08-IP组播命令参考
05-IGMP命令
本章节下载: 05-IGMP命令  (389.38 KB)
05-IGMP命令
1 IGMP
1.1 IGMP配置命令
1.1.1 display igmp attack-suppression per-interface configuration
1.1.2 display igmp attack-suppression per-interface entry
1.1.3 display igmp group
1.1.4 display igmp host-tracking
1.1.5 display igmp interface
1.1.6 display igmp proxy group
1.1.7 display igmp proxy routing-table
1.1.8 display igmp ssm-mapping
1.1.9 host-tracking enable (IGMP view)
1.1.10 igmp
1.1.11 igmp attack-suppression per-interface aging-time
1.1.12 igmp attack-suppression per-interface check-interval
1.1.13 igmp attack-suppression per-interface enable
1.1.14 igmp attack-suppression per-interface threshold
1.1.15 igmp enable
1.1.16 igmp fast-leave
1.1.17 igmp group-policy
1.1.18 igmp host-tracking { disable | enable }
1.1.19 igmp host-tracking limit
1.1.20 igmp join-by-session
1.1.21 igmp last-member-query-count
1.1.22 igmp last-member-query-interval
1.1.23 igmp max-response-time
1.1.24 igmp non-stop-routing
1.1.25 igmp other-querier-present-interval
1.1.26 igmp proxy enable
1.1.27 igmp proxy forwarding
1.1.28 igmp query-interval
1.1.29 igmp robust-count
1.1.30 igmp startup-query-count
1.1.31 igmp startup-query-interval
1.1.32 igmp static-group
1.1.33 igmp version
1.1.34 last-member-query-count (IGMP view)
1.1.35 last-member-query-interval (IGMP view)
1.1.36 max-response-time (IGMP view)
1.1.37 other-querier-present-interval (IGMP view)
1.1.38 proxy multipath (IGMP view)
1.1.39 query-interval (IGMP view)
1.1.40 reset igmp attack-suppression per-interface entry
1.1.41 reset igmp attack-suppression per-interface statistics
1.1.42 reset igmp group
1.1.43 robust-count (IGMP view)
1.1.44 ssm-mapping (IGMP view)
1.1.45 startup-query-count (IGMP view)
1.1.46 startup-query-interval (IGMP view)
1 IGMP
1.1  IGMP配置命令
display igmp attack-suppression per-interface configuration命令用来显示基于接口的IGMP攻击检测相关配置信息。
# 显示基于接口的IGMP攻击检测相关配置信息。
<Sysname> display igmp attack-suppression per-interface configuration
IGMP attack-suppression per-interface is enabled.
Check interval: 5s
Threshold: 20
Aging time: 300s
表1-1 display igmp attack-suppression per-interface configuration命令显示信息描述表
Check interval
IGMP基于接口的IGMP攻击检测周期
Threshold
IGMP基于接口的IGMP攻击抑制阈值
Aging time
IGMP基于接口的攻击检测表项老化时间
·     igmp attack-suppression per-interface aging-time
·     igmp attack-suppression per-interface check-interval
·     igmp attack-suppression per-interface enable
·     igmp attack-suppression per-interface threshold
display igmp attack-suppression per-interface entry命令用来显示基于接口的IGMP攻击检测表项。
(独立运行模式)
display igmp attack-suppression per-interface entry slot slot-number [ interface interface-type interface-number ] [ attack ] [ verbose ]
display igmp attack-suppression per-interface entry chassis chassis-number slot slot-number [ interface interface-type interface-number ] [ attack ] [ verbose ]
interface interface-type interface-number:显示指定接口上的IGMP攻击检测表项,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,则显示所有接口下的IGMP攻击检测表项。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
attack:显示基于接口的IGMP攻击报文的攻击检测表项。如果未指定本参数,则显示所有已创建的IGMP攻击检测表项。
verbose:显示基于接口的IGMP攻击检测表项的详细信息。如果未指定本参数,则显示简要信息。
# 显示基于接口的IGMP攻击报文的攻击检测表项。(独立运行模式)
<Sysname> display igmp attack-suppression per-interface entry slot 1 attack
Total entries: 1
Interface             Attack start time      Expires
GE3/1/4               2018/09/10 15:53:34    00:01:15
# 显示基于接口的IGMP攻击检测表项的详细信息。(独立运行模式)
<Sysname> display igmp attack-suppression per-interface entry slot 1 verbose
Total entries: 2
Interface: GE3/1/1
Drv status: N/A
Attack start time: N/A
Expires: Off
CPU receive: 10
CPU drop: 0
Drv drop: 0
Interface: GE3/1/2
Drv status: Succeeded
Attack start time: 2018/09/10 15:53:34
Expires: 00:01:15
CPU receive: 123456789
CPU drop: 123456
Drv drop: 18446744073709551615
表1-2 display igmp attack-suppression per-interface 命令显示信息描述表
Total entries
IGMP攻击检测表项总数
接口名称
Drv status
驱动状态:
·     Succeeded:下驱动成功,产品通过硬件限速
·     Failed:下驱动失败,可能设备故障或硬件攻击表项资源已被占满。此时通过软件进行限速
·     N/A:当前表项对应的报文为非攻击报文,尚未下驱动
Attack start time
检测到攻击开始的时间,N/A表示还未检测到攻击
Expires
IGMP攻击检测表项的超时时间,Off表示该定时器关闭
CPU receive
CPU收到报文数
CPU drop
CPU丢弃的报文数
Drv drop
驱动丢弃的报文数
·     reset igmp attack-suppression per-interface entry
display igmp group命令用来显示IGMP组播组(即通过IGMP加入的组播组)的信息。
display igmp [ vpn-instance vpn-instance-name ] group [ group-address | interface interface-type interface-number ] [ static | verbose ]
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
group-address:显示指定组播组的信息,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的信息。
static:显示静态加入的组播组信息。如果未指定本参数,将只显示动态加入的组播组信息。
verbose:显示详细信息。
# 显示公网实例中动态加入的所有IGMP组播组信息。
<Sysname> display igmp group
IGMP groups in total: 3
 GigabitEthernet3/1/1(10.10.1.20):
  IGMP groups reported in total: 3
   Group address   Last reporter   Uptime      Expires
   225.1.1.1       10.10.1.10      00:02:04    00:01:15
   225.1.1.2       10.10.1.10      00:02:04    00:01:15
   225.1.1.3       10.10.1.10      00:02:04    00:01:15
表1-3 display igmp group命令显示信息描述表
IGMP组播组的总数
当前接口上动态加入的IGMP组播组总数
Group address
组播组地址
Last reporter
最后发送报告报文的主机地址
Uptime
组播组的运行时间
Expires
组播组的超时时间,Off表示该定时器关闭
# 显示公网实例中动态加入的IGMP组播组232.1.1.1的详细信息(假设当前运行IGMPv3)。
<Sysname> display igmp group 232.1.1.1 verbose
   Group: 232.1.1.1
     Uptime: 00:00:34
     Exclude expires: 00:04:16
     Mapping expires: 00:02:16
     Last reporter: 10.10.1.10
     Last-member-query-counter: 0
     Last-member-query-timer-expiry: Off
     Mapping last-member-query-counter: 0
     Mapping last-member-query-timer-expiry: Off
     Group mode: Exclude
     Version1-host-present-timer-expiry: Off
     Version2-host-present-timer-expiry: 00:02:11
     Mapping version1-host-present-timer-expiry: Off
     Source list (sources in total: 1):
       Source: 10.1.1.1
          Uptime: 00:00:03
          V3 expires: 00:04:16
表1-4 display igmp group verbose命令显示信息描述表
当前接口上动态加入的IGMP组播组总数
Group
组播组地址
Uptime
组播组的运行时间
Exclude expires
EXCLUDE模式下组播组的超时时间,Off表示该定时器关闭
Mapping expires
IGMP SSM Mapping规则所生成组播组的超时时间。只有运行IGMP SSM Mapping时才会显示本字段
Last reporter
最后发送报告报文的主机地址
最后组成员查询次数
最后组成员查询定时器的超时时间,Off表示该定时器关闭
IGMP SSM Mapping规则所生成组播组的最后组成员查询次数。只有运行IGMP SSM Mapping时才会显示本字段
IGMP SSM Mapping规则所生成组播组的最后组成员查询定时器的超时时间,Off表示该定时器关闭。只有运行IGMP SSM Mapping时才会显示本字段
Group mode
对组播源的过滤模式:
·     Include:表示INCLUDE模式
·     Exclude:表示EXCLUDE模式
IGMPv1/v2本身并不区分过滤模式,但当运行IGMP SSM Mapping时,会根据具体配置以及加入的组播组来显示相应的模式;而当未运行IGMP SSM Mapping时,则固定显示为Exclude
IGMPv1主机超时时间,Off表示该定时器关闭。只有运行IGMPv2或IGMPv3时才会显示本字段
IGMPv2主机超时时间,Off表示该定时器关闭。只有运行IGMPv3时才会显示本字段
运行IGMP SSM Mapping时IGMPv1主机的超时时间,Off表示该定时器关闭。只有运行IGMP SSM Mapping时才会显示本字段
组播源列表及总数。只有运行IGMPv3或IGMP SSM Mapping时才会显示本字段
Source
组播源地址。只有运行IGMPv3或IGMP SSM Mapping时才会显示本字段
Uptime
组播源的运行时间。只有运行IGMPv3或IGMP SSM Mapping时才会显示本字段
V3 expires
IGMPv3组播源的超时时间,Off表示该定时器关闭,“---”表示该组播源由IGMP SSM Mapping规则生成。只有运行IGMPv3或IGMP SSM Mapping时才会显示本字段
Mapping expires
IGMP SSM Mapping规则所生成组播源的超时时间。只有运行IGMP SSM Mapping时才会显示本字段
最后源组成员查询次数。只有运行IGMPv3或IGMP SSM Mapping时才会显示本字段
最后源组成员查询定时器的超时时间,Off表示该定时器关闭。只有运行IGMPv3或IGMP SSM Mapping时才会显示本字段
# 显示公网实例中静态加入的IGMP组播组信息。
<Sysname> display igmp group static
 Entries in total: 2
   Group address   Source address  Interface           Expires
   225.1.1.1       0.0.0.0         GE3/1/1             Never
   225.2.2.2       1.1.1.1         GE3/1/1             Never
表1-5 display igmp group static命令显示信息描述表
Entries in total
IGMP组播组的总数
Group address
组播组地址
Source address
组播源地址
接口名称
Expires
组播组的超时时间,固定显示为Never,表示永不超时
·     reset igmp group
display igmp host-tracking用来显示IGMP跟踪的主机信息。
display igmp [ vpn-instance vpn-instance-name ] host-tracking [ interface interface-type interface-number ] [ group group-address ] [ source source-address ] [ active ]
vpn-instance vpn-instance-name:显示指定VPN实例内IGMP主机跟踪信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例内IGMP主机跟踪信息。
interface-type interface-number:显示指定接口上IGMP主机跟踪信息。如果未指定本参数,将显示所有接口上IGMP主机跟踪信息。
group group-address:显示IGMP跟踪的加入指定组播组的主机信息。group-address为组播组的地址,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,将显示IGMP跟踪的所有组播组的主机信息。
source source-address:显示指定IGMP跟踪的指定组播源的主机信息。如果未指定本参数,将显示IGMP跟踪的所有组播源的主机信息。
active:显示IGMP跟踪的当前活跃的主机。如果未指定本参数,将显示IGMP跟踪的所有的主机。
# 显示IGMP跟踪的所有主机信息。
<Sysname> display igmp host-tracking
IGMP hosts in total: 4
 GigabitEthernet3/1/1(192.168.1.1):
  IGMP hosts reported in total: 2
   (0.0.0.0,224.1.1.1)
    Host                            Uptime          Expires
    192.168.1.1                     00:02:20        00:00:40
    192.168.1.2                     00:02:21        00:00:39
 GigabitEthernet2/1/2(192.168.2.1):
   (1.1.1.1,224.1.1.1)
    Host                            Uptime          Expires       Type
    192.168.2.1                     00:03:20        Expired       G
    192.168.2.2                     00:02:20        00:00:39      G
# 显示接口GigabitEthernet3/1/1上IGMP跟踪的加入组播组232.1.1.1的主机信息。
<Sysname> display igmp host-tracking interface gigabitethernet 3/1/1 group 232.1.1.1
  IGMP hosts reported in total: 5
   (1.1.1.1,232.1.1.1)
    192.168.1.1                     00:02:20        00:00:40      M
    192.168.1.2                     00:02:21        00:00:39      M
   (2.2.2.2,232.1.1.1)
    192.168.1.1                     00:02:20        00:00:40      G/M
    192.168.1.2                     00:02:21        00:00:39      G/M
    192.168.1.3                     00:02:21        00:00:39      G/M
# 显示接口GigabitEthernet3/1/1上IGMP跟踪的当前活跃主机信息。
<Sysname> display igmp host-tracking interface gigabitethernet 3/1/1 active
   (1.1.1.1, 224.1.1.1)
   (1.1.1.1, 225.1.1.1)
表1-6 display igmp host-tracking命令显示信息描述表
IGMP hosts in total
跟踪的主机总数
接口的名称和IP地址
接口下跟踪的主机数
(0.0.0.0, 224.1.1.1)
(S,G)表项,0.0.0.0表示所有组播源
Host
主机的IP地址
Uptime
主机加入组播组的运行时长
Expires
主机的超时剩余时间,在收到主机的成员关系报告报文时会进行刷新(与端口老化时间一致),Expired表示已超时
表示主机加入的版本信息,取值为:
·     G:IGMPv3版本主机正常加入
·     M:IGMPv1/v2版本主机ssm-mapping加入
·     G/M:以上两种情况同时存在
IGMPv1/v2版本主机不通过ssm-mapping加入,则不显示该字段
·     host-tracking enable
·     igmp host-tracking { disable | enable }
display igmp interface命令用来显示接口上IGMP配置和运行的信息。
display igmp [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ host | proxy ] [ verbose ]
interface-type interface-number:显示指定接口上IGMP配置和运行信息。
host:显示主机接口(即使能了IGMP主机行为的接口)的信息。有关IGMP主机行为的详细介绍,请参见“VXLAN配置指导”中的“VXLAN”。
proxy:显示代理接口的信息。
verbose:显示详细信息。
执行本命令时,如果未指定任何参数,将显示所有接口上IGMP配置和运行的信息。
# 显示公网实例接口GigabitEthernet3/1/1.3(非代理接口)上IGMP配置和运行的详细信息。
<Sysname> display igmp interface gigabitethernet 3/1/1.3 verbose
 GigabitEthernet3/1/1.3 (10.10.1.20):
   IGMP is enabled.
   IGMP version: 2
   Query interval for IGMP: 125s
   Other querier present time for IGMP: 255s
   Maximum query response time for IGMP: 10s
   Last member query interval: 1s
   Last member query count: 2
   Startup query interval: 31s
   Startup query count: 2
   General query timer expiry (hh:mm:ss): 00:00:54
   Querier for IGMP: 10.10.1.20 (This router)
   IGMP activity: 1 join(s), 0 leave(s)
   Multicast routing on this interface: Enabled
   Robustness: 2
   Require-router-alert: Disabled
   Fast-leave: Disabled
   Startup-query: Off
   Other-querier-present-timer-expiry (hh:mm:ss): Off
  IGMP groups reported in total: 1
# 显示公网实例所有代理接口上IGMP配置和运行的详细信息。
<Sysname> display igmp interface proxy verbose
 GigabitEthernet3/1/2(20.10.1.20):
   IGMP proxy is enabled.
   IGMP version: 2
   Version1-querier-present-timer-expiry (hh:mm:ss): Off
# 显示公网实例所有主机接口上IGMP配置和运行的详细信息。
<Sysname> display igmp interface host verbose
 GigabitEthernet3/1/3(30.10.1.20):
   IGMP host is enabled.
   IGMP version: 2
表1-7 display igmp interface命令显示信息描述表
接口的名称和IP地址
IGMP is enabled
接口上已使能IGMP
IGMP version
此接口运行的IGMP版本
IGMP普遍组查询报文的发送间隔(秒)
IGMP其它查询器的存在时间(秒)
IGMP普遍组查询报文的最大响应时间(秒)
最后组成员查询间隔(秒)
最后组成员查询次数
IGMP查询器启动查询间隔(秒)
Startup query count
IGMP查询器启动查询次数
IGMP普遍组查询的超时时间,Off表示该定时器关闭
Querier for IGMP
IGMP查询器的IP地址。当本设备运行IGMPv1且不是IGMPv1查询器时,将不会显示本字段
IGMPv1查询器由PIM DR来担任,可通过display pim interface命令查看
No querier elected
没有进行IGMP查询器选举。只有本设备运行IGMPv1且不是IGMPv1查询器时才会显示本字段
IGMP的活动统计:
·     join(s):表示加入过的组播组总数
·     leave(s):表示离开过的组播组总数
是否使能IP组播路由:
·     Enabled:表示已使能
·     Disabled:表示未使能
Robustness
IGMP查询器的健壮系数
是否开启丢弃未携带Router-Alert选项的IGMP报文功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
Fast-leave
是否开启快速离开功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
Startup-query
是否处于启动查询状态:
·     On:表示处于启动查询状态
·     Off:表示未处于启动查询状态
IGMP其它查询器的存在超时时间,Off表示该定时器关闭
此接口上动态加入的组播组数量。没有加入组时不显示本字段
IGMP代理功能已开启
IGMP主机行为功能已开启。
IGMPv1查询器的存在超时时间,如果查询器关闭则显示为Off
display igmp proxy group命令用来显示IGMP代理记录的组播组信息。
display igmp [ vpn-instance vpn-instance-name ] proxy group [ group-address | interface interface-type interface-number ] [ verbose ]
interface interface-type interface-number:显示指定接口上的信息。如果未指定本参数,将显示所有接口上的信息。
verbose:显示详细信息。
# 显示公网实例中IGMP代理记录的所有组播组信息。
<Sysname> display igmp proxy group
IGMP proxy group records in total: 2
 GigabitEthernet3/1/1(1.1.1.20):
   Group address      Member state      Expires
   225.1.1.1          Delay             00:00:02
   225.1.1.2          Idle              Off
# 显示公网实例中IGMP代理记录的组播组225.1.1.1的详细信息。
<Sysname> display igmp proxy group 225.1.1.1 verbose
   Group: 225.1.1.1
     Group mode: Include
     Member state: Delay
     Expires: 00:00:02
       1.1.1.1
表1-8 display igmp proxy group命令显示信息描述表
IGMP代理记录的组播组总数
IGMP代理接口的名称和IP地址
Pending proxy group
等待生效的代理组
Group address/Group
组播组地址
Member state
组播组成员的状态,其中:
·     Delay:表示加入了一个组,并对该组启动了延迟发送报告报文的定时器
·     Idle:表示加入了一个组,但对该组尚未启动延迟发送报告报文的定时器
Expires
组播组延迟发送报告报文的时间,Off表示该定时器关闭
Group mode
对组播源的过滤模式,其中:
Source list
IGMP代理的组播组所包含的组播源列表
sources in total
组播源的总数
display igmp proxy routing-table命令用来显示IGMP代理路由表的信息。
display igmp [ vpn-instance vpn-instance-name ] proxy routing-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] ] * [ verbose ]
source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
mask-length:指定组播组或组播源地址的掩码长度。对于组播源地址,其取值范围为0~32,缺省值为32;对于组播组地址,其取值范围为4~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
verbose:显示详细信息。
# 显示公网实例IGMP代理路由表的信息。
<Sysname> display igmp proxy routing-table
 Total 1 (*, G) entries, 2 (S, G) entries.
 (172.168.0.12, 227.0.0.1)
     Upstream interface: GigabitEthernet3/1/1
     Downstream interfaces (1 in total):
         1: GigabitEthernet3/1/2
             Protocol: IGMP
 (*, 225.1.1.1)
             Protocol: STATIC
 (2.2.2.2, 225.1.1.1)
     Downstream interfaces (2 in total):
         1: LoopBack1
             Protocol: STATIC
         2: GigabitEthernet3/1/2
             Protocol: PROXY
# 显示公网实例IGMP代理路由表的详细信息。
<Sysname> display igmp proxy routing-table verbose
             Protocol: IGMP
             Querier state: Querier
             Join/Prune state:Join
     Non-downstream interfaces: None
 (*, 225.1.1.1)
             Protocol: STATIC
     Non-downstream interfaces (1 in total):
         1: GigabitEthernet3/1/3
             Protocol: IGMP
             Querier state: Non-querier
         1: LoopBack1
             Protocol: STATIC
             Join/Prune state: Join
             Protocol: PROXY
表1-9 display igmp proxy routing-table命令显示信息描述表
(S,G)表项和(*,G)表项的总数
(S,G)表项
Upstream interface
表项的入接口
下游的出接口信息及总数
下游的非出接口信息及总数
接口的索引号及接口名称
Protocol
接口使用的协议类型:
·     IGMP:表示动态IGMP
·     PROXY:表示IGMP代理
·     STATIC:表示静态IGMP
Querier state
接口的查询器状态:
·     Querier:表示接口为IGMP查询器
·     Non-querier:表示接口不是IGMP查询器
Join/Prune state
接口的加入/剪枝状态:
·     NI:表示默认状态
·     Join:表示处于IGMP加入的状态
·     Prune:表示处于IGMP剪枝的状态
display igmp ssm-mapping命令用来显示IGMP SSM Mapping规则。
display igmp [ vpn-instance vpn-instance-name ] ssm-mapping group-address
# 显示公网实例中组播组232.1.1.1对应的IGMP SSM Mapping规则。
<Sysname> display igmp ssm-mapping 232.1.1.1
 Group: 232.1.1.1
 Source list:
        1.2.3.4
        5.5.5.5
        10.1.1.1
        100.1.1.10
表1-10 display igmp ssm-mapping命令显示信息描述表
Group
组播组地址
Source list
组播源地址列表
host-tracking enable命令用来全局开启IGMP主机跟踪功能。
undo host-tracking enable命令用来全局关闭IGMP主机跟踪功能。
全局IGMP主机跟踪功能处于关闭状态。
IGMP视图
通过开启IGMP主机跟踪功能,可以使设备能够记录正在接收组播数据的成员主机信息(包括主机的IP地址、运行时间和超时时间等),以便于网络管理员对这些主机进行监控和管理。
使用本命令可以在全局开启IGMP主机跟踪功能。使用igmp host-tracking enable命令在接口视图下开启IGMP主机跟踪功能。接口下的配置仅对当前接口生效,全局配置对所有接口生效,接口下的配置优先于全局配置。
# 在公网实例中全局开启IGMP主机跟踪功能。
[Sysname] igmp
[Sysname-igmp] host-tracking enable
# 在VPN实例mvpn中全局开启主机跟踪功能。
[Sysname] igmp vpn-instance mvpn
[Sysname-igmp-mvpn] host-tracking enable
1.1.10  igmp
igmp命令用来进入IGMP视图。
undo igmp命令用来清除IGMP视图下的所有配置。
undo igmp [ vpn-instance vpn-instance-name ]
# 进入公网实例的IGMP视图。
[Sysname] igmp
[Sysname-igmp]
# 进入VPN实例mvpn的IGMP视图。
[Sysname-igmp-mvpn]
igmp attack-suppression per-interface aging-time命令用来配置基于接口的IGMP攻击检测表项老化时间。
undo igmp attack-suppression per-interface aging-time命令用来恢复缺省情况。
igmp attack-suppression per-interface aging-time time
基于接口的IGMP攻击检测表项老化时间为30秒。
time:基于接口的IGMP攻击检测表项老化时间,取值范围为1~65535,单位为秒。
当某个接口上的IGMP攻击检测表项到达老化时间后,设备会检测该表项对应的IGMP报文是否为攻击报文:
·     如果是攻击报文,则继续对接口上的IGMP报文限速。
·     如果不是攻击报文,则解除该接口上的IGMP报文限速。该表项老化后,设备会重新统计该接口上对应的IGMP报文数,根据配置的IGMP攻击检测周期和阈值,再次判断该接口上的IGMP报文是否为攻击报文。
只有配置igmp attack-suppression per-interface enable命令开启了基于接口的IGMP攻击抑制功能,本功能才生效。
多次执行本命令,最后一次执行的命令生效。
# 配置基于接口的IGMP攻击检测表项老化时间为60秒。
[Sysname] igmp attack-suppression per-interface aging-time 60
igmp attack-suppression per-interface check-interval命令用来配置基于接口的IGMP攻击检测周期。
undo igmp attack-suppression per-interface check-interval命令用来恢复缺省情况。
igmp attack-suppression per-interface check-interval interval
基于接口的IGMP攻击检测周期为30秒。
interval:基于接口的IGMP攻击检测周期,取值范围为1~255,单位为秒。
# 配置基于接口的IGMP攻击检测周期为10秒。
[Sysname] igmp attack-suppression per-interface check-interval 10
igmp attack-suppression per-interface enable命令用来使能基于接口的IGMP攻击抑制功能。
undo igmp attack-suppression per-interface enable命令用来关闭基于接口的IGMP攻击抑制功能。
基于接口的IGMP攻击抑制功能处于关闭状态。
配置基于接口的IGMP攻击抑制功能后,设备会在对应接口下统计收到的IGMP报文数,并创建攻击检测表项。当设备在指定的IGMP攻击检测周期内,在某个接口下收到的IGMP报文数超过配置的攻击抑制阈值,则认为该接口受到IGMP报文的攻击,此时设备会限制该接口的IGMP报文上送CPU的速率。
在全局使能IGMP Snooping的情况下,仅对三层以太网接口和以太网子接口生效,此时VLAN接口和二层接口(例如二层聚合接口)收到IGMP报文后,会由二层组播进行处理,三层组播的IGMP攻击抑制功能不再生效。
# 开启基于接口的IGMP攻击抑制功能。
[Sysname] igmp attack-suppression per-interface enable
igmp attack-suppression per-interface threshold命令用来配置基于接口的IGMP攻击抑制阈值。
undo igmp attack-suppression per-interface threshold命令用来恢复缺省情况。
igmp attack-suppression per-interface threshold threshold-value
基于接口的IGMP攻击抑制阈值为6000。
threshold-value:基于接口的IGMP攻击抑制阈值,即攻击检测周期内可接收的IGMP报文最大个数,取值范围为1~4294967295。
在指定攻击检测周期内,如果某个接口下收到的IGMP报文数量超过配置的攻击抑制阈值,则认为该接口受到了攻击。
# 配置基于接口的IGMP攻击抑制阈值为300。
[Sysname] igmp attack-suppression per-interface threshold 300
1.1.15  igmp enable
igmp enable命令用来在接口上使能IGMP。
undo igmp enable命令用来在接口上关闭IGMP。
igmp enable
undo igmp enable
接口上的IGMP处于关闭状态。
只有在相应实例中先使能了IP组播路由,本命令才能生效。
只有在接口上使能了IGMP,在该接口上所做的IGMP配置才能生效。
# 使能公网实例中的IP组播路由,并在接口GigabitEthernet3/1/1上使能IGMP。
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] igmp enable
·     multicast routing(IP组播命令参考/组播路由与转发)
igmp fast-leave命令用来在接口上开启组播组成员快速离开功能。
undo igmp fast-leave命令用来在接口上关闭组播组成员快速离开功能。
igmp fast-leave [ group-policy ipv4-acl-number ]
组播组成员快速离开功能处于关闭状态,即IGMP查询器在收到主机发送的IGMP离开组报文后将发送IGMP特定组查询报文或IGMP特定源组查询报文,而不会直接向上游发送离开通告。
ipv4-acl-number:指定IPv4基本ACL的编号,取值范围为2000~2999。如果指定了本参数,快速离开功能将只为该ACL规则所允许的组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则快速离开功能将为所有组播组服务。
开启了组播组成员快速离开功能之后,当IGMP查询器收到来自主机的离开组报文时,不再发送IGMP特定组查询报文或IGMP特定源组查询报文。
对于IPv4基本ACL,该ACL规则中的source参数用来指定组播组的范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
若ACL中指定了vpn-instance参数则该条规则不生效。
# 在接口GigabitEthernet3/1/1上开启组播组成员快速离开功能。
[Sysname-GigabitEthernet3/1/1] igmp fast-leave
igmp group-policy命令用来在接口上配置组播组过滤器,以限定该接口下的主机所能加入的组播组。
undo igmp group-policy命令用来在接口上删除组播组过滤器。
igmp group-policy ipv4-acl-number [ version-number ]
接口上不存在组播组过滤器,即该接口下的主机可以加入任意组播组。
ipv4-acl-number:指定IPv4基本或高级ACL的编号,取值范围为2000~3999。主机只能加入该ACL规则所允许的组播组。当指定的ACL不存在或ACL中未配置有效规则,将过滤掉所有组播组。
version-number:指定IGMP的版本号,取值范围为1~3。缺省情况下,系统同时支持对IGMPv1、IGMPv2和IGMPv3报告报文的过滤。
由于本命令只能过滤IGMP报文,因此无法对接口静态加入组播组或组播源组进行限制。
对于IPv4基本ACL,该ACL规则中的source参数用来指定IGMP报文中的组播组地址范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
对于IPv4高级ACL,该ACL规则中的source参数用来指定IGMP报文中的组播源地址(对于IGMPv1/v2报文和未携带组播源地址的IS_EX/TO_EX类型的IGMPv3报文,视其组播源地址为0.0.0.0)范围,destination参数用来指定组播组地址范围,并且该规则中除source、destination、fragment和time-range以外的其它可选参数都将被忽略。
# 限定接口GigabitEthernet3/1/1下的主机只能加入组播组225.1.1.1。
[Sysname] acl basic 2005
[Sysname-acl-ipv4-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-ipv4-basic-2005] quit
[Sysname-GigabitEthernet3/1/1] igmp group-policy 2005
igmp host-tracking enable命令用来在接口上开启IGMP主机跟踪功能。
igmp host-tracking disable命令用来在接口上关闭IGMP主机跟踪功能。
undo igmp host-tracking命令用来恢复缺省情况。
接口视图下IGMP主机跟踪功能状态与全局保持一致。
使用本命令可以在接口上开启IGMP主机跟踪功能;使用host-tracking enable命令在全局开启IGMP主机跟踪功能。接口下的配置仅对当前接口生效,全局配置对所有接口生效,接口下的配置优先于全局配置。
# 在接口GigabitEthernet3/1/1上开启IGMP主机跟踪功能。
[Sysname-GigabitEthernet3/1/1] igmp host-tracking enable
·     host-tracking enable (IGMP view)
igmp host-tracking limit命令用来配置接口上可跟踪的最大IGMP主机数。
undo igmp host-tracking limit命令用来恢复缺省情况。
igmp host-tracking limit limit
接口上可跟踪的最大IGMP主机数为4096。
limit:接口上可跟踪的最大IGMP主机数,取值范围为1~65535。
多次执行本命令,最后一次执行的命令生效。当接口可跟踪的主机数量达到最大值后,设备将会重新开始记录,并覆盖之前的记录信息。
# 配置接口GigabitEthernet3/1/1可跟踪最大IGMP主机数为2000。
[Sysname-GigabitEthernet 3/1/1] igmp host-tracking limit 2000
igmp join-by-session命令用来配置按会话记录用户加入的组播组。
undo igmp join-by-session命令用来恢复缺省情况。
按接口记录用户加入的组播组。
三层以太网接口视图/三层以太网子接口视图
三层聚合接口视图/三层聚合子接口视图
当按接口记录用户加入的组播组时,设备只会向物理接口发送一份组播报文;当按会话记录用户加入的组播组时,设备会向接口下的每位用户分别发送一份组播报文。
# 在接口GigabitEthernet3/1/1上配置所有类型的用户均按会话记录加入的组播组。
[Sysname-GigabitEthernet3/1/1] igmp join-by-session
igmp last-member-query-count命令用来在接口上配置IGMP最后组成员查询次数。
undo igmp last-member-query-count命令用来恢复缺省情况。
igmp last-member-query-count count
IGMP最后组成员查询次数等于IGMP查询器的健壮系数。
count:指定IGMP最后组成员查询次数,取值范围为1~255。
本命令与last-member-query-count命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP最后组成员查询次数为6次。
[Sysname-GigabitEthernet3/1/1] igmp last-member-query-count 6
·     last-member-query-count (IGMP view)
igmp last-member-query-interval命令用来在接口上配置IGMP最后组成员查询间隔。
undo igmp last-member-query-interval命令用来恢复缺省情况。
igmp last-member-query-interval interval
IGMP最后组成员查询间隔为1秒。
interval:指定IGMP最后组成员的查询间隔,取值范围为1~25,单位为秒。
本命令与last-member-query-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP最后组成员查询间隔为6秒。
[Sysname-GigabitEthernet3/1/1] igmp last-member-query-interval 6
·     last-member-query-interval (IGMP view)
igmp max-response-time命令用来在接口上配置IGMP普遍组查询报文的最大响应时间。
undo igmp max-response-time命令用来恢复缺省情况。
igmp max-response-time time
IGMP普遍组查询报文的最大响应时间为10秒。
time:指定IGMP普遍组查询报文的最大响应时间,取值范围为1~3174,单位为秒。
本命令与max-response-time命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP普遍组查询报文的最大响应时间为25秒。
[Sysname-GigabitEthernet3/1/1] igmp max-response-time 25
·     max-response-time (IGMP view)
igmp non-stop-routing命令用来开启IGMP协议的NSR功能。
undo igmp non-stop-routing命令用来关闭IGMP协议的NSR功能。
IGMP协议的NSR功能处于关闭状态。
# 开启IGMP协议的NSR功能。
[Sysname] igmp non-stop-routing
igmp other-querier-present-interval命令用来在接口上配置IGMP其它查询器的存在时间。
undo igmp other-querier-present-interval命令用来恢复缺省情况。
igmp other-querier-present-interval interval
IGMP其它查询器的存在时间=IGMP普遍组查询报文的发送间隔×IGMP查询器的健壮系数+IGMP普遍组查询的最大响应时间÷2。
interval:指定IGMP其它查询器的存在时间,取值范围为1~31744,单位为秒。
本命令与other-querier-present-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP其它查询器的存在时间为125秒。
[Sysname-GigabitEthernet3/1/1] igmp other-querier-present-interval 125
·     other-querier-present-interval (IGMP view)
igmp proxy enable命令用来在接口上开启IGMP代理功能。
undo igmp proxy enable命令用来关闭接口上的IGMP代理功能。
igmp proxy enable
接口上的IGMP代理功能处于关闭状态。
只有在公网或VPN实例中先使能了IP组播路由,本命令才能生效。
# 使能公网实例中的IP组播路由,并在接口GigabitEthernet3/1/1上开启IGMP代理功能。
[Sysname-mrib] quit
[Sysname-GigabitEthernet3/1/1] igmp proxy enable
igmp proxy forwarding命令用来开启非查询器转发功能。
undo igmp proxy forwarding命令用来关闭非查询器转发功能。
非查询器转发功能处于关闭状态。
组播数据通常只被查询器转发,非查询器不具备组播转发能力,这样可避免组播数据被重复转发。但如果IGMP代理设备的路由器接口未能当选查询器,应在该接口上开启非查询器转发功能,否则下游主机将无法收到组播数据。
# 在IGMP代理设备的路由器接口GigabitEthernet3/1/1上开启非查询器转发功能。
[Sysname-GigabitEthernet3/1/1] igmp proxy forwarding
igmp query-interval命令用来在接口上配置IGMP普遍组查询报文的发送间隔。
undo igmp query-interval命令用来恢复缺省情况。
igmp query-interval interval
IGMP普遍组查询报文的发送间隔为125秒。
interval:指定IGMP普遍组查询报文的发送间隔,取值范围为1~31744,单位为秒。
本命令与query-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP普遍组查询报文的发送间隔为60秒。
[Sysname-GigabitEthernet3/1/1] igmp query-interval 60
·     query-interval (IGMP view)
igmp robust-count命令用来在接口上配置IGMP查询器的健壮系数。
undo igmp robust-count命令用来恢复缺省情况。
igmp robust-count count
IGMP查询器的健壮系数为2。
count:指定IGMP查询器的健壮系数,取值范围为1~255。
IGMP查询器的健壮系数是为了弥补可能发生的网络丢包而设置的报文重传次数,健壮系数越大,IGMP查询器就越“健壮”,但是组播组超时所需的时间也就越长。
本命令与robust-count命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP查询器的健壮系数为5。
[Sysname-GigabitEthernet3/1/1] igmp robust-count 5
·     robust-count (IGMP view)
igmp startup-query-count命令用来在接口上配置IGMP查询器的启动查询次数。
undo igmp startup-query-count命令用来恢复缺省情况。
igmp startup-query-count count
IGMP查询器的启动查询次数等于IGMP查询器的健壮系数。
count:指定IGMP查询器的启动查询次数,取值范围为1~255。
本命令与startup-query-count命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP查询器的启动查询次数为5次。
[Sysname-GigabitEthernet3/1/1] igmp startup-query-count 5
·     startup-query-count (IGMP view)
igmp startup-query-interval命令用来在接口上配置IGMP查询器的启动查询间隔。
undo igmp startup-query-interval命令用来恢复缺省情况。
igmp startup-query-interval interval
IGMP查询器的启动查询间隔为IGMP普遍组查询报文发送间隔的1/4。
interval:指定IGMP查询器的启动查询间隔,取值范围为1~31744,单位为秒。
本命令与startup-query-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置IGMP查询器的启动查询间隔为100秒。
[Sysname-GigabitEthernet3/1/1] igmp startup-query-interval 100
·     startup-query-interval (IGMP view)
igmp static-group命令用来配置接口静态加入组播组或组播源组。
undo igmp static-group命令用来恢复缺省情况。
igmp static-group group-address [ source source-address ]
undo igmp static-group { all | group-address [ source source-address ] }
接口没有以静态方式加入组播组或组播源组。
group-address:指定组播组地址,取值范围为224.0.1.0~239.255.255.255。
source-address:指定组播源的地址。如果未指定本参数,表示针对所有组播源。
all:删除此接口加入的所有静态组播组。
如果指定的组播组地址在SSM组地址范围内,则必须同时指定组播源的地址,否则将不会生成组播路由表项用于指导组播转发;如果指定的组播组地址不在SSM组地址范围内,则无此限制。
# 配置接口GigabitEthernet3/1/1静态加入组播组224.1.1.1。
[Sysname-GigabitEthernet3/1/1] igmp static-group 224.1.1.1
# 配置接口GigabitEthernet3/1/1静态加入组播源组(192.168.1.1,232.1.1.1)。
[Sysname-GigabitEthernet3/1/1] igmp static-group 232.1.1.1 source 192.168.1.1
1.1.33  igmp version
igmp version命令用来在接口上配置IGMP的版本。
undo igmp version命令用来恢复缺省情况。
igmp version version-number
undo igmp version
IGMP的版本为IGMPv2。
version-number:表示IGMP的版本号,取值范围为1~3。
由于不同版本IGMP协议的报文结构与种类不同,因此需要为同一网段上的所有设备配置相同版本的IGMP,否则IGMP将不能正常运行。
# 指定接口GigabitEthernet3/1/1使用IGMPv1。
[Sysname-GigabitEthernet3/1/1] igmp version 1
last-member-query-count命令用来全局配置IGMP最后组成员查询次数。
undo last-member-query-count命令用来恢复缺省情况。
IGMP视图
本命令与igmp last-member-query-count命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP最后组成员查询次数为6次。
[Sysname] igmp
[Sysname-igmp] last-member-query-count 6
·     igmp last-member-query-count
last-member-query-interval命令用来全局配置IGMP最后组成员查询间隔。
undo last-member-query-interval命令用来恢复缺省情况。
IGMP最后组成员查询间隔为1秒。
IGMP视图
本命令与igmp last-member-query-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP最后组成员查询间隔为6秒。
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 6
·     igmp last-member-query-interval
max-response-time命令用来全局配置IGMP普遍组查询报文的最大响应时间。
undo max-response-time命令用来恢复缺省情况。
IGMP视图
本命令与igmp max-response-time命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP普遍组查询报文的最大响应时间为25秒。
[Sysname] igmp
[Sysname-igmp] max-response-time 25
·     igmp max-response-time
other-querier-present-interval命令用来全局配置IGMP其它查询器的存在时间。
undo other-querier-present-interval命令用来恢复缺省情况。
IGMP视图
本命令与igmp other-querier-present-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP其它查询器的存在时间为125秒。
[Sysname] igmp
[Sysname-igmp] other-querier-present-interval 125
·     igmp other-querier-present-interval
proxy multipath命令用来开启IGMP代理的负载分担功能。
undo proxy multipath命令用来关闭IGMP代理的负载分担功能。
proxy multipath
IGMP代理的负载分担功能处于关闭状态。
IGMP视图
当在IGMP代理设备的多个接口上开启了IGMP代理功能时:如果关闭了IGMP代理的负载分担功能,则只有IP地址最大的接口会转发组播流量;如果开启了IGMP代理的负载分担功能,则可通过这些接口对组播流量按组进行负载分担。
# 在公网实例中开启IGMP代理的负载分担功能。
[Sysname] igmp
[Sysname-igmp] proxy multipath
query-interval命令用来全局配置IGMP普遍组查询报文的发送间隔。
undo query-interval命令用来恢复缺省情况。
undo query-interval
IGMP视图
本命令与igmp query-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP普遍组查询报文的时间间隔为60秒。
[Sysname] igmp
[Sysname-igmp] query-interval 60
·     igmp query-interval
reset igmp attack-suppression per-interface entry命令用来清除基于接口的IGMP攻击检测表项。
(独立运行模式)
reset igmp attack-suppression per-interface entry { all | slot slot-number { all | interface interface-type interface-number  } }
reset igmp attack-suppression per-interface entry { all | chassis chassis-number slot slot-number { all | interface interface-type interface-number } }
all:前一个all表示清除所有单板上基于接口的IGMP攻击检测表项。后一个all表示清除指定单板所有基于接口的IGMP攻击检测表项。(独立运行模式)
all:前一个all表示清除所有成员设备上基于接口的IGMP攻击检测表项。后一个all表示清除指定单板所有基于接口的IGMP攻击检测表项。(IRF模式)
slot slot-number:清除指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
interface interface-type interface-number:清除指定接口上的IGMP攻击检测表项,interface-type interface-number表示接口类型和接口编号。
# 清除所有基于接口的IGMP攻击检测表项。
<Sysname> reset igmp attack-suppression per-interface entry all
·     display igmp attack-suppression per-interface entry
reset igmp attack-suppression per-interface statistics命令用来清除基于接口的IGMP攻击检测相关的IGMP报文计数信息。
(独立运行模式)
reset igmp attack-suppression per-interface statistics { all | slot slot-number { all | interface interface-type interface-number } }
reset igmp attack-suppression per-interface statistics { all | chassis chassis-number slot slot-number { all | interface interface-type interface-number } }
all:前一个all表示清除所有单板上基于接口的IGMP攻击检测相关的IGMP报文计数信息。后一个all表示清除指定单板所有基于接口的IGMP攻击检测相关的IGMP报文计数信息。(独立运行模式)
all:前一个all表示清除所有成员设备上基于接口的IGMP攻击检测相关的IGMP报文计数信息。后一个all表示清除指定单板所有基于接口的IGMP攻击检测相关的IGMP报文计数信息。(IRF模式)
interface interface-type interface-number:清除指定接口上的IGMP攻击检测相关的IGMP报文计数信息,interface-type interface-number表示接口类型和接口编号。
本命令清除的统计信息为display igmp attack-suppression per-interface entry verbose中的如下字段:CPU receive(CPU收到的报文数)、CPU drop(CPU丢弃的报文数)和Drv drop(驱动丢弃的报文数)。
# 清除所有基于接口的IGMP攻击检测相关的IGMP报文计数信息。
<Sysname> reset igmp attack-suppression per-interface statistics all
reset igmp group命令用来清除IGMP组播组的动态加入记录。
reset igmp [ vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
vpn-instance vpn-instance-name:清除指定VPN实例的记录,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的记录。
all:前一个all表示清除所有接口上的记录,后一个all表示清除指定接口上所有组播组的记录。
interface-type interface-number:清除指定接口上的记录。
group-address:清除指定组播组的记录,取值范围为224.0.1.0~239.255.255.255。
source-address:清除指定组播源的记录。如果未指定本参数,将清除所有组播源的记录。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
执行本命令可能导致接收者中断组播信息的接收。
# 清除公网实例所有接口上IGMP组播组的动态加入记录。
<Sysname> reset igmp group all
# 清除公网实例接口GigabitEthernet3/1/1上所有IGMP组播组的动态加入记录。
<Sysname> reset igmp group interface gigabitethernet 3/1/1 all
# 清除公网实例接口GigabitEthernet3/1/1上IGMP组播组225.0.0.1的动态加入记录。
<Sysname> reset igmp group interface gigabitethernet 3/1/1 225.0.0.1
·     display igmp group
robust-count命令用来全局配置IGMP查询器的健壮系数。
undo robust-count命令用来恢复缺省情况。
robust-count count
undo robust-count
IGMP查询器的健壮系数为2。
IGMP视图
本命令与igmp robust-count命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP查询器的健壮系数为5。
[Sysname] igmp
[Sysname-igmp] robust-count 5
·     igmp robust-count
ssm-mapping命令用来配置IGMP SSM Mapping规则。
undo ssm-mapping命令用来删除IGMP SSM Mapping规则。
ssm-mapping source-address ipv4-acl-number
undo ssm-mapping { source-address | all }
不存在IGMP SSM Mapping规则。
IGMP视图
source-address:指定组播源地址。
ipv4-acl-number:指定IPv4基本ACL的编号,取值范围为2000~2999。通过该ACL规则中的permit语句指定组播组的范围。当指定的ACL不存在或ACL中未配置有效规则,则表示未指定任何组播组。
all:删除所有的IGMP SSM Mapping规则。
# 在公网实例中添加如下一条IGMP SSM Mapping规则:组地址范围为232.1.1.0/24,对应的源地址为125.1.1.1。
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 232.1.1.1 0.0.0.255
[Sysname] igmp
[Sysname-igmp] ssm-mapping 125.1.1.1 2001
·     display igmp ssm-mapping
startup-query-count命令用来全局配置IGMP查询器的启动查询次数。
undo startup-query-count命令用来恢复缺省情况。
IGMP视图
本命令与igmp startup-query-count命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP查询器的启动查询次数为5次。
[Sysname] igmp
[Sysname-igmp] startup-query-count 5
·     igmp startup-query-count
startup-query-interval命令用来全局配置IGMP查询器的启动查询间隔。
undo startup-query-interval命令用来恢复缺省情况。
IGMP视图
本命令与igmp startup-query-interval命令的功能相同,只是作用范围不同:IGMP视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置IGMP查询器的启动查询间隔为100秒。
[Sysname] igmp
[Sysname-igmp] startup-query-interval 100
·     igmp startup-query-interval
