H3C S3610[S5510]系列以太网交换机命令手册-RELEASE 0001(V1.03)
17-DHCP命令
本章节下载  (383.54 KB)
17-DHCP命令
第1章 DHCP服务器配置命令
1.1 DHCP服务器配置命令
1.1.1 bims-server
1.1.2 bootfile-name
1.1.3 dhcp enable
1.1.4 dhcp select server global-pool
1.1.5 dhcp server detect
1.1.6 dhcp server forbidden-ip
1.1.7 dhcp server ip-pool
1.1.8 dhcp server ping packets
1.1.9 dhcp server ping timeout
1.1.10 dhcp server relay information enable
1.1.11 display dhcp server conflict
1.1.12 display dhcp server expired
1.1.13 display dhcp server free-ip
1.1.14 display dhcp server ip-in-use
1.1.15 display dhcp server statistics
1.1.16 display dhcp server tree
1.1.17 dns-list
1.1.18 domain-name
1.1.19 expired
1.1.20 gateway-list
1.1.21 nbns-list
1.1.22 netbios-type
1.1.23 network
1.1.24 option
1.1.25 reset dhcp server conflict
1.1.26 reset dhcp server ip-in-use
1.1.27 reset dhcp server statistics
1.1.28 static-bind client-identifier
1.1.29 static-bind ip-address
1.1.30 static-bind mac-address
1.1.31 tftp-server domain-name
1.1.32 tftp-server ip-address
1.1.33 voice-config
第2章 DHCP中继配置命令
2.1 DHCP中继配置命令
2.1.1 dhcp enable
2.1.2 dhcp relay address-check
2.1.3 dhcp relay information enable
2.1.4 dhcp relay information format
2.1.5 dhcp relay information strategy
2.1.6 dhcp relay release
2.1.7 dhcp relay security static
2.1.8 dhcp relay security tracker
2.1.9 dhcp relay server-detect
2.1.10 dhcp relay server-group
2.1.11 dhcp relay server-select
2.1.12 dhcp select relay
2.1.13 display dhcp relay
2.1.14 display dhcp relay security
2.1.15 display dhcp relay security statistics
2.1.16 display dhcp relay security tracker
2.1.17 display dhcp relay server-group
2.1.18 display dhcp relay statistics
2.1.19 reset dhcp relay statistics
第3章 DHCP Snooping配置命令
3.1 DHCP Snooping配置命令
3.1.1 dhcp-snooping
3.1.2 dhcp-snooping trust
3.1.3 display dhcp-snooping
3.1.4 display dhcp-snooping trust
第4章 DHCP客户端配置命令
4.1 DHCP客户端配置命令
4.1.1 display dhcp client
4.1.2 ip address dhcp-alloc
第5章 BOOTP客户端配置命令
5.1 BOOTP客户端配置命令
5.1.1 display bootp client
5.1.2 ip address bootp-alloc
第1章  DHCP服务器配置命令
&  说明:
l      DHCP服务器中对于接口的相关配置,目前只能在VLAN接口上进行。
l      DHCP服务器上不能配置DHCP Snooping功能。
1.1  DHCP服务器配置命令
1.1.1  bims-server
bims-server ip ip-address [ port port-number ] sharekey key
undo bims-server
DHCP地址池视图
ip ip-address:BIMS服务器的IP地址。
port port-number:BIMS服务器的端口号,取值范围为1~65534。
sharekey key:BIMS服务器的共享密钥,为1~16个字符的字符串。
【描述】
bims-server命令用来配置DHCP地址池为DHCP客户端分配的BIMS服务器IP地址、端口及共享密钥信息。undo bims-server命令用来删除DHCP地址池为DHCP客户端分配的BIMS服务器信息。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的BIMS服务器信息。
如果多次执行该命令,新的配置会覆盖已有配置。
相关配置可参考命令dhcp server ip-pool。
# 配置DHCP地址池0为DHCP客户端分配的BIMS服务器的IP地址为1.1.1.1,端口号为80,共享密钥为aabbcc。
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey aabbcc
1.1.2  bootfile-name
bootfile-name bootfile-name
undo bootfile-name
DHCP地址池视图
bootfile-name:启动文件名,为1~63个字符的字符串。
【描述】
bootfile-name命令用来配置DHCP地址池为DHCP客户端分配的启动文件名。undo bootfile-name命令用来删除DHCP地址池为DHCP客户端分配的启动文件名。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的启动文件名。
# 配置DHCP地址池0为DHCP客户端分配的启动文件名为aaa。
[Sysname-dhcp-pool-0] bootfile-name aaa
1.1.3  dhcp enable
dhcp enable
undo dhcp enable
无
【描述】
dhcp enable命令用来使能DHCP服务。undo dhcp enable命令用来禁止DHCP服务。
缺省情况下,DHCP服务处于禁止状态。
&  说明:
只有使能DHCP服务后,其它相关的DHCP配置才能生效。该配置对于DHCP服务器和DHCP中继都是必需的。
# 使能DHCP服务。
[Sysname] dhcp enable
dhcp select server global-pool [ subaddress ]
undo dhcp select server global-pool subaddress
VLAN接口视图
subaddress:支持从地址分配。即DHCP服务器与客户端在同一网段,当DHCP服务器为客户端分配IP地址时,从与服务器接口(与客户端相连的接口)的从IP地址在同一网段的地址池中选择地址分配给客户端。如果接口有多个从IP地址,则从第一个从IP地址开始依次匹配。
【描述】
dhcp select server global-pool命令用来配置接口工作在DHCP服务器模式,即当接口收到DHCP客户端发来的DHCP报文时,将从DHCP服务器的地址池中分配地址。undo dhcp select server global-pool subaddress命令用来取消对从地址分配的支持。
缺省情况下,接口工作在DHCP服务器模式。
# 配置VLAN接口1工作在DHCP服务器模式。
[Sysname-Vlan-interface1] dhcp select server global-pool
dhcp server detect
undo dhcp server detect
无
【描述】
dhcp server detect命令用来使能伪DHCP服务器检测功能。undo dhcp server detect命令用来禁止伪DHCP服务器检测功能。
缺省情况下,禁止伪DHCP服务器检测功能。
# 启动伪DHCP服务器检测功能。
[Sysname] dhcp server detect
dhcp server forbidden-ip low-ip-address [ high-ip-address ]
undo dhcp server forbidden-ip low-ip-address [ high-ip-address ]
low-ip-address:不参与自动分配的最小IP地址。
high-ip-address:不参与自动分配的最大IP地址,不能小于low-ip-address。如果不指定该参数,表示只有一个IP地址,即low-ip-address。
【描述】
dhcp server forbidden-ip命令用来配置DHCP地址池中不参与自动分配的IP地址。undo dhcp server forbidden-ip命令用来取消DHCP地址池中不参与自动分配的IP地址的配置。
缺省情况下,DHCP地址池中的所有IP地址都参与自动分配。
需要注意的是,如果通过dhcp server forbidden-ip将已经静态绑定的IP地址配置为不参与自动分配的地址,则该地址仍然可以分配给静态绑定的用户。
相关配置可参考命令dhcp server ip-pool,network和static-bind ip-address。
# 将10.110.1.1到10.110.1.63之间的IP地址保留,不参与地址自动分配。
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
pool-name:DHCP地址池名称,是地址池的唯一标识,为1~35个字符的字符串。
【描述】
dhcp server ip-pool命令用来创建DHCP地址池并进入DHCP地址池视图,如果已经创建了DHCP地址池,则直接进入该地址池视图。undo dhcp server ip-pool命令用来删除指定的地址池。
缺省情况下,没有创建DHCP地址池。
相关配置可参考命令dhcp enable。
# 创建标识为0的DHCP地址池。
undo dhcp server ping packets
number:发送回显请求报文的最大数目,取值范围为0~10,0表示不进行ping操作。
【描述】
dhcp server ping packets命令用来配置DHCP服务器发送回显请求报文的最大数目。undo dhcp server ping packets命令用来恢复缺省情况。
缺省情况下,DHCP服务器发送回显请求报文的最大数目为1。
# 配置DHCP服务器最多发送10个回显请求报文。
[Sysname] dhcp server ping packets 10
undo dhcp server ping timeout
milliseconds:等待回显响应报文的超时时间,取值范围是0~10000,单位是毫秒,0表示不进行ping操作。
【描述】
dhcp server ping timeout命令用来配置DHCP服务器等待回显响应报文的超时时间。undo dhcp server ping timeout命令用来恢复缺省情况。
缺省情况下,DHCP服务器等待回显响应报文的超时时间为500毫秒。
# 配置DHCP服务器等待回显响应报文的超时时间为1000毫秒。
[Sysname] dhcp server ping timeout 1000
undo dhcp server relay information enable
无
【描述】
dhcp server relay information enable命令用来配置DHCP服务器支持Option 82功能。undo dhcp server relay information enable命令用来禁止DHCP服务器支持Option 82功能。
缺省情况下,DHCP服务器支持Option 82功能。
# 禁止DHCP服务器支持Option 82功能。
[Sysname] undo dhcp server relay information enable
display dhcp server conflict { all | ip ip-address }
all:所有IP地址。
ip-address:指定IP地址。
【描述】
display dhcp server conflict命令用来显示DHCP的地址冲突统计信息。
相关配置可参考命令reset dhcp server conflict。
# 显示DHCP的地址冲突统计信息。
<Sysname> display dhcp server conflict all
    Address             Discover time
    201.43.1.8          May  4 2000 10:50:31
 --- total 1 entry ---
表1-1 display dhcp server conflict命令显示信息描述表
Address
发生冲突的IP地址
Discover Time
检测到冲突的时间
display dhcp server expired { all | ip ip-address | pool [ pool-name ] }
all:显示所有DHCP地址池的租约超期信息。
ip ip-address:显示指定IP地址的租约超期信息。
pool [ pool-name ]:显示指定地址池的租约超期信息,pool-name为地址池名称,为1~35个字符的字符串。如不指定地址池的名称,则显示所有地址池的租约超期信息。
【描述】
display dhcp server expired命令用来显示DHCP地址池中的租约超期信息。在DHCP地址池的可用地址分配完后,这类租约超期的地址将被分配给DHCP客户端。
# 显示所有DHCP地址池中的租约超期信息。
<Sysname> display dhcp server expired all
 Global pool:
 IP address       Client-identifier/    Lease expiration          Type
                    Hardware address
 1.1.1.4        0001-0001-0003        Feb 21 2006 18:07:26      Release
 1.1.1.5        0001-0001-0004        Feb 21 2006 18:07:26      Release
 --- total 2 entry ---
表1-2 display dhcp server expired命令显示信息描述表
Global pool
地址池的超期租约信息
IP address
租约超期的IP地址
Client-identifier/Hardware address
租约超期的客户端ID或MAC地址
Lease expiration
租约超期的时间
租约超期的类型,目前取值只能为Release
无
【描述】
display dhcp server free-ip命令用来显示DHCP地址池的可用地址信息,即尚未分配的IP地址信息。
# 显示DHCP地址池的可用地址信息。
<Sysname> display dhcp server free-ip
IP Range from 10.0.0.0              to  10.0.0.255
display dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] }
all:显示所有DHCP地址池的地址绑定信息。
ip ip-address:显示指定IP地址的地址绑定信息。
pool [ pool-name ]:显示指定地址池的地址绑定信息,pool-name为地址池名称,为1~35个字符的字符串。如不指定地址池的名称,则显示所有地址池的地址绑定信息。
【描述】
display dhcp server ip-in-use命令用来显示DHCP地址池中的地址绑定信息。
相关配置可参考命令reset dhcp server ip-in-use。
# 显示所有DHCP地址池的地址绑定信息。
<Sysname> display dhcp server ip-in-use all
 Global pool:
                 Hardware address
 10.1.1.1      4444-4444-4444        NOT Used                  Manual
表1-3 display dhcp server ip-in-use命令显示信息描述表
Global pool
地址池的地址绑定信息
IP address
绑定的IP地址
绑定的客户端ID或MAC地址
Lease expiration
租约到期时间
地址绑定的类型,包括Manual、Auto:OFFERED和Auto:COMMITTED。其中,
l      Manual:手工绑定
l      Auto:OFFERED:DHCP服务器发送DHCP-OFFER报文所指定的临时绑定
l      Auto:COMMITTED:DHCP服务器发送DHCP-ACK报文所指定的绑定
无
【描述】
display dhcp server statistics命令用来显示DHCP服务器的统计信息。
相关配置可参考命令reset dhcp server statistics。
# 显示DHCP服务器的统计信息。
<Sysname> display dhcp server statistics
    Global Pool:
     Pool Number:            5
     Binding:
      Auto:              0
      Manual:                1
      Expire:                0
    BOOTP Request:           7
     DHCPDISCOVER:           1
     DHCPREQUEST:            4
     DHCPDECLINE:            0
     DHCPRELEASE:            1
     DHCPINFORM:         0
     BOOTPREQUEST:           1
    BOOTP Reply:         5
     DHCPOFFER:          1
     DHCPACK:                3
     DHCPNAK:                0
     BOOTPREPLY:         1
    Bad Messages:            0
表1-4 display dhcp server statistics命令显示信息描述表
Global Pool
地址池的统计信息
Pool Number
地址池的数目
Auto
自动绑定的IP地址数
Manual
手工绑定的IP地址数
Expire
租约超期的IP地址数
BOOTP Request:                         7
     DHCPDISCOVER:                  1
     DHCPREQUEST:                   4
     DHCPDECLINE:           0
     DHCPRELEASE:           1
     DHCPINFORM:              0
         BOOTPREQUEST              1
DHCP客户端发给DHCP服务器的报文数
BOOTP Reply:                              5
     DHCPOFFER:                         1
     DHCPACK:                     3
     DHCPNAK:                     0
         BOOTPREPLY                    1
DHCP服务器发给DHCP客户端的报文数
Bad Messages
错误的报文数
display dhcp server tree { all | pool [ pool-name ] }
all:显示所有DHCP地址池的树状结构信息。
pool [ pool-name ]:显示指定地址池的树状结构信息,pool-name为地址池名称,为1~35个字符的字符串。如果不指定地址池的名称,则显示所有地址池的树状结构信息。
【描述】
display dhcp server tree命令用来显示DHCP地址池的树状结构信息。
# 显示所有DHCP地址池的树状结构信息。
<Sysname> display dhcp server tree all
Global pool:
Pool name: 0
 network 20.1.1.0 mask 255.255.255.0
 Sibling node:1
 option 2 ip-address 1.1.1.1
 expired 1 0 0
Pool name: 1
 static-bind ip-address 10.10.1.2 mask 255.0.0.0
 static-bind mac-address 000f-e2fc-0001
PrevSibling node:0
 expired unlimited
表1-5 display dhcp server tree命令显示信息描述表
Global pool
地址池信息
Pool name
地址池的名称
network
可分配的地址范围
静态绑定的IP地址和MAC地址
Sibling node
此节点的下一个兄弟节点,在这一位置可能出现的节点类型包括:
l      Child node:此节点的子节点(子网)地址池
l      Parent node:此节点的父节点(自然网段)地址池
l      Sibling node:此节点的下一个兄弟节点(同一自然网段的其它子网)地址池。兄弟节点之间的顺序由配置的先后决定。
l      PrevSibling node:此节点的前一个兄弟节点
option
自定义的DHCP选项
expired
地址租约期限,包括天数、小时数、分钟数
1.1.17  dns-list
dns-list ip-address&<1-8>
undo dns-list { ip-address | all }
DHCP地址池视图
ip-address&<1-8>:DNS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
all:所有已配置的DNS服务器的IP地址。
【描述】
dns-list命令用来配置DHCP地址池为DHCP客户端分配的DNS服务器地址。undo dns-list命令用来删除DHCP地址池为DHCP客户端分配的DNS服务器地址。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的DNS服务器地址。
# 配置DHCP地址池0为DHCP客户端分配的DNS服务器地址为10.1.1.254。
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
1.1.18  domain-name
domain-name domain-name
undo domain-name
DHCP地址池视图
domain-name:DHCP客户端域名,为1~50个字符的字符串。
【描述】
domain-name命令用来配置DHCP地址池为DHCP客户端分配的域名。undo domain-name命令用来删除DHCP地址池为DHCP客户端分配的域名。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的域名。
# 配置DHCP地址池0为DHCP客户端分配的域名为mydomain.com。
[Sysname-dhcp-pool-0] domain-name mydomain.com
1.1.19  expired
expired { day day [ hour hour [ minute minute ] ] | unlimited }
undo expired
DHCP地址池视图
day day:天数,取值范围为0~365。
hour hour:小时数,取值范围为0~23。
minute minute:分钟数,取值范围为0~59。
unlimited:有效期限为无限长(实际上系统限定约为136年)。
【描述】
expired命令用来配置DHCP地址池中动态分配的IP地址的租用有效期限。undo expired命令用来恢复缺省情况。
缺省情况下,DHCP地址池中IP地址的租用有效期限为1天。
需要注意的是,如果租期的截止时间超过2106年,则系统就认为租约已过期。
# 配置地址池0的IP地址租用有效期为1天2小时3分。
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3
1.1.20  gateway-list
gateway-list ip-address&<1-8>
undo gateway-list { ip-address | all }
DHCP地址池视图
ip-address&<1-8>:网关的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
all:所有网关的IP地址。
【描述】
gateway-list命令用来配置DHCP地址池为DHCP客户端分配的网关地址。undo gateway-list命令用来删除DHCP地址池为DHCP客户端分配的网关地址。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的网关地址。
# 配置DHCP地址池0为DHCP客户端分配的网关地址为10.110.1.99。
[Sysname-dhcp-pool-0] gateway-list 10.110.1.99
1.1.21  nbns-list
nbns-list ip-address&<1-8>
undo nbns-list { ip-address | all }
DHCP地址池视图
ip-address&<1-8>:WINS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
all:所有已配置的WINS服务器的IP地址。
【描述】
nbns-list命令用来配置DHCP地址池为DHCP客户端分配的WINS服务器地址。undo nbns-list命令用来删除DHCP地址池为DHCP客户端分配的WINS服务器地址。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的WINS服务器地址。
相关配置可参考命令dhcp server ip-pool和netbios-type。
# 配置DHCP地址池0为DHCP客户端分配WINS服务器地址为10.12.1.99。
[Sysname-dhcp-pool-0] nbns-list 10.12.1.99
1.1.22  netbios-type
undo netbios-type
DHCP地址池视图
b-node:b类节点,采用广播方式获取主机名和IP地址之间的映射。
h-node:h类节点,是具备“端对端”通信机制的b类节点。
m-node:m类节点,是具有部分广播特性的p类节点。
p-node:p类节点,采用与WINS服务器通信的方式来获取映射关系。
【描述】
netbios-type命令用来配置DHCP地址池为DHCP客户端分配的NetBIOS节点类型。undo netbios-type命令用来删除DHCP地址池为DHCP客户端分配的NetBIOS节点类型。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的NetBIOS节点类型。
相关配置可参考命令dhcp server ip-pool和nbns-list。
# 配置DHCP地址池0为DHCP客户端分配的NetBIOS节点类型为b-node。
[Sysname-dhcp-pool-0] netbios-type b-node
1.1.23  network
network network-address [ mask-length | mask mask ]
undo network
DHCP地址池视图
network-address:用于动态分配的IP地址范围。不指定掩码长度和掩码时,表示采用自然掩码。
mask-length:IP地址的网络掩码长度,取值范围为1~30。
mask mask:IP地址的网络掩码,为点分十进制形式。
【描述】
network命令用来配置DHCP地址池动态分配的IP地址范围。undo network命令用来删除动态分配的IP地址范围。
缺省情况下,没有配置动态分配的IP地址范围,即没有可供分配的IP地址。
需要注意的是:每个DHCP地址池只能配置一个网段,如果多次执行network命令,新的配置会覆盖已有配置。
相关配置可参考命令dhcp server ip-pool和dhcp server forbidden-ip。
# 配置DHCP地址池0动态分配的地址范围为192.168.8.0/24。
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
1.1.24  option
option code { ascii ascii-string | hex hex-string&<1-16> | ip-address ip-address&<1-8> }
undo option code
DHCP地址池视图
code:用户定义的选项的数值,取值范围为2~254,不包括3、6、15、44、46、50~55、57~61、66、67、82、150、184、217。
ascii ascii-string:ASCII字符串,为1~63个字符的字符串。
hex hex-string&<1-16>:十六进制数串。hex-string取值范围为2、4、6或8位的十六进制数串。&<1-16>表示最多可以输入16个十六进制数串,每个十六进制数串之间用空格分隔,但目前设备最多支持128位十六进制数(不包括空格)。
ip-address ip-address&<1-8>:IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
【描述】
option命令用来配置DHCP地址池的DHCP自定义选项。undo option命令用来删除DHCP地址池的DHCP自定义选项。
缺省情况下,没有配置DHCP地址池的DHCP自定义选项。
# 定义DHCP地址池的自定义选项100的十六进制数为0x11和0x22。
[Sysname-dhcp-pool-0] option 100 hex 11 22
reset dhcp server conflict { all | ip ip-address }
all:清除所有地址的冲突统计信息。
ip ip-address:清除指定IP地址的冲突统计信息。
【描述】
reset dhcp server conflict命令用来清除DHCP地址冲突的统计信息。
相关配置可参考命令display dhcp server conflict。
# 清除全部地址冲突统计信息。
<Sysname> reset dhcp server conflict all
reset dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] }
all:清除所有IP地址的动态绑定信息。
ip ip-address:清除指定IP地址的动态绑定信息。
pool [ pool-name ]:清除指定地址池的动态绑定信息,pool-name为地址池名称,为1~35个字符的字符串。如果不指定地址池的名称,则清除所有地址池的动态绑定信息。
【描述】
reset dhcp server ip-in-use命令用来清除DHCP动态地址绑定信息。
相关配置可参考命令display dhcp server ip-in-use。
# 清除地址10.110.1.1的绑定信息。
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
无
【描述】
reset dhcp server statistics命令用来清除DHCP服务器的统计信息,包括:DHCP地址池数目,自动、手工和过期绑定的地址数目,不可识别的报文数量,DHCP请求和应答的报文数目统计等。
相关配置可参考命令display dhcp server statistics。
# 清除DHCP服务器统计信息。
<Sysname> reset dhcp server statistics
static-bind client-identifier client-identifier
undo static-bind client-identifier
DHCP地址池视图
client-identifier:待绑定的客户端ID,为4~160个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的ID,aabb-c-dddd和aabb-cc-dddd为无效的ID。
【描述】
static-bind client-identifier命令用来配置DHCP地址池中静态绑定的客户端ID。undo static-bind client-identifier命令用来删除DHCP地址池中静态绑定的客户端ID。
缺省情况下,没有配置DHCP地址池中静态绑定的客户端ID。
l              static-bind client-identifier命令必须与static-bind ip-address命令配合使用,分别配置静态绑定的客户端ID和IP地址。
l              静态绑定的客户端ID,要与在待绑定客户端通过display dhcp client verbose命令显示的客户端ID一致。否则,客户端无法成功获取IP地址。
l              如果多次执行该命令或static-bind mac-address命令,新的配置会覆盖已有配置。
相关配置可参考命令dhcp server ip-pool、static-bind ip-address、static-bind mac-address和display dhcp client verbose。
# 将客户端ID为aaaa-bbbb的主机与IP地址10.1.1.1绑定,掩码为255.255.255.0。
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0
[Sysname-dhcp-pool-0] static-bind client-identifier aaaa-bbbb
static-bind ip-address ip-address [ mask-length | mask mask ]
undo static-bind ip-address
DHCP地址池视图
ip-address:待绑定的IP地址。不指定掩码长度和掩码时,表示采用自然掩码。
mask-length:待绑定IP地址的掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
mask mask:待绑定IP地址的掩码,为点分十进制形式。
【描述】
static-bind ip-address命令用来配置DHCP地址池中静态绑定的IP地址。undo static-bind ip-address命令用来删除DHCP地址池中静态绑定的IP地址。
缺省情况下,没有配置DHCP地址池中静态绑定的IP地址。
l              static-bind ip-address命令必须与static-bind mac-address或static-bind client-identifier命令配合使用,分别配置静态绑定的IP地址和MAC地址或客户端ID。
l              静态绑定的IP地址不能是DHCP服务器的接口IP地址,否则静态绑定不生效。
l              如果多次执行该命令,新的配置会覆盖已有配置。
相关配置可参考命令dhcp server ip-pool、static-bind client-identifier和static-bind mac-address。
# 将MAC地址为0000-e03f-0305的PC机与IP地址10.1.1.1绑定,掩码为255.255.255.0。
Info:Please configure a client-identifier/MAC for the binding.
[Sysname-dhcp-pool-0] static-bind mac-address 0000-e03f-0305
static-bind mac-address mac-address
undo static-bind mac-address
DHCP地址池视图
mac-address:待绑定的主机MAC地址,形式为H-H-H。
【描述】
static-bind mac-address命令用来配置DHCP地址池中静态绑定的MAC地址。undo static-bind mac-address命令用来删除DHCP地址池中静态绑定的MAC地址。
缺省情况下,没有配置DHCP地址池中静态绑定的MAC地址。
l              static-bind mac-address命令必须与static-bind ip-address命令配合使用,分别配置静态绑定的MAC地址和IP地址。
l              如果多次执行该命令或static-bind client-identifier命令,新的配置会覆盖已有配置。
相关配置可参考命令dhcp server ip-pool、static-bind client-identifier和static-bind ip-address。
undo tftp-server domain-name
DHCP地址池视图
domain-name:TFTP服务器名,为1~63个字符的字符串。
【描述】
tftp-server domain-name命令用来配置DHCP地址池为DHCP客户端分配的TFTP服务器名。undo tftp-server domain-name命令用来删除DHCP地址池为DHCP客户端分配的TFTP服务器名。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的TFTP服务器名。
# 配置DHCP地址池0为DHCP客户端分配的TFTP服务器名为aaa。
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
undo tftp-server ip-address
DHCP地址池视图
ip-address:TFTP服务器的IP地址。
【描述】
tftp-server ip-address命令用来配置DHCP地址池为DHCP客户端分配的TFTP服务器地址。undo tftp-server ip-address命令用来删除DHCP地址池为DHCP客户端分配的TFTP服务器地址。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的TFTP服务器地址。
# 配置DHCP地址池0为DHCP客户端分配的TFTP服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
1.1.33  voice-config
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
DHCP地址池视图
as-ip ip-address:指定备用服务器的IP地址。
fail-over ip-address dialer-string:指定自动故障转移IP地址及呼叫字符串。dialer-string为1~39个字符的字符串,字符可以是数字0~9及“*”。
ncp-ip ip-address:指定网络呼叫处理器的IP地址。
voice-vlan vlan-id:指定语音VLAN的ID。vlan-id取值范围为1~4094。
l              disable:指定VLAN处于非使能状态,即DHCP客户端不会将所指定的VLAN ID作为语音VLAN。
l              enable:指定VLAN处于使能状态,即DHCP客户端会将所指定的VLAN ID作为语音VLAN。
【描述】
voice-config命令用来配置DHCP地址池为DHCP客户端分配的Option 184内容。undo voice-config命令用来删除DHCP地址池为DHCP客户端分配的Option 184内容。
缺省情况下,没有配置DHCP地址池为DHCP客户端分配的Option 184内容。
需要注意的是,在配置其它参数前必须先配置ncp-ip,否则其它参数不生效。
# 为DHCP地址池0指定Option 184的内容:网络呼叫处理器的IP地址为10.1.1.1,备用服务器的IP地址为10.2.2.2,语音VLAN的ID为1,为使能状态,自动故障转移IP地址为10.3.3.3,呼叫字符串为99*。
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 1 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
第2章  DHCP中继配置命令
&  说明:
l      DHCP中继中对于接口的相关配置,目前只能在VLAN接口上进行。
l      DHCP中继上不能配置DHCP Snooping功能。
2.1  DHCP中继配置命令
2.1.1  dhcp enable
dhcp enable
undo dhcp enable
无
【描述】
缺省情况下,DHCP服务处于禁止状态。
&  说明:
# 使能DHCP服务。
dhcp relay address-check { disable | enable }
VLAN接口视图
disable: 禁止DHCP中继的地址匹配检查功能。
enable: 使能DHCP中继的地址匹配检查功能。
【描述】
dhcp relay address-check命令用来配置DHCP中继的地址匹配检查功能。
缺省情况下,禁止DHCP中继的地址匹配检查功能。
# 使能DHCP中继的地址匹配检查功能。
[Sysname-Vlan-interface1] dhcp relay address-check enable
undo dhcp relay information enable
VLAN接口视图
无
【描述】
dhcp relay information enable命令用来配置DHCP中继支持Option 82功能。undo dhcp relay information enable命令用来禁止DHCP中继支持Option 82功能。
缺省情况下,DHCP中继不支持Option 82功能。
# 配置DHCP中继支持Option 82功能。
[Sysname-Vlan-interface1] dhcp relay information enable
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp relay information format [ verbose node-identifier ]
VLAN接口视图
normal:指定以Normal格式进行填充。
verbose:指定以Verbose格式进行填充。
node-identifier { mac | sysname | user-defined node-identifier }:接入节点的标识。其中mac表示以节点的MAC地址作为节点标识;sysname表示以节点的名称作为节点标识;user-defined node-identifier表示以指定的字符串作为节点标识,node-identifier为1~50个字符的字符串。
【描述】
dhcp relay information format命令用来配置Option 82选项的填充格式。undo dhcp relay information format命令用来恢复缺省情况。
缺省情况下,Opiton 82选项的填充格式为normal。
&  说明:
l      在使用undo dhcp relay information format命令时,如果不带verbose node-identifier参数,则恢复为缺省的normal填充格式;如果带verbose node-identifier参数,则恢复为verbose填充格式中的mac方式。
l      DHCP中继对包含Option 82请求报文的处理策略为replace时,需要配置Option 82选项的填充格式;处理策略为keep或drop时,不需要配置Option 82选项的填充格式。
# 配置Option 82选项以Verbose格式进行填充。
[Sysname-Vlan-interface1] dhcp relay information strategy replace
[Sysname-Vlan-interface1] dhcp relay information format verbose
undo dhcp relay information strategy
VLAN接口视图
drop:如果报文中带有Option 82选项,则丢弃该报文。
keep:如果报文中带有Option 82选项,则保持该报文中的Option 82选项不变并进行转发。
replace:如果报文中带有Option 82选项,则按照配置的填充格式填充Option 82选项,并用该选项替换报文中原有的Option 82选项,并进行转发。
【描述】
dhcp relay information strategy命令用来配置DHCP中继对包含Option 82选项的请求报文的处理策略。undo dhcp relay information strategy命令用来恢复缺省情况。
缺省情况下,DHCP中继对带有Option 82选项的请求报文的处理策略为replace。
# 配置DHCP中继对带有Option 82选项的请求报文使用keep策略。
[Sysname-Vlan-interface1] dhcp relay information strategy keep
dhcp relay release client-ip client-mac [ server-ip ]
系统视图/VLAN接口视图
client-ip:DHCP客户端的IP地址。
client-mac:DHCP客户端的MAC地址,形式为H-H-H。
server-ip:DHCP服务器的IP地址。
【描述】
dhcp relay release命令用来向DHCP服务器请求释放客户端申请到的IP地址。
如果不指定DHCP服务器的IP地址,则:
l              在系统视图下,向所有配置为中继模式的接口所对应的DHCP服务器组中的DHCP服务器发送释放申请;
l              在接口视图下,向该接口所对应的DHCP服务器组中的所有DHCP服务器发送释放申请。
如果指定了DHCP服务器的IP地址,则只向指定DHCP服务器发送释放申请。
# 向VLAN接口1对应的DHCP服务器请求释放客户端000f-e200-0001申请到的IP地址1.1.1.1。
[Sysname-Vlan-interface1] dhcp relay release 1.1.1.1 000f-e200-0001
# 向所有的DHCP服务器请求释放客户端000f-e200-0001申请到的IP地址1.1.1.1。
[Sysname] dhcp relay release 1.1.1.1 000f-e200-0001
dhcp relay security static ip-address mac-address
undo dhcp relay security { ip-address | all | dynamic | static }
ip-address:DHCP客户端的IP地址。
mac-address:DHCP客户端的MAC地址,形式为H-H-H。
all:所有的用户地址表项。
dynamic:动态用户地址表项。
static:静态用户地址表项。
【描述】
dhcp relay security static命令用来配置DHCP中继的静态用户地址表项,即IP地址和MAC地址之间的静态绑定。undo dhcp relay security命令用来删除用户地址表项。
缺省情况下,没有配置DHCP中继的静态用户地址表项。
相关配置可参考命令display dhcp relay security。
# 配置DHCP中继的静态用户地址表项:客户端IP地址为1.1.1.1,MAC地址为0005-5d02-f2b3。
[Sysname] dhcp relay security static 1.1.1.1 0005-5d02-f2b3
dhcp relay security tracker { interval | auto }
undo dhcp relay security tracker [ interval ]
interval:刷新时间间隔,取值范围为1~120,单位为秒。
auto:根据表项的数目自动计算刷新时间间隔,计算方式为60秒除以表项个数。表项越多,刷新时间间隔越短,但最短时间间隔不能小于500毫秒。
【描述】
dhcp relay security tracker命令用来配置DHCP中继动态用户地址表项的定时刷新周期。undo dhcp relay security tracker命令用来恢复缺省情况。
缺省情况下,定时刷新周期为auto,即根据表项的数目自动计算刷新时间间隔。
# 配置刷新时间间隔为100秒。
[Sysname] dhcp relay security tracker 100
undo dhcp relay server-detect
无
【描述】
dhcp relay server-detect命令用来在DHCP中继设备上使能伪DHCP服务器检测功能。undo dhcp relay server-detect命令用来禁止此功能。
# 使能伪DHCP服务器检测功能。
[Sysname] dhcp relay server-detect
dhcp relay server-group group-id ip ip-address
undo dhcp relay server-group group-id [ ip ip-address ]
group-id:DHCP服务器组号,取值范围为0~19。
ip-address:DHCP服务器的IP地址。
【描述】
dhcp relay server-group命令用来配置DHCP服务器组中DHCP服务器的IP地址。undo dhcp relay server-group命令用来删除DHCP服务器组中服务器的IP地址,如果不指定ip ip-address参数,则删除指定DHCP服务器组及组中所有服务器的IP地址。
缺省情况下,没有配置DHCP服务器组中服务器的IP地址。
l              设备上最多可以配置20个DHCP服务器组。每个DHCP服务器组最多可以配置8个外部DHCP服务器地址。
l              DHCP服务器组中服务器的IP地址不能与DHCP中继和客户端相连的接口IP地址在同一网段;否则,可能导致客户端无法获得IP地址。
l              如果一个组已经和多个接口建立起了归属关系,要首先取消这些接口和该组的归属关系,才能把这个组删除。
相关配置可参考命令display dhcp relay server-group。
# 配置DHCP服务器组1的服务器IP地址为1.1.1.1。
[Sysname] dhcp relay server-group 1 ip 1.1.1.1
dhcp relay server-select group-id
undo dhcp relay server-select
group-id:DHCP服务器组号,取值范围为0~19。此处指定的DHCP服务器组必须事先已经存在,即必须是已配置了服务器IP地址的组。
【描述】
dhcp relay server-select命令用来配置接口与DHCP服务器组的归属关系。undo dhcp relay server-select命令用来取消这种归属关系。
缺省情况下,接口没有与DHCP服务器组建立归属关系。
需要注意的是,同一接口同时只能与一个DHCP服务器组建立归属关系,后面的配置将覆盖已有的配置。但是,如果新指定的DHCP服务器组不存在时,新的归属关系配置不成功,接口还是维持与上一次配置的DHCP服务器组的归属关系。
# 配置VLAN接口1与DHCP服务器组1的归属关系。
[Sysname-Vlan-interface1] dhcp relay server-select 1
dhcp select relay
undo dhcp select relay
无
【描述】
dhcp select relay命令用来配置接口工作在DHCP中继模式,即当接口收到DHCP客户端发来的DHCP报文时,将报文转发给DHCP服务器,由服务器分配地址。undo dhcp select relay命令用来恢复接口对DHCP报文的处理模式为缺省模式。
缺省情况下,使能DHCP服务后,接口工作在DHCP服务器模式,即当接口收到DHCP客户端发来的DHCP报文时,将从DHCP服务器的地址池中分配地址。
# 配置VLAN接口1工作在DHCP中继模式。
[Sysname-Vlan-interface1] dhcp select relay
display dhcp relay { all | interface interface-type interface-number }
all:显示所有接口对应的DHCP服务器组的信息。
interface interface-type interface-number:显示指定接口对应的DHCP服务器组的信息。
【描述】
display dhcp relay命令用来显示接口对应的DHCP服务器组的信息。
# 显示所有接口对应的DHCP服务器组的信息。
<Sysname> display dhcp relay all
    Interface name            Server-group
    Vlan-interface2               2
表2-1 display dhcp relay命令显示信息描述表
Interface name
接口名
Server-group
接口对应的DHCP服务器组的组号
display dhcp relay security [ ip-address | dynamic | static ]
ip-address:显示指定IP地址的用户地址表项信息。
dynamic:显示动态用户地址表项信息。
static:显示静态用户地址表项信息。
【描述】
display dhcp relay security命令用来显示DHCP中继的用户地址表项信息。如不指定参数,则显示全部的用户地址表项信息。
# 显示用户地址表项信息。
<Sysname> display dhcp relay security
IP Address      MAC Address     Type
 10.1.1.1       000f-e20f-0001  Static
 10.1.1.5       000f-e20f-0000  Static
---   2 dhcp-security item(s) found   ---
表2-2 display dhcp relay security命令显示信息描述表
IP Address
DHCP客户端的IP地址
MAC Address
DHCP客户端的MAC地址
用户地址表项的类型,Static表示静态地址表项,Dynamic表示动态地址表项
无
【描述】
display dhcp relay security statistics命令用来显示DHCP中继用户地址表项的统计信息。
# 显示用户地址表项的统计信息。
<Sysname> display dhcp relay security statistics
Static Items     :0
Dynamic Items        :0
Temporary Items  :0
All Items            :0
表2-3 display dhcp relay security statistics命令显示信息描述表
Static Items
静态用户地址表项数目
Dynamic Items
动态用户地址表项数目
Temporary Items
临时用户地址表项数目
All Items
所有用户地址表项的总数
无
【描述】
display dhcp relay security tracker命令用来显示DHCP中继动态用户地址表项的定时刷新周期。
# 显示DHCP中继动态用户地址表项的定时刷新周期。
<Sysname> display dhcp relay security tracker
Current tracker interval: 10s
以上信息表示当前定时刷新周期为10s。
display dhcp relay server-group { group-id | all }
group-id:显示指定的DHCP服务器组的信息,取值范围为0~19。
all:显示所有的DHCP服务器组的信息。
【描述】
display dhcp relay server-group命令用来显示DHCP服务器组中服务器的IP地址。
# 显示DHCP服务器组1中的服务器IP地址。
<Sysname> display dhcp relay server-group 1
    No.            Group IP
    1              1.1.1.1
    2              1.1.1.2
表2-4 display dhcp relay server-group命令显示信息描述表
No.
序号
Group IP
DHCP服务器组中服务器的IP地址
display dhcp relay statistics [ server-group { group-id | all } ]
group-id:显示指定DHCP服务器组的报文统计信息,取值范围为0~19。
all:显示所有DHCP服务器组的报文统计信息,每个组的信息单独显示。
【描述】
display dhcp relay statistics命令用来显示DHCP中继的相关报文统计信息。
如果不指定server-group参数,则显示所有DHCP服务器组的相关报文统计信息之和。
# 显示所有DHCP服务器组的相关报文统计信息之和。
<Sysname> display dhcp relay statistics
     Bad packets received:                   0
     DHCP packets received from clients: 20
         DHCPDISCOVER packets received:      10
         DHCPREQUEST packets received:       10
         DHCPINFORM packets received:        0
         DHCPRELEASE packets received:       0
         DHCPDECLINE packets received:       0
         BOOTPREQUEST packets:               0
     DHCP packets received from servers: 20
         DHCPOFFER packets received:     10
         DHCPACK packets received:           10
         DHCPNAK packets received:           0
         BOOTPREPLY packets:             0
     DHCP packets sent to servers:           20
     DHCP packets sent to clients:           20
表2-5 display dhcp relay statistics命令显示信息描述表
DHCP中继接收的错误报文数
DHCP中继从客户端接收的DHCP报文数
DHCP中继从服务器接收的DHCP报文数
DHCP中继发送给服务器的DHCP报文数
DHCP中继发送给客户端的DHCP报文数
# 分组显示所有DHCP服务器组的相关报文统计信息。
<Sysname> display dhcp relay statistics server-group all
DHCP relay server-group           #2
     Packet type               Packet number
 Client -> Server:
     DHCPDISCOVER                   5
     DHCPREQUEST                5
     DHCPINFORM                         0
     DHCPRELEASE                    0
     DHCPDECLINE                    0
     BOOTPREQUEST                   0
 Server -> Client:
     DHCPOFFER                      5
     DHCPACK                        5
     DHCPNAK                        0
     BOOTPREPLY                     0
DHCP relay server-group           #3
 Client -> Server:
     DHCPDISCOVER                   5
     DHCPREQUEST                5
     DHCPINFORM                         0
     DHCPRELEASE                    0
     DHCPDECLINE                    0
     BOOTPREQUEST                   0
 Server -> Client:
     DHCPOFFER                      5
     DHCPACK                        5
     DHCPNAK                        0
     BOOTPREPLY                     0
表2-6 display dhcp relay statistics server-group命令显示信息描述表
DHCP服务器组
Packet type
DHCP报文类型
Packet number
DHCP中继接收到的报文数目
Client -> Server
DHCP中继从客户端接收的DHCP报文
Server -> Client
DHCP中继从服务器接收的DHCP报文
reset dhcp relay statistics [ server-group group-id ]
server-group group-id:清除指定DHCP服务器组的DHCP中继的统计信息,取值范围为0~19。
【描述】
reset dhcp relay statistics命令用来清除DHCP中继的统计信息。
如果不指定server-group参数,则清除所有DHCP服务器组的DHCP中继的统计信息。
相关配置可参考命令display dhcp relay statistics。
# 清除所有DHCP服务器组的DHCP中继的统计信息。
<Sysname> reset dhcp relay statistics
&  说明:
l      DHCP Snooping不支持链路聚合。若以太网端口加入聚合组,则该端口上进行的DHCP Snooping配置不会生效;该端口退出聚合组后,之前的DHCP Snooping配置才会生效。
l      设备只有位于DHCP客户端与DHCP服务器之间,或DHCP客户端与DHCP中继之间时,DHCP Snooping功能配置后才能正常工作;设备位于DHCP服务器与DHCP中继之间时,DHCP Snooping功能配置后不能正常工作。
l      使能DHCP Snooping功能的设备,不能作为DHCP服务器和DHCP中继。
l      建议不要在同一台设备上同时配置DHCP客户端/BOOTP客户端和DHCP Snooping功能,否则可能无法生成DHCP Snooping表项,DHCP客户端/BOOTP客户端也可能申请不到IP地址。
3.1.1  dhcp-snooping
dhcp-snooping
undo dhcp-snooping
无
【描述】
dhcp-snooping命令用来使能DHCP Snooping功能。undo dhcp-snooping命令用来关闭此功能。在DHCP Snooping功能关闭后,所有端口都可转发DHCP服务器的响应报文,并且不记录DHCP客户端的IP地址和MAC地址。
缺省情况下,DHCP Snooping功能处于关闭状态。
相关配置可参考命令display dhcp-snooping。
# 使能DHCP Snooping功能。
[Sysname] dhcp-snooping
dhcp-snooping trust
undo dhcp-snooping trust
以太网端口视图
无
【描述】
dhcp-snooping trust命令用来配置端口为信任端口。undo dhcp-snooping trust命令用来恢复端口为不信任端口。
缺省情况下,在使能DHCP Snooping功能后,设备的所有端口均为不信任端口。
相关配置可参考命令display dhcp-snooping trust。
# 配置以太网端口Ethernet1/0/1为信任端口。
[Sysname-Ethernet1/0/1] dhcp-snooping trust
无
【描述】
display dhcp-snooping命令用来显示通过DHCP Snooping记录的绑定信息表。
相关配置可参考命令dhcp-snooping。
&  说明:
display dhcp-snooping命令只显示DHCP-ACK和DHCP-REQUEST报文中IP地址与MAC地址绑定关系一致的绑定信息项。
# 显示通过DHCP Snooping记录的绑定信息表。
<Sysname> display dhcp-snooping
DHCP Snooping is enabled.
The client binding table for all untrusted ports.
Type : D--Dynamic , S--Static
Type IP Address      MAC Address        Lease          VLAN    Interface
D     10.1.1.1            000f-e200-0006   286            1  Ethernet1/0/1
---   1 dhcp-snooping item(s) found   ---
表3-1 display dhcp snooping命令显示信息描述表
绑定类型
IP Address
DHCP服务器为DHCP客户端分配的IP地址
MAC Address
DHCP客户端的MAC地址
Lease
绑定的租约剩余时间,单位为秒
VLAN
与DHCP客户端连接的设备端口所属的VLAN
与DHCP客户端连接的设备端口
无
【描述】
display dhcp-snooping trust命令用来显示信任端口信息。
相关配置可参考命令dhcp-snooping trust。
# 显示信任端口信息。
<Sysname> display dhcp-snooping trust
DHCP Snooping trust becomes active.
Interface                                       Trusted
Ethernet1/0/1                                  Trusted
以上显示信息表示DHCP Snooping处于使能状态,DHCP Snooping信任功能生效,信任端口为Ethernet1/0/1。
第4章  DHCP客户端配置命令
&  说明:
l      DHCP客户端中对于接口的相关配置,目前只能在VLAN接口上进行。
l      建议不要在同一台设备上同时配置DHCP客户端和DHCP Snooping功能,否则可能无法生成DHCP Snooping表项,DHCP客户端也可能申请不到IP地址。
4.1  DHCP客户端配置命令
verbose:显示DHCP客户端的详细信息。
interface interface-type interface-number:显示指定接口的DHCP客户端相关信息。
【描述】
display dhcp client命令用来显示DHCP客户端的相关信息。
如果不指定interface interface-type interface-number参数,显示所有接口的DHCP客户端相关信息。
# 显示所有接口的DHCP客户端相关信息。
<Sysname> display dhcp client
Vlan-interface1 DHCP client information:
 Current machine state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# 显示所有接口的DHCP客户端详细信息。
<Sysname> display dhcp client verbose
 Lease from 2005.08.13 15:37:59   to   2005.08.16 15:37:59
 Transaction ID: 0x1c09322d
 Default router: 40.1.1.2
 DNS server: 44.1.1.11
 DNS server: 44.1.1.12
 Domain name: ddd.com
Client ID: 3030-3066-2e65-3234-
392e-3830-3438-2d56-
6c61-6e2d-696e-7465-
7266-6163-6531
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
表4-1 display dhcp client命令显示信息描述表
作为DHCP客户端的接口信息
DHCP客户端状态机的当前状态
Allocated IP
DHCP服务器为接口分配的IP地址
Allocated lease
租约时长
T1
DHCP客户端的1/2租约时间(以秒为单位)
T2
DHCP客户端的7/8租约时间(以秒为单位)
Lease from….to….
租约起止时间
DHCP Server
选择的DHCP服务器的地址
Transaction ID
DHCP客户端发起申请时生成的一个随机数,用来唯一标识一次申请过程
Default router
为DHCP客户端指定的网关地址
DNS server
为DHCP客户端指定的DNS服务器地址
Domain name
为DHCP客户端指定的域名
Client ID
DHCP客户端ID
在多少时间后T1定时器(即1/2租约时间)将到期
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
undo ip address dhcp-alloc
client-identifier mac interface-type interface-number:使用指定接口的MAC地址作为客户端ID来获取IP地址。interface-type interface-number表示接口类型和接口号。
【描述】
ip address dhcp-alloc命令用来配置接口使用DHCP方式获取IP地址。undo ip address dhcp-alloc命令用来取消接口使用DHCP方式获取IP地址。
如果不选择参数,则使用接口的MAC地址和接口名组成的字符串作为客户端ID来获取IP地址。
缺省情况下,接口不使用DHCP方式获取IP地址。
需要注意的是:释放接口上以DHCP方式获取的IP地址时,DHCP客户端会发送DHCP-RELEASE报文。如果此时该接口处于down状态,则无法保证报文成功发送。
# 指定VLAN接口1使用DHCP方式获取IP地址。
[Sysname-Vlan-interface1] ip address dhcp-alloc
第5章  BOOTP客户端配置命令
&  说明:
l      BOOTP客户端中对于接口的相关配置,目前只能VLAN接口上进行。
l      建议不要在同一台设备上同时配置BOOTP客户端和DHCP Snooping功能,否则可能无法生成DHCP Snooping表项,BOOTP客户端也可能申请不到IP地址。
5.1  BOOTP客户端配置命令
interface interface-type interface-number:指定接口类型和接口号。
【描述】
display bootp client命令用来显示BOOTP客户端的相关信息,包括BOOTP客户端的MAC地址和申请到的IP地址等信息。
如果不指定interface interface-type interface-number参数,则显示所有接口上的BOOTP客户端的相关信息。
# 显示VLAN接口1的BOOTP客户端的相关信息。
<Sysname> display bootp client interface vlan-interface 1
Vlan-interface1 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID = 0x3d8a7431
Mac Address  00e0-fc0a-c3ef
表5-1 display bootp client命令显示信息描述表
作为BOOTP客户端的接口信息
Allocated IP
BOOTP服务器为BOOTP客户端分配的IP地址
Transaction ID
BOOTP报文中XID字段值,即BOOTP客户端发送BOOTP请求报文时选择的随机数,用来与BOOTP服务器的响应报文相匹配。如果响应报文的XID字段值与请求报文的XID字段值不相同,则BOOTP客户端丢弃该响应报文
Mac Address
BOOTP客户端的MAC地址
undo ip address bootp-alloc
无
【描述】
ip address bootp-alloc命令用来配置接口通过BOOTP协议获取IP地址。undo ip address bootp-alloc命令用来取消接口通过BOOTP协议获取IP地址。
缺省情况下,接口不通过BOOTP协议获取IP地址。
相关配置可参考命令display bootp client。
# 配置VLAN接口1通过BOOTP协议获取IP地址。
[Sysname-Vlan-interface1] ip address bootp-alloc
