09-MPLS命令参考
03-LDP命令
本章节下载: 03-LDP命令  (774.15 KB)
03-LDP命令
1 LDP
1.1 LDP公共配置命令
1.1.1 accept target-hello
1.1.2 backoff
1.1.3 display mpls ldp discovery
1.1.4 display mpls ldp error-packet
1.1.5 display mpls ldp fec
1.1.6 display mpls ldp interface
1.1.7 display mpls ldp lsp
1.1.8 display mpls ldp lsp fault-analysis
1.1.9 display mpls ldp parameter
1.1.10 display mpls ldp peer
1.1.11 display mpls ldp summary
1.1.12 display mpls ldp troubleshooting
1.1.13 dscp
1.1.14 entropy-label enable
1.1.15 graceful-restart
1.1.16 graceful-restart timer
1.1.17 keychain-authentication all
1.1.18 keychain-authentication peer
1.1.19 keychain-authentication prefix-list
1.1.20 label-distribution
1.1.21 log enable
1.1.22 log record-size
1.1.23 loop-detect
1.1.24 lsr-id
1.1.25 maxhops
1.1.26 md5-authentication all
1.1.27 md5-authentication peer-lsr-id
1.1.28 md5-authentication prefix-list
1.1.29 mpls entropy-label-capability enable
1.1.30 mpls ldp
1.1.31 mpls ldp local-lsr-id
1.1.32 mpls ldp timer
1.1.33 propagate mapping
1.1.34 pv-limit
1.1.35 reset mpls ldp
1.1.36 snmp-agent trap enable ldp
1.1.37 snmp-agent trap enable ldp-private
1.1.38 vpn-instance
1.2 LDP IPv4配置命令
1.2.1 accept-label
1.2.2 advertise-label
1.2.3 display mpls ldp igp sync
1.2.4 igp sync delay
1.2.5 igp sync delay on-restart
1.2.6 import bgp
1.2.7 lsp-trigger
1.2.8 mpls ldp enable
1.2.9 mpls ldp igp sync disable
1.2.10 mpls ldp sync (IS-IS view)
1.2.11 mpls ldp sync (OSPF view/OSPF area view)
1.2.12 mpls ldp transport-address
1.2.13 session protection
1.2.14 targeted-peer
1.3 LDP IPv6配置命令
1.3.1 ipv6 accept-label
1.3.2 ipv6 advertise-label
1.3.3 ipv6 import bgp
1.3.4 ipv6 lsp-trigger
1.3.5 mpls ldp ipv6 enable
1.3.6 mpls ldp transport-address
1.3.7 targeted-peer
2 mLDP
2.1 mLDP配置命令
2.1.1 display mpls mldp lsp p2mp
2.1.2 mldp p2mp
2.1.3 mldp recursive-fec
2.1.4 mpls mldp p2mp disable
1 LDP
1.1  LDP公共配置命令
accept target-hello命令用来开启设备根据Targeted Hello消息自动建立LDP Targeted会话的功能。
undo accept target-hello命令用来关闭设备根据Targeted Hello消息自动建立LDP Targeted会话的功能。
accept target-hello { all | prefix-list prefix-list-name }
设备根据Targeted Hello消息自动建立LDP Targeted会话的功能处于关闭状态。
LDP视图
all:设备根据所有Targeted Hello消息自动建立LDP Targeted会话。
prefix-list prefix-list-name:设备只能根据通过IPv4地址前缀列表过滤的对等体发送的Targeted Hello消息自动建立LDP Targeted会话。prefix-list-name表示IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
在某些场景中需要目的端设备根据源端发送的Targeted Hello消息自动建立LDP Targeted会话。例如:在部署Remote LFA FRR的场景中,当源端设备利用Remote LFA算法计算出PQ节点后,LDP需要自动建立源端设备与PQ节点之间的LDP Targeted会话。此时,需要在PQ节点设备上配置本命令,使PQ节点根据收到的Targeted Hello消息自动建立LDP Targeted会话。有关Remote LFA FRR的详细介绍,请参见“三层技术-IP路由配置指导”中的“IS-IS”。
多次执行本命令,最后一次执行的命令生效。
# 配置设备根据对等体1.1.1.9和2.2.2.9发来的Targeted Hello消息自动建立LDP Targeted会话。
[Sysname] ip prefix-list accept-fec-list index 1 permit 1.1.1.9 32
[Sysname] ip prefix-list accept-fec-list index 2 permit 2.2.2.9 32
[Sysname] mpls ldp
[Sysname-ldp] accept target-hello prefix-list accept-fec-list
·     ip prefix-list(三层技术-IP路由命令参考/路由策略)
1.1.2  backoff
backoff命令用来配置LDP倒退机制的初始延迟和最大延迟。
undo backoff命令用来恢复缺省情况。
backoff initial initial-time maximum maximum-time
undo backoff
LDP倒退机制的初始延迟为15秒,最大延迟为120秒。
LDP视图
LDP-VPN实例视图
initial initial-time:指定LDP倒退机制的初始延迟。initial-time表示LDP倒退机制的初始延迟,取值范围15~50331,单位为秒。
maximum maximum-time:指定LDP倒退机制的最大延迟。maximum-time表示LDP倒退机制的最大延迟,取值范围120~50331,单位为秒。
如果LDP对等体上配置的LDP会话参数不兼容,则可能导致会话参数协商失败、LDP对等体无休止地反复尝试建立会话。
LDP倒退机制用来抑制尝试建立会话的频率。如果会话因为参数不兼容而建立失败,LSR将等待初始延迟时间再尝试建立会话;如果会话再次因为参数不兼容而建立失败,则再次尝试建立会话的延迟时间为上一次延迟时间的二倍;延迟时间达到配置的最大值后,尝试建立会话的等待时间将保持为配置的最大延迟。
如果配置的LDP倒退机制的初始延迟大于最大延迟,则初始延迟采用所配置的最大延迟的值。
# 配置公网LDP实例LDP倒退机制的初始延迟时间为100秒,最大延迟时间为300秒。
[Sysname] mpls ldp
[Sysname-ldp] backoff initial 100 maximum 300
display mpls ldp discovery命令用来显示LDP发现过程相关信息。
display mpls ldp discovery [ all [ ipv6 ] | [ vpn-instance vpn-instance-name ] [ [ interface interface-type interface-number | peer peer-lsr-id ] [ ipv6 ] | targeted-peer { ipv4-address | ipv6-address } ] ] [ verbose ] [ slot slot-number ]
all:显示公网和所有VPN实例的LDP发现过程相关信息。
vpn-instance vpn-instance-name:显示指定LDP实例的发现过程相关信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例的发现过程相关信息。
interface interface-type interface-number:显示通过指定接口发送Link hello消息的LDP发现过程相关信息,即基本发现机制相关信息。interface-type interface-number为接口类型和接口编号。
peer peer-lsr-id:显示发现指定对等体的LDP发现过程相关信息,既可以是通过基本发现机制发现对等体的信息,也可以是通过扩展发现机制发现对等体的信息。peer-lsr-id为LDP对等体的LSR ID。
ipv6:显示IPv6 Link hello和IPv6 Targeted hello消息发现过程的相关信息。如果不指定本参数,则显示IPv4 Link hello和IPv4 Targeted hello消息发现过程的相关信息。
targeted-peer:显示向指定对等体发送Targeted hello消息的LDP发现过程相关信息,即扩展发现机制相关信息。
ipv4-address:LDP对等体的IPv4地址。
ipv6-address:LDP对等体的IPv6地址。
verbose:显示LDP发现过程的详细信息。如果不指定本参数,则显示LDP发现过程的简要信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
如果不指定all和vpn-instance参数,则显示公网LDP实例的发现过程相关信息。
如果未指定interface、peer、ipv6和targeted-peer中的任何一个参数,则显示所有LDP IPv4发现过程相关信息,包括基本发现机制相关信息和扩展发现机制相关信息。
# 显示所有公网LDP IPv4 hello消息发现过程的简要信息。
<Sysname> display mpls ldp discovery
VPN instance: public instance
     Type: L - Link Hello, T - Targeted Hello
Discovery Source              Hello Sent/Rcvd       Peer LDP ID
(L) XGE3/0/2                  83/80                 100.100.100.18:0
                                                    200.100.100.18:0
(T) 100.100.100.18            23/20                 100.100.100.18:0
表1-1 display mpls ldp discovery命令显示信息描述表
VPN instance
LDP所属的公网或VPN实例信息,公网LDP显示为public instance,私网LDP显示为VPN实例名称
LDP发现过程类型,取值包括:
·     L:表示通过发送Link hello消息发现对等体的基本发现机制
·     T:表示通过发送Targeted hello消息发现对等体的扩展发现机制
Discovery Source
LDP对等体的发现源:
·     LDP发现过程类型为L时,显示为发现该对等体的接口
·     LDP发现过程类型为T时,显示为对等体的IPv4地址
Hello Sent/Rcvd
接口上发送和接收的Hello报文数目
Peer LDP ID
LDP对等体的LDP ID
# 显示所有公网LDP IPv6 hello消息发现过程的简要信息。
<Sysname> display mpls ldp discovery ipv6
Interface: Ten-GigabitEthernet3/0/2
  Hello Sent/Rcvd: 12/12
    Peer LDP ID: 100.100.100.18:0
    Peer LDP ID: 200.200.200.28:0
Targeted Hellos: 2001:0000:130F::09C0:876A:130B ->
                 2005:130F::09C0:876A:130B
  Hello Sent/Rcvd: 93/80
    Peer LDP ID: 100.100.100.180:0
表1-2 display mpls ldp discovery命令显示信息描述表
VPN instance
采用基本发现机制发现的对等体的接口
Hello Sent/Rcvd
向该对等体发送和从该对等体接收的Hello报文数目
Peer LDP ID
LDP对等体的LDP ID
Targeted Hellos
采用扩展发现机制发现的对等体。其中,“->”前面的地址为本地地址;“->”后面的地址为对等体地址
# 显示所有公网LDP IPv4 hello消息发现过程的详细信息。
<Sysname> display mpls ldp discovery verbose
Link Hellos:
  Interface Ten-GigabitEthernet3/0/2
    Local LDP ID     : 100.100.100.17:0
    Hello Interval   : 5000 ms            Hello Sent/Rcvd  : 83/160
    Transport Address: 100.100.100.17
    Peer LDP ID      : 100.100.100.18:0
      Source Address : 202.118.224.18     Transport Address: 100.100.100.18
      Hello Hold Time: 15 sec (Local: 15 sec, Peer: 15 sec)
    Peer LDP ID      : 100.100.100.20:0
      Source Address : 202.118.224.20     Transport Address: 100.100.100.20
Targeted Hellos:
  100.100.100.17 -> 100.100.100.18 (Active, Passive)
    Hello Interval   : 15000 ms           Hello Sent/Rcvd  : 23/20
    Session Setup    : Config/Tunnel
      Source Address : 100.100.100.18     Transport Address: 100.100.100.18
      Hello Hold Time: 45 sec (Local: 45 sec, Peer: 45 sec)
  100.100.100.17 -> 100.100.100.20 (Active, Passive)
    Hello Interval   : 15000 ms           Hello Sent/Rcvd  : 23/22
      Source Address : 100.100.100.20     Transport Address: 100.100.100.20
# 显示所有公网LDP IPv6 hello消息发现过程的详细信息。
<Sysname> display mpls ldp discovery ipv6 verbose
Link Hellos:
    Transport Address: 2001::2
      Source Address : FE80:130F:20C0:29FF:FEED:9E60:876A:130B
      Transport Address: 2001::1
Targeted Hellos:
        2005:130F::09C0:876A:130B(Active, Passive)
    Transport Address: 2001:0000:130F::09C0:876A:130B
      Source Address : 2005:130F::09C0:876A:130B
      Destination Address : 2001:0000:130F::09C0:876A:130B
      Transport Address   : 2005:130F::09C0:876A:130B
表1-3 display mpls ldp discovery verbose命令显示信息描述表
VPN instance
Link Hellos
发送Link hello消息的LDP发现过程相关信息,即基本发现机制相关信息,按接口显示
多播类型接口下,可能发现多个对等体
运行LDP基本发现机制的接口
Local LDP ID
本地的LDP ID
Hello Interval
hello报文发送时间间隔,单位为毫秒
Hello Sent/Rcvd
接口上发送和接收的hello报文数
Transport Address
本地传输地址
Session Setup
LDP Targeted会话建立的方式,取值包括:
·     Config:表示由用户配置触发创建
·     Tunnel:通过Tunnel接口下配置MPLS LDP触发创建
·     L2VPN:通过MPLS L2VPN自动触发创建
·     Session-Protect:通过LDP会话保护触发创建
·     OSPF RLFA:通过OSPF Remote LFA触发创建
·     IS-IS RLFA:通过IS-IS Remote LFA触发创建
·     Auto Accept:接收Targeted Hello消息后自动触发创建
Peer LDP ID
LDP对等体的LDP ID
Source Address
收到hello报文的源IP地址
Destination Address
收到hello报文的目的IP地址
Transport Address
收到的hello报文中指定的传输地址,即LDP对等体的传输地址
Hello Hold Time
协商出来的Hello保持时间,单位为秒
Local:本地配置的Hello保持时间,单位为秒;Peer:收到的hello报文中指定的Hello保持时间,即LDP对等体的Hello保持时间,单位为秒
协商出来的Hello保持时间为Local和Peer值中的较小者
Targeted Hellos
发送Targeted hello消息的LDP发现过程相关信息,即扩展发现机制相关信息,按对等体LSR ID显示
·     100.100.100.17(“->”前面的地址)为本地的地址
·     100.100.100.18(“->”后面的地址)为对等体的地址
·     (Active):本地LSR为主动方,即主动向对等体发送Targeted hello消息
·     (Passive):本地LSR为被动方,被动应答对等体发送的Targeted hello消息
·     (Active, Passive):本地LSR既作为主动方,又作为被动方
display mpls ldp error-packet命令用来显示LDP会话中收到的错误TCP报文信息。
本命令最多显示最近的100条错误报文信息。
# 显示LDP会话中收到的错误TCP报文信息。
<Sysname> display mpls ldp error-packet
Total 1 records
Peer LDP ID    : 2.2.2.9
VPN instance   : public
Receive time   : 2018-04-31 07:12:41
Error reason   : Bad LDP Identifier
Packet length  : 18 bytes
Message type   : -
Packet content :
 00 01 00 0E 02 02 02 09 00 00 02 01 00 04 80 00
 A0 D8
表1-4 display mpls ldp error-packet命令显示信息描述表
Peer LDP ID
对等体的LDP标识符
VPN instance
VPN实例名称
Receive time
接收到错误报文的时间,格式为YYYY-MM-DD HH:MM:SS
Error Reson
错误原因:
·     Bad LDP identifier:LDP标识符错误
·     Bad protocol version:LDP版本号错误
·     Bad PDU length:LDP PDU长度错误
·     Unknown message type:未知的消息类型
·     Bad message length:消息长度错误
·     Unkown TLV:未知的TLV
·     Bad TLV length:TLV长度错误
·     Malformed TLV value:错误的TLV
·     Unknown FEC:未知的FEC
·     Missing message parameters:消息参数丢失
·     Unsupported address family:地址族不支持
Packet length
错误报文的长度,单位为字节
Message type
消息类型:
·     Label Request Message:标签请求消息
·     Label Mapping Message:标签映射消息
·     Label Release Message:标签释放消息
·     Label Withdraw Message:标签撤销消息
·     Label Abort Request Message:标签终止请求消息
·     Initialization Message:Initialization消息
·     Keepalive Message:Keepalive消息
·     Notification Message:Notification消息
·     Address Message:Address消息
·     Address Withdraw Message:Address Withdraw消息
·     -:不能识别出消息类型
Packet content
错误报文内容
display mpls ldp fec命令用来显示通过LDP学习到的FEC—标签映射信息。
display mpls ldp fec [ all [ ipv6 ] [ summary ] | [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6-address prefix-length | [ ipv6 ] [ summary ] ] ] [ slot slot-number ]
all:显示公网和所有VPN实例的FEC-标签映射信息。
vpn-instance vpn-instance-name:显示指定LDP实例的FEC—标签映射信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例的FEC—标签映射信息。
ipv4-address mask-length:显示指定IPv4 FEC的标签映射详细信息。ipv4-address为FEC的目的IPv4地址前缀,mask-length为FEC目的IPv4地址前缀的掩码长度,取值范围为0~32。
ipv6-address prefix-length:显示指定IPv6 FEC的标签映射详细信息。ipv6-address为FEC的目的IPv6地址前缀,prefix-length为前缀长度,取值范围为0~128。
ipv6:显示IPv6的FEC标签映射相关信息。
summary:显示LDP学习到的所有FEC—标签映射的概要信息。
如果不指定all和vpn-instance参数,则显示公网LDP实例的FEC—标签映射信息。
如果仅指定summary参数,则显示所有IPv4 FEC—标签映射的概要信息。
如果仅指定ipv6参数,则显示所有IPv6 FEC—标签映射的详细信息。
如果同时指定summary参数和ipv6参数,则显示所有IPv6 FEC—标签映射的概要信息。
如果不指定ipv4-address mask-length、ipv6-address prefix-length、ipv6和summary参数,则显示所有IPv4 FEC—标签映射的详细信息。
# 显示公网LDP学习到的所有IPv4 FEC—标签映射详细信息。
<Sysname> display mpls ldp fec
 FEC: 100.100.100.18/32
   Flags: 0x02
   In Label: 1531
   Label Advertisement Policy:
     FEC Prefix-list: Fec-prefix-list
     Peer Prefix-list: Peer-prefix-list
   Upstream Info:
     Peer: 100.100.100.18:0        State: Established (stale)
     Peer: 100.100.100.20:0        State: Established (stale)
   Downstream Info:
       Out Label: 3                State: Established (stale)
       Next Hops: 202.118.224.18          XGE3/0/2
       Out Label: 1025             State: Established (stale)
       Label Stack Index: 16777218
   RIB Info:
     Protocol        : OSPF        BGP AS Num   : 0
     Label Proto ID  : 1           NextHopCount : 2
     VN ID           : 0x423000004
     Tunnel ID       : -
     BkTunnel ID     : 0x1200001
 FEC: 200.100.100.18/32 (No route)
   Flags: 0x0
   In Label: 1532
   Upstream Info:
     Peer: 200.200.200.28:0        State: Established
   Downstream Info:
     Peer: 120.100.100.18:0
       Out Label: 3                State: Idle
# 显示公网LDP学习到的IPv6 FEC—标签映射详细信息。
<Sysname> display mpls ldp fec ipv6
 FEC: 2005:130F::09C0/128
   Flags: 0x02
   In Label: 1026
     FEC Prefix-list: Fec-ipv6-prefix-list
     Peer Prefix-list: Peer-ipv6-prefix-list
   Upstream Info:
   Downstream Info:
       Next Hops:
       FE80:130F:20C0:29FF:FEED:9E60:876A:130B          XGE3/0/2
   RIB Info:
     Label Proto ID  : 1           NextHopCount : 1
     VN ID           : 0x423000004
     Tunnel ID       : -
表1-5 display mpls ldp fec命令显示信息描述表
VPN instance
FEC
转发等价类,即IP地址前缀和前缀长度
Flags
FEC标志位,通过将不同的比特位置1来表示不同的含义(可以多个比特位同时置1表示多种含义的组合,如0x21表示0x01和0x20的组合):
·     0x0:表示初始值,无含义
·     0x00000001:表示Egress LSP
·     0x00000002:表示Ingress LSP
·     0x00000004:表示等待向RIB设置出标签
·     0x00000008:表示等待向LSM刷新LSP
·     0x00000010:表示满足发送标签通告的条件
·     0x00000020:表示GR恢复期间,FEC和标签绑定关系已刷新
·     0x00000040:表示延迟向LSM刷新LSP
·     0x00000080:表示GR恢复期间,非Egress LSP等待恢复
·     0x00000100:表示LDP会话使用该地址作为传输地址
·     0x10000000:表示FEC为OSPF Remote LFA注册的PQ地址
·     0x20000000:表示FEC为IS-IS Remote LFA注册的PQ地址
·     0x40000000:表示等待向OSPF刷新LSP
·     0x80000000:表示等待向IS-IS刷新LSP
In Label
入标签值,即本地LSR为此FEC分配的标签
标签通告控制策略信息
FEC Prefix-list
用于检查FEC目的地址的IP地址前缀列表
Peer Prefix-list
用于检查LDP对等体LSR ID的IP地址前缀列表
Upstream Info
上游信息,即向哪些对等体通告FEC—标签映射信息及与上游对等体建立的LSP的当前状态
Peer
上游对等体的LDP ID
与上游对等体建立的LSP的当前状态,取值包括:
·     Established:激活状态
·     Idle:初始状态
·     Release Awaited:等待Release消息状态
·     Resource Awaited:等待标签资源分配状态
状态后带有以下标记,分别表示:
·     stale:表示对应的FEC—标签映射处于GR期间
·     backup:表示备份LSP
·     unavailable:表示该LSP不是优选LSP,不能参与转发
Downstream Info
下游信息,即从哪些对等体接收到FEC—标签映射信息及与下游对等体建立的LSP的当前状态
Peer
下游对等体的LDP ID
Out Label
出标签值,即下游对等体为此FEC分配的标签
与下游对等体建立的LSP的当前状态,取值包括:
·     Established:激活状态
·     Idle:未激活状态
状态后带有以下标记,分别表示:
·     backup:表示备份LSP
Next Hops
出接口和下一跳信息
Label Stack Index
该LDP LSP迭代的Ingress LDP LSP表项标签栈索引值
RIB Info
RIB信息,即FEC对应的路由相关信息
Protocol
建立LDP LSP的路由协议:
·     BGP
·     Direct
·     IS-IS
·     OSFP
·     Static
BGP AS Num
BGP的AS号,当建立LDP LSP的路由协议不是BGP时,显示为0
Label Proto ID
标签分发协议类型:
·     0:表示没有标签协议
·     1:表示LDP
·     2:表示BGP
·     3:表示静态LSP
NextHop Count
等价路由数
VN ID
虚拟下一跳ID
Tunnel ID
LDP over MPLS TE组网下,FEC对应的隧道ID,不存在隧道时显示为“-”
BkTunnel ID
LDP over MPLS TE组网下,FEC对应的备份隧道ID,不存在备份隧道时显示为“-”
# 显示公网LDP学习到的所有IPv4 FEC—标签映射的概要信息。
<Sysname> display mpls ldp fec summary
FECs         : 3
Implicit Null: 1
Explicit Null: 0
Non-Null     : 2
No Label     : 0
No Route     : 0
Sent         : 3
Received     : 3
# 显示公网LDP学习到的IPv6 FEC—标签映射的概要信息。
<Sysname> display mpls ldp fec ipv6 summary
FECs         : 4
Implicit Null: 0
Explicit Null: 0
Non-Null     : 4
No Label     : 0
No Route     : 0
Sent         : 3
Received     : 3
表1-6 display mpls ldp fec summary命令显示汇总信息描述表
VPN instance
FECs
LDP发现的转发等价类个数,FEC来自路由协议或者LDP对等体通告的标签映射
Implicit Null
绑定隐式空标签的FEC个数
Explicit Null
绑定显式空标签的FEC个数
Non-Null
绑定非空标签的FEC个数
No Label
未分配到标签的FEC个数
No Route
LDP没有对应路由的FEC个数,包含几种情况:
·     路由表中没有对应路由信息
·     路由表中有对应路由信息,但是没有将路由引入到LDP
·     对于IPv6路由,如果路由表中有对应路由信息,并已引入LDP,但是当前设备上未配置mpls ldp ipv6 enable或者未配置targeted-peer ipv6-address,FEC也会视为没有对应路由
Sent
已经发送和正在发送的标签映射个数
Received
已经收到并接受的标签映射个数
display mpls ldp interface命令用来显示使能了LDP能力的接口的LDP相关信息。
display mpls ldp interface [ all | [ vpn-instance vpn-instance-name ] [ interface-type interface-number ] ] [ ipv6 ]
all:显示公网和所有VPN实例的接口LDP相关信息。
vpn-instance vpn-instance-name:显示指定LDP实例的接口的LDP相关信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例下所有使能接口LDP能力的接口的LDP相关信息。
interface-type interface-number:显示指定接口的LDP相关信息。interface-type interface-number为接口类型和接口编号。如果不指定本参数,则显示所有使能LDP能力的接口的LDP相关信息。
ipv6:显示使能了LDP支持IPv6能力的接口的相关信息。如果不指定本参数,则显示使能LDP支持IPv4的能力的接口的相关信息。
如果不指定all和vpn-instance参数,则显示公网LDP实例下所有使能接口LDP能力的接口的LDP相关信息。
# 显示公网LDP实例下所有使能了LDP支持IPv4能力的接口的LDP相关信息。
<Sysname> display mpls ldp interface
Interface                 MPLS         LDP             Auto-config
XGE3/0/2                  Enabled      Configured      -
XGE3/0/6                  Enabled      Configured      -
# 显示公网LDP实例下所有使能了LDP支持IPv6能力的接口的LDP相关信息。
<Sysname> display mpls ldp interface ipv6
XGE3/0/2                  Enabled      Not Configured  -
XGE3/0/3                  Enabled      Not Configured  -
表1-7 display mpls ldp interface命令显示信息描述表
VPN instance
使能了LDP能力的接口名称
MPLS
接口上MPLS是否使能,取值包括:
·     Enabled:使能了MPLS
·     Disabled:未使能MPLS
LDP
接口上是否配置了mpls ldp enable命令或mpls ldp ipv6 enable命令,取值包括:
·     Configured:配置了该命令
·     Not Configured:未配置该命令
Auto-config
(暂不支持)通过IGP自动使能接口上LDP能力的相关信息:
如果通过IGP自动使能了接口的LDP能力,则显示对应的IGP实例参数,如OSPF的实例号和区域标识
如果没有通过IGP自动使能接口的LDP能力,则显示为“-”
·     mpls ldp
·     mpls ldp enable
·     mpls ldp ipv6 enable
display mpls ldp lsp命令用来显示LDP协议生成的LSP信息,即LDP LSP信息。
display mpls ldp lsp [ all [ ipv6 ] | [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6-address prefix-length | ipv6 ] ]
all:显示公网和所有VPN实例的LDP LSP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的LDP LSP信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例的LDP LSP信息。
ipv4-address mask-length:显示到达指定IPv4 FEC的LDP LSP信息。ipv4-address为FEC的目的IPv4地址前缀;mask-length为FEC目的IPv4地址前缀的掩码长度,取值范围为0~32。
ipv6-address prefix-length:显示到达指定IPv6 FEC的LDP LSP信息。ipv6-address为FEC的目的IPv6地址前缀;prefix-length为前缀长度,取值范围为0~128。
ipv6:显示IPv6 FEC的LDP LSP信息。
如果不指定all和vpn-instance参数,则显示公网LDP实例的LDP LSP信息。
如果不指定参数ipv4-address mask-length、ipv6-address prefix-length和ipv6,则显示所有IPv4 FEC的LDP LSP信息。
# 显示公网LDP实例的IPv4 FEC的LDP LSP信息。
<Sysname> display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A – unavailable
FECs: 4            Ingress: 1          Transit: 1      Egress: 3
FEC                In/Out Label        Nexthop         OutInterface/LSINDEX
1.1.1.1/32         -/3                 10.1.1.1        XGE3/0/2
                   1151/3              10.1.1.1        XGE3/0/2
                   -/1025(B)           30.1.1.1        XGE3/0/3
                   1151/1025(B)        30.1.1.1        XGE3/0/3
2.2.2.2/32         3/-
                   -/1151(L)
3.3.3.3/32         -/3                 10.1.1.1        XGE3/0/2
                   1152/3              10.1.1.1        XGE3/0/2
                   -/1025(B)                           LSINDEX16777218
                   1152/1025(B)                        LSINDEX16777218
10.1.1.0/24        1149/-
                   -/1149(L)
192.168.1.0/24     1150/-
                   -/1150(L)
# 显示公网LDP实例的IPv6 FEC的LDP LSP信息。
<Sysname> display mpls ldp lsp ipv6
FECs: 2            Ingress: 1          Transit: 1      Egress: 1
FEC: 2080::29FF:FEED:9E60:876A:130B/128
In/Out Label: -/3                                OutInterface : XGE3/0/2
Nexthop     : FE80:12F:C0::130B
In/Out Label: 1151/3                             OutInterface : XGE3/0/2
In/Out Label: -/1026(L)                          OutInterface : -
Nexthop     : -
FEC: 2001::1/128
In/Out Label: 3/-                               OutInterface : -
Nexthop     : -
表1-8 display mpls ldp lsp命令显示信息描述表
VPN instance
Status Flags
LSP状态,取值包括:
·     *:即stale,表示LSP处于GR过程中
·     L:即liberal,表示发布该标签的对等体不是路由的下一跳,该LSP处于未激活状态
·     B:即backup,表示备份LSP
·     N/A:即unavailable,表示该LSP不是优选LSP,不能参与转发
FECs
FEC的总数
Ingress
本地设备作为入节点的LSP数
Transit
本地设备作为中间节点的LSP数
Egress
本地设备作为出节点的LSP数
FEC
转发等价类,即IP地址前缀和前缀长度
In/Out Label
入标签值/出标签值
Nexthop
下一跳地址
出接口名称/LDP LSP的标签栈索引值
取值为LSINDEXnumber时,表示该LDP LSP迭代到标签栈索引为number的LsIndex表项对应的Ingress LDP LSP
·     display mpls forwarding nhlfe(MPLS命令参考/MPLS基础)
·     display mpls lsp(MPLS命令参考/MPLS基础)
display mpls ldp lsp fault-analysis命令用来显示LDP LSP没有建立成功的原因。
display mpls ldp lsp fault-analysis [ vpn-instance vpn-instance-name ] ipv4-address mask-length
vpn-instance vpn-instance-name:显示指定LDP实例下LDP LSP没有建立成功的原因。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例LDP LSP没有建立成功的原因。
ipv4-address mask-length:显示指定IPv4 FEC的LDP LSP没有建立成功的原因。ipv4-address为FEC的目的IPv4地址前缀,mask-length为FEC目的IPv4地址前缀的掩码长度,取值范围为0~32。
# 显示公网LDP实例LDP LSP没有建立成功的原因。
<Sysname> display mpls ldp lsp fault-analysis 1.1.1.1 24
Ingress:
  LSP State               : Up         Route Check             : Passed
  Policy Check            : Passed     Downstream Session Check: Passed
  Downstream Mapping Check: Passed     Resource Check          : Passed
Transit:
Egress:
  LSP State               : Down       Route Check             : Passed
  Policy Check            : Failed     Resource Check          : Passed
表1-9 display mpls ldp lsp fault-analysis命令显示信息描述表
Ingress
入节点
Transit
中间节点
Egress
出节点
LSP State
LSP的建立状态:
·     Up:已建立
·     Down:未建立
Route Check
检查路由信息是否存储在LDP进程中:
·     Passed:检查结果为通过
·     Failed:检查结果为失败
Policy Check
检查是否通过LDP相关策略过滤:
·     Passed:检查结果为通过
·     Failed:检查结果为失败
检查与下游之间是否存在会话:
·     Passed:检查结果为通过
·     Failed:检查结果为失败
检查下游是否向当前节点通告标签:
·     Passed:检查结果为通过
·     Failed:检查结果为失败
Resource Check
检查标签资源是否可用:
·     Passed:检查结果为通过
·     Failed:检查结果为失败
display mpls ldp parameter命令用来显示LDP的运行参数。
display mpls ldp parameter [ all | vpn-instance vpn-instance-name ]
all:显示公网和所有VPN实例的LDP运行参数。
vpn-instance vpn-instance-name:显示指定LDP实例的运行参数。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例的运行参数。
如果不指定all和vpn-instance参数,则显示公网LDP实例的运行参数。
本命令的显示信息内容包括适用于所有LDP实例的全局运行参数和适用于特定LDP实例的运行参数。
# 显示公网LDP实例的运行参数。
<Sysname> display mpls ldp parameter
 Global Parameters:
   Protocol Version    : V1         IGP Sync Delay on Restart : 90 sec
   Nonstop Routing     : Off        Nonstop Routing State     : Not Ready
   Graceful Restart    : Off        Forwarding State Hold Time: 360 sec
   Reconnect Time      : 120 sec    DSCP Value                : 48
   mLDP P2MP           : On         mLDP Recursive-FEC        : Off
 Instance Parameters:
   Instance ID         : 0
   LSR ID              : 0.0.0.0
   Loop Detection      : Off        Entropy Label                  : On
   Hop Count Limit     : 32         Path Vector Limit              : 32
   Label Retention Mode: Liberal    Label Distribution Control Mode: Ordered
   IGP Sync Delay      : 0 sec
表1-10 display mpls ldp parameter命令显示信息描述表
VPN instance
Global Parameters
适用于所有LDP实例的全局运行参数
Protocol Version
LDP的协议版本
LDP重启时IGP同步延迟时间,单位为秒
Nonstop Routing
是否使能不间断路由功能,取值包括:
·     On:使能了不间断路由功能
·     Off:未使能不间断路由功能
LDP NSR的备份状态,取值包括:
·     Ready:使能不间断路由功能,且现有的LDP会话信息和LDP LSP信息已从主进程备份到备进程。若在该状态下进行主备进程切换,可使LDP会话保持在Operational状态,且数据转发不中断
·     Not Ready:未使能不间断路由功能,或已使能不间断路由功能,但LDP会话信息和LDP LSP信息未完成从主进程到备进程的备份。若在该状态下进行主备进程切换,无法保证LDP会话保持在Operational状态和数据转发不中断
Graceful Restart
是否使能Graceful Restart功能,取值包括:
·     On:使能了GR功能
·     Off:未使能GR功能
GR转发状态保持定时器的值,单位为秒
Reconnect Time
GR重连定时器间的值,单位为秒
DSCP Value
发送的LDP报文的DSCP优先级
mLDP P2MP
mLDP P2MP功能状态,取值包括:
·     On:mLDP P2MP功能处于开启状态
·     Off:mLDP P2MP功能处于关闭状态
mLDP Recursive-FEC
mLDP P2MP的跨域功能状态,取值包括:
·     On:mLDP P2MP的跨域功能处于开启状态
·     Off:mLDP P2MP的跨域功能处于关闭状态
Instance Parameters
适用于特定LDP实例的运行参数
Instance ID
VPN实例索引,取值为0时表示公网
LSR ID
本地设备的LSR ID
Loop Detection
是否使能环路检测功能,取值包括:
·     On:使能了环路检测功能
·     Off:未使能环路检测功能
Entropy Label
是否使能熵标签处理能力,取值包括:
·     On:使能熵标签处理能力
·     Off:未使能熵标签处理能力
Hop Count Limit
环路检测的最大跳数
Path Vector Limit
路径向量方式下LSP的最大跳数
使用的标签保持方式,目前取值只能是Liberal,表示自由标签保持方式
使用的标签分发控制方式,取值包括:
·     Ordered:有序方式
·     Independent:独立方式
IGP Sync Delay
IGP同步延迟时间,单位为秒
display mpls ldp peer命令用来显示LDP对等体和LDP会话信息。
display mpls ldp peer [ all | [ vpn-instance vpn-instance-name ] [ peer-lsr-id ] ] [ verbose ] [ slot slot-number ]
all:显示公网和所有VPN实例的LDP对等体和LDP会话信息。
vpn-instance vpn-instance-name:显示指定LDP实例的LDP对等体和LDP会话信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网LDP实例的LDP对等体和会话信息。
peer peer-lsr-id:显示与指定LDP对等体之间LDP会话的信息。peer-lsr-id为LDP对等体的LSR ID。如果不指定本参数,则显示所有LDP对等体和LDP会话的信息。
verbose:显示LDP对等体和LDP会话的详细信息。如果不指定本参数,则显示LDP对等体和LDP会话的简要信息。
如果不指定all和vpn-instance参数,则显示公网LDP实例的LDP对等体和会话信息。
# 显示公网LDP实例中所有LDP对等体和LDP会话的简要信息。
<Sysname> display mpls ldp peer
Total number of peers: 1
Peer LDP ID             State         Role     GR   Auth      KA Sent/Rcvd
2.2.2.9:0               Operational   Passive  Off  Keychain  39/39
表1-11 display mpls ldp peer命令显示信息描述表
VPN instance
LDP对等体的总数
Peer LDP ID
对等体的LDP ID
本地LSR与LDP对等体之间的LDP会话的状态,取值包括:
·     Non Existent:尚未建立TCP连接
·     Initialized:TCP连接已经建立
·     OpenRecv:本地LSR接收到可接受的初始化消息
·     OpenSent:本地LSR已经发送初始化消息
·     Operational:成功建立会话
Role
本地LSR在会话中的角色,取值包括Active(主动方)和Passive(被动方),IP地址大的LSR为主动方,IP地址小的LSR为被动方,由主动方发起建立TCP连接
GR
对等体上是否使能了GR功能,取值包括
·     On:使能了GR功能
·     Off:未使能GR功能
Auth
本地是否使能了与该对等体之间LDP会话的认证功能,取值包括:
·     MD5:使能了MD5认证功能
·     Keychain:使能了keychain认证功能
KA Sent/Rcvd
本地LSR发送和接收的Keepalive消息数
# 显示公网LDP实例中所有LDP对等体和LDP会话的详细信息。
<Sysname> display mpls ldp peer verbose
 TCP Connection   : 100.100.100.20:47515 -> 100.100.100.17:646
 Session State    : Operational        Session Role     : Passive
 Session Up Time  : 0000:00:03 (DD:HH:MM)
 Max PDU Length   : 4096 bytes (Local: 4096 bytes, Peer: 4096 bytes)
 Keepalive Time     : 45 sec (Local: 45 sec, Peer: 45 sec)
 Keepalive Interval : 15 sec
 Msgs Sent/Rcvd   : 288/426
 KA Sent/Rcvd     : 13/13
 Label Adv Mode   : DU                 Graceful Restart : On
 Reconnect Time   : 120 sec            Recovery Time    : 360 sec
 Loop Detection   : On                 Path Vector Limit: 32
 mLDP P2MP        : On
 Discovery Sources:
   Targeted Hello 100.100.100.17 -> 100.100.100.20 (Active, Passive)
     Hello Hold Time: 45 sec           Hello Interval   : 15000 ms
   Targeted Hello 2005:130F::09C0:876A:130B ->
                  2001:0000:130F:0000:0000:09C0:876A:130B (Active, Passive)
     Hello Hold Time: 15 sec           Hello Interval   : 5000 ms
   Ten-GigabitEthernet3/0/2 (v6)
 Label Acceptance Policy :
   prefix-from-20
   prefix-from-30(v6)
 Session Protection      : On
   State            : Ready            Duration         : 120 sec
 Addresses received from peer:
   202.118.224.20   100.100.100.20   11.22.33.44      1.2.3.10
   1.2.3.4
表1-12 display mpls ldp peer verbose命令显示信息描述表
VPN instance
Peer LDP ID
对等体的LDP标识符
Local LDP ID
本地的LDP标识符
TCP connection
该会话的TCP连接信息,即TCP连接两端的IP地址和端口号、是否使能了TCP连接的验证功能(如果使能了MD5验证,则显示MD5 On;如果使能了keychain验证,则显示Keychain On;如果未使能验证功能,则不显示任何信息)
Session State
本地LSR与对等体之间的LDP会话的状态,取值包括:
Session Role
本地LSR在会话中的角色,取值包括:
·     Active:主动方
·     Passive:被动方
Session Up time
会话处于Operational状态的持续时间
Max PDU Length
协商出来的最大PDU长度值,单位为字节
Local:本地LSR允许的最大PDU长度值,单位为字节
Peer:对等体发送的报文中携带的最大PDU长度值,单位为字节
Keepalive Time
协商出来的Keepalive时间值,单位为秒
Local:本地配置的Keepalive保持时间值,单位为秒
Peer:对等体发送的报文中携带的Keepalive时间值,单位为秒
Keepalive Interval
当前在用的Keepalive报文发送时间间隔,单位为秒
Msgs Sent/Rcvd
本地发送和接收的各种LDP消息的总数
KA Sent/Rcvd
本地发送和接收的Keepalive消息的总数
Label Adv Mode
协商后的标签通告方式,目前取值只能为DU,表示下游自主通告方式
Graceful Restart
对等体上是否使能了Graceful Restart功能,取值包括:
·     On:使能了GR功能
·     Off:未使能GR功能
Reconnect Time
协商出来的GR重连时间,单位为秒
Recovery Time
对等体发送的报文中携带的GR恢复时间,单位为秒
Loop Detection
对等体是否使能了环路检测功能,取值包括
·     On:使能了环路检测功能
·     Off:未使能环路检测功能
Path Vector Limit
对等体发送的报文中携带的路径向量最大长度值
mLDP P2MP
对等体的mLDP P2MP功能状态,取值包括:
Discovery Sources
对等体的发现源
Targeted Hello
通过扩展发现机制发现的LDP对等体
·     100.100.100.20(“->”后面的地址)为对等体的地址
运行LDP基本发现机制的接口,通过从该接口发送Link hello消息发现了LDP对等体
(v6):表示通过IPv6 Link hello消息发现对等体
Hello Hold Time
协商出来的Hello保持时间,单位为秒
Hello Interval
当前在用的Hello报文发送时间间隔,单位为毫秒
对从对等体接收的标签映射进行过滤时使用的标签接受控制策略
(v6):表示通过IPv6地址前缀列表进行过滤的标签接受控制策略
Session Protection
是否使能了会话保护功能,取值包括:
·     On:使能了会话保护功能
·     Off:未使能会话保护功能
会话保护状态,取值包括:
·     Incomplete:会话保护未准备好
·     Ready:会话保护准备就绪
·     Protecting:会话处于保护中
Duration
本地配置的会话保护持续时间,单位为秒
取值为Infinite时,表示永久保护
Holdup time remaining
会话保持剩余时间,单位为秒
取值为Infinite时,表示永久保护
会话保护处于Protecting状态时,才会显示此字段
对等体发送的地址列表
display mpls ldp summary命令用来显示LDP运行数据汇总信息。
display mpls ldp summary [ all | vpn-instance vpn-instance-name ] [ slot slot-number ]
all:显示公网和所有VPN实例的LDP汇总信息。
vpn-instance vpn-instance-name:显示指定VPN实例的LDP汇总信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
如果未指定任何参数,则显示公网LDP汇总信息。
# 显示公网LDP运行数据的汇总信息。
<Sysname> display mpls ldp summary
VPN Instance Name    : Public
  Instance ID        : 0
  Instance State     : Active
  Interfaces         : 1 (1 active)
  Targeted Peers     : 0
  Targeted Peers(v6) : 0
  Adjacencies        : 1
  Adjacencies(v6)    : 1
  Peers              : 1
    Operational : 1 (0 GR)
    OpenSent    : 0
    OpenRecv    : 0
    Initialized : 0
    Non-Existent: 0
表1-13 display mpls ldp summary命令显示信息描述表
VPN Instance Name
VPN实例名称
Instance ID
VPN实例标识,取值为0表示公网
Instance State
LDP实例的状态,取值包括:
·     Active:LDP实例已激活
·     Inactive:LDP实例未激活
Interfaces
使能了LDP能力的接口数
active:表示已经正常运行LDP协议的接口数
Targeted Peers
通过扩展发现机制发现的LDP IPv4对等体数目,包括手工指定和自动生成的对等体
Targeted Peers(v6)
通过扩展发现机制发现的LDP IPv6对等体数目,包括手工指定和自动生成的对等体
Adjacencies
IPv4 Hello邻接体的数目
Adjacencies(v6)
IPv6 Hello邻接体的数目
Peers
对等体总数
Operational
处于Operational状态下的对等体数
GR:表示使能了GR功能的对等体数
OpenSent
处于OpenSent状态下的对等体数
OpenRecv
处于OpenRecv状态下的对等体数
Initialized
处于Initialized状态下的对等体数
Non-Existent
处于Non-Existent状态下的对等体数
display mpls ldp troubleshooting命令用来显示LDP会话中断事件信息。
通过本命令可以查看LDP会话断开的原因,以方便定位和解决LDP会话中断问题。
# 显示LDP会话中断事件信息。
<Sysname> display mpls ldp troubleshooting
Total records: 1
Date and time: 2019-05-23 14:33:26
Event description:
Session (22.2.2.2:0, public instance) is down (received a fatal notification message: Keepalive timer expired). (LocalTransportAddr=11.1.1.1, PeerTransportAddr=22.2.2.2, SessionRole=Passive, SessionUpTime=0000:00:35, KeepaliveTime=45s, KeepaliveSentCount=143, KeepaliveRcvdCount=148, GracefulRestart=Off, SocketID=35, WaitSendMsgCount=0, CPUUsage=19%, MemoryState=Normal, PingResult: packets sent 9, received 0, lost 9)
表1-14 display mpls ldp troubleshooting命令显示信息描述表
Total n records
LDP会话中断事件总数
Date and time
LDP会话中断事件产生的日期和时间,格式为YYYY-MM-DD HH:MM:SS
Event Description
LDP会话中断事件描述:Session (peer-lsr-id, vpn-instance-name) is down (reason). (session-information)
·     peer-ldp-id:对等体的LDP ID。如果无法获得对等体的LDP ID,显示为0.0.0.0:0
·     vpn-instance-name:VPN实例名。如果该会话属于公网,显示为public instance
·     reason:会话失败的原因,具体内容请参见表1-15
·     session-information:LDP会话信息,具体内容请参见表1-16
表1-15 会话失败的原因
interface not operational
接口不可用
MPLS disabled on interface
接口已关闭MPLS
LDP disabled on interface
接口已关闭LDP
LDP auto-configure disabled on interface
接口已关闭LDP自动配置功能
VPN instance changed on interface
接口所属的VPN实例已更改
LDP instance deleted
LDP实例已删除
targeted peer deleted
手动删除targeted peer
L2VPN disabled targeted peer
L2VPN注销targeted peer
TE tunnel disabled targeted peer
TE隧道注销targeted peer
session protection disabled targeted peer
会话保护注销targeted peer
OSPF Remote LFA disabled targeted peer
OSPF Remote LFA注销targeted peer
IS-IS Remote LFA disabled targeted peer
IS-IS Remote LFA注销targeted peer
process deactivated
LDP进程降级
failed to receive the initialization message
未收到初始化信息
graceful restart reconnect timer expired
GR重连定时器超时
failed to recover adjacency by NSR
NSR恢复邻接关系失败
failed to upgrade session by NSR
NSR升级会话失败
closed the GR session
GR会话关闭
keepalive hold timer expired
keepalive保持时间超时
hello hold timer expired
hello保持时间超时
session reset
重启会话
TCP connection down
TCP连接断开
收到致命的通知信息
internal error
内部错误
memory in critical state
内存达到critical状态
transport address changed on interface
接口上的传输地址更改
MD5 password changed
会话MD5密码变化
表1-16 LDP会话信息
LocalTransportAddr
本地传输地址
PeerTransportAddr
对端传输地址
SessionRole
本地LSR在会话中的角色,取值为:
·     Active:主动方
·     Passive:被动方
SessionUpTime
会话处于Operational状态的持续时间,格式为DD:HH:MM
KeepaliveTime
KeepaliveSentCount
本地发送的Keepalive消息的总数
KeepaliveRcvdCount
本地接收的Keepalive消息的总数
GracefulRestart
对等体上是否使能了LDP GR功能:
·     On:表示使能
·     Off:表未使能
SocketID
会话的套接字ID
WaitSendMsgCount
等待发送的TCP消息数量
CPUusage
会话down时的CPU使用率
MemoryState
会话down时内存门限状态:
·     normal:正常
·     minor:一级门限
·     severe:二级门限
·     critical:三级门限
PingResult
开启MTP(Maintain Probe,维护探测器)功能后,ping对端传输地址的结果,包括发送的ICMP回显请求报文数、收到的ICMP响应报文数和未响应ICMP请求报文数
有关MTP功能的详细介绍,请参见“三层技术-IP路由配置指导”中的“IP路由基础”
1.1.13  dscp
dscp命令用来配置发送的LDP报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
发送的LDP报文的DSCP优先级为48。
LDP视图
dscp-value:发送的LDP报文的DSCP优先级,取值范围为0~63。
DSCP(Differentiated Services Code Point,差分服务编码点)携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。通过本命令可以指定发送的LDP报文中携带的DSCP优先级的取值。
# 配置发送的LDP报文的DSCP优先级为56。
[Sysname] mpls ldp
[Sysname-ldp] dscp 56
·     display mpls ldp parameter
entropy-label enable命令用来开启头节点LDP支持熵标签功能。
undo entropy-label enable命令用来关闭头节点LDP支持熵标签功能。
头节点LDP支持熵标签功能处于关闭状态。
LDP视图
熵标签由Ingress节点基于接收到的IP报文中的IP地址生成。中间节点可以根据熵标签进行负载分担运算,以简化中间节点的处理。
在Ingress节点上开启LDP熵标签功能后,如果Egress节点也支持LDP熵标签功能,则Ingress通过LSP向Egress转发报文时,从内到外依次为报文封装熵标签、标签值7(用来标识内层标签为熵标签)、LSP标签(下游LSR分配的标签,用来转发报文)。
# 开启头节点支持熵标签功能。
[Sysname] mpls ldp
[Sysname-ldp] entropy-label enable
graceful-restart命令用来使能LDP协议的GR功能。
undo graceful-restart命令用来关闭LDP协议的GR功能。
graceful-restart
LDP协议的GR功能处于关闭状态。
LDP视图
LDP GR(Graceful Restart,平滑重启)在LDP协议重启时,保持标签转发表项,LSR依然根据该表项转发报文,从而保证数据转发不中断。
通过graceful-restart命令使能GR功能后,不会对已建立的LDP会话生效。如果要求对已建立的会话生效,则需要执行reset mpls ldp命令重新建立LDP会话。
# 使能LDP协议的GR能力。
[Sysname] mpls ldp
[Sysname-ldp] graceful-restart
·     reset mpls ldp
graceful-restart timer命令用来配置GR转发状态保持定时器的值和GR重连超时时间。
undo graceful-restart timer命令用来恢复缺省情况。
graceful-restart timer { forwarding-hold hold-time | reconnect reconnect-time }
undo graceful-restart timer { forwarding-hold | reconnect }
GR转发状态保持定时器的值为180秒,GR重连超时时间为120秒。
LDP视图
forwarding-hold hold-time:指定GR转发状态保持定时器的值,即本地LSR控制平面重启后,本地LSR转发状态的保持时间。hold-time取值范围为60~6000,单位为秒。
reconnect reconnect-time:指定GR重连超时时间。GR重连超时时间由本地LSR发送给对等体,该值表示本地LSR期望对等体在检测到LDP会话失效后等待重建LDP会话的时间。timeout取值范围为60~300,单位为秒。
配置的GR转发状态保持定时器的值必须大于GR重连超时时间。
通过graceful-restart timer命令更改GR转发状态保持定时器的值和GR重连超时时间后,不会对已建立的LDP会话生效。如果要求对已建立的会话生效,则需要执行reset mpls ldp命令重新建立LDP会话。
# 配置转发状态保持定时器的值为200秒,GR重连超时时间为100秒。
[Sysname] mpls ldp
[Sysname-ldp] graceful-restart timer forwarding-hold 200
[Sysname-ldp] graceful-restart timer reconnect 100
·     graceful-restart
keychain-authentication all命令用来开启所有LDP会话的keychain安全认证功能。
undo keychain-authentication all命令用来关闭所有LDP会话的keychain安全认证功能。
keychain-authentication all name keychain-name
所有LDP会话的keychain认证功能处于关闭状态。
LDP视图
LDP-VPN实例视图
name keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
为了提高LDP会话的安全性,可以配置在LDP会话使用的TCP连接上采用keychain认证,来验证LDP消息的完整性。
建立LDP会话的两端必须都配置keychain认证,且两端使用的keychain中包含的key的认证算法和认证密钥必须一致,才能正常建立TCP连接,交互LDP消息。
指定或改变LDP会话使用的keychain名称后,不会对已建立的LDP会话生效。若需对已建立的会话生效,则需要执行reset mpls ldp命令重新建立会话。
对于keychain认证算法和key的标识符的范围,LDP的支持情况如下:
·     LDP支持HMAC-MD5、MD5、HMAC-SHA-256、HMAC-SM3和SM3认证算法,通过authentication-algorithm命令进行配置。
·     LDP仅支持标识符为0~63的key,通过key命令进行配置。
同一视图下,本命令与md5-authentication all命令互斥。
LDP安全认证包括LDP MD5认证和LDP keychain认证,按生效优先级从高到低的排序是:与指定对等体的LDP会话的认证配置—>通过IPv4地址前缀列表过滤的LDP会话的认证配置—>所有LDP会话的认证配置。
·     对于同一优先级的认证配置,keychain认证和MD5认证是互斥的。例如,通过md5-authentication peer-lsr-id命令对指定对等体的LDP会话配置MD5认证后,无法再通过keychain-authentication peer命令对该对等体的LDP会话配置keychain认证。
·     对于不同优先级的配置,keychain认证和MD5认证可以同时配置,但对同一对等体的LDP会话来说,只有高优先级的配置生效。例如,通过md5-authentication peer-lsr-id命令对指定对等体Peer1的LDP会话配置MD5认证后,再通过keychain-authentication all命令对所有LDP会话配置keychain认证,则Peer1的LDP会话采用MD5认证,其他对等体的LDP会话采用keychain认证。
# 开启所有LDP会话的keychain安全认证功能,使用的keychain名称为test。
[Sysname] mpls ldp
[Sysname-ldp] keychain-authentication all name test
The configuration doesn't take effect on previously established sessions.
·     authentication-algorithm(安全命令参考/keychain)
·     key(安全命令参考/keychain)
·     keychain-authentication peer
·     keychain-authentication prefix-list
·     md5-authentication all
·     reset mpls ldp
keychain-authentication peer命令用来开启与指定对等体之间的LDP会话的keychain安全认证功能。
undo keychain-authentication peer命令用来关闭与指定对等体之间的LDP会话的keychain安全认证功能。
keychain-authentication peer peer-id name keychain-name
undo keychain-authentication peer peer-id
与指定对等体之间的LDP会话的keychain安全认证功能处于关闭状态。
LDP视图
LDP-VPN实例视图
peer-id:对等体的LSR ID。
同一视图下对于同一LDP会话,本命令与md5-authentication命令互斥。
# 开启与对等体10.10.10.10之间的LDP会话的keychain安全认证功能,使用的keychain名称为test。
[Sysname] mpls ldp
[Sysname-ldp] keychain-authentication peer 10.10.10.10 name test
·     keychain-authentication all
·     reset mpls ldp
keychain-authentication prefix-list命令用来为通过IPv4地址前缀列表过滤的LDP会话开启keychain安全认证功能。
undo keychain-authentication prefix-list命令用来为通过IPv4地址前缀列表过滤的LDP会话关闭keychain安全认证功能。
keychain-authentication prefix-list prefix-list-name name keychain-name
undo keychain-authentication prefix-list prefix-list-name
通过IPv4地址前缀列表过滤的LDP会话的keychain安全认证功能处于关闭状态。
LDP视图
LDP-VPN实例视图
prefix-list-name:IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
对于keychain认证算法和key的标识符的范围,LDP支持情况如下:
同一视图下,本命令与md5-authentication prefix-list命令互斥。
# 为通过IPv4地址前缀列表aaa过滤的LDP会话开启keychain安全认证功能,使用的keychain名称为test。
[Sysname] mpls ldp
[Sysname-ldp] keychain-authentication prefix-list aaa name test
·     md5-authentication prefix-list
·     reset mpls ldp
label-distribution命令用来配置标签分发控制方式。
undo label-distribution命令用来恢复缺省情况。
label-distribution { independent | ordered }
标签分发控制方式为有序方式(ordered)。
LDP视图
LDP-VPN实例视图
independent:独立方式,即LSR可以在任意时间向与它连接的LSR通告标签映射。
ordered:有序方式,即LSR只有收到它的下游LSR通告来的特定FEC的标签映射,或该LSR是特定FEC的出口节点时,才会向它的上游LSR通告该FEC的标签映射。
有序方式的优点是,收到标签时可以确认下游的LSP已经成功建立。
独立方式的优点是,LSP收敛快,因为每个LSR都独立通告标签,不需要等待下游通告标签。
# 配置公网LDP的标签分发控制方式为独立方式。
[Sysname] mpls ldp
[Sysname-ldp] label-distribution independent
1.1.21  log enable
log enable命令用来开启LDP日志记录功能。
undo log enable命令用来关闭LDP日志记录功能。
log enable
undo log enable
LDP日志记录功能处于开启状态。
LDP视图
开启LDP日志记录功能后,当LDP的运行状况发生变化时会生成日志信息,并保存到本地文件中。
# 开启LDP日志记录功能。
[Sysname] mpls ldp
[Sysname-ldp] log enable
log record-size命令用来配置允许记录的LDP日志的最大数目。
undo log record-size命令用来恢复缺省情况。
log record-size record-size
允许记录的LDP日志的最大数目为4096。
LDP视图
record-size:允许记录的LDP日志的最大数目,取值范围为0~200000。取值为0时表示不记录LDP日志信息。
在设备上保存适量的LDP日志信息既能够满足运维的需要又能减少系统资源的消耗。通过本命令可以控制本地保存的LDP日志信息数量,以便合理利用系统资源。
# 配置允许记录的LDP日志的最大数目为1000。
[Sysname] mpls ldp
[Sysname-ldp] log record-size 1000
1.1.23  loop-detect
loop-detect命令用来开启环路检测功能。
undo loop-detect命令用来关闭环路检测功能。
loop-detect
undo loop-detect
环路检测功能处于关闭状态。
LDP视图
LDP-VPN实例视图
设备不支持LDP环路检测功能,但如果邻居支持该功能,且要求LDP会话协商时两端设备通告的环路检测参数一致,为保证与此类邻居能够建立LDP会话,需要保证本端设备上进行相同的LDP环路检测参数配置。
配置本命令后,设备仍然不支持LDP环路检测功能,仅在建立LDP会话时具有协商环路检测功能的能力。
# 开启公网LDP的环路检测功能。
[Sysname] mpls ldp
[Sysname-ldp] loop-detect
1.1.24  lsr-id
lsr-id命令用来配置LDP的LSR ID。
undo lsr-id命令用来恢复缺省情况。
lsr-id lsr-id
undo lsr-id
未配置LDP LSR ID,公网LDP和VPN实例LDP的LSR ID均为mpls lsr-id命令配置的LSR ID。
LDP视图
LDP-VPN实例视图
lsr-id:LDP的LSR ID,点分十进制格式。
公网LDP和VPN实例LDP的LSR ID选择方式为:如果在LDP视图或LDP-VPN实例视图下通过lsr-id命令配置了LDP LSR ID,则LDP的LSR ID为此命令配置的值;否则,LDP的LSR ID为mpls lsr-id命令配置的MPLS LSR ID。
同一个LDP实例内所有会话的LSR ID都相同。修改LDP实例的LSR ID配置后,该LDP实例内的所有会话将被删除重建。
公网LDP推荐使用mpls lsr-id命令配置的LSR ID。如果要使用lsr-id命令配置的LSR ID,推荐使用本地loopback接口的IP地址,以避免非loopback接口的状态down导致LSR ID对应的IP地址未被路由协议通告带来的影响。修改公网LDP的LSR ID后,所有公网LDP会话将被删除重建。
# 配置公网LDP的LSR ID为2.2.2.2。
[Sysname] mpls ldp
[Sysname-ldp] lsr-id 2.2.2.2
# 修改公网LDP的LSR ID为3.3.3.3。
[Sysname-ldp] lsr-id 3.3.3.3
All associated LDP sessions will be reset. Continue? [Y/N]:Y
·     mpls lsr-id(MPLS命令参考/MPLS基础)
1.1.25  maxhops
maxhops命令用来配置最大跳数环路检测方式下LSP的最大跳数。
undo maxhops命令用来恢复缺省情况。
maxhops hop-number
undo maxhops
最大跳数环路检测方式下LSP的最大跳数为32。
LDP视图
LDP-VPN实例视图
hop-number:最大跳数环路检测方式下LSP的最大跳数值,取值范围为1~32。
最大跳数环路检测方式的工作机制为:在传递的标签映射(或者标签请求)消息中携带跳数信息,每经过一跳该值就加一。当该值达到本命令配置的最大跳数值时即认为出现环路,终止LSP的建立过程。
请根据网络中LSR的数目和连接方式,合理选择LSP最大跳数。配置的LSP最大跳数较小时,能够快速检测并避免环路,但是要求网络中不能存在经过跳数较多的LSP;配置的LSP最大跳数较大时,允许建立经过跳数较多的LSP,但是环路检测速度较慢。
通过maxhops命令配置最大跳数环路检测方式下LSP的最大跳数后,不会对已建立的LDP会话生效。如果要求对已建立的会话生效,则需执行reset mpls ldp命令重新建立LDP会话。
# 配置公网LDP的LSP最大跳数为25。
[Sysname] mpls ldp
[Sysname-ldp] maxhops 25
·     loop-detect
·     pv-limit
md5-authentication all命令用来开启所有LDP会话的MD5安全认证功能。
undo md5-authentication all命令用来关闭所有LDP会话的MD5安全认证功能。
md5-authentication all { cipher | plain } string
所有LDP会话的MD5安全认证功能处于关闭状态。
LDP视图
LDP-VPN实例视图
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~16个字符的字符串,密文密钥为1~53个字符的字符串。
为了提高LDP会话的安全性,可以配置在LDP会话使用的TCP连接上采用MD5认证,来验证LDP消息的完整性。
本地配置的密钥必须与对等体上配置的密钥相同。否则,本地LSR和对等体之间无法建立TCP连接。
指定或改变LDP会话使用的认证密钥值后,不会对已建立的LDP会话生效。若需对已建立的会话生效,则需要执行reset mpls ldp命令重新建立会话。
同一视图下,本命令与keychain-authentication all命令互斥。
# 开启所有LDP会话的MD5安全认证功能,以明文方式设置密钥,密钥值为pass。
[Sysname] mpls ldp
[Sysname-ldp] md5-authentication all plain pass
·     reset mpls ldp
md5-authentication peer-lsr-id命令用来开启与指定对等体之间的LDP会话的MD5认证功能。
undo md5-authentication peer-lsr-id命令用来关闭与指定对等体之间的LDP会话的MD5认证功能。
md5-authentication peer-lsr-id { cipher | plain } string
与指定对等体之间的LDP会话的MD5认证功能处于关闭状态。
LDP视图
LDP-VPN实例视图
peer-lsr-id:对等体的LSR ID。
cipher:以密文方式设置密钥。
string:密钥字符串,区分大小写。明文密钥为1~32个字符的字符串,密文密钥为1~73个字符的字符串。
同一视图下对于同一LDP会话,本命令与keychain-authentication peer命令互斥。
# 配置与对等体3.3.3.3建立的LDP会话上采用MD5认证,以明文方式设置密钥,密钥值为pass。
[Sysname] mpls ldp
[Sysname-ldp] md5-authentication 3.3.3.3 plain pass
·     display mpls ldp peer
·     reset mpls ldp
md5-authentication prefix-list命令用来为通过IPv4地址前缀列表过滤的LDP会话开启MD5安全认证功能。
undo md5-authentication prefix-list命令用来为通过IPv4地址前缀列表过滤的LDP会话关闭MD5安全认证功能。
md5-authentication prefix-list prefix-list-name { cipher | plain } string
undo md5-authentication prefix-list prefix-list-name
通过IPv4地址前缀列表过滤的LDP会话的MD5安全认证功能处于关闭状态。
LDP视图
LDP-VPN实例视图
cipher:以密文方式设置密钥。
同一视图下,本命令与keychain-authentication prefix-list命令互斥。
# 为通过IPv4地址前缀列表aaa过滤的LDP会话开启MD5安全认证功能,以明文方式设置密钥,密钥值为pass。
[Sysname] mpls ldp
[Sysname-ldp] md5-authentication prefix-list aaa plain pass
·     reset mpls ldp
mpls entropy-label-capability enable命令用来开启尾节点支持熵标签功能。
undo mpls entropy-label-capability enable命令用来关闭尾节点支持熵标签功能。
尾节点支持熵标签功能处于关闭状态。
在Egress节点上开启本功能后,Egress节点将通过LDP mapping或RSVP Resv报文向上游通告熵标签能力。上游节点逐跳将该能力传递给Ingress节点。如果Ingress节点上通过entropy-label enable命令开启了熵标签功能,则Ingress和Egress节点的熵标签能力协商成功,即Ingress和Egress节点间的LSP支持熵标签功能,可以通过熵标签实现负载分担。
如果网络中有不支持熵标签能力的设备,由于这类设备无法感知熵标签能力变化,故无法重新通告熵标签能力。需要在这些设备上撤销Egress节点的环回口地址路由,再重新发布,例如在Egress节点震荡环回口、路由邻居断开重连。
# 开启尾节点支持熵标签功能。
[Sysname] mpls entropy-label-capability enable
1.1.30  mpls ldp
mpls ldp命令用来全局使能LSR的LDP能力,并进入LDP视图。
undo mpls ldp命令用来全局关闭LSR的LDP能力,并删除所有LDP实例。
mpls ldp
undo mpls ldp
LSR的全局LDP能力处于关闭状态。
只有全局使能LSR的LDP能力后,LSR上才可能正常运行LDP协议。
除了LDP的NSR、GR、会话保护功能相关命令和targeted-peer命令外,LDP视图下的命令都可以在LDP-VPN实例视图下使用。其中:
·     NSR、GR功能相关命令是全局命令,对所有LDP实例生效。
·     会话保护功能相关命令和targeted-peer命令只对公网LDP实例生效。
·     LDP视图下的命令对公网LDP实例生效。
·     LDP-VPN实例视图下的命令对指定VPN的LDP实例生效。
# 全局使能本节点的LDP能力,并进入LDP视图。
<Sysname> System-view
[Sysname] mpls ldp
[Sysname-ldp]
·     mpls ldp enable
·     vpn-instance
mpls ldp local-lsr-id命令用来配置指定接口的主IPv4地址作为LDP会话的LSR ID。
undo mpls ldp local-lsr-id命令用来恢复缺省情况。
接口视图下:
mpls ldp local-lsr-id { interface interface-type interface-number | self-interface }
LDP对等体视图下:
mpls ldp local-lsr-id interface interface-type interface-number
使用LDP实例的LSR ID作为LDP会话的LSR ID。
LDP对等体视图
interface interface-type interface-number:使用指定接口的主IPv4地址作为LSR ID。interface-type interface-number为接口类型和接口编号。
self-interface:使用当前接口的主IPv4地址作为LSR ID。
在使用LDP隧道承载L2VPN、L3VPN业务的场景中,本地所有LDP会话缺省均采用LDP实例的LSR ID建立,这样所有业务流量共用同一LDP会话建立LDP LSP,不利于不同VPN业务的隔离。通过配置本命令可以为不同的LDP会话指定不同的LSR ID,从而实现业务隔离。
·     在与直连LSR邻接建立Link Hello邻接关系时,如果与LSR邻居通过多条链路连接,则不同链路对应的接口配置的LSR ID必须相同。否则,设备将采用第一个建立Link Hello邻接关系的链路的LSR ID建立LDP会话,而其他具有不同LSR ID的链路将无法通过该LDP会话建立LDP LSP。
·     在Link Hello和Targeted Hello两种邻接关系共存的场景中,Link Hello和Targeted Hello邻接关系对应的LDP会话必须配置相同的LSR ID,否则只有首先建立邻接关系的LDP会话能够成功建立。
修改LDP会话的LSR ID配置后,所有LDP会话将被删除重建。
# 在接口Ten-GigabitEthernet3/0/1上配置当前接口的主IPv4地址作为LSR ID。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp local-lsr-id self-interface
# 在对等体3.3.3.3上配置使用接口Loopback2的主IPv4地址作为LSR ID。
[Sysname] mpls ldp
[Sysname-ldp] targeted-peer 3.3.3.3
[Sysname-ldp-peer-3.3.3.3] mpls ldp local-lsr-id interface loopback 2
# 在对等体2001::1上配置使用接口Loopback1的主IPv4地址作为LSR ID。
[Sysname] mpls ldp
[Sysname-ldp] targeted-peer 2001::1
[Sysname-ldp-peer-2001::1] mpls ldp local-lsr-id interface loopback 1
·     display mpls ldp discovery
·     lsr-id
·     targeted-peer
mpls ldp timer命令用来配置Hello保持时间、Hello报文发送时间间隔、Keepalive保持时间和Keepalive报文发送时间间隔。
undo mpls ldp timer命令用来恢复缺省情况。
mpls ldp timer { hello-hold timeout | hello-interval interval | keepalive-hold timeout | keepalive-interval interval }
undo mpls ldp timer { hello-hold | hello-interval | keepalive-hold | keepalive-interval }
Link hello保持时间为15秒、Link hello报文发送时间间隔为5秒、Targeted hello保持时间为45秒、Targeted hello报文发送时间间隔为15秒、Keepalive保持时间为45秒、Keepalive报文发送时间间隔为15秒。
LDP对等体视图
hello-hold timeout:指定Hello保持时间。Hello保持时间用来控制LSR保持与对端的Hello邻接关系的时间。LSR将本端和对端的Hello保持时间中的较小者,作为Hello保持定时器的值。如果在Hello保持定时器超时时,仍没有收到来自对端的Hello消息,则删除与对端的Hello邻接关系。timeout取值范围为1~65535,单位为秒。取值为65535表示无穷大,即永远保持与对端的Hello邻接关系。
hello-interval interval:指定Hello报文发送时间间隔。interval取值范围为1~65535,单位为秒。
keepalive-hold timeout:指定Keepalive保持时间。Keepalive保持时间用来控制LSR保持与对等体的LDP会话的时间。LSR将本端和对端的Keepalive保持时间中的较小者,作为Keepalive保持定时器的值。如果在Keepalive保持定时器超时时,仍没有收到来自对等体的任何LDP消息,则删除与该对等体的LDP会话。timeout取值范围为15~65535,单位为秒。
keepalive-interval interval:指定Keepalive报文发送时间间隔。interval取值范围为1~65535,单位为秒。
接口视图下配置的是Link hello保持时间和Link hello报文发送时间间隔;LDP对等体视图下配置的是Targeted hello保持时间和Targeted hello报文发送时间间隔。
配置了LDP会话保护、LDP over MPLS TE、MPLS L2VPN LDP PW或VPLS LDP PW后,LDP自动向指定对等体发送Targeted hello消息来建立LDP会话,如果要修改Targeted hello或Keepalive的保持时间及发送时间间隔,必须使用targeted-peer命令创建对等体,并在LDP对等体视图下进行配置。
LDP对等体上配置不同的Hello保持时间和Keepalive保持时间时,按照如下原则进行协商:
·     LDP邻居发现时,LSR比较本地配置的Hello保持时间与Hello消息中携带的对端LSR上配置的Hello保持时间,从中选择较小者作为协商后的Hello保持时间。如果协商后的Hello保持时间大于本地配置的Hello报文发送时间间隔的三倍,则Hello报文的实际发送时间间隔为本地配置的值;否则,为协商后Hello保持时间的1/3。
·     LDP会话协商时,通过交换会话初始化消息,LSR比较本地配置的Keepalive保持时间与对端LSR上配置的Keepalive保持时间,从中选择较小者作为协商后的Keepalive保持时间。如果协商后的Keepalive保持时间大于本地配置的Keepalive报文发送时间间隔的三倍,则Keepalive报文的实际发送时间间隔为本地配置的值;否则,为协商后Keepalive保持时间的1/3。
如果设置的Hello保持时间和Keepalive保持时间过大,则可能会导致LDP不能快速发现链路故障;如果设置的值过小,则可能会导致LDP错误地将未故障链路判断为故障链路。建议使用缺省值。
如果两个LSR之间存在多个邻接关系,如通过多条直连链路相连时存在多个Link hello邻接关系或同时存在Link hello和Targeted hello邻接关系时,则两个LSR之间的所有链路和LDP对等体视图下配置的Keepalive保持时间必须相同。
通过mpls ldp timer命令配置Keepalive保持时间和Keepalive报文发送时间间隔后,不会对已建立的LDP会话生效。如果要求对已建立的会话生效,则需执行reset mpls ldp命令重新建立LDP会话。
# 为对等体3.3.3.3配置Targeted hello保持时间为1000秒、Targeted hello报文的发送时间间隔为50秒、Keepalive保持时间为1000秒、Keepalive报文发送时间间隔为50秒。
[Sysname] mpls ldp
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer hello-hold 1000
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer hello-interval 50
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer keepalive-hold 1000
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer keepalive-interval 50
# 在接口Ten-GigabitEthernet3/0/1上配置Link hello保持时间为100秒、Link hello报文的发送时间间隔为20秒、Keepalive保持时间为50秒、Keepalive报文发送时间间隔为10秒。
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp timer hello-hold 100
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp timer hello-interval 20
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp timer keepalive-hold 50
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp timer keepalive-interval 10
propagate mapping命令用来配置Transit LSP的触发策略。
undo propagate mapping命令用来恢复缺省情况。
propagate mapping { all | none | prefix-list prefix-list-name }
只有引入到LDP的32位掩码的IPv4主机路由能够触发建立Transit LSP。
LDP视图
LDP-VPN实例视图
all:所有引入到LDP的路由表项都会触发建立Transit LSP。
none:所有引入到LDP的路由表项都不会触发建立Transit LSP。
prefix-list prefix-list-name:利用IPv4地址前缀列表对引入到LDP的路由表项进行过滤。通过IPv4地址前缀列表过滤的路由表项可以触发建立Transit LSP;被IPv4地址前缀列表拒绝的路由表项无法触发建立Transit LSP。prefix-list-name表示IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
Transit LSP触发策略用来控制引入到LDP的路由中哪些路由可以建立Transit LSP。
在非必要的情况下,建议用户采用缺省的Transit LSP触发策略,以免建立过多的Transit LSP,占用系统和网络资源。
建立Transit LSP时会同时建立Ingress LSP。
当同时配置lsp-trigger命令和propagate mapping命令时,Transit LSP的建立由propagate mapping命令决定,不受lsp-trigger命令控制。
# 配置只有引入到LDP中的网段路由10.10.1.0/24和10.20.1.0/24能够触发建立Transit LSP。
[Sysname] ip prefix-list transit-fec-list index 1 permit 10.10.1.0 24
[Sysname] ip prefix-list transit-fec-list index 2 permit 10.20.1.0 24
[Sysname] mpls ldp
[Sysname-ldp] propagate mapping prefix-list transit-fec-list
·     lsp-trigger
1.1.34  pv-limit
pv-limit命令用来配置路径向量环路检测方式下LSP的最大跳数。
undo pv-limit命令用来恢复缺省情况。
pv-limit pv-number
undo pv-limit
路径向量环路检测方式下LSP的最大跳数为32。
LDP视图
LDP-VPN实例视图
pv-number:路径向量环路检测方式下LSP的最大跳数,取值范围为1~32。
路径向量环路检测方式的工作机制为:
·     在传递的标签映射(或者标签请求)消息中记录路径信息,即记录经过的每一跳LSR的LSR ID。每个LSR接收到标签映射(或者标签请求)消息后,都会检查自己的LSR ID是否在记录的路径信息中。如果路径信息中没有本LSR的LSR ID,LSR就会将自己的LSR ID添加到其中;如果已存在本LSR的LSR ID,则认为出现环路,终止LSP的建立过程。
·     采用路径向量方式进行环路检测时,也需要规定LSP的最大跳数。当路径信息中的LSR ID数目达到本命令配置的最大跳数值时,也会认为出现环路,终止LSP的建立过程。
通过pv-limit命令配置路径向量环路检测方式下LSP的最大跳数后,不会对已建立的LDP会话生效。如果要求对已建立的会话生效,则需执行reset mpls ldp命令重新建立LDP会话。
# 设置公网LDP路径向量环路检测方式下LSP的最大跳数为3。
[Sysname] mpls ldp
[Sysname-ldp] pv-limit 3
·     loop-detect
·     maxhops
reset mpls ldp命令用来重启LDP会话。
reset mpls ldp [ vpn-instance vpn-instance-name ] [ peer peer-id ]
vpn-instance vpn-instance-name:重启指定LDP实例的会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则重启公网LDP实例的会话。
peer peer-id:重启与指定对等体之间的LDP会话。peer-id为对等体的LSR ID。如果不指定本参数,则重启公网或指定LDP实例中的所有会话。
重启LDP会话后,指定的LDP会话将会被删除并重新建立,基于该LDP会话建立的LSP也将删除并重新建立。
修改LDP会话参数后,可以通过执行reset mpls ldp命令重启公网或指定LDP实例中的所有会话,使新配置的LDP参数生效。如果指定peer参数,则仅重启与指定对等体之间的LDP会话,新配置的LDP参数不会生效。
# 重启公网LDP实例的所有会话。
<Sysname> reset mpls ldp
# 重启VPN实例vpn1的所有LDP会话。
<Sysname> reset mpls ldp vpn-instance vpn1
snmp-agent trap enable ldp命令用来开启LDP模块的告警功能。
undo snmp-agent trap enable ldp命令用来关闭LDP模块的告警功能。
LDP模块的告警功能处于开启状态。
开启LDP模块的告警功能后,当LDP会话状态发生变化时会产生RFC 3815中规定的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启LDP模块的告警功能。
[Sysname] snmp-agent trap enable ldp
snmp-agent trap enable ldp-private命令用来开启LDP模块的私有告警功能。
undo snmp-agent trap enable ldp-private命令用来关闭LDP模块的私有告警功能。
LDP模块的私有告警功能处于关闭状态。
开启LDP模块的私有告警功能后,多链路配置检查完成(即LDP对等体之间存在多条链路时,不同链路所在接口上的LDP配置一致性检查完成)时,会产生告警信息。这些告警信息未在RFC中规定,是Comware私有的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
执行本命令时,如果未指定任何参数,则表示开启或关闭LDP模块的所有私有告警功能。
# 开启LDP模块的所有私有告警功能。
[Sysname] snmp-agent trap enable ldp-private
·     snmp-agent trap enable ldp
1.1.38  vpn-instance
vpn-instance命令用来使能指定VPN实例的LDP能力,为该VPN创建LDP实例,并进入LDP-VPN实例视图。如果指定VPN的LDP实例已经存在,则直接进入LDP-VPN实例视图。
undo vpn-instance命令用来删除指定VPN的LDP实例。
undo vpn-instance vpn-instance-name
VPN实例的LDP能力处于关闭状态。
LDP视图
vpn-instance-name:VPN实例名称,为1~31个字符的字符串,区分大小写。本参数所指定的VPN实例必须已经通过系统视图下的ip vpn-instance命令创建。
为VPN创建LDP实例主要用于一级运营商PE与二级运营商PE之间采用LDP协议的“运营商的运营商”组网环境。在此组网中,一级运营商PE上需要为每个VPN配置相应的LDP实例。
除了LDP的DSCP、NSR、GR、IGP同步功能相关命令、会话保护功能相关命令和targeted-peer命令外,LDP视图下的命令都可以在LDP-VPN实例视图下使用。其中:
·     DSCP、NSR、GR功能相关命令是全局命令,对所有LDP实例生效。
·     IGP同步功能相关命令、会话保护功能相关命令和targeted-peer命令只对公网LDP实例生效。
# 使能VPN实例vpn1的LDP能力,为该VPN创建LDP实例,并进入LDP-VPN实例视图。
[Sysname] mpls ldp
[Sysname-ldp] vpn-instance vpn1
[Sysname-ldp-vpn-instance-vpn1]
·     ip vpn-instance(MPLS命令参考/MPLS L3VPN)
·     mpls ldp
1.2  LDP IPv4配置命令
1.2.1  accept-label
accept-label命令用来配置标签接受控制策略。
undo accept-label命令用来删除指定的标签接受控制策略。
accept-label peer peer-lsr-id prefix-list prefix-list-name
undo accept-label peer peer-lsr-id
未配置标签接受控制策略,接受来自所有对等体的所有IPv4地址前缀的标签映射。
LDP视图
LDP-VPN实例视图
peer peer-lsr-id:指定LDP对等体。peer-lsr-id为LDP对等体的LSR ID。
prefix-list prefix-list-name:指定用来对收到的IPv4地址前缀标签映射进行过滤的IPv4地址前缀列表。prefix-list-name表示IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
当LSR接收到的标签映射数量较大时,可以配置标签接受控制策略对来自特定对等体的标签映射进行过滤,减少LSR接受的标签映射数量,降低设备内存等资源的消耗。配置标签接受控制策略后,对于来自指定对等体的标签映射,只有标签映射中FEC的IPv4地址前缀通过指定IPv4地址前缀列表的过滤时,LSR才接受该标签映射,否则LSR不会接受且不会保存该标签映射。
当LSR上配置的标签接受控制策略发生变化,使得LSR可以接受来自特定对等体的、以前被拒绝的标签映射时(如执行undo accept-label命令删除标签接受控制策略,或者将IPv4地址前缀列表的过滤条件修改得更宽松时),只有执行reset mpls ldp命令重建与特定对等体的LDP会话,触发指定对等体重新通告标签映射,LSR才能获取之前拒绝的标签映射。
在下游LSR上配置标签通告控制策略与在上游LSR上配置标签接受控制策略具有相同的效果。如果下游LSR支持配置标签通告控制策略,则推荐使用标签通告控制策略,以减轻网络负担。
# 对于LSR ID为1.1.1.9的LDP对等体通告的标签映射,只接受IPv4地址前缀属于10.1.1.0/24和10.2.1.0/24网段的标签映射。
[Sysname] ip prefix-list prefix-from-RTA index 1 permit 10.1.1.0 24
[Sysname] ip prefix-list prefix-from-RTA index 2 permit 10.2.1.0 24
[Sysname] mpls ldp
[Sysname-ldp] accept-label peer 1.1.1.9 prefix-list prefix-from-RTA
·     display mpls ldp peer verbose
advertise-label命令用来配置标签通告控制策略。
undo advertise-label命令用来删除指定的标签通告控制策略。
advertise-label prefix-list prefix-list-name [ peer peer-prefix-list-name ]
undo advertise-label prefix-list prefix-list-name
未配置标签通告控制策略,即向所有对等体通告满足LSP触发策略的所有IPv4地址前缀的标签映射。
LDP视图
LDP-VPN实例视图
prefix-list prefix-list-name:指定用来对将要通告的标签映射进行过滤的IPv4地址前缀列表。prefix-list-name表示IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
peer peer-prefix-list-name:指定用来对LDP对等体进行过滤的IPv4地址前缀列表。peer-prefix-list-name表示IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。如果不指定本参数,则表示向所有对等体通告标签映射。
标签通告控制策略用来实现对本地LSR向对等体通告的标签映射进行过滤。
多次执行本命令,可以配置多条标签通告控制策略。
LSR按照下面的规则来判断是否向特定对等体通告标签:
·     如果待通告的标签映射的IPv4地址前缀没有通过IPv4地址前缀列表的检查(没有匹配任何一条permit规则或匹配了deny规则),则不向任何对等体通告该标签映射。
·     如果待通告的标签映射的IPv4地址前缀通过某个IPv4地址前缀列表的检查,且对应标签通告控制策略中的对等体IPv4地址前缀列表为空(只配置advertise-label prefix-list prefix-list-name,未指定peer peer-prefix-list-name),则向所有对等体通告该标签映射。
·     如果待通告的标签映射的IPv4地址前缀通过某个IPv4地址前缀列表的检查,且对应标签通告控制策略中指定了对等体IPv4地址前缀列表,则只向通过对等体IPv4地址前缀列表检查的对等体通告该标签映射。
·     如果待通告的标签映射的IPv4地址前缀通过多于一个IPv4地址前缀列表的检查(多次执行advertise-label命令配置多条标签通告控制策略),则以配置的第一条命令为准。
# 配置标签通告控制策略:向LSR ID为3.3.3.9的对等体通告网段地址10.1.1.0/24对应的标签映射;向LSR ID为4.4.4.9的对等体通告网段地址10.2.1.0/24对应的标签映射;不通告其他网段地址对应的标签映射。
[Sysname] ip prefix-list prefix-to-C permit 10.1.1.0 24
[Sysname] ip prefix-list prefix-to-D permit 10.2.1.0 24
[Sysname] ip prefix-list peer-C permit 3.3.3.9 32
[Sysname] ip prefix-list peer-D permit 4.4.4.9 32
[Sysname] mpls ldp
[Sysname-ldp] advertise-label prefix-list prefix-to-C peer peer-C
[Sysname-ldp] advertise-label prefix-list prefix-to-D peer peer-D
·     display mpls ldp fec
·     lsp-trigger
display mpls ldp igp sync命令用来显示LDP IGP同步信息。
display mpls ldp igp sync [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的LDP IGP同步信息。interface-type interface-number为接口类型和接口编号。如果不指定本参数,则显示所有接口的LDP IGP同步信息。
# 显示所有接口的LDP IGP同步信息。
<Sysname> display mpls ldp igp sync
Ten-GigabitEthernet3/0/2:
  IGP protocols: OSPF
  Sync status: Ready
  Peers:
    10.1.1.2:0
Ten-GigabitEthernet3/0/3:
  IGP protocols: OSPF, IS-IS
  Sync status: Delayed (24 sec remaining)
  Peers:
    20.1.1.2:0
Ten-GigabitEthernet3/0/4:
  LDP-IGP synchronization is disabled on the interface
表1-17 display mpls ldp igp sync命令显示信息描述表
IGP protocols
要求LDP IGP同步的IGP协议,取值包括OSPF、IS-IS
Sync status
接口上的LDP IGP同步状态,取值包括:
·     Ready:LDP已收敛,可以被IGP使用
·     Delayed:满足LDP收敛条件,但处于IGP延迟等待期间,remaining为延迟剩余时间,单位为秒
·     Not ready:LDP未收敛,不可以被IGP使用
·     LDP not enabled:接口上未使能LDP
Peers
接口上已收敛的LDP对等体
接口上的LDP IGP同步功能处于关闭状态
igp sync delay命令用来配置向IGP通知LDP已收敛的延迟时间。
undo igp sync delay命令用来恢复缺省情况。
igp sync delay time
undo igp sync delay
LDP收敛后立即通知IGP。
LDP视图
time:向IGP通知LDP收敛的延迟时间,取值范围为5~300,单位为秒。
同时满足如下条件时,设备认为LDP在某条链路上已收敛:
·     在该链路上本地设备至少与一个对等体建立了LDP会话,且该LDP会话已进入operational状态。
·     在该链路上本地设备至少向一个对等体发送完标签映射。
缺省情况下,LDP在某条链路上收敛后立即通知IGP,以便IGP发布该链路的正常开销值。但是,在某些情况下,LDP收敛后立即通知IGP,可能会导致MPLS流量转发中断,例如:
·     对等体的标签分发控制方式为有序方式时,LDP会话进入operational状态后,设备需要等待下游的标签映射。如果尚未收到下游的标签映射就向IGP通知LDP收敛,则可能导致MPLS流量转发中断。
·     下游的标签映射比较多时,如果LDP收敛后立即通知IGP,则下游的标签映射可能尚未通告完成,导致MPLS流量转发中断。
在这些情况下,需要通过本命令配置恰当的延迟通知时间,即LDP在某条链路上收敛后,等待延迟时间再通知IGP,以最大限度地缩短MPLS流量中断的时间。
# 配置LDP收敛后延迟通知IGP的时间为30秒。
[Sysname] mpls ldp
[Sysname-ldp] igp sync delay 30
·     igp sync delay on-restart
·     mpls ldp igp sync disable
·     mpls ldp sync (IS-IS view)
·     mpls ldp sync (OSPF view/OSPF area view)
igp sync delay on-restart命令用来配置在LDP协议重启或倒换后,向IGP通告LDP IGP同步状态的最大延迟时间。
undo igp sync delay on-restart命令用来恢复缺省情况。
igp sync delay on-restart time
在LDP协议重启或倒换后,向IGP通告LDP IGP同步状态的最大延迟时间为90秒。
LDP视图
time:在LDP协议重启或倒换后,向IGP通告LDP IGP同步状态的最大延迟时间,取值范围为60~600,单位为秒。
LDP协议重启或倒换后,需要等待一段时间LDP才会收敛。如果在协议重启或倒换后,LDP立即将当前所有的LDP IGP同步状态通知给IGP,在LDP收敛后再更新这些状态,则可能会导致IGP频繁地根据不同的同步状态进行处理,增加了IGP的处理开销。
LDP协议重启或倒换后的延迟通知机制可以用来解决上述问题。该机制提供了LDP进程级别的延迟通知时间,即在LDP协议重启或倒换的情况下,等待LDP恢复到重启或倒换前的收敛状态后,再批量通知LDP IGP同步状态,以减少IGP的处理开销。如果到达本命令指定的最大延迟时间时,仍未恢复之前的收敛状态,则立即向IGP批量通告当前的LDP IGP同步状态。
# 配置LDP协议重启或倒换后,向IGP通告LDP IGP同步状态的最大延迟时间为300秒。
[Sysname] mpls ldp
[Sysname-ldp] igp sync delay on-restart 300
·     igp sync delay
1.2.6  import bgp
import bgp命令用来配置LDP引入BGP IPv4单播路由。
undo import bgp命令用来恢复缺省情况。
import bgp [ as-number ]
undo import bgp
LDP不主动引入BGP IPv4单播路由。
LDP视图
LDP-VPN实例视图
as-number:引入指定AS内的BGP IPv4单播路由。as-number为AS号,取值范围为1~4294967295。如果不指定本参数,则表示引入所有的BGP IPv4单播路由。
提示
配置此命令后,可能会导致LDP引入大量的BGP IPv4单播路由,占用设备的标签、内存资源等问题,建议仅在必要时使用此命令。
缺省情况下,LDP自动引入IPv4 IGP路由(包括已引入到IGP的BGP IPv4单播路由),并为通过LSP触发策略的IGP路由和通过LSP触发策略的带标签BGP路由分配标签,但不自动引入未被引入到IGP的BGP IPv4单播路由。这就导致了在一些特殊的组网环境下,如在运营商的运营商组网中,如果一级运营商的PE与二级运营商CE之间未配置OSPF、IS-IS等IGP协议,则无法通过LDP为BGP IPv4单播路由分配标签,因而无法建立LDP LSP。有关运营商的运营商组网的详细信息,请参见“MPLS配置指导”中的“MPLS L3VPN”。
通过配置LDP引入BGP IPv4单播路由,可将BGP IPv4单播路由强制引入至LDP,如果该路由通过LSP触发策略,则为其分配标签建立LSP。
# 在公网LDP实例下,配置LDP主动引入AS号为100的BGP IPv4单播路由。
[Sysname] mpls ldp
[Sysname-ldp] import bgp 100
·     lsp-trigger
1.2.7  lsp-trigger
lsp-trigger命令用来配置IPv4 FEC的LSP触发策略。
undo lsp-trigger命令用来恢复缺省情况。
lsp-trigger { all | mapping | prefix-list prefix-list-name }
undo lsp-trigger
只有引入到LDP的32位掩码的IPv4主机路由能够触发建立LSP。
LDP视图
LDP-VPN实例视图
all:所有引入到LDP的路由表项都会触发LDP建立LSP。对于Loopback接口,仅32位掩码的路由可以触发LDP建立LSP。
mapping:引入到LDP且已经收到下游通告的标签映射的路由表项会触发LDP建立LSP。
prefix-list prefix-list-name:利用IPv4地址前缀列表对引入到LDP的路由表项进行过滤,通过IPv4地址前缀列表过滤的路由表项可以触发建立LSP,被IPv4地址前缀列表拒绝的路由表项不触发建立LSP。prefix-list-name表示IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
LSP触发策略用来控制引入到LDP的路由中的哪些路由可以建立LDP LSP。
在非必要的情况下,建议用户采用缺省的LSP触发策略,以免建立过多的LSP,占用系统和网络资源。
缺省情况下,LSP的触发策略与标签分发控制方式有关:
·     有序方式下:只有32位掩码的本地Loopback接口地址路由和已经收到下游通告的标签映射且掩码为32位的路由可以触发建立LDP LSP。
·     独立方式下:只要是32位掩码的路由都会触发建立LDP LSP。
配置mapping触发策略后,LSP的触发策略也与标签分发控制方式有关:
·     有序方式下:32位掩码的本地Loopback接口地址路由和已经收到下游通告的标签映射的路由可以触发建立LDP LSP。
·     独立方式下:32位掩码的路由和已经收到下游通告的标签映射的路由都会触发建立LDP LSP。
配置all或prefix-list触发策略后,引入到LDP中的所有路由或通过IPv4地址前缀列表的路由都会触发建立LDP LSP,独立和有序标签分发控制方式的处理没有差别。
# 配置公网LDP实例中只有引入到LDP中的网段路由10.10.1.0/24和10.20.1.0/24能够触发建立LDP LSP。
[Sysname] ip prefix-list egress-fec-list index 1 permit 10.10.1.0 24
[Sysname] ip prefix-list egress-fec-list index 2 permit 10.20.1.0 24
[Sysname] mpls ldp
[Sysname-ldp] lsp-trigger prefix-list egress-fec-list
·     import bgp
mpls ldp enable命令用来使能接口的LDP支持IPv4能力。
undo mpls ldp enable命令用来关闭接口的LDP支持IPv4能力。
mpls ldp enable
接口的LDP支持IPv4能力处于关闭状态。
如果在接口上使能了MPLS能力和LDP支持IPv4能力,且该接口处于up状态,则LDP会在该接口上启动基本发现机制,通过该接口发送IPv4 Link hello消息。
在LDP over MPLS TE组网环境下,如果在MPLS TE隧道接口上使能了LDP能力,且MPLS TE隧道接口处于up状态,则LDP将启动扩展发现机制,向隧道目的地址发送Targeted hello消息,尝试建立跨越MPLS TE隧道的LDP会话,以建立承载在MPLS TE隧道之上的LDP LSP。
执行本命令前,需要先在系统视图下执行mpls ldp命令全局使能LSR的LDP能力。如果接口已与某个VPN实例绑定,还需要通过vpn-instance命令使能此VPN实例的LDP能力。
关闭接口的LDP能力将会导致接口下的所有LDP会话中断,基于这些会话的所有LSP也将被删除。
同一接口上既可以通过配置mpls ldp enable使能LDP支持IPv4能力,也可以通过配置mpls ldp ipv6 enable使能LDP支持IPv6能力。
# 在接口Ten-GigabitEthernet3/0/1上使能LDP支持IPv4能力。
[Sysname] mpls ldp
[Sysname-ldp] quit
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp enable
·     display mpls ldp interface
·     mpls enable(MPLS命令参考/MPLS基本配置)
·     mpls ldp
mpls ldp igp sync disable命令用来关闭接口的LDP IGP同步功能。
undo mpls ldp igp sync disable命令用来开启接口的LDP IGP同步功能。
接口上的LDP IGP同步功能处于开启状态。
在IGP协议(如OSPF区域、IS-IS进程)下使能LDP IGP同步功能后,与该IGP实例相关的接口上将使能LDP IGP同步功能。如果某个接口不希望使能LDP IGP同步功能,则可以通过在该接口上执行mpls ldp igp sync diasable命令关闭当前接口的LDP IGP同步功能。
# 关闭接口Ten-GigabitEthernet3/0/1的LDP IGP同步功能。
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp igp sync disable
mpls ldp sync命令用来使能LDP IS-IS同步功能。
undo mpls ldp sync命令用来关闭LDP IS-IS同步功能。
mpls ldp sync [ level-1 | level-2 ]
undo mpls ldp sync [ level-1 | level-2 ]
LDP IS-IS同步功能处于关闭状态。
IS-IS视图
level-1:在Level-1使能LDP IS-IS同步功能。
level-2:在Level-2使能LDP IS-IS同步功能。
LDP基于IGP最优路由建立LSP,LDP和IGP不同步可能导致MPLS流量转发中断。LDP IGP同步功能用来解决上述问题。
启用LDP IGP同步功能后,只有LDP在某条链路上收敛,IGP才会为这条链路通告正常的开销值,否则通告链路开销的最大值,使得这条链路在IGP拓扑中可见,但是在其它链路可用的情况下,IGP不会将该链路选为最优路由,从而确保设备收到MPLS报文时,不会因为最优路由上的LDP LSP没有建立而丢弃MPLS报文。
使用isis命令创建IS-IS进程时,如果通过vpn-instance vpn-instance-name参数指定了IS-IS进程所属的VPN实例,则该IS-IS进程下不能通过本命令使能LDP IGP同步功能。
如果不指定level-1或level-2,则同时使能Level-1和Level-2的LDP IS-IS同步功能。
在同一个IS-IS进程下,多次执行本命令,最后一次执行的命令生效。例如,执行mpls ldp sync命令同时使能Level-1和Level-2的LDP IS-IS同步功能后,如果再执行mpls ldp sync level-1命令,则使能Level-1的LDP IS-IS同步功能,关闭Level-2的LDP IS-IS同步功能。
# 在IS-IS进程1的Level-2上使能LDP IS-IS同步功能。
[Sysname] isis 1
[Sysname-isis-1] mpls ldp sync level-2
·     display mpls ldp igp sync
·     igp sync delay
mpls ldp sync命令用来使能LDP OSPF同步功能。
undo mpls ldp sync命令用来关闭LDP OSPF同步功能。
mpls ldp sync
undo mpls ldp sync
LDP OSPF同步功能处于关闭状态。
OSPF视图
OSPF区域视图
使用ospf命令创建OSPF进程时,如果通过vpn-instance vpn-instance-name参数指定了OSPF进程所属的VPN实例,则该OSPF进程下、该进程的OSPF区域下不能配置LDP IGP同步功能。
如果在OSPF进程下执行本命令,则该OSPF进程下的所有区域都使能LDP OSPF同步功能;如果在OSPF区域下执行本命令,则只在该区域下使能LDP OSPF同步功能。
# 在OSPF进程1上使能LDP OSPF同步功能。
[Sysname] ospf 1
[Sysname-ospf-1] mpls ldp sync
·     igp sync delay
mpls ldp transport-address命令用来配置LDP传输地址。
undo mpls ldp transport-address命令用来取消对LDP传输地址的配置。
接口视图下:
mpls ldp transport-address { ipv4-address | interface }
undo mpls ldp transport-address { ipv4-address | interface }
LDP对等体视图下:
mpls ldp transport-address ipv4-address
接口视图下:
接口属于公网,则传输地址是本LSR的LSR ID;
接口属于某个VPN,则传输地址是本接口的主IPv4地址。
对等体视图下:
传输地址为LSR的LSR ID。
LDP对等体视图
ipv4-address:LDP使用此地址作为LDP传输地址。
interface:LDP使用当前接口的IPv4地址作为LDP传输地址。
在两个LSR之间建立LDP会话之前,需要先建立TCP连接。本命令配置的LDP传输地址就是LSR建立用于LDP会话的TCP连接时使用的地址。
建议用户不要修改LDP IPv4的传输地址,采用传输地址的缺省值。
当两个LSR之间存在多条链路时,如果要在这多条链路上都建立LDP会话,则所有链路上配置的传输地址必须相同。
# 配置与对等体3.3.3.3建立TCP连接时采用的LDP传输地址为2.2.2.2,即向对等体3.3.3.3发送的Targeted hello消息中携带的传输地址为2.2.2.2。
[Sysname] mpls ldp
[Sysname-ldp-peer-3.3.3.3] mpls ldp transport-address 2.2.2.2
# 在接口Ten-GigabitEthernet3/0/1上配置Link hello消息中携带的传输地址为本接口的IP地址。
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp transport-address interface
·     targeted-peer
session protection命令用来使能会话保护功能。
undo session protection命令用来关闭会话保护功能。
session protection [ duration time ] [ peer peer-prefix-list-name ]
会话保护功能处于关闭状态。
LDP视图
duration time:会话保护持续时间,取值范围为30~2147483,单位为秒。如果不指定本参数,则会话保护永久持续。
peer peer-prefix-list-name:指定被保护的LDP会话。只有对等体的LSR ID通过IP地址前缀列表过滤时,才会保护本端与该对等体之间的会话。peer-prefix-list-name表示IP地址前缀列表名,为1~63个字符的字符串,区分大小写。如果不指定本参数,则表示保护所有通过基本发现机制建立的LDP会话。
会话保护功能实现了基本发现机制失效时,利用扩展发现机制来保持与对等体的会话,确保基本发现机制恢复时,LDP协议能够快速收敛。会话保护功能主要应用在LDP对等体之间存在直连(只有一跳)和非直连(多于一跳)多条路径的组网环境中。
使能与指定对等体的会话保护功能后,如果通过Link hello消息发现了该直连的LDP对等体,则本地LSR不仅与其建立Link hello邻接关系,还会向该对等体发送Targeted hello消息,与其建立Targeted hello邻接关系。当直连链路出现故障时,Link hello邻接关系将被删除。如果此时非直连链路正常工作,则Targeted hello邻接关系依然存在,因此,LDP会话不会被删除,基于该会话的FEC—标签映射等信息也不会删除。直连链路恢复后,不需要重新建立LDP会话、重新学习FEC—标签映射等信息,从而加快了LDP收敛速度。
使能会话保护功能时,还可以指定会话保护持续时间,即Link hello邻接关系被删除后,保留Targeted hello邻接关系的时间。如果在会话保护持续时间内,Link hello邻接关系没有恢复,则删除Targeted hello邻接关系,对应的LDP会话也将被删除。如果未指定会话保护持续时间,则永远不会删除Targeted hello邻接关系。
# 配置保护本端与LSR ID为3.3.3.3的对等体之间的LDP会话,会话保护持续时间为120秒。
[Sysname] ip prefix-list protected-peer-list index 1 permit 3.3.3.3 32
[Sysname] mpls ldp
[Sysname-ldp] session protection duration 120 peer protected-peer-list
1.2.14  targeted-peer
targeted-peer命令用来配置主动向指定对等体发送IPv4 Targeted hello消息来建立LDP会话,允许应答指定对等体的Targeted hello消息,并进入LDP对等体视图。如果指定的Targeted peer已经存在,则直接进入LDP对等体视图。
undo targeted-peer命令用来取消向指定对等体发送IPv4 Targeted hello消息。
targeted-peer ipv4-address [ peer-name ]
undo targeted-peer ipv4-address
设备不会主动向对等体发送IPv4 Targeted hello消息,也不会应答对等体的IPv4 Targeted hello消息。
LDP视图
ipv4-address:对等体的IPv4地址。
peer-name:指定Targeted peer的名称。未指定本参数时,使用ipv4-address作为Targeted peer的名称。不同IPv4地址不能配置相同的Targeted peer名称。
使用targeted-peer ipv4-address命令配置指定目的IPv4地址的对等体时,如果不配置传输地址,LDP默认会使用LSR ID作为传输地址,发送IPv4 Targeted hello消息。
若要成功建立IPv4 Targeted hello邻接关系,需保证对等体两端配置的一致性,即在本端使用targeted-peer ipv4-address命令配置的目的地址需为对端在对等体视图下配置的传输地址,并保证本端传输地址与目的地址之间路由可达。
配置了LDP会话保护、LDP over MPLS TE、MPLS L2VPN LDP PW或VPLS LDP PW后,LDP自动向指定对等体发送Targeted hello消息来建立LDP会话,如果要修改Targeted hello或KeepAlive的保持时间及发送时间间隔,必须使用targeted-peer命令创建对等体,并在LDP对等体视图下进行配置。
# 配置向对等体3.3.3.3发送IPv4 Targeted hello消息,并进入LDP对等体视图。
[Sysname] mpls ldp
1.3  LDP IPv6配置命令
1.3.1  ipv6 accept-label
ipv6 accept-label命令用来配置标签接受控制策略。
undo ipv6 accept-label命令用来删除指定的标签接受控制策略。
ipv6 accept-label peer peer-lsr-id prefix-list prefix-list-name
undo ipv6 accept-label peer peer-lsr-id
未配置标签接受控制策略,接受来自所有对等体的所有IPv6地址前缀的标签映射。
LDP视图
LDP-VPN实例视图
prefix-list prefix-list-name:指定用来对收到的IPv6地址前缀标签映射进行过滤的IPv6地址前缀列表。prefix-list-name表示IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。
当LSR接收到的标签映射数量较大时,可以配置标签接受控制策略对来自特定对等体的标签映射进行过滤,减少LSR接受的标签映射数量,降低设备内存等资源的消耗。配置标签接受控制策略后,对于来自指定对等体的标签映射,只有标签映射中FEC的IPv6地址前缀通过指定IPv6地址前缀列表的过滤时,LSR才接受该标签映射,否则LSR不会接受且不会保存该标签映射。
当LSR上配置的标签接受控制策略发生变化,使得LSR可以接受来自特定对等体的、以前被拒绝的标签映射时(如执行undo ipv6 accept-label命令删除标签接受控制策略,或者将IPv6地址前缀列表的过滤条件修改得更宽松时),只有执行reset mpls ldp命令重建与特定对等体的LDP会话,触发指定对等体重新通告标签映射,LSR才能获取之前拒绝的标签映射。
# 对于LSR ID为1.1.1.9的LDP对等体通告的标签映射,允许地址前缀为2001:D00::/32,前缀长度大于等于32位的IPv6地址的标签映射。
[Sysname] ipv6 prefix-list prefix-from-RTA permit 2001:D00:: 32 less-equal 128
[Sysname] mpls ldp
[Sysname-ldp] ipv6 accept-label peer 1.1.1.9 prefix-list prefix-from-RTA
·     ipv6 prefix-list(三层技术-IP路由命令参考/路由策略)
1.3.2  ipv6 advertise-label
ipv6 advertise-label命令用来配置标签通告控制策略。
undo ipv6 advertise-label命令用来删除指定的标签通告控制策略。
ipv6 advertise-label prefix-list prefix-list-name [ peer peer-prefix-list-name ]
undo ipv6 advertise-label prefix-list prefix-list-name
未配置标签通告控制策略,即向所有对等体通告满足LSP触发策略的所有IPv6地址前缀的标签映射。
LDP视图
LDP-VPN实例视图
prefix-list prefix-list-name:指定用来对将要通告的标签映射进行过滤的IPv6地址前缀列表。prefix-list-name表示IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。
peer peer-prefix-list-name:指定用来对LDP对等体进行过滤的IPv6地址前缀列表。peer-prefix-list-name表示IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。如果不指定本参数,则表示向所有对等体通告标签映射。
·     如果待通告的标签映射的IPv6地址前缀没有通过IPv6地址前缀列表的检查(没有匹配任何一条permit规则或匹配了deny规则),则不向任何对等体通告该标签映射。
·     如果待通告的标签映射的IPv6地址前缀通过某个IPv6地址前缀列表的检查,且对应标签通告控制策略中的对等体IPv6地址前缀列表为空(只配置ipv6 advertise-label prefix-list prefix-list-name,未指定peer peer-prefix-list-name),则向所有对等体通告该标签映射。
·     如果待通告的标签映射的IPv6地址前缀通过某个IPv6地址前缀列表的检查,且对应标签通告控制策略中指定了对等体IPv6地址前缀列表,则只向通过对等体IPv6地址前缀列表检查的对等体通告该标签映射。
·     如果待通告的标签映射的IPv6地址前缀通过多于一个IPv6地址前缀列表的检查(多次执行ipv6 advertise-label命令配置多条标签通告控制策略),则以配置的第一条命令为准。
# 配置标签通告控制策略:向LSR ID为3.3.3.9的对等体通告网段地址2001::1/64对应的标签映射;向LSR ID为4.4.4.9的对等体通告网段地址3001::1/64对应的标签映射;不通告其他网段地址对应的标签映射。
[Sysname] ipv6 prefix-list prefix-to-C permit 2001::1 64
[Sysname] ipv6 prefix-list prefix-to-D permit 3001::1 64
[Sysname] mpls ldp
[Sysname-ldp] ipv6 advertise-label prefix-list prefix-to-C peer peer-C
[Sysname-ldp] ipv6 advertise-label prefix-list prefix-to-D peer peer-D
·     ipv6 lsp-trigger
1.3.3  ipv6 import bgp
ipv6 import bgp命令用来配置LDP引入BGP IPv6单播路由。
undo ipv6 import bgp命令用来恢复缺省情况。
ipv6 import bgp [ as-number ]
LDP不主动引入BGP IPv6单播路由。
LDP视图
LDP-VPN实例视图
as-number:引入指定AS内的BGP IPv6单播路由。as-number为AS号,取值范围为1~4294967295。如果不指定本参数,则表示引入所有的BGP IPv6单播路由。
提示
配置此命令后,可能会导致LDP引入大量的BGP IPv6单播路由,占用设备的标签、内存资源等问题,建议仅在必要时使用此命令。
缺省情况下,LDP自动引入IPv6 IGP路由(包括已引入到IGP的BGP IPv6单播路由),并为通过LSP触发策略的IGP路由和通过LSP触发策略的带标签BGP路由分配标签,但不自动引入未被引入到IGP的BGP IPv6单播路由。这就导致了在一些特殊的组网环境下,如在运营商的运营商组网中,如果一级运营商的PE与二级运营商CE之间未配置OSPF、IS-IS等IGP协议,则无法通过LDP为BGP IPv6单播路由分配标签,因而无法建立LDP LSP。有关运营商的运营商组网的详细信息,请参见“MPLS配置指导”中的“MPLS L3VPN”。
通过配置LDP引入BGP IPv6单播路由,可将BGP IPv6单播路由强制引入至LDP,如果该路由通过LSP触发策略,则为其分配标签建立LSP。
# 配置公网LDP实例中,强制引入AS号为100的BGP IPv6单播路由,触发建立LDP LSP。
[Sysname] mpls ldp
[Sysname-ldp] ipv6 import bgp 100
·     ipv6 lsp-trigger
1.3.4  ipv6 lsp-trigger
ipv6 lsp-trigger命令用来配置IPv6 FEC的LSP触发策略。
undo ipv6 lsp-trigger命令用来恢复缺省情况。
ipv6 lsp-trigger { all | mapping | prefix-list prefix-list-name }
只有引入到LDP的128位前缀的IPv6主机路由能够触发建立LSP。
LDP视图
LDP-VPN实例视图
all:所有引入到LDP的IPv6路由表项都会触发LDP建立LSP。
mapping:引入到LDP且已经收到下游通告的标签映射的IPv6路由表项会触发LDP建立LSP。
prefix-list prefix-list-name:利用IPv6地址前缀列表对引入到LDP的路由表项进行过滤,通过IPv6地址前缀列表过滤的路由表项可以触发建立LSP,被IPv6地址前缀列表拒绝的路由表项不触发建立LSP。prefix-list-name表示IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。
LSP触发策略用来控制引入到LDP中的哪些路由可以建立LDP LSP。
·     有序方式下:只有128位前缀的本地Loopback接口IPv6地址路由和已经收到下游通告的标签映射且前缀长度为128位的路由可以触发建立LDP LSP。
·     独立方式下:只要是128位前缀的路由都会触发建立LDP LSP。
·     有序方式下:128位前缀的本地Loopback接口IPv6地址路由和已经收到下游通告的标签映射的IPv6路由可以触发建立LDP LSP。
·     独立方式下:128位前缀的路由和已经收到下游通告的标签映射的IPv6路由都会触发建立LDP LSP。
配置all或prefix-list触发策略后,引入到LDP中的所有IPv6路由或通过IPv6地址前缀列表的路由都会触发建立LDP LSP,独立和有序标签分发控制方式的处理没有差别。
# 配置公网LDP实例中只有路由2001::1/ 64能够触发建立LDP LSP。
[Sysname] ipv6 prefix-list egress-fec-list permit 2001::1 64
[Sysname] mpls ldp
[Sysname-ldp] ipv6 lsp-trigger prefix-list egress-fec-list
·     ipv6 import bgp
1.3.5  mpls ldp ipv6 enable
mpls ldp ipv6 enable命令用来使能接口的LDP支持IPv6能力。
undo mpls ldp ipv6 enable命令用来关闭接口的LDP支持IPv6能力。
接口的LDP支持IPv6能力处于关闭状态。
如果在接口上使能了MPLS能力和LDP支持IPv6能力,且该接口处于up状态,则LDP会在该接口上启动基本发现机制,通过该接口发送Link hello消息,hello消息源地址以及携带的TCP传输地址的地址类型为IPv6地址。
执行本命令前,需要先在系统视图下执行mpls ldp命令全局使能LSR的LDP能力。如果接口已与某个VPN实例绑定,则还需要通过vpn-instance命令使能此VPN实例的LDP能力。
如果接口上仅使能了LDP支持IPv6能力,则必须使用mpls ldp transport-address命令配置LDP传输地址后,才会发送IPv6 hello消息。
# 在接口Ten-GigabitEthernet3/0/1上使能LDP支持IPv6能力。
[Sysname] mpls ldp
[Sysname-ldp] quit
[Sysname-Ten-GigabitEthernet3/0/1] mpls ldp ipv6 enable
·     mpls ldp
·     mpls ldp enable
1.3.6  mpls ldp transport-address
接口视图下:
mpls ldp transport-address ipv6-address
undo mpls ldp transport-address ipv6-address
LDP对等体视图下:
未配置LDP IPv6传输地址。
LDP对等体视图
ipv6-address:LDP使用此地址作为LDP传输地址。
# 配置与对等体建立TCP连接时采用的LDP传输地址为2002::1。
[Sysname] mpls ldp
[Sysname-ldp-peer-2001::1] mpls ldp transport-address 2002::1
·     targeted-peer
1.3.7  targeted-peer
targeted-peer命令用来配置主动向指定对等体的IPv6地址发送Targeted hello消息来建立LDP会话,允许应答指定对等体的Targeted hello消息,并进入LDP对等体视图。如果指定的Targeted peer已经存在,则直接进入LDP对等体视图。
undo targeted-peer命令用来取消向指定对等体的IPv6地址发送Targeted hello消息。
targeted-peer ipv6-address [ peer-name ]
undo targeted-peer ipv6-address
设备不会主动向对等体发送Targeted hello消息,也不会应答对等体的Targeted hello消息。
LDP视图
ipv6-address:指定对等体的IPv6地址。
peer-name:指定Targeted peer的名称。未指定本参数时,使用ipv6-address作为Targeted peer的名称。不同IPv6地址不能配置相同的Targeted peer名称。
通过targeted-peer ipv6-address命令指定LDP IPv6对等体,并进入对等体视图后,必须在该视图下配置IPv6传输地址,LDP才会发送IPv6 Targeted hello消息。
若要保证建立IPv6 Targeted hello邻接关系,需保证对等体两端配置的一致性,即在本端使用targeted-peer ipv6-address命令配置的目的地址需为对端在对等体视图下配置的传输地址,并保证本端传输地址与目的地址之间路由可达。
# 配置向对等体的指定地址2001::1发送Targeted hello消息,并进入LDP对等体视图。
[Sysname] mpls ldp
2 mLDP
2.1  mLDP配置命令
2.1.1  display mpls mldp lsp p2mp
display mpls mldp lsp p2mp命令用来显示mLDP协议生成的P2MP LSP信息。
display mpls mldp lsp p2mp [ root-ip ip-address { lsp-id lsp-id | opaque-value opaque-value } [ slot slot-number ]
root-ip ip-address:显示指定根节点地址的P2MP LSP信息。如果不指定本参数,则显示mLDP协议生成的所有P2MP LSP信息。
lsp-id lsp-id:显示指定LSP ID的P2MP LSP信息。lsp-id表示LSP ID,取值范围为0~4294967295。
opaque-value opaque-value:显示指定Opaque Value的P2MP LSP信息,opaque-value为1~255个字符的字符串,字符取值只能为十六进制数。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示mLDP协议生成的所有P2MP LSP信息。
<Sysname> display mpls mldp lsp p2mp
Ingress: 1           Transit: 0           Egress: 0           Bud: 0
FECs: 1              Liberal: 0
Root IP        : 1.1.1.9              Instance         : --
Opaque decoded : LSP-ID 3825205248
Opaque value   : 010004e4000000
Tunnel ID      : 1
LSR type       : Ingress
Trigger type   : MVPN
Downstream info:
  Peer: 2.2.2.9:0
    Out label: 1279             State: Established
    Next hops: 20.1.1.2                XGE3/0/1
# 显示根节点地址为1.1.1.9,LSP ID为34952的P2MP LSP信息。
<Sysname> display mpls mldp lsp p2mp root-ip 1.1.1.9 lsp-id 34952
Ingress: 0           Transit: 1           Egress: 0           Bud: 0
FECs: 1              Liberal: 0
Opaque decoded : LSP-ID 34952
Opaque value   : 01000400008888
LSR type       : Transit
Trigger type   : --
In label       : 1279
Upstream info:
  Peer: 1.1.1.9:0               State: Established
    New root: 99.1.1.1
    Opaque value: 0700110600010401010109000701000400008888
Downstream info:
  Peer: 2.2.2.9:0
    Next hops: 20.1.1.2                XGE3/0/2
表2-1 display mpls mldp lsp p2mp命令显示信息描述表
FECs
mLDP发现的转发等价类个数,FEC来自组播协议或者LDP对等体通告的标签映射
Ingress
本地设备作为入节点的LSP数
Transit
本地设备作为中间节点的LSP数
Egress
本地设备作为出节点的LSP数
Bud
本地设备作为Bud节点的LSP数
Liberal
本地设备未激活的LSP数
Root IP
mLDP P2MP LSP的根节点的IP地址
Instance
实例名称,目前只支持公网实例
Opaque decoded
mLDP协议报文中的Opaque Value解码后的值
Opaque value
mLDP协议报文中原始Opaque Value值
Tunnel ID
mLDP P2MP隧道索引
LSR type
LSR类型:
·     Ingress:LSP的入节点
·     Transit:LSP的中间节点
·     Egress:LSP的出节点
·     Bud:LSP的Bud节点
Trigger type
P2MP LSP建立的触发方式:
·     MVPN:由BGP通告的MVPN路由自动触发
·     --:未知触发方式
In label
入标签值
Upstream Info
Peer
上游对等体的LDP ID
·     Established:激活状态
·     Idle:未激活状态
如果状态后带有stale标记,则表示对应的FEC—标签映射处于GR期间
New Root
跨域组网中,新的根节点IP地址
Opaque value
跨域组网中,新的根节点的Opaque Value
Downstream Info
Out label
出标签值
·     Established:激活状态
·     Idle:未激活状态
Next Hops
出接口和下一跳信息
·     display mpls multicast-lsp protocol mldp p2mp(MPLS命令参考/MPLS基础)
2.1.2  mldp p2mp
mldp p2mp命令用来开启mLDP P2MP功能。
undo mldp p2mp命令用来关闭mLDP P2MP功能。
mldp p2mp
undo mldp p2mp
mLDP P2MP功能处于关闭状态。
LDP视图
开启或者关闭mLDP P2MP功能,所有LDP会话都将重建。
mLDP P2MP网络中,各个节点均需开启本功能。
# 开启mLDP P2MP功能。
[Sysname] mpls ldp
[Sysname-ldp] mldp p2mp
2.1.3  mldp recursive-fec
mldp recursive-fec命令用来开启mLDP P2MP的跨域功能。
undo mldp recursive-fec命令用来关闭mLDP P2MP的跨域功能。
mldp recursive-fec
mLDP P2MP的跨域功能处于关闭状态。
LDP视图
缺省情况下,设备只能根据IGP路由选择到根节点的最优路由,并将该路由的下一跳作为自己的上游节点。在mLDP模式MVPN组网环境中,为组播流量建立跨越不同IGP域(例如OSPF区域)或跨越BGP的AS域的隧道时,需要开启mLDP P2MP的跨域功能。有关mLDP模式MVPN的详细介绍,请参见“IP组播配置指导”中的“组播VPN”。
开启本功能后,除了IGP路由外,设备还可以根据BGP通告的MVPN路由查找到达根节点的最优路由,将下一跳作为新的根节点。
除组播源连接的AS以外,其他AS内的ASBR和PE设备上需要配置本功能。
# 开启mLDP P2MP的跨域功能。
[Sysname] mpls ldp
[Sysname-ldp] mldp recursive-fec
·     mldp p2mp
2.1.4  mpls mldp p2mp disable
mpls mldp p2mp disable命令用来关闭接口的mLDP P2MP功能。
undo mpls mldp p2mp disable命令用来开启接口的mLDP P2MP功能。
接口的mLDP P2MP功能处于开启状态。
在LDP视图下开启mLDP P2MP功能后,公网所有接口上均开启mLDP P2MP功能。
在mLDP P2MP组网环境下,如果某两台设备通过多条链路连接,为了使用特定的链路转发流量,则需要关闭其他链路的mLDP P2MP功能,即在对应接口下执行mpls mldp p2mp diasable命令关闭当前接口的mLDP P2MP功能。
# 关闭接口Ten-GigabitEthernet3/0/1的mLDP P2MP功能。
[Sysname-Ten-GigabitEthernet3/0/1] mpls mldp p2mp disable
·     mldp p2mp
