13-ACL和QoS
03-HH3C-IFQOS2-MIB
本章节下载 03-HH3C-IFQOS2-MIB  (756.16 KB)
03-HH3C-IFQOS2-MIB
HH3C-IFQOS2-MIB
功能介绍
MIB文件名
根节点
全局节点详细描述
hh3cIfQoSChassis
hh3cIfQoSSlot
hh3cIfQoSCPU
hh3cIfQoSChip
hh3cIfQoSIfName
hh3cIfQoSDirection
hh3cIfQoSPassPacketRate
hh3cIfQoSCoppProtocol
hh3cIfQoSBandwidth
hh3cIfQoSServiceName
hh3cIfQoSApplyObject
hh3cIfQoSFailReason
hh3cIfQoSBandwidthUnit
hh3cIfQoSAggregativeCarNextIndex
hh3cIfQoSWredGroupNextIndex
hh3cQoSTypeOfServiceMode
hh3cIfQoSProcessingStatus
表节点详细描述
hh3cIfQoSQSModeTable
hh3cIfQoSQSWeightTable
hh3cIfQoSHardwareQueueRunInfoTable
hh3cIfQoSHQueueTcpRunInfoTable
hh3cIfQoSLRConfigTable
hh3cIfQoSLRRunInfoTable
hh3cIfQoSAggregativeCarConfigTable
hh3cIfQoSAggregativeCarApplyTable
hh3cIfQoSAggregativeCarRunInfoTable
hh3cIfQoSTricolorCarConfigTable
hh3cIfQoSTricolorCarRunInfoTable
hh3cIfQoSGTSConfigTable
hh3cIfQoSGTSRunInfoTable
hh3cIfQoSWredGroupTable
hh3cIfQoSWredGroupContentTable
hh3cIfQoSWredGroupApplyIfTable
hh3cIfQoSPortPriorityTable
hh3cIfQoSPortPirorityTrustTable
hh3cIfQoSPrePriMapTable
hh3cQoSRemarkTcpPortPriTable
hh3cQoSRemarkUdpPortPriTable
hh3cQoSRemarkIPv4AddrPriTable
hh3cQoSRemarkIPv6AddrPriTable
hh3cQoSRemarkProtocolPriTable
hh3cQoSRemarkVlanPriTable
hh3cIfQoSCoppFlowStatTable
告警信息
hh3cIfQoSLRDiscardAlarm
hh3cIfQoSLRDiscardAlarmRecover
hh3cIfQoSCarDiscardAlarm
hh3cIfQoSCarDiscardAlarmRecover
hh3cIfQoSCoppDropPktAlarm
hh3cIfQoSCoppDropPktAlarmRecover
hh3cIfQoSQueExcpAlarm
hh3cIfQoSQueExcpAlarmRecover
hh3cIfQoSBoardL3AclResLack
hh3cIfQoSAclResAlarm
hh3cIfQoSAclResAlarmRecover
hh3cIfQoSAclMemFullAlarm
hh3cIfQoSAclMemFullAlarmRecover
hh3cIfQoSBufferAlarm
hh3cIfQoSBufferAlarmRecover
hh3cIfQoSQueBufferOverrunAlarm
hh3cIfQoSQueBufferOverrunRecover
hh3cIfQoSFCoEPriorityAlarm
hh3cIfQoSFCoEPriorityRecover
hh3cIfQoSRcyPortPktsDropAlarm
hh3cIfQoSRcyPortPktsDropRecover
hh3cIfQoSStormSuppressAlarm
hh3cIfQoSStormSuppressRecover
hh3cIfQoSUniPktsDiscardAlarm
hh3cIfQoSUniPktsDiscardRecover
hh3cIfQoSIngressDiscardAlarm
hh3cIfQoSIngressDiscardRecover
HH3C-IFQOS2-MIB
功能介绍
HH3C-IF-QOS-MIB包括如下几个模块:
·      硬件队列
·      软件队列
·      LINE RATE
·      CAR
·      GTS
·      WRED
·      端口优先级和端口优先级信任
·      MAP
其中,CAR分为聚合CAR和三色CAR;WRED分为全局WRED和端口WRED。
全局WRED
Weighted Random Early Detection,加权早期随机丢弃检测(简称WRED),在队列还没有满的时候随机进行丢弃,用于拥塞避免。采用WRED时,用户可以设定队列的阈值(threshold)。当队列的长度小于低阈值时,不丢弃报文;当队列的长度在低阈值和高阈值之间时,WRED开始随机丢弃报文(队列的长度越长,丢弃的概率越高);当队列的长度大于高阈值时,丢弃所有的报文。WRED可以感知QoS的带内信令,包括IP优先级、DSCP,和MPLS EXP。可以为不同IP优先级,DSCP,或MPLS EXP的报文设定不同的队列长度滤波系数、队列阈值、丢弃概率,从而对不同优先级的报文提供不同的丢弃特性。与RED不同,WRED生成的随机数是基于优先权的,它引入IP优先权区别丢弃策略,考虑了高优先权报文的利益并使其被丢弃的概率相对较小。
由于WRED随机地丢弃报文,将避免使多个TCP连接同时降低发送速度,从而避免了TCP的全局同步现象。在配置了WRED的队列中,每当一个新的数据包入队的时候,都要对它进行随机丢弃检测,如果通过这加入队列,否则丢弃。WRED可以应用到每个端口,WRED和WFQ配合使用时,可以实现基于流的WRED。
WRED根据作用范围来说,可以划分为:
·     基于端口的WRED。它对所有从该端口发送的报文进行WRED丢弃。
·     基于队列的WRED。仅对配置了WRED的队列起作用,它在数据包入队列的时候对报文进行WRED丢弃。
·     基于丢弃级别的WRED。在接口上将报文根据不同丢弃级别(如高、中、低丢弃级别)分类,并为每种不同丢弃级别配置不同的早期丢弃参数。
·     基于ACL的WRED。在接口上将报文按照ACL分类,并对每种不同分类的报文配置不同的早期丢弃参数。
·     基于8021P的WRED。在接口上根据报文携带的802.1P优先级进行分类,为每个802.1P优先级(0~7)配置不同的早期丢弃参数。
·     基于EXP的WRED。在接口上根据报文携带的EXP优先级进行分类,为每个EXP优    先级(0~7)配置不同的早期丢弃参数。
·     基于ATM-CLP的WRED。在ATM接口上根据信元携带的CLP(Cell Loss Priority)优先级(0~1),为每个CLP优先级配置不同的早期丢弃参数。
·     基于DSCP的WRED。在接口上根据报文携带的DSCP优先级进行分类,为每个DSCP优先级(0~63)配置不同的早期丢弃参数。
·     基于IP-Precedence的WRED。在接口上根据报文携带的IP优先级进行分类,为每个IP优先级(0~7)配置不同的早期丢弃参数。
·     基于Fr-De的WRED。在接口上根据fr-de来配置wred参数。
ComwareV500R002支持两种WRED应用方式:
·     接口下应用WRED参数。用户可以直接在接口下使能WRED功能,并配置WRED丢弃参数。
·     接口下应用WRED Group。用户也可以在全局下配置WRED GROUP,全局将支持64个WRED GROUP。然后在接口下直接应用已经配置的WRED GROUP。功能与接口下应用WRED参数相同,但是能简化用户配置。
聚合CAR
部分交换机芯片支持聚合CAR,能够对于指定的多个端口匹配流使用一个CAR进行流量监管。
聚合CAR是全局CAR的一种子类型。全局CAR为配置在全局的一套CAR参数,在端口通过名称引用该全局CAR。根据全局CAR的生效方式,可以分为聚合CAR和非聚合全局CAR。如果全局CAR指定为聚合模式,引用该全局CAR的端口流量共同使用该CAR的令牌桶进行流量监管;如果全局CAR指定为非聚合模式,引用该全局CAR的端口各独立生成一个该CAR对应的令牌桶,流量在各端口独立进行流量监管。聚合CAR相当于各端口流量共用同一令牌桶进行流量监管,非聚合全局CAR的作用只是为不同端口配置相同的流量监管参数提供便捷方式。QOS项目二期只提供聚合模式的全局CAR功能。
MIB文件名
hh3c-ifqos2.mib
根节点
iso(1).org(3).dod(6).internet(1).private(4).huawei(2011).hh3c(10).hh3cCommon(2).hh3cQos2(65).hh3cIfQos2(1)
全局节点详细描述
hh3cIfQoSChassis
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSChassis
(1.3.6.1.4.1.25506.2.65.1.15.1)
accessible-for-notify
Integer32
0~65534
框号
hh3cIfQoSSlot
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSSlot
(1.3.6.1.4.1.25506.2.65.1.15.2)
Integer32
0~65534
槽号
hh3cIfQoSCPU
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSCPU
 (1.3.6.1.4.1.25506.2.65.1.15.3)
Integer32
0~65534
CPU号
hh3cIfQoSChip
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSChip
(1.3.6.1.4.1.25506.2.65.1.15.4)
Integer32
0~65534
芯片号
hh3cIfQoSIfName
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSIfName (1.3.6.1.4.1.25506.2.65.1.15.5)
OCTET STRING
SIZE (1~47)
接口名称
hh3cIfQoSDirection
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSDirection
(1.3.6.1.4.1.25506.2.65.1.15.6)
Direction
同MIB标准取值
方向
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSPassPacketRate (1.3.6.1.4.1.25506.2.65.1.15.7)
read-only
Unsigned32
同MIB标准取值
流量速率
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSCoppProtocol (1.3.6.1.4.1.25506.2.65.1.15.8)
read-only
OCTET STRING
SIZE (1~31)
协议类型
hh3cIfQoSBandwidth
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSBandwidth (1.3.6.1.4.1.25506.2.65.1.15.9)
read-only
Unsigned32
同MIB标准取值
带宽
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSServiceName (1.3.6.1.4.1.25506.2.65.1.15.10)
read-only
OCTET STRING
SIZE (1~63)
服务名称
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSApplyObject (1.3.6.1.4.1.25506.2.65.1.15.11)
read-only
OCTET STRING
SIZE (1~127)
应用对象
hh3cIfQoSFailReason
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSFailReason (1.3.6.1.4.1.25506.2.65.1.15.12)
read-only
OCTET STRING
SIZE (1~127)
失败原因
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSBandwidthUnit (1.3.6.1.4.1.25506.2.65.1.15.13)
read-only
INTEGER
·     unitUnavailable (0)
·     unitAbsolute (1)
·     unitAbsolutePPS (4)
带宽单位
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSAggregativeCarNextIndex (1.3.6.1.4.1.25506.2.65.1.4.1.1)
read-only
Integer32
·     1~65534
聚合CAR索引
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSWredGroupNextIndex (1.3.6.1.4.1.25506.2.65.1.6.1.1)
read-only
Integer32
·     0~256
WRED Group索引
需要产品确认规格
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSTypeOfServiceMode (1.3.6.1.4.1.25506.2.65.1.12.7.1)
read-write
Integer32
·     disabled (1)
·     ipPrecedence (2)
·     dscp (3)
·     disabled (4)
全局服务类型
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSProcessingStatus (1.3.6.1.4.1.25506.2.65.1.13.1)
read-only
Integer32
·     idle (1)
·     busy (2)
IFQoS模块进程状态
表节点详细描述
【功能描述】
该表用来设置队列的调度方式,与hh3cIfQoSQSWeightTable协同完成对队列的配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSQSMode (1.3.6.1.4.1.25506.2.65.1.1.1.1.1.1)
read-write
INTEGER
·     sp(1)
·     sp0(2)
·     sp1(3)
·     sp2(4)
·     wrr(5)
·     hwfq(6)
·     wrr-sp(7)
·     byteCountWrr(8)byteCountWfq(9)
·     gmb(10)
端口的队列调度模式
需要产品确认规格
【功能描述】
该表用来配置队列的调度方式不是SP的端口的各个队列调度属性,其中包括队列属于哪个WRR优先组,队列调度的方式,队列调度的权重,与hh3cIfQoSQSModeTable协同完成对端口队列调度的配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex、hh3cIfQoSQueueID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSQueueID (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.1)
not-accessible
Integer32
同MIB标准取值
端口的队列号
实现与MIB文件定义一致
hh3cIfQoSQueueGroupType (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.2)
read-write
INTEGER
·     group0(1)
·     group1(2)
·     group2(3)
·     group3(4)
·     group4(5)
表示该队列属于哪个WRR优先组
需要产品确认规格
hh3cIfQoSQSType (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.3)
read-write
INTEGER
·     weight(1)
·     byte-count(2)
队列调度方式
实现与MIB文件定义一致
hh3cIfQoSQSValue (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.4)
read-write
Integer32
同MIB标准取值
队列调度权重
实现与MIB文件定义一致
hh3cIfQoSQSMaxDelay (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.5)
read-write
Integer32
同MIB标准取值
最大延迟
不支持
值总是9
hh3cIfQoSQSMinBandwidth (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.6)
read-write
Integer32
同MIB标准取值
最小带宽保证
需要产品确认规格
hh3cIfQoSQSMinBandwidthPercent(1.3.6.1.4.1.25506.2.65.1.1.1.2.1.7)
read-write
Unsigned32
·     0~100
·     255
最小保证带宽占可用带宽的百分比
需要产品确认规格
【功能描述】
该表用来收集端口队列运行信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSPassPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.1)
read-only
Counter64
同MIB标准取值
报文数量-已转发的报文
实现与MIB文件定义一致
hh3cIfQoSDropPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.2)
read-only
Counter64
同MIB标准取值
报文数量-丢弃的报文
实现与MIB文件定义一致
hh3cIfQoSPassBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.3)
read-only
Counter64
同MIB标准取值
字节数量-已转发的报文
实现与MIB文件定义一致
hh3cIfQoSPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.4)
read-only
Unsigned32
同MIB标准取值
报文速率-已转发的报文
实现与MIB文件定义一致
hh3cIfQoSPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.5)
read-only
Unsigned32
同MIB标准取值
字节速率-已转发的报文
实现与MIB文件定义一致
hh3cIfQoSDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.6)
read-only
Counter64
同MIB标准取值
字节数量-丢弃的报文
实现与MIB文件定义一致
hh3cIfQoSQueueLengthInPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.7)
read-only
Unsigned32
同MIB标准取值
报文数量-队列最大长度
实现与MIB文件定义一致
hh3cIfQoSQueueLengthInBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.8)
read-only
Unsigned32
同MIB标准取值
字节数量-队列最大长度
不支持
hh3cIfQoSCurQueuePkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.9)
read-only
Unsigned32
同MIB标准取值
报文数量-当前排队的报文
不支持
hh3cIfQoSCurQueueBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.10)
read-only
Unsigned32
同MIB标准取值
字节数量-当前排队报文
不支持
hh3cIfQoSCurQueuePPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.11)
read-only
Unsigned32
同MIB标准取值
报文速率-当前排队报文
不支持
hh3cIfQoSCurQueueBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.12)
read-only
Unsigned32
同MIB标准取值
字节速率-当前排队报文
不支持
hh3cIfQoSTailDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.13)
read-only
Counter64
同MIB标准取值
报文数量-队尾丢弃的报文
不支持
hh3cIfQoSTailDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.14)
read-only
Counter64
同MIB标准取值
字节数量-队尾丢弃的报文
不支持
hh3cIfQoSTailDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.15)
read-only
Unsigned32
同MIB标准取值
报文速率-队尾丢弃的报文
不支持
hh3cIfQoSTailDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.16)
read-only
Unsigned32
同MIB标准取值
字节速率-队尾丢弃的报文
不支持
hh3cIfQoSWredDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.17)
read-only
Counter64
同MIB标准取值
报文数量-WRED丢弃的报文
不支持
hh3cIfQoSWredDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.18)
read-only
Counter64
同MIB标准取值
字节数量-WRED丢弃的报文
不支持
hh3cIfQoSWredDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.19)
read-only
Unsigned32
同MIB标准取值
报文速率-WRED丢弃的报文
不支持
hh3cIfQoSWredDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.20)
read-only
Unsigned32
同MIB标准取值
字节速率-WRED丢弃的报文
不支持
hh3cIfQoSPeakPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.24)
read-only
Unsigned32
同MIB标准取值
报文峰值速率-已转发的报文
实现与MIB文件定义一致
hh3cIfQoSPeakPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.25)
read-only
Unsigned32
同MIB标准取值
字节峰值速率-已转发的报文
实现与MIB文件定义一致
【功能描述】
该表用来收集关于TCP和非TCP报文的端口队列运行信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSWredDropLPreNTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.1)
read-only
Counter64
同MIB标准取值
报文数量-WRED丢弃的低优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreNTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.2)
read-only
Counter64
同MIB标准取值
字节数量-WRED丢弃的低优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreNTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.3)
read-only
Unsigned32
同MIB标准取值
报文速率-WRED丢弃的低优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreNTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.4)
read-only
Unsigned32
同MIB标准取值
字节速率-WRED丢弃的低优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.5)
read-only
Counter64
同MIB标准取值
报文数量-WRED丢弃的低优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.6)
read-only
Counter64
同MIB标准取值
字节数量-WRED丢弃的低优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.7)
read-only
Unsigned32
同MIB标准取值
报文速率-WRED丢弃的低优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropLPreTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.8
read-only
Unsigned32
同MIB标准取值
字节速率-WRED丢弃的低优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreNTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.9)
read-only
Counter64
同MIB标准取值
报文数量-WRED丢弃的高优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreNTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.10)
read-only
Counter64
同MIB标准取值
字节数量-WRED丢弃的高优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreNTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.11)
read-only
Unsigned32
同MIB标准取值
报文速率-WRED丢弃的高优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreNTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.12)
read-only
Unsigned32
同MIB标准取值
字节速率-WRED丢弃的高优先级非TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.13)
read-only
Counter64
同MIB标准取值
报文数量-WRED丢弃的高优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.14)
read-only
Counter64
同MIB标准取值
字节数量-RED丢弃的高优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.15)
read-only
Unsigned32
同MIB标准取值
报文速率-WRED丢弃的高优先级TCP报文
实现与MIB文件定义一致
hh3cIfQoSWredDropHPreTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.16)
read-only
Unsigned32
同MIB标准取值
字节速率-WRED丢弃的高优先级TCP报文
实现与MIB文件定义一致
【功能描述】
该表用来限制物理接口的接收或者向外发送数据的速率的配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是IfIndex、hh3cIfQoSLRDirection。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSLRDirection (1.3.6.1.4.1.25506.2.65.1.3.1.1.1)
not-accessible
Direction
同MIB标准取值
对接口的入/出方向数据流进行限速
需要产品确认规格
hh3cIfQoSLRCir (1.3.6.1.4.1.25506.2.65.1.3.1.1.2)
read-create
Unsigned32
同MIB标准取值
承诺信息速率
需要产品确认规格
hh3cIfQoSLRCbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.3)
read-create
Unsigned32
同MIB标准取值
在绝对值调度方式下,表示承诺突发尺寸;在百分比调度方式下,表示某段时间内的承诺突发尺寸
需要产品确认规格
hh3cIfQoSLREbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.4)
read-create
Unsigned32
同MIB标准取值
超额突发尺寸,在双令牌桶算法中超额突发流量超出承诺突法流量的部分
在百分比调度方式下,表示某段时间内超出的突发尺寸
需要产品确认规格
hh3cIfQoSRowStatus (1.3.6.1.4.1.25506.2.65.1.3.1.1.5)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cIfQoSLRPir (1.3.6.1.4.1.25506.2.65.1.3.1.1.6)
read-create
Unsigned32
同MIB标准取值
峰值信息速率
需要产品确认规格
hh3cIfQoSLRUnit (1.3.6.1.4.1.25506.2.65.1.3.1.1.7)
read-create
INTEGER
·     unitAbsolute(1)
·     unitPercent(2)
限速的单位
需要产品确认规格
【功能描述】
该表用来统计端口使能物理限速的运行信息统计表。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex、hh3cIfQoSLRDirection。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSLRRunInfoPassedPackets (1.3.6.1.4.1.25506.2.65.1.3.2.1.1)
read-only
Counter64
同MIB标准取值
已经通过的数据包数目
实现与MIB文件定义一致
hh3cIfQoSLRRunInfoPassedBytes (1.3.6.1.4.1.25506.2.65.1.3.2.1.2)
read-only
Counter64
同MIB标准取值
已经通过的字节数
实现与MIB文件定义一致
hh3cIfQoSLRRunInfoDelayedPackets (1.3.6.1.4.1.25506.2.65.1.3.2.1.3)
read-only
Counter64
同MIB标准取值
被延迟发送的数据包数目
实现与MIB文件定义一致
hh3cIfQoSLRRunInfoDelayedBytes (1.3.6.1.4.1.25506.2.65.1.3.2.1.4)
read-only
Counter64
同MIB标准取值
被延迟发送的字节数
实现与MIB文件定义一致
hh3cIfQoSLRRunInfoActiveShaping (1.3.6.1.4.1.25506.2.65.1.3.2.1.5)
read-only
INTEGER
·     active(1)
·     inactive(2)
当前限速配置是否被激活
实现与MIB文件定义一致
【功能描述】
该表用来统计全局聚合CAR的配置信息。聚合CAR能够对于指定的多个端口匹配流,使用一个CAR进行流量监管。路由器当前不支持该规格;部分交换机芯片支持聚合CAR功能,请参考产品说明手册。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cIfQoSAggregativeCarIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSAggregativeCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.1)
not-accessible
Integer32
1~65534
聚合CAR索引
实现与MIB文件定义一致
hh3cIfQoSAggregativeCarName (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.2)
read-create
OCTET STRING
SIZE (1~31)
聚合CAR名称
实现与MIB文件定义一致
hh3cIfQoSAggregativeCarCir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.3)
read-create
Unsigned32
同MIB标准取值
承诺信息速率
实现与MIB文件定义一致
hh3cIfQoSAggregativeCarCbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.4)
read-create
Unsigned32
同MIB标准取值
承诺突发尺寸
需要产品确认规格
hh3cIfQoSAggregativeCarEbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.5)
read-create
Unsigned32
同MIB标准取值
超额突发尺寸
需要产品确认规格
hh3cIfQoSAggregativeCarPir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.6)
read-create
Unsigned32
同MIB标准取值
峰值信息速率
需要产品确认规格
hh3cIfQoSAggregativeCarGreenActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.7)
read-create
Hh3cIfCarAction
同MIB标准取值
低于承诺信息速率时采取的动作
需要产品确认规格
hh3cIfQoSAggregativeCarGreenActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.8)
read-create
Integer32
·     0~63
·     255
绿色报文重新标记值
需要产品确认规格
hh3cIfQoSAggregativeCarYellowActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.9)
read-create
Hh3cIfCarAction
同MIB标准取值
超过承诺信息速率但低于峰值信息速率时采取的动作
需要产品确认规格
hh3cIfQoSAggregativeCarYellowActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.10)
read-create
Integer32
·     0~63
·     255
黄色报文重新标记值
需要产品确认规格
hh3cIfQoSAggregativeCarRedActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.11)
read-create
Hh3cIfCarAction
同MIB标准取值
超过峰值信息速率时采取的动作
需要产品确认规格
hh3cIfQoSAggregativeCarRedActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.12)
read-create
Integer
·     0~63
·     255
红色报文重新标记值
需要产品确认规格
hh3cIfQoSAggregativeCarType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.13)
read-create
INTEGER
·     aggregative(1)
·     NotAggregative(2)
·     hierarchy(3)
聚合CAR的类型
需要产品确认规格
hh3cIfQoSAggregativeCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.14)
read-create
RowStatus
同MIB标准取值
行状态
实现与MIB文件定义一致
【功能描述】
该表用来统计聚合CAR在端口的应用情况。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是IfIndex、hh3cIfQoSAggregativeCarApplyDirection、hh3cIfQoSAggregativeCarApplyRuleType、hh3cIfQoSAggregativeCarApplyRuleValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSAggregativeCarApplyDirection (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.1)
not-accessible
Direction
同MIB标准取值
流量监管方向
需要产品确认规格
hh3cIfQoSAggregativeCarApplyRuleType (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.2)
not-accessible
INTEGER
·     ipv4acl(1)
·     ipv6acl(2)
·     carl(3)
·     any(4)
分类规则类型
需要产品确认规格
hh3cIfQoSAggregativeCarApplyRuleValue (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.3)
not-accessible
Integer32
0~2147483647
分类规则信息
需要产品确认规格.
hh3cIfQoSAggregativeCarApplyCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.4)
read-create
Integer32
1~65534
聚合CAR索引
实现与MIB文件定义一致
hh3cIfQoSAggregativeCarApplyRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.5)
read-create
RowStatus
同MIB标准取值
行状态
实现与MIB文件定义一致
【功能描述】
该表用来统计聚合CAR的运行信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
不支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSAggregativeCarGreenPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.1)
read-only
Counter64
同MIB标准取值
绿色报文数统计
需要产品确认规格
hh3cIfQoSAggregativeCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.2)
read-only
Counter64
同MIB标准取值
绿色报文字节数统计
需要产品确认规格
hh3cIfQoSAggregativeCarYellowPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.3)
read-only
Counter64
同MIB标准取值
黄色报文数统计
需要产品确认规格
hh3cIfQoSAggregativeCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.4)
read-only
Counter64
同MIB标准取值
黄色报文字节数统计
需要产品确认规格
hh3cIfQoSAggregativeCarRedPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.5)
read-only
Counter64
同MIB标准取值
红色报文数统计
需要产品确认规格
hh3cIfQoSAggregativeCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.6)
read-only
Counter64
同MIB标准取值
红色报文字节数统计
需要产品确认规格
【功能描述】
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSTricolorCarDirection (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.1)
not-accessible
Direction
同MIB标准取值
聚合CAR索引
需要产品确认规格
hh3cIfQoSTricolorCarType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.2)
not-accessible
INTEGER
·     ipv4acl(1)
·     ipv6acl(2)
·     carl(3)
·     any(4)
聚合CAR名称
需要产品确认规格
hh3cIfQoSTricolorCarValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.3)
not-accessible
Integer32
0~2147483647
承诺信息速率
需要产品确认规格
hh3cIfQoSTricolorCarCir (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.4)
read-create
Unsigned32
同MIB标准取值
承诺突发尺寸
需要产品确认规格
hh3cIfQoSTricolorCarCbs (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.5)
read-create
Unsigned32
同MIB标准取值
超额突发尺寸
需要产品确认规格
hh3cIfQoSTricolorCarEbs (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.6)
read-create
Unsigned32
同MIB标准取值
峰值信息速率
需要产品确认规格
hh3cIfQoSTricolorCarPir (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.7)
read-create
Unsigned32
同MIB标准取值
低于承诺信息速率时采取的动作
需要产品确认规格
hh3cIfQoSTricolorCarGreenActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.8)
read-create
Hh3cIfCarAction
同MIB标准取值
绿色报文重新标记值
需要产品确认规格
hh3cIfQoSTricolorCarGreenActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.9)
read-create
Integer32
·     0~63
·     255
需要产品确认规格
hh3cIfQoSTricolorCarYellowActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.10)
read-create
Hh3cIfCarAction
同MIB标准取值
黄色报文重新标记值
需要产品确认规格
hh3cIfQoSTricolorCarYellowActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.11)
read-create
Integer32
·     0~63
·     255
超过峰值信息速率时采取的动作
需要产品确认规格
hh3cIfQoSTricolorCarRedActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.12)
read-create
Hh3cIfCarAction
同MIB标准取值
红色报文重新标记值
需要产品确认规格
hh3cIfQoSTricolorCarRedActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.13)
read-create
Integer32
·     0~63
·     255
聚合CAR的类型
需要产品确认规格
hh3cIfQoSTricolorCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.14)
read-create
RowStatus
同MIB标准取值
行状态
实现与MIB文件定义一致
hh3cIfQoSTricolorCarUnitType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.15)
read-create
INTEGER
·     unitAbsolute(1)
·     unitPercent(2)
限速单位
需要产品确认规格.
【功能描述】
该表用来统计三色CAR的运行信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex、hh3cIfQoSTricolorCarDirection、hh3cIfQoSTricolorCarType、hh3cIfQoSTricolorCarValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSTricolorCarGreenPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.1)
read-only
Counter64
同MIB标准取值
绿色报文数统计
需要产品确认规格
hh3cIfQoSTricolorCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.2)
read-only
Counter64
同MIB标准取值
绿色报文字节数统计
需要产品确认规格
hh3cIfQoSTricolorCarYellowPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.3)
read-only
Counter64
同MIB标准取值
黄色报文数统计
需要产品确认规格
hh3cIfQoSTricolorCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.4)
read-only
Counter64
同MIB标准取值
黄色报文字节数统计
需要产品确认规格
hh3cIfQoSTricolorCarRedPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.5)
read-only
Counter64
同MIB标准取值
红色报文数统计
需要产品确认规格
hh3cIfQoSTricolorCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.6)
read-only
Counter64
同MIB标准取值
红色报文字节数统计
需要产品确认规格
【功能描述】
该表用来统计端口GTS配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是ifIndex、hh3cIfQoSGTSClassRuleType、hh3cIfQoSGTSClassRuleValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
(1.3.6.1.4.1.25506.2.65.1.5.1.1.1)
not-accessible
INTEGER
·     any(1)
·     ipv4acl(2)
·     ipv6acl(3)
·     queue(4)
GTS的类型
只支持queue(4)
hh3cIfQoSGTSClassRuleValue (1.3.6.1.4.1.25506.2.65.1.5.1.1.2)
not-accessible
Integer32
0~2147483647
GTS的类型对应的取值
范围是0~7
hh3cIfQoSGTSCir (1.3.6.1.4.1.25506.2.65.1.5.1.1.3)
read-create
Unsigned32
同MIB标准取值
承诺信息速率
·     GigabitEthernet的范围是300~1000000
·     Ten-GigabitEthernet的范围是300~10000000
·     FortyGigE的范围是300~40000000
·     HundredGigE的范围是300~100000000
hh3cIfQoSGTSCbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.4)
read-create
Unsigned32
同MIB标准取值
承诺突发尺寸
·     GigabitEthernet的范围是4096~133169152
·     Ten-GigabitEthernet的范围是4096~133169152
·     FortyGigE的范围是4096~535822336
·     HundredGigE的范围是4096~1341128704
hh3cIfQoSGTSEbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.5)
read-create
Unsigned32
同MIB标准取值
超额突发尺寸,在双令牌桶算法中超额突发流量超出承诺突法流量的部分,单位是byte
不支持
hh3cIfQoSGTSQueueLength (1.3.6.1.4.1.25506.2.65.1.5.1.1.6)
read-create
Integer32
同MIB标准取值
缓存队列的最大长度
不支持
hh3cIfQoSGTSConfigRowStatus (1.3.6.1.4.1.25506.2.65.1.5.1.1.7)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cIfQoSGTSPir (1.3.6.1.4.1.25506.2.65.1.5.1.1.8)
read-create
Unsigned32
同MIB标准取值
端口GTS的峰值信息速率
不支持
hh3cIfQoSGTSUnitType (1.3.6.1.4.1.25506.2.65.1.5.1.1.9)
read-create
INTEGER
·     unitAbsolute (1)
·     unitPercent(2)
端口GTS的单位
只支持unitAbsolute(1)
【功能描述】
该表用来统计端口GTS的运行信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex,hh3cIfQoSGTSClassRuleType,hh3cIfQoSGTSClassRuleValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSGTSQueueSize (1.3.6.1.4.1.25506.2.65.1.5.2.1.1)
read-only
Integer32
同MIB标准取值
当前缓冲区中数据包的数目
实现与MIB文件定义一致
hh3cIfQoSGTSPassedPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.2)
read-only
Counter64
同MIB标准取值
已经通过的数据包数
实现与MIB文件定义一致
hh3cIfQoSGTSPassedBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.3)
read-only
Counter64
同MIB标准取值
已经通过的字节数
实现与MIB文件定义一致
hh3cIfQoSGTSDiscardPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.4)
read-only
Counter64
同MIB标准取值
被丢弃的数据包数
实现与MIB文件定义一致
hh3cIfQoSGTSDiscardBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.5)
read-only
Counter64
同MIB标准取值
被丢弃的字节数
实现与MIB文件定义一致
hh3cIfQoSGTSDelayedPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.6)
read-only
Counter64
同MIB标准取值
被延迟发送的数据包数
实现与MIB文件定义一致
hh3cIfQoSGTSDelayedBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.7)
read-only
Counter64
同MIB标准取值
被延迟发送的字节数
实现与MIB文件定义一致
【功能描述】
该表用来用于创建WRED GROUP。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cIfQoSWredGroupIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSWredGroupIndex (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.1)
not-accessible
Integer32
0~256
WRED Group索引
需要产品确认规格
hh3cIfQoSWredGroupName (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.2)
read-create
OCTET STRING
SIZE (1~32)
WRED Group名称
实现与MIB文件定义一致
hh3cIfQoSWredGroupType (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.3)
read-create
INTEGER
·     userdefined(0)
·     dot1p(1)
·     ippre(2)
·     dscp(3)
·     localpre(4)
·     atmclp(5)
·     frde(6)
·     exp(7)
·     queue(8)
·     dropLevel(9)
WRED Group类型
需要产品确认规格.
hh3cIfQoSWredGroupWeightingConstant (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.4)
read-create
Integer32
1~15
平均队长指数,缺省值为9
不支持queue(8)
hh3cIfQoSWredGroupRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.6)
read-create
RowStatus
同MIB标准取值
行状态
实现与MIB文件定义一致
【功能描述】
该表用来统计完成对WRED GROUP配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cIfQoSWredGroupIndex、hh3cIfQoSWredGroupContentIndex、hh3cIfQoSWredGroupContentSubIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSWredGroupContentIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.1)
not-accessible
Integer32
0~63
hh3cIfQoSWredGroupContentTable的第2个索引,对于不同的类型,有各自的含义
需要产品确认规格
hh3cIfQoSWredGroupContentSubIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.2)
not-accessible
Integer32
0~63
hh3cIfQoSWredGroupContentTable的第3个索引
需要产品确认规格
hh3cIfQoSWredLowLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.3)
read-create
Integer32
同MIB标准取值
低门限
需要产品确认规格
hh3cIfQoSWredHighLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.4)
read-create
Integer32
同MIB标准取值
高门限
需要产品确认规格
hh3cIfQoSWredDiscardProb (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.5)
read-create
Integer32
同MIB标准取值
丢弃可能
需要产品确认规格
hh3cIfQoSWredGroupExponent (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.6)
read-create
Integer32
0~15
WRED Group的类型为QUEUE时每个队列的平均队长指数,缺省值为9
需要产品确认规格
hh3cIfQoSWredRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.7)
read-create
RowStatus
同MIB标准取值
行状态
实现与MIB文件定义一致
【功能描述】
该表用来描述WRED表在端口上的应用情况。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是ifIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSWredGroupApplyIndex (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.1)
read-create
Integer32
0~256
WRED Group索引
实现与MIB文件定义一致
hh3cIfQoSWredGroupApplyName (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.2)
read-only
OCTET STRING
SIZE (1~32)
WRED Group名称
实现与MIB文件定义一致
hh3cIfQoSWredGroupIfRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.3)
read-create
RowStatus
同MIB标准取值
行状态
实现与MIB文件定义一致
【功能描述】
该表用来统计端口的优先级。交换机在接收到报文之后,首先会根据端口的优先级信任模式,使用报文相应优先级查找系统预定义映射表来获取报文的其余QoS相关的参数。如果没有成功为报文分配到本地优先级或端口设置为非信任模式,交换机会采用缺省QoS参数分配机制,该缺省机制与产品芯片类型相关,例如使用报文接收端口的优先级作为报文的本地优先级或者使用报文接收端口的优先级作为802.1p优先级进行映射。路由器当前不支持此节点。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSPortPriorityValue (1.3.6.1.4.1.25506.2.65.1.7.1.1.1.1)
read-write
Integer32
0~7
端口优先级
需要产品确认规格
【功能描述】
该表用来统计端口优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是ifIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSPortPriorityTrustTrustType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.1)
read-write
INTEGER
·     untrust(1)
·     dot1p(2)
·     dscp(3)
·     exp(4)
·     ipPrecedence (5)
·     dot11e(6)
·     auto(7)
端口信任模式
需要产品确认规格
hh3cIfQoSPortPriorityTrustOvercastType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.2)
read-write
INTEGER
·     noOvercast(1)
·     overcastDSCP(2)
·     overcastCOS(3)
·     overcast(4)
覆盖模式
需要产品确认规格
【功能描述】
该表用来设置预定义优先级映射表的各个参数。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cIfQoSPrePriMapTableType、hh3cIfQoSPrePriMapTableColor、hh3cIfQoSPrePriMapTableDirection、hh3cIfQoSPrePriMapTableImportValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSPrePriMapTableType (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.1)
not-accessible
INTEGER
·     dot1pToLp(1)
·     dot1pToDp(2)
·     expToLp(3)
·     dscpToLp(4)
·     expToDp(5)
·     dscpToDp(6)
·     dscpToDot1p(7)
·     dot1pToDscp(8)
·     dscpToDscp(9)
·     dscpToExp(10)
·     expToDscp(11)
·     expToDot1p(12)
·     expToExp(13)
·     lpToDot1p(14)
·     dot1pToRpr(15)
·     dscpToRpr(16)
·     expToRpr(17)
·     ippreToRpr(18)
·     upToDot1p(19)
·     upToDscp(20)
·     upToExp(21)
·     upToDp(22)
·     upToLp(23)
·     upToRpr(24)
·     upToFc(25)
·     lpTodscp(26)
·     dot11eToLp(27)
·     lpToDot11e(28)
·     lpToLp(29)
·     dot1pToExp(30)
·     lpToExp(31)
·     lpToDp(32)
·     upToUp(33)
·     dot1pToDot1p(34)
预定义优先级映射表的类型
需要产品确认规格
hh3cIfQoSPrePriMapTableColor (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.2)
not-accessible
INTEGER
·     nocolor(1)
·     green(2)
·     yellow(3)
·     red(4)
预定义优先级映射表的颜色
需要产品确认规格
hh3cIfQoSPrePriMapTableDirection (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.3)
not-accessible
INTEGER
·     nodirection(1)
·     inbound(2)
·     outbound(3)
预定义优先级映射表的方向
需要产品确认规格
hh3cIfQoSPrePriMapTableImportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.4)
not-accessible
Integer32
0~63
预定义优先级映射表的入方向值
实现与MIB文件定义一致
hh3cIfQoSPrePriMapTableExportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.5)
read-write
Integer32
0~63
预定义优先级映射表的出方向值
实现与MIB文件定义一致
【功能描述】
该表用来统计基于四层TCP端口的优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cQoSRemarkTcpPortStart。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSRemarkTcpPortStart(1.3.6.1.4.1.25506.2.65.1.12.1.1.1)
not-accessible
Integer32
0~65535
TCP端口号范围的起始值
实现与MIB文件定义一致
hh3cQoSRemarkTcpPortEnd (1.3.6.1.4.1.25506.2.65.1.12.1.1.2)
read-create
Integer32
0~65535
TCP端口号范围的结束值
实现与MIB文件定义一致
hh3cQoSRemarkTcpPortType (1.3.6.1.4.1.25506.2.65.1.12.1.1.3)
read-create
INTEGER
·     ipAll(1)
·     ipv4(2)
·     ipv6(3)
匹配报文规则时指定的IP类型
实现与MIB文件定义一致
hh3cQoSRemarkTcpPortDot1p (1.3.6.1.4.1.25506.2.65.1.12.1.1.4)
read-create
Unsigned32
·     0~7
·     255
匹配指定规则报文的dot1p值
实现与MIB文件定义一致
hh3cQoSRemarkTcpPortDscp (1.3.6.1.4.1.25506.2.65.1.12.1.1.5)
read-create
Unsigned32
·     0~63
·     255
匹配指定规则报文的DSCP值
实现与MIB文件定义一致
hh3cQoSRemarkTcpPortRowStatus (1.3.6.1.4.1.25506.2.65.1.12.1.1.6)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
【功能描述】
该表用来统计基于四层UDP端口的优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cQoSRemarkUdpPortStart。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSRemarkUdpPortStart (1.3.6.1.4.1.25506.2.65.1.12.2.1.1)
not-accessible
Integer32
0~65535
UDP端口号范围的起始值
实现与MIB文件定义一致
hh3cQoSRemarkUdpPortEnd (1.3.6.1.4.1.25506.2.65.1.12.2.1.2)
read-create
Integer32
0~65535
UDP端口号范围的结束值
实现与MIB文件定义一致
hh3cQoSRemarkUdpPortType (1.3.6.1.4.1.25506.2.65.1.12.2.1.3)
read-create
INTEGER
·     ipAll(1)
·     ipv4(2)
·     ipv6(3)
匹配报文规则时指定的IP类型
实现与MIB文件定义一致
hh3cQoSRemarkUdpPortDot1p (1.3.6.1.4.1.25506.2.65.1.12.2.1.4)
read-create
Unsigned32
·     0~7
·     255
匹配指定规则报文的dot1p值
实现与MIB文件定义一致
hh3cQoSRemarkUdpPortDscp (1.3.6.1.4.1.25506.2.65.1.12.2.1.5)
read-create
Unsigned32
·     0~63
·     255
匹配指定规则报文的DSCP值
实现与MIB文件定义一致
hh3cQoSRemarkUdpPortRowStatus(1.3.6.1.4.1.25506.2.65.1.12.2.1.6)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
【功能描述】
该表用来统计基于IPv4地址的优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cQoSRemarkIPv4AddrValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSRemarkIPv4AddrValue (1.3.6.1.4.1.25506.2.65.1.12.3.1.1)
not-accessible
IpAddress
同MIB标准取值
IPv4地址
实现与MIB文件定义一致
hh3cQoSRemarkIPv4AddrMask (1.3.6.1.4.1.25506.2.65.1.12.3.1.2)
read-create
IpAddress
同MIB标准取值
IPv4地址的掩码
实现与MIB文件定义一致
hh3cQoSRemarkIPv4AddrMaskLength (1.3.6.1.4.1.25506.2.65.1.12.3.1.3)
read-create
Unsigned32
·     1~32
·     4294967295
IPv4地址的掩码长度
实现与MIB文件定义一致
hh3cQoSRemarkIPv4AddrDot1p (1.3.6.1.4.1.25506.2.65.1.12.3.1.4)
read-create
Unsigned32
·     0~7
·     255
匹配指定规则报文的dot1p值
实现与MIB文件定义一致
hh3cQoSRemarkIPv4AddrDscp (1.3.6.1.4.1.25506.2.65.1.12.3.1.5)
read-create
Unsigned32
·     0~63
·     255
匹配指定规则报文的DSCP值
实现与MIB文件定义一致
hh3cQoSRemarkIPv4AddrRowStatus (1.3.6.1.4.1.25506.2.65.1.12.3.1.6)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
【功能描述】
该表用来统计基于IPv6地址的优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cQoSRemarkIPv6AddrValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSRemarkIPv6AddrValue (1.3.6.1.4.1.25506.2.65.1.12.4.1.1)
not-accessible
InetAddressIPv6
同MIB标准取值
IPv6地址
实现与MIB文件定义一致
hh3cQoSRemarkIPv6AddrPrefixLength (1.3.6.1.4.1.25506.2.65.1.12.4.1.2)
read-create
InetAddressPrefixLength
同MIB标准取值
IPv6地址的前缀长度
实现与MIB文件定义一致
hh3cQoSRemarkIPv6AddrDot1p (1.3.6.1.4.1.25506.2.65.1.12.4.1.3)
read-create
Unsigned32
·     0~7
·     255
匹配指定规则报文的dot1p值
实现与MIB文件定义一致
hh3cQoSRemarkIPv6AddrDscp (1.3.6.1.4.1.25506.2.65.1.12.4.1.4)
read-create
Unsigned32
·     0~63
·     255
匹配指定规则报文的DSCP值
实现与MIB文件定义一致
hh3cQoSRemarkIPv6AddrRowStatus (1.3.6.1.4.1.25506.2.65.1.12.4.1.5)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
【功能描述】
该表用来统计基于三层协议类型的优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cQoSRemarkProtocolValue。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSRemarkProtocolValue (1.3.6.1.4.1.25506.2.65.1.12.5.1.1)
not-accessible
Integer32
·     ip(1)
·     ipx(2)
·     arp(3)
·     appletalk(4)
·     sna(5)
·     netbeui(6)
三层协议类型
实现与MIB文件定义一致
hh3cQoSRemarkProtocolDot1p (1.3.6.1.4.1.25506.2.65.1.12.5.1.2)
read-create
Unsigned32
·     0~7
·     255
匹配指定规则报文的dot1p值
实现与MIB文件定义一致
hh3cQoSRemarkProtocolRowStatus (1.3.6.1.4.1.25506.2.65.1.12.5.1.3)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
【功能描述】
表用来统计基于VLAN的优先级信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cQoSRemarkVlanStart。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cQoSRemarkVlanStart (1.3.6.1.4.1.25506.2.65.1.12.6.1.1)
not-accessible
Ingeter32
1~4094
VLAN范围的起始ID
实现与MIB文件定义一致
hh3cQoSRemarkVlanEnd (1.3.6.1.4.1.25506.2.65.1.12.6.1.2)
read-create
Ingeter32
1~4094
VLAN范围的结束ID
实现与MIB文件定义一致
hh3cQoSRemarkVlanDot1p (1.3.6.1.4.1.25506.2.65.1.12.6.1.3)
read-create
Unsigned32
·     0~7
·     255
匹配指定规则报文的dot1p值
实现与MIB文件定义一致
hh3cQoSRemarkVlanDscp (1.3.6.1.4.1.25506.2.65.1.12.6.1.4)
read-create
Unsigned32
·     0~63
·     255
匹配指定规则报文的DSCP值
实现与MIB文件定义一致
hh3cQoSRemarkVlanRowStatus (1.3.6.1.4.1.25506.2.65.1.12.6.1.5)
read-create
RowStatus
同MIB标准取值
行状态
·     active(1)
·     createAndGo(4)
·     destroy(6)
【功能描述】
该表用来实现获取控制平面协议流量统计功能。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cIfQoSCoppFlowStatChassis、hh3cIfQoSCoppFlowStatSlot、hh3cIfQoSCoppFlowStatProType。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cIfQoSCoppFlowStatChassis (1.3.6.1.4.1.25506.2.65.1.14.1.1.1)
not-accessible
Unsigned32
同MIB标准取值
架号
实现与MIB文件定义一致
hh3cIfQoSCoppFlowStatSlot (1.3.6.1.4.1.25506.2.65.1.14.1.1.2)
not-accessible
Unsigned32
同MIB标准取值
槽号
实现与MIB文件定义一致
hh3cIfQoSCoppFlowStatProType (1.3.6.1.4.1.25506.2.65.1.14.1.1.3)
not-accessible
Unsigned32
1~65
协议类型
实现与MIB文件定义一致
hh3cIfQoSCoppFlowPassPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.4)
read-only
Counter64
同MIB标准取值
通过的包个数
实现与MIB文件定义一致
hh3cIfQoSCoppFlowPassBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.5)
read-only
Counter64
同MIB标准取值
通过的字节个数
实现与MIB文件定义一致
hh3cIfQoSCoppFlowDropPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.6)
read-only
Counter64
同MIB标准取值
丢包个数
实现与MIB文件定义一致
hh3cIfQoSCoppFlowDropBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.7)
read-only
Counter64
同MIB标准取值
丢字节个数
实现与MIB文件定义一致
告警信息
本节介绍HH3C-IFQOS2-MIB模块输出的告警信息。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.13
接口出方向的流量速率超过接口配置的承诺信息速率
故障告警
重要
关闭
【触发原因】
接口出方向的流量速率超过接口配置的承诺信息速率。
【系统影响】
接口出方向的流量可能被丢弃。
【状态控制】
开启
·     命令行:snmp-agent trap enable qos
关闭
·     命令行:undo snmp-agent trap enable qos
【绑定变量】
OID (变量名)
含义
索引节点
类型
取值范围
接口名称
OCTET STRING
SIZE (1~47)
承诺信息速率
Unsigned32
同MIB标准取值
当前接口出方向流量速率
Unsigned32
同MIB标准取值
【处理建议】
请增大接口上配置的承诺信息速率。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.14
接口出方向的流量速率小于接口配置的承诺信息速率
恢复告警
重要
关闭
【触发原因】
接口出方向的流量速率超过接口配置的承诺信息速率告警消除。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口名称
OCTET STRING
SIZE (1~47)
承诺信息速率
Unsigned32
同MIB标准取值
当前接口出方向流量速率
Unsigned32
同MIB标准取值
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.15
接口上存在由于CAR而产生的丢包
故障告警
重要
关闭
【触发原因】
接口上配置了CAR,流量超出CAR的流量监管而产生的丢包时,触发该告警。
【系统影响】
流量可能被丢弃。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
hh3cIfQoSChassis (1.3.6.1.4.1.25506.2.65.1.15.1)
框号
Integer32
0~65534
hh3cIfQoSSlot (1.3.6.1.4.1.25506.2.65.1.15.2)
槽号
Integer32
0~65534
接口名称
OCTET STRING
SIZE (1~47)
hh3cIfQoSDirection (1.3.6.1.4.1.25506.2.65.1.15.6)
方向
Direction
同MIB标准取值
【处理建议】
取消接口上的流量监管配置或者增加CAR的承诺速率。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.16
接口上由于CAR而产生的丢包已经恢复
恢复告警
重要
关闭
【触发原因】
接口上由于CAR而产生的丢包已经恢复。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
接口名称
OCTET STRING
SIZE (1~47)
方向
Direction
同MIB标准取值
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.17
接口上由于控制平面CAR而产生协议丢包
故障告警
重要
关闭
【触发原因】
基于控制平面配置流量监管,上送控制平面的报文速率过大而产生协议丢包。
【系统影响】
上送控制平面的报文被丢弃,业务或者设备内部控制信息可能无法正常处理。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
协议类型
OCTET STRING
SIZE (1~31)
带宽
Unsigned32
同MIB标准取值
1.3.6.1.4.1.25506.2.65.1.15.13 (hh3cIfQoSBandwidthUnit)
带宽单位
INTEGER
·     unitAbsolute (1)
【处理建议】
取消基于控制平面的流量监管配置。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.18
接口上由于控制平面CAR而产生的协议丢包已经恢复
恢复告警
重要
关闭
【触发原因】
接口上由于控制平面CAR而产生的协议丢包已经恢复。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
协议类型
OCTET STRING
SIZE (1~31)
带宽
Unsigned32
同MIB标准取值
带宽单位
INTEGER
·     unitAbsolute (1)
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.19
队列异常导致没有报文转发
故障告警
重要
关闭
【触发原因】
队列异常导致没有报文转发。
【系统影响】
报文无法转发。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
协议类型
OCTET STRING
SIZE (1~31)
【处理建议】
请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.20
队列异常导致没有报文转发已经恢复
恢复告警
重要
关闭
【触发原因】
队列异常导致没有报文转发已经恢复。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
协议类型
OCTET STRING
SIZE (1~31)
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.21
L3ACL资源不足
故障告警
重要
关闭
【触发原因】
硬件设备的L3 ACL资源不足时,触发告警。
【系统影响】
硬件ACL规则无法正常下发或者无法正常匹配。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
服务名称
OCTET STRING
SIZE (1~63)
失败原因
OCTET STRING
SIZE (1~127)
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.22
ACL资源不足告警
故障告警
重要
关闭
【触发原因】
ACL资源不足时,触发告警。
【系统影响】
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
服务名称
OCTET STRING
SIZE (1~63)
应用对象
OCTET STRING
SIZE (1~127)
方向
Direction
同MIB标准取值
失败原因
OCTET STRING
SIZE (1~127)
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.23
ACL资源不足告警恢复
恢复告警
重要
关闭
【触发原因】
ACL资源不足告警恢复。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
服务名称
OCTET STRING
SIZE (1~63)
应用对象
OCTET STRING
SIZE (1~127)
方向
Direction
同MIB标准取值
失败原因
OCTET STRING
SIZE (1~127)
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.24
ACL转发引擎内存用尽告警
故障告警
重要
关闭
【触发原因】
ACL转发引擎内存用尽告警。
【系统影响】
ACL规则无法正常匹配。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.25
ACL转发引擎内存恢复
恢复告警
重要
关闭
【触发原因】
ACL转发引擎内存告警恢复。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框号
Integer32
0~65534
槽号
Integer32
0~65534
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.26
QoS缓存队列告警
故障告警
重要
关闭
【触发原因】
QoS缓存队列告警。
【系统影响】
QoS转发相关业务功能不正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.65.1.15.2 (hh3cIfQoSSlot)
槽号
Integer32
0~65534
1.3.6.1.4.1.25506.2.65.1.15.4 (hh3cIfQoSChip)
芯片号
Integer32
0~65534
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.27
QoS缓存队列告警恢复
恢复告警
重要
关闭
【触发原因】
QoS缓存队列告警恢复。
【系统影响】
QoS转发相关业务功能恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
芯片号
Integer32
0~65534
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.28
接口队列缓存门限告警
故障告警
重要
关闭
【触发原因】
接口队列缓存门限告警。
【系统影响】
出接口流量丢包。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.65.1.15.14 (hh3cIfQoSQueBufferQueID)
队列ID
Integer32
0~65535
1.3.6.1.4.1.25506.2.65.1.15.5 (hh3cIfQoSIfName)
接口名称
OCTET STRING
SIZE (1~47)
1.3.6.1.4.1.25506.2.65.1.15.19 (hh3cIfQoSSlot)
产生拥塞流量的上行单板
Integer32
0~65534
1.3.6.1.4.1.25506.2.65.1.15.15 (hh3cIfQoSQueBufferUsedCell)
拥塞时的缓存使用值
Unsigned32
同MIB标准取值
1.3.6.1.4.1.25506.2.65.1.15.16 (hh3cIfQoSQueBufferUsedLength)
拥塞时的队列长度
Unsigned32
同MIB标准取值
1.3.6.1.4.1.25506.2.65.1.15.17 (hh3cIfQoSQueBufferDiscard)
丢弃计数
Counter64
同MIB标准取值
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.29
接口队列缓存门限告警恢复
恢复告警
重要
关闭
【触发原因】
接口队列缓存门限告警恢复。
【系统影响】
出接口流量丢包恢复。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.65.1.15.2 (hh3cIfQoSQueBufferQueID)
队列ID
Integer32
0~65535
接口名称
OCTET STRING
SIZE (1~47)
产生拥塞流量的上行单板
Integer32
0~65534
拥塞时的缓存使用值
Unsigned32
同MIB标准取值
拥塞时的队列长度
Unsigned32
同MIB标准取值
丢弃计数
Counter64
同MIB标准取值
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.30
优先级映射告警
故障告警
重要
关闭
【触发原因】
优先级映射告警。
【系统影响】
去使能接口出方向报文的PHB到802.1p的映射功能后,可能会导致FCoE转发报文的优先级错误,从而可能会导致FCoE转发报文丢包。
【状态控制】
开启
关闭
【绑定变量】
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.31
优先级映射告警恢复
恢复告警
重要
关闭
【触发原因】
优先级映射告警恢复。
【系统影响】
去使能接口出方向报文的PHB到802.1p的映射功能后,可能会导致FCoE转发报文的优先级错误,从而可能会导致FCoE转发报文丢包恢复。
【状态控制】
开启
关闭
【绑定变量】
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.32
环回口丢包告警
故障告警
重要
关闭
【触发原因】
环回口丢包告警。
【系统影响】
环回口业务出现丢包。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.65.1.15.18 (hh3cIfQoSPortID)
端口号
Integer32
0~65535
槽号
Integer32
0~65534
芯片号
Integer32
0~65534
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.33
环回口丢包告警恢复
恢复告警
重要
关闭
【触发原因】
环回口丢包告警恢复。
【系统影响】
环回口业务丢包恢复。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
端口号
Integer32
0~65535
槽号
Integer32
0~65534
芯片号
Integer32
0~65534
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.34
QoS风暴抑制告警
故障告警
重要
关闭
【触发原因】
QoS风暴抑制告警。
【系统影响】
QoS风暴抑制功能异常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.35
QoS风暴抑制告警恢复
恢复告警
重要
关闭
【触发原因】
QoS风暴抑制告警恢复。
【系统影响】
QoS风暴抑制功能恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.36
单播报文丢包
故障告警
重要
关闭
【触发原因】
单播报文丢包。
【系统影响】
报文单播功能异常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.37
单播报文丢包恢复
恢复告警
重要
关闭
【触发原因】
单播报文丢包恢复。
【系统影响】
报文单播功能恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.38
入方向报文调度失败
故障告警
重要
关闭
【触发原因】
入方向报文调度失败。
【系统影响】
入方向报文调度功能异常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.65.1.16.0.39
入方向报文调度失败恢复
恢复告警
重要
关闭
【触发原因】
入方向报文调度异常恢复。
【系统影响】
对系统无影响。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
槽号
Integer32
0~65534
【处理建议】
无需处理。
