01-基础配置命令参考
07-设备管理命令
本章节下载: 07-设备管理命令  (816.30 KB)
07-设备管理命令
1 设备管理
1.1 设备管理配置命令
1.1.1 card-mode
1.1.2 clock datetime
1.1.3 clock protocol
1.1.4 clock summer-time
1.1.5 clock timezone
1.1.6 command
1.1.7 copyright-info enable
1.1.8 display alarm
1.1.9 display clock
1.1.10 display copyright
1.1.11 display cpu-usage
1.1.12 display cpu-usage configuration
1.1.13 display cpu-usage history
1.1.14 display cpu-usage overload
1.1.15 display cpu-usage overload summary
1.1.16 display device
1.1.17 display device manuinfo
1.1.18 display device manuinfo chassis-only
1.1.19 display device manuinfo fan
1.1.20 display device manuinfo power
1.1.21 display diagnostic-information
1.1.22 display environment
1.1.23 display fan
1.1.24 display fan-speed
1.1.25 display hardware-failure-detection
1.1.26 display hardware-failure-protection
1.1.27 display health
1.1.28 display memory
1.1.29 display memory-threshold
1.1.30 display non-stop-routing status
1.1.31 display power
1.1.32 display power-off high-temp-board
1.1.33 display power-information
1.1.34 display resource-monitor
1.1.35 display scheduler job
1.1.36 display scheduler logfile
1.1.37 display scheduler reboot
1.1.38 display scheduler schedule
1.1.39 display service-mode status
1.1.40 display slot-mode
1.1.41 display system stable state
1.1.42 display transceiver alarm
1.1.43 display transceiver diagnosis
1.1.44 display transceiver interface
1.1.45 display transceiver manuinfo
1.1.46 display version
1.1.47 display version-update-record
1.1.48 fabric load-sharing algorithm
1.1.49 fabric load-sharing mode
1.1.50 fan-speed
1.1.51 forwarding bandwidth
1.1.52 forward-path-detection enable
1.1.53 hardware-failure-detection
1.1.54 hardware-failure-protection aggregation
1.1.55 hardware-failure-protection auto-down
1.1.56 header
1.1.57 job
1.1.58 memory-threshold
1.1.59 memory-threshold usage
1.1.60 memory-threshold  usage resend-interval
1.1.61 monitor cpu-usage enable
1.1.62 monitor cpu-usage interval
1.1.63 monitor cpu-usage threshold
1.1.64 monitor resend cpu-usage
1.1.65 monitor resend cpu-usage core-interval
1.1.66 monitor resend memory-threshold
1.1.67 password-recovery enable
1.1.68 power control-mode
1.1.69 power-off high-temp-board clear
1.1.70 power-off high-temp-board enable
1.1.71 reboot
1.1.72 reset scheduler logfile
1.1.73 reset version-update-record
1.1.74 resource-monitor minor resend enable
1.1.75 resource-monitor output
1.1.76 resource-monitor resource
1.1.77 restore factory-default
1.1.78 scheduler job
1.1.79 scheduler logfile size
1.1.80 scheduler reboot at
1.1.81 scheduler reboot delay
1.1.82 scheduler schedule
1.1.83 service-mode
1.1.84 shutdown-interval
1.1.85 slot-mode
1.1.86 switch-fabric isolate
1.1.87 switch-fabric removal-signal-report enable
1.1.88 sysname
1.1.89 temperature-limit
1.1.90 time at
1.1.91 time once
1.1.92 time repeating
1.1.93 user-role
1 设备管理
本文中的“SPC类单板”仅代表单板丝印以“SPC”开头的单板。
1.1  设备管理配置命令
1.1.1  card-mode
·     仅MIC-SP4L、RX-NIC-LGQ2L和RX-NIC-CQ1LF接口子卡支持配置本命令。
·     仅RX-NIC-LGQ2L和RX-NIC-CQ1LF接口子卡支持ethernet和flexe模式。
card-mode命令用来配置接口子卡的工作模式。
(独立运行模式)
card-mode slot slot-number subslot subslot-number mode-name
card-mode chassis chassis-number slot slot-number subslot subslot-number mode-name
MIC-SP4L接口子卡的工作模式为oc-3-pos,RX-NIC-LGQ2L和RX-NIC-CQ1LF接口子卡的工作模式为ethernet。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
subslot subslot-number:子卡所在的子槽位号。
mode-name:指定接口子卡的工作模式。工作模式如下所示:
·     oc-12-atm:配置接口子卡的工作模式为oc-12-atm模式。配置后,该接口子卡上的所有接口都可作为基于SONET/SDH承载的ATM OC-12c/STM-4接口来工作。关于ATM接口的详细介绍请参见“接口管理配置指导”中“ATM接口”。
·     oc-12-pos:配置接口子卡的工作模式为oc-12-pos模式。该接口子卡上的所有接口都可作为622M POS接口来工作。关于POS接口的详细介绍请参见“接口管理配置指导”中“POS接口”。
·     oc-3-atm:配置接口子卡的工作模式为oc-3-atm模式。配置后,该接口子卡上的所有接口都可作为基于SONET/SDH承载的ATM OC-3c/STM-1接口来工作。关于ATM接口的详细介绍请参见“接口管理配置指导”中“ATM接口”。
·     oc-3-pos:配置接口子卡的工作模式为oc-3-pos模式。该接口子卡上的所有接口都可作为155M POS接口来工作。关于POS接口的详细介绍请参见“接口管理配置指导”中“POS接口”。
·     ethernet:配置接口卡的工作模式为标准以太模式。配置后,该接口卡上的所有接口可作为以太网接口使用。关于以太网接口的详细介绍请参见“接口管理配置指导”中“以太网接口”。
·     flexe:配置接口卡的工作模式为灵活以太模式。配置后,该接口卡上的所有接口可作为FlexE物理接口使用。关于FlexE物理接口的详细介绍请参见“接口管理配置指导”中“FlexE接口”。
模式切换后接口子卡会自动重启,重启后新配置的模式才会生效。
仅位于MPE-1104、CSPEX-1104-E、CSPEX-1304X/CSPEX-1304S、CSPEX-1404X/CSPEX-1404S和CSPEX-1504X/CSPEX-1504S单板上的MIC-SP4L子卡支持oc-3-atm和oc-12-atm模式。
接口子卡的工作模式切换为oc-12-atm和oc-12-pos模式后,该子卡上仅第一个接口可用,后三个接口不可用。
若当前接口子卡损坏,更换相同型号的接口子卡后,新子卡上以当前设备配置的工作模式生效。
# 将位于指定接口子卡的工作模式配置为oc-12-atm模式。(独立运行模式)
[Sysname] card-mode slot 2 subslot 1 oc-12-atm
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为出厂时间。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
修改夏令时或时区后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
# 配置设备的系统时间为2012年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2012
# 配置设备的系统时间为2012年1月1日8时10分。
<Sysname> clock datetime 8:10 2012/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ptp:表示通过PTP(Precision Time Protocol,精确时间协议)协议获取时间。关于PTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“PTP”。对于SR8800-X-S设备,暂不支持本参数。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号。
系统时间的获取方式有:
·     配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
·     配置clock protocol { ntp | ptp }命令后,通过NTP/PTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用格林威治标准时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.6  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可,比如:command 1 display interface;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。比如:要使用Job定时执行shutdown命令,则需执行三次command命令,分别分配system-view、interface、shutdown命令,且各command命令的id值逐渐增大。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口GigabitEthernet3/1/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 3/1/1
[Sysname-job-shutdownGE] command 3 shutdown
·     scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Without the owner's prior written consent,                                 *
1.1.8  display alarm
display alarm命令用来显示设备的告警信息。
(独立运行模式)
display alarm [ slot slot-number ]
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
表1-1 display alarm命令显示信息描述表
Slot
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上
CPU
告警CPU的编号
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息。取值为:
·     faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态)
·     Fan n is absent:风扇n当前不在位
·     Power n is absent:电源n当前不在位
·     The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限
·     The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限
1.1.9  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2012
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2012
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2012
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
# 显示设备的版权信息。
<Sysname> display copyright
……显示信息略……
display cpu-usage命令用来显示CPU利用率的统计信息。
(独立运行模式)
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
data-plane:显示数据平面CPU利用率的统计信息。不指定data-plane参数时,显示控制平面CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
表1-2 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
Last 5 sec
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
Last 1 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Last 5 min
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
(独立运行模式)
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
Current recovery threshold is 69%.
表1-3 display cpu-usage configuration命令显示信息描述表
CPU利用率监控功能处于开启状态
CPU利用率监控功能的采样周期为60秒
CPU利用率的严重级阈值为99%
CPU利用率提示级阈值为79%
CPU利用率恢复门限为69%
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
(独立运行模式)
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息,job-id表示进程的编号。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。(独立运行模式)
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display cpu-usage overload命令用来显示CPU过载记录的具体信息。
(独立运行模式)
display cpu-usage overload show-number [ stack-info ] slot slot-number [ cpu cpu-number ]
(IRF设备)
display cpu-usage overload show-number [ stack-info ] chassis chassis-number slot slot-number [ cpu cpu-number ]
show-number:显示指定数目的CPU过载记录的具体信息,取值范围为1~10。
stack-info:显示CPU过载时,占用CPU最多的前三条进程的堆栈信息。不指定该参数时,不会显示堆栈信息。
slot slot-number:显示指定单板的CPU过载信息。表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的CPU过载信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
CPU过载记录的具体信息包括CPU过载记录的汇总信息、CPU过载时占用CPU较多的进程的信息以及占用CPU最多的前三条进程的堆栈信息。
# 显示指定单板最近1次CPU过载记录的具体信息,不包括占用CPU最多的前三条进程的堆栈信息。(独立运行模式)
<Sysname> display cpu-usage overload 2 slot 2
CPU overload summary information:
Slot/CPU          Time                     Overload status    Processes
2/0               0000-00-00 00:00:00:000  No overloaded      NA
No CPU overload history.
# 显示指定单板最近1次CPU过载记录的具体信息,不包括占用CPU最多的前三条进程的堆栈信息。(IRF模式)
<Sysname> display cpu-usage overload 1 chassis 1 slot 2 cpu 0
Chassis/Slot/CPU  Time                     Overload status    Processes
1/2/0             2018-11-12 12:00:00:000  Recovered          300
                  2018-11-12 11:00:00:000  Minor alarm        400
                  2018-11-12 10:00:00:000  Severe alarm       500
                  2018-11-12 09:00:00:000  Minor alarm        400
CPU overload history on overload time 2018-11-12 11:00:00:000.
CPU utilization in recent 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%.
Top processes in recent 5 secs:
    JID    PID   PPID  CPU  State   Mem   5sec   1min   5min  Name
 811795 811795 811792    0    S  21584K   0.6%   0.0%   0.0%  login
 811801 811801 811799    0    S  21524K   0.6%   0.0%   0.0%  login
 811796 811796 811794    0    S  21524K   0.5%   0.0%   0.0%  login
    257    257      2    0    S      0K   0.0%   0.0%   0.0%  [CLKM]
    206    206      2    0    S      0K   0.0%   0.0%   0.0%  [DIPC]
    679    679    342    0    S 137324K   0.1%   0.0%   0.0%  comsh
    211    211      2    0    D      0K   0.0%   0.0%   0.0%  [DTIM]
   1778   1778    342    0    S  95352K   0.0%   0.0%   0.0%  comsh
    261    261      2    0    D      0K   0.0%   0.0%   0.0%  [TEMP]
# 显示指定单板最近2次CPU过载记录的具体信息,包括占用CPU最多的前三条进程的堆栈信息。(IRF模式)
<Sysname> display cpu-usage overload 2 stack-info chassis 1 slot 2 cpu 0
CPU overload information:
1/2/0             2018-11-12 11:00:00:000  Minor alarm        400
CPU utilization in 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%.
      1      1      0    0    S  21584K   0.6%   0.0%   0.0%  scmd
    152    152      1    0    S  21524K   0.6%   0.0%   0.0%  ifmgr
    153    153      1    0    S  21524K   0.5%   0.0%   0.0%  edev
    805    805    804    0    S  21440K   0.4%   0.0%   0.0%  login
Stack information of process 1 (scmd):
Thread LWP 1:
Switches: 2205
User stack:
#0  0x00007f957d47b320 in epoll_wait+0x14/0x2e
#1  0x0000000000422c1c in ScmMainThread+0x51/0x125
#2  0x0000000000422650 in main+0xd0/0xd7
#3  0x00007f957d4a7ad0 in __uClibc_main+0x242/0x26c
#4  0x0000000000407519 in _start+0x29/0x2a
Kernel stack:
[<ffffffff811eeca3>] ep_poll+0x2f3/0x370
[<ffffffff811eedf0>] SyS_epoll_wait+0xd0/0xe0
[<ffffffff814deb39>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
Stack information of process 152 (ifmgr):
Thread LWP 152:
Switches: 177
User stack:
#0  0x00007f4418429154 in pthread_cond_wait+0xc4/0x203
#1  0x00007f4416b138d0 in logicFlowRoutine+0x1b/0x49
#2  0x0000000000403e33 in main+0x12c/0x133
#3  0x00007f4415deaad0 in __uClibc_main+0x242/0x26c
#4  0x00000000004038f9 in _start+0x29/0x2a
Kernel stack:
[<ffffffff81107287>] futex_wait_queue_me+0xd7/0x140
[<ffffffff811074f0>] futex_wait+0x190/0x280
[<ffffffff81109725>] do_futex+0xe5/0xcf0
[<ffffffff8110a477>] SyS_futex+0x147/0x180
Thread LWP 154:
Switches: 3222
User stack:
#0  0x00007f4415dbe320 in epoll_wait+0x14/0x2e
#1  0x00007f4416b106ef in lipcRoutine+0x6f/0xa5
#2  0x00007f44184219e0 in ??
#3  0x00007f4418427fe5 in __clone+0x79/0x83
Kernel stack:
Thread LWP 156:
Switches: 3151
User stack:
#1  0x00007f4416b15cf8 in miscJobsRoutine+0x18/0x80
Kernel stack:
Stack information of process 153 (edev):
Thread LWP 153:
Switches: 163
User stack:
#0  0x00007f7d3c276320 in epoll_wait+0x14/0x2e
#1  0x0000000000413748 in main+0x9f/0x10f
#2  0x00007f7d3c2a2ad0 in __uClibc_main+0x242/0x26c
#3  0x00000000004082f9 in _start+0x29/0x2a
Kernel stack:
Thread LWP 155:
Switches: 1
User stack:
#0  0x00007f7d3c2a22fd in __read+0x2d/0x5e
#1  0x0000000000414be6 in EdevDisioctlThread+0x2d/0x72
#2  0x00007f7d3dacc9e0 in ??
#3  0x00007f7d3dad2fe5 in __clone+0x79/0x83
Kernel stack:
[<ffffffff811f15dd>] eventfd_ctx_read+0x15d/0x210
[<ffffffff811f16dd>] eventfd_read+0x4d/0x80
[<ffffffff811ab621>] vfs_read+0xa1/0x160
[<ffffffff811ab7c4>] SyS_read+0x54/0xc0
CPU Overload history on overload time 2018-11-12 10:00:00:000.
Thread (LWP 1):
Switches: 2205
User stack:
Kernel stack:
Thread (LWP 152):
Switches: 177
User stack:
Kernel stack:
Thread (LWP 154):
Switches: 3222
User stack:
Kernel stack:
Thread (LWP 156):
Switches: 3151
User stack:
Kernel stack:
Thread (LWP 153):
Switches: 163
User stack:
Kernel stack:
Thread (LWP 155):
Switches: 1
User stack:
Kernel stack:
表1-4 display cpu-usage overload命令显示信息描述表
CPU的简要过载信息
Time
过载时间,未过载时显示0000-00-00 00:00:00:000
Overload status
过载状态,取值为:
·     No overloaded:未过载状态,初始状态
·     Minor alarm:低级别过载状态,超过低级别告警门限。
·     Severe alarm:高级别过载状态,超过高级别告警门限
·     Recovered:过载恢复状态,降到恢复门限以下。
Processes
过载时的进程数目,没有过载时显示NA
CPU overload history on overload time 2018-11-12 10:00:00:000:
CPU的详细过载信息,如果没有显示No  CPU overload history.
Overload time
过载时间,没有过载时显示0000-00-00 00:00:00:000
系统最近5秒CPU使用率;最近1分钟CPU使用率;最近5分钟CPU使用率
按5 sec利用率由高到低排序
JID
任务编号(用于唯一标识一个进程,该编号不会随着进程的重启而改变)
PID
进程编号
PPID
父进程编号
CPU
进程最近一次被调度时,所在的CPU
进程状态,可能的取值为:
·     R:running,运行状态或处于运行队列
·     S:sleeping,可中断睡眠状态
·     T:traced or stopped,暂停状态
·     D:uninterruptible sleep,不可中断睡眠状态
·     Z:zombie,僵死状态
Mem
进程所使用的内存大小(内核线程该项显示为0)
5sec
最近5秒钟内进程的CPU使用率
1min
最近1分钟内进程的CPU使用率
5min
最近5分钟内进程的CPU使用率
Name
进程名称(如果进程名称带有“[ ]”标记,则表示该进程为内核线程)
进程的堆栈信息,进程的PID为1,进程名称为scmd
Thread LWP 1:
被跟踪进程的子进程
Switches
调度计数
User stack
用户态堆栈信息,仅用户态进程显示该信息
Kernel stack
内核态堆栈信息,仅内核态进程显示该信息
·     display cpu-usage overload summary
display cpu-usage overload summary用来显示所有CPU过载记录的汇总信息。
# 显示所有CPU过载记录的汇总信息。(独立运行模式)
<Sysname> display cpu-usage overload summary
1/0               2018-11-12 12:00:00:000  Recovered          300
#显示所有CPU过载记录的汇总信息。(IRF模式)
1/1/0             0000-00-00 00:00:00:000  No overloaded      NA
1/3/0             0000-00-00 00:00:00:000  No overloaded      NA
本命令显示信息描述请参见表1-4。
display device命令用来显示设备信息。
(独立运行模式)
display device [ cf-card | sd-card ] [ slot slot-number [ subslot subslot-number ] | verbose ]
display device [ cf-card | sd-card ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
cf-card:显示CF卡的信息。
sd-card:显示SD卡的信息。仅SR05SRP1P3单板支持本参数。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
不指定cf-card和sd-card参数时,显示单板的信息。
# 显示设备信息。
<Sysname> display device
……显示信息略……
表1-5 display device命令显示信息描述表
Slot No.
单板的槽位号
Brd Type
单板的硬件类型
Brd Status
单板状态:
·     Standby表示该板是备用主控板
·     Master表示该板是主用主控板
·     Absent表示该槽位没有插入单板
·     Fault表示该槽位单板出错,不能正常启动
·     Normal表示该槽位单板是接口板并处于正常工作状态
·     Power-off:表示该槽位的单板没有上电
·     Offline:表示该槽位单板处于被隔离状态
Software version
软件版本信息
display device manuinfo命令用来显示设备的电子标签信息。
(独立运行模式)
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
display device manuinfo [ chassis chassis-number [ slot slot-number  [ subslot subslot-number ] ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
电子标签信息也可以称为永久配置数据或档案信息等,在单板的调测(调试、测试)过程中被写入到设备的存储器件中,包括单板的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo
……显示信息略……
表1-6 display device manuinfo命令信息显示描述表
DEVICE_NAME
设备名称
DEVICE_SERIAL_NUMBER
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
(独立运行模式)
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
# 显示机框背板的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo chassis-only
……显示信息略……
表1-7 display device manuinfo chassis-only命令信息显示描述表
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display device manuinfo fan命令用来显示风扇的电子标签信息。
(独立运行模式)
display device manuinfo fan fan-id
display device manuinfo chassis chassis-number fan fan-id
fan-id:表示设备上风扇的ID编号。
SR8800-X-S设备不支持此命令。
# 显示指定风扇的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo fan 0
……显示信息略……
表1-8 display device manuinfo fan命令信息显示描述表
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display device manuinfo power命令用来显示电源的电子标签信息。
(独立运行模式)
display device manuinfo power power-id
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号。
对于SR8800-X-S设备,只有PSR2500-12D和PSR2500-12AHD两款电源支持此命令。
# 显示指定电源的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 1
……显示信息略……
表1-9 display device manuinfo power命令信息显示描述表
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1)     使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2)     使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3)     使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以导出到PC上使用Linux系统下的gunzip -c命令解压查看。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
不指定filename参数执行display diagnostic-information命令,当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
该命令不支持“|”、“>”和“>>”参数。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2012
其他显示信息略……。
# 将收集到的诊断信息保存到缺省文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     gunzip(基础配置命令参考/文件系统管理)
·     more(基础配置命令参考/文件系统管理)
·     tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
(独立运行模式)
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
·     SR8800-X
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 0     inflow  1 25           0      48       60     NA
 0     hotspot 1 31           0      80       95     NA
 2     inflow  1 29           0      80       97     NA
 2     outflow 1 26           0      80       97     NA
 2     hotspot 1 31           0      80       97     NA
 2     hotspot 2 42           0      80       97     NA
 3     inflow  1 31           0      80       97     NA
 3     outflow 1 32           0      80       97     NA
 3     hotspot 1 47           0      80       97     NA
 3     hotspot 2 38           0      80       97     NA
 4     hotspot 1 30           0      75       90     NA
 6     hotspot 1 41           0      88       100    110
·     SR8800-X-S
 0     inflow  1 29           0      80       97     NA
 0     hotspot 1 37           0      80       97     NA
 0     hotspot 2 26           0      80       97     NA
 0     hotspot 3 32           0      80       97     NA
 1     inflow  1 28           0      80       97     NA
 1     hotspot 1 37           0      80       97     NA
 1     hotspot 2 26           0      80       97     NA
 1     hotspot 3 30           0      80       97     NA
 2     hotspot 1 30           0      75       90     NA
 7     inflow  1 38           0      80       97     NA
 7     outflow 1 37           0      80       97     NA
 7     hotspot 1 59           0      80       97     NA
 7     hotspot 2 47           0      80       97     NA
表1-10 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息,单位为摄氏度
sensor
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Slot
当显示数字时表示指定slot上温度传感器的温度信息;当显示Vent时表示位于机框、风扇框上的温度传感器的温度信息
Temperature
当前温度
LowerLimit
低温告警门限
WarningLimit
一般级(Warning)高温告警门限
AlarmLimit
严重级(Alarm)高温告警门限
ShutdownLimit
关断级(Shutdown)高温告警门限
当温度传感器的温度大于该门限时,单板会自动下电
1.1.23  display fan
display fan命令用来显示风扇的工作状态。
(独立运行模式)
display fan [ fan-id ]
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。(IRF模式)
fan-id:表示设备内置风扇的编号。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan Frame 0  State: Normal
表1-11 display fan命令显示信息描述表
Fan Frame
风扇框的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Fault:风扇故障
display fan-speed命令用来显示风扇的当前工作模式与转速。
(独立运行模式)
display fan-speed
display fan-speed [ chassis chassis-number ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示显示所有风扇的当前工作模式与转速。(IRF模式)
对于SR8800-X-S设备,只能显示风扇的当前工作模式,暂不支持显示风扇转速。
# 显示设备上所有风扇的当前工作模式与转速。(独立运行模式)
·     SR8800-X
[Sysname] display fan-speed
Current fan speed mode is auto
Frame 0 fan 1 speed is 2414 (R.P.M)
Frame 0 fan 2 speed is 2406 (R.P.M)
Frame 0 fan 3 speed is 3364 (R.P.M)
Frame 0 fan 4 speed is 3342 (R.P.M)
Frame 0 fan 5 speed is 3357 (R.P.M)
Frame 0 fan 6 speed is 3324 (R.P.M)
Frame 0 fan 7 speed is 3361 (R.P.M)
Frame 0 fan 8 speed is 3288 (R.P.M)
·     SR8800-X-S
The device doesn't support displaying fan speeds.
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(独立运行模式)
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(IRF模式)
# 查看设备的硬件故障检测和故障修复信息。(独立运行模式)
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    forwarding : warning
Recent record:
--------------------------Slot  0 executed records:-----------------------------
--------------------------Slot  0 trapped records:-----------------------------
表1-12 display hardware-failure-detection命令显示信息描述表
Current level
当前故障检测对应的修复操作
chip       :
器件类故障对应的修复操作
forwarding :
转发类故障对应的修复操作
Recent record:
最近记录
Slot  n executed records:
主控板n上记录的各个单板的历史操作记录(独立运行模式)
Chassis n, Slot m executed records:
成员设备n主控板m上记录的各个单板的历史操作记录(IRF模式)
Slot  n trapped records:
主控板n上记录的各个单板的trap告警信息(独立运行模式)
Chassis n, Slot m trapped records:
成员设备n主控板m上记录的各个单板的trap告警信息(IRF模式)
display hardware-failure-protection命令用来显示设备上硬件故障保护的配置信息。
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation:显示聚合组的硬件故障保护配置信息。
port:显示端口硬件故障保护的配置信息。
auto-down:显示已配置端口硬件故障保护的端口列表。
interface-type interface-number:显示指定端口上硬件故障保护的配置信息。
如果不带参数,则显示设备上所有硬件故障保护的配置信息,包括是否配置了针对聚合组的硬件故障保护和所有配置了端口硬件故障保护的端口列表。
# 显示设备上所有硬件故障保护的配置信息。
<Sysname> display hardware-failure-protection
Aggregation: on
Port: GE3/1/1     GE3/1/2
# 显示配置了端口硬件故障保护的端口列表。
<Sysname> display hardware-failure-protection port auto-down
# 显示端口GE3/1/2是否配置了硬件故障保护。
<Sysname> display hardware-failure-protection port gigabitethernet 3/1/2
Hardware failure protection is enabled on the interface. The system will shut down the interface when it detects a hardware failure on the interface.
表1-13 display hardware-failure-protection命令显示信息描述表
Aggregation
显示是否配置了针对聚合组的硬件故障保护功能。取值为:
·     on:表示针对聚合组的硬件故障保护功能处于开启状态
·     off:表示针对聚合组的硬件故障保护功能处于关闭状态
Port:
显示配置了端口硬件故障保护的端口列表
硬件故障保护功能处于开启状态,当系统检测到接口硬件故障时,会自动关闭该接口
Hardware failure protection is disabled on the interface.
接口的硬件故障保护功能处于关闭状态
display health命令用来显示CPU和内存的使用情况。
(独立运行模式)
display health [ slot slot-number [ cpu cpu-number ] ]
display health [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] ] ]
slot slot-number [ cpu cpu-number ]:显示指定单板上CPU和内存的使用情况。slot-number表示单板所在的槽位号,不指定slot参数时,显示所有单板上CPU和内存的使用情况。cpu-number表示CPU的槽位号,指定slot不指定cpu参数时,显示指定单板上CPU和内存的使用情况。(独立运行模式)
chassis chassis-number [ slot slot-number [ cpu cpu-number ] ]:显示指定单板上CPU和内存的使用情况。chassis-number表示设备在IRF中的成员编号,不指定该参数时,显示所有成员设备上CPU和内存的使用情况。slot-number表示单板所在的槽位号,指定chassis不指定slot参数时,显示指定成员设备上CPU和内存的使用情况。cpu-number表示CPU的槽位号,指定chassis和slot、不指定cpu参数时,显示指定单板上CPU和内存的使用情况。(IRF模式)
# 显示所有slot上CPU和内存的使用情况。(独立运行模式)
<Sysname> display health
Slot CPU Role         CPU Usage(%) Memory Usage(%) Used/Total(MB)
1    0   MPU(Master)  7            23              1902504/8130012
2    0   LPU          9            48              963064/1991292
3    0   LPU          7            47              1913916/4052524
5    0   LPU          4            18              1538196/8158684
6    0   SFU          3            36              361296/984332
7    0   SFU          6            36              361348/984332
表1-14 display health命令显示信息描述表
Role
成员设备在IRF中的角色,取值为:
·     MPU(Master)表示主用主控板(独立运行模式)
·     MPU(Standby)表示备用主控板(独立运行模式)
·     MPU(Master)表示全局主用主控板(IRF模式)
·     MPU(Standby)表示全局备用主控板(IRF模式)
·     LPU表示接口板
·     BLADE表示Blade单板
CPU Usage(%)
CPU利用率信息,表示系统在过去5秒内CPU利用率的平均值
Memory Usage(%)
单板上当前的内存利用率
Used/Total(MB)
单板上当前已使用的内存大小/单板上内存总大小,单位为MB
display memory命令用来显示内存使用情况。
(独立运行模式)
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。(IRF模式)
cpu cpu-number:表示CPU编号。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。(独立运行模式)
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        984504    576428    408076         0        12    131056       41.5%
-/+ Buffers/Cache:    445360    539144
Swap:            0         0         0
LowMem:     739768    352152    387616        --        --        --       52.4%
HighMem:    244736    224276     20460        --        --        --        8.4%
# 显示设备的内存使用情况的简要信息。(独立运行模式)
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0       984504    576428    408076       12    131056     41.4%
Low memory statistics are measured in KB:
   1   0       739768    352152    387616       --        --     52.4%
High memory statistics are measured in KB:
   1   0       244736    224276     20460       --        --      8.4%
表1-15 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储以及内核管理开销等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额
Buffers
已使用的文件缓冲区的大小
Cached
高速缓冲寄存器已使用的内存大小
Caches
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ buffers/cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
(独立运行模式)
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
     Minor: 475M
    Severe: 316M
    Critical: 158M
    Normal: 633M
    Early-warning: 792M
    Secure: 950M
Current free-memory state: Normal (secure)
Free-memory event statistics:
 [Back to secure state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered early-warning state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to normal state]
 [Entered minor alarm state]
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
表1-16 display memory-threshold命令显示信息描述表
内存利用率门限
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
剩余内存门限:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的门限,单位为MB
·     Early-warning:预警门限,单位为MB
·     Secure:恢复预警门限状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
·     Normal (early-warning):预告警状态
·     Normal (secure):安全状态
门限事件统计信息,事件分为:
·     Back to secure state:恢复到预警前的状态
·     Entered early-warning state:进入预告警门限状态
·     Back to normal state:内存恢复到正常状态
·     Entered minor alarm state:进入一级告警门限状态
·     Back to minor alarm state:恢复到一级告警前的状态
·     Entered severe alarm state:进入二级告警门限状态
·     Back to severe alarm state:恢复到二级告警前的状态
·     Entered critical alarm state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display non-stop-routing status命令用来显示所有支持NSR(Nonstop Routing,不间断路由)功能模块的NSR状态信息。
# 显示所有支持NSR功能模块的NSR状态信息。
<Sysname> display non-stop-routing status
System NSR status: Not ready
Module name(instance name/process ID)                Status
MSDP                                                 Not ready
OSPF(1)                                              Ready
OSPF(2)                                              Ready
BGP(default)                                         Ready
BGP(aaa)                                             Ready
PIM                                                  Not configured
表1-17 display non-stop-routing status命令显示信息描述表
System NSR status
系统的NSR状态:
·     Ready:系统的NSR处于稳定状态,即设备上所有使能NSR的模块的NSR状态均处于稳定状态
·     Not ready:系统的NSR处于未稳定状态,即设备上有些模块的NSR状态处于未稳定状态
·     Not configured:系统的NSR处于未使能状态,即设备上没有模块使能NSR
·     No standby:由于没有备用硬件,而导致设备无法实施NSR
支持NSR功能的模块名称(实例名称/进程编号)。部分模块用instance name区分不同的实例,例如BGP (default);用process ID区分不同的进程,例如OSPF(1)。当模块无具体实例名称或进程时,仅显示模块名称,例如MSDP
Status
NSR的状态信息:
·     Ready:NSR处于稳定状态
·     Not ready:NSR处于未稳定状态,此时不能进行进程倒换或者主备倒换
·     Not configured:NSR处于未使能状态,此时不能进行进程倒换或者主备倒换
display power命令用来显示设备电源的信息。
(独立运行模式)
display power [ power-id ]
display power [ chassis chassis-number [ power-id ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。(IRF模式)
power-id:表示电源的编号。不指定该参数时,表示指定位置的所有电源。
# 显示设备电源的状况。
·     SR8800-X
<Sysname> display power
 Power        0 State: Normal
 Power        1 State: Absent
 Power        2 State: Absent
 Power        3 State: Absent
·     SR8800-X-S
 Power        1 State: Normal
表1-18 display power命令显示信息描述表
Power         n State
电源模块的状态:
·     Normal:表示该槽位电源模块处于正常工作状态
·     Absent:表示该槽位没有插入电源模块
·     Error:表示该槽位电源模块出错,不能正常运行
display power-off high-temp-board命令用来显示单板过温下电功能是否使能。
本命令在如下单板上支持:
·     端口容量大于80G的SPC类单板。单板的端口容量是指整块单板上所有接口速率的总和,如SPC-XP24LCX单板的端口容量为240G,即24x10G。
·     MPE-1104单板、IM-MSUX单板
·     CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E单板、SPEX类单板、CSPEX类单板、SPE类单板和CEPC类单板
·     交换网板
# 查询单板过温下电功能是否使能。
<Sysname> display power-off high-temp-board
Power off high temperature board mode: Enable
display power-information命令用来显示设备电源和单板的功率信息。
(独立运行模式)
display power-information [ verbose ]
display power-information [ chassis chassis-number ] [ verbose ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示显示所有设备电源和单板的功率信息。(IRF模式)
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
# 显示设备电源及单板的功率信息。(独立运行模式)
·     SR8800-X
[Sysname] display power-information
Power control mode: strict
Device power: 2500W
Surplus power: 1296W (contain 100W reserve power)
Fan power: 300W
Slot No.     Power(W)
  0           100         reserve  for  mainboard
  1           100         reserve  for  mainboard
  3           95
  4           300
  5           164
  6           65
  7           80
·     SR8800-X-S
Power supply policy: balance
Device power: 1190W
Surplus power: 752W (contain  0W reserve power)
Fan power: 28W
Slot No.     Power(W)
  0           60         reserve  for  mainboard
  1           60         reserve  for  mainboard
  2           95
  3           195
表1-19 display power-information命令显示信息描述表
Chassis n
设备在IRF中的成员编号(IRF模式)
Device Power
设备的额定功率
Power control mode
单板上电控制模式(仅SR8800-X设备显示):
·     loose:宽松模式
·     strict:严格模式
Power supply policy
电源工作模式,仅SR8800-X-S设备显示,目前仅支持电源工作模式为平衡模式(balance)
Surplus power
设备的剩余功率
Fan Power
风扇的最大功率
contain 100 reserve power
保留100W电源功率
Slot No.
单板的槽位号
Power(W)
单板的最大功率
主控板的保留功率
Power No.
电源的槽位号
Status
电源的状态
Input(V)
电源当前的输入电压
Output(V)
电源当前的输出电压
Input(A)
电源当前的输入电流
Output(A)
电源当前的输出电流
Input(W)
电源当前的输入功率
Output(W)
电源当前的输出功率
Current input total power
当前的电源输入总功率
Current output total power
当前的电源输出总功率
display resource-monitor命令用来显示资源监控功能的相关信息。
(独立运行模式)
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见表1-35。
slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arpnd                            20    10     1042296/1042298
表1-20 display resource-monitor命令显示信息描述表
周期发送低级别资源告警通知功能的开启状态:
·     Enabled:表示该功能已开启
·     Disabled:表示该功能未开启
Resource
监控资源的名称
Minor
低级别告警门限,单位为百分比
Severe
高级别门限,单位为百分比
Free/Total
(absolute)
剩余资源的数量/该资源的总数,用绝对值形式表示
·     resource-monitor minor resend enable
·     resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface rang gigabitethernet 3/1/1 to gigabitethernet 3/1/3
[Sysname-if-range]shutdown
表1-21 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2011
Last execution time  : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts     : 1
shutdown                                          Successful
表1-22 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display service-mode status用于查看单板当前的工作模式。
(独立运行模式)
display service-mode status chassis chassis-number
chassis chassis-number:显示指定成员设备上所有单板当前的工作模式。chassis-number表示设备在IRF中的成员编号。(IRF模式)
# 查看设备所有单板当前的工作模式。(独立运行模式)
<Sysname> display service-mode status
 Slot No.    Service-mode
    1        MIX-BRIDGING-ROUTING
    4        ROUTING
    5        NONE
    6        NONE
   14        NONE
表1-23 display service-mode status显示信息描述表
Slot No.
单板槽位号
Service-mode
单板的工作模式
混合扩展模式
ROUTING
路由扩展模式
ENHANCE-IPV6-ROUTE
IPv6增强模式
NONE
表示该单板不支持工作模式的配置
·     service-mode
仅MPE-1104单板支持本命令。
display slot-mode命令用来显示单板支持的子卡模式。
(独立运行模式)
display slot-mode slot slot-number
display slot-mode chassis chassis-number slot slot-number
# 显示指定单板支持的子卡模式。(独立运行模式)
<Sysname> display slot-mode slot 2
The current slot mode is 4-card.
The slot mode for next startup is 3-card.
display system stable state命令用来显示系统的稳定状态。
display system stable state [ summary ]
summary:显示系统稳定状态的汇总信息,包括CPU的运行状态、主备状态和NSR的稳定状态。不指定该参数时,显示CPU的运行状态、主备状态,以及CPU运行状态的详细信息。
设备/单板启动需要一定的时间,才能达到Stable状态。如果设备/单板长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
·     通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
执行display system stable state命令时,会自动执行display ha service-group all命令。通过display ha service-group all命令获取的信息判断系统的稳定状态。有关display ha service-group all命令的详细介绍,请参见“可靠性命令参考”中的“进程分布优化”。
# 显示系统的稳定状态。
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundance
NSR     state     : No standby
# 显示CPU的运行状态、主备状态,以及CPU运行状态的详细信息。
  Slot    CPU    Role       State
  0       0      Active     Stable
  2       0      Other      Stable
  3       0      Other      Stable
表1-24 display system stable state命令显示信息描述表
System state
所有CPU的运行状态的汇总,取值为:
·     Stable:稳定运行
·     Not ready:未稳定
所有CPU的运行状态为Stable时,该字段将显示为Stable;只要有一个CPU的运行状态不是Stable,该字段将显示为Not ready
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No redundance:系统无冗余,不能倒换
·     Not ready:未稳定,不可以倒换
NSR state
各业务模块NSR状态的汇总,取值为:
·     Stable:稳定状态
·     Not ready:未稳定状态,此时不能进行进程倒换或者主备倒换
Role
Slot在系统中的身份:
·     Active:主用主控板
·     Standby:备用主控板,提供冗余备份
·     Other:业务板
单板的运行状态:
·     Stable:单板稳定运行
·     Board inserted:单板插入
·     Kernel initiating:单板内核初始化
·     Service starting:单板上的服务正在启动
·     Service stopping:单板上的服务正在关闭
·     HA Batch backup:HA批量备份中
·     Interface data batch backup:接口管理批量备份未完成
当前对象处于未稳定状态
·     display device
·     display ha service-group(可靠性命令参考/进程分布优化)
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-25 SFP/SFP28/SFP+/GBIC/SFF的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX power high
接收光功率高
RX power low
接收光功率低
TX fault
发送错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
表1-26 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
RX signal loss in channel x
通道x接收到的信号丢失
TX fault in channel x
通道x发送报文时出错
TX signal loss in channel x
通道x发送的信号丢失
RX power high in channel x
通道x接收到的光的功率太高
RX power low in channel x
通道x接收到的光的功率太低
TX bias high in channel x
通道x的偏置电流高
TX bias low in channel x
通道x的偏置电流低
模块读写错误
模块信息校验和错误
Transceiver type and port configuration mismatched
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-27 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked
发送Jitter PLL失锁
TX CMU unlocked
发送CMU失锁
Overloaded
负载过大
Loss of REFCLK input
缺乏参考时钟
Channel signals out of alignment
主机通道信号不对齐
PLD or flash initialization error
初始化错误
Power supply fault
电源错误
CFP checksum error
校验和错误
TX bias high
偏置电流高
TX bias low
偏置电流低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
通道x接收到的信号丢失
RX IC unlocked in channel x
通道x接收到的IC时钟失锁
RX FIFO error in channel x
通道x接收到FIFO错误
通道x发送的信号丢失
TX IC unlocked in channel x
通道x发送的IC时钟失锁
TX FIFO error in channel x
主机通道x的发送FIFO出错
主机通道x发送的IC时钟失锁
APD supply fault in channel x
通道x出现APD错误
TEC fault in channel x
通道x出现TEC错误
Wavelength unlocked in channel x
通道x的光信号波长失锁
RX power high in lane x
通道x接收到的光的功率太高
RX power low in lane x
通道x接收到的光的功率太低
TX power high in lane x
通道x发送的光的功率太高
TX power low in lane x
通道x发送的光的功率太低
TX bias high in lane x
通道x的偏置电流高
TX bias low in lane x
通道x的偏置电流低
Temp high in lane x
通道x的温度高
Temp low in lane x
通道x的温度低
模块读写错误
模块信息校验和错误
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-28 XFP的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX not ready
接收状态未就绪
RX CDR loss of lock
RX CDR时钟失锁
RX power high
接收光功率高
RX power low
接收光功率低
TX not ready
发送状态未就绪
TX fault
发送错误
TX CDR loss of lock
TX CDR时钟失锁
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Module not ready
模块状态未就绪
APD supply fault
APD(Avalanche Photo Diode,雪崩光电二极管)错误
TEC fault
TEC(Thermoelectric Cooler,热点冷却器)错误
Wavelength unlocked
光信号波长失锁
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
表1-29 XENPAK的display transceiver alarm命令输出信息描述表
WIS local fault
WIS(WAN Interface Sublayer)本地错误
Receive optical power fault
接收光功率错误
PMA/PMD receiver local fault
PMA/PMD(Physical Medium Attachment/Physical Medium Dependent)接收器本地错误
PCS receive local fault
PCS(Physical Coding Sublayer)接收本地错误
PHY XS receive local fault
PHY XS(PHY Extended Sublayer)接收本地错误
RX power high
接收光功率高
RX power low
接收光功率低
Laser bias current fault
激光器偏置电流错误
Laser temperature fault
激光器温度错误
Laser output power fault
激光器输出光功率错误
TX fault
发送器错误
PMA/PMD接收器本地错误
PCS接收本地错误
PHY XS接收本地错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
模块信息I/O错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
# 显示接口GigabitEthernet3/1/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver current alarm information:
  RX signal loss
  RX power low
表1-30 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX signal loss
接收信号丢失
RX power low
接收光功率低告警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/1/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(℃)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
表1-31 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/1/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),275(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
表1-32 display transceiver interface命令显示信息描述表
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Connector Type
可插拔接口模块的连接器类型,其中:
·     光纤连接器包括SC(SC Connector,NTT公司推出的拔插锁紧式光纤连接器)、LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)两种类型
·     其他连接器包括RJ-45、CX4等类型
Wavelength(nm)
·     光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔
·     电模块:显示为“N/A”
Transfer Distance(xx)
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
·     CX4:表示CX4电缆
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/1/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
表1-33 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number
在生产过程中生成的序列号
Manufacturing Date
写入电子标签的日期
Vendor Name
厂商名称
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
……显示信息略……
display version-update-record命令用来显示启动软件包版本更新操作的记录。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1  (updated on Sep 30 2 at 08:35:21):
  Version     : 7.1.075 Beta 7603
  Compile time: Aug 22 2016 16:00:00
表1-34 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54)
最近的第n次更新的时间,Record 1为最新的一次更新
*Name
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化
Version
软件包的版本号
Compile time
版本编译时间
·     reset version-update-record
fabric load-sharing algorithm命令用来配置业务板的负载分担算法。
undo fabric load-sharing algorithm命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing algorithm algorithm-number slot slot-number
undo fabric load-sharing algorithm algorithm-number slot slot-number
fabric load-sharing algorithm algorithm-number chassis chassis-number slot slot-number
undo fabric load-sharing algorithm algorithm-number chassis chassis-number slot slot-number
未配置负载分担算法。
algorithm-number:表示负载分担算法,取值范围为1~9。
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number为单板所在的槽位号。(IRF模式)
如果多次执行本命令,最后一次执行的命令生效。
仅端口容量大于80G的SPC类单板(除SPC-CP2LB单板和SPC-CP2LA单板)支持本功能。单板的端口容量是指整块单板上所有接口速率的总和,如SPC-XP24LCX单板的端口容量为240G,即24x10G。
# 配置指定slot按照算法3进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing algorithm 3 slot 2
fabric load-sharing mode命令用来配置业务板的负载分担类型。
undo fabric load-sharing mode命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing mode { { destination-ip | destination-mac | source-ip | source-mac } * | flexible } slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | source-ip | source-mac } * | flexible ] slot slot-number
fabric load-sharing mode { { destination-ip | destination-mac | source-ip | source-mac } * | flexible } chassis chassis-number slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | source-ip | source-mac } * | flexible ] chassis chassis-number slot slot-number
按报文的入端口进行负载分担。
destination-ip:表示按报文的目的IP地址进行负载分担。
destination-mac:表示按报文的目的MAC地址进行负载分担。
source-ip:表示按报文的源IP地址进行负载分担。
source-mac:表示按报文的源MAC地址进行负载分担。
flexible:表示按报文类型(如二层、IPv4等)自动选择负载分担的类型。
slot slot-number:单板所在的槽位号。(独立运行模式)
仅MPE-1104单板和SPC类单板(除SPC-CP2LB、SPC-CP2LA)支持配置本功能。
SPC类单板和MPE-1104单板按报文类型进行负载分担,只对单板的上行口(包括IRF物理端口)生效。
对于业务板不支持的负载分担类型,系统将提示用户不支持。
执行undo fabric load-sharing mode命令不指定可选参数时,表示删除指定slot的所有负载分担类型。
# 配置指定slot按照报文目的MAC地址进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing mode destination-mac slot 2
1.1.50  fan-speed
fan-speed命令用来配置风扇的工作模式。
(独立运行模式)
fan-speed { auto | high | middle | low }
fan-speed [ chassis chassis-number ] { auto | high | middle | low }
风扇的工作模式为auto。
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。(IRF模式)
auto:表示风扇的工作模式为自动调速模式。该模式下,设备会根据单板温度进行自动调速,推荐使用该模式。
high:表示风扇的工作模式为高速模式。该模式下,风扇转速快,散热效果好,但是噪音比较大。
middle:表示风扇的工作模式为中速模式。该模式下,风扇转速较快,散热较好,噪声较轻。
low:表示风扇的工作模式为低速模式。该模式下,风扇转速较低,噪音较小,但是单板散热效果比较差。
# 配置风扇的工作模式为自动调速模式。(独立运行模式)
[Sysname] fan-speed auto
Fan speed changed successfully!
forwarding bandwidth命令用来配置业务板转发带宽的分配模式。
undo forwarding bandwidth命令用来恢复缺省情况。
forwarding bandwidth { balanced | inter | intra }
业务板转发带宽的分配模式为inter。
balanced:配置业务板转发带宽的模式为均衡模式。即分配给板间和板内转发带宽各占总带宽的50%。
inter:配置业务板转发带宽的模式为板间转发优先模式。即分配给板间转发带宽占总带宽的66.7%。
intra:配置业务板转发带宽的模式为板内转发优先模式。即分配给板内转发带宽占总带宽的66.7%。
仅安装在SR8802-X-S上的CSPEX类单板(CSPEX-1104-E除外)支持配置本功能。
设备总的转发带宽是一个固定值,分配给板内转发的带宽增多,会导致板间转发的带宽相应地减少,请根据业务板实际转发带宽需求调整业务板转发带宽的分配模式。
切换业务板转发带宽的分配模式可能会导致报文丢失,请在专业人士指导下使用。
# 配置业务板转发带宽的模式为intra。
[Sysname] forwarding bandwidth intra
This command might cause packet loss. Continue? [Y/N]:y
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { chip | forwarding }
当系统检测到器件(chip)和转发(forwarding)的硬件故障时,修复操作为warning。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动关闭端口、隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,不会修复故障。
设备启动后,系统会持续自动检测器件和转发的硬件故障。
# 配置系统检测到转发层面的故障时自动告警。
[Sysname] hardware-failure-detection forwarding warning
hardware-failure-protection aggregation命令用来开启针对聚合组的硬件故障保护功能。
undo hardware-failure-protection aggregation命令用来关闭针对聚合组的硬件故障保护功能。
针对聚合组的硬件故障保护功能处于关闭状态。
只有配置hardware-failure-detection forwarding isolate命令后,该命令才生效。
配置该命令后,当系统检测到硬件故障时,会按顺序遵循如下原则处理:
·     如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而且该端口不是聚合组中最后一个UP状态的端口,则该端口会被自动关闭;
·     如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而该端口是聚合组中最后一个UP状态的端口,则该端口不会被关闭;
·     如果聚合组成员端口配置了hardware-failure-protection auto-down命令,则不管该端口是不是聚合组中最后一个UP状态的端口,该端口都会被关闭。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对聚合组中的该成员端口失效:
·     端口下配置了以太网接口环回测试功能,即loopback { external | internal }命令;
·     端口下配置了以太网接口的强制开启功能,即port up-mode命令;
·     该端口配置为IRF物理端口。
# 开启针对聚合组的硬件故障保护功能。
[Sysname] hardware-failure-protection aggregation
·     hardware-failure-detection
·     hardware-failure-protection auto-down
hardware-failure-protection auto-down命令用来开启针对端口的硬件故障保护功能。
undo hardware-failure-protection auto-down命令用来关闭针对端口的硬件故障保护功能。
针对端口的硬件故障保护功能处于开启状态。
以太网接口视图
在端口上配置该命令前,请确保该端口存在备份的链路,以免造成业务中断。
在端口上配置hardware-failure-protection auto-down命令后,当系统检测到硬件故障时,会自动关闭该端口。此时使用display interface命令可看到该端口状态为Protect DOWN。端口硬件故障解除后,请在接口下执行undo shutdown命令来恢复端口状态。
配置了hardware-failure-detection forwarding isolate后,本命令才会生效。
出现以下任意一种情况时,hardware-failure-protection auto-down命令会对该端口失效:
·     该端口配置为IRF物理端口。
# 对端口配置硬件故障保护。
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] hardware-failure-protection auto-down
1.1.56  header
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
未配置欢迎信息。
incoming:配置Modem登录用户登录进入用户视图时的欢迎信息。如果要求认证,则欢迎信息在通过认证后输出。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置非Modem登录用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
1.1.57  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
1.1.58  memory-threshold
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
一级告警门限为96MB,二级告警门限为64MB,三级告警门限为48MB,系统恢复到正常的内存门限为128MB。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限,单位为兆字节(MB);minor-value应小于等于normal-value;为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB);severe-value必须小于等于minor-value;为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB);critical-value必须小于等于severe-value;为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB);normal-value必须小于等于实际内存大小。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
系统实时监控剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
对于支持低端内存的slot,设备监控的是低端内存中剩余空闲内存的大小;对于不支持低端内存的slot,设备监控的是系统内存中剩余空闲内存的大小。执行display memory命令,如果显示信息中包含LowMem字段,则表示该slot支持低端内存。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
·     display memory-threshold
1.1.59  memory-threshold usage
memory-threshold usage命令用来配置内存利用率门限。
undo memory-threshold usage命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率门限为100%。
memory-threshold:内存利用率门限百分比,取值范围为0~100。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率门限比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率门限为80%。
[Sysname] memory-threshold usage 80
1.1.60  memory-threshold  usage resend-interval
memory-threshold usage resend-interval命令用来配置发送内存利用率告警事件的时间间隔。
undo memory-threshold usage resend-interval命令用来取消内存利用率告警事件发送时间间隔的配置。
(独立运行模式)
memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-intervel interval-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-intervel
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage resend-intervel interval-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage resend-intervel
持续5分钟超过内存利用率门限则上报一次告警事件。
interval-value:内存利用率告警事件周期发送的时间间隔,取值范围1~3600,单位为分钟。
设备定期对内存使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,进入告警状态并生成相应的告警事件。
# 配置slot 1 CPU 0发送内存利用率告警事件的时间间隔为300分钟。
[Sysname] memory-threshold slot 1 cpu 0 usage resend-interval 300
·     memory-threshold usage
1.1.61  monitor cpu-usage enable
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
(独立运行模式)
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
1.1.62  monitor cpu-usage interval
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
(独立运行模式)
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
1.1.63  monitor cpu-usage threshold
monitor cpu-usage threshold命令用来配置CPU利用率阈值。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
(独立运行模式)
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率高级别告警门限为99%,CPU利用率低级别告警门限为79%,CPU利用率恢复门限为69%。
cpu-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.8。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.7。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的CPU利用率门限比较。当采样值大时,则认为CPU利用率过高,设备会发送Trap报文。
当采样值回落,小于等于CPU利用率恢复门限时,则认为CPU利用率已经恢复到正常范围。
# 配置CPU利用率高级别告警门限为80%。
[Sysname] monitor cpu-usage threshold 80
1.1.64  monitor resend cpu-usage
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定参数时,仅将该参数恢复到缺省值。
# 配置slot 2 CPU 0低级别告警事件的发送周期为60秒。
[Sysname] monitor resend cpu-usage minor-interval 60 slot 2 cpu 0
1.1.65  monitor resend cpu-usage core-interval
monitor resend cpu-usage core-interval命令用来配置发送CPU核告警事件的间隔。
undo monitor resend cpu-usage core-interval命令用来取消CPU核告警事件发送间隔的配置。
(独立运行模式)
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU核低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU核高级别告警事件。
minor-interval minor-interval:CPU核低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU核高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU核使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,CPU核将进入该告警状态并生成告警事件。
CPU核处于告警状态时,会周期发送CPU核告警事件,直到CPU核告警状态解除。使用本命令可以修改CPU核告警事件的发送周期。
# 配置设备上所有CPU核发送告警事件的间隔:低级别告警为100秒、高级别告警为60秒。
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
1.1.66  monitor resend memory-threshold
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
执行undo monitor resend memory-threshold命令并不指定critical-interval、early-warning-interval、minor-interval和severe-interval参数时,表示将这些参数均恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
·     memory-threshold
1.1.67  password-recovery enable
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
清除认证密码的操作必须在主用主控板的启动过程中进入BootWare菜单进行。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.68  power control-mode
power control-mode命令用来设置单板上电控制模式。
undo power control-mode命令用来恢复缺省情况。
power control-mode { loose | strict }
单板上电控制模式为严格模式。
loose:设置单板上电控制模式为宽松模式。当有新的业务板或网板插入时,若风扇、主控板保留功率和所有的业务板和网板(包括新插入的)的最大功率之和不超过设备额定功率的1.2倍时,该业务板或网板可以正常上电。
strict:设置单板上电控制模式为严格模式。在此模式下,当有新的业务板或网板插入时,若风扇、主控板保留功率和所有的业务板和网板(包括新插入的)的最大功率之和超过设备额定功率,该业务板或网板无法上电。
SR8800-X-S设备不支持此命令。
# 设置单板上电控制模式为宽松模式。
[Sysname] power control-mode loose
1.1.69  power-off high-temp-board clear
power-off high-temp-board clear命令用来将过温下电的单板恢复上电。
(独立运行模式)
power-off high-temp-board clear chassis chassis-number
当单板上的热点传感器的温度超过shutdown阈值,系统会自动给单板下电。通过该命令行能够给因上述情况而下电的单板重新上电重启。
本命令在如下单板上支持:
·     交换网板
# 将过温下电的单板恢复上电。
[Sysname] power-off high-temp-board clear
1.1.70  power-off high-temp-board enable
power-off high-temp-board enable命令用来使能单板过温下电功能。
undo power-off high-temp-board enable
单板过温下电功能处于开启状态。
开启单板过温下电功能后,当单板上的热点传感器的温度超过shutdown阈值,系统会自动给该单板下电。
本命令在如下单板上支持:
·     交换网板
# 使能单板过温下电功能。
[Sysname] power-off high-temp-board enable
·     display power-off high-temp-board
1.1.71  reboot
reboot命令用来重启设备。
(独立运行模式)
reboot [ slot slot-number [ cpu cpu-number | subslot subslot-number ] ] [ force ]
reboot [ chassis chassis-number [ slot slot-number [ cpu cpu-number | subslot subslot-number ] ] ] [ force ]
cpu cpu-number:CPU的编号。不指定该参数时,会重启slot。
subslot subslot-number:子卡所在的子槽位号。
force:强制重启:
·     不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(独立运行模式)
不指定slot参数,会导致整个设备重启。
指定slot参数,不指定subslot参数,会重启指定单板。
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
不指定chassis和slot参数,则会重启所有成员设备。
只指定chassis不指定slot参数,则会重启IRF中指定的成员设备。
同时指定chassis和slot参数,则会重启IRF中指定的单板。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
·     display system stable state
1.1.72  reset scheduler logfile
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
1.1.73  reset version-update-record
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
1.1.74  resource-monitor minor resend enable
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
是否仅缺省MDC支持本命令与设备的型号有关,请以设备实际情况为准。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
·     开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
·     关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
·     display resource-monitor
·     resource-monitor output
1.1.75  resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
·     NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
·     信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
·     SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
1.1.76  resource-monitor resource
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
(独立运行模式)
resource-monitor resource resource-name slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
resource-monitor resource resource-name  chassis chassis-number slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见表1-35。不同单板上支持监测的资源不同,请以单板的实际情况为准。
表1-35 设备可监测的资源描述表
取值
含义
acl_car
CAR模板资源
acl_counter
ACL计数器资源
arp
ARP表项资源
arpnd
ARP和ND表项资源
bfd_hardbfd_session
硬件BFD会话数目
bpa_counter_in
入方向BGP统计资源
bpa_counter_out
出方向BGP统计资源
cfd_counterid_index
CFD counterid索引资源
cfd_watchdog_index
CFD watchdog索引资源
ecmp
路由等价资源
efp_acl
出方向ACL资源
eth_subif_statistic
路由子接口统计计数器资源
flow_mirror
流镜像资源
Ifp_acl
入方向ACL资源
ipmc
组播复制表项资源
ipv4_acl
IPv4 ACL资源
ipv4_defip
IPv4路由表项资源
ipv4fib
IPv4 FIB硬件表项资源
ipv4mc
IPv4组播转发表项资源
ipv6_acl
IPv6 acl资源
ipv6_defip
IPv6路由表项资源
ipv6_defip64
掩码长度为0~64位的IPv6路由表项资源
ipv6_defip128
掩码长度为65~128位的IPv6路由表项资源
ipv6fib
IPv6 FIB硬件表项资源
ipv6mc
IPv6组播转发表项资源
mac
MAC地址表项资源
maptable_in
入方向灵活优先级映射表资源
maptable_out
出方向灵活优先级映射表资源
mirror_group
镜像组资源
mpls_cbts
CBTS统计资源
mpls_dynvpnid
VXLAN 泛洪MAC资源
mpls_ecmplsp
ECMP LSP等价资源
mpls_ilm
ILM标签资源
mpls_inlabel
入方向mpls标签资源
mpls_l3vpn
L3VPN实例数目
mpls_label
标签索引资源
mpls_lsp
MPLS LSP统计资源
mpls_outlabel
出方向MPLS标签资源
mpls_te
MPLS TE隧道的配置数目
mpls_outlif
MPLS outlif资源
mpls_vp
MPLS VP资源
mpls_vpls_pw
VPLS 实例PW数目
mpls_vpws
VPWS配置数目
mpls_vsi
VSI(Virtual Switch Instance,虚拟交换实例)数目
mpls_vxlan_tunnel
VXLAN 隧道数目
mpls_vxlanvni
VXLAN 专线统计资源
mplste_tunnel_lr
MAC地址表项资源
mtunnel
组播隧道接口资源
nd
ND表项资源
nexthop
下一跳资源
nqa_client_1564
NQA 客户端1564会话数
nqa_client_2544
NQA 客户端2544会话数
nqa_client_twamplight
NQA 客户端twamp会话数
nqa_reflector_remote
NQA 服务器1564、1564会话数
nqa_reflector_twamplight
NQA 服务器twamp会话数
nqa_veinlif
NQA VEinlif资源
port_shape
主接口整形资源
qinq_inlif
子接口QinQ Inlif表项资源
qos_queue
Qos八队列资源
queue_shape
队列整形资源
rport
协议端口表项资源
sampler
采样器资源
share_policy_in
入方向共享MQC资源
share_policy_out
出方向共享MQC资源
subif_tb_in
入方向子接口统计资源
subif_tb_out
出方向子接口统计资源
subport_shape
子接口整形资源
tunnel
隧道接口资源
v4mcpro
IPv4协议组播表项资源
v6mcpro
IPv6协议组播表项资源
vfp_acl
VLAN相关ACL资源
wfq_weight
加权公平队列权重资源
wred_table
WRED模板资源
slot slot-number:表示监测指定单板上的资源。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示监测指定单板上的资源。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-absolute:以绝对值的方式配置告警门限。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
CSPEX-1204单板不支持本功能。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent  minor-threshold 30 severe-threshold 10
1.1.77  restore factory-default
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
执行该命令后,需手工重启设备才能使该命令生效。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
1.1.78  scheduler job
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
·     command
1.1.79  scheduler logfile size
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
1.1.80  scheduler reboot at
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
·     配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2011年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
1.1.81  scheduler reboot delay
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2011年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
1.1.82  scheduler schedule
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule。
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
1.1.83  service-mode
本命令仅适用于端口容量不大于80G的SPC类单板和丝印为MPE-1104的单板。单板的端口容量是指整块单板上所有接口速率的总和,如SPC-GP24XP2LB单板的端口容量为44G,即2x10G+24x1G。
如需配置,请务必与技术支持人员确认。
service-mode命令用于配置设备业务板的工作模式。
undo service-mode命令用于恢复业务板的工作模式为缺省情况。
(独立运行模式)
service-mode { routing | mix-bridging-routing | enhance-ipv6-route } slot slot-number
undo service-mode slot slot-number
service-mode { routing | mix-bridging-routing | enhance-ipv6-route } chassis chassis-number slot slot-number
undo service-mode chassis chassis-number slot slot-number
工作模式为mix-bridging-routing。
routing:路由扩展模式。
mix-bridging-routing:混合扩展模式。
enhance-ipv6-route:业务板工作模式为IPv6增强模式。
slot slot-number:业务板所在槽位号。
chassis chassis-number:表示IRF中设备的成员编号。(IRF模式)
·     业务板的工作模式变化只能改变本单板的业务能力,对整机业务能力没有影响。
·     业务板的工作模式配置完毕后需保存配置并重启该业务板,所做配置才会生效。
·     仅SPC-GP24LA1、SPC-GT48LA1、SPC-XP2LA1、SPC-XP8LA、SPC-XP4LA1、SPC-GP24XP2LA和SPC-GP48LA1单板支持配置为enhance-ipv6-route模式。
# 配置设备3号槽位业务板的工作模式为IPv6增强模式。(独立运行模式)
[Sysname] service-mode enhance-ipv6-route slot 3
·     display service-mode status
1.1.84  shutdown-interval
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示不进行定时检测。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
1.1.85  slot-mode
仅MPE-1104单板支持本命令。
slot-mode命令用来设置单板的子卡模式。
(独立运行模式)
slot-mode slot slot-number { 3-card | 4-card }
slot-mode chassis chassis-number slot slot-number { 3-card | 4-card }
单板的子卡模式为4-card。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
3-card:配置MPE-1104单板支持3个子卡槽位。3号子卡槽位无限制,4号子卡槽位不可用。
4-card:配置MPE-1104单板支持4个子卡槽位,该模式下,如果该单板的1号或2号子卡槽位插有MIC-SP8L子卡,则3号和4号子卡槽位只能插MIC-CLP2L或MIC-ET16L子卡;反之,如果3号或者4号子卡槽位插有除MIC-CLP2L和MIC-ET16L之外的子卡,则该单板的1号和2号子卡槽位不能插MIC-SP8L子卡。
模式切换后需要重启单板,新配置的模式才会生效。
# 将指定单板的子卡模式配置为4-card模式。(独立运行模式)
[Sysname] slot-mode slot 2 4-card
Slot mode changed. For the change to take effect,please reboot the card.
1.1.86  switch-fabric isolate
switch-fabric isolate命令用来将网板或网板通道从转发平面隔离出去,所有数据流量都不经过该网板或该网板通道。
undo switch-fabric isolate命令用来恢复缺省情况。
(独立运行模式)
switch-fabric isolate slot slot-number [ channel channel-number ]
undo switch-fabric isolate slot slot-number [ channel channel-number ]
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
undo switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
每块网板的每个网板通道都处于转发平面,数据流量会经过该网板的各个通道进行转发。
slot slot-number:表示网板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定网板。(IRF模式)
channel channel-number:网板的通道编号。不指定该参数时,表示隔离整块网板。设备不支持配置本参数。
·     每块网板都有一定的转发带宽,隔离一块网板后会减少相应的转发带宽,使设备整体转发带宽降低。请根据需要配置。
·     当设备上仅存在一块网板时,请不要隔离该网板。
仅CSPC-GE16XP4L-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E、CSPEX-1104-E和SPEX-1204单板本命令配置后不生效,即配置本命令将网板或网板通道隔离后,仅上述单板的数据流量仍会经过该网板或网板通道,其他单板的数据流量不会从该网板或网板通道正常转发。
配置某块网板的隔离功能后,如果该网板不需要再使用,请及时拔出该网板;如果该网板需要继续使用,请使用undo switch-fabric isolate命令对该网板取消隔离,并且在网板隔离期间请不要重启设备。
配置该功能后主控板与网板的正常通信,控制平面上协议报文的解析与协议的计算等功能均不受影响,从而保证了通过undo switch-fabric isolate 命令快速恢复网板的转发能力。
# 将10号槽位网板的1号通道隔离。(独立运行模式)
[Sysname] switch-fabric isolate slot 10 channel 1
The command will isolate the channel of the switch fabric from the system. Continue? [Y/N]y
1.1.87  switch-fabric removal-signal-report enable
switch-fabric removal-signal-report enable命令用来打开上报网板中断信号功能。
undo switch-fabric removal-signal-report enable命令用来恢复缺省情况。
上报网板中断信号功能处于关闭状态。
打开上报网板中断信号功能后,网板拔出前,会触发一次中断信号。系统收到中断信号后会将网板的业务迁移到其他网板上,以便网板拔出的时候,不影响当前业务。
# 打开上报网板中断信号功能。
[Sysname] switch-fabric removal-signal-report enable
1.1.88  sysname
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备名称是H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
1.1.89  temperature-limit
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
(独立运行模式)
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
不同单板的温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,取值为从1开始的正整数,每一个数字对应设备上的一个温度传感器。
lowlimit:低温告警门限,单位为摄氏度。
warninglimit:一般级(Warning)高温告警门限,单位为摄氏度,但必须大于低温告警门限。
alarmlimit:严重级(Alarm)高温告警门限,单位为摄氏度,但必须大于一般级高温告警门限。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上入风方向1号温度传感器,低温门限为0摄氏度,Warning级高温门限为60摄氏度,Alarm级高温门限为70摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 inflow 1 0 60 70
1.1.90  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2011年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
1.1.91  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
1.1.92  time repeating
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.93  user-role
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
