H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide-6W101
HomeSupportQuick StartH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide-6W101
Table of Contents
Related Documents
26-SSH Quick Start Configuration Guide
26-SSH Quick Start Configuration Guide 175.12 KB
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Configuring the device as an SSH server
Introduction
The following information uses an example to describe the basis procedure for configuring the device as an SSH server.
As shown in Figure 1, configure the switch to meet the following requirements:
·     The switch acts as the SSH server and uses password authentication to authenticate the SSH client locally.
·     Set the username of the client to client001 and password to hello12345 for login. After the user logs in to the switch from the host, the user can use all commands to configure the switch.
Figure 1 Network diagram
# Generate RSA key pairs.
<Switch> system-view
[Switch] public-key local create rsa
The range of public key modulus is (512 ~ 4096).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[Switch] public-key local create dsa
The range of public key modulus is (512 ~ 2048).
Generating Keys...
# Generate an ECDSA key pair.
[Switch] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the SSH server.
[Switch] ssh server enable
# Create VLAN 2 and assign Ten-GigabitEthernet 1/0/2 to VLAN 2.
[Switch] vlan 2
[Switch-vlan2] port ten-gigabitethernet 1/0/2
[Switch-vlan2] quit
# Assign an IP address to VLAN-interface 2. The SSH client uses this address as the destination for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[Switch-Vlan-interface2] quit
# Enable the login authentication mode to scheme for user lines VTY 0 through VTY 63.
[Switch] line vty 0 63
[Switch-line-vty0-63] authentication-mode scheme
[Switch-line-vty0-63] quit
# Create a local device management user named client001.
[Switch] local-user client001 class manage
New local user added.
# Set the password to hello12345 in plain text for local user client001.
[Switch-luser-manage-client001] password simple hello12345
# Authorize local user client001 to use the SSH service.
[Switch-luser-manage-client001] service-type ssh
# Assign the network-admin user role to local user client001.
[Switch-luser-manage-client001] authorization-attribute user-role network-admin
[Switch-luser-manage-client001] quit
There are different types of SSH client software. This example uses an SSH client that runs PuTTY version 0.60 to verify the SSH login.
# Install PuTTY version 0.60 on the host.
# Launch PuTTY.exe. The PuTTY Configuration window opens. Click Session.
·     In the Host Name (or IP address) field, enter IP address 192.168.1.40 of the SSH server.
·     In the Port field, enter 22.
·     Select SSH as the connection type.
Figure 2 Configuring the SSH client
# Click Open. The PuTTY Security Alert dialog box opens.
Figure 3 PuTTY Security Alert
# Click Yes. Enter username client001 and password hello12345 (not shown on the interface) to log in to the SSH server.
Figure 4 Logging in to the SSH server
The output shows that you have successfully log in to the switch and can use all commands available on the switch.
Configuration files
vlan 2
interface Vlan-interface2
 port access vlan 2
line vty 0 63
ssh server enable
 password hash $h$6$CqMnWdX6LIW/hz2Z$4+0Pumk+A98VlGVgqN3n/mEi7hJka9fEZpRZIpSNi9b
cBEXhpvIqaYTvIVBf7ZUNGnovFsqW7nYxjoToRDvYBg==
 service-type ssh
Related documentation
·     SSH configuration in the security configuration guide for the device.
·     SSH commands in the security command reference for the device.
Configuring the device as an SSH client
Introduction
The following information uses an example to describe the basis procedure for configuring the device as an SSH client.
As shown in Figure 5, configure the switches to meet the following requirements:
·     Switch A acts as the SSH client.
·     Switch B acts as the SSH server and uses password authentication to authenticate the SSH client locally.
·     Set the username of the client to client001 and password to hello12345 for login. After the user logs in to Switch B from Switch A, the user can use all commands to configure Switch B.
Figure 5 Network diagram
1.     Configure Switch A:
[SwitchA] vlan 2
[SwitchA-vlan2] port ten-gigabitethernet 1/0/2
[SwitchA-vlan2] quit
[SwitchA-Vlan-interface2] ip address 192.168.1.56 255.255.255.0
2.     Configure Switch B:
# Configure Switch B as the SSH server. For more information, see "Configuring the device as an SSH server."
Verify that you can successfully log in to Switch B as a network administrator:
# On Switch A, establish an SSH connection to the SSH server (Switch B) at 192.168.1.40.
# Enter username client001 and enter Y to continue accessing the server without authenticating the server.
# Enter N to not save the server public key.
If you enter Y to save the server public key, when the server public key changes, execute the delete SSH client server public key command in the system view of Switch A to delete the saved public key, so that you can establish a connection to the server again.
# Enter password hello12345 (not shown on the interface) to log in to the SSH server.
<SwitchA> ssh2 192.168.1.40
Username: client001
Connecting to 192.168.1.40 port 22.
The server is not authenticated. Continue? [Y/N]:Y
Do you want to save the server public key? [Y/N]:N
Enter password:
* Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
<SwitchB>
Configuration files
·     Switch A
vlan 2
 port link-mode bridge
 port access vlan 2
·     Switch B
See "Configuration files."
