- H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide-6W101
- 01-H3C Devices CLI Reference
- 02-Login Management Quick Start Configuration Guide
- 03-Configuration File Management Quick Start Configruation Guide
- 04-Software Upgrade Quick Start Configuration Guide
- 05-Device Management Quick Start Configuration Guide
- 06-NTP Quick Start Configuration Guide
- 07-RBAC Quick Start Configuration Guide
- 08-IRF Quick Start Configuration Guide
- 09-Ethernet Interface Quick Start Configuration Guide
- 10-VLAN Quick Start Configuration Guide
- 11-Port Isolation Quick Start Configuration Guide
- 12-Loop Detection Quick Start Configuration Guide
- 13-QinQ Quick Start Configuration Guide
- 14-MAC Address Table Quick Start Configuration Guide
- 15-Ethernet Link Aggregation Quick Start Configuration Guide
- 16-Spanning Tree Quick Start Configuration Guide
- 17-DHCP Quick Start Configuration Guide
- 18-OSPF Quick Start Configuration Guide
- 19-Static Routing Quick Start Configuration Guide
- 20-Basic RIP Quick Start Configuration Guide
- 21-PBR Quick Start Configuration Guide
- 22-IGMP Snooping Quick Start Configuration Guide
- 23-Packet Filtering Quick Start Configuration Guide
- 24-QoS Quick Start Configuration Guide
- 25-IP Source Guard Quick Start Configuration Guide
- 26-SSH Quick Start Configuration Guide
- 27-Port Security Quick Start Configuration Guide
- 28-VRRP Quick Start Configuration Guide
- 29-PoE Quick Start Configuration Guide
- 30-Mirroring Quick Start Configuration Guide
- 31-Information Center Quick Start Configuration Guide
- 32-SNMP Quick Start Configuration Guide
- 33-LAN Networks Quick Start Configuration Guide
| 09-Ethernet Interface Quick Start Configuration Guide | 62.01 KB |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Activating the copper port or fiber port of a combo interface
Introduction
The following information uses an example to describe the basic procedure for activating the copper port or fiber port of a combo interface.
Activate the copper port or fiber port of a combo interface at the CLI.
A combo interface is a logical interface that physically comprises one fiber combo port and one copper combo port on the device panel. The two ports share one forwarding interface and one interface view. As a result, they cannot work simultaneously. When you activate one port, the other port is automatically disabled.
# Activate the copper combo port of GigabitEthernet 1/0/1, and connect a twisted pair cable to the interface.
[Sysname-GigabitEthernet1/0/1] combo enable copper
# Activate the fiber combo port of GigabitEthernet 1/0/1, and connect a fiber to the interface.
[Sysname-GigabitEthernet1/0/1] combo enable fiber
# When a combo interface is connected to a cable or transceiver module, use the display interface command to view information about the interface. If Media type is twisted pair is displayed in the command output, the copper port is activated. If not, the fiber port is activated.
[Sysname] display interface GigabitEthernet 1/0/1
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 00ff-00ff-0139
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Loopback is not set
Port hardware type is 1000_BASE_T
Configuration files
port link-mode bridge
combo enable copper
Related documentation
· Ethernet interface configuration in the Layer 2—Ethernet switching configuration guide for the device.
· Ethernet interface commands in the Layer 2—Ethernet switching command reference for the device.
