02-接口管理命令参考
02-以太网接口命令
本章节下载: 02-以太网接口命令  (827.31 KB)
02-以太网接口命令
1 以太网接口
1.1 以太网接口通用配置命令
1.1.1 bandwidth
1.1.2 dampening
1.1.3 default
1.1.4 description
1.1.5 display counters
1.1.6 display counters rate
1.1.7 display ethernet statistics
1.1.8 display ifindex-constant configuration
1.1.9 display ifindex-constant map
1.1.10 display interface
1.1.11 display interface link-info
1.1.12 display interface main
1.1.13 display interface phy-option
1.1.14 display link-flap protection
1.1.15 display link-state-change statistics interface
1.1.16 display packet-drop
1.1.17 display slot-monitor
1.1.18 display this interface
1.1.19 duplex
1.1.20 flag sdh
1.1.21 flow-control
1.1.22 flow-control receive enable
1.1.23 flow-interval
1.1.24 frame-format
1.1.25 ifindex-constant enable
1.1.26 ifindex-constant max-number
1.1.27 ifmonitor crc-error
1.1.28 ifmonitor giant
1.1.29 ifmonitor input-buffer-drop
1.1.30 ifmonitor input-error
1.1.31 ifmonitor input-usage
1.1.32 ifmonitor output-buffer-drop
1.1.33 ifmonitor output-error
1.1.34 ifmonitor output-usage
1.1.35 ifmonitor runt
1.1.36 interface
1.1.37 jumboframe enable
1.1.38 link-delay
1.1.39 link-flap protect enable
1.1.40 loopback
1.1.41 port fec mode
1.1.42 port ifmonitor crc-error
1.1.43 port ifmonitor giant
1.1.44 port ifmonitor input-buffer-drop
1.1.45 port ifmonitor input-error
1.1.46 port ifmonitor input-usage
1.1.47 port ifmonitor output-buffer-drop
1.1.48 port ifmonitor output-error
1.1.49 port ifmonitor output-usage
1.1.50 port ifmonitor runt
1.1.51 port link-flap protect enable
1.1.52 port link-mode
1.1.53 port-mode
1.1.54 priority-flow-control inner-port
1.1.55 priority-flow-control inner-port no-drop
1.1.56 reset counters interface
1.1.57 reset counters mib interface
1.1.58 reset counters slot
1.1.59 reset ethernet statistics
1.1.60 reset ifindex-constant map
1.1.61 reset link-state-change statistics interface
1.1.62 shutdown
1.1.63 shutdown all-physical-interface
1.1.64 slot-monitor packet-drop
1.1.65 snmp-agent trap enable ifmonitor
1.1.66 snmp-agent trap enable slot-monitor
1.1.67 speed
1.1.68 traffic-statistic include-interframe
1.1.69 using gigabit
1.1.70 using tengige
1.2 三层以太网接口/子接口的配置命令
1.2.1 bridge-forwarding enable
1.2.2 interface virtual-bridge-port
1.2.3 mac-address
1.2.4 mtu
1.2.5 port-type switch
1.2.6 traffic-statistic enable
1 以太网接口
1.1  以太网接口通用配置命令
1.1.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
以太网接口视图
以太网子接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口Ten-GigabitEthernet3/0/1的期望带宽为1000kbps。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] bandwidth 1000
# 设置以太网子接口Ten-GigabitEthernet3/0/1.1的期望带宽为1000kbps。
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] bandwidth 1000
·     speed
1.1.2  dampening
dampening命令用来开启接口的dampening功能。
undo dampening命令用来恢复缺省情况。
undo dampening
接口的dampening功能处于关闭状态。
以太网接口视图
half-life:半衰期,取值范围为1~120,单位为秒,缺省值为54。
reuse:启用值,取值范围为200~20000,缺省值为750,必须要小于suppress的值。
suppress:抑制门限,取值范围为200~20000,缺省值为2000。
max-suppress-time:最大抑制时间,取值范围为1~255,单位为秒,缺省值为半衰期的3倍,即162。
以太网接口上不能同时配置本命令和port link-flap protect enable命令。
本命令对使用shutdown命令手动关闭的接口无效。手工shutdown接口时,dampening的惩罚值恢复为初始值0。
对于使能了MSTP的接口不建议使用该命令。
接口在抑制期发生up事件,通过display interface命令、MIB网管等方式查看时,该接口的状态仍然为down。
# 按照缺省值开启接口Ten-GigabitEthernet3/0/1的dampening功能。
[Sysname-Ten-GigabitEthernet3/0/1] dampening
# 开启接口Ten-GigabitEthernet3/0/1的dampening功能,配置半衰期为2秒,启用值为800,抑制门限为3000,最大抑制时间为5秒。
[Sysname-Ten-GigabitEthernet3/0/1] dampening 2 800 3000 5
·     display interface
·     port link-flap protect enable
1.1.3  default
default命令用来恢复当前接口的缺省配置。
default
以太网接口视图
以太网子接口视图
# 将以太网接口Ten-GigabitEthernet3/0/1恢复为缺省配置。
[Sysname-Ten-GigabitEthernet3/0/1] default
# 将以太网子接口Ten-GigabitEthernet3/0/1.1恢复为缺省配置。
[Sysname-Ten-GigabitEthernet3/0/1.1] default
1.1.4  description
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“接口名 Interface”,例如:Ten-GigabitEthernet3/0/1 Interface。
以太网接口视图
以太网子接口视图
虚拟二层以太网接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 设置以太网接口Ten-GigabitEthernet3/0/1的描述信息为“lan-interface”。
[Sysname-Ten-GigabitEthernet3/0/1] description lan-interface
# 设置以太网子接口Ten-GigabitEthernet3/0/1.1的描述信息为“subinterface3/0/1.1”。
[Sysname-Ten-GigabitEthernet3/0/1.1] description subinterface3/0/1.1
display counters命令用来显示接口的流量统计信息。
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ description ]
inbound:显示输入报文的流量统计信息。
outbound:显示输出报文的流量统计信息。
interface-type:指定接口类型。
interface-number:指定接口编号。
interface-number.subnumber:指定子接口。其中interface-number为主接口编号;subnumber为子接口编号。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示。
可通过命令reset counters interface清除以太网接口的统计信息。
如果不指定interface-type,则显示所有可统计的接口的流量统计信息。
如果指定interface-type而不指定interface-number/interface-number.subnumber,则显示该类型下所有接口的流量统计信息。
如果同时指定interface-type和interface-number/interface-number.subnumber,则显示指定接口/子接口的报文流量统计信息。
# 显示Ten-GigabitEthernet类型接口的报文输入流量统计信息。
<Sysname> display counters inbound interface ten-gigabitethernet
Interface                            Total(pkt) Broadcast(pkt) Multicast(pkt) Err(pkt)
XGE3/0/1                                    100            100              0        0
XGE3/0/2                               Overflow       Overflow       Overflow Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
表1-1 display counters命令显示信息描述表
接口名称缩写
Total(pkt)
接口接收或发送报文的总数(单位为包)
Broadcast(pkt)
接口接收或发送广播报文的总数(单位为包)
Multicast(pkt)
接口接收或发送组播报文的总数(单位为包)
Err (pkts)
接口接收或发送错误报文的总数(单位为包)
用户配置的接口的描述信息
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围:
·     对于Err项,Overflow表示数据的长度超过了7位十进制数
·     对于其它项,Overflow表示数据的长度超过了14位十进制数
--: Not supported.
当某个统计信息的值为“--”时,表示设备不支持该项数据的统计
·     reset counters interface
display counters rate命令用来显示最近一个统计周期内处于up状态的接口的报文速率统计信息。
display counters rate [ inbound | outbound ] interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ description ]
inbound:显示报文接收速率统计信息。
outbound:显示报文发送速率统计信息。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号。
如果不指定inbound和outbound,则显示可统计所有或者指定接口类型中最近一个统计周期内处于up状态的接口接收和发送的报文速率统计信息。
如果不指定interface-type和interface-number,则显示所有可统计的接口类型中最近一个统计周期内处于up状态的接口的报文速率统计信息。
如果指定interface-type而不指定interface-number,则显示该类型下最近一个统计周期内处于up状态接口的报文速率统计信息。
如果同时指定interface-type和interface-number,则显示指定接口在最近一个统计周期内报文速率统计信息。如果该接口在最近一个统计周期内一直处于down状态,则提示接口不支持该操作。
统计周期可以通过flow-interval命令来配置。
# 显示以太网接口Ten-GigabitEthernet3/0/1接收和发送报文速率统计信息。
<Sysname> display counters rate interface ten-gigabitethernet 3/0/1
Usage: Bandwidth utilization in percentage
Interface                          InUsage(%)   InTotal(pps)  OutUsage(%)  OutTotal(pps)
XGE3/0/1                                 0.01           1000         0.01           1000
 Overflow: More than 14 digits.
       --: Not supported.
# 显示Ten-GigabitEthernet类型接口的报文接收速率统计信息。
<Sysname> display counters rate inbound interface ten-gigabitethernet
Interface                          Usage(%)     Total(pps) Broadcast(pps) Multicast(pps)
XGE3/0/1                               0.03            200            100            100
       --: Not supported.
表1-2 display counters rate命令显示信息描述表
接口名称缩写
Usage(%)
在最近一个统计周期内,接口的带宽利用率(单位为百分比)
分为两种计算方式:
·     普通组网中,接口的带宽利用率计算公式为:本地物理接口带宽/本端所有选中接口带宽总和
·     M-LAG组网中,接口的带宽利用率计算公式为:本端物理接口带宽/(本端所有选中接口带宽+对端所有选中接口带宽)
Total(pps)
在最近一个统计周期内,接口接收或发送所有类型报文的平均速率(单位为包/秒)
InUsage(%)
在最近一个统计周期内,接口接收所有类型报文的带宽利用率(单位为百分比),不足0.01%且有流量时显示0.01%
InTotal(pps)
在最近一个统计周期内,接口接收所有类型报文的平均速率(单位为包/秒)
OutUsage(%)
在最近一个统计周期内,接口发送所有类型报文的带宽利用率(单位为百分比),不足0.01%且有流量时显示0.01%
OutTotal(pps)
在最近一个统计周期内,接口发送所有类型报文的平均速率(单位为包/秒)
Broadcast(pps)
在最近一个统计周期内,接口接收或发送广播报文的平均速率(单位为包/秒)
Multicast(pps)
在最近一个统计周期内,接口接收或发送组播报文的平均速率(单位为包/秒)
用户配置的接口的描述信息
当某个统计信息的值为Overflow时,表示该项数据的长度超过了14位十进制数
--: Not supported.
当某个统计信息的值为“--”时,则表示设备不支持该项数据的统计
·     flow-interval
display ethernet statistics命令用来显示以太网软件模块收发报文的统计信息。
display ethernet statistics slot slot-number
slot slot-number:显示指定单板的信息。slot-number为单板所在的槽位号。
# 显示指定slot上的以太网软件模块收发报文的统计信息。
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
    TotalNum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
表1-3 display ethernet statistics命令显示信息描述表
以太网软件模块接收到的以太网报文的统计信息:
·     TotalNum:接收报文的总个数
·     ETHIINum:接收的ETHII封装格式报文个数
·     SNAPNum:接收的SNAP封装格式报文个数
·     RAWNum:接收的RAW封装格式报文个数
·     ISISNum:接收的ISIS封装格式报文个数
·     LLCNum:接收的LLC封装格式报文个数
·     UnknowNum:接收的未知封装格式报文个数
·     ForwardNum:二层转发或上送CPU的报文个数‌
·     ARP:接收的ARP报文个数
·     MPLS:接收的MPLS报文个数
·     ISIS:接收的ISIS报文个数
·     ISIS2:接收的ISIS2报文个数
·     IP:接收的IP报文个数
·     IPv6:接收的IPv6报文个数
以太网软件模块接收错误的以太网报文的统计信息(可能是包本身包含错误或者是接收动作出错了):
·     NullPoint:接收报文时指针为空的报文的个数
·     ErrIfindex:接收报文时接口索引错误的报文个数
·     ErrIfcb:接收报文时接口控制块错误的报文个数
·     IfShut:接收报文时接口shutdown的报文个数
·     ErrAnalyse:接收报文时报文解析错误的报文个数
·     ErrSrcMAC:接收的包含源MAC地址错误的报文个数
·     ErrHdrLen:接收的包含报文头长度错误的报文个数
以太网软件模块发送的以太网报文的统计信息:
·     L3OutNum:通过三层以太网接口发送的报文总个数
·     VLANOutNum:通过VLAN接口发送的报文总个数‌
·     FastOutNum:快速发送的报文总个数
·     L2OutNum:通过二层以太网接口发送的报文总个数‌
以太网软件模块发送的错误以太网报文的统计信息:
·     MbufRelayNum:透传发送的报文总个数
·     NullMbuf:发送报文时空指针错误的报文个数
·     ErrAdjFwd:发送报文时邻接表错误的报文个数
·     ErrPrepend:发送报文时扩展错误的报文个数
·     ErrHdrLen:发送的包含报文头长度错误的报文个数
·     ErrPad:发送报文时填充错误的报文个数
·     ErrQoSTrs:发送报文时QoS发送失败的报文个数
·     ErrVLANTrs:发送报文时VLAN发送失败的报文个数‌
·     ErrEncap:发送报文时封装链路头失败的报文个数
·     rrTagVLAN:发送报文时封装VLAN TAG失败的报文个数‌
·     IfShut:发送报文时端口shutdown的报文个数
·     IfErr:发送报文时出接口错误的报文个数
·     reset ethernet statistics
display ifindex-constant configuration命令用来显示接口索引固化功能的配置信息。
# 显示接口索引固化功能的配置信息。
<Sysname> display ifindex-constant configuration
Ifindex constancy: Enabled
Ifindex max-number: 131070
表1-4 display ifindex-constant configuration命令显示信息描述表
Ifindex constancy
接口索引固化功能状态:
·     Disabled:接口索引固化功能处于关闭状态
·     Enabled:接口索引固化功能处于开启状态
Ifindex max-number
接口索引最大固化数量
display ifindex-constant map命令用来显示接口名称和固化的接口索引之间的映射关系。
display ifindex-constant map [ file filename ]
filename:显示从指定flash文件导入的接口名称和固化的接口索引之间的映射关系。如果未指定本参数,则显示当前设备上接口名称和固化的接口索引之间的映射关系。文件的名称为filesystemname/ifindex.dat或filesystemname/snmp_ifindex.dat。该文件必须保存在设备任一文件系统的根目录下,该参数中必须包含文件系统的名称,从存储介质名称开始最多可输入63个字符。有关指定文件夹和文件详细介绍请参见“基础配置指导”中的“文件系统管理”。
# 显示当前设备上接口名称和固化的接口索引之间的映射关系。
<Sysname> display ifindex-constant map
Total number of constant ifindexes: 1
Interface name                                    Interface index
GE3/0/1                                           386
表1-5 display ifindex-constant map命令显示信息描述表
固化的接口索引总数
Interface name
接口简名
Interface index
固化的接口索引
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
如果不指定接口类型和接口编号,则显示所有接口的信息。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看三层以太网接口Ten-GigabitEthernet3/0/1的运行状态和相关信息。
<Sysname> display interface ten-gigabitethernet 3/0/1
Interface index: 386
Current state: UP
Line protocol state: UP
Description: Ten-GigabitEthernet3/0/1 Interface
Bandwidth: 1000000 kbps
Flow-control is not enabled
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 1234-5678-9066
IPv6 packet frame type: Ethernet II, hardware address: 1234-5678-9066
Media type is twisted pair, port hardware type is 1000_BASE_T
Port priority: 0
Loopback is not set
1000Mbps-speed mode, full-duplex mode
The maximum frame length is 10240
Last link flapping: 0 hours 30 minutes 52 seconds
Current system time:2017-12-21 09:10:12 bj+08:00:00
Last time when physical state changed to up:2017-12-21 08:39:19 bj+08:00:00
Last time when physical state changed to down:2017-12-21 08:37:21 bj+08:00:00
Traffic statistic: Include Inter-frame Gaps and Preambles
 Peak input rate: 0 bytes/sec, at 2017-12-21 07:02:00
 Peak output rate: 0 bytes/sec, at 2017-12-21 09:10:07
 Last 300 seconds input:  0 packets/sec 0 bytes/sec 0 bits/sec -%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec 0 bits/sec -%
 Input  (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
          0 ignored, - parity errors
 Output (normal): 0 packets, 0 bytes
          - unicasts, - broadcasts, - multicasts, 0 pauses
 Output: 0 output errors, 0 giants, - underruns, - buffer failures
          0 aborts, 0 deferred, - collisions, 0 late collisions
          - lost carrier, - no carrier
# 查看三层以太网子接口Ten-GigabitEthernet3/0/1.1的运行状态和相关信息。
<Sysname> display interface ten-gigabitethernet 3/0/1.1
Current state: DOWN
Line protocol state: DOWN
Description: Ten-GigabitEthernet3/0/1.1 Interface
IP packet frame type: Ethernet II, hardware address: 80f6-fe00-f4a3
IPv6 packet frame type: Ethernet II, hardware address: 80f6-fe00-f4a3
 Last 300 seconds input rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
 Last 300 seconds output rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
        (broadcasts) 0 packets, 0 bytes
        (multicasts) 0 packets, 0 bytes
        (unicasts) 0 packets, 0 bytes
# 查看二层以太网接口Ten-GigabitEthernet3/0/1的运行状态和相关信息。
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 00fc-5ba5-d800
Loopback is not set
Media type is not sure,port hardware type is No connector
Maximum frame length: 9216
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 0
Last link flapping: Never
Current system time:2017-12-13 12:07:43 bj+08:00:00
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-12-11 17:51:41 bj+08:00:00
 Peak input rate: 0 bytes/sec, at 2017-12-12 17:27:42
 Peak output rate: 0 bytes/sec, at 2017-12-12 17:27:42
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, 0 parity errors
 Output: 0 output errors, 0 giants, 0 underruns, 0 buffer failures
         0 lost carrier, 0 no carrier
表1-6 display interface命令显示信息描述表
接口Ten-GigabitEthernet3/0/1的相关信息
Interface index
接口索引
Derive Interface
三层以太网接口对应的虚拟二层以太网接口的名称
Origin interface
虚拟二层以太网接口对应的三层以太网接口的名称
Current state
接口的物理状态,状态可能为:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭
·     ETH-rddc Shutdown:表示该接口被冗余组模块关闭,即接口状态为冗余关闭
·     mac-address moving down:由于MAC地址迁移抑制导致接口被关闭
·     Storm-Constrain:表示端口上因为未知单播、组播或广播报文中某类报文的流量大于其上限阈值而被关闭
·     STP DOWN:表示接口由于触发了STP BPDU保护而自动关闭
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
·     DOWN:表示数据链路层协议状态为关闭
·     DOWN(protocols):表示接口的数据链路层被一个或者多个协议模块关闭。protocols为DLDP、OAM、LAGG、BFD和MACSEC的任意组合:
¡     DLDP:表示由于DLDP模块检测到单通而关闭接口的数据链路层
¡     OAM:表示由于以太网OAM模块检测到远端链路故障而关闭接口的数据链路层
¡     LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层
¡     BFD:表示由于BFD模块检测到链路故障而关闭接口的数据链路层
¡     MACSEC:表示由于MACSEC模块还未协商成功接口的通信加密参数而关闭接口的数据链路层
¡     VBP:表示由于配置二层转发功能后而关闭接口的数据链路层
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址时,接口的网络协议配置参数:
·     Disabled:不能处理IP报文
·     Enabled:可以处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“BRAS业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“BRAS业务配置指导”中的“DHCP”
·     PPP-negotiated:PPP协商过程中由Server端分配的IP地址,详细介绍请参见“BRAS业务配置指导”中的“PPP”
·     Unnumbered:借用其他接口的IP地址
·     MTunnel:组播隧道接口的IP地址(采用的是MD源接口的IP地址),关于MD源接口的详细介绍请参见“IP组播配置指导”中的“组播VPN”
IPv4报文发送帧格式
hardware address
接口的MAC地址
IPv6报文发送帧格式
Media type is
接口的介质类型
Port hardware type is
接口的硬件类型
FEC mode
FEC模式,该显示信息与用户的配置有关
配置接口的FEC模式为自协商(auto)模式后,FEC模式由接口插入的光模块的型号决定
Port priority
接口优先级
Loopback is set internal
以太网接口正在进行对内环回测试,该显示信息与用户的配置有关
Loopback is set external
对以太网接口进行对外环回测试,该显示信息与用户的配置有关
Loopback is not set
接口上未配置环回测试,该显示信息与用户的配置有关
10Mbps-speed mode
接口速率为10Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
100Mbps-speed mode
接口速率为100Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
1000Mbps-speed mode
接口速率为1000Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
10Gbps-speed mode
接口速率为10Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
100Gbps-speed mode
接口速率为100Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
Unknown-speed mode
速率未知,可能因为速率协商失败或者接口物理未连通
half-duplex mode
接口工作在半双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
full-duplex mode
接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
unknown-duplex mode
未知双工模式,可能因为双工模式协商失败或者接口物理未连通
当用户配置了speed auto时显示该信息
Link speed type is force link
当用户使用speed命令配置了具体的速率时显示该信息,例如10M或者100M等
当用户配置了duplex auto时显示该信息
link duplex type is force link
当用户使用duplex命令配置了具体的双工模式时显示该信息,例如half或者full
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
接口允许通过的最大以太网帧长度
Allow jumbo frame to pass
允许长帧通过
Broadcast max-
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Multicast max-
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Unicast max-
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
PVID
接口所在的缺省VLAN ID
MDI type
网线类型,取值为automdix、mdi或mdix,与用户的配置有关
Port link-type
链路类型,取值为access、trunk或hybrid,与用户的配置有关
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
VLAN Passing
该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN)
VLAN permitted
接口允许通过的VLAN报文
Trunk port encapsulation
Trunk接口的封装格式
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
Ethernet port mode
10GE接口的工作模式:
·     LAN:LAN模式
·     WAN:WAN模式
相关命令请参考port-mode
Regenerator section layer
再生段的告警和错误统计
J0(TX)
发送出去的J0跟踪信息值
J0(RX)
接收到的J0跟踪信息值
Error
错误统计
Multiplex section layer
复用段的告警和错误统计
Higher order path layer
高阶通道的告警和错误统计
 J1(TX)
发送出去的J1跟踪信息值
J1(RX)
接收到的J1跟踪信息值
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,时间显示格式为YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS
最近一次接口物理状态变为UP的时刻
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
Last interval seconds input:  0 packets/sec 0 bytes/sec 0 bits/sec 0%
Last interval seconds output:  0 packets/sec 0 bytes/sec 0 bits/sec 0%
端口在最近一个统计周期内接收和发送报文的平均速率,单位分别为数据包/秒、字节/秒和比特/秒,以及实际速率和接口带宽的百分比。统计周期interval可以通过flow-interval命令设置
如果值显示为“-”,则表示不支持该统计项。
Traffic statistic
统计接口平均速率时是否包含帧间隙和前导码
·     Include Inter-frame Gaps and Preambles:包含帧间隙和前导码
·     Not include Inter-frame Gaps and Preambles:不包含帧间隙和前导码
Input (total):  123220 packets, 11777588 bytes
          482 unicasts, 87316 broadcasts, 35422 multicasts, - pauses
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
Input (normal):  123220 packets, - bytes
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
以太网子接口在最近300秒接收和发送报文的平均速率,单位分别为字节/秒、比特/秒和数据包/秒
仅配置traffic-statistic enable命令后才会显示
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧
giants
接收和发送的超大帧的数量
超大帧是指有效长度大于端口允许通过最大报文长度的帧:
·     对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧
·     对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧
throttles
接收到的长度为非整数字节的帧的个数
CRC
接收到的CRC校验错误、长度正常的帧的数量
frame
接收到的CRC校验错误、且长度不是整字节数的帧的数量
overruns
当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃
aborts
接收到的非法报文总数,非法报文包括:
·     报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧
·     jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧
·     符号错误帧:报文中至少包含1个错误的符号
·     操作码未知帧:报文是MAC控制帧,但不是Pause帧
·     长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配
ignored
由于端口接收缓冲区不足等原因而丢弃的报文数量
parity errors
接收到的奇偶校验错误的帧的数量
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
output errors
各种发送错误的报文总数
underruns
当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败
deferred
延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
collisions
冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
late collisions
延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
lost carrier
载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
no carrier
无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
Peak input rate
接口输入流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
Peak output rate
接口输出流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
IPv4 traffic statistics
IPv4报文统计信息
IPv6 traffic statistics
IPv6报文统计信息
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
端口在最近300秒接收报文的平均速率,单位分别为数据包/秒和字节/秒
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
端口在最近300秒发送报文的平均速率,单位分别为数据包/秒和字节/秒
Input: 0 packets, 0 bytes
端口接收报文的统计值,包括报文数、字节数
Output: 0 packets, 0 bytes
端口发送报文的统计值,包括报文数、字节数
# 显示所有接口的概要信息。
Protocol: (s) – spoofing
Interface                         Link Protocol Primary IP      Description
XGE3/0/1                          DOWN DOWN     --
Loop0                             UP   UP(s)    2.2.2.9
NULL0                             UP   UP(s)    --
Vlan1                             UP   DOWN     --
Vlan999                           UP   UP       192.168.1.42
Speed: (a) - auto
Interface                         Link Speed   Duplex Type PVID Description
XGE3/0/2                          DOWN auto    A      A    1
XGE3/0/3                          UP   100M(a) F(a)   A    1    aaaaaaaaaaaaaaaa
# 显示接口Ten-GigabitEthernet3/0/3的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface ten-gigabitethernet 3/0/3 brief description
Speed: (a) - auto
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示当前物理状态为down的接口的信息以及down的原因。
Interface                         Link Cause
XGE3/0/1                          DOWN Not connected
XGE3/0/2                          DOWN Not connected
表1-7 display interface brief命令显示信息描述表
三层模式下(route)接口的概要信息,即三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口
Protocol: (s) - spoofing
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
接口名称缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层协议状态为开启
·     DOWN:表示接口的数据链路层协议状态为关闭
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会取该值
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Brief information of interfaces in bridge mode:
二层模式下(bridge)的接口概要信息,即二层接口的概要信息
Speed: (a) - auto
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始
如果某接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
当显示为“A”时表示该接口的Duplex属性是通过自动协商获取的,但协商还未开始
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
Speed
接口的速率,单位为bps
Duplex
接口的双工模式,取值为:
·     A:表示双工模式由自动协商结果决定
·     F:表示全双工
·     F(a):表示自由协商的结果为全双工
·     H:表示半双工
·     H(a):表示自由协商的结果为半双工
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     DOWN ( Link-Aggregation interface down ):聚合接口被关闭后,该聚合接口的所有成员端口的状态会显示为DOWN,down的原因会显示为DOWN ( Link-Aggregation interface down )
·     Not connected:表示没有物理连接(可能没有插网线或者网线故障)
·     STP DOWN:由于触发了STP BPDU保护而自动关闭接口
·     Standby:表示接口处于备份状态
display interface link-info命令用来显示接口的状态和报文统计等信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] link-info [ down | up ] [ description ] [ main ] [ verbose ]
down:显示当前物理状态为down的接口的信息。不指定该参数时,将不会根据接口物理状态过滤显示信息。
up:显示当前物理状态为up的接口的信息。不指定该参数时,将不会根据接口物理状态过滤显示信息。
main:显示除子接口外的所有接口的状态和报文统计等信息。不指定该参数,显示所有接口的状态和报文统计等信息。
verbose:显示详细信息。如果不指定该参数,则显示简要信息。
# 显示所有接口的状态和报文统计等信息。
<Sysname> display interface link-info
Interface                         Link Pro   InUsage OutUsage   InErrs  OutErrs Description
XGE3/0/1                        UP   UP      0.05%    0.05%     3000     3000
NULL0                           UP   UP(s)      -%       -%        0        0
 Overflow: More than 7 digits.
       --: Not supported.
# 显示所有接口的状态和报文统计等详细信息。
<Sysname> display interface link-info verbose
Interface                         Link Pro   InUsage OutUsage   InTotal(pps)  Ou
tTotal(pps)  InTotal(pkt) OutTotal(pkt)   InErrs  OutErrs Description
XGE3/0/2                          DOWN DOWN  --      --         --            --
表1-8 display interface link-info命令显示信息描述表
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会具有该属性
接口名简称
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
Pro
接口数据链路层协议状态,取值为:
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会取该值
InUsage
接收方向最近一个统计周期的带宽利用率。接口接收方向最近一个统计周期内的带宽利用率=接口接收方向最近一个统计周期内平均速率/接口带宽。不足0.01%且有流量时显示0.01%。统计周期可以通过flow-interval命令进行设置
OutUsage
发送方向最近一个统计周期的带宽利用率。接口发送方向最近一个统计周期内的带宽利用率=接口发送方向最近一个统计周期内平均速率/接口带宽。不足0.01%且有流量时显示0.01%。统计周期可以通过flow-interval命令进行设置
InTotal(pps)
OutTotal(pps)
InTotal(pkt)
接口接收的报文总数(单位为包)
OutTotal(pkt)
接口发送的报文总数(单位为包)
InErrs
接口接收的错误报文总数(单位为包)
OutErrs
接口发送的错误报文总数(单位为包)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围,Overflow表示数据的长度超过了7位十进制数
--: Not supported.
·     flow-interval
display interface main命令用来显示除子接口以外的接口的运行状态和相关信息。
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type:指定接口类型。如果不指定本参数,则显示所有类型接口的信息。
# 查看除子接口以外的接口的运行状态和相关信息。
<Sysname> display interface main
Current state: UP
Description: GigabitEthernet3/0/1 Interface
Port priority: 0
Loopback is not set
# 显示除子接口以外所有接口的概要信息。
<Sysname> display interface brief main
NULL0                             UP   UP(s)    --
REG0                              UP   --       --
VT1                               DOWN DOWN     --
Speed: (a) - auto
# 显示除子接口以外的接口的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface brief description main
Speed: (a) - auto
XGE3/0/3                          UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaa
# 显示除子接口以外当前物理状态为down的接口的信息以及down的原因。
<Sysname> display interface brief down main
display interface main命令显示信息描述请参见表1-6和表1-7。
display interface phy-option命令用来显示接口的物理属性。
display interface [ interface-type [ interface-number ] ] phy-option
如果不指定接口类型和接口编号,则显示所有接口的物理属性。
如果仅指定接口类型,则显示所有该类型接口的物理属性。
# 显示二层以太网接口Ten-GigabitEthernet3/0/1的物理属性。
<Sysname> display interface ten-gigabitethernet 3/0/1 phy-option
Current state: UP
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Loopback is not set
Maximum frame length: 3072
Transceiver information:
  Transceiver Type              : 1000_BASE_T_AN_SFP
  Wavelength(nm)                : 2147483647
  Transfer Distance(m)          : 100
  Digital Diagnostic Monitoring : NO
  Vendor Name                   : FINISAR CORP.
  RX power: 2147483647dBm/100, Alarm thresholds:[0, 0]uw/10
  RT power: 2147483647dBm/100, Alarm thresholds:[0, 0]uw/10
# 显示三层以太网接口Ten-GigabitEthernet3/0/1的物理属性。
Current state: UP
Loopback is not set
The maximum frame length is 3072
表1-9 display interface命令显示信息描述表
Current state
接口的物理状态,状态可能为:
Flow-control is enabled
已开启流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
Media type is
接口的介质类型
Loopback is not set
1000Mbps-speed mode
10Gbps-speed mode
Unknown-speed mode
half-duplex mode
full-duplex mode
unknown-duplex mode
接口允许通过的最大以太网帧长度
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Wavelength(nm)
光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔
电模块:显示为“N/A”
Transfer Distance(xx)
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
·     CX4:表示CX4电缆
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
RX power(dBm/100)
数字诊断参数——接收光功率,单位为dBm/100
TX power(dBm/100)
数字诊断参数——发送光功率,单位为dBm/100
Alarm thresholds
告警门限
·     display interface
·     display transceiver interface(基础配置命令参考/设备管理)
display link-flap protection命令用来显示接口链路震荡保护功能的相关信息。
display link-flap protection [ interface interface-type [ interface-number ] ]
interface interface-type [ interface-number ]:显示指定接口的链路震荡保护功能信息。其中,interface-type表示接口类型,interface-number表示指定接口编号。如果不指定本参数,则显示所有支持接口的链路震荡保护功能信息。
如果不指定接口编号,则显示所有该类型接口的信息。
# 显示接口链路震荡保护功能的相关信息。
<Sysname> display link-flap protection
Link-flap protection: Enable
Interface                         Link-flap  Status  Interval  Threshold
XGE3/0/1                          Enable     Down    10        5
XGE3/0/2                          Disable    N/A     --        --
表1-10 display link-flap protection命令显示信息描述表
全局链路震荡保护功能,取值为:
·     Enable:表示全局的链路震荡功能处于开启状态
·     Disable:表示全局的链路震荡功能处于关闭状态
接口名称缩写
Link-flap
接口链路震荡保护功能,取值为:
·     Enable:表示接口的链路震荡功能处于开启状态
·     Disable:表示接口的链路震荡功能处于关闭状态
Status
接口状态,取值为:
·     Down:表示接口因为受到链路震荡保护被关闭
·     N/A:表示接口状态未受到链路震荡保护功能影响
Interval
接口链路震荡检查时间间隔
Threshold
接口链路震荡次数
·     link-flap protect enable
display link-state-change statistics interface命令用来显示接口状态变化的统计信息。
display link-state-change statistics interface [ interface-type [ interface-number ] ]
如果不指定interface-type和interface-number,则显示所有接口的统计信息;
如果指定interface-type而不指定interface-number,则显示所有该类型接口的统计信息
# 显示所有以太网接口的状态变化统计信息。
<Sysname> display link-state-change statistics interface
Interface              Change-times  Last-change-time     Reset link-state time
                                     Link-flap-begin      Link-flap-end
XGE3/0/1               0             Never                Never
                                     Never                Never
表1-11 display link-state-change statistics interface命令显示信息描述表
接口名称缩写
Change-times
物理状态变换次数
Last-change-time
上一次物理状态变化的时间
清除接口的状态变化统计信息的时间
Link-flap-begin
最近一次检测到的物理频繁震荡的开始时间,没有发生频繁震荡时显示为Never
Link-flap-end
最近一次检测到的物理频繁震荡的结束时间,没有发生频繁震荡时显示为Never
·     reset link-state-change statistics interface
display packet-drop命令用来显示单板丢弃的报文的信息。
display packet-drop slot [ slot-number ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示所有slot的丢弃报文统计信息。
<Sysname> display packet-drop slot
Slot            Total
0               0
1               210
2               210
表1-12 display packet-drop命令显示信息描述表
Slot
Slot编号
Total
丢弃报文统计信息
display slot-monitor命令用来显示单板告警信息。
display slot-monitor slot slot-number
# 显示slot 1的单板告警信息。
<Sysname> display slot-monitor slot 1
Slot 1:
  Packet-Drop:
    Trap enable    : Y
    Trigger Action : Reboot
    Alarm status   : N
    High threshold : 1000
    Low threshold  : 100
    Interval       : 10 s
    Value          : 10
    Trigger at     : Never
表1-13 display slot-monitor命令显示信息描述表
Trap enable
告警是否开启:
·     Y:表示开启
·     N:表示关闭
Trigger Action
达到告警阈值后的处理方式:
·     Reboot:重启单板
·     Down:关闭单板下所有接口
Alarm status
告警状态:
·     Y:表示当前处于告警状态
·     N:表示当前未处于告警状态
High threshold
告警上限阈值或误码率高门限
Low threshold
告警下限阈值或误码率低门限
Interval
告警的收集和比较间隔周期,单位为秒
Value
最近一次统计周期内的错误报文数量
Trigger at
记录最近一次触发告警阈值或者误码率门限的时间:
·     [L]YYYY/MM/DD HH:MM:SS:记录最近一次触发告警下限阈值或者误码率低门限的系统时间
·     [H]YYYY/MM/DD HH:MM:SS:记录最近一次触发告警上限阈值或者误码率高门限的系统时间
·     Never:未触发告警阈值或者误码率门限
display this interface命令用来显示当前接口的运行状态和相关信息。
以太网接口视图
在接口视图下,如果希望快速看到该接口的状态信息或报文统计信息,可以使用本命令查看。
在当前接口视图下执行display this interface命令与任意视图下执行display interface interface-type interface-number查看到的显示信息一致。
·     display interface
1.1.19  duplex
duplex命令用来设置以太网接口的双工模式。
undo duplex命令用来恢复缺省情况。
duplex { auto | full | half }
undo duplex
以太网接口的双工模式为auto(自协商)状态,10GE接口的双工模式为全双工状态。
以太网接口视图
auto:接口与对端接口自动协商双工状态。
full:全双工状态,接口在发送数据包的同时可以接收数据包。
half:半双工状态,接口同一时刻只能发送数据包或接收数据包。
# 将以太网接口Ten-GigabitEthernet3/0/1接口设置为全双工状态。
[Sysname-Ten-GigabitEthernet3/0/1] duplex full
1.1.20  flag sdh
本命令只有10GE接口工作在WAN模式下时配置才有效。
flag sdh命令用来设置10GE接口工作在WAN模式下时,SDH(Synchronous Digital Hierarchy,同步数字系列)帧开销字段中J0或J1字节的值。
undo flag sdh命令用来恢复缺省情况。
flag { j0 | j1 } sdh value
undo flag { j0 | j1 } sdh
SDH帧格式下再生段踪迹字节J0的缺省值为“CR16000”。
Ten-GigabitEthernet接口视图
j0:再生段踪迹字节。
j1:通道踪迹字节。
value:J0或J1字节的值,为1~15个字符的字符串。
# 配置SDH帧中J0字节的值为Sysname。
[Sysname-Ten-GigabitEthernet3/0/1] port-mode wan
[Sysname-Ten-GigabitEthernet3/0/1] flag j0 sdh Sysname
·     port-mode
1.1.21  flow-control
flow-control命令用来开启以太网接口的流量控制功能。
undo flow-control命令用来关闭以太网接口流量控制功能。
flow-control
undo flow-control
以太网接口的流量控制功能处于关闭状态。
以太网接口视图
配置flow-control命令后,设备具有发送和接收流量控制报文的能力:
·     当本端发生拥塞时,设备会向对端发送流量控制报文。
·     当本端收到对端的流量控制报文后,会停止报文发送。
只有本端和对端设备都开启了流量控制功能,才能实现对本端以太网接口的流量控制。
# 开启以太网接口Ten-GigabitEthernet3/0/1的流量控制功能。
[Sysname-Ten-GigabitEthernet3/0/1] flow-control
flow-control receive enable命令用来开启以太网接口的接收流量控制功能。
undo flow-control命令用来关闭以太网接口的接收流量控制功能。
undo flow-control
以太网接口的接收流量控制功能处于关闭状态。
以太网接口视图
配置flow-control receive enable命令后,设备具有接收流量控制报文的能力,但不具有发送流量控制报文的能力。
开启以太网接口的接收流量控制功能后:
·     当设备收到对端的流量控制报文,会停止向对端发送报文。
·     当本端发生拥塞时,设备不能向对端发送流量控制报文。
如果要应对单向网络拥塞的情况,可以在一端配置flow-control receive enable,在对端配置flow-control;如果要求本端和对端网络拥塞都能处理,则两端都必须配置flow-control。
# 使能以太网接口Ten-GigabitEthernet3/0/1的接收流量控制功能。
[Sysname-Ten-GigabitEthernet3/0/1] flow-control receive enable
【相关配置】
·     flow-control
flow-interval命令用来配置接口统计报文信息的时间间隔。
undo flow-interval命令用来恢复缺省情况。
flow-interval interval
undo flow-interval
接口统计报文信息的时间间隔为300秒。
以太网接口视图
interval:接口统计信息的时间间隔值。系统视图下取值范围为5~300,单位为秒,步长为5(即取值必须为5的整数倍);以太网接口视图下取值范围为1~300,单位为秒,步长为1。
用户可以通过系统视图和接口视图下的配置来配置以太网接口统计信息的时间间隔:
·     系统视图下的配置对所有以太网接口生效;
·     以太网接口视图下的配置对当前接口生效;
·     当接口视图下的配置为缺省情况时,系统视图下的配置生效;
·     当系统视图和接口视图下都配置本命令,接口视图下的配置优先生效。
系统视图下的flow-interval命令建议采用缺省值。如果将该时间间隔配置过短,可能导致系统性能下降,统计的数据不准确。
修改接口统计信息的时间间隔后,需要等待两个统计周期,才能通过display interface命令的Last interval seconds input和Last interval seconds output字段查看正确的统计信息。
# 设置以太网接口Ten-GigabitEthernet3/0/1的统计信息时间间隔为100秒。
[Sysname-Ten-GigabitEthernet3/0/1] flow-interval 100
·     display interface
1.1.24  frame-format
frame-format命令用来配置工作在WAN模式的10GE接口的帧格式。
undo frame-format命令用来恢复缺省情况。
frame-format sdh
undo frame-format
10GE接口的帧格式为SDH。
sdh:帧格式为SDH。
不支持参数:sonet
SDH与SONET是两种光传输标准,分别由不同的组织制定,两者除了在技术细节参数上有一些差别外,在实质内容和主要规范上并没有很大区别,但是两者应用的地域范围有所不同,不同设备厂商也有不同的缺省参数,配置帧格式与传输设备保持一致即可。
# 配置工作在WAN模式的10GE接口的帧格式为SDH。
[Sysname-Ten-GigabitEthernet3/0/1] frame-format sdh
ifindex-constant enable命令用来开启接口索引固化功能。
undo ifindex-constant enable命令用来关闭接口索引固化功能。
ifindex-constant enable [ file filename ]
接口索引固化功能处于关闭状态。
filename:表示从指定flash文件导入接口索引。文件的名称为filesystemname/ifindex.dat或filesystemname/snmp_ifindex.dat。该文件必须保存在设备任一文件系统的根目录下,该参数中必须包含文件系统的名称,从存储介质名称开始最多可输入63个字符。有关指定文件夹和文件详细介绍请参见“基础配置指导”中的“文件系统管理”。
在某些应用程序环境中(例如使用接口索引用作为计费参考),接口索引值必须恒定并且不受接口添加或删除、系统重启或软件/硬件配置更改的影响。在这种情况下,可以开启接口索引固化功能以满足要求。开启接口索引固化功能后,所有当前接口和新创建的接口的接口索引值都将固定。
重新启动设备时,请先运行save命令。否则,设备重启后接口索引值可能会发生变化。
# 开启接口索引固化功能。
[Sysname] ifindex-constant enable
ifindex-constant max-number命令用来配置可固化的接口索引的最大数量。
undo ifindex-constant max-number命令用来恢复缺省情况。
ifindex-constant max-number number
可固化的接口索引的最大数量为131070。
number:最多可固化接口索引的个数,本参数的取值范围为0~131070。配置固定索引接口数量为0时,表示不固化任何接口的索引。
配置本命令前需要开启MIB上接口索引固化功能。
# 配置可固化接口索引的最大数量为1000。
[Sysname] ifindex-constant max-number 1000
·     ifindex-constant enable
ifmonitor crc-error命令用来全局配置CRC错误报文告警参数。
undo ifmonitor crc-error命令用来恢复缺省情况。
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
CRC错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定CRC错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定CRC错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的CRC错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因CRC错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的CRC错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
slot slot-number:配置指定单板的参数。slot-number为单板所在的槽位号。
开启CRC错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的CRC错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的CRC错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置CRC错误报文告警参数。
·     系统视图下的配置对指定slot的所有接口有效,接口视图下的配置只对当前接口有效。
·     对于接口来说,优先采用接口视图下的配置,当该接口未进行配置时,才采用系统视图下的配置。
多次执行本命令,最后一次执行的命令生效。
# 配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor crc-error slot 1 high-threshold 5000 low-threshold 400 interval 6
·     snmp-agent trap enable ifmonitor
ifmonitor giant命令用来全局配置超大帧告警参数。
undo ifmonitor giant命令用来恢复缺省情况。
ifmonitor giant slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor giant slot slot-number
超大帧告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口超大帧告警上限阈值,取值范围是1~4294967295。
low-threshold low-value:指定接口超大帧告警下限阈值,取值范围是1~4294967295。
interval interval:指定接口超大帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口进入超大帧告警状态时,关闭接口,该接口将停止转发所有报文。因超大帧告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。
当接口处于正常状态,并在指定的时间内收到的超大帧个数超出告警上限阈值时,接口将进入告警状态,产生超大帧告警。当接口处于超大帧告警状态,并在指定的时间内收到的超大帧个数低于下限阈值时,接口将恢复到正常状态,产生超大帧恢复告警。
用户可在系统视图和接口视图下配置超大帧告警参数。
# 全局配置超大帧告警上限阈值为5,超大帧告警下限阈值为4,超大帧数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor giant slot 1 high-threshold 5 low-threshold 4 interval 6
·     port ifmonitor giant
ifmonitor input-buffer-drop命令用来全局配置入方向数据缓冲区丢弃报文告警参数。
undo ifmonitor input-buffer-drop命令用来恢复缺省情况。
ifmonitor input-buffer-drop slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-buffer-drop slot slot-number
入方向数据缓冲区丢弃报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定入方向数据缓冲区丢弃报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定入方向数据缓冲区丢弃报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定入方向数据缓冲区丢弃报文的数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的入方向数据缓冲区丢弃报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向数据缓冲区丢弃报文被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向数据缓冲区丢弃报文超出上限告警阈值,接口不会被关闭,接口将产生超上限告警,并进入告警状态。当已经触发超上限告警后,如果配置本参数,则接口会被关闭。
开启入方向数据缓冲区丢弃报文告警功能后,当接口处于正常状态,并在指定的时间内接收的入方向数据缓冲区丢弃报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的入方向数据缓冲区丢弃报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向数据缓冲区丢弃报文告警参数。
# 配置入方向数据缓冲区丢弃报文告警上限阈值为5000,入方向数据缓冲区丢弃报文告警下限阈值为400,入方向数据缓冲区丢弃报文的数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor input-buffer-drop slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-error命令用来全局配置入方向错误报文告警参数。
undo ifmonitor input-error命令用来恢复缺省情况。
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
入方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口入方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口入方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口入方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口入方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启入方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内入方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内入方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向错误报文告警参数。
# 配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor input-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage命令用来全局配置入方向带宽利用率的告警参数。
undo ifmonitor input-usage命令用来恢复缺省情况。
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
入方向带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定入方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内入方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内入方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启入方向带宽利用率告警功能后才能生效。
# 配置全局入方向带宽利用率告警上限阈值为95,入方向带宽利用率告警下限阈值为80。
[Sysname] ifmonitor input-usage slot 1 high-threshold 95 low-threshold 80
·     flow-interval
ifmonitor output-buffer-drop命令用来全局配置出方向数据缓冲区丢弃报文告警参数。
undo ifmonitor output-buffer-drop命令用来恢复缺省情况。
ifmonitor output-buffer-drop slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-buffer-drop slot slot-number
出方向数据缓冲区丢弃报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定出方向数据缓冲区丢弃报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定出方向数据缓冲区丢弃报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定出方向数据缓冲区丢弃报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的出方向数据缓冲区丢弃报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向数据缓冲区丢弃报文被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向数据缓冲区丢弃报文超出上限告警阈值,接口不会被关闭,接口将产生超上限告警,并进入告警状态。当已经触发超上限告警后,如果配置本参数,则接口会被关闭。
开启出方向数据缓冲区丢弃报文告警功能后,当接口处于正常状态,并在指定的时间内接收的出方向数据缓冲区丢弃报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的出方向数据缓冲区丢弃报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向数据缓冲区丢弃报文告警参数。
# 配置出方向数据缓冲区丢弃报文告警上限阈值为5000,出方向数据缓冲区丢弃报文告警下限阈值为400,出方向数据缓冲区丢弃报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor output-buffer-drop slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-error命令用来全局配置出方向错误报文告警参数。
undo ifmonitor output-error命令用来恢复缺省情况。
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
出方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口出方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口出方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口出方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口出方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启出方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内出方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内出方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向错误报文告警参数。
# 配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor output-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage命令用来全局配置出方向带宽利用率的告警参数。
undo ifmonitor output-usage命令用来恢复缺省情况。
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
出方向的带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定出方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定出方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内出方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内出方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启出方向带宽利用率告警功能后才能生效。
# 配置全局出方向带宽利用率告警上限阈值为80,出方向带宽利用率告警下限阈值为60。
[Sysname] ifmonitor output-usage slot 1 high-threshold 80 low-threshold 60
·     flow-interval
ifmonitor runt命令用来全局配置超小帧告警参数。
undo ifmonitor runt命令用来恢复缺省情况。
ifmonitor runt slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor runt slot slot-number
超小帧告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口超小帧告警上限阈值,取值范围是1~4294967295。
low-threshold low-value:指定接口超小帧告警下限阈值,取值范围是1~4294967295。
interval interval:指定接口超小帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口进入超小帧告警状态时,关闭接口,该接口将停止转发所有报文。因超小帧告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。
当接口处于正常状态,并在指定的时间内收到的超小帧个数超出告警上限阈值时,接口将进入告警状态,产生超小帧告警。当接口处于超小帧告警状态,并在指定的时间内收到的超小帧个数低于下限阈值时,接口将恢复到正常状态,产生超小帧恢复告警。
用户可在系统视图和接口视图下配置超小帧告警参数。
# 全局配置超小帧告警上限阈值为5,超小帧告警下限阈值为4,超小帧数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor runt slot 1 high-threshold 5 low-threshold 4 interval 6
·     port ifmonitor runt
1.1.36  interface
interface命令用来进入接口视图或创建子接口并进入子接口视图。如果指定的子接口已经存在,则直接进入子接口视图。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~99999999。主接口下支持创建的子接口数量上限为16383。
# 进入以太网接口Ten-GigabitEthernet3/0/1视图。
# 创建以太网子接口Ten-GigabitEthernet3/0/1.1并进入该子接口的视图。
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
设备允许最大取值的超长帧通过以太网接口。
二层以太网接口视图
三层以太网接口视图
MIC-CQ1L-M、MIC-CQ2L-M和MIC-XP4L-M单板不支持本命令。
# 允许超长帧通过以太网接口Ten-GigabitEthernet3/0/1。
[Sysname-Ten-GigabitEthernet3/0/1] jumboframe enable
1.1.38  link-delay
link-delay命令用来配置以太网接口物理连接状态抑制功能。
undo link-delay命令用来恢复缺省情况。
undo link-delay { down | up }
未配置以太网接口物理连接down状态抑制功能;配置以太网接口物理连接up状态抑制时间为1秒。
以太网接口视图
down:设置以太网接口物理连接down状态抑制功能。
up:设置以太网接口物理连接up状态抑制功能。
msec:表示配置的抑制时间为毫秒级。不指定该参数时,表示配置的抑制时间为秒级。
delay-time:接口物理连接状态抑制时间值,0表示不抑制,即接口状态改变时立即上报CPU。
·     未指定msec参数时,取值范围为0~300,单位为秒。
·     指定msec参数时,取值范围为0~10000,且为10的倍数,单位为毫秒。
使用该命令时,选取的参数不同,抑制效果不同:
·     down:表示接口状态从up变成down时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是down,再上报。
·     up:表示接口状态从down变成up时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是up,再上报。
同一接口下,接口状态从up变成down的抑制时间和接口状态从down变成up的抑制时间可以不同。在同一接口下,多次执行本命令:
·     可以分别配置抑制上报down状态和抑制上报up状态。
·     当配置的是同一状态的抑制时间时,则最新的配置生效。
对于开启了生成树协议的端口不推荐使用该命令。
# 设置以太网接口物理连接down状态抑制时间为8秒。
[Sysname-Ten-GigabitEthernet3/0/1] link-delay down 8
# 设置以太网接口物理连接up状态抑制时间为800毫秒。
[Sysname-Ten-GigabitEthernet3/0/1] link-delay up msec 800
link-flap protect enable命令用来开启全局链路震荡保护功能。
undo link-flap protect enable命令用来关闭全局链路震荡保护功能。
全局链路震荡功能处于关闭状态。
链路震荡即接口的物理状态频繁变化时,会导致网络拓扑结构不断变化,给系统带来额外的开销。例如,在主备链路场景中,当主链路的接口物理状态频繁UP/DOWN时,业务将在主备链路之间来回切换,增加了设备的负担。为了解决该问题,设备提供了链路震荡保护功能。
配置本功能后,当接口状态从UP变为DOWN时,系统会启动链路震荡检查。在链路震荡检查时间间隔内,如果该接口状态从UP变为DOWN的次数大于等于链路震荡次数阈值,则关闭该接口。
只有系统视图下和接口视图下同时开启链路震荡保护功能后,接口的链路震荡保护功能才能生效。
# 全局开启链路震荡保护功能。
[Sysname] link-flap protect enable
1.1.40  loopback
开启环回功能后,接口将不能正常转发数据包,请按需配置。
loopback命令用来开启以太网接口的环回功能。
undo loopback命令用来关闭以太网接口的环回功能。
undo loopback
以太网接口的环回功能处于关闭状态。
以太网接口视图
external:开启以太网接口的外部环回功能。
internal:开启以太网接口的内部环回功能。
开启环回功能后,接口将自动切换到全双工模式,关闭环回功能后会自动恢复原有双工模式。
shutdown和loopback命令互斥,后配置的失败。
# 开启以太网接口Ten-GigabitEthernet3/0/1的内部环回功能。
[Sysname-Ten-GigabitEthernet3/0/1] loopback internal
port fec mode命令用来配置接口的FEC(Forward Error Correction,前向纠错)模式。
undo port fec mode命令用来恢复缺省情况。
port fec mode { auto | base-r | none | rs-fec }
undo port fec mode
接口处于FEC自协商(auto)模式。
100GE接口视图
auto:表示自适应FEC模式,根据光模块类型自动设置FEC模式或者关闭接口的FEC功能。
base-r:表示BASE-R FEC模式。100GE接口不支持本参数。
none:不进行前向纠错。
rs-fec:表示RS-FEC模式。
FEC用于报文纠错,它通过在发送端为数据报文附加纠错信息,在接收端利用纠错信息来纠正数据报文在传输时产生的错误码,以提高传输质量。用户需要根据实际情况来选择FEC模式。
当接口处于FEC自协商模式时,会根据插入的光模块改变接口FEC模式。
用户需要保证链路两端使用的FEC模式一致。
# 配置以太网接口Twenty-FiveGigE3/0/1的FEC模式为自协商模式。
[Sysname] interface twenty-fivegige 3/0/1
[Sysname-Twenty-FiveGigE3/0/1] port fec mode auto
# 配置以太网接口HundredGigE3/0/1的FEC模式为自协商模式。
[Sysname] interface hundredgige 3/0/1
[Sysname-HundredGigE3/0/1] port fec mode auto
port ifmonitor crc-error命令用来配置CRC错误报文告警参数。
undo port ifmonitor crc-error命令用来恢复缺省情况。
接口采用的CRC错误报文告警参数与全局采用的CRC错误报文告警参数一致。
以太网接口视图
ratio:表示以百分比形式配置告警阈值。不指定该参数时,表示配置的是告警阈值的大小。
high-threshold high-value:指定CRC错误报文告警上限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
# 在接口Ten-GigabitEthernet3/0/1上配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor giant命令用来在接口下配置超大帧告警参数。
undo port ifmonitor giant命令用来恢复缺省情况。
port ifmonitor giant high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的超大帧告警参数与全局采用的超大帧告警参数一致。
以太网接口视图
# 在接口Ten-GigabitEthernet3/0/1下配置超大帧告警上限阈值为5、超大帧告警下限阈值为4,超大帧数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor giant high-threshold 5 low-threshold 4 interval 6
·     ifmonitor giant
port ifmonitor input-buffer-drop命令用来配置入方向数据缓冲区丢弃报文告警参数。
undo port ifmonitor input-buffer-drop命令用来恢复缺省情况。
port ifmonitor input-buffer-drop high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的入方向数据缓冲区丢弃报文告警参数与全局采用的入方向数据缓冲区丢弃报文告警参数一致。
以太网接口视图
interval interval:指定入方向数据缓冲区丢弃报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口Ten-GigabitEthernet3/0/1上配置入方向数据缓冲区丢弃报文告警上限阈值为5000,入方向数据缓冲区丢弃报文告警下限阈值为400,入方向数据缓冲区丢弃报文的数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor input-buffer-drop high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-error命令用来配置入方向错误报文告警参数。
undo port ifmonitor input-error命令用来恢复缺省情况。
接口采用的入方向错误报文告警参数与全局采用的入方向错误报文告警参数一致。
以太网接口视图
# 在接口Ten-GigabitEthernet3/0/1上配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage命令用来配置入方向带宽利用率的告警参数。
undo port ifmonitor input-usage命令用来恢复缺省情况。
接口采用的入方向带宽利用率告警参数与全局采用的入方向带宽利用率告警参数一致。
high-threshold high-value:指定入方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
# 在接口Ten-GigabitEthernet3/0/1上配置入方向带宽利用率告警上限阈值为80,入方向带宽利用率告警下限阈值为60。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor input-usage high-threshold 80 low-thershold 60
·     flow-interval
port ifmonitor output-buffer-drop命令用来配置出方向数据缓冲区丢弃报文告警参数。
undo port ifmonitor output-buffer-drop命令用来恢复缺省情况。
port ifmonitor output-buffer-drop high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的出方向数据缓冲区丢弃报文告警参数与全局采用的出方向数据缓冲区丢弃报文告警参数一致。
以太网接口视图
interval interval:指定出方向数据缓冲区丢弃报文的数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口Ten-GigabitEthernet3/0/1上配置出方向数据缓冲区丢弃报文告警上限阈值为5000,出方向数据缓冲区丢弃报文告警下限阈值为400,出方向数据缓冲区丢弃报文的数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor output-buffer-drop high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-error命令用来配置出方向错误报文告警参数。
undo port ifmonitor output-error命令用来恢复缺省情况。
接口采用的出方向错误报文告警参数与全局采用的出方向错误报文告警参数一致。
以太网接口视图
# 在接口Ten-GigabitEthernet3/0/1上配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage命令用来配置出方向带宽利用率的告警参数。
undo port ifmonitor output-usage命令用来恢复缺省情况。
接口采用的出方向带宽利用率告警参数与全局采用的出方向带宽利用率告警参数一致。
high-threshold high-value:指定接口出方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
high-threshold high-value:指定接口出方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
# 在接口Ten-GigabitEthernet3/0/1上配置出方向带宽利用率告警上限阈值为9,出方向带宽利用率告警下限阈值为7。
[Sysname-Ten-GigabitEthernet3/0/1]port ifmonitor output-usage high-threshold 9 low-threshold 7
·     flow-interval
port ifmonitor runt命令用来在接口下配置超小帧告警参数。
undo port ifmonitor runt命令用来恢复缺省情况。
port ifmonitor runt high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的超小帧告警参数与全局采用的超小帧告警参数一致。
以太网接口视图
# 在接口Ten-GigabitEthernet3/0/1下配置超小帧告警上限阈值为5、超小帧告警下限阈值为4,超小帧数据收集和比较时间间隔为6秒。
[Sysname-Ten-GigabitEthernet3/0/1] port ifmonitor runt high-threshold 5 low-threshold 4 interval 6
·     ifmonitor runt
port link-flap protect enable命令用来开启接口链路震荡保护功能。
undo port link-flap protect enable命令用来关闭接口链路震荡保护功能。
port link-flap protect enable [ interval interval | threshold threshold ] *
undo port link-flap protect enable [ interval | threshold ]
接口的链路震荡功能处于关闭状态。
以太网接口视图
interval interval:链路震荡检查时间间隔,取值范围10~60,单位为秒,缺省值为10秒。
threshold threshold:链路震荡次数阈值,取值范围5~10,缺省值为5次。
只有系统视图下和接口视图下同时配置链路震荡保护功能后,接口的链路震荡保护功能才能生效。
执行port link-flap protect enable命令时,如果未指定interval或threshold,表示采用interval或threshold的缺省值。
执行undo port link-flap protect enable命令时,如果指定interval或threshold,表示恢复interval或threshold的缺省值。
接口下配置本命令后,当接口状态从UP变为DOWN时,系统会启动链路震荡检查。在链路震荡检查时间间隔内,如果该接口状态从UP变为DOWN的次数大于等于链路震荡次数阈值,则关闭该接口。
接口因链路频繁震荡被关闭后,不会自动恢复,需要用户执行undo shutdown命令手工恢复。
以太网接口上不能同时配置本命令和dampening命令。
# 开启接口的链路震荡保护功能,链路震荡检查时间间隔为10秒,链路震荡次数阈值为5次。
[Sysname-Ten-GigabitEthernet3/0/1] port link-flap protect enable interval 10 threshold 5
·     dampening
port link-mode命令用来切换以太网接口的工作模式。
undo port link-mode命令用来恢复缺省情况。
undo port link-mode
以太网接口的工作模式为三层模式。
以太网接口视图
bridge:工作在二层模式。
route:工作在三层模式。
接口模式切换后,除了shutdown命令,该以太网接口下的其它所有命令都将恢复到新模式下的缺省情况。
设备上的接口比较灵活,工作模式可以通过命令行设置。如果将工作模式设置为二层模式(bridge),则作为一个二层以太网接口使用,如果将工作模式设置为三层模式(route),则作为一个三层以太网接口使用。
# 使接口Ten-GigabitEthernet3/0/1工作在二层模式。
[Sysname-Ten-GigabitEthernet3/0/1] port link-mode bridge
The configuration of the interface will be restored to the default. Continue? [Y/N]:y
1.1.53  port-mode
port-mode命令用来设置10GE接口工作在LAN模式或WAN模式。
undo port-mode命令用来恢复缺省情况。
port-mode { lan | wan }
undo port-mode
10GE接口工作在LAN模式。
lan:指定接口工作在LAN模式。工作在该模式下的接口传输以太网报文,用于连接以太网。
wan:指定接口工作在WAN模式。工作在该模式下的接口传输SDH(Synchronous Digital Hierarchy,同步数字系列)报文,用于连接SDH网络。接口工作在WAN模式下仅支持点到点的报文传输。
仅MIC-XP10L-M单板支持本命令。
# 设置Ten-GigabitEthernet3/0/1接口工作在WAN模式。
[Sysname] interface ten-gigabitethernet3/0/1
priority-flow-control inner-port命令用来开启内联接口的PFC功能。
undo priority-flow-control inner-port命令用来关闭内联接口的PFC功能。
priority-flow-control inner-port { auto | enable }
内联接口的PFC功能处于关闭状态。
auto:表示与对端自动协商是否开启PFC功能。
enable:表示强制开启PFC功能。
内联接口是指设备网板和业务板间进行通信的接口,用户不可见。
当内联接口的PFC功能处于开启状态,如果从业务板到网板的流量发生拥塞时,网板上的内联接口将发送PFC PAUSE帧给业务板的内联接口,通知业务板暂时停止向网板发送报文;拥塞解除后,再通知业务板继续发送报文,反之亦然。
# 开启内联接口的PFC功能。
[Sysname] priority-flow-control inner-port enable
·     priority-flow-control inner-port no-drop
priority-flow-control inner-port no-drop命令用来开启内联接口的802.1p优先级的PFC功能。
undo priority-flow-control inner-port no-drop命令用来关闭配置内联接口的802.1p优先级的PFC功能。
priority-flow-control inner-port no-drop dot1p dot1p-list
undo priority-flow-control inner-port no-drop dot1p dot1p-list
内联接口的802.1p优先级的PFC功能处于关闭状态。
dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5。(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)
如果内联接口的PFC功能处于开启状态,并配置了本命令,本端内联口发送拥塞时,本端内联口将向对端内联口发送PFC PAUSE帧通知对端内联口停止发送该优先级的报文,以免指定优先级的报文因为链路拥塞被丢弃。有关802.1p优先级的介绍,请参见“ACL和QoS配置指导”中的“QoS”。
# 开启内联接口的802.1p优先级1的PFC功能。
[Sysname] priority-flow-control inner-port no-drop dot1p 1
reset counters interface命令用来清除接口的统计信息。
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
如果不指定interface-type和interface-number,则清除所有接口的统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的统计信息。
# 清除以太网接口Ten-GigabitEthernet3/0/1的统计信息。
<Sysname> reset counters interface ten-gigabitethernet 3/0/1
·     display interface
·     display counters interface
·     display counters rate interface
reset counters mib interface命令用来清除MIB上接口的统计信息。
reset counters mib interface [ interface-type [ interface-number | interface-number.subnumber ] ]
在某些情况下,需要在MIB中统计一定时间内某接口的流量,这就需要在统计开始前清除该接口原有的MIB统计信息,重新进行统计。
如果不指定interface-type和interface-number,则清除所有接口的mib统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的mib统计信息。
# 清除MIB上以太网接口Ten-GigabitEthernet3/0/1的统计信息。
<Sysname> reset counters mib interface ten-gigabitethernet 3/0/1
reset counters slot命令用来清除单板及单板上接口的统计信息。
reset counters slot [ slot-number ]
slot [ slot-number ]:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示所有单板。
# 清除slot 1及slot 1上接口的统计信息。
<Sysname> reset counter slot 1
reset ethernet statistics命令用来清除以太网软件模块收发报文的统计信息。
reset ethernet statistics [ slot slot-number ]
slot slot-number:清除指定单板的信息。slot-number为单板所在的槽位号。如果不指定本参数,则表示所有单板。
# 清除指定slot上的以太网软件模块收发报文的统计信息。
<Sysname> reset ethernet statistics slot 1
·     display ethernet statistics
reset ifindex-constant map命令用来清除接口名称和固化的接口索引之间的映射关系。
本命令仅能清除当前设备上接口名称和固化的接口索引之间的映射关系,不能清除flash文件中的接口名称和固化的接口索引之间的映射关系。执行本命令后,设备还会根据当前接口索引,重新构造接口名称和接口索引对应关系。
执行本命令前需要开启接口索引固化功能。
# 清除接口名称和固化的接口索引之间的映射关系。
<Sysname> reset ifindex-constant map
·     display ifindex-constant map
reset link-state-change statistics interface命令用来清除接口的状态变化统计信息。
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
未清除接口状态变化统计信息。
接口的状态变化统计值可以通过display link-state-change statistics interface命令查看,使用本命令,可以将接口的状态变化次数统计值清零。
# 清除以太网接口Ten-GigabitEthernet3/0/1的状态变化统计信息。
<Sysname> reset link-state-change statistics interface ten-gigabitethernet 3/0/1
·     display link-state-change statistics interface
1.1.62  shutdown
shutdown命令用来关闭以太网接口/子接口。
undo shutdown命令用来打开以太网接口/子接口。
shutdown
以太网接口、以太网子接口处于开启状态。
以太网接口视图
以太网子接口视图
执行本命令会导致使用该接口建立的链路中断,不能通信,请谨慎使用。
在某些特殊情况下(例如修改接口的工作参数),接口相关配置不能立即生效,需要关闭再打开接口后,才能生效。
# 关闭以太网接口Ten-GigabitEthernet3/0/1后打开该接口。
[Sysname-Ten-GigabitEthernet3/0/1] shutdown
[Sysname-Ten-GigabitEthernet3/0/1] undo shutdown
# 关闭以太网子接口Ten-GigabitEthernet3/0/1.1后打开该接口。
[Sysname-Ten-GigabitEthernet3/0/1.1] shutdown
[Sysname-Ten-GigabitEthernet3/0/1.1] undo shutdown
shutdown all-physical-interfaces命令用来关闭全部物理接口。
undo shutdown all-physical-interfaces命令用来开启全部物理接口。
物理接口处于开启状态。
通过配置shutdown all-physical-interfaces命令,可以关闭和开启设备上除管理以太网接口外的所有物理接口,所有物理接口状态变为ADM。
在系统视图下执行shutdown all-physical-interfaces命令或在接口视图下执行shutdown命令,接口均会被关闭。
在系统视图下执行undo shutdown all-physical-interfaces命令和在接口视图下执行undo shutdown命令后,接口才会被开启。
# 关闭全部物理接口。
[Sysname] shutdown all-physical-interfaces
·     Shutdown
slot-monitor packet-drop命令用来配置单板丢失报文的告警参数。
undo slot-monitor packet-drop命令用来恢复缺省情况。
slot-monitor packet-drop [ slot slot-number ] high-threshold high-threshold-value low-threshold low-threshold-value interval interval [ shutdown | reboot ]
undo slot-monitor packet-drop [ slot slot-number ]
单板丢失报文的告警上限阈值为1000000,下限阈值为100,数据收集和比较时间间隔为30秒。
high-threshold high-threshold-value:指定单板丢失报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-threshold-value:指定单板丢失报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定单板丢失报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当单板接收到因丢失报文超出上限告警阈值时,关闭单板下所有接口,该单板将停止转发所有报文。因单板告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当单板接收到因丢失报文超出上限告警阈值,单板将产生超上限告警,并进入告警状态。
reboot:表示当单板接收到因丢失报文超出上限告警阈值时,重启单板。未指定本参数时,表示当单板因接收到因丢失报文超出上限告警阈值,单板将产生超上限告警,并进入告警状态。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示所有单板。
开启单板丢失报文告警功能后,当单板处于正常状态,并在指定的时间内接收的丢失报文超出告警上限阈值时,单板将产生超上限告警,并进入告警状态。当单板处于告警状态,且在指定时间间隔内接收的单板丢失报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
如果未指定slot,则本命令对所有slot生效;如果指定了slot,则本命令只对指定的slot生效。如果某个slot同时配置了slot-monitor packet-drop和slot-monitor packet-drop slot命令,则该slot以slot-monitor packet-drop slot命令的配置为准。
# 配置单板丢失报文告警上限阈值为5000,单板丢失报文告警下限阈值为1000,单板丢失报文数据收集和比较时间间隔为60秒。
[Sysname] slot-monitor packet-drop slot 1 high-threshold 5000 low-threshold 1000 interval 60 shutdown
·     snmp-agent trap enable slot-monitor
snmp-agent trap enable ifmonitor命令用来开启接口告警功能。
undo snmp-agent trap enable ifmonitor命令用来关闭接口告警功能。
snmp-agent trap enable ifmonitor [ crc-error | giant | input-buffer-drop | input-error | input-usage | output-buffer-drop | output-error | output-usage | runt ] *
undo snmp-agent trap enable ifmonitor [ crc-error | giant | input-buffer-drop | input-error | input-usage | output-buffer-drop | output-error | output-usage | runt ] *
接口告警功能处于开启状态。
crc-error:开启接口CRC错误报文告警功能。
giant:开启接口超大帧告警功能。
input-buffer-drop:开启接口入方向数据缓冲区丢弃报文告警功能。
input-error:开启接口入方向错误报文告警功能。
input-usage:开启接口入方向带宽利用率告警功能。
output-buffer-drop:开启接口出方向数据缓冲区丢弃报文告警功能。
output-error:开启接口出方向错误报文告警功能。
output-usage:开启接口出方向带宽利用率告警功能。
runt:开启接口超小帧告警功能。
# 开启接口CRC错误报文告警功能。
[Sysname] snmp-agent trap enable ifmonitor crc-error
1.1.66  snmp-agent trap enable slot-monitor
snmp-agent trap enable slot-monitor命令用来开启单板告警功能。
undo snmp-agent trap enable slot-monitor命令用来关闭单板告警功能。
snmp-agent trap enable slot-monitor [ packet-drop ]
undo snmp-agent trap enable slot-monitor [ packet-drop ]
单板告警功能处于开启状态。
packet-drop:开启单板丢失报文告警功能。
# 开启单板丢失报文告警功能。
[Sysname] snmp-agent trap enable slot-monitor packet-drop
1.1.67  speed
speed命令用来设置以太网接口的速率。
undo speed命令用来恢复缺省情况。
speed { 10 | 100 | 1000 | 10000 | 100000 | auto }
undo speed
GE接口的速率为auto(自协商)状态。10GE/100GE接口的速率为最大速率。
以太网接口视图
10:表示接口速率为10Mbps。
100:表示接口速率为100Mbps。
1000:表示接口速率为1000Mbps。
10000:表示接口速率为10000Mbps。
100000:表示接口速率为100000Mbps。
auto:表示接口速率处于自协商状态。
对于以太网电口来说,使用speed命令设置端口速率,目的是使其与对端进行速率匹配。不同类型的电口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前电口支持该速率。否则,当前电口不支持该速率。
对于光口来说,使用speed命令设置端口速率,目的是使其与可插拔光模块进行速率匹配。不同类型的光口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前光口支持该速率。否则,当前光口不支持该速率。同时需要根据所选用光模块类型,在光口下配置匹配的速率,以便正常使用光模块。如果光口所配置的速率光模块无法支持,则光模块无法使用。例如SFP+口插入SFP千兆光模块时配置speed 10000,或SFP+口插入万兆光模块时配置speed 1000,光模块都无法使用。
设置MIC-XP10L-M单板上以太网接口的速率时,需要注意:
·     仅MIC-XP10L-M单板支持1000Mbps/10000Mbps速率切换;其他万兆以太网接口单板均不支持1000Mbps/10000Mbps速率切换。
·     MIC-XP10L-M单板配置speed auto命令后,接口速率处于10M/100M/1000M/10000M自协商状态。
·     MIC-XP10L-M单板进行速率切换时,可以单端口进行切换。
# 将以太网接口Ten-GigabitEthernet3/0/1的速率设置为自协商获得。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] speed auto
1.1.68  traffic-statistic include-interframe
traffic-statistic include-interframe命令用来配置接口流量统计时对帧间隙和前导码进行统计。
undo traffic-statistic include-interframe命令用来恢复缺省情况。
以太网接口视图
用户可执行命令display interface查看以太网接口当前运行状态和接口统计信息。显示信息中的Last 300 seconds input rate或Last 300 seconds output rate字段表示接口在最近300秒内接收和发送报文的平均速率。
缺省情况下,接口流量统计速率=原始报文长度×每秒通过的报文个数。如果用户希望了解接口单位时间内通过的总字节数,即包含报文字节数以及帧间隙和前导码时,可以配置本命令,将包括帧间隙和前导码的流量统计。此时,接口流量统计速率=(原始报文长度+帧间隙+前导码)× 每秒通过的报文个数。
# 配置对以太网接口Ten-GigabitEthernet3/0/1进行流量统计时对帧间隙和前导码进行统计。
[Sysname-Ten-GigabitEthernet3/0/1] traffic-statistic include-interframe
Traffic statistic will be set to include Inter-frame Gaps and Preambles. Continue? [Y/N]:y
·     display interface
1.1.69  using gigabit
using gigabit命令用来将10GE接口切换成GE接口。
using gigabit
10GE接口未切换成GE接口。
10GE接口视图
如果对端连接的是GE接口,或者用户当前只有GE光模块没有10GE光模块,可以将10GE接口切换成GE接口使用。
仅MIC-XP4L-M单板支持本命令。
# 将Ten-GigabitEthernet3/0/1接口切换成GE接口。
[Sysname-Ten-GigabitEthernet3/0/1] using gigabit
·     using tengige
1.1.70  using tengige
using tengige命令用来将由10GE接口切换成的GE接口恢复成10GE接口。
using tengige
GE接口未切换成10GE接口。
GE接口视图
如果用户需要更大的带宽,可以将切换成的GE接口恢复成10GE接口使用。
仅MIC-XP4L-M单板支持本命令。
# 将GigabitEthernet3/0/1接口切换成10GE接口。
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] using tengige
·     using gigabit
1.2  三层以太网接口/子接口的配置命令
1.2.1  bridge-forwarding enable
bridge-forwarding enable命令用来开启接口的二层转发功能。
undo bridge-forwarding enable命令用来关闭接口的二层转发功能。
接口的二层转发功能处于关闭状态。
三层以太网接口视图
配置本命令后,将删除三层以太网接口上的物理层相关配置,请根据实际情况配置本命令。
缺省情况下,三层接口只能收发三层报文。配置本命令后,设备会自动创建与三层接口对应的虚拟二层接口,用于实现在三层接口下传输VLAN报文的功能。此时,该三层接口的数据链路层会自动变成DOWN状态,其转发报文方式为:
·     通过虚拟二层接口进行二层转发。
·     通过三层子接口进行三层转发。
如果三层以太网接口已经加入三层聚合组,则不能在三层以太网接口下配置本命令。
如果子接口能够终结的VLAN报文的最外层VLAN ID范围中包含VLAN 1,则不能在主接口下配置本命令;子接口能够终结的VLAN报文的最外层VLAN ID范围中不能包含虚拟二层接口允许通过的VLAN和PVID。有关VLAN终结描述,请参见“二层技术-以太网交换配置指导”中的“VLAN终结”。
当在三层以太网接口下配置本命令后,则不能执行以下操作:
·     接口拆分及切换
·     二三层切换
·     加入三层聚合组
# 开启三层以太网接口Ten-GigabitEthernet3/0/1的二层转发功能。
[Sysname-Ten-GigabitEthernet3/0/1] bridge-forwarding enable
This operation will clear the routing configuration that affects bridge forwarding on the interface. Continue?[Y/N]:y
1.2.2  interface virtual-bridge-port
interface virtual-bridge-port命令用来进入虚拟二层以太网接口视图。
interface virtual-bridge-port interface-number
不存在虚拟二层以太网接口。
interface-number:指定接口编号。
在三层以太网接口下配置bridge-forwarding enable命令后,设备会自动创建与三层以太网接口对应的虚拟二层接口,用于实现在三层以太网接口下传输VLAN报文的功能。
在虚拟二层以太网接口下,可配置description以及基于端口的VLAN的相关命令。相关命令具体请参见“二层技术-以太网交换命令参考”中的“VLAN命令”。
# 进入虚拟二层以太网接口Virtual-Bridge-Port3/0/1视图。
[Sysname] interface virtual-bridge-port 3/0/1
[Sysname-Virtual-Bridge-Port3/0/1]
·     bridge-forwarding enable
·     description
1.2.3  mac-address
mac-address命令用来配置以太网接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
三层以太网接口的MAC地址由设备分配。
以太网接口视图
mac-address:MAC地址,形式为H-H-H。
给接口配置MAC地址时,请不要使用VRRP协议保留的MAC地址段。
# 配置三层以太网接口Ten-GigabitEthernet3/0/1的MAC地址为0001-0001-0001。
[Sysname-Ten-GigabitEthernet3/0/1] mac-address 1-1-1
1.2.4  mtu
mtu命令用来设置三层以太网接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size [ spread ]
undo mtu [ spread ]
三层以太网接口/子接口的MTU值为1500字节。
三层以太网接口视图
三层以太网子接口视图
spread:批量修改子接口的MTU。子接口不支持指定本参数。
由于QoS队列长度的限制(如FIFO队列的缺省长度为75),MTU太小会造成分片太多,从而被QoS队列丢弃。此时,可适当增大MTU值或QoS队列的长度。以太网接口视图下的命令qos fifo queue-length可以改变QoS队列长度(具体配置请参见“ACL和QoS配置指导”中的“QoS”)。
在主接口视图下执行mtu size命令仅对主接口生效,在子接口视图下配置本命令仅对该子接口生效。
在主接口视图下执行mtu size spread命令可同时修改主接口和其下所有子接口的MTU,但子接口视图下单独配置的MTU值优先生效。
接口作为流量的入接口且流量出接口的MTU配置值小于1280时,该流量的IP报文会根据MTU值1280来进行分片。当设备上单板在位时,建议将出接口的MTU值配置成1280以上。
# 设置三层以太网接口Ten-GigabitEthernet3/0/1的最大传输单元为1430字节。
[Sysname-Ten-GigabitEthernet3/0/1] mtu 1430
# 设置三层以太网子接口Ten-GigabitEthernet3/0/1.1的最大传输单元为1430字节。
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] mtu 1430
# 设置三层以太网接口Ten-GigabitEthernet3/0/1的MTU值为1430字节,并同步修改子接口的MTU值。
[Sysname-Ten-GigabitEthernet3/0/1] mtu 1430 spread
1.2.5  port-type switch
port-type switch命令用来在POS接口和三层GE接口间进行类型切换。
在POS接口视图下:
port-type switch gigabitethernet
在三层GE接口视图下:
port-type switch pos
POS接口视图
三层GE接口视图
gigabitethernet:将当前POS接口切换为三层GE接口。
pos:将当前三层GE接口切换为POS接口。
接口类型切换后,原接口删除并创建新的接口,该接口下的其它所有命令都将恢复到新接口下的缺省情况。
仅MIC-TCP8L-M单板支持本命令。
接口类型切换后,切换后的接口编号与切换前保持一致。
命令执行成功后会自动切换到新接口的接口视图下。
# 将Pos3/0/1接口切换为GigabitEthernet3/0/1接口。
[Sysname] interface pos 3/0/1
[Sysname-Pos3/0/1] port-type switch gigabitethernet
Changing port type can result in loss of port configuration. Are you sure to continue? [Y/N]:y
1.2.6  traffic-statistic enable
traffic-statistic enable命令用来开启以太网子接口的报文统计功能。
undo traffic-statistic enable命令用来关闭以太网子接口的报文统计功能。
以太网子接口的报文统计功能处于关闭状态。
三层以太网子接口视图
开启以太网子接口报文统计功能后会占用系统硬件资源,在大量以太网子接口下开启本功能或者通过flow-interval命令配置的时间间隔较小时会导致系统繁忙,CPU占用率升高。
配置本命令后,可以通过display interface命令的Input和Output字段或者display counters命令查看以太网子接口的统计信息。
同一三层以太网子接口下,以太网子接口的报文统计功能和IPoE L2VPN专线用户互斥,二者只能配置其一。有关IPoE L2VPN专线用户的详细介绍,请参见“BRAS业务配置指导”中的“IPoE”。
# 开启三层以太网子接口Ten-GigabitEthernet3/0/1.1的报文统计功能。
[Sysname-Ten-GigabitEthernet3/0/1.1] traffic-statistic enable
·     display counters
·     display interface
·     flow-interval
