15-BRAS业务命令参考
09-L2TP命令
本章节下载: 09-L2TP命令  (633.23 KB)
09-L2TP命令
1 L2TP
1.1 L2TP配置命令
1.1.1 allow l2tp
1.1.2 bandwidth
1.1.3 default
1.1.4 default-lac-group enable
1.1.5 description
1.1.6 display interface bas-interface
1.1.7 display interface virtual-ppp
1.1.8 display l2tp aging
1.1.9 display l2tp control-packet statistics
1.1.10 display l2tp packet-limit configuration
1.1.11 display l2tp packet-limit statistics
1.1.12 display l2tp session
1.1.13 display l2tp session temporary
1.1.14 display l2tp statistics
1.1.15 display l2tp tunnel
1.1.16 display l2tp-group
1.1.17 interface virtual-ppp
1.1.18 ip dscp
1.1.19 l2tp aging
1.1.20 l2tp calling-number-avp encapsulate-format version1
1.1.21 l2tp enable
1.1.22 l2tp icrq-limit
1.1.23 l2tp lns calling-number-avp parse-vlan-format ascii
1.1.24 l2tp sccrq-limit
1.1.25 l2tp session-threshold
1.1.26 l2tp tsa-id
1.1.27 l2tp tunnel-id
1.1.28 l2tp-auto-client
1.1.29 l2tp-group
1.1.30 lns-ip
1.1.31 mandatory-chap
1.1.32 mandatory-lcp
1.1.33 mtu
1.1.34 reset counters interface virtual-ppp
1.1.35 reset l2tp aging
1.1.36 reset l2tp control-packet statistics
1.1.37 reset l2tp packet-limit statistics
1.1.38 reset l2tp statistics
1.1.39 reset l2tp tunnel
1.1.40 shutdown
1.1.41 snmp-agent trap enable l2tp
1.1.42 source-ip
1.1.43 tunnel authentication
1.1.44 tunnel avp-hidden
1.1.45 tunnel load-sharing
1.1.46 tunnel name
1.1.47 tunnel password
1.1.48 tunnel timer hello
1.1.49 tunnel window receive
1.1.50 tunnel window send
1.1.51 tunnel-alarm enable
1.1.52 tunnel-per-user
1.1.53 timer-hold
1.1.54 timer-hold retry
1.1.55 user
1 L2TP
1.1  L2TP配置命令
1.1.1  allow l2tp
allow l2tp命令用来配置LNS接受来自LAC的L2TP隧道建立请求,并建立L2TP隧道时使用的虚拟模板接口。
undo allow命令用来禁止和LAC上指定域名的用户或不带域名的用户建立会话。
L2TP组1视图下:
allow l2tp virtual-template virtual-template-number [ local ip-address | remote remote-name ] [ domain domain-name ]
undo allow [ domain domain-name ]
非L2TP组1视图下:
allow l2tp virtual-template virtual-template-number { local ip-address | remote remote-name } [ domain domain-name ]
LNS不接受任何LAC的L2TP隧道建立请求。
LNS模式的L2TP组视图
virtual-template virtual-template-number:指定虚拟模板接口。其中,virtual-template-number为虚拟模板接口序号,取值范围为0~1023。LNS根据虚拟模板接口下配置的参数,动态地创建PPP会话。不同的PPP会话用来处理不同L2TP会话上的数据。
local ip-address:指定隧道本端绑定的IP地址。
remote remote-name:指定发起L2TP隧道建立请求的对端(即LAC)。其中,remote-name表示隧道对端的名称,为1~31个字符的字符串,区分大小写。
domain domain-name:指定允许建立L2TP会话的用户域名,domain-name表示用户域名,为1~255个字符的字符串,不区分大小写。用户名中的ISP域信息是通过L2TP会话建立请求中ICCN(Incoming-Call-Connected)报文携带的PPP代理信息传递给LNS端的。NAS-Initiated模式下ICCN报文携带PPP代理信息,该模式下:LNS端在收到LAC端的L2TP会话建立请求时会检查隧道所在L2TP组下是否存在某allow l2tp命令中指定的domain-name与用户名中携带的ISP域相同,如存在则使用该命令的配置建立L2TP会话;如不存在,则继续检查L2TP组下是否存在未指定domain的allow l2tp命令,如存在则使用该命令的配置建立L2TP会话,否则不允许建立L2TP会话。
Client-Initiated模式和LAC-Auto-Initiated模式下ICCN报文不携带PPP代理信息,故LNS端无法获取用户名中的ISP域信息,这两种模式下:LNS端在收到LAC端的L2TP会话建立请求时会检查L2TP组下是否存在未指定domain的allow l2tp命令,如存在则使用该命令的配置建立L2TP会话,否则不允许建立L2TP会话。
本命令需要在LNS设备上执行,用来指定LNS可以接受来自哪些LAC的L2TP隧道建立请求。
在L2TP组1下:
·     如果指定了local,当本端接收到对端的隧道建立请求时,将检查隧道请求报文中的目的端IP地址是否与本参数指定的IP地址相同。当且仅当二者相同时接受对端的隧道建立请求,否则拒绝对端的隧道建立请求。指定隧道本端绑定的IP地址时,需要确保在LAC端指定的LNS端IP地址中至少有一个与本端绑定的IP地址相同。
·     如果指定了remote,当本端接收到对端的隧道建立请求时,将检查隧道请求报文中的LAC端名称是否与本参数指定隧道对端名称相同。当且仅当二者相同时接受对端的隧道建立请求,否则拒绝对端的隧道建立请求。指定隧道对端名称时,需要确保指定的隧道对端名称和LAC端配置的隧道本端名称一致。
·     如果未指定local和remote中任意一个,此时的L2TP组1又称为缺省L2TP组,这种情况下LNS端可以接受任何隧道对端的隧道建立请求。
非L2TP组1下:
·     如果对端发送的隧道请求报文中的目的端IP地址或LAC端名称与本端某个非L2TP组1下配置的本端绑定的IP地址或者对端名称匹配,则LNS端采用该L2TP组下配置的隧道参数(如隧道验证功能等)与该对端建立L2TP隧道。
·     如果对端发送的隧道请求报文中的目的端IP地址和LAC端名称未与本端任何非L2TP组1下配置的本端绑定的IP地址或者对端名称匹配,此时,若存在缺省L2TP组,则LNS端采用缺省L2TP组下配置的隧道参数与该对端建立的L2TP隧道,若不存在缺省L2TP组,则LNS端无法与该对端建立L2TP隧道。
undo allow命令不指定domain参数时,表示禁止和LAC上不带域名的用户建立会话;指定domain参数时,表示禁止和LAC上指定域名的用户建立会话。
如下情况下,建议用户在LNS上配置缺省L2TP组:
·     某些LAC(如采用Windows 2000 beta 2版本的主机)发送的L2TP隧道建立请求中本端名称为空。为了接受这种不知名的对端发起的隧道建立请求,LNS上需要配置缺省L2TP组。
·     LNS与多个LAC建立的L2TP隧道参数相同时,可以通过缺省L2TP组简化配置。
在同一个L2TP组下:
·     如果执行的第一条本命令中指定了remote和domain,则后续执行的所有本命令必须都指定remote并且remote-name必须和执行的第一条命令中指定的remote-name相同。
·     如果执行的第一条本命令中指定了local和domain,则后续执行的所有本命令必须都指定local并且ip-address必须和执行的第一条命令中指定的ip-address相同。
·     (仅适用于L2TP组1)如果执行的第一条本命令中指定了domain,但未指定local和remote中任意一个,则后续执行的所有本命令都不允许指定local或remote。
·     (仅适用于L2TP组1)多次执行指定不同domain-name,但未指定local和remote中任意一个的本命令,多次执行的命令均生效。
·     多次执行不指定domain参数的本命令时,最后一次执行的命令生效。
·     多次执行指定相同domain参数的本命令时,最后一次执行的命令生效。
# 配置LNS接受名称为aaa的对端(LAC)发起的L2TP隧道建立请求,并指定建立L2TP隧道时使用的虚拟模板接口为Virtual-Template2。对于其他名称的对端,LNS接受L2TP隧道建立请求,L2TP隧道建立时使用的虚拟模板接口为Virtual-Template1。
[Sysname] l2tp-group 1 mode lns
[Sysname-l2tp1] allow l2tp virtual-template 1
[Sysname-l2tp1] quit
[Sysname] l2tp-group 2 mode lns
[Sysname-l2tp2] allow l2tp virtual-template 2 remote aaa
·     lns-ip
·     tunnel name
1.1.2  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
虚拟PPP接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
接口的期望带宽会影响链路的开销值。具体介绍请参见“三层技术-IP路由配置指导”中的“OSPF”、“OSPFv3”和“IS-IS”。
# 设置虚拟PPP接口10的期望带宽为100kbps。
[Sysname] interface virtual-ppp 10
[Sysname-Virtual-PPP10] bandwidth 100
1.1.3  default
default命令用来恢复虚拟PPP接口的缺省配置。
default
虚拟PPP接口视图
# 将虚拟PPP接口10恢复为缺省配置。
[Sysname-Virtual-PPP10] default
default-lac-group enable命令用来配置当前L2TP组为缺省L2TP组。
undo default-lac-group enable命令用来取消当前L2TP组为缺省L2TP组。
未配置当前L2TP组为缺省L2TP组。
LAC模式的L2TP组视图
配置某L2TP组为缺省L2TP组后,该L2TP组除了具备普通L2TP组的功能外,还具备缺省L2TP组功能。缺省L2TP组功能,是指当某L2TP用户未能匹配到除缺省L2TP组外的其它所有L2TP组时,可以直接使用该缺省L2TP组。
当采用RADIUS服务器授权隧道属性方式建立L2TP隧道时,缺省L2TP组同时具备普通L2TP组功能和缺省L2TP组功能;当采用非RADIUS服务器授权隧道属性方式建立L2TP隧道时,缺省L2TP组不具备缺省L2TP组功能,仅可作为普通L2TP组使用。
当采用RADIUS服务器授权隧道属性方式建立L2TP隧道时:
·     如果RADIUS服务器授权的隧道属性不全,则需要使用本地L2TP组中配置的属性来补全授权信息。通过配置缺省L2TP组,可以确保在未能匹配其它L2TP组的情况下,最后可以使用缺省L2TP组中配置的属性来补全授权信息。
·     如果涉及到的认证域或者授权域较多,为简化配置,避免为不同的域配置不同的L2TP组,通过配置缺省L2TP组,可以使用缺省L2TP组中配置的属性为这些不同域的L2TP用户统一提供需要补全的授权信息。
设备上仅允许配置一个L2TP组为缺省L2TP组。
# 配置当前L2TP组为缺省L2TP组。
[Sysname] l2tp-group 1 mode lac
[Sysname-l2tp1] default-lac-group enable
1.1.5  description
description命令用来设置接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“该接口的接口名 Interface”,比如:Virtual-PPP254 Interface。
虚拟PPP接口视图
text:接口描述信息,为1~255个字符的字符串,区分大小写。
# 配置虚拟PPP接口10的描述信息为“virtual-interface”。
[Sysname-Virtual-PPP10] description virtual-interface
display interface bas-interface命令用来显示BAS接口的相关信息。
display interface [ bas-interface [ interface-number ] ] [ brief [ description | down ] ]
bas-interface [ interface-number ]:显示指定BAS接口的信息。interface-number表示BAS接口的编号。如果不指定bas-interface参数,将显示设备支持的所有接口的相关信息;如果指定bas-interface参数,不指定interface-number参数,将显示所有已创建的BAS接口的相关信息。
brief:显示接口的概要信息。如果未指定本参数,将显示接口的详细信息。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,如果未指定本参数,将仅显示描述信息中的前27个字符,超出部分不显示。
down:显示当前物理状态为down的接口的信息以及down的原因。如果未指定本参数,将不会根据接口物理状态来过滤显示信息。
BAS接口仅在LNS端支持,LAC端不支持。当在LNS端执行allow l2tp命令后,设备将创建相应的BAS接口。
# 显示接口bas-interface0的运行状态和相关信息。
<Sysname> display interface bas-interface 0
Bas-interface0
Interface index: 17803
Current state: UP
Line protocol state: UP
Description: Bas-interface0 Interface
Bandwidth: 1000000 kbps
Hold timer: 10 seconds, retry times: 5
Internet protocol processing: Enabled
Link layer protocol: PPP
Physical: L2TP, baudrate: 1000000 kbps
# 显示bas-interface0接口的概要信息。
<Sysname> display interface bas-interface 0 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
BAS0                 UP   UP       4.1.1.1
# 显示当前物理状态为down的bas-interface接口的信息以及down的原因。
<Sysname> display interface bas-interface brief down
Interface             Link Cause
BAS0                  DOWN Not connected
表1-1 display interface Bas-interface命令显示信息描述表
Interface index
接口索引
Current state
接口当前的物理状态和管理状态,可能的取值及含义如下:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     DOWN:表示数据链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
Hold timer
当前接口发送keepalive报文的周期
retry times
在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路
接口当前可以处理IP报文
链路层封装的协议
Physical
接口的物理类型
baudrate
接口的波特率
最后一次清除接口统计信息的时间(Never表示未清除过接口的统计信息)
三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
Primary IP
接口主IP地址。当显示“--”时,表示接口下还未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为(Not connected:表示没有物理连接(可能没有插网线或者网线故障)
display interface virtual-ppp命令用来显示虚拟PPP接口的相关信息。
display interface [ virtual-ppp [ interface-number ] ] [ brief [ description | down ] ]
virtual-ppp [ interface-number ]:显示指定虚拟PPP接口的信息。interface-number表示虚拟PPP接口的编号,取值范围为0~255。如果不指定virtual-ppp参数,则显示设备支持的所有接口的相关信息。如果指定virtual-ppp参数,不指定interface-number参数,则显示所有已创建的虚拟PPP接口的相关信息。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
description:显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示;指定该参数时,可以显示全部描述信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则显示全部物理状态的接口的显示信息。
# 显示虚拟PPP接口10的详细信息。
<Sysname> display interface virtual-ppp 10
Virtual-PPP10
Interface index: 17805
Line protocol state: DOWN
Description: Virtual-PPP10 Interface
Bandwidth: 100000 kbps
Internet address: 10.0.0.1/24 (primary)
LCP: initial
Physical: L2TP, baudrate: 100000000 bps
Input: 154 packets, 1880 bytes, 0 drops
Output: 155 packets, 1875 bytes, 0 drops
表1-2 display interface virtual-ppp命令显示信息描述表
Interface index
接口索引
Current state
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
·     UP:表示数据链路层协议状态为开启
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
Hold timer
当前接口发送keepalive报文的周期,单位为秒
retry times
接口当前不能处理IP报文
接口的主IP地址
Link layer protocol
链路层封装的协议,取值为PPP
LCP
LCP(Link Control Protocol,链路控制协议)状态
Physical
接口的物理类型,取值为L2TP
baudrate
接口的波特率
当前接口最近300秒内输入报文的平均速率:
·     bytes/sec表示平均每秒输入的字节数
·     bits/sec表示平均每秒输入的比特数
·     packets/sec表示平均每秒输入的包数
当前接口最近300秒内输出报文的平均速率:
·     bytes/sec表示平均每秒输出的字节数
·     bits/sec表示平均每秒输出的比特数
·     packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数, 总计输出的字节,总计丢弃的输出报文数
# 显示虚拟PPP接口10的概要信息。
<Sysname> display interface virtual-ppp 10 brief
VPPP10               ADM  DOWN     10.0.0.1
# 显示所有当前物理状态为down的虚拟PPP接口的信息以及down的原因。
<Sysname> display interface virtual-ppp brief down
VPPP9                ADM  Administratively
VPPP10               ADM  Administratively
VPPP12               ADM  Administratively
# 显示虚拟PPP接口10的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface Virtual-PPP 10 brief description
表1-3 display interface virtual-ppp brief命令显示信息描述表
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
接口名称缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会取该值
Primary IP
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有物理连接(可能没有插网线或者网线故障)
display l2tp aging命令用来显示处于锁定状态的LNS信息。
display l2tp aging
可通过本命令查看LNS锁定的配置信息和锁定的LNS信息。
# 显示LNS锁定信息。
<Sysname> display l2tp aging
LNS IP     Aging(S)   VPN
1.1.1.1    128        Not set
2.2.2.2    200        Not set
表1-4 display l2tp aging命令显示信息描述表
LNS IP
被锁定LNS的IP地址
Aging(S)
剩余锁定时间(单位为秒)
VPN
L2TP隧道对端所属的VPN实例(Not set表示隧道对端属于公网)
·     lns-ip
·     l2tp aging
display l2tp control-packet statistics命令用来显示L2TP协议报文的统计信息。
display l2tp control-packet statistics [ summary | tunnel [ tunnel-id ] ]
summary:显示所有L2TP隧道的L2TP协议报文的汇总统计信息。
tunnel:显示每个L2TP隧道的L2TP协议报文的统计信息。
tunnel-id:L2TP隧道ID,取值范围为1~65535。如果未指定本参数,将显示所有L2TP隧道的L2TP协议报文统计信息。
如果未指定任何参数,将同时显示所有L2TP隧道协议报文的汇总统计信息和单独统计信息。
# 显示所有L2TP隧道协议报文的汇总统计信息和单独统计信息。
<Sysname> display l2tp control-packet statistics
Summary packet statistics:
Recv SCCRQ  : 2           Sent SCCRQ  : 0           Rsnt SCCRQ  : 4
Recv SCCRP  : 0           Sent SCCRP  : 0           Rsnt SCCRP  : 0
Recv SCCCN  : 0           Sent SCCCN  : 0           Rsnt SCCCN  : 0
Recv STOPCCN: 2           Sent STOPCCN: 0           Rsnt STOPCCN: 0
Recv HELLO  : 0           Sent HELLO  : 0           Rsnt HELLO  : 0
Recv ICRQ   : 0           Sent ICRQ   : 0           Rsnt ICRQ   : 0
Recv ICRP   : 0           Sent ICRP   : 0           Rsnt ICRP   : 0
Recv ICCN   : 0           Sent ICCN   : 0           Rsnt ICCN   : 0
Recv CDN    : 0           Sent CDN    : 0           Rsnt CDN    : 0
Tunnel packet statistics: (LocalAddr 1.2.1.1, LocalTID 10567)
Recv SCCRQ  : 1           Sent SCCRQ  : 0           Rsnt SCCRQ  : 2
Recv STOPCCN: 1           Sent STOPCCN: 0           Rsnt STOPCCN: 0
Tunnel packet statistics: (LocalAddr 1.2.1.1, LocalTID 8956)
# 显示每个L2TP隧道的L2TP协议报文的统计信息。
<Sysname> display l2tp control-packet statistics tunnel
# 显示隧道ID为10567的L2TP隧道协议报文的统计信息。
<Sysname> display l2tp control-packet statistics tunnel 10567
表1-5 display l2tp control-packet statistics命令显示信息描述表
LocalAddr
本端L2TP隧道IP地址
LocalTID
本端L2TP隧道ID
Recv SCCRQ
本端已接收的SCCRQ报文数
Recv SCCRP
本端已接收的SCCRP报文数
Recv SCCCN
本端已接收的SCCCN报文数
Recv STOPCCN
本端已接收的STOPCCN报文数
Recv HELLO
本端已接收的HELLO报文数
Recv ICRQ
本端已接收的ICRQ报文数
Recv ICRP
本端已接收的ICRP报文数
Recv ICCN
本端已接收的ICCN报文数
Recv CDN
本端已接收的CDN报文数
Sent SCCRQ
本端已发送的SCCRQ报文数
Sent SCCRP
本端已发送的SCCRP报文数
Sent SCCCN
本端已发送的SCCCN报文数
Sent STOPCCN
本端已发送的STOPCCN报文数
Sent HELLO
本端已发送的HELLO报文数
Sent ICRQ
本端已发送的ICRQ报文数
Sent ICRP
本端已发送的ICRP报文数
Sent ICCN
本端已发送的ICCN报文数
Sent CDN
本端已发送的CDN报文数
Rsnt SCCRQ
本端重传的SCCRQ报文数
Rsnt SCCRP
本端重传的SCCRP报文数
Rsnt SCCCN
本端重传的SCCCN报文数
Rsnt STOPCCN
本端重传的STOPCCN报文数
Rsnt HELLO
本端重传的HELLO报文数
Rsnt ICRQ
本端重传的ICRQ报文数
Rsnt ICRP
本端重传的ICRP报文数
Rsnt ICCN
本端重传的ICCN报文数
Rsnt CDN
本端重传的CDN报文数
·     reset l2tp control-packet statistics
display l2tp packet-limit configuration命令用来显示LNS端报文限速的配置信息。
可通过本命令查看LNS端l2tp sccrq-limit和l2tp icrq-limit命令的配置信息。
# 显示LNS端报文限速的配置信息。
<Sysname> display l2tp packet-limit configuration
ICRQ limit: 1000 packets/sec
SCCRQ limit: 500 packets/sec minlimit: 200 packets/sec
表1-6 display l2tp packet-limit configuration命令显示信息描述表
ICRQ limit
LNS端每秒能处理ICRQ报文的最大数目
SCCRQ limit
LNS端每秒能处理SCCRQ报文的最大数目和最小报文数
·     l2tp icrq-limit
·     l2tp sccrq-limit
display l2tp packet-limit statistics命令用来显示LNS端报文限速的统计信息。
# 显示LNS端报文限速的统计信息。
<Sysname> display l2tp packet-limit statistics
Dropped ICRQ : 0
Dropped SCCRQ: 0
Peak dropped ICRQ : 0
Peak dropped SCCRQ: 0
表1-7 display l2tp packet-limit statistics命令显示信息描述表
Dropped ICRQ
LNS端已丢弃的ICRQ报文数
Dropped SCCRQ
LNS端已丢弃的SCCRQ报文数
Peak dropped ICRQ
ICRQ报文的丢包峰值
Peak dropped SCCRQ
SCCRQ报文的丢包峰值
·     reset l2tp packet-limit statistics
display l2tp session命令用来显示L2TP会话的信息。
display l2tp session [ [ lac | lns ] [ [ local-address local-address | tunnel-id tunnel-id [ session-id session-id ] ] * | remote-address remote-address | username username ] ] [ statistics | verbose ]
lac:显示LAC端的L2TP会话信息。
lns:显示LNS端的L2TP会话信息。
local-address local-address:显示指定本端地址的L2TP会话信息。local-address表示隧道本端IP地址。
tunnel-id tunnel-id:显示指定隧道ID的L2TP会话信息。tunnel-id表示本端隧道ID,取值范围为1~65535。
session-id session-id:显示指定会话ID的L2TP会话信息。session-id表示本端会话ID,取值范围为1~65535。
remote-address remote-address:显示指定隧道对端地址的L2TP会话信息。remote-address表示隧道对端IP地址。
username username:显示指定用户名的L2TP会话信息。username表示用户名,为1~80个字符的字符串,区分大小写。
statistics:显示L2TP会话的统计信息。
verbose:显示L2TP会话的详细信息。
如果未指定statistics和verbose参数,则显示L2TP会话的简要信息。
# 显示L2TP会话的统计信息。
<Sysname> display l2tp session statistics
Total number of sessions: 1
# 显示所有L2TP会话的简要信息。
LocalSID      RemoteSID      LocalTID      State
              Username
89            36245          10878         Established
              user1@d1
表1-8 display l2tp session命令显示信息描述表
L2TP会话总数
LocalSID
本端的会话ID
RemoteSID
对端的会话ID
LocalTID
本端的隧道ID
会话的状态,取值包括:
·     Idle:空闲状态
·     Wait-tunnel:等待建立隧道
·     Wait-reply:等待ICRP报文
·     Wait-connect:等待ICCN报文
·     Established:会话成功建立
Username
PPP用户名(Client-Initiated和LAC-Auto-Initiated两种模式下,该字段无意义,永远显示为N/A)
# 显示隧道ID为45277、会话ID为32502的L2TP会话的详细信息。
<Sysname> display l2tp session tunnel-id 45277 session-id 32502 verbose
Local tunnel ID    : 45277
Local session ID   : 32502
Remote session ID  : 14670
PPP index          : 0xb0dd7ef6800001c1
User name          : N/A
Call serial number : 32502
LIP address        : 32768
Session mode       : LAC
Session state      : Established
Flow control       : Disabled
LAC-Auto-Initiated : Yes
Age flag           : 0
Phy interface      : N/A
Bas interface      : N/A
User trace switch  : Disabled
表1-9 display l2tp session verbose命令显示信息描述表
Local tunnel ID
本端隧道ID
Local session ID
本端会话ID
Remote session ID
对端会话ID
PPP index
PPP索引
User name
Call serial number
L2TP会话的呼叫号码
LIP address
LIP地址(该地址用于系统内部记录L2TP会话所在位置)
Session mode
L2TP会话模式:
·     LAC:表示LAC端的L2TP会话
·     LNS:表示LNS端的L2TP会话
Session state
会话状态,取值包括:
·     Idle:空闲状态
Flow control
(暂不支持)L2TP会话的流控功能的开启状态:
·     Enabled:开启
·     Disabled:关闭
LAC-Auto-Initiated
L2TP隧道是否为LAC-Auto-Initiated模式:
·     Yes:是
·     No:否
Age flag
未协商成功表项老化标识
Phy interface
物理接口,即LNS端隧道报文的入接口(LAC端上该字段无意义,永远显示为N/A)
Bas interface
BAS口(LAC端上该字段无意义,永远显示为N/A)
User trace switch
业务跟踪对象开关的开启状态(即是否通过trace access-user命令用来创建业务跟踪对象):
·     Enabled:开启
·     Disabled:关闭
display l2tp session temporary命令用来显示当前L2TP非稳态会话的信息。
# 显示当前L2TP非稳态会话信息。
<Sysname> display l2tp session temporary
Total number of temporary sessions: 6
LocalSID    RemoteSID    LocalTID     LocalAddress    State
2298        0            19699        20.1.1.2        Wait-tunnel
42805       0            19699        20.1.1.2        Wait-tunnel
17777       0            19699        20.1.1.2        Wait-tunnel
58284       0            19699        20.1.1.2        Wait-tunnel
33256       0            19699        20.1.1.2        Wait-tunnel
8228        0            19699        20.1.1.2        Wait-tunnel
表1-10 display l2tp session temporary命令显示信息描述表
非稳态会话的数目
LocalSID
本端的非稳态会话ID
RemoteSID
对端的非稳态会话ID
LocalTID
本端的隧道ID
LocalAddress
本端隧道的IP地址
非稳态会话的状态,取值包括:
·     Idle:空闲状态
display l2tp statistics命令用来显示L2TP的统计信息。
display l2tp statistics { { all | failure-reason } [ slot slot-number ] }
all:显示L2TP的所有统计信息。
failure-reason:显示L2TP上线失败原因和异常下线原因的统计信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定所有单板。
# 显示L2TP上线失败原因和异常下线原因的统计信息。
<Sysname> display l2tp statistics failure-reason slot 0
L2TP failure reason statistics in slot 0:
  L2TP disabled:                                               1
  Online with RADIUS authorization while configured with VSRP: 0
  Failed to get tunnel source IP:                              0
  Failed to get L2TP group:                                    0
  Tunnel creation failed:                                      0
  Session creation failed:                                     1
  SCCRQ check success but not accept:                          1
  SCCRQ check failed:                                          0
  SCCRP check success but not accept:                          0
  Insufficient resources when process SCCRP:                   0
  SCCRP check failed:                                          0
  SCCRN check success but not accept:                          0
  Insufficient resources when process SCCRN:                   0
  SCCRN check failed:                                          0
  ICRQ check success but not accept:                           0
  ICRQ check failed:                                           0
  ICRP check success but not accept:                           0
  Insufficient resources when process ICRP:                    0
  ICRP check failed:                                           0
  ICCN check success but not accept:                           0
  Insufficient resources when process ICCN:                    0
  ICCN check failed:                                           0
  AVP message check failed:                                    0
  AVP header check failed:                                     0
  Received CDN:                                                1
  Received StopCCN:                                            0
  NS sequence number larger than expected:                     0
  NS sequence number smaller than expected:                    0
  Tunnel ACK timeout:                                          0
  Tunnel keep alive timeout:                                   1
  ICRQ limit exceeded:                                         0
  Packet illegal:                                              0
  Smoothing failed:                                            1
表1-11 display l2tp statistics failure-reason命令显示信息描述表
L2TP disabled
L2TP功能未开启
(暂不支持)配置了VSRP的情况下使用RADIUS授权方式上线
获取L2TP隧道源IP失败
获取L2TP组失败
创建tunnelL2TP隧道失败
创建L2TP会话session失败
检查SCCRQ成功但是不可接受(例如报文中携带的AVP属性不符合要求)
SCCRQ check failed
检查SCCRQ失败
检查SCCRP成功但是不可接受
处理SCCRP时资源不足
SCCRP check failed
检查SCCRP失败
检查SCCRN成功但是不可接受
处理SCCRN时资源不足
SCCRN check failed
检查SCCRN失败
检查ICRQ成功但是不可接受
ICRQ check failed
检查ICRQ失败
检查ICRP成功但是不可接受
处理ICRP时资源不足
ICRP check failed
检查ICRP失败
检查ICCN成功但是不可接受
处理ICCN时资源不足
ICCN check failed
检查ICCN失败
AVP message字段检查失败
AVP头字段检查失败
Received CDN
接收CDN导致下线
Received StopCCN
收到StopCCN导致下线
收到的报文NS序号比期待值大
收到的报文NS序号比期待值小
Tunnel ACK timeout
隧道确认报文超时导致下线
隧道保活定时器超时导致下线
ICRQ limit exceeded
ICRQ报文超过限制
Packet illegal
报文不合法(例如L2TP报文长度不合法)
Smoothing failed
L2TP平滑失败导致掉线下线的统计
·     reset l2tp statistics
display l2tp tunnel命令用来显示L2TP隧道的信息。
display l2tp tunnel [ [ lac | lns ] [ group-name group-name | group-number group-number | [ local-address local-address | tunnel-id tunnel-id ] * | remote-address remote-address | tunnel-name remote-name ] ] [ statistics | verbose ]
lac:显示LAC端的L2TP隧道信息。
lns:显示LNS端的L2TP隧道信息。
group-name group-name:显示指定L2TP组名的L2TP隧道信息。group-name表示L2TP组名,为1~32个字符的字符串,不区分大小写。
group-number group-number:显示指定L2TP组号的L2TP隧道信息。group-number表示L2TP组号,取值范围1~65535。
local-address local-address:显示指定本端IP地址的L2TP隧道信息。local-address表示本端隧道IP地址。
tunnel-id tunnel-id:显示指定本端隧道ID的L2TP隧道信息。tunnel-id表示隧道ID,取值范围1~65535。
remote-address remote-address:显示指定对端IP地址的L2TP隧道信息。remote-address表示对端隧道IP地址。
tunnel-name remote-name:显示指定隧道对端的名称的L2TP隧道信息。remote-name表示隧道对端的名称,为1~31个字符的字符串,区分大小写。
statistics:显示L2TP隧道的统计信息。
verbose:显示L2TP隧道的详细信息。
如果未指定statistics和verbose参数,将显示L2TP隧道的简要信息。
# 显示L2TP隧道的统计信息。
<Sysname> display l2tp tunnel statistics
Total number of tunnels: 1
# 显示所有L2TP隧道的简要信息。
LocalTID  RemoteTID   State         Sessions RemoteAddress    RemotePort
          RemoteName
10878     21          Established   1        20.1.1.2         1701
          lns
表1-12 display l2tp tunnel命令显示信息描述表
隧道的数目
LocalTID
本端的隧道ID
RemoteTID
对端的隧道ID
隧道的状态,取值包括:
·     Idle:空闲状态
·     Wait-reply:等待SCCRP报文
·     Wait-connect:等待SCCCN报文
·     Established:隧道成功建立
·     Stopping:正在下线
Sessions
此隧道上的会话数目
RemoteAddress
对端的IP地址
RemotePort
对端L2TP使用的UDP端口号
RemoteName
隧道对端的名称
# 显示L2TP隧道ID为10878的L2TP隧道的详细信息。
<Sysname> display l2tp tunnel tunnel-id 10878 verbose
Group number          : 1
Group mode            : LNS
Tunnel state          : Established
Tunnel type           : Group
Local tunnel ID       : 10878
Remote tunnel ID      : 28143
Local IP address      : 20.1.1.1
Remote IP address     : 20.1.1.2
Sessions              : 1
Send window size      : 1024
Send win lower-limit  : 5922
Send win upper-limit  : 5921
Recv window size      : 1024
Control message Nr    : 5924
Latest hello packet Ns: 5923
Recv same hello times : 0
Ack timeout times     : 0
Remote framing cap    : Both
Remote bearer cap     : Both
Remote protocol ver   : 1
Remote port           : 1701
Remote tunnel name    : LAC
Remote vendor name    : Sysname
Tunnel auth           : Disabled
Assignment ID         : N/A
表1-13 display l2tp tunnel verbose命令显示信息描述表
Group number
隧道所属L2TP组的组号
Group mode
隧道所属L2TP组的模式,取值包括:
·     LAC:LAC模式,表示设备可以作为L2TP隧道的LAC端向LNS发起隧道建立请求
·     LNS:LNS模式,表示设备可以作为L2TP隧道的LNS端接受来自LAC的隧道建立请求
Tunnel state
隧道的状态,取值包括:
·     Idle:空闲状态
·     Stopping:正在下线
Tunnel type
隧道的创建类型:
·     Group:通过L2TP组的配置来创建隧道
·     Radius:通过RADIUS服务器为LAC下发配置来创建隧道
Disconnection cause
L2TP隧道连接断开的原因(仅在隧道连接被断开时,才显示该字段),取值包括:
·     L2TP fail:协商失败,例如:隧道协商过程中收到错误的报文
·     L2TP cut command:本端清除,如:管理员执行reset l2tp tunnel命令
·     L2TP peer clear:对端触发本端清除,如:收到对端发送的StopCCN报文
·     L2TP no response:对端无响应,如:本端报文重传多次但未收到对端正确的回应报文
·     N/A:其它未知原因导致隧道连接断开
Local tunnel ID
本端的L2TP隧道ID
Remote tunnel ID
对端的L2TP隧道ID
Local IP address
本端隧道IP地址
Remote IP address
对端隧道IP地址
Sessions
此隧道上的会话数目
Send window size
发送窗口大小
发送窗口下限值
发送窗口上限值
Recv window size
接收窗口大小
Control message Nr
期望接收控制报文的序列号
最近一次收到Hello报文的Ns序号
收到相同序号的Hello报文的次数
Ack timeout times
ACK定时器超时次数
Remote framing cap
对端能够支持(接受和要求)的帧类型:
·     Sync:同步
·     Async:异步
·     Both:支持同步异步
该字段仅在LNS端显示
Remote bearer cap
对端设备接口能够通过哪种媒介发送L2TP报文:
·     Digital:数字通道
·     Analog:模拟通道
·     Both:数字、模拟通道
Remote protocol ver
对端L2TP版本号
Remote port
对端使用的端口号
Remote tunnel name
对端隧道名称
Remote vendor name
对端设备描述
Tunnel auth
L2TP隧道验证功能的开启状态:
·     Enabled:开启
·     Disabled:关闭
Assignment ID
AAA下发的Assignment ID,用来标识会话承载在哪条隧道上(N/A表示AAA未下发的Assignment ID)
·     reset l2tp tunnel
display l2tp-group命令用来显示L2TP组的信息。
display l2tp-group [ group-number | group-name group-name ] [ verbose ]
group-number:显示指定组号的L2TP组的信息。group-number表示L2TP组号,取值范围1~65535。
group-name group-name:显示指定组名的L2TP组的信息。group-name表示L2TP组名,为1~32个字符的字符串,不区分大小写。
verbose:显示L2TP组的详细信息。如果未指定本参数,则显示L2TP组的简要信息。
如果未指定任何参数,将显示所有L2TP组的简要信息。
# 显示所有L2TP组的简要信息。
<Sysname> display l2tp-group
Group-Number   Group-Mode     Group-Name   Tunnels    Sessions
1              LNS            group1       2          20
2              LAC            N/A          3          120
3              LAC (default)  N/A          4          60
表1-14 display l2tp-group命令显示信息描述表
Group-Number
L2TP组号
Group-Mode
L2TP组的模式:
·     LAC:LAC模式
·     LAC (default):缺省LAC模式
·     LNS:LNS模式
Group-Name
L2TP组名(N/A表示该L2TP组的组名为空)
Tunnels
L2TP组下的隧道总数
Sessions
L2TP组下的会话总数
# 显示组号为1的L2TP组的详细信息。
<Sysname> display l2tp-group 1 verbose
Group number      : 1
Group name        : lac1
Group mode        : LAC
Tunnels           : 2
Sessions          : 20
Local tunnel name : lac
Tunnel recv window: 1024
Tunnel send window: 0
AVP hidden        : No
Hello interval(s) : 60
IP DSCP           : 0
VPN instance      : N/A
Working mode      : Master-backup
LNS IP            : 190.1.1.5 (weight 1)
                    190.1.1.6 (weight 2)
Source IP         : 0.0.0.0
Tunnel per user   : No
Trigger           : Fullusername (user1)
VSRP source IP    : 0.0.0.0
VSRP instance     : N/A
# 显示组号为2的L2TP组的详细信息。
<Sysname> display l2tp-group 2 verbose
Group number      : 2
Group name        : lns1
Group mode        : LNS
Tunnels           : 2
Sessions          : 20
Local tunnel name : lns
AVP hidden        : No
IP DSCP           : 0
VPN instance      : N/A
Local IP address  : 190.1.1.2
Remote tunnel name: N/A
Mandatory CHAP    : No
Mandatory LCP     : No
表1-15 display l2tp-group verbose命令显示信息描述表
Group number
L2TP组号
Group name
Group mode
L2TP组的模式,取值包括:
Tunnel auth
L2TP隧道验证功能的开启状态:
·     Enabled:开启
·     Disabled:关闭
Local tunnel name
L2TP隧道本端的名称(缺省隧道本端的名称为设备的名称)
Tunnel recv window
L2TP隧道接收窗口的大小
Tunnel send window
L2TP隧道发送窗口的大小
AVP hidden
L2TP隧道是否采用隐藏方式(即密文方式)传输AVP数据:
·     Yes:是
·     No:否
Hello interval(s)
L2TP隧道中Hello报文的发送时间间隔,单位为秒
IP DSCP
L2TP隧道报文的DSCP优先级
Flow control
·     Enabled:开启
·     Disabled:关闭
VPN instance
L2TP隧道对端所属的VPN实例(N/A表示L2TP隧道对端属于公网)
Working mode
LAC的工作模式:
·     Master-backup:主备模式
·     Load-sharing:按权重负载分担模式
LNS IP
在LAC端配置的LNS的IP地址和权重,权重信息仅在负载分担模式下才显示
Source IP
L2TP隧道的源端IP地址,即封装后L2TP隧道报文的源地址
Tunnel per user
是否允许每个L2TP用户单独使用一条L2TP隧道:
·     Yes:允许
·     No:不允许
Trigger
LAC端向LNS端发起隧道建立请求的触发条件,取值包括:
·     Domain (domain-name):指定接入用户的域名与配置的域名匹配时,LAC向LNS发起L2TP隧道建立请求。其中,domain-name表示配置的域名
·     Fullusername (user-name):指定接入用户的用户名与配置的完整用户名匹配时,LAC向LNS发起L2TP隧道建立请求。其中,user-name表示配置的完整用户名
VSRP source IP
(暂不支持)多机备份情况下L2TP隧道的源端地址,即封装后L2TP隧道报文的源地址(若不存在,则显示0.0.0.0)
VSRP instance
(暂不支持)L2TP组关联的多机备份实例(N/A表示该L2TP组未关联多机备份实例)
Local IP address
隧道本端绑定的IP地址(0.0.0.0表示未指定隧道本端绑定的IP地址)
Remote tunnel name
发起L2TP隧道建立请求的隧道对端的名称(N/A表示未指定发起L2TP隧道建立请求的隧道对端的名称)
Mandatory CHAP
是否强制LNS对用户进行CHAP验证:
·     Yes:强制
·     No:未强制
Mandatory LCP
是否强制LNS与用户进行LCP协商:
·     Yes:强制
·     No:未强制
·     l2tp group
interface virtual-ppp命令用来创建虚拟PPP接口,并进入虚拟PPP接口视图。如果虚拟PPP接口已经创建,则该命令用来直接进入虚拟PPP接口视图。
undo interface virtual-ppp命令用来删除虚拟PPP接口。
interface virtual-ppp interface-number
undo interface virtual-ppp interface-number
未配置任何虚拟PPP接口。
interface-number:虚拟PPP接口的编号,取值范围为0~255。
配置LAC-Auto-Initiated模式的L2TP隧道时,需要在LAC端创建虚拟PPP接口。
# 创建虚拟PPP接口10,并进入虚拟PPP接口视图。
1.1.18  ip dscp
ip dscp命令用来配置隧道报文的DSCP(Differentiated Services Code Point,区分服务编码点)优先级。
undo ip dscp命令用来恢复缺省情况。
ip dscp dscp-value
undo ip dscp
隧道报文的DSCP优先级为0。
L2TP组视图
dscp-value:隧道报文的DSCP优先级,取值范围为0~63。
DSCP携带在IP报文中前6个比特的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。通过本命令可以指定发送的L2TP隧道报文中携带的DSCP优先级的取值。
# 配置隧道报文的DSCP优先级为50。
[Sysname-l2tp1] ip dscp 50
1.1.19  l2tp aging
l2tp aging命令用来配置LAC对LNS的锁定时间。
undo l2tp aging命令用来恢复缺省情况。
l2tp aging seconds
undo l2tp aging
LAC对LNS的锁定时间为300秒。
seconds:LAC对LNS的锁定时间,取值范围是1~3600,单位为秒。
当LAC和某个LNS尝试建立L2TP隧道时,如果LAC在一定的时间内无法和该LNS成功建立L2TP隧道,则LAC会将该LNS锁定一段时间。在锁定时间内,LAC不会再尝试和该LNS建立L2TP隧道。当LNS锁定时间超时后,LAC在需要时可以继续尝试和该LNS建立L2TP隧道。
本命令配置后仅对被新锁定的LNS生效,对于已锁定的LNS无影响。
# 配置LAC对LNS的锁定时间为20秒。
[Sysname] l2tp aging 20
·     lns-ip
·     display l2tp aging
·     reset l2tp aging
l2tp calling-number-avp encapsulate-format version1命令用来配置LAC端按照version1格式封装calling-number-avp属性内的信息。
undo l2tp calling-number-avp encapsulate-format version1命令用来恢复缺省情况。
LAC端按照以下格式封装calling-number-avp属性内的信息。
·     按十六进制格式封装MAC地址信息。
·     按字符串格式封装接口信息。
·     按十六进制格式封装VLAN信息。
LAC模式的L2TP组视图
应用场景
在L2TP组网中,calling-number-avp属性由用户MAC地址、LAC设备上用户接入接口和用户所属VLAN组成。LNS端有时需要依据用户的VLAN信息进行用户认证或生成DHCP客户端ID等操作。在与第三方设备的互联中,如果第三方LNS端仅支持以ASCII格式解析收到的calling-number内的VLAN信息,而非十六进制格式,为确保LAC端能够按照LNS端支持的ASCII格式封装VLAN信息,让L2TP用户能够顺利接入网络,必须在LAC上配置本功能。
工作机制
配置本功能后,LAC端在向LNS端发送ICRQ报文时,LAC会将原本以十六进制格式封装的VLAN信息将改为ASCII格式封装,MAC地址和接口的封装格式不变,具体如下:
·     按十六进制格式封装MAC地址信息。
·     按字符串格式封装接口信息。
·     按ASCII格式封装VLAN信息。
配置注意事项
·     在配置本功能按ASCII格式封装VLAN信息前,必须确认LNS端解析VLAN信息的具体格式。只有当LNS端实际以ASCII格式解析VLAN信息时,才需要在LAC端配置本功能。
·     如果用户在LAC侧无实际的VLAN信息(例如,通过主接口上线),此时LAC端将使用数值4096进行VLAN信息的封装。
# 配置LAC按照version1格式封装calling-number-avp属性内的信息。
[Sysname-l2tp1] l2tp calling-number-avp encapsulate-format version1
·     l2tp lns calling-number-avp parse-vlan-format ascii
1.1.21  l2tp enable
l2tp enable命令用来开启L2TP功能。
undo l2tp enable命令用来关闭L2TP功能。
l2tp enable
undo l2tp enable
L2TP功能处于关闭状态。
只有开启该功能后其他L2TP相关配置才能生效。
当L2TP使用的UDP端口号1701被设备上的其他服务占用时,会导致L2TP功能启动失败。用户可使用display udp命令查看设备上UDP端口的使用情况。关于display udp命令的详细介绍,请参见“三层技术-IP业务”中的“IP性能优化”。
# 开启L2TP功能。
[Sysname] l2tp enable
l2tp icrq-limit命令用来配置LNS端每秒能处理ICRQ(Incoming Call Request,入呼叫请求)报文的最大数目。
undo l2tp icrq-limit命令用来恢复缺省情况。
l2tp icrq-limit number
未限制设备每秒能处理ICRQ报文的最大数目。
number:LNS端每秒能处理ICRQ报文的最大数目,取值范围为1~60000。
为避免大量L2TP用户的突发上线请求对设备性能造成影响,同时又确保L2TP用户能够平稳上线,可以通过本命令限制设备接收处理ICRQ报文的速率。
# 配置LNS端每秒最多能处理200个ICRQ报文。
[Sysname] l2tp icrq-limit 200
l2tp lns calling-number-avp parse-vlan-format ascii命令用来配置LNS端按照ASCII码格式解析收到的calling-number-avp属性内的VLAN信息。
undo l2tp lns calling-number-avp parse-vlan-format ascii命令用来恢复缺省情况。
LNS端按照十六进制格式解析收到的calling-number-avp属性内的VLAN信息。
应用场景
在L2TP组网中,LNS端有时需要依据用户的VLAN信息进行用户认证或生成DHCP客户端ID等操作。在与第三方设备的互联中,如果第三方LAC端仅支持以ASCII格式发送calling-number-avp属性内的VLAN信息,而非十六进制格式,为确保LNS能够正确解析ASCII格式的VLAN信息,让L2TP用户能够顺利接入网络,必须在LNS上配置本功能。
工作机制
配置本功能后,当LNS端从LAC端收到ICRQ报文时,将按照ASCII格式解析收到的ICRQ报文中calling-number-avp属性内的VLAN信息。
配置注意事项
·     在配置ASCII格式解析前,必须确认LAC端发送VLAN信息的具体格式。只有当LAC实际以ASCII格式发送VLAN信息时,才需要配置本功能。
·     执行本命令修改解析格式会影响LNS端发送给AAA服务器的报文中某些属性的值,比如NAS-PORT-ID。如果AAA服务器基于这些属性的值部署了策略(例如认证、计费等),那么修改LNS的解析格式后,需要同步修改AAA服务器上的配置,否则可能会出现认证失败或计费错误等问题。
# 配置LNS端按照ASCII码格式解析calling-number-avp属性内的VLAN信息。
[Sysname] l2tp lns calling-number-avp parse-vlan-format ascii
·     l2tp calling-number-avp encapsulate-format version1
l2tp sccrq-limit命令用来配置LNS端每秒能处理SCCRQ(Start Control Connection Request,开始连接请求)报文的最大和最小数目。
undo l2tp sccrq-limit命令用来恢复缺省情况。
l2tp sccrq-limit max-number [ minimum min-number ]
未限制每秒能处理SCCRQ报文的最大和最小数目。
max-number:LNS端每秒能处理SCCRQ报文的最大数目,取值范围为1~10000。max-number值要大于等于min-number值。
minimum min-number:LNS端每秒能处理SCCRQ报文的最小数目,取值范围为1~10000,缺省值为1。
在多个LAC设备接入同一个LNS设备的组网环境中,多个LAC设备可能会同时发起L2TP隧道建立请求,并且每个隧道中又会发送大量的会话建立请求,此时:
·     如果max-number过大,会对LNS设备性能造成影响,大量请求报文因不能得到及时处理导致用户无法正常上线。
·     如果min-number过小,大量超限请求报文因不能得到及时处理导致用户无法正常上线。
为了避免上述情况对LNS设备性能造成影响,同时又确保L2TP用户能够平稳上线,请根据实际需要合理配置LNS端每秒能处理SCCRQ报文的最大和最小数目。
本命令配置后,设备会采用一定的算法把每秒能处理SCCRQ报文的最大数目从min-number逐渐增大到max-number,而非立即按配置的最大值max-number进行限速。故在设备每秒能处理SCCRQ报文的最大数目从min-number增大到max-number之前,即使某时刻收到的SCCRQ报文数小于max-number,也可能存在SCCRQ报文被丢弃的情况。
多次执行本命令,最后一次执行的命令生效。
# 配置LNS端每秒最多能处理500个SCCRQ报文,最少可以处理200个SCCRQ报文。
[Sysname] l2tp sccrq-limit 500 minimum 200
l2tp session-threshold命令用来配置整机上线L2TP会话数目的告警阈值。
undo l2tp session-threshold命令用来恢复缺省情况。
l2tp session-threshold { lower-limit lower-limit-value | upper-limit upper-limit-value }
undo l2tp session-threshold { lower-limit | upper-limit }
整机上线L2TP会话数目的上限告警阈值为100,下限告警阈值为0。
lower-limit lower-limit-value:下限告警阈值。lower-limit-value表示允许上线的L2TP会话的最大数目的百分比,取值范围为0~99。
upper-limit upper-limit-value:上限告警阈值。upper-limit-value表示允许上线的L2TP会话的最大数目的百分比,取值范围为1~100。
整机上线L2TP会话数目,是指整个设备上线的所有L2TP会话总数目。
可通过本命令分别配置L2TP会话数的上限、下限告警阈值,使得L2TP会话数目大于或小于某个设定值时能够自动触发告警,便于管理员及时了解现网的在线用户情况。管理员可通过display l2tp session statistics命令查看当前在线L2TP会话总数。
假定整机允许上线的L2TP会话的最大数目为a,上限告警阈值为b,下限告警为c,则:
·     当在线L2TP会话数目超过上限a×b或低于下限a×c时,都将打印对应告警信息。
·     当在线L2TP会话数目恢复到正常数值范围后,打印恢复信息。
为避免特殊情况下在线L2TP会话数目在临界区反复变化导致频繁打印告警信息和恢复信息,当在线L2TP会话数目从上限或下限恢复时,系统内部有一个缓冲区,缓冲区大小为在线L2TP会话数目上下限差值的10%,假定为d,d=a×(b-c)÷10,仅当在线L2TP会话数目恢复到小于a×b-d或大于a×c+d时才会打印恢复信息。
例如,假定a为1000,b为80%,c为20%,则d=a×(b-c)÷10=1000×(80%-20%)÷10=1000×60%÷10=600÷10=60,则:
·     当在线L2TP会话数目超过上限a×b=1000×80%=800时,打印上限告警信息。当在线L2TP会话数目恢复到小于a×b-d=800-60=740时,打印恢复信息。
·     当在线L2TP会话数目低于下限a×c=1000×20%=200时,打印下限告警信息。当在线L2TP会话数目恢复到大于a×c+d=200+60=260时,打印恢复信息。
输出的上限告警信息和恢复信息均包含日志信息和Trap告警信息。需要注意的是,为确保Trap告警信息可以正常输出到NMS主机,除了需要正确配置SNMP告警功能外,还需要配置snmp-agent trap enable user-warning-threshold命令。
# 配置整机上线L2TP会话数目的上限告警阈值为允许上线L2TP会话的最大数目的80%。
[Sysname] l2tp session-threshold upper-limit 80
·     snmp-agent trap enable user-warning-threshold(BRAS业务命令参考/UCM)
1.1.26  l2tp tsa-id
l2tp tsa-id命令用来配置LTS设备的TSA ID,并开启LTS设备的L2TP环路检测功能。
undo l2tp tsa-id命令用来恢复缺省情况。
l2tp tsa-id tsa-id
undo l2tp tsa-id
未指定LTS设备的TSA ID,且LTS设备的L2TP环路检测功能处于关闭状态。
tsa-id:LTS设备的唯一标识,为1~64个字符的字符串,区分大小写。
在L2TP隧道交换组网中,LTS通过ICRQ(Incoming Call Request,入呼叫请求)报文中的TSA(Tunnel Switching Aggregator,隧道交换聚合) ID AVP来避免环路。
LTS接收到ICRQ报文后,将报文中携带的所有TSA ID AVP中的TSA ID逐一与本地配置的TSA ID进行比较。如果TSA ID AVP中存在与本地相同的TSA ID,则表示存在环路,LTS立即拆除会话。否则,LTS将自己的TSA ID封装到新的TSA ID AVP中,LTS向它的下一跳LTS发送ICRQ报文时携带接收到的所有TSA ID AVP及本地封装的TSA ID AVP。
为不同LTS设备配置的TSA ID不能相同,否则会导致环路检测错误。
# 配置LTS设备的TSA ID为lts0,并开启LTS设备的L2TP环路检测功能。
[Sysname] l2tp tsa-id lts0
l2tp tunnel-id命令用来配置L2TP隧道ID的分配范围。
undo l2tp tunnel-id命令用来恢复缺省情况。
l2tp tunnel-id low-id high-id
undo l2tp tunnel-id
L2TP隧道ID的分配范围为1~65535。
low-id:L2TP隧道ID分配范围的下边界值,取值为1~65535。
high-id:L2TP隧道ID分配范围的上边界值,取值为1~65535,并且上边界值不能小于下边界值。
当LAC设备上存在L2TP隧道时,不能修改L2TP隧道ID分配范围。
# 配置上线L2TP隧道ID为1~200。
[Sysname] l2tp tunnel-id 1 200
l2tp-auto-client命令用来触发LAC自动建立L2TP隧道。
undo l2tp-auto-client命令用来拆除LAC自动建立的L2TP隧道。
l2tp-auto-client l2tp-group group-number
LAC不会自动建立L2TP隧道。
虚拟PPP接口视图
l2tp-group group-number:指定LAC采用特定L2TP组下配置的隧道参数建立L2TP隧道。group-number为L2TP组号,取值范围为1~65535。
本命令指定的L2TP组必须已经创建,并且L2TP组的模式必须是LAC,否则本命令配置后不生效。
配置本命令后,会立即触发LAC端建立L2TP隧道,如果L2TP隧道建立失败,但未达到LNS锁定条件,LAC端将周期性向LNS端发起L2TP隧道建立请求,直到L2TP隧道成功建立为止;如果达到LNS锁定条件,L2TP隧道仍未能建立,则LAC会将该LNS锁定一段时间。在锁定时间内,LAC不会再尝试和该LNS建立L2TP隧道。当LNS锁定时间超时后,LAC会重复上述过程,继续尝试和该LNS建立L2TP隧道。
触发LAC建立L2TP隧道后,该隧道将始终存在,直到通过undo l2tp-auto-client或reset l2tp tunnel命令拆除该隧道。
# 触发LAC自动建立L2TP隧道,建立隧道时采用L2TP组10下配置的隧道参数。
[Sysname-Virtual-PPP1] l2tp-auto-client l2tp-group 10
·     l2tp aging
·     l2tp-group
1.1.29  l2tp-group
l2tp-group命令用来创建L2TP组。
undo l2tp-group命令用来删除L2TP组。
l2tp-group group-number [ group-name group-name ] [ mode { lac | lns } ]
undo l2tp-group group-number
未配置任何L2TP组。
group-number:L2TP组号,取值范围为1~65535。
group-name group-name:指定L2TP组名。group-name表示指定的组名,为1~32个字符的字符串,不区分大小写。如果未指定本参数,则创建的L2TP组的组名为空。
mode:指定L2TP组的模式。
lac:LAC模式,表示设备可以作为L2TP隧道的LAC端向LNS发起隧道建立请求。
lns:LNS模式,表示设备可以作为L2TP隧道的LNS端接受来自LAC的隧道建立请求。
通过本命令创建L2TP组时,必须携带mode关键字,指定L2TP组的模式。通过本命令进入已经创建的L2TP组视图时,不需要携带mode关键字。
在L2TP组视图下,可以配置L2TP隧道的参数,如隧道验证功能等。
一台设备上可以同时存在LAC模式和LNS模式的L2TP组。
# 创建L2TP组2,指定组名为g1,指定L2TP组模式为LAC,并进入L2TP组视图。
[Sysname] l2tp-group 2 group-name g1 mode lac
[Sysname-l2tp2]
·     allow l2tp
·     lns-ip
·     user
1.1.30  lns-ip
lns-ip命令用来在LAC端配置LNS的IP地址。
undo lns-ip命令用来在LAC端删除LNS的IP地址。
lns-ip { ip-address [ weight lns-weight ] }&<1-5>
undo lns-ip
未在LAC端指定LNS的IP地址。
LAC模式的L2TP组视图
ip-address:LNS的IP地址。
weight lns-weight:LNS的权重。lns-weight表示权重值,取值范围为1~10,缺省值为5。数值越大,优先级越高。仅在LAC工作在负载分担模式的情况下,本参数配置后才生效。
&<1-5>表示前面的参数最多可以输入5次。
LAC支持主备模式和负载分担模式两种工作模式。
·     在主备模式下,当通过lns-ip命令配置了多个LNS地址时,LAC按照配置的先后顺序依次向各LNS尝试建立隧道,直到和某个LNS成功建立隧道。和LAC成功建立隧道的LNS称作主用LNS,其余LNS称作备用LNS,只有当主用LNS故障时,LAC才会选择备用LNS尝试建立隧道。
·     在负载分担模式下,当通过lns-ip命令配置了多个LNS地址时,LAC按照LNS的权重将L2TP业务分配到对应的LNS上。
如果在同一个L2TP组下多次执行本命令,最后一次执行的命令生效。
# 在LAC端配置LNS的IP地址为202.1.1.1。
[Sysname-l2tp1] lns-ip 202.1.1.1
·     tunnel load-sharing
mandatory-chap命令用来强制LNS对用户进行CHAP验证。
undo mandatory-chap命令用来恢复缺省情况。
mandatory-chap
undo mandatory-chap
LNS不会对用户进行CHAP验证。
LNS模式的L2TP组视图
缺省情况下,LAC代替LNS对用户进行验证,并将用户的所有验证信息及LAC端本身配置的验证方式发送给LNS。LNS根据接收到的信息及LNS端配置的验证方式,判断用户是否合法。
为了增加安全性,可以执行mandatory-chap命令,强制在LAC代理验证成功后,LNS再次对用户进行CHAP验证。
执行mandatory-chap命令配置强制CHAP验证后,对于NAS-Initiated模式L2TP隧道的用户来说,会经过两次验证:一次是在NAS端的验证,另一次是在LNS端的验证。一些用户可能不支持进行第二次验证,这时,LNS端的CHAP验证会失败。在这种情况下,建议不要开启LNS的强制CHAP验证功能。
本命令只对NAS-Initiated模式的L2TP隧道有效,对Client-Initiated模式和LAC-Auto-Initiated模式的L2TP隧道无效。
mandatory-lcp命令的优先级高于本命令,即如果在L2TP组下同时执行了mandatory-chap命令和mandatory-lcp命令,则LNS与用户进行LCP协商。
# 强制LNS对用户进行CHAP验证。
[Sysname-l2tp1] mandatory-chap
·     mandatory-lcp
mandatory-lcp命令用来强制LNS与用户进行LCP(Link Control Protocol,链路控制协议)协商。
undo mandatory-lcp命令用来恢复缺省情况。
mandatory-lcp
undo mandatory-lcp
LNS不会与用户进行LCP协商。
LNS模式的L2TP组视图
缺省情况下,对于NAS-Initialized模式的L2TP隧道,用户先和LAC进行LCP协商。如果协商通过,则由LAC发起L2TP隧道建立请求,并把与用户协商时收集到的信息(包括验证信息)发送给LNS。LNS根据接收到的信息判断用户是否合法。LNS不会与用户进行LCP协商。
LAC与用户协商出来的LCP参数可能不是LNS期望的参数。此时,需要在LNS上执行mandatory-lcp命令,强制LNS与用户进行LCP协商,忽略LAC发送的信息。
如果一些PPP用户不支持LCP协商,则LCP协商过程会失败。在这种情况下,建议不要开启LNS的强制LCP重协商功能。
本命令只对NAS-Initiated模式的L2TP隧道有效,对Client-Initiated模式和LAC-Auto-Initiated模式的隧道无效。
本命令的优先级高于mandatory-chap命令,即如果在L2TP组下同时执行了mandatory-chap命令和mandatory-lcp命令,则LNS与用户进行LCP协商。
# 强制LNS与用户进行LCP协商。
[Sysname-l2tp1] mandatory-lcp
·     mandatory-chap
1.1.33  mtu
mtu命令用来配置接口的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
虚拟PPP接口的MTU值为1500字节。
虚拟PPP接口视图
接口的MTU值影响IP协议报文在该接口上传输时的分片与重组。
需要注意的是,配置了mtu命令后需要执行命令shutdown和undo shutdown,这样该配置才能在接口上生效。
# 配置虚拟PPP接口10的MTU值为1400字节。
[Sysname-Virtual-PPP10] mtu 1400
reset counters interface virtual-ppp命令用来清除虚拟PPP接口的统计信息。
reset counters interface [ virtual-ppp [ interface-number ] ]
virtual-ppp [ interface-number ]:虚拟PPP接口的编号,取值范围为0~255。如果不指定virtual-ppp和interface-number,则清除所有接口的统计信息;如果指定virtual-ppp而不指定interface-number,则清除所有虚拟PPP接口的统计信息;如果同时指定virtual-ppp和interface-number,则清除指定虚拟PPP接口的统计信息。
# 清除虚拟PPP接口10的统计信息。
<Sysname> reset counters interface virtual-ppp 10
reset l2tp aging命令用来解除LNS的锁定状态。
reset l2tp aging [ ip-address ]
ip-address:解除指定IP地址的LNS的锁定状态。如果未指定该参数,将解除所有LNS的锁定状态。
缺省情况下,LNS一旦达到锁定条件被置于锁定状态,则只能等待锁定时间超时而释放,才能解除锁定;在锁定期内LAC不再尝试和该LNS建立L2TP隧道。
通过执行本命令可以手动解除LNS的锁定状态,LNS锁定状态解除后,当LAC需要建立L2TP隧道时,依然可以尝试和该LNS建立L2TP隧道。
# 解除IP为1.1.1.2的LNS的锁定状态。
<Sysname> reset l2tp aging 1.1.1.2
·     l2tp aging
reset l2tp control-packet statistics命令用来清除L2TP协议报文的统计信息。
reset l2tp control-packet statistics [ summary | tunnel [ tunnel-id ] ]
summary:清除所有L2TP隧道协议报文的汇总统计信息。
tunnel:清除每个L2TP隧道的L2TP协议报文的统计信息。
tunnel-id:L2TP隧道ID,取值范围为1~65535。如果未指定本参数,将清除所有L2TP隧道的L2TP协议报文统计信息。
如果未指定任何参数,将同时清除所有L2TP隧道协议报文的汇总统计信息和单独统计信息。
# 清除所有L2TP隧道协议报文的汇总统计信息和单独统计信息。
<Sysname> reset l2tp control-packet statistics
·     display l2tp control-packet statistics
reset l2tp packet-limit statistics命令用来清除LNS端报文限速的统计信息。
# 清除LNS端报文限速的统计信息。
<Sysname> reset l2tp packet-limit statistics
·     display l2tp packet-limit statistics
reset l2tp statistics命令用来清除L2TP的统计信息。
reset l2tp statistics { { all | failure-reason } [ slot slot-number ] }
all:清除L2TP的所有统计信息。
# 清除L2TP的所有统计信息。
<Sysname> reset l2tp statistics all
·     display l2tp statistics
reset l2tp tunnel命令用来断开L2TP隧道,同时断开该隧道内的所有会话。
reset l2tp tunnel [ [ local-address local-address | tunnel-id tunnel-id ] * | tunnel-name remote-name ]
local-address local-address:断开本端IP地址为指定值的L2TP隧道。local-address表示本端隧道IP地址。
tunnel-id tunnel-id:断开隧道ID为指定值的L2TP隧道。tunnel-id为隧道ID,取值范围为1~65535。
tunnel-name remote-name:断开与指定隧道对端之间的L2TP隧道。remote-name表示隧道对端的名称,为1~31个字符的字符串,区分大小写。
在用户数为零、网络发生故障等情况下,可以通过本命令强制断开指定的L2TP隧道。LAC和LNS任何一端都可主动发起断开L2TP隧道的请求。隧道断开后,该隧道上的所有L2TP会话也将被清除。
强制断开一个L2TP隧道后,当对端用户再次呼入时,隧道可以重新建立。
通过指定隧道的对端名称来确定需要断开的L2TP隧道时,如果没有符合条件的L2TP隧道存在,则对当前的L2TP隧道没有影响;如果有多个符合条件的L2TP隧道存在(同一个名称,不同IP地址),则断开所有符合条件的L2TP隧道。
如果未指定任何参数,则断开本设备上所有的L2TP隧道。
# 断开对端名称为aaa的L2TP隧道,并断开该隧道内的所有会话。
<Sysname> reset l2tp tunnel tunnel-name aaa
·     display l2tp tunnel
1.1.40  shutdown
shutdown命令用来关闭接口。
undo shutdown命令用来打开接口。
shutdown
接口处于打开状态。
虚拟PPP接口视图
执行本命令关闭接口会导致基于当前接口的L2TP功能不可用。建议您在执行该命令前,完全了解其对网络产生的影响。
# 关闭虚拟PPP接口10。
[Sysname-Virtual-PPP10] shutdown
snmp-agent trap enable l2tp命令用来开启添加L2TP会话失败的Trap告警功能。
undo snmp-agent trap enable l2tp命令用来关闭添加L2TP会话失败的Trap告警功能。
snmp-agent trap enable l2tp [ add-session-failed ]
undo snmp-agent trap enable l2tp [ add-session-failed ]
添加L2TP会话失败的Trap告警功能处于关闭状态。
add-session-failed:开启添加L2TP会话失败的Trap告警功能。
开启添加L2TP会话失败的Trap告警功能后,当设备添加L2TP会话失败(例如:已有L2TP会话数达到设备允许的最大值时,将无法创建新的L2TP会话)时将会生成Trap告警信息。生成的Trap告警信息将被送到设备的SNMP模块,通过设置SNMP中的Trap告警信息的发送参数,来决定Trap告警信息输出的相关属性。有关Trap告警的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
配置本命令时,snmp-agent trap enable l2tp命令与snmp-agent trap enable l2tp add-session-failed命令的配置效果相同,都是开启添加L2TP会话失败的Trap告警功能。
# 开启添加L2TP会话失败的Trap告警功能。
[Sysname] snmp-agent trap enable l2tp add-session-failed
1.1.42  source-ip
source-ip命令用来设置L2TP隧道的源端地址,即封装后L2TP隧道报文的源地址。
undo source-ip命令用来恢复缺省情况。
source-ip ip-address
undo source-ip
L2TP隧道的源端地址为本端隧道出接口的IP地址。
LAC模式的L2TP组视图
ip-address:L2TP隧道的源端IP地址。
建议将L2TP隧道的源端地址配置为设备上某LoopBack接口的IP地址,以减小物理接口故障对L2TP业务造成的影响。
# 设置L2TP隧道的源端地址为2.2.2.2。
[Sysname-l2tp1] source-ip 2.2.2.2
tunnel authentication命令用来开启L2TP隧道验证功能。
undo tunnel authentication命令用来关闭L2TP隧道验证功能。
L2TP隧道验证功能处于开启状态。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
L2TP隧道验证功能用来防止本端设备与非法的对端设备建立L2TP隧道,提高网络的安全性。
如果LAC和LNS两端都开启了隧道验证功能,则两端密钥(通过tunnel password命令配置)不为空并且完全一致的情况下,二者之间才能成功建立L2TP隧道。
如果LAC和LNS中的一端开启了隧道验证功能,则另一端可不开启隧道验证功能,但需要两端密钥(通过tunnel password命令配置)不为空并且完全一致,二者之间才能成功建立L2TP隧道。
如果LAC和LNS两端都禁用隧道验证功能,则无论两端是否配置密钥、密钥是否相同,都不影响隧道建立。
为了保证隧道安全,建议用户不要禁用隧道验证功能。
# 开启L2TP隧道验证功能。
[Sysname-l2tp1] tunnel authentication
·     tunnel password
tunnel avp-hidden命令用来配置隧道采用隐藏方式(即密文方式)传输AVP数据。
undo tunnel avp-hidden命令用来恢复缺省情况。
tunnel avp-hidden
隧道采用明文方式传输AVP数据。
LAC模式的L2TP组视图
L2TP协议通过AVP(Attribute Value Pair,属性值对)来传输隧道协商参数、会话协商参数和用户认证信息等。如果用户不希望这些信息(如用户密码)被窃取,则可以使用本配置将AVP数据的传输方式配置为隐藏传输,即利用隧道验证密钥(通过tunnel password命令配置)对AVP数据进行加密传输。
目前LNS模式的L2TP组下本命令不会生效。
只有通过tunnel authentication命令开启隧道验证功能后,本命令才会生效。
# 配置AVP数据采用隐藏方式传输。
[Sysname-l2tp1] tunnel avp-hidden
·     tunnel authentication
·     tunnel password
tunnel load-sharing命令用来配置LAC工作在负载分担模式。
undo tunnel load-sharing命令用来恢复缺省情况。
tunnel load-sharing
LAC工作在主备模式。
LAC模式的L2TP组视图
因性能、可靠性等原因,当单个LNS无法满足大量L2TP业务需求时,可配置LAC端工作在负载分担模式,把L2TP业务按权重分配到多个LNS进行处理,权重可通过lns-ip命令的weight参数配置。
# 在配置LAC端工作在负载分担模式。
[Sysname-l2tp1] tunnel load-sharing
·     lns-ip
1.1.46  tunnel name
tunnel name命令用来配置隧道本端的名称。
undo tunnel name命令用来恢复缺省情况。
tunnel name name
undo tunnel name
隧道本端的名称为设备的名称。设备名称的详细介绍,请参见“基础配置指导”中的“设备管理”。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
# 配置隧道本端的名称为lac。
[Sysname-l2tp1] tunnel name lac
·     sysname(基础配置命令参考/设备管理)
tunnel password命令用来配置隧道验证密钥。
undo tunnel password命令用来恢复缺省情况。
tunnel password { cipher | simple } string
未配置隧道验证密钥。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:隧道验证密钥,区分大小写。如果是cipher方式,则string为1~53个字符的密文字符串;如果是simple方式,则string为1~16个字符的明文字符串。
以明文或密文形式设置的密钥,均以密文的方式保存在配置文件中。
如果用户需要修改隧道验证的密钥,请在隧道开始协商前进行,否则修改的密钥不生效。
# 以明文方式配置隧道验证密钥为yougotit。
[Sysname-l2tp1] tunnel password simple yougotit
tunnel timer hello命令用来配置隧道中Hello报文的发送时间间隔。
undo tunnel timer hello命令用来恢复缺省情况。
tunnel timer hello hello-interval
隧道中Hello报文的发送时间间隔为60秒。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
hello-interval:Hello报文的发送时间间隔,取值范围为60~1000,单位为秒。
设备按照本命令配置的时间间隔周期性发送Hello报文,以免LAC和LNS之间的L2TP隧道和会话在超时后被删除。
在LNS和LAC上,可以配置不同的Hello报文发送时间间隔。
# 配置隧道中Hello报文的发送时间间隔为90秒。
[Sysname-l2tp1] tunnel timer hello 90
tunnel window receive命令用来配置L2TP隧道接收窗口的大小。
undo tunnel window receive命令用来恢复缺省情况。
tunnel window receive size
L2TP隧道接收窗口的大小为1024。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
如果乱序报文过多,可以通过调整L2TP接收窗口的大小进行缓解。当出现乱序报文的时候,如果乱序报文NS(L2TP报文中用于标识当前报文序列号的字段)在接收窗范围内,设备会先将报文缓存起来,等待NS等于接收窗下沿的报文到达。当收到NS等于接收窗下沿的报文时,则对其(NS等于接收窗下沿的报文)进行处理,处理完该报文后,接收窗下沿加1;如果此时缓存中存在NS等于接收窗下沿的报文,则继续处理;如不存在,则继续等待NS等于接收窗下沿的报文到达;依次类推。对于超过接收窗范围的报文进行丢弃。
在L2TP隧道建立时,接收窗口大小以L2TP组视图下配置的接收窗口大小为准。隧道建立完成后通过本命令修改L2TP隧道接收窗口的大小对已经建立的隧道接收窗口的大小无影响。
# 配置隧道的接收窗口大小为128。
[Sysname-l2tp1] tunnel window receive 128
·     tunnel window send
tunnel window send命令用来配置L2TP隧道发送窗口的大小。
undo tunnel window send命令用来恢复缺省情况。
tunnel window send size
L2TP隧道发送窗口的大小为0,即本端发送窗口的大小以隧道建立过程中对端携带的接收窗口大小的属性值为准,如果隧道建立过程中对端没有携带接收窗口大小属性,则本端隧道发送窗口的大小为4。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
在某些组网中可能出现对端的报文接收处理能力和对端接收窗口的大小不匹配的情况(例如:对端实际的报文接收处理能力为10,但接收窗口的大小为20),此时可以通过本命令调整本端L2TP隧道发送窗口的大小来适配对端的实际报文接收处理能力,以保证L2TP用户平稳上线。
在L2TP隧道建立时会获取L2TP组视图下配置的发送窗口大小。如果配置的发送窗口大小为0,则按缺省情况处理;如果配置的发送窗口大小非0,则以配置的发送窗口大小为准。隧道建立完成后通过本命令修改L2TP隧道发送窗口的大小对已经建立的隧道发送窗口的大小无影响。
# 配置隧道的发送窗口大小为128。
[Sysname-l2tp1] tunnel window send 128
·     tunnel window receive
tunnel-alarm enable命令用来开启L2TP隧道告警功能。
undo tunnel-alarm enable命令用来关闭L2TP隧道告警功能。
tunnel-alarm enable
L2TP隧道告警功能处于开启状态。
LAC模式的L2TP组视图
LNS模式的L2TP组视图
开启L2TP隧道告警功能后,当L2TP隧道Up/Down时均会输出Trap告警信息。需要注意的是,为确保Trap告警信息可以正常输出到NMS主机,除了开启L2TP隧道告警功能外,还需要正确配置SNMP告警功能。有关SNMP告警功能的介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
当需要新建/拆除大量L2TP隧道时,为避免输出大量Trap告警影响设备性能,建议在新建/拆除L2TP隧道前,关闭L2TP隧道告警功能。
# 开启L2TP隧道告警功能。
[Sysname-l2tp1] tunnel-alarm enable
tunnel-per-user命令用来配置每个L2TP用户单独使用一条L2TP隧道。
undo tunnel-per-user命令用来恢复缺省情况。
tunnel-per-user
同一个L2TP隧道可供多个L2TP用户使用。
LAC模式的L2TP组视图
# 在LAC端配置每L2TP用户单独使用一条L2TP隧道。
[Sysname] l2tp-group 2 mode lac
[Sysname-l2tp2] tunnel-per-user
1.1.53  timer-hold
timer-hold命令用来配置接口发送keepalive报文的周期。
undo timer-hold命令用来恢复缺省情况。
timer-hold seconds
undo timer-hold
接口发送keepalive报文的周期为10秒。
虚拟PPP接口视图
seconds:接口发送keepalive报文的周期,取值范围为0~32767,单位为秒。
虚拟PPP接口定期向对端发送keepalive报文。如果在一段时间内无法收到对端发来的keepalive报文,虚拟PPP接口的链路层会认为对端故障,上报链路层Down。
在速率非常低的链路上,参数seconds不能配置过小。因为在低速链路上,大报文可能会需要很长的时间才能传送完毕,这样就会延迟keepalive报文的发送与接收。而接口如果在retries个(可以通过timer-hold retry命令修改该个数)keepalive周期之后仍然无法收到对端的keepalive报文,它就会认为链路发生故障。如果keepalive报文被延迟的时间超过接口的这个限制,链路就会被认为发生故障而被关闭。
# 配置虚拟PPP接口10发送keepalive报文的周期为20秒。
[Sysname-Virtual-PPP10] timer-hold 20
·     timer-hold retry
timer-hold retry命令用来配置接口在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路。
undo timer-hold retry命令用来恢复缺省情况。
timer-hold retry retries
接口在5个keepalive周期内没有收到keepalive报文的应答就拆除链路。
虚拟PPP接口视图
retries:接口在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路,取值范围为1~255。
在速率非常低的链路上,参数retries不能配置过小。因为在低速链路上,大报文可能会需要很长的时间才能传送完毕,这样就会延迟keepalive报文的发送与接收。而接口如果在retries个keepalive周期之后仍然无法收到对端的keepalive报文,它就会认为链路发生故障。如果keepalive报文被延迟的时间超过接口的这个限制,链路就会被认为发生故障而被关闭。
# 配置虚拟PPP接口10在10个keepalive周期内没有收到keepalive报文的应答就拆除链路。
[Sysname-Virtual-PPP10] timer-hold retry 10
·     timer-hold
1.1.55  user
user命令用来配置本端作为LAC端时向LNS发起隧道建立请求的触发条件。
undo user命令用来恢复缺省情况。
user { domain domain-name | fullusername user-name }
undo user
未指定本端作为LAC端时向LNS发起隧道建立请求的触发条件。
LAC模式的L2TP组视图
domain domain-name:指定接入用户的域名与配置的域名匹配时,LAC向LNS发起L2TP隧道建立请求。domain-name表示配置的域名,为1~255个字符的字符串,不区分大小写。
fullusername user-name:指定接入用户的用户名与配置的完整用户名匹配时,LAC向LNS发起L2TP隧道建立请求。user-name表示配置的完整用户名,为1~255个字符的字符串,区分大小写。
当拨号用户拨入LAC,并认证通过后,LAC按如下原则进行处理:
·     如果拨号用户所属的ISP域下通过l2tp-group命令指定了L2TP组,即认为当前ISP域下用户均L2TP用户。用户认证通过后即向LNS发起隧道建立请求。
·     如果拨号用户所属的ISP域下未通过l2tp-group命令指定L2TP组,则:
¡     先根据拨号用户的用户名与LAC设备上所有L2TP组下配置的完整用户名(fullusername user-name)进行匹配,一旦和某个L2TP组下配置的完整用户名匹配,则使用该L2TP组触发隧道建立请求。
¡     如果拨号用户的用户名与当前LAC设备上所有L2TP组下配置的完整用户名都不匹配,则使用拨号用户所属ISP域的域名与LAC设备上所有L2TP组下配置的域名(domain domain-name)进行匹配,一旦和某个L2TP组下配置的域名匹配,则使用该L2TP组触发隧道建立请求。如果拨号用户所属ISP域的域名与LAC设备上所有L2TP组下配置的域名都不匹配,则该用户无法触发隧道建立请求。
拨号用户所属ISP域的域名按如下原则选择:
·     选择AAA授权的域名。如果AAA授权的域名与LAC设备上所有L2TP组下配置的域名都不匹配,则进入下一步。
·     选择PPP链路认证阶段使用的认证域的域名。有关PPP链路认证阶段使用的认证域的选择原则,请参见“BRAS业务命令参考”中的“PPP”。
¡     如果PPP链路认证阶段使用的认证域的是PPP强制认证域,但PPP强制认证域与LAC设备上所有L2TP组下配置的域名都不匹配时:
-     如果用户名中携带了域名,则继续使用用户名中携带的域名与当前LAC设备上所有L2TP组下配置的域名匹配,一旦和某个L2TP组下配置的域名匹配,则使用该L2TP组触发隧道建立请求。
-     如果用户名携带的域名与当前LAC设备上所有L2TP组下配置的域名都不匹配,则该用户无法触发隧道建立请求。
-     如果用户名中未携带域名,则该用户无法触发隧道建立请求。
¡     如果PPP链路认证阶段使用的认证域的是:户名中携带域、PPP非强制认证域,或AAA模块选择的认证域,则使用选择出的域名与当前LAC设备上所有L2TP组下配置的域名进行匹配:
-     如果选择出的域名与某个L2TP组下配置的域名匹配,则使用该L2TP组触发隧道建立请求。
-     如果选择出的域名与所有L2TP组下配置的域名都不匹配,则该用户无法触发隧道建立请求。
每个L2TP组下指定的domain domain-name或fullusername user-name都必须唯一,即各个L2TP组下指定的触发条件不允许相同。
如果在用户所属的ISP域下配置了l2tp-user radius-force命令,则仅当通过RADIUS服务器给用户授权了64号属性(Tunnel-Type),且隧道类型为L2TP时,LAC才认为该PPP用户为L2TP用户,进行后续的L2TP处理。有关l2tp-user radius-force命令的详细介绍,请参见“BRAS业务命令参考”中的“AAA”。
# 配置接入用户的完整用户名为test@dm1时,触发LAC向LNS发送L2TP隧道建立请求。
[Sysname-l2tp1] user fullusername test@dm1
·     l2tp-user radius-force(BRAS业务命令参考/AAA)
·     ppp authentication-mode(BRAS业务命令参考/PPP)
