ten-GigabitEthernet2/0/0下开启DHCPv6中继支Option 37功能。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay remote-id enable
·     ipv6 dhcp relay remote-id duid
ipv6 dhcp relay server-address命令指定DHCPv6中继对应的DHCPv6服务器地址。
undo ipv6 dhcp relay server-address命令用来删除DHCPv6中继对应的DHCPv6服务器地址。
ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ]
undo ipv6 dhcp relay server-address [ ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ] ]
未指定DHCPv6中继对应的DHCPv6服务器地址。
ipv6-address:DHCPv6服务器的IPv6地址。如果DHCPv6服务器的IPv6地址是组播地址或者链路本地地址,则必须指定报文的出接口。
interface interface-type interface-number:指定报文的出接口。其中,interface-type interface-number为接口类型和接口编号。如果指定了本参数,则通过指定的接口将DHCPv6客户端发送的请求报文转发给DHCPv6服务器;如果未指定本参数,则根据路由查找报文的出接口。
public:指定DHCPv6中继配置的DHCPv6服务器地址属于公网。
vpn-instance vpn-instance-name:指定DHCPv6中继配置的DHCPv6服务器的地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~32个字符的字符串,区分大小写。
工作在DHCPv6中继模式的接口接收到DHCPv6客户端发来的报文后,将其封装在Relay-forward报文中,并发送给指定的DHCPv6服务器,由DHCPv6服务器为客户端分配地址和网络配置参数。
通过多次执行ipv6 dhcp relay server-address命令可以指定多个DHCPv6服务器,一个接口下最多可以指定8个DHCPv6服务器。DHCPv6中继从接口接收到DHCPv6客户端发送的报文后,将其转发给该接口上指定的所有DHCPv6服务器。
如果指定的DHCPv6服务器地址为链路本地地址或组播地址,则必须指定出接口,否则报文可能会无法到达服务器。
如果指定了vpn-instance参数,则DHCPv6中继根据配置的DHCPv6服务器地址对应的VPN信息,向该VPN内的DHCPv6服务器转发报文。如果未指定publicvpn-instance vpn-instance-name参数,则以当前DHCPv6客户端位置(公网或VPN)为准。
执行undo ipv6 dhcp relay server-address命令时,如果指定了ipv6-address参数,则删除指定的DHCPv6服务器地址;如果未指定任何参数,则删除接口上的所有DHCPv6服务器地址。
建议不要在一个接口上同时配置DHCPv6客户端和DHCPv6中继功能。
# 配置接口Ten-GigabitEthernet2/0/0工作在DHCPv6中继模式,并指定DHCPv6中继对应的DHCPv6服务器地址为2001:1::3。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay server-address 2001:1::3
·     display ipv6 dhcp relay remote-server-info
·     ipv6 dhcp select
ipv6 dhcp relay server-address algorithm命令用来配置DHCPv6中继选择DHCPv6服务器方式。
undo ipv6 dhcp relay server-address algorithm命令用来恢复缺省情况。
ipv6 dhcp relay server-address algorithm { master-backup | polling }
DHCPv6中继同时向所有DHCPv6服务器转发DHCPv6请求报文(polling方式)。
master-backup:主备方式,即DHCPv6中继向主用DHCPv6服务器转发DHCPv6请求报文,当主用DHCPv6服务器不可用或没有空闲地址时,再按照服务器地址配置顺序依次向其他备用DHCPv6服务器发送DHCPv6请求报文。
polling:全部方式,即DHCPv6中继同时向所有DHCPv6服务器转发DHCPv6请求报文。
# 在接口Ten-GigabitEthernet2/0/0上配置DHCPv6中继使用主备方式选择DHCPv6服务器。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay server-address algorithm master-backup
·     remote-server
ipv6 dhcp relay subscriber-id enable命令用来开启DHCPv6中继添加Subscriber ID选项功能。
undo ipv6 dhcp relay subscriber-id enable命令用来关闭DHCPv6中继添加Subscriber ID选项功能。
DHCPv6中继不在Relay-forward报文中添加Subscriber ID选项。
三层聚合接口视图/三层聚合子接口视图
VSI虚接口视图/VSI子接口视图
L3VE接口视图/L3VE子接口视图
VLAN接口视图
应用场景
DHCPv6中继组网中,DHCPv6服务器可以根据Relay-forward报文中携带的Subscriber ID选项的信息制定IP地址和其他参数的分配策略,提供更加灵活的地址分配方案。
工作机制
在DHCPv6中继的入接口开启DHCPv6中继添加Subscriber ID选项功能后,DHCPv6中继将向转发给DHCPv6服务器的Relay-forward报文中添加Subscriber ID选项,选项内容由ipv6 dhcp relay subscriber-id命令决定。
# 开启DHCPv6中继支持添加Subscriber ID选项功能。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay subscriber-id enable
·     ipv6 dhcp relay subscriber-id
ipv6 dhcp relay subscriber-id命令用来配置DHCPv6中继填充Subscriber ID选项的格式和内容。
undo ipv6 dhcp relay subscriber-id命令用来恢复缺省情况
ipv6 dhcp relay subscriber-id { ascii ascii-string | hex hex-string }
Subscriber ID选项中填充的是客户端的MAC地址。
三层聚合接口视图/三层聚合子接口视图
VSI虚接口视图/VSI子接口视图
L3VE接口视图/L3VE子接口视图
VLAN接口视图
ascii ascii-string:指定以配置的ASCII码格式内容填充Subscriber ID选项。ascii-string为1~128个字符的ASCII字符串,区分大小写。
hex hex-string:指定以配置的十六进制格式内容填充Subscriber ID选项。hex-string为十六进制数,位数的取值范围为2~256之间的偶数。
工作机制
通过执行本命令,可以配置Subscriber ID选项内容为指定的ASCII字符串或十六进制数。DHCPv6中继将携带Subscriber ID选项的Relay-forward报文转发给DHCPv6服务器后,由DHCPv6服务器根据该选项中填充的信息为DHCPv6客户端分配合适的IPv6地址。
配置准备
执行ipv6 dhcp relay subscriber-id enable命令用来开启DHCPv6中继添加Subscriber ID选项功能。
注意事项
# 配置采用ASCII字符串填充Subscriber ID选项。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay subscriber-id ascii device001
·     ipv6 dhcp relay subscriber-id enable
ipv6 dhcp relay source-address命令用来指定DHCPv6中继向DHCPv6服务器转发报文的源地址。
undo ipv6 dhcp relay source-address命令用来恢复缺省情况。
ipv6 dhcp relay source-address { ipv6-address | interface interface-type interface-number }
当DHCPv6中继连接服务器的接口和DHCPv6服务器属于同一个VPN时,DHCPv6中继向DHCPv6服务器转发报文出接口的一个全球单播地址作为报文源地址;当DHCPv6中继连接服务器的接口和DHCPv6服务器不属于同一个VPN时,DHCPv6中继会选择一个中继上和DHCPv6服务器同VPN的最小地址作为报文源地址。
ipv6-address:指定该IPv6地址为发送到DHCPv6服务器的报文源地址。
在某些组网中,DHCPv6中继接口到DHCPv6服务器没有可达路由,用户需要配置本命令选择DHCPv6中继设备上的另一个接口(一般选择的是Loopback口)的IPv6地址填充到转发给DHCPv6服务器的DHCPv6请求报文中的源地址字段。
当使用interface interface-type interface-number参数指定DHCPv6服务器的报文源地址时,如果该接口不存在IPv6全球单播地址,则恢复缺省情况。
多次执行命令,最后一次执行的命令生效。
# 在接口Ten-GigabitEthernet2/0/0上指定DHCPv6中继向DHCPv6服务器转发报文的源地址为10::1
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp relay source-address 10::1
ipv6 dhcp remote-server命令用来配置远端DHCPv6服务器可用性探测功能。
undo ipv6 dhcp remote-server命令用来恢复缺省情况。
ipv6 dhcp remote-server [ ipv6-address [ vpn-instance vpn-instance-name ] ] { dead-count dead-count-value | dead-time dead-time | timeout timeout } *
undo ipv6 dhcp remote-server [ ipv6-address [ vpn-instance vpn-instance-name ] ] { dead-count | dead-time | timeout } *
DHCPv6中继在55秒后还未收到远端DHCPv6服务器的应答,则DHCPv6中继认为该远端DHCPv6服务器不可用。
ipv6-address:配置DHCPv6中继判断指定远端DHCPv6服务器是否可用的条件。如果未指定本参数,则表示配置的是所有远端DHCPv6服务器不可用的共用判断条件。
dead-count dead-count-value:指定远端DHCPv6服务器连续未回复DHCPv6应答报文的最大次数。dead-count-value的取值范围为1~64,缺省值为0。
dead-time dead-time:指定DHCPv6中继认为远端DHCPv6服务器不可用的时长。该时间到达后,DHCPv6中继重新认为远端DHCPv6服务器可用。dead-time的取值范围为1~65536,单位为分钟,缺省值为3。
timeout timeout:指定DHCPv6中继检查是否收到远端DHCPv6服务器回复DHCPv6应答报文的时间间隔。timeout的取值范围为1~60,单位为秒,缺省值为55。
本功能只适用于DHCPv6中继使用IPv6中继地址池选择对应远端DHCPv6服务器的组网环境。
配置本功能后,当DHCPv6中继向远端DHCPv6服务器转发第一个DHCPv6请求报文时,开始对请求报文进行计数,并开始计时。每经过一个timeout时长后,DHCPv6中继都会检查向远端DHCPv6服务器转发的报文数,当DHCPv6中继选择DHCPv6服务器方式不同时,DHCPv6中继探测DHCPv6服务器可用性的机制不同:
·     DHCPv6中继选择DHCPv6服务器方式为master-backup时,机制如下:
¡     DHCPv6中继向选中的远端DHCPv6服务器转发第一个DHCPv6请求报文时,启动timeout计时器。timeout时长为DHCPv6中继选中的DHCPv6服务器的timeout值。
¡     如果在timeout内收到应答报文,中继会清除报文计数,关闭timeout计时器。再次发送请求时,DHCPv6中继会重新进行报文计数,并重新开始timeout计时。
¡     如果在timeout内收到IPv6地址/前缀分配失败的应答报文,DHCPv6中继认为该远端DHCPv6服务器不可用。
¡     如果DHCPv6中继向远端DHCPv6服务器转发了不多于dead-count-value个请求报文,且未收到一个应答报文,则DHCPv6中继会在下次转发报文时重新开始计时,并继续报文计数。
¡     如果DHCPv6中继向远端服务器转发了多于dead-count-value个请求报文,却仍未收到一个应答报文,则认为该远端DHCPv6服务器不可用。后续DHCPv6中继收到请求报文后,会选择其他可用的远端服务器转发请求报文。如果所有的远端DHCPv6服务器均不可用,DHCPv6中继收到请求报文后,会向所有的远端DHCPv6服务器转发DHCPv6请求报文,但是不会启动timeout计时器。
·     DHCPv6中继选择DHCPv6服务器方式为polling时,机制如下:
¡     DHCPv6中继向所有可用的远端DHCPv6服务器转发第一个DHCPv6请求报文时,启动timeout计时器。计时器的时长选取所有可用的DHCPv6服务器中timeout的最大值。
¡     如果在timeout内收到应答报文,且报文中包含可用的IPv6地址/前缀,中继会清除报文计数,关闭timeout计时器。再次发送请求时,DHCPv6中继会重新进行报文计数,并重新开始timeout计时。
¡     如果在timeout内收到IPv6地址/前缀分配失败的应答报文,DHCPv6中继认为该远端DHCPv6服务器不可用。同时,timeout计时器继续计时,DHCPv6中继继续报文计数。
¡     如果DHCPv6中继向远端服务器转发了多于dead-count-value个请求报文,却仍未收到一个应答报文,则认为所有的远端服务器不可用。这种情况下,如果DHCPv6中继收到一个请求报文,会向所有的远端DHCPv6服务器转发DHCPv6请求报文,但是不会启动timeout计时器。
当DHCPv6中继认为某台远端DHCPv6服务器不可用后,dead-time定时器开始计时。在dead-time时长内,DHCPv6中继认为该远端DHCPv6服务器不可用,当DHCPv6中继再次匹配到该远端DHCPv6服务器时,也不会向其转发DHCPv6请求报文。经过dead-time时长后,DHCPv6中继会重新认为该远端DHCPv6服务器可用。当DHCPv6中继再次匹配到该远端DHCPv6服务器时,会向其转发DHCPv6请求报文。
对于同一台远端DHCPv6服务器来说,DHCPv6中继优先使用指定判断条件;如果指定判断条件不存在,则使用共用判断条件。
多次配置ipv6 dhcp remote-server命令时,如果ipv6-address参数取值不同,则可以配置多条。如果ipv6-address参数取值相同,或者不带ipv6-address参数时,则配置相同参数时,最后一次配置生效,配置不同参数时,所有配置均可以生效。
# 配置DHCPv6中继判断IPv6地址为1::1的远端DHCPv6服务器是否可用的条件:指定远端DHCPv6服务器连续未回复DHCPv6应答报文的最大次数为10,DHCPv6中继等待远端DHCPv6服务器回复DHCP应答报文的超时时长为20秒,DHCPv6中继认为远端DHCPv6服务器不可用的时长为3分钟。
[Sysname] ipv6 dhcp remote-server 1::1 dead-count 10 timeout 20 dead-time 3
·     remote-server
remote-server命令指定中继地址池对应的DHCPv6服务器地址。
undo remote-server命令用来删除为中继地址池指定的DHCPv6服务器地址。
remote-server ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ]
undo remote-server [ ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ] ]
未指定中继地址池的DHCPv6服务器的地址。
IPv6地址池视图
interface interface-type inteface-number:指定DHCPv6中继将报文转发给DHCPv6服务器的出接口,interface-type inteface-number表示接口类型和接口编号。如果未指定本参数,则DHCPv6中继根据路由表查找报文出接口。
public:指定公网中的DHCPv6服务器。
vpn-instance vpn-instance-name:指定VPN中的DHCPv6服务器,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定公网。
在一个地址池中,最多可以通过配置remote-server命令来指定8个DHCPv6服务器的地址。
执行undo remote-server命令时,如果未指定任何参数,则删除所有配置的DHCPv6服务器地址。
当配置的目的地址是链路本地地址时,必须指定DHCPv6中继将报文转发给DHCPv6服务器的出接口。
# 配置IPv6地址池0为中继配置的服务器地址为10::1。
[Sysname] ipv6 pool 0
[Sysname-ipv6-pool-0] remote-server 10::1
remote-server algorithm命令用来配置DHCPv6中继选择DHCPv6服务器方式。
undo remote-server algorithm命令用来恢复缺省情况。
remote-server algorithm { master-backup | polling }
IPv6地址池视图
master-backup:主备方式,即DHCPv6中继向主用DHCPv6服务器转发DHCPv6请求报文,当主用DHCPv6服务器不可用,再按照服务器地址配置顺序依次向其他备用DHCPv6服务器发送DHCPv6请求报文。
# 在远端IPv6地址池0内,配置DHCPv6中继使用主备方式选择DHCPv6服务器。
[Sysname-ipv6-pool-0] remote-server algorithm master-backup
·     remote-server
reset ipv6 dhcp relay client-information address命令用来清除DHCPv6中继用户地址表项信息。
reset ipv6 dhcp relay client-information address [ interface interface-type interface-number | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:清除指定接口上的DHCPv6中继用户地址表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口上的DHCPv6中继用户地址表项信息。
ipv6 ipv6-address:清除指定IPv6地址的DHCPv6中继用户地址表项信息。如果未指定本参数,则清除所有IPv6地址的DHCPv6中继用户地址表项信息。
reset ipv6 dhcp relay client-information address命令在清除DHCPv6中继用户地址表项信息时,如果需要发送Release报文知会DHCPv6服务器释放租约,就需要配置ipv6 dhcp relay release-agent命令。
# 清除所有DHCPv6中继用户地址表项信息。
<Sysname> reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd命令用来清除DHCPv6中继的用户前缀表项信息。
reset ipv6 dhcp relay client-information pd [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number:清除指定接口上的DHCPv6中继用户前缀表项信息,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口上的DHCPv6中继用户前缀表项信息。
prefix prefix/prefix-len:清除指定IPv6前缀的DHCPv6中继用户前缀表项信息。prefix-len为前缀长度,取值范围为1~128。如果未指定本参数,则清除所有IPv6前缀的DHCPv6中继用户前缀表项信息。
# 清除所有DHCPv6中继用户前缀表项信息。
<Sysname> reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay packet statistics命令用来清除DHCPv6中继的相关报文统计信息。
reset ipv6 dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number:指定接口,interface-type interface-number为接口类型和接口编号。如果不指定本参数,则清除所有接口上的DHCPv6中继相关报文统计信息。
# 清除DHCPv6中继的相关报文统计信息。
<Sysname> reset ipv6 dhcp relay packet statistics
1.3  DHCPv6客户端配置命令
display ipv6 dhcp client命令用来显示DHCPv6客户端的信息。
display ipv6 dhcp client [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的DHCPv6客户端信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有DHCPv6客户端的信息。
# 显示接口Ten-GigabitEthernet2/0/0上的DHCPv6客户端信息。
<Sysname> display ipv6 dhcp client interface ten-gigabitethernet 2/0/0
Ten-GigabitEthernet2/0/0:
  Type: Stateful client requesting address and prefix
    State: OPEN
    Client DUID: 0003000100e002000000
    Preferred server
      Reachable via address: FE80::2E0:1FF:FE00:18
      Server DUID: 0003000100e001000000
    IA_NA: IAID 0x00000642, T1 50 sec, T2 80 sec
      Address: 1:1::2/128
        Preferred lifetime 100 sec, valid lifetime 200 sec
        Will expire on Feb 4 2014 at 15:37:20(288 seconds left)
    IA_PD: IAID 0x00000642, T1 50 sec, T2 80 sec
      Prefix: 12:34::/48
        Will expire on Mar 27 2014 at 08:13:24 (199 seconds left)
    DNS server addresses:
      2:2::3
    Domain name:
      aaa.example.com
    SIP server addresses:
      2:2::4
    SIP server domain names:
      bbb.example.com
    Options:
      Code: 88
        Length: 3 bytes
        Hex: AABBCC
表1-6 display ipv6 dhcp client命令显示信息描述表
DHCPv6客户端类型,取值包括:
·     Stateful client requesting address:表示获取IPv6地址的DHCPv6客户端
·     Stateful client requesting prefix:表示获取IPv6前缀的DHCPv6客户端
·     Stateful client requesting address and prefix:表示同时获取IPv6地址和IPv6前缀的DHCPv6客户端
·     Stateless client:表示无状态DHCPv6客户端
客户端的当前状态,取值包括:
·     IDLE:闲置状态
·     SOLICIT:正在定位服务器
·     REQUEST:正在申请租约
·     OPEN:申请成功
·     RENEW:正在申请更新租约(租约T1时间之后,T2时间之前)
·     REBIND:正在申请更新租约(租约T2时间之后,过期之前)
·     RELEASE:正在申请释放租约
·     DECLINE:检测到地址冲突,正在申请禁用该地址
·     INFO-REQUESTING:正在无状态获取配置信息
Client DUID
客户端的DUID
Preferred server
DHCPv6客户端选用的DHCPv6服务器的信息
可达地址,服务器或中继的链路本地地址
Server DUID
服务器的DUID
IA_NA
申请到的IA_NA信息
IA_PD
申请到的IA_PD信息
IAID
IA标识符
T1
租约的T1生命期,单位为秒
T2
租约的T2生命期,单位为秒
Address
申请到的地址,只有客户端类型为Stateful client requesting address时,显示该信息
Prefix
申请到的前缀,只有客户端类型为Stateful client requesting prefix时,显示该信息
Preferred lifetime
租约的首选生命期,单位为秒
valid lifetime
租约的有效生命期,单位为秒
将在2014年2月4日15点37分20秒过期(还有288秒)。如果租约过期时间在2100年以后,则显示为Will expire after 2100
申请到的DNS服务器地址
Domain name
申请到的域名后缀
申请到的SIP服务器地址
申请到的SIP服务器域名
Options
申请到的自定义选项
Code
自定义选项编码
Length
自定义选项长度,单位为字节
Hex
自定义选项内容,以十六进制数表示
·     ipv6 address dhcp-alloc
·     ipv6 dhcp client duid
·     ipv6 dhcp client pd
display ipv6 dhcp client statistics命令用来显示DHCPv6客户端的统计信息。
display ipv6 dhcp client statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上DHCPv6客户端的统计信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有DHCPv6客户端的统计信息。
# 显示接口Ten-GigabitEthernet2/0/0上DHCPv6客户端的统计信息。
<Sysname> display ipv6 dhcp client statistics interface ten-gigabitethernet 2/0/0
Interface                     :  Ten-GigabitEthernet2/0/0
         Reply                :  1
         Advertise            :  0
         Reconfigure         :   0
         Invalid              :  0
Packets sent                  :  5
         Solicit              :  0
         Request              :  0
         Renew                :  0
         Rebind               :  0
         Information-request  :  5
         Release              :  0
         Decline              :  0
表1-7 display ipv6 dhcp client statistics命令显示信息描述表
DHCPv6客户端所在的接口
Packets received
收到的报文数目
Reply
收到Reply报文的数目
Advertise
收到Advertise报文的数目
Reconfigure
收到Reconfigure报文的数目
Invalid
无效报文的数目
Packets sent
已发送报文的数目
Solicit
已发送Solicit报文的数目
Request
已发送Request报文的数目
Renew
已发送Renew报文的数目
Rebind
已发送Rebind报文的数目
Information-request
已发送Information-request报文的数目
Release
已发送Release报文的数目
Decline
已发送Decline报文的数目
·     reset ipv6 dhcp client statistics
ipv6 address dhcp-alloc命令用来配置接口作为DHCPv6客户端,通过DHCPv6方式获取IPv6地址和其他网络配置参数。
undo ipv6 address dhcp-alloc命令用来取消接口作为DHCPv6客户端,并删除通过DHCPv6获取到的IPv6地址和其他网络配置参数。
ipv6 address dhcp-alloc [ option-group option-group-number | rapid-commit ] *
接口不会作为DHCPv6客户端获取IPv6地址和其他网络配置参数。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VLAN接口视图
FlexE业务接口视图
option-group option-group-number:指定DHCPv6选项组编号。option-group-number表示DHCPv6选项组编号,取值范围为1~100。如果指定了本参数,则DHCPv6客户端获取到DHCPv6选项后,将自动创建指定编号的DHCPv6选项组,并将获取到的DHCPv6选项保存在该DHCPv6选项组中。如果未指定本参数,则不会自动创建DHCPv6选项组。
rapid-commit:配置客户端支持地址快速分配功能。如果未指定该参数,表示该客户端不支持地址快速分配功能。
# 配置接口Ten-GigabitEthernet2/0/0作为DHCPv6客户端,通过DHCPv6方式获取IPv6地址和其他网络配置参数,指定客户端支持地址快速分配功能,并指定获取到网络配置参数时,创建DHCPv6选项组1,并将获取的参数保存在该选项组中。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 address dhcp-alloc rapid-commit option-group 1
·     display ipv6 dhcp client
ipv6 dhcp client dscp命令用来配置DHCPv6客户端发送的DHCPv6报文的DSCP优先级。
undo ipv6 dhcp client dscp命令用来恢复缺省情况。
ipv6 dhcp client dscp dscp-value
dscp-value:DHCPv6报文的DSCP优先级,取值范围为0~63。
DSCP携带在DHCPv6报文中的Traffic class字段,用来体现报文自身的优先等级,决定报文传输的优先程度。配置的DSCP优先级的取值越大,报文的优先级越高。
# 配置DHCPv6客户端发送的DHCPv6报文的DSCP优先级为30。
[Sysname] ipv6 dhcp client dscp 30
ipv6 dhcp client duid命令用来配置接口使用指定的DHCPv6客户端DUID。
undo ipv6 dhcp client duid命令用来恢复缺省情况。
ipv6 dhcp client duid { ascii ascii-string | hex hex-string | mac interface-type interface-number }
根据设备的桥MAC地址生成DHCPv6客户端DUID。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VLAN接口视图
FlexE业务接口视图
ascii ascii-string:使用指定的ASCII字符串作为该接口的DHCPv6客户端DUID,为1~130个字符的字符串,区分大小写。
hex hex-string:使用指定的十六进制数作为该接口的DHCPv6客户端DUID,为2~260个字符的字符串。
mac interface-type interface-number:使用指定接口的MAC地址作为该接口的DHCPv6客户端DUID,interface-type interface-number表示接口类型和接口编号。
DHCPv6客户端DUID用来填充DHCPv6报文的Option 1,作为识别DHCPv6客户端的唯一标识。DHCPv6服务器可以根据DHCPv6客户端DUID为特定的DHCPv6客户端分配特定的IPv6地址。用户需保证不同DHCPv6客户端的DUID不会相同。
# 配置接口Ten-GigabitEthernet2/0/0使用的DHCPv6客户端DUID为接口Ten-GigabitEthernet2/0/1的MAC地址。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp client duid mac ten-gigabitethernet 2/0/1
ipv6 dhcp client pd命令用来配置接口作为DHCPv6客户端,通过DHCPv6方式获取IPv6前缀和其他网络配置参数。
undo ipv6 dhcp client pd命令用来取消接口作为DHCPv6客户端,并删除通过DHCPv6获取到的IPv6前缀和其他网络配置参数。
ipv6 dhcp client pd prefix-number [ option-group option-group-number | rapid-commit ]*
接口不会作为DHCPv6客户端,通过DHCPv6方式获取IPv6前缀和其他网络配置参数。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
三层RPR逻辑接口视图
VLAN接口视图
FlexE业务接口视图
prefix-number:IPv6前缀编号,取值范围为1~1024。DHCPv6客户端获取到IPv6前缀后,将动态创建指定编号的IPv6前缀,该前缀编号对应的IPv6前缀为DHCPv6客户端获取到的前缀。
rapid-commit:指定客户端支持前缀快速分配功能。未指定该参数时,表示不支持前缀快速分配功能。
# 配置接口Ten-GigabitEthernet2/0/0作为DHCPv6客户端,通过DHCPv6方式获取IPv6前缀和其他网络配置参数;指定获取到IPv6前缀后,创建编号为1的IPv6前缀;配置客户端支持前缀快速分配功能;指定获取到网络配置参数时,创建DHCPv6选项组1,并将获取的参数保存在该选项组中。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp client pd 1 rapid-commit option-group 1
ipv6 dhcp client stateful命令用来配置接口作为DHCPv6客户端,通过DHCPv6方式同时获取IPv6地址、IPv6前缀和网络配置参数。
undo ipv6 dhcp client stateful命令用来取消接口作为DHCPv6客户端,通过DHCPv6方式同时获取IPv6地址、IPv6前缀和网络配置参数。
ipv6 dhcp client stateful prefix prefix-number [ option-group option-group-number | rapid-commit ] *
接口不会作为DHCPv6客户端同时获取IPv6地址、IPv6前缀和网络配置参数。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
三层RPR逻辑接口视图
VLAN接口视图
FlexE业务接口视图
prefix prefix-number:IPv6前缀编号,取值范围为1~1024。DHCPv6客户端获取到IPv6前缀后,将动态创建指定编号的IPv6前缀,该前缀编号对应的IPv6前缀为DHCPv6客户端获取到的前缀。
ipv6 dhcp client stateful命令优先于ipv6 address dhcp-allocipv6 dhcp client pd命令:
·     接口上同时配置以上三个命令时,接口上只会生效ipv6 dhcp client stateful命令运行状态机去同时申请IPv6地址和前缀。
·     接口上同时存在以上三个命令时,如果执行undo ipv6 dhcp client stateful命令,则会生效接口上另外两条命令,分别去申请IPv6地址和IPv6前缀。
# 配置接口Ten-GigabitEthernet2/0/0作为DHCPv6客户端,通过DHCPv6方式获取IPv6地址、IPv6前缀和其他网络配置参数;指定获取到IPv6前缀后,创建编号为1的IPv6前缀;指定客户端支持快速分配功能;指定获取到网络配置参数时,创建DHCPv6选项组1,并将获取的参数保存在该选项组中。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp client stateful prefix 1 rapid-commit option-group 1
ipv6 dhcp client stateless enable命令用来开启DHCPv6客户端无状态配置功能。
undo ipv6 dhcp client stateless enable命令用来关闭DHCPv6客户端无状态配置功能。
DHCPv6客户端无状态配置功能处于关闭状态。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
三层RPR逻辑接口视图
VLAN接口视图
FlexE业务接口视图
接口开启无状态配置功能后发送information request报文申请配置信息。
# 在接口Ten-GigabitEthernet2/0/0上开启DHCPv6客户端无状态配置功能。
[Sysname-Ten-GigabitEthernet2/0/0] ipv6 dhcp client stateless enable
reset ipv6 dhcp client statistics命令用来清除DHCPv6客户端的统计信息。
reset ipv6 dhcp client statistics [ interface interface-type interface-number ]
interface interface-type interface-number:清除指定接口上DHCPv6客户端的统计信息。其中,interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有DHCPv6客户端的统计信息。
# 清除所有DHCPv6客户端的统计信息。
<Sysname> reset ipv6 dhcp client statistics
·     display ipv6 dhcp client statistics
