- H3C S9500 Operation Manual-Release1648[v1.24]-08 System Volume
- 00-1Cover
- 01-Command Line Interface Configuration
- 02-Login and User Interface Configuration
- 03-FTP and TFTP Configuration
- 04-HA Configuration
- 05-NQA Configuration
- 06-NetStream Configuration
- 07-NTP Configuration
- 08-RMON Configuration
- 09-SNMP Configuration
- 10-Packet Statistics Accounting Configuration
- 11-Device Management Configuration
- 12-Configuration File Management Configuration
- 13-File System Management Configuration
- 14-Cluster Management Configuration
- 15-System Maintenance and Debugging Configuration
- 16-Information Center Configuration
- 17-PoE Configuration
- 18-Clock Module Configuration
- 19-ACSEI Server Configuration
- 20-OAP Module Configuration
| 19-ACSEI Server Configuration | 40.2 KB |
Table of Contents
Chapter 1 ACSEI Server Configuration
1.1.3 ACSEI Server Startup and Running
1.2 ACSEI Server Configuration
1.2.2 Configuring the Clock Synchronization Time Interval
1.2.3 Configuring the Monitoring Time Interval
1.2.4 Closing an ACSEI Client System
1.2.5 Restarting an ACSEI Client System
1.2.6 Displaying and Maintaining ACSEI Server
When configuring ACSEI, go to these sections for information you are interested in:
1.1 Introduction to ACSEI
As a private protocol, ACSEI provides a method for exchanging information between ACFP clients and ACFP server. It well supports Application Control Forwarding Protocol (ACFP) collaboration, ensuring valid information interaction between the ACFP clients and the ACFP server, so that the ACFP server and clients can cooperate to run a service.
As a supporting protocol of ACFP, ACSEI defines two entities: server and client.
l ACSEI server is integrated into the software system of the device and is supported by the device.
l ACSEI client is integrated into the software system of the open application platform (OAP) module. In this way it is a function supported by the OAP module.
& Note:
l ACFP is designed based on the Open Application Architecture (OAA).
l The OAP is designed for new services. On OAP module runs the Linux operating system. You can load various service software, such as security, voice, and so on as needed.
l This manual only provides the configuration of the ACSEI server that is integrated into the software system of the device.
1.1.1 Functions of ACSEI
ACSEI mainly provides the following functions:
l Registration and deregistration of an ACSEI client to the ACSEI server.
l ID assignment. The ACSEI server assigns IDs to ACSEI clients to distinguish between them.
l Mutual monitoring and awareness between an ACSEI client and the ACSEI server.
l Information interaction between the ACSEI server and ACSEI clients, including clock synchronization.
l Control of the ACSEI clients on the ACSEI server. For example, you can close ACSEI client, or restart ACSEI client on the ACSEI server.
& Note:
An ACSEI server can register multiple ACSEI clients.
1.1.2 ACSEI Timers
An ACSEI server has two timers, the clock synchronization timer and the monitoring timer.
l The clock synchronization timer can be set by users to periodically trigger the ACSEI server to send clock synchronization advertisements to ACSEI clients.
l The monitoring timer can be set by users to periodically trigger the ACSEI server to send monitoring requests to ACSEI clients.
An ACSEI client starts two timers, the registration timer and the monitoring timer.
l The registration timer is used to periodically trigger the ACSEI client to multicast registration requests.
l The monitoring timer is used to periodically trigger the ACSEI client to send monitoring requests to the ACSEI server.
ACSEI server starts up and runs in the following procedures:
1) Run the ACSEI client application to enable ACSEI client.
2) Start up the device and enable the ACSEI server function on it.
3) The ACSEI client multicasts registration requests.
4) After the ACSEI server receives a valid registration request, it negotiates parameters with the ACSEI client and establishes connection with the client if the negotiation succeeds.
5) The ACSEI server and the ACSEI client mutually monitor the connection.
The section covers these topics:
l Configuring the Clock Synchronization Time Interval
l Configuring the Monitoring Time Interval
l Displaying and Maintaining ACSEI Server
1.2.1 Enabling ACSEI Server
Follow these steps to enable ACSEI server:
Use the command… |
Remarks |
Enter system view |
system-view |
Enable ACSEI server |
acsei server enable |
Required Disabled by default. |
Follow these steps to configure the clock synchronization time interval:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the ACSEI server function |
Required |
Enter ACSEI server view |
acsei server |
Configure the time interval for clock synchronization from ACSEI server to ACSEI client |
acsei timer clock-sync minutes |
Required Five minutes by default. |
Follow theses steps to configure the monitoring time interval:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
acsei server |
Configure the time interval for ACSEI server to monitor ACSEI client |
acsei timer monitor seconds |
Required Five seconds by default. |
Follow these steps to close an ACSEI client system:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
acsei server |
Close the specified ACSEI client system |
acsei client close client-id |
Required |
Follow these steps to restart an ACSEI client system:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
acsei server |
Restart the specified ACSEI client system |
acsei client reboot client-id |
Required |
To do… |
Use the command… |
Remarks |
Display ACSEI client summary |
display acsei client summary [ client-id ] |
Available in any view |
Display ACSEI client information |
display acsei client info [ client-id ] |
Enable ACSEI debugging |
debugging acsei server { error | packet | event | all } |
