13-可靠性命令参考
08-BFD命令
本章节下载: 08-BFD命令  (618.54 KB)
08-BFD命令
1 BFD
1.1 BFD配置命令
1.1.1 associate-static-session
1.1.2 bfd authentication-mode
1.1.3 bfd dampening
1.1.4 bfd demand enable
1.1.5 bfd detect-interface first-fail-timer
1.1.6 bfd detect-interface source-ip
1.1.7 bfd detect-interface special-processing
1.1.8 bfd detect-multiplier
1.1.9 bfd echo enable
1.1.10 bfd echo-source-ip
1.1.11 bfd echo-source-ipv6
1.1.12 bfd init-fail-timer
1.1.13 bfd min-echo-receive-interval
1.1.14 bfd min-receive-interval
1.1.15 bfd min-transmit-interval
1.1.16 bfd multi-hop authentication-mode
1.1.17 bfd multi-hop destination-port
1.1.18 bfd multi-hop detect-multiplier
1.1.19 bfd multi-hop min-echo-receive-interval
1.1.20 bfd multi-hop min-receive-interval
1.1.21 bfd multi-hop min-transmit-interval
1.1.22 bfd session init-mode
1.1.23 bfd session-negotiation delay-upon-down
1.1.24 bfd session-negotiation delay-upon-reboot
1.1.25 bfd static
1.1.26 bfd template
1.1.27 discriminator
1.1.28 display bfd session
1.1.29 hardware bfd enable
1.1.30 display bfd working-mode
1.1.31 reset bfd session statistics
1.1.32 snmp-agent trap enable bfd
1.2 SBFD配置命令
1.2.1 bfd detect-multiplier
1.2.2 bfd min-echo-receive-interval
1.2.3 bfd min-transmit-interval
1.2.4 bfd multi-hop detect-multiplier
1.2.5 bfd multi-hop min-transmit-interval
1.2.6 bfd session-negotiation delay-upon-down
1.2.7 bfd session-negotiation delay-upon-reboot
1.2.8 bfd template
1.2.9 display sbfd session
1.2.10 hardware sbfd-reflector enable
1.2.11 sbfd destination ipv4 remote-discriminator
1.2.12 sbfd destination ipv6 remote-discriminator
1.2.13 sbfd local-discriminator
1.2.14 sbfd initiator accept-down-response
1.2.15 sbfd source-ipv6
1 BFD
1.1  BFD配置命令
associate-static-session命令用来将静态BFD会话与其他静态BFD会话关联。
undo associate-static-session命令用来恢复缺省情况。
associate-static-session session-name [ re-negotiate seconds ]
静态BFD会话未关联其他静态BFD会话。
静态BFD会话视图
session-name:关联的静态BFD会话的名称,为1~64个字符的字符串,区分大小写。session-name不能与当前视图对应的静态BFD会话名称相同。
re-negotiate seconds:当前视图对应的静态BFD会话状态由Down重新变为Up后,允许关联会话重新进行协商的最长时间。seconds表示允许会话重新协商的最长时间,取值范围为10~600,单位为秒,缺省值为60。重新协商时间仅在双向关联关系中生效。
假设建立关联关系的静态BFD会话名称分别为a和b,a、b之间支持建立如下两种关联关系:
·     单向关联:仅在a的会话视图下配置本命令将a与b关联,或者仅在b的会话视图下配置本命令将b与a关联。
·     双向关联:在a的会话视图下配置本命令将a与b关联,并在b的会话视图下配置本命令将b与a关联。
单向关联关系的工作机制如下(假设仅在a的会话视图下配置本命令将a与b关联):
(1)     a的会话状态变为Down时,触发b的会话状态变为Down。在a的会话状态为Down期间,不允许b进行会话协商。
(2)     当a的会话状态由Down重新变为Up后,触发b进行会话协商。不管b能否协商为Up状态,都不会影响a的会话状态。
双向关联关系的工作机制如下(假设在a的会话视图下配置本命令将a与b关联,并在b的会话视图下配置本命令将b与a关联):
(1)     a的会话状态变为Down,触发b的会话状态变为Down。在a的会话状态为Down期间,不允许b进行会话协商。
(2)     当a的会话状态由Down重新变为Up后,触发b进行会话协商,机制如下:
¡     如果b在a指定的时间内协商为Up状态,则a和b的会话状态均保持为Up状态。
¡     如果b在a指定的时间内未协商为Up状态,则触发a的会话状态变为Down。
(3)     同样地,b的会话状态变为Down后,触发a的会话状态变化的工作机制与(1)和(2)类似。
不能通过重复执行本命令修改关联的静态BFD会话。如需修改,请先通过undo associate-static-session命令取消关联关系,再执行associate-static-session命令。
# 配置名称为aaa的静态BFD会话与名称为bbb的静态BFD会话关联。
[Sysname] bfd static aaa
[Sysname-bfd-static-session-aaa] associate-static-session bbb
bfd authentication-mode命令用来配置单跳BFD控制报文进行认证的方式。
undo bfd authentication-mode命令用来恢复缺省情况。
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
单跳BFD控制报文不进行认证。
BFD模板视图
静态BFD会话视图
hmac-md5:采用基于HMAC的MD5算法进行认证。
hmac-mmd5:采用基于HMAC的Meticulous MD5算法进行认证。
hmac-msha1:采用基于HMAC的Meticulous SHA1算法进行认证。
hmac-sha1:采用基于HMAC的SHA1算法进行认证。
m-md5:采用Meticulous MD5算法进行认证。
m-sha1:采用Meticulous SHA1算法进行认证。
md5:采用MD5算法进行认证。
sha1:采用SHA1算法进行认证。
simple:采用简单认证。
key-id:认证字标识符,取值范围为1~255。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~16个字符的字符串,密文密钥为33~53个字符的字符串。
本命令主要为了提高BFD会话的安全性。
BFD版本0不支持本命令,配置不生效。
对于静态BFD会话,仅IPv4或IPv6控制报文方式单跳检测的静态BFD会话视图下支持配置本命令。
# 配置接口Ten-GigabitEthernet3/0/1对单跳BFD控制报文进行简单明文认证,认证字标识符为1,密钥为123456。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] bfd authentication-mode simple 1 plain 123456
1.1.3  bfd dampening
bfd dampening命令用来开启BFD会话震荡抑制功能。
undo bfd dampening命令用来关闭BFD会话震荡抑制功能。
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
不会对BFD会话的建立进行抑制。
maximum-interval:抑制BFD会话建立的最大时间间隔,取值范围为1~3600,单位为秒,缺省值为20秒。
initial-interval:第一次抑制BFD会话建立的时间间隔,取值范围为1~3600,单位为秒,缺省值为6秒。
secondary-interval:第二次抑制BFD会话建立的时间间隔,取值范围为1~3600,单位为秒,缺省值为10秒。
BFD检测到链路故障时,会拆除BFD会话,并通知上层协议邻居不可达。当上层协议重新建立邻居关系后,BFD会话重新up。当链路频繁发生故障并故障恢复时,将导致BFD会话震荡,引发设备不断执行上述操作,这会占用大量的系统资源并影响网络的稳定性。可配置本命令通过如下惩罚机制对BFD会话震荡进行抑制。BFD会话震荡的惩罚机制通过initial-interval、secondary-interval、maximum-interval参数来进行抑制:
·     在抑制时间间隔内,不允许建立BFD会话;在抑制时间间隔超时后,允许建立BFD会话。抑制时间最大不超过maximum-interval。
·     BFD会话第二次down后,在initial-interval时间间隔内,不允许重新建立BFD会话。
·     BFD会话第三次down后,在secondary-interval时间间隔内,不允许重新建立BFD会话。
·     BFD会话第四次或更多次down后,按照如下规则抑制BFD会话的建立:
¡     secondary-interval×2n-3(n为BFD会话震荡的次数,初始值为4)小于或等于maximum-interval时,在secondary-interval×2n-3时间间隔内,不允许重新建立BFD会话。
¡     secondary-interval×2n-3(n为BFD会话震荡的次数,初始值为4)大于maximum-interval时,在maximum-interval时间间隔内,不允许重新建立BFD会话。
# 配置BFD会话震荡时,抑制BFD会话建立的最大时间间隔为12秒,第一次抑制BFD会话建立的时间间隔为4秒,第二次抑制BFD会话建立的时间间隔为8秒。
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
bfd demand enable命令用来配置BFD会话为查询模式。
undo bfd demand enable命令用来恢复缺省情况。
bfd demand enable
BFD会话为异步模式。
在查询模式下,设备周期性发送BFD控制报文,但是对端(缺省为异步模式)会停止周期性发送BFD控制报文。如果通信双方都是查询模式,则双方都停止周期性发送BFD控制报文。当需要验证连接性的时候,设备会以协商的周期连续发送几个P比特位置1的BFD控制报文。如果在检测时间内没有收到返回的报文,就认为会话down;如果收到对方的回应F比特位置1的报文,就认为连通,停止发送报文,等待下一次触发查询。此模式下,建议用户通过bfd echo enable命令使能echo功能,设备将周期性发送echo报文来检测链路的连通性,如果在检测时间内未收到对端返回的echo报文,则认为会话down。
在异步模式下,设备周期性地发送BFD控制报文,如果在检测时间内对端没有收到BFD控制报文,则认为会话down。
BFD版本0不支持本命令,配置不生效。
# 在接口Ten-GigabitEthernet3/0/1上配置BFD会话为查询模式。
[Sysname-Ten-GigabitEthernet3/0/1] bfd demand enable
·     bfd echo enable
bfd detect-interface first-fail-timer命令用来配置首次建立检测接口状态的BFD会话失败时,通知数据链路层BFD会话down的超时时间。
undo bfd detect-interface first-fail-timer命令用来恢复缺省情况。
bfd detect-interface first-fail-timer seconds
首次建立检测接口状态的BFD会话失败时,不会通知数据链路层BFD会话down。
seconds:首次建立检测接口状态的BFD会话失败时,通知数据链路层BFD会话down的超时时间,即在seconds时间后如果检测接口状态的BFD会话仍未建立成功,BFD会将此消息通知给数据链路层。取值范围为1~10000,单位为秒。
本端配置bfd detect-interface source-ip命令后,会尝试建立检测接口状态的BFD会话。如果对端未配置bfd detect-interface source-ip命令或两端BFD的认证配置不一致等原因,均会导致首次建立检测接口状态的BFD会话失败。如果需要关闭接口的数据链路层,快速定位首次建立检测接口状态的BFD会话失败的接口,可通过配置本命令来实现。
配置本命令后,如果接口首次建立检测接口状态的BFD会话失败,执行display bfd session命令显示该BFD会话的状态为down,执行display interface命令会显示该接口的Line protocol state为DOWN(BFD)。
# 配置首次建立检测接口状态的BFD会话失败时,通知数据链路层BFD会话down的超时时间为10秒。
[Sysname-Ten-GigabitEthernet3/0/1] bfd detect-interface first-fail-timer 10
bfd detect-interface source-ip命令用来配置接口状态与BFD联动。
undo bfd detect-interface命令用来取消接口状态与BFD联动的配置。
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
接口状态不与BFD联动,即BFD检测到链路故障时,不会将接口链路层协议状态置为“DOWN(BFD)。
ip-address:BFD控制报文的源IP地址。
discriminator:指定BFD会话的标识符。如果未指定本参数,设备将通过自动协商的方式获取BFD会话标识符。
local local-value:指定BFD会话的本地标识符。local-value表示BFD会话的本地标识符,取值范围为1~32768。
remote remote-value:指定BFD会话的远端标识符。remote-value表示BFD会话的远端标识符,取值范围为1~4294967295。
template template-name:指定引用的BFD会话参数的模板名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则BFD会话使用接口视图下配置的单跳BFD会话参数。
·     请不要在三层以太网接口和该三层以太接口创建的子接口上同时使用该功能,否则,将导致主接口或子接口的BFD检测功能失效。
·     建议不要在三层聚合口以及该三层聚合口的成员口上同时使用此功能。如需同时使用,必须分别指定三层聚合口和三层聚合成员口的BFD会话的本地标识符和远端标识符,否则,将导致BFD检测功能异常。
·     接口状态与BFD联动时,建议不要将BFD会话配置为查询模式,否则,可能会导致BFD会话状态异常。
配置接口状态与BFD联动后,系统将通过发送BFD控制报文来协商建立单跳检测的BFD会话,实现对链路的快速检测。当检测到链路故障时,将接口链路层协议状态置为“DOWN(BFD)”,从而帮助依赖接口链路层协议状态的应用快速收敛。系统发送的BFD控制报文中的源地址为用户手工指定的IP地址,目的地址固定为224.0.0.184。对于有IP地址的接口,建议将源地址指定为该接口的IP地址;如果接口没有IP地址,建议将源地址指定为0.0.0.0以外的单播地址。
支持与BFD联动的接口类型为:
·     二层以太网接口
·     加入聚合组的二层以太网接口
·     三层以太网接口
·     加入聚合组的三层以太网接口
·     三层以太网子接口
·     三层聚合口
·     Serial接口、POS接口、E1通道创建出来的串口、E3通道创建出来的串口、T1通道创建出来的串口、T3通道创建出来的串口、MP-group接口和加入MP-group的成员接口、HDLC捆绑接口和加入HDLC捆绑的成员接口。如果通过link-protocol命令修改接口的链路层协议,接口状态与BFD联动的配置将自动取消,需要重新配置。配置MP-group的成员接口或加入HDLC捆绑的成员接口状态与BFD联动时,必须指定discriminator参数。
两端都必须配置本功能才能建立BFD会话。
当对端设备不支持通过自动协商的方式获取BFD会话的标识符时,必须指定discriminator参数,且两端都需要指定该参数,否则,BFD会话无法up。
指定BFD会话的标识符时,两端的BFD会话本地标识符和远端标识符必须匹配,即本端指定的本地标识符和远端标识符必须是对端设备上指定的远端标识符和本地标识符。例如,本端配置bfd detect-interface source-ip 20.1.1.1 discriminator local 513 remote 514时,对端要配置bfd detect-interface source-ip 20.1.1.2 discriminator local 514 remote 513,才能正确建立起BFD会话。
同一设备不同接口上的BFD会话的本地标识符不能相同。
回声功能对接口状态与BFD联动的会话无效。
# 配置接口Ten-GigabitEthernet3/0/1的接口状态与BFD联动,并指定BFD会话的源地址为接口地址20.1.1.1。
[Sysname-Ten-GigabitEthernet3/0/1] bfd detect-interface source-ip 20.1.1.1
bfd detect-interface special-processing命令用来开启对检测接口状态的BFD会话进行特殊处理的功能。
undo bfd detect-interface special-processing命令用来关闭对检测接口状态的BFD会话进行特殊处理的功能。
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
对检测接口状态的BFD会话进行特殊处理的功能处于关闭状态。
admin-down:本端收到会话状态为AdminDown的BFD报文时,将BFD会话down的消息通知给数据链路层。使用本参数,有利于快速发现BFD会话被手工关闭的接口。如果未配置本参数,本端收到会话状态为AdminDown的BFD报文,将BFD会话状态置为down,但是不会将BFD会话down的消息通知给数据链路层。
authentication-change:本端认证信息发生变化时,立即将BFD会话状态置为down。使用本参数,有利于快速发现认证信息不一致的接口。如果未配置本参数,本端认证信息发生变化时,会预留时间给用户修改本端或对端的认证参数,如果预留时间结束时,两端认证信息任未达成一致,本端会将BFD会话状态置为down。
session-up:本端BFD会话处于up状态时,不再检查收到的BFD报文中的认证信息。当设备上的BFD会话数量较多时,检查BFD报文中携带的认证信息会影响设备性能。配置本参数后,不再检查收到的报文中的认证信息,从而可以降低对设备性能的影响。如果未配置本参数,本端BFD会话处于up状态时,会检查收到的BFD报文中的认证信息,需要保证BFD会话两端认证信息的一致性,否则会导致BFD会话down。
如果未指定任何参数,将开启或关闭对检测接口状态的BFD会话进行所有特殊处理的功能。
BFD报文的认证方式为M-MD5、M-SHA1、HMAC-MMD5或HMAC-MSHA1时,如果仅在本端或对端配置bfd detect-interface special-processing session-up命令,则会导致BFD会话震荡。这种情况下,建议修改BFD报文的认证方式,或者两端均配置bfd detect-interface special-processing session-up命令。
# 在Ten-GigabitEthernet3/0/1接口下开启对检测接口状态的BFD会话进行特殊处理的功能,包括收到会话状态为AdminDown的BFD报文、本端认证信息发生变化以及BFD会话处于up状态时对收到的BFD报文中认证信息检查的特殊处理。
[Sysname-Ten-GigabitEthernet3/0/1] bfd detect-interface special-processing admin-down authentication-change session-up
bfd detect-multiplier命令用来配置控制报文方式或echo报文方式单跳检测的BFD检测时间倍数。
undo bfd detect-multiplier命令用来恢复缺省情况。
bfd detect-multiplier value
单跳BFD检测时间倍数为3。
BFD模板视图
静态BFD会话视图
value:单跳BFD检测时间倍数,取值范围为3~50。
检测时间倍数,即允许发送方发送BFD报文(包括echo报文和控制报文)的最大连续丢包数。
实际检测时间的计算方法遵循如下规则:
·     对于echo报文方式,本端实际检测时间=本端的检测时间倍数×本端实际发送echo报文的时间间隔。
·     对于控制报文方式单跳检测的异步模式,本端实际检测时间=对端的检测时间倍数×MAX(本端支持的接收BFD控制报文的最小时间间隔,对端支持的发送BFD控制报文的最小时间间隔)。
·     对于控制报文方式单跳检测的查询模式,本端实际检测时间=本端的检测时间倍数×MAX(本端支持的发送BFD控制报文的最小时间间隔,对端支持的接收BFD控制报文的最小时间间隔)。
对于静态BFD会话,仅如下类型的静态BFD会话视图下支持配置本命令:
·     IPv4控制报文方式单跳检测静态BFD会话
·     IPv4 echo报文方式单跳检测静态BFD会话
·     IPv6控制报文方式单跳检测静态BFD会话
·     IPv6 echo报文方式单跳检测静态BFD会话
# 配置接口Ten-GigabitEthernet3/0/1的控制报文方式单跳检测和echo报文方式的BFD检测时间倍数为6。
[Sysname-Ten-GigabitEthernet3/0/1] bfd detect-multiplier 6
·     bfd static
bfd echo enable命令用来使能回声功能。
undo bfd echo enable命令用来关闭回声功能。
undo bfd echo [ receive | send ] enable
回声功能处于关闭状态。
静态BFD会话视图
receive:表示设备接收echo报文的能力。
send:表示设备发送echo报文的能力。
本功能在发送控制报文的BFD会话时使用。使能回声功能并且会话up后,设备周期性发送echo报文检测链路连通性,同时降低控制报文的接收速率。
使用bfd echo receive enable命令,表示使能回声功能后,只开启设备接收echo报文的能力;使用bfd echo send enable命令,表示使能回声功能后,只开启设备发送echo报文的能力。当不指定receive和send参数时,表示使能回声功能后,同时开启设备收、发echo报文的能力。
回声功能对使用IPv6链路本地地址建立的控制报文的BFD会话无效。
BFD版本0不支持本命令,配置不生效。
# 配置接口Ten-GigabitEthernet3/0/1使能回声功能。
[Sysname-Ten-GigabitEthernet3/0/1] bfd echo enable
bfd echo-source-ip命令用来配置echo报文的源IP地址。
undo bfd echo-source-ip命令用来删除echo报文的源IP地址。
bfd echo-source-ip ip-address
未配置echo报文的源IP地址。
ip-address:echo报文的源IP地址,点分十进制形式,取值范围为合法的单播IPv4地址。
对于echo报文方式的BFD会话,建议在创建BFD会话的一端配置本命令,且配置的源IP地址不属于该设备任何一个接口所在网段,以避免对端发送大量的ICMP重定向报文造成网络拥塞。
# 配置echo报文的源IP地址为8.8.8.8。
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6命令用来配置echo报文的源IPv6地址。
undo bfd echo-source-ipv6命令用来删除echo报文的源IPv6地址。
未配置echo报文的源IPv6地址。
ipv6-address:echo报文的源IPv6地址。
echo报文源IPv6地址仅支持全球单播地址。
对于echo报文方式的BFD会话,建议在创建BFD会话的一端配置本命令,且配置的源IPv6地址不属于该设备任何一个接口所在网段,以避免对端发送大量的ICMPv6重定向报文造成网络拥塞。
# 配置echo报文的源IPv6地址为80::2。
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail-timer命令用来配置BFD会话无法建立时,通知上层协议BFD会话down的超时时间。
undo bfd init-fail-timer命令用来恢复缺省情况。
bfd init-fail-timer seconds
BFD会话无法建立时,不会通知上层协议BFD会话down。
seconds:BFD会话无法建立时,通知上层协议BFD会话down的超时时间,即在seconds时间后将BFD会话down的消息通知给上层协议。取值范围为5~600,单位为秒。
配置本命令后,对于由于配置原因(比如对端设备没有使能BFD,或者两端的BFD认证配置不一致等)造成BFD会话无法进入up状态的情况,如果配置了本定时器,会导致上层协议作出错误的处理,所以,请谨慎使用本命令。
缺省情况下,控制报文工作方式的BFD会话无法建立时,不会通知上层协议BFD会话down。某些情况下,需要将BFD会话无法建立的消息通知给上层协议,以使上层协议作出正确的处理。比如在聚合链路中,由于链路故障等原因,BFD会话无法进入up状态,从而导致聚合模块无法及时将成员端口的选中状态修改为非选中状态,配置本命令可避免上述情况的发生。
对于echo报文方式的BFD会话,本命令不生效。
# 配置BFD会话无法建立时,通知上层协议BFD会话down的超时时间为10秒。
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval命令用来配置接收echo报文的最小时间间隔。
undo bfd min-echo-receive-interval命令用来恢复缺省情况。
接收echo报文的最小时间间隔为100毫秒。
BFD模板视图
静态BFD会话视图
interval:接收echo报文的最小时间间隔,单位为毫秒。取值范围为0或3~10000。
使用本命令,设备能够控制接收两个echo报文之间的时间间隔,即echo报文实际发送时间间隔。
对于控制报文方式的BFD会话,本端使能echo功能后,如果对端通过本命令将interval设置为0毫秒,那么本端设备与对端设备自动协商后,本端设备不再周期性发送echo报文。
# 配置接口Ten-GigabitEthernet3/0/1接收echo报文的最小时间间隔为500毫秒。
[Sysname-Ten-GigabitEthernet3/0/1] bfd min-echo-receive-interval 500
·     bfd static
bfd min-receive-interval命令用来配置接收单跳BFD控制报文的最小时间间隔。
undo bfd min-receive-interval命令用来恢复缺省情况。
缺省情况下,接收单跳BFD控制报文的最小时间间隔为100毫秒。
BFD模板视图
静态BFD会话视图
interval:接收单跳BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要为了防止对端发送控制报文的速度超过本地接收控制报文的速度。
对端的控制报文实际发送时间为对端发送控制报文的最小时间间隔和本地接收控制报文的最小时间间隔之间的较大值。
# 配置接口Ten-GigabitEthernet3/0/1接收单跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname-Ten-GigabitEthernet3/0/1] bfd min-receive-interval 500
·     bfd static
bfd min-transmit-interval命令用来配置发送单跳BFD控制报文的最小时间间隔。
undo bfd min-transmit-interval命令用来恢复缺省情况。
发送单跳BFD控制报文的最小时间间隔为100毫秒。
BFD模板视图
静态BFD会话视图
interval:发送单跳BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要是为了保证发送BFD控制报文的速度不能超过设备发送报文的能力。
本地实际发送BFD控制报文的时间间隔,为本地配置的发送BFD控制报文的最小时间间隔和对端接收BFD控制报文的最小时间间隔的最大值。
# 配置接口Ten-GigabitEthernet3/0/1发送单跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname-Ten-GigabitEthernet3/0/1] bfd min-transmit-interval 500
·     bfd static
bfd multi-hop authentication-mode命令用来配置多跳BFD控制报文进行认证的方式。
undo bfd multi-hop authentication-mode命令用来恢复缺省情况。
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
多跳BFD控制报文不进行认证。
静态BFD会话视图
md5:采用MD5算法进行认证。
sha1:采用SHA1算法进行认证。
simple:采用简单认证。
cipher:以密文方式设置密钥。
本命令主要为了提高BFD会话的安全性。
对于静态BFD会话,仅IPv4或IPv6控制报文方式多跳检测的静态BFD会话视图下支持配置本命令。
BFD版本0不支持本命令,配置不生效。
# 配置多跳BFD控制报文进行简单明文认证,认证字标识符为1,密钥为123456。
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
·     bfd static
bfd multi-hop destination-port命令用来配置多跳BFD控制报文的目的端口号。
undo bfd multi-hop destination-port命令用来恢复缺省情况。
多跳BFD控制报文的目的端口号为4784。
port-number:多跳BFD控制报文的目的端口号,取值可以为3784或者4784。
IANA(Internet Assigned Numbers Authority,互联网编号分配委员会)将端口号4784分配给BFD,用于BFD控制报文多跳检测。缺省情况下,H3C设备多跳BFD控制报文的目的端口号为4784。与多跳BFD控制报文目的端口号为3784的其他厂商设备互通时,建议两端使用相同的多跳BFD控制报文端口号,否则可能会导致BFD会话协商失败。
配置本命令后,只有此后新创建的控制报文方式的多跳BFD会话,才会使用本命令设置的端口块作为发送报文的目的端口号。对于配置本命令前已经Up的控制报文方式的多跳BFD会话,不会使用本命令设置的端口号作为发送报文的目的端口号。
# 配置多跳BFD控制报文的目的端口号为3784。
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier命令用来配置控制报文方式或echo报文方式多跳检测的BFD检测时间倍数。
undo bfd multi-hop detect-multiplier命令用来恢复缺省情况。
控制报文方式多跳检测和echo报文方式多跳检测的BFD检测时间倍数为3。
静态BFD会话视图
value:BFD检测时间倍数,取值范围为3~50。
检测时间倍数,即接收方允许发送方发送BFD控制报文的最大连续丢包数。
实际检测时间的计算方法遵循如下规则:
·     对于echo报文方式的多跳检测,本端实际检测时间=本端的检测时间倍数×本端实际发送echo报文的时间间隔。
·     对于控制报文方式的多跳检测异步模式,本端实际检测时间=对端的检测时间倍数×MAX(本端支持的接收BFD控制报文的最小时间间隔,对端支持的发送BFD控制报文的最小时间间隔)。
·     对于控制报文方式的多跳检测查询模式,本端实际检测时间=本端的检测时间倍数×MAX(本端支持的发送BFD控制报文的最小时间间隔,对端支持的接收BFD控制报文的最小时间间隔)。
·     IPv4控制报文方式多跳检测静态BFD会话
·     IPv4 echo报文方式多跳检测静态BFD会话
·     IPv6控制报文方式多跳检测静态BFD会话
·     IPv6 echo报文方式多跳检测静态BFD会话
# 配置多跳检测的BFD检测时间倍数为6。
[Sysname] bfd multi-hop detect-multiplier 6
·     bfd static
bfd multi-hop min-echo-receive-interval命令用来配置接收多跳echo报文的最小时间间隔。
undo bfd multi-hop min-echo-receive-interval命令用来恢复缺省情况。
bfd multi-hop min-echo-receive-interval interval
接收多跳echo报文的最小时间间隔为100毫秒。
静态BFD会话视图
interval:接收echo报文的最小时间间隔,单位为毫秒。取值范围为0或3~10000。如果将其设置为0毫秒,则表示设备不再接收echo报文。
设备发送多跳echo报文的时间间隔与接收多跳echo报文的时间间隔相同。使用本命令,设备能够控制接收两个多跳echo报文之间的时间间隔,进而控制发送多跳echo报文的时间间隔。
对于静态BFD会话,仅IPv4或IPv6 echo报文方式多跳检测的静态BFD会话视图下支持配置本命令。
# 配置接收多跳echo报文的最小时间间隔为500毫秒。
[Sysname] bfd multi-hop min-echo-receive-interval 500
·     bfd static
bfd multi-hop min-receive-interval命令用来配置接收多跳BFD控制报文的最小时间间隔。
undo bfd multi-hop min-receive-interval命令用来恢复缺省情况。
接收多跳BFD控制报文的最小时间间隔为100毫秒。
静态BFD会话视图
interval:接收BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要为了防止对端设备发送报文的速度超出本地接收报文的能力(接收BFD控制报文的最小时间间隔),若超出,则对端设备将发送BFD控制报文的时间间隔动态调整为本地接收BFD控制报文的最小时间间隔。
# 配置接收多跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname] bfd multi-hop min-receive-interval 500
·     bfd static
bfd multi-hop min-transmit-interval命令用来配置发送多跳BFD控制报文的最小时间间隔。
undo bfd multi-hop min-transmit-interval命令用来恢复缺省情况。
发送多跳BFD控制报文的最小时间间隔为100毫秒。
静态BFD会话视图
interval:发送BFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
# 配置发送多跳BFD控制报文的最小时间间隔为500毫秒。
[Sysname] bfd multi-hop min-transmit-interval 500
·     bfd static
bfd session init-mode命令用来配置BFD会话建立前的运行模式。
undo bfd session init-mode命令用来恢复缺省情况。
BFD会话建立前的运行模式为主动模式。
active:主动模式。在建立会话前不管是否收到对端发来的BFD控制报文,都会主动向会话的对端发送BFD控制报文。
passive:被动模式。在建立会话前不会主动向会话的对端发送BFD控制报文,只有等收到BFD控制报文后才会向对端发送BFD控制报文。
通信双方至少要有一方运行在主动模式才能成功建立起BFD会话。
BFD版本0不支持本命令,配置不生效。
# 配置BFD会话建立前的运行模式为被动模式。
[Sysname] bfd session init-mode passive
bfd session-negotiation delay-upon-down命令用来开启延迟DOWN状态的BFD会话进行协商的功能,并设置延迟会话协商的时间。
undo bfd session-negotiation delay-upon-down命令用来恢复缺省情况。
bfd session-negotiation delay-upon-down interval
延迟DOWN状态的BFD会话进行协商的功能处于关闭状态。
interval:设置延迟DOWN状态的BFD会话进行协商的时间,取值范围为1~1200,单位为秒。
在上层应用使用BFD检测主用路径的场景中,主用路径DOWN后,触发上层协议进行主备路径切换。如果主路径故障恢复前,检测主用路径的BFD会话重新UP,将会触发备份路径切换到处于故障状态的主路径,会导致流量丢失。使用本功能可以解决上述问题。
开启本功能后,工作机制如下:
·     设备将对每一个从UP状态切换为DOWN状态的BFD会话启动一个定时器,在定时器超时前,对应的会话不会进行重协商。
·     任何新建立的BFD会话,设备都会启动定时器。在定时器超时前,不会重新进行会话协商。
# 开启延迟DOWN状态的BFD会话进行会话协商的功能,并设置延迟会话协商的时间为6秒。
[Sysname] bfd session-negotiation delay-upon-down 6
·     display bfd session
bfd session-negotiation delay-upon-reboot命令用来开启设备整机重启后延迟BFD进行会话协商的功能,并设置延迟会话协商的时间。
undo bfd session-negotiation delay-upon-reboot命令用来恢复缺省情况。
bfd session-negotiation delay-upon-reboot interval
设备整机重启后延迟BFD进行会话协商的功能处于关闭状态。
interval:设置设备整机重启后延迟BFD进行会话协商的时间,取值范围为1~1200,单位为秒。
在上层应用使用BFD检测主用路径的场景中,设备整机重启可能会触发主备路径切换。当设备重启成功后,若检测主用路径的BFD会话重新UP,则触发备份路径切换到主路径。但是,如果此时上层协议的主路径还未完全恢复,会导致流量丢失。使用本功能可以解决上述问题。
开启本功能的设备重启成功后,会启动一个延迟定时器,在定时器超时前,如下两种情况的BFD会话不会进行会话协商:
·     已有的DOWN状态的BFD会话不会进行重新协商。
·     新建立的BFD会话不会进行协商。
延时定时器超时后,BFD会话的协商不再受本命令影响。
同时存在bfd session-negotiation delay-upon-reboot和bfd session-negotiation delay-upon-down配置的设备重启成功后,bfd session-negotiation delay-upon-reboot命令选取较大的interval值作为自己的定时器取值。
# 开启设备整机重启后延迟BFD进行会话协商的功能,并设置延迟会话协商的时间为6秒。
[Sysname] bfd session-negotiation delay-upon-reboot 6
·     bfd session-negotiation delay-upon-down
1.1.25  bfd static
bfd static命令用来创建静态BFD会话,并进入静态BFD会话视图。如果指定的BFD会话已经存在,则直接进入静态BFD会话视图。
undo bfd static命令用来删除静态BFD会话及静态BFD会话视图下的所有配置。
IPv4控制报文方式单跳检测:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ] ]
IPv4控制报文方式多跳检测:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ] ]
IPv4 echo报文方式单跳检测:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
IPv4 echo报文方式多跳检测:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
IPv6控制报文方式单跳检测:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] ]
IPv6控制报文方式多跳检测:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ] ]
IPv6 echo报文方式单跳检测:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number  destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
IPv6 echo报文方式多跳检测:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
对端地址固定为组播地址224.0.0.184的IPv4控制报文方式单跳检测静态BFD会话:
bfd static session-name [ peer-ip default-ip interface interface-type interface-number source-ip ip-address [ discriminator local discr-value remote remote-value ] ]
删除静态BFD会话:
undo bfd static session-name
不存在静态BFD会话。
session-name:静态BFD会话的名称,为1~64个字符的字符串,区分大小写。
peer-ip ipv4-address:静态BFD会话的对端IPv4地址,点分十进制形式,取值范围为合法的单播IPv4地址。对于控制报文方式的静态BFD,peer-ip地址和source-ip地址共同决定了静态BFD需要检测的路径。对于echo报文方式的静态BFD,peer-ip地址和destination-ip地址共同决定了静态BFD需要检测的路径。
peer-ipv6 ipv6-address:静态BFD会话的对端IPv6地址。对于控制报文方式的静态BFD,peer-ipv6地址和source-ipv6地址共同决定了静态BFD需要检测的路径。对于echo报文方式的静态BFD,peer-ipv6地址和destination-ipv6地址共同决定了静态BFD需要检测的路径。
default-ip:静态BFD会话的对端地址固定为组播地址224.0.0.184。
vpn-instance vpn-instance-name:指定静态BFD会话所属的VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示静态BFD会话属于公网实例。
interface interface-type interface-number:指定BFD会话所在的本地接口。interface-type interface-number表示接口类型和接口编号。指定本参数后,BFD将以该接口作为出接口发送报文。
destination-ip ipv4-address:指定echo报文的目的地址,点分十进制形式,取值范围为合法的单播IPv4地址。该地址为本端IPv4地址。
destination-ipv6 ipv6-address:指定echo报文的目的IPv6地址。该地址为本端IPv6地址。
source-ip ipv4-address:BFD报文的源IPv4地址,点分十进制形式,取值范围为合法的单播IPv4地址。
source-ipv6 ipv6-address:BFD报文的源IPv6地址。
one-arm-echo:指定静态BFD会话的方式为echo报文方式。
auto:自动分配BFD会话的本地标识符。指定本参数后,设备自动为静态BFD会话分配本地标识符。
track-interface interface-type interface-number:指定静态BFD会话监视的接口,当接口故障时,静态BFD会话状态变为down。interface-type interface-number表示接口类型和接口编号。如果未指定本参数,静态BFD会话不会监视任何接口。
创建的静态BFD会话可以用来进行BFD单跳检测和多跳检测,通过与Track配合可为对链路故障响应速度要求较高的业务提供故障检测服务。关于Track与BFD联动的详细信息,请参见“可靠性配置指导”中的“Track”。
如果对端静态创建控制报文方式的静态BFD会话,那么本端必须通过本命令创建静态BFD会话,且两端的静态BFD会话的配置项必须匹配,例如,本端配置bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514,对端要配置bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513。
创建和修改静态BFD会话时,需要注意:
·     首次创建静态BFD会话时,必须指定静态BFD会话的对端IPv4或IPv6地址。通过bfd static session-name命令只能进入已经存在的静态BFD会话视图。系统仅检查IP地址的形式,不检查其正确性。指定错误的目的IP地址或源IP地址均会导致静态BFD会话无法建立。
·     可以不指定静态BFD会话的本地标识符和远端标识符,但要使配置生效,必须通过如下方式为静态BFD会话指定本地标识符和远端标识符:
¡     使用discriminator命令指定静态BFD会话的本地标识符和远端标识符。
¡     执行undo bfd static命令删掉当前配置,再执行bfd static命令指定静态BFD会话的本地标识符和远端标识符。
·     如果使用echo报文方式的静态BFD会话进行检测,仅需在本端创建静态BFD会话。创建echo报文方式的静态BFD会话时,如果未指定source-ip/source-ipv6参数,将使用bfd echo-source-ip/bfd echo-source-ipv6命令配置的地址作为BFD报文IP头的源地址。如果用户既未指定source-ip/source-ipv6参数,也未配置bfd echo-source-ip/bfd echo-source-ipv6命令,BFD报文IP头中的源IPv4/IPv6地址为destination-ip/destination-ipv6参数指定的IPv4/IPv6地址。
建议用户创建echo报文方式的静态BFD会话时指定source-ip/source-ipv6参数,且配置的echo报文源地址不能属于该设备任何一个接口所在的网段。
·     使用控制报文方式的静态BFD会话进行单跳检测时,需要保证创建的静态BFD会话的peer-ip为对端静态BFD会话所在接口的IP地址,source-ip为本端静态BFD会话所在接口的IP地址,否则无法建立静态BFD会话。
·     不能通过重复执行本命令修改静态BFD会话。如需修改静态BFD会话,请先通过undo bfd static命令删除静态BFD会话,再执行bfd static命令。
·     不同的静态BFD会话的本地标识符不能相同。
BFD报文IP头中源IP地址和目的IP地址的获取方式与BFD会话的工作方式有关,具体如下:
·     对于控制报文方式的静态BFD,BFD报文IP头中的源IP地址为source-ip/source-ipv6,目的IP地址为peer-ip/peer-ipv6。
·     对于echo报文方式的静态BFD,BFD报文IP头中的源IP地址为source-ip/source-ipv6,目的IP地址为destination-ip/destination-ipv6。如果用户既未指定source-ip/source-ipv6参数,也未配置bfd echo-source-ip/bfd echo-source-ipv6命令,BFD报文IP头中的源IPv4/IPv6地址为destination-ip/destination-ipv6参数指定的IPv4/IPv6地址。
检测设备间数据链路层的连通性时,请配置bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value命令。对于配置了IP地址的接口,建议将source-ip指定为该接口的IP地址;如果接口未配置或无法配置IP地址,建议将source-ip指定为0.0.0.0以外的单播地址。一个接口上只能采用一个静态BFD会话进行链路层故障检测。
EVPN VPWS双归属组网中,当DF侧AC故障时,BDF无法快速感知该故障并切换为DF。通过在DF上配置静态BFD会话监测本地AC接口的状态(通过指定track-interface参数),并在BDF上配置evpn track bfd命令,可以实现:
(1)     DF侧AC故障时,DF上的静态BFD会话状态变为down,并将静态BFD会话状态通告给BDF。
(2)     BDF快速切换为DF,缩短DF的切换时间,减少丢包。
关于EVPN VPWS组网以及DF选举的详细介绍,请参见“EVPN配置指导”中的“EVPN VPWS”。
静态BFD会话支持监视的接口类型如下:
·     二层以太网接口
·     三层以太网接口及其子接口
·     二层聚合接口及二层聚合口的成员端口
·     三层聚合接口、三层聚合接口的子接口以及三层聚合口的成员端口
# 创建名称为abc的静态BFD会话,并进入静态BFD会话视图。对1.1.1.1和1.1.1.2之间的路径进行检测,并通过接口Ten-GigabitEthernet3/0/1发送BFD报文。其中,BFD报文的源IP地址为1.1.1.1,目的IP地址为1.1.1.2,本地标识符为1537,远端标识符为2048。
[Sysname] bfd static abc peer-ip 1.1.1.2 interface ten-gigabitethernet 3/0/1 source-ip 1.1.1.1 discriminator local 1537 remote 2048
[Sysname-bfd-static-session-abc]
# 创建名称为abc的echo报文方式静态BFD会话,并进入静态BFD会话视图。对1.1.1.1和1.1.1.2之间的路径进行检测,并通过接口Ten-GigabitEthernet3/0/1发送BFD报文。其中,BFD报文的源IP地址为9.9.9.9,目的IP地址为本机地址1.1.1.2。
[Sysname] bfd static abc peer-ip 1.1.1.1 interface ten-gigabitethernet 3/0/1 destination-ip 1.1.1.2 source-ip 9.9.9.9 one-arm-echo discriminator auto
·     bfd echo-source-ip
·     bfd echo-source-ipv6
·     discriminator
·     evpn track bfd(EVPN命令参考/EVPN VPWS)
·     track bfd(可靠性命令参考/Track)
1.1.26  bfd template
bfd template命令用来创建BFD模板,并进入BFD模板视图。如果指定的BFD模板已经存在,则直接进入BFD模板视图。
undo bfd template命令用来删除BFD模板。
bfd template template-name
undo bfd template template-name
不存在BFD模板。
template-name:BFD模板名称,为1~63个字符的字符串,区分大小写。
# 创建BFD模板bfd1,并进入BFD模板视图。
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
discriminator命令用来指定静态BFD会话的本地标识符和远端标识符。
undo discriminator命令用来删除静态BFD会话的本地标识符和远端标识符。
discriminator { local local-value | remote remote-value }
undo discriminator { local local-value | remote remote-value }
未指定静态BFD会话的本地标识符和远端标识符。
静态BFD会话视图
local local-value:指定静态BFD会话的本地标识符。local-value表示静态BFD会话的本地标识符,取值范围为1~32768。
remote remote-value:指定静态BFD会话远端标识符。remote-value表示静态BFD会话的远端标识符,取值范围为1~4294967295。
本命令仅用于创建静态BFD会话时未指定静态BFD会话标识符的场景。
不能通过重复执行本命令修改静态BFD会话的本地标识符或远端标识符。如需修改,请先通过undo discriminator命令删掉相应的静态BFD会话的本地标识符或远端标识符,再执行discriminator命令为静态BFD会话配置新的本地标识符或远端标识符。
# 指定名称为abc的静态BFD会话的本地标识符为1537,远端标识符为2048。
[Sysname-bfd-static-session-abc] discriminator local 1537
[Sysname-bfd-static-session-abc] discriminator remote 2048
·     bfd static
display bfd session命令用来显示BFD会话信息。
display bfd session [ discriminator local local-value | static name session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ] [ slot slot-number ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ] [ slot slot-number ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw | srv6-policy ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ] [ slot slot-number ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] [ slot slot-number ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] [ slot slot-number ]
discriminator local local-value:显示指定本地标识符的BFD会话的详细信息。local-value为本地标识符的值,取值范围为1~4294967295。
dynamic:显示动态BFD会话的信息。
static:显示静态BFD会话的信息。
name session-name:显示指定名称的静态BFD会话的详细信息,session-name表示静态BFD会话的名称,为1~64个字符的字符串,区分大小写。
control:显示控制报文方式的BFD会话信息。
echo:显示echo报文方式的BFD会话信息。
ip:显示检测IPv4链路的BFD会话信息。
ipv6:显示检测IPv6链路的BFD会话信息。
lsp:显示检测LSP链路的BFD会话信息。
te:显示检测TE隧道的BFD会话信息。
pw:显示检测PW链路的BFD会话信息。
srv6-policy:显示检测SRv6 Policy的BFD会话信息。
state:显示不同状态下的BFD会话信息。
down:显示会话状态为Down的BFD会话信息。
admin-down:显示会话状态为AdminDown的BFD会话信息。
init:显示会话状态为Init的BFD会话信息。
up:显示会话状态为Up的BFD会话信息。
discriminator remote remote-value:显示指定远端标识符的BFD会话信息。remote-value表示BFD会话的远端标识符的值,取值范围为1~4294967295。
peer-ip ipv4-address:显示指定对端IPv4地址的BFD会话信息,ipv4-address表示对端IPv4地址,为点分十进制形式。
peer-ipv6 ipv6-address:显示指定对端IPv6地址的BFD会话信息,ipv6-address表示对端IPv6地址。
vpn-instance vpn-instance-name:显示指定VPN实例的BFD会话信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则显示公网实例的BFD会话信息。
verbose:显示BFD会话的详细信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定所有单板。
如果未指定dynamic或static参数,将显示所有动态BFD会话和静态BFD会话的信息。
# 显示所有BFD会话的概要信息。
<Sysname> display bfd session
 Total sessions: 10        Up sessions: 10        Init mode: Active
 LD/RD            SourceAddr      DestAddr        State  Holdtime    Interface
 513/513          1.1.1.1         1.1.1.2         Up     2297ms      XGE3/0/1
 IPv6 session working in control packet mode:
       Local discr: 513                  Remote discr: 513
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session state: Up                      Interface: XGE3/0/2
         Hold time: 2142ms
 MPLS LSP session working in control packet mode:
 32773/32770     1.1.1.9         3.3.3.9         Up      0ms         N/A
 IPv6 SR session working in echo mode:
       Local discr: 2049
     Session state: Up                      Interface: Tun1
         Hold time: 2142ms
 IPv6 SR policy session working in echo mode:
       Local discr: 33793
         Source IP: 1::1
    Destination IP: 4::4
     Session state: Up                      Interface: XGE3/0/1
         Hold time: 2357ms
 IPv4 static session working in control packet mode:
 1600/1600        1.1.1.1         1.1.1.2         Up     2290ms      XGE3/0/1
 IPv6 static session working in control packet mode:
       Local discr: 1700                  Remote discr: 1700
         Hold time: 2142ms
 MPLS TE session working in control packet mode:
 2050/2050      1.1.1.1         127.0.0.1       Up       2458ms      N/A
 MPLS TE session working in echo mode:
 LD             SourceAddr      DestAddr        State    Holdtime    Interface
 2051           1.1.1.1         3.3.3.3         Up       4851ms      Tun2
 MPLS PW session working in control packet mode:
 20481/20481    2.2.2.2         127.0.0.1       Up       2489ms      N/A
表1-1 display bfd session命令显示信息描述表
Total sessions
所有BFD会话的数目
Up sessions
up的BFD会话的数目
Init mode
BFD运行模式:
·     Active:主动模式
·     Passive:被动模式
XX session working in yy mode
BFD会话类型及工作方式,有以下几种情况:
·     IPv4 session working in control packet mode:IPv4 BFD会话,工作方式为控制报文方式
·     IPv4 session working in echo mode:IPv4 BFD会话,工作方式为echo报文方式
·     IPv6 session working in control packet mode:IPv6 BFD会话,工作方式为控制报文方式
·     IPv6 session working in echo mode:IPv6 BFD会话,工作方式为echo报文方式
·     MPLS LSP session working in control packet mode:检测LSP的BFD会话,工作方式为控制报文方式
·     MPLS LSP session working in echo mode:检测LSP的BFD会话,工作方式为echo报文方式
·     IPv6 SR session working in echo mode:检测SRv6隧道的BFD会话,工作方式为echo报文方式
·     IPv4 static session working in control packet mode:IPv4静态BFD会话,工作方式为控制报文方式
·     IPv6 static session working in control packet  mode:IPv6静态BFD会话,工作方式为控制报文方式
·     MPLS TE session working in control packet mode:检测MPLS TE隧道的BFD会话,工作方式为控制报文方式
·     MPLS TE session working in echo mode:检测MPLS TE隧道的BFD会话,工作方式为echo报文方式
·     MPLS PW session working in control packet mode:检测LDP PW或静态PW的BFD会话,工作方式为控制报文方式
·     IPv6 SR policy session working in echo mode:检测SRv6 Policy的BFD会话,工作方式为echo报文方式
LD/RD
LD表示会话的本地标识符,RD表示会话的远端标识符
SourceAddr
会话的源IP地址
DestAddr
会话的目的IP地址
会话状态,包括Down、AdmDown、Init和Up
Holdtime
BFD会话离检测时间超时的剩余时间。BFD会话处于down状态时,显示为0ms
会话所在的接口名
Local discr
BFD会话的本地标识符
Remote discr
BFD会话的远端标识符
Source IP
BFD会话的源IP地址
Destination IP
BFD会话的目的IP地址
Session state
BFD会话状态,包括Down、AdmDown、Init和Up
Hold time
# 显示BFD会话的详细信息。
<Sysname> display bfd session verbose
 Total sessions: 9        Up sessions: 9        Init mode: Active
            Source IP: 1.1.1.1                  Destination IP: 1.1.1.2
     Destination port: 3784                      Session state: Up
            Interface: Ten-GigabitEthernet3/0/1
      Min Tx interval: 500ms                Actual Tx interval: 500ms
      Min Rx interval: 500ms                    Detection time: 2500ms
             Rx count: 42                             Tx count: 43
      Connection type: Direct                      Up duration: 00:00:20
            Hold time: 2078ms                        Auth mode: None
       Detection mode: Async                              Slot: 0
             Protocol: OSPF
              Version: 1
            Diag info: No Diagnostic
        Hardware mode: Disable
            Interface: Ten-GigabitEthernet3/0/2
             Rx count: 38                             Tx count: 38
      Connection type: Direct                      Up duration: 00:00:15
            Hold time: 2211ms                        Auth mode: None
             Protocol: OSPFv3
              Version: 1
          Local discr: 32774                      Remote discr: 32770
            Source IP: 1.1.1.9                  Destination IP: 3.3.3.9
     Destination port: 4784                      Session state: Up
            Interface: N/A
      Min Tx interval: 1000ms               Actual Tx interval: 3000ms
      Min Rx interval: 1000ms                   Detection time: 150000ms
             Rx count: 1                              Tx count: 13
      Connection type: Indirect                    Up duration: 00:00:36
            Hold time: 149536ms                      Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
          Local discr: 2049
     Destination port: 3785                      Session state: Up
            Interface: Tunnel1
            Hold time: 2049ms               Actual Tx interval: 500ms
             Rx count: 7065                           Tx count: 7065
      Connection type: Indirect                    Up duration: 00:50:08
       Detection mode: Async                              Slot: 2
             Protocol: SRv6
              Version: 1
         Session name: abc
          Local discr: 310                        Remote discr: 308
            Source IP: 12.1.1.1                 Destination IP: 12.1.1.2
      Min Tx interval: 1000ms               Actual Tx interval: 1000ms
      Min Rx interval: 1000ms                   Detection time: 5000ms
             Rx count: 59                             Tx count: 1003
      Connection type: Direct                      Up duration: 00:19:36
            Hold time: 4426ms                        Auth mode: None
             Protocol: STATIC_IPv4
              Version: 1
      Session name: bbbb
             Protocol: STATIC_IPv6
              Version: 1
 MPLS TE Session working in control packet mode:
          Local discr: 2050                       Remote discr: 2050
            Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
            Interface: N/A
             Rx count: 72                             Tx count: 73
      Connection type: Indirect                    Up duration: 00:00:30
            Hold time: 2458ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
          Local discr: 2051
            Source IP: 1.1.1.1                  Destination IP: 3.3.3.3
            Interface: Tunnel2
            Hold time: 4851ms               Actual Tx interval: 1000ms
             Rx count: 9083                           Tx count: 9637
      Connection type: Indirect                    Up duration: 02:20:42
             Protocol: MPLS_LSPV
              Version: 1
            Diag info: No Diagnostics
          Local discr: 20481                      Remote discr: 20481
            Source IP: 2.2.2.2                  Destination IP: 127.0.0.1
            Interface: N/A
            Hold time: 2489ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
表1-2 display bfd session verbose命令显示信息描述表
Total sessions
所有BFD会话的数目
Up sessions
up的BFD会话的数目
Init mode
BFD运行模式:
·     Active:主动模式
·     Passive:被动模式
Session name
静态BFD会话名称
Local discr
会话的本地标识符
Remote discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Destination port
Comware中BFD报文的目的端口号:
·     控制报文单跳检测的目的端口号为3784
·     echo报文单跳或多跳检测的目的端口号均为3785
·     控制报文多跳检测的目的端口号为4784
·     链路聚合与BFD联动的控制报文的目的端口号为6784
如果本端收到的报文的目的端口号与Comware中使用的端口号不同,本端将使用收到报文的目的端口号作为发送报文的目的端口号
Session state
会话所在的接口名
Min Tx interval
最小发送时间间隔
Min Rx interval
最小接收时间间隔
Actual Tx interval
实际发送间隔。开启延迟BFD协商建立会话的功能后,定时器超时前该字段显示为“-”
Detection time
实际检测间隔
Rx count
接收的报文数
Tx count
发送的报文数
Hold time
Auth mode
会话的认证模式
Connection type
接口的连接类型:
·     Direct:直连
·     Indirect:非直连
Up duration
会话持续up的时间
Detection mode
检测模式:
·     Async:异步模式
·     Demand:查询模式
·     Async/Echo:开启了echo功能的异步模式
·     Demand/Echo:开启了echo功能的查询模式
Slot
BFD会话所在的单板:
格式为“slot-number”,slot-number表示BFD会话所在单板的槽位号
Remaining delay time
延迟会话协商的剩余时间,单位为秒。如果未开启延迟BFD协商建立会话的功能,或者定时器超时,则不显示该字段
Protocol
协议名:
·     OSPF:OSPF与BFD联动的BFD会话
·     ISIS_BR_L1:IS-IS与BFD联动的BFD会话,其中IS-IS的网络类型为广播网络,路由器类型为Level-1
·     ISIS_BR_L2:IS-IS与BFD联动的BFD会话,其中IS-IS的网络类型为广播网络,路由器类型为Level-2
·     ISIS_P2P:IS-IS与BFD联动的BFD会话,其中IS-IS的网络类型为P2P
·     ISIS6_BR_L1:IPv6 IS-IS与BFD联动的BFD会话,其中IPv6 IS-IS的网络类型为广播网络,路由器类型为Level-1
·     ISIS6_BR_L2:IPv6 IS-IS与BFD联动的BFD会话,其中IPv6 IS-IS的网络类型为广播网络,路由器类型为Level-2
·     ISIS6_P2P:IPv6 IS-IS与BFD联动的BFD会话,其中IPv6 IS-IS的网络类型为P2P
·     BGP:BGP与BFD联动的BFD会话
·     MPLS_RSVP:RSVP与BFD联动的BFD会话
·     STATIC4:静态路由与BFD联动的BFD会话
·     TRACK:Track与BFD联动的BFD会话
·     RIP:RIP与BFD联动的BFD会话
·     IPFRR:FIB IP FRR与BFD联动的BFD会话
·     MAD:MAD与BFD联动的BFD会话
·     MPLS_LSPV:检测LSP的BFD会话
·     OSPFv3:OSPFv3与BFD联动的BFD会话
·     BGP4+:IPv6 BGP与BFD联动的BFD会话
·     PIM:PIM与BFD联动的BFD会话
·     PIM6:IPv6 PIM与BFD联动的BFD会话
·     STATIC6:IPv6静态路由与BFD联动的BFD会话
·     RIPNG:RIPng与BFD联动的BFD会话
·     Interface:检测接口状态类型的BFD会话
·     TUNNEL:检测隧道的BFD会话
·     VTEP:检测VTEP的BFD会话
·     LAGG:检测聚合链路的BFD会话
·     SRv6:检测SRv6隧道的BFD会话
·     SRv6PLY:检测SRv6 TE Policy的BFD会话
·     STATIC_IPv4:IPv4静态BFD会话
·     STATIC_IPv6:IPv6静态BFD会话
·     TRACK_EVPN_AC:EVPN的BDF监测的静态BFD会话
Version
版本号
Diag info
会话的诊断信息:
·     No Diagnostic:表示无诊断信息
·     Control Detection Time Expired:表示Ctrl会话本端检测时间超时,会话down
·     Echo Function Failed:表示Echo会话本端检测时间超时或echo报文的源IP地址被删除,会话down
·     Neighbor Signaled Session Down:表示对端通知本端BFD会话down
·     Administratively Down:表示本端系统阻止BFD会话的建立
·     Dampening Down (Remaining time: XXs):BFD会话震荡抑制功能生效期间,不允许建立BFD会话。Remaining time表示剩余抑制时间,单位为秒
Hardware mode
硬件处理BFD报文模式:
·     Enabled:硬件处理BFD报文模式处于开启状态
·     Disable:硬件处理BFD报文模式处于关闭状态,此时由软件处理BFD报文
Encapsulation mode
检测SRv6 TE Policy的BFD会话的报文封装模式:
·     Encaps:普通封装模式
·     Insert:插入封装模式
Tracked interface
静态BFD会话监视的接口
·     bfd static
hardware bfd enable命令用来开启硬件BFD检测或高精度硬件BFD检测。
undo hardware bfd enable命令用来关闭硬件BFD检测。
hardware bfd enable [ high-precision ]
默认硬件BFD检测和高精度硬件BFD检测都是关闭的。
high-precision:开启高精度硬件BFD检测。
在开启或者关闭之前需保证当前环境不存在已建立的BFD会话,否则再次使能该命令可能会引起BFD功能问题。
该命令仅生效于开启硬件BFD检测/高精度硬件BFD检测功能后新建立的BFD会话。
高精度硬件BFD模式功能开启后,该功能支持的最小时间检测间隔为3ms。
[Sysname] hardware bfd enable
The operation will enable hardware BFD. Are you sure you want to continue? [Y/N]:y
display bfd working-mode用来查询系统BFD的工作模式、硬件规格占用情况以及会话支持情况。
开启该命令查询系统BFD的工作模式、硬件规格占用情况以及会话支持情况。
<Sysname> display bfd working-mode
Working in hardware BFD mode:
Total      Reserved   Configured   Remaining
8          1          0            7
Machine0:   reserved  interval:         refcnt:0
Machine1:   dynamic   interval:         refcnt:0
Machine2:   dynamic   interval:         refcnt:0
Machine3:   dynamic   interval:         refcnt:0
Machine4:   dynamic   interval:         refcnt:0
Machine5:   dynamic   interval:         refcnt:0
Machine6:   dynamic   interval:         refcnt:0
Machine7:   dynamic   interval:         refcnt:0
reset bfd session statistics命令用来清除所有BFD会话的统计信息。
# 清除所有BFD会话的统计信息。
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd命令用来开启BFD的告警功能。
undo snmp-agent trap enable bfd命令用来关闭BFD的告警功能。
BFD的告警功能处于开启状态。
开启BFD模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 关闭BFD的告警功能。
[Sysname] undo snmp-agent trap enable bfd
1.2  SBFD配置命令
bfd detect-multiplier命令用来配置SBFD检测时间倍数。
SBFD检测时间倍数为3。
BFD模板视图
value:SBFD检测时间倍数,取值范围为3~50。
检测时间倍数,即允许Initiator发送SBFD报文的最大连续丢包数。
实际检测时间为Initiator的检测时间倍数和发送SBFD报文的最小时间间隔的乘积。
# 在BFD模板abc中,配置SBFD检测时间倍数为6。
[Sysname] bfd template abc
[Sysname-bfd-template-abc] bfd detect-multiplier 6
·     bfd min-transmit-interval
bfd min-echo-receive-interval命令用来配置接收SBFD echo报文的最小时间间隔。
接收SBFD echo报文的最小时间间隔为100毫秒。
BFD模板视图
interval:接收SBFD echo报文的最小时间间隔,单位为毫秒。取值范围为0或3~10000,如果将其设置为0毫秒,则表示设备不再接收SBFD echo报文。
使用本命令,设备能够控制接收两个SBFD echo报文之间的时间间隔,即SBFD echo报文实际发送时间间隔。
# 配置接口Ten-GigabitEthernet3/0/1接收SBFD echo报文的最小时间间隔为500毫秒。
bfd min-transmit-interval命令用来配置发送SBFD报文的最小时间间隔。
发送SBFD报文的最小时间间隔为100毫秒。
BFD模板视图
interval:发送SBFD报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
本命令主要是为了保证发送SBFD控制报文的速度不能超过设备发送报文的能力。
Initiator实际发送SBFD报文的时间间隔即为本地配置的发送SBFD报文的最小时间间隔。
# 在BFD模板abc中,配置发送SBFD报文的最小时间间隔为500毫秒。
[Sysname-bfd-template-abc] bfd min-transmit-interval 500
·     bfd detect-multiplier
bfd multi-hop detect-multiplier命令用来配置SBFD检测时间倍数。
SBFD检测时间倍数为3。
# 配置SBFD检测时间倍数为6。
bfd multi-hop min-transmit-interval命令用来配置发送SBFD控制报文的最小时间间隔。
发送SBFD控制报文的最小时间间隔为100毫秒。
interval:发送SBFD控制报文的最小时间间隔,单位为毫秒。取值范围为3~10000。
# 配置发送SBFD控制报文的最小时间间隔为500毫秒。
bfd session-negotiation delay-upon-down命令用来开启延迟DOWN状态的SBFD会话进行协商的功能,并设置延迟会话协商的时间。
延迟DOWN状态的SBFD会话进行协商的功能处于关闭状态。
interval:设置延迟DOWN状态的SBFD会话进行协商的时间,取值范围为1~1200,单位为秒。
在上层应用使用SBFD检测主用路径的场景中,主用路径DOWN后,触发上层协议进行主备路径切换。如果主路径故障恢复前,检测主用路径的SBFD会话重新UP,将会触发备份路径切换到处于故障状态的主路径,会导致流量丢失。使用本功能可以解决上述问题。
开启本功能后,工作机制如下:
·     设备将对每一个从UP状态切换为DOWN状态的SBFD会话启动一个定时器,在定时器超时前,对应的会话不会进行重协商。
·     任何新建立的SBFD会话,设备都会启动定时器。在定时器超时前,不会重新进行会话协商。
# 开启延迟DOWN状态的SBFD会话进行会话协商的功能,并设置延迟会话协商的时间为6秒。
·     display sbfd session
bfd session-negotiation delay-upon-reboot命令用来开启设备整机重启后延迟SBFD进行会话协商的功能,并设置延迟会话协商的时间。
设备整机重启后延迟SBFD进行会话协商的功能处于关闭状态。
interval:设置设备整机重启后延迟SBFD进行会话协商的时间,取值范围为1~1200,单位为秒。
在上层应用使用SBFD检测主用路径的场景中,设备整机重启可能会触发主备路径切换。当设备重启成功后,若检测主用路径的SBFD会话重新UP,则触发备份路径切换到主路径。但是,如果此时上层协议的主路径还未完全恢复,会导致流量丢失。使用本功能可以解决上述问题。
开启本功能的设备重启成功后,会启动一个延迟定时器,在定时器超时前,如下两种情况的SBFD会话不会进行会话协商:
·     已有的DOWN状态的SBFD会话不会进行重新协商。
·     新建立的SBFD会话不会进行协商。
延时定时器超时后,SBFD会话的协商不再受本命令影响。
# 开启设备整机重启后延迟SBFD进行会话协商的功能,并设置延迟会话协商的时间为6秒。
1.2.8  bfd template
不存在BFD模板。
display sbfd session命令用来显示SBFD会话信息。
display sbfd session { initiator | reflector } [ discriminator value | verbose ]
display sbfd session initiator srv6-policy [ verbose ]
initiator:显示Initiator端的SBFD会话信息。
srv6-policy:显示检测SRv6 Policy的SBFD会话。
reflector:显示Reflector端的SBFD会话信息。
discriminator value:显示指定本地标识符的SBFD会话的详细信息。value为本地标识符的值,取值范围为1~4294967295。
verbose:显示所有SBFD会话的详细信息。
如果未指定discriminator或verbose参数,将显示Initiator端或Reflector端的所有SBFD会话的概要信息。
# 显示所有Initiator SBFD会话的概要信息。
<Sysname> display sbfd session initiator
 Total sessions: 2     Up sessions: 2
 SBFD session (MPLS LSP):
       Local discr: 32770                Remote discr: 1000001
     Session state: Up                      Hold time: 2184ms
 SBFD session (SRv6 PLY):
       Local discr: 33794                Remote discr: 1000001
         Source IP: 15::15
    Destination IP: 3::3
     Session state: Up                      Hold time: 4201ms
表1-3 display sbfd session initiator命令显示信息描述表
Total sessions
所有SBFD会话的数目
Up sessions
up的SBFD会话的数目
SBFD session (xxx)
创建SBFD会话的协议类型,xxx表示协议名称:
·     MPLS LSP:MPLS协议创建的SBFD会话
·     SRv6 PLY:SRv6 Policy创建的SBFD会话
Local discr
会话的本地标识符
Remote discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Session state
SBFD会话状态,包括Up和Down
Hold time
SBFD会话离检测时间超时的剩余时间,单位为毫秒。SBFD会话处于down状态时,显示为0ms
# 显示Initiator端本地标识符为32770的SBFD会话的详细信息。
<Sysname> display sbfd session initiator discriminator 32770
          Local discr: 32770                      Remote discr: 1000002
        Session state: Up                            Hold time: 4130ms
       Detection time: 5000ms                      Up duration: 00:01:18
             Rx count: 1                              Tx count: 78
                 Slot: 0
             Protocol: MPLS_LSPV
        Template name: temmpls
表1-4 display sbfd session initiator discriminator命令显示信息描述表
Local discr
会话的本地标识符
Remote discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Session state
会话状态,包括Up和Down
Hold time
Color
SRv6 TE Policy的Color属性
NID
SRv6 TE Policy SID列表的转发表项索引
Min Tx interval
当前最小发送时间间隔,单位为毫秒
Actual Tx interval
实际的发送间隔,单位为毫秒。开启延迟SBFD协商建立会话的功能后,定时器超时前该字段显示为“-”
Detection time
实际检测间隔,单位为毫秒
Up duration
会话持续UP的时间
Rx count
接收的报文数
Tx count
发送的报文数
Slot
格式为“slot-number”,slot-number表示SBFD会话所在单板的槽位号
延迟会话协商的剩余时间,单位为秒。如果未开启延迟SBFD协商建立会话的功能,或者定时器超时,则不显示该字段
Protocol
协议名称
Diag info
会话的诊断信息
·     Control Detection Time Expired:表示本端SBFD会话检测时间超时,会话down
·     Neighbor Signaled Session Down:表示对端通知本端SBFD会话down
Template name
关联的BFD模板名称。如果未关联BFD模板,则不显示该字段
Hardware mode
硬件处理SBFD报文模式:
·     Enabled:硬件处理SBFD报文模式处于开启状态
·     Disable:硬件处理SBFD报文模式处于关闭状态,此时由软件处理SBFD报文
Encapsulation mode
检测SRv6 TE Policy的SBFD会话的报文封装模式:
·     Encaps:普通封装模式
·     Insert:插入封装模式
# 显示Initiator端所有SBFD会话的详细信息。
<Sysname> display sbfd session initiator verbose
       Detection time: 5000ms                      Up duration: 00:01:19
             Rx count: 1                              Tx count: 79
                 Slot: 0
             Protocol: MPLS_LSPV
        Template name: abc
            Source IP: 15::15
                Color: 10                                  NID: 2149580802
       Detection time: 5000ms                      Up duration: 00:22:43
             Rx count: 232                            Tx count: 242
                 Slot: 0
             Protocol: SRv6PLY
表1-5 display sbfd session initiator verbose命令显示信息描述表
Total sessions
所有BFD会话的数目
Up sessions
up的BFD会话的数目
SBFD session (xxx)
创建SBFD会话的协议,xxx表示协议名称:
·     MPLS LSP:MPLS协议创建的会话
Local discr
会话的本地标识符
Remote discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Session state
会话状态,包括Up和Down
Hold time
SBFD会话离检测时间超时的剩余时间。SBFD会话处于down状态时,显示为0ms
Color
NID
Min Tx interval
当前最小发送时间间隔
Actual Tx interval
实际的发送间隔。开启延迟SBFD协商建立会话的功能后,定时器超时前该字段显示为“-”
Detection time
实际检测间隔,单位为毫秒
Up duration
会话持续UP的时间
Rx count
接收的报文数
Tx count
发送的报文数
Slot
Protocol
协议名称:
·     MPLS_LSPV:检测LSP的SBFD会话
·     SRv6PLY:检测SRv6 TE Policy的SBFD会话
Diag info
会话的诊断信息
Template name
关联的BFD模板名称。关联的BFD模板名称。如果未关联BFD模板,则不显示该字段
Hardware mode
硬件处理SBFD报文模式:
Encapsulation mode
·     Encaps:普通封装模式
·     Insert:插入封装模式
# 显示Reflector端所有SBFD会话的概要信息。
<Sysname> display sbfd session reflector
 Local discriminator 1000001 on slot 0
 Configured mode: Explicit Value
 Total sessions: 1
       Local discr: 1000001              Remote discr: 32770
         Source IP: 3.2.1.2            Destination IP: 1.1.1.1
         Hold time: 29296ms                  VRF name: -
 Local discriminator 1234567 on slot 0
 Total sessions: 1
       Local discr: 1234567              Remote discr: 33793
         Source IP: 2::22
    Destination IP: 100::1
         Hold time: 29678ms                  VRF name: -
表1-6 display sbfd session reflector命令显示信息描述表
Local discriminator xx on slot yy
在slot yy上本地标识符为xx的SBFD会话信息
Configured mode
标识符的配置形式:
·     IP Address:表示配置IPv4地址形式的Reflector端标识符
·     Explicit Value:表示配置整数形式的Reflector端标识符
Total sessions
标识符所在slot上的会话数目
Local discr
会话的本地标识符
Remote discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Hold time
VRF name
会话的VPN实例名称(“-”表示未绑定VPN实例)
# 显示Reflector端本地标识符为1000001的SBFD会话的详细信息。
<Sysname> display sbfd session reflector discriminator 1000001
 Configured mode: IP Address
 Total sessions: 1
      Min Tx interval: 1000ms                  Min Rx interval: 10ms
         Detect multi: 5                           Up duration: 00:16:51
             Rx count: 967                            Tx count: 967
        Max Rx period: 3008ms                    Max Tx period: 1000us
            Hold time: 29374ms
             VRF name: -
# 显示Reflector端本地标识符为1234567的SBFD会话的详细信息。
<Sysname> display sbfd session reflector discriminator 1234567
 Total sessions: 1
            Source IP: 2::22
      Min Tx interval: 500ms                   Min Rx interval: 10ms
         Detect multi: 5                           Up duration: 05:35:20
             Rx count: 46371                          Tx count: 46371
        Max Rx period: 611ms                     Max Tx period: 2000us
            Hold time: 29622ms
             VRF name: -
表1-7 display sbfd session reflector discriminator命令显示信息描述表
Configured mode
标识符的配置形式:
·     IP address:表示配置IPv4地址形式的Reflector端标识符
Total sessions
标识符所在板上的会话数目
Local discr
会话的本地标识符
Remote discr
会话的远端标识符
Source IP
会话的源IP地址
Destination IP
会话的目的IP地址
Min Tx interval
收到报文中的最小发送时间间隔
Min Rx interval
最小接收间隔
Detect multi
接收到的报文中携带的检测倍数
Up duration
会话持续UP的时间
Rx count
接收的报文数
Tx count
发送的报文数
Max Rx period
最大收包时间间隔,单位为毫秒
Max Tx period
收到报文后回复应答报文的最大时间间隔,单位为微秒
Hold time
VRF name
Hardware mode
硬件处理SBFD报文模式:
·     sbfd local-discriminator
hardware sbfd-reflector enable命令用来在SBFD会话的Reflector端开启硬件反射功能。
undo hardware sbfd-reflector enable命令用来在SBFD会话的Reflector端关闭硬件反射功能。
硬件SBFD反射功能是开启的。
# 在SBFD会话的Reflector端开启硬件反射功能。
[Sysname] hardware sbfd-reflector enable
sbfd destination ipv4 remote-discriminator命令用来在Initiator端配置被检测路径的目的IPv4地址和远端标识符的映射关系。
undo sbfd destination ipv4命令用来取消Initiator端被检测路径的目的IPv4地址和远端标识符的映射关系的配置。
sbfd destination ipv4 destination-ipv4-address remote-discriminator { ipv4-address | integer-value }
undo sbfd destination ipv4 destination-ipv4-address
未配置Initiator端被检测路径的目的IPv4地址和远端标识符的映射关系。
destination-ipv4-address:被检测路径的目的IPv4地址,需要为有效的单播地址。
ipv4-address:IPv4地址形式的远端标识符,需要为有效的单播地址。
integer-value:整数形式的远端标识符,取值范围为1~4294967295。
使用SBFD检测LSP、MPLS TE隧道或SR-MPLS TE Policy时,如果希望控制建立SBFD会话使用的远端标识符,可以使用本命令配置被检测路径的目的IPv4地址和远端标识符的映射关系。
Initiator端按照下面的顺序选取SBFD会话的远端标识符:
(1)     使用SBFD进行路径连通性检测的配置中指定的SBFD会话的远端标识符。例如,使用mpls sbfd命令检测LSP的连通性的配置中指定的SBFD会话的远端标识符。
(2)     本命令配置的远端标识符。
(3)     被检测路径的目的IPv4地址。例如,使用SBFD检测SR-MPLS TE Policy时,将End-point地址作为SBFD会话的远端标识符。
多次执行本命令,可以在Initiator端配置多个被检测路径的目的IPv4地址和远端标识符的映射关系。
配置映射关系或者取消映射关系的配置时,如果SBFD会话处于UP状态,可能会导致会话震荡。
# 在Initiator端配置使用SBFD检测到达目的地址22.22.2.2/32的LSP的连通性,并使用1.1.1.1作为SBFD会话的远端标识符。
[Sysname] mpls bfd enable
[Sysname] mpls sbfd 22.22.2.2 32
[Sysname] sbfd destination ipv4 22.22.2.2 remote-discriminator 1.1.1.1
·     mpls sbfd(MPLS命令参考/MPLS OAM)
·     sbfd(Segment Routing命令参考/SR-MPLS TE Policy)
·     sr-policy sbfd enable(Segment Routing命令参考/SR-MPLS TE Policy)
sbfd destination ipv6 remote-discriminator命令用来在Initiator端配置被检测路径的目的IPv6地址和远端标识符的映射关系。
undo sbfd destination ipv6命令用来取消Initiator端被检测路径的目的IPv6地址和远端标识符的映射关系的配置。
sbfd destination ipv6 destination-ipv6-address remote-discriminator { ipv4-address | integer-value }
undo sbfd destination ipv6 destination-ipv6-address
未配置Initiator端被检测路径的目的IPv6地址和远端标识符的映射关系。
destination-ipv6-address:被检测路径的目的IPv6地址,需要为有效的全球单播地址。
integer-value:整数形式的远端标识符。本参数的取值范围为1~4294967295。
使用SBFD检测SRv6 TE Policy时,如果希望控制建立SBFD会话使用的远端标识符,可以使用本命令配置被检测路径的目的IPv6地址和远端标识符的映射关系。
(1)     使用SBFD检测SRv6 TE Policy连通性的配置中指定的SBFD会话的远端标识符。
(2)     本命令配置的远端标识符。
使用SBFD检测SRv6 TE Policy时,如果未配置SBFD会话的远端标识符,则无法建立SBFD会话。
多次执行本命令,可以在Initiator端配置多个被检测路径的目的IPv6地址和远端标识符的映射关系。
# 在Initiator端全局开启SRv6 TE Policy的SBFD功能,并使用1.1.1.1作为SBFD会话的远端标识符。
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] srv6-policy sbfd
[Sysname-srv6-te] quit
[Sysname-segment-routing-ipv6] quit
[Sysname] sbfd destination ipv6 10::1 remote-discriminator 1.1.1.1
·     sbfd(Segment Routing命令参考/SRv6 TE Policy)
·     srv6-policy sbfd(Segment Routing命令参考/SRv6 TE Policy)
sbfd local-discriminator命令用来在SBFD会话的Reflector端配置本地标识符。
undo sbfd local-discriminator命令用来取消SBFD会话的Reflector端本地标识符的配置。
sbfd local-discriminator { ipv4-address | integer-value }
undo sbfd local-discriminator { ipv4-address | integer-value }
未配置SBFD会话的Reflector端的本地标识符。
ipv4-address:在SBFD会话的Reflector端配置IPv4地址形式的本地标识符,需要为有效的单播地址。
integer-value:在SBFD会话的Reflector端配置整数形式的本地标识符,取值范围为1000001~4294967295。
在BFD会话中,会话的两端都需要维护BFD状态信息,通过周期性地发送BFD报文来检测网络设备间的双向转发路径的可达性。SBFD对链路进行单向检测,其检测速度比BFD更快速,适用于仅一端需要进行链路状态检测的情况,如使用静态SRLSP建立MPLS TE隧道的场景。
SBFD使用Initiator和Reflector来实现对链路的检测:
·     Initiator通过周期性发送SBFD控制报文来检测网络节点到远端实体的链路是否可达。由Initiator发起SBFD会话并维护BFD会话的状态信息。
·     Reflector监听到达本地实体的SBFD控制报文,并发送SBFD控制报文类型的响应报文给Initiator。
Initiator发送的SBFD控制报文中携带的远端标识符必须为本命令指定的标识符,否则Reflector不会发送响应报文给Initiator。
多次执行本命令,可以配置多个SBFD Reflector端标识符。建议配置的SBFD Reflector端标识符的个数不要超过1000个,否则会影响SBFD报文处理性能。
一个节点可以同时作为不同SBFD会话的Initiator和Reflector。
# 在SBFD会话的Reflector端配置本地标识符为1.1.1.1。
[Sysname] sbfd local-discriminator 1.1.1.1
# 在SBFD会话的Reflector端配置本地标识符为1000001。
[Sysname] sbfd local-discriminator 1000001
·     mpls bfd(MPLS命令参考/MPLS OAM)
sbfd initiator accept-down-response命令用来配置Initiator在SBFD会话建立期间收到Reflector发送的Down状态的SBFD报文时,发送Up状态的SBFD报文。
undo sbfd initiator accept-down-response命令用来恢复缺省情况。
Initiator在SBFD会话建立期间收到Reflector发送的Down状态的SBFD报文时,Initiator丢弃该报文,SBFD会话无法建立。
缺省情况下,Initiator建立SBFD会话时,先向Reflector发送状态为Down的SBFD报文。此时,如果Reflector向Initiator发送状态为Down的SBFD响应报文,Initiator将丢弃该报文,导致SBFD会话无法建立。为了避免上述情况的发生,请在Initiator配置本命令。配置本命令后,Initiator在SBFD会话建立期间接收到Down状态的SBFD响应报文后,会发送Up状态的SBFD报文,以便建立SBFD会话。
# 配置Initiator在SBFD会话建立期间收到Reflector发送的Down状态的SBFD报文时,发送Up状态的SBFD报文。
[Sysname] sbfd initiator accept-down-response
sbfd source-ipv6命令用来配置Initiator发送SBFD报文使用的源IPv6地址。
undo sbfd source-ipv6命令用来恢复缺省情况。
sbfd source-ipv6 ipv6-address
未配置Initiator发送SBFD报文使用的源IPv6地址。
ipv6-address:SBFD报文的源IPv6地址,必须是单播地址。
使用SBFD检测SRv6 Policy中转发路径的可达性时,需要在Initiator配置本命令,并确保Reflector上存在到达通过本命令配置的IPv6地址的路由。
# 配置Initiator发送SBFD报文使用的源IPv6地址为80::2。
[Sysname] sbfd source-ipv6 80::2
