- H3C S9500 Operation Manual-Release1648[v1.24]-08 System Volume
- 00-1Cover
- 01-Command Line Interface Configuration
- 02-Login and User Interface Configuration
- 03-FTP and TFTP Configuration
- 04-HA Configuration
- 05-NQA Configuration
- 06-NetStream Configuration
- 07-NTP Configuration
- 08-RMON Configuration
- 09-SNMP Configuration
- 10-Packet Statistics Accounting Configuration
- 11-Device Management Configuration
- 12-Configuration File Management Configuration
- 13-File System Management Configuration
- 14-Cluster Management Configuration
- 15-System Maintenance and Debugging Configuration
- 16-Information Center Configuration
- 17-PoE Configuration
- 18-Clock Module Configuration
- 19-ACSEI Server Configuration
- 20-OAP Module Configuration
| 01-Command Line Interface Configuration | 110.51 KB |
Table of Contents
Chapter 1 Command Line Interface
1.3 Features and Functions of Command Line
1.3.1 Online Help of Command Line
1.3.2 Displaying Characteristics of Command Line
1.3.3 History Command of Command Line
1.3.4 Common Command Line Error Messages
1.3.5 Editing Characteristics of Command Line
When configuring command line interface, go to these sections for information you are interested in:
l Features and Functions of Command Line
1.1 Command Line Interface
H3C series switches provide a series of configuration commands and command line interfaces for configuring and managing the switch. The command line interface has the following characteristics:
l Local configuration via the Console port and AUX port.
l Local or remote configuration via Telnet.
l Remote configuration through dialing with modem via the AUX port.
l Hierarchy command protection to avoid the unauthorized users accessing switch.
l Enter a “?” to get immediate online help.
l Provide network testing commands, such as Tracert and Ping, to fast troubleshoot the network.
l Provide various detailed debugging information to help with network troubleshooting.
l Log in and manage other switch directly, using the Telnet command.
l Provide FTP service for the users to upload and download files.
l Provide the function similar to Doskey to execute a history command.
l The command line interpreter searches for target not fully matching the keywords. You can key in either the whole keyword or part of it, as long as it is unique and not ambiguous.
1.2 Command Line View
H3C series switches provide hierarchy protection for the command lines to avoid unauthorized user accessing illegally.
Commands are classified into four levels, namely visit level, monitor level, system level and manage level. They are introduced as follows:
l Visit level: Commands of this level involve command of network diagnosis tool (such as ping and tracert), command of switch between different language environments of user interface (language-mode) and the telnet command. The operation of saving configuration file is not allowed on this level of commands.
l Monitor level: Commands of this level, including the display command and the debugging command, are used for system maintenance, service fault diagnosis, etc. The operation of saving configuration file is not allowed on this level of commands.
l System level: Service configuration commands, including routing command and commands on each network layer, are used to provide direct network service to the user.
l Manage level: They are commands that influence basis operation of the system and system support module, which plays a support role on service. Commands of this level involve file system commands, FTP commands, TFTP commands, XModem downloading commands, user management commands, and level setting commands.
At the same time, login users are classified into four levels that correspond to the four command levels respectively. After users of different levels log in, they can only use commands at the levels that are equal to or lower than their own level.
In order to prevent unauthorized users from illegal intrusion, users will be authenticated when switching from a lower level to a higher level with super [ level ] command. User ID authentication is performed when users at lower level switch to users at higher level. If users pass the authentication, they will switch to a higher level; otherwise, they will remain at the original user level.
Different command views are implemented according to different requirements. They are related to one another. For example, after logging into the switch, you will enter user view, in which you can only use some basic functions such as displaying the running state and statistics information. In user view, key in system-view to enter system view, in which you can key in different configuration commands and enter the corresponding views.
The command line provides the following views:
l User view
l System view
l Port view
l VLAN view
l VLAN interface view
l Local-user view
l User interface view
l FTP Client command view
l SFTP Client view
l MST region view
l PIM view
l MSDP view
l IPv4 multicast sub-address family view
l RIP view
l OSPF view
l OSPF area view
l BGP view
l IS-IS view
l Route policy view
l Basic ACL view
l Advanced ACL view
l Layer-2 ACL view
l Conform-level view
l WRED index view
l RADIUS server group view
l ISP domain view
l MPLS view
l VPNv4 sub-address family view
l VPN-instance sub-address family view
l BGP-VPNv4 sub-address family view
l MPLS L2VPN view
l L2VPN address family view
l Route-Policy view
l vpn-instance view
l OSPF protocol view
l Remote-peer view
l VSI-LDP view
l VSI view
l HWTACACS view
l Port group view
l Lanswitch view
l HGMP view
l NQA test group view
The following table describes the function features of different views and the ways to enter or quit. Port numbers are only for examples.
Table 1-1 Function feature of command view
Command view |
Function |
Prompt |
Command to enter |
Command to exit |
User view |
Show the basic information about operation and statistics |
<H3C> |
Enter right after connecting the switch |
Use quit to end the disconnection with the switch |
System view |
Configure system parameters |
[H3C] |
Key in system-view in user view |
Use quit or return to return to user view |
Port view |
Ethernet port view: Configure Ethernet port parameters |
100M Ethernet port view Key in interface ethernet 2/1/1 in system view |
Use quit to return to system view Use return to return to user view |
[H3C-GigabitEthernet2/1/1] |
GigabitEthernet port view Key in interface gigabitethernet 2/1/1 in system view |
10G Ethernet port view Key in interface gigabitethernet 2/1/1 in system view |
POS port view: Configure POS port parameters |
[H3C-Pos2/1/1] |
Key in interface pos 2/1/1 in system view |
RPR logical port view: Configure RPR port parameters |
[H3C- RprPos 3/1/1] |
Key in interface RprPos 3/1/1 in system view |
RPR POS physical port view: Configure physical parameters for RPR ports |
[H3C-RprPos2/1/1.1] |
Key in interface RprPos2/1/1.1 in system view |
VLAN view |
Configure VLAN parameters |
[H3C-Vlan1] |
Key in vlan 1 in system view |
VLAN interface view |
Configure IP interface parameters for a VLAN or a VLAN aggregation |
[H3C-Vlan-interface1] |
Key in interface vlan-interface 1 in system view |
Local-user view |
Configure local user parameters |
[H3C-luser-user1] |
Key in local-user user1 in system view |
User interface view |
Configure user interface parameters |
[H3C-ui0] |
Key in user-interface 0 in system view |
FTP client command view |
Configure FTP Client parameters |
[ftp] |
Key in ftp in user view |
Use quit to return to system view |
SFTP Client view |
Configure SFTP Client parameters |
<sftp-client> |
Key in sftp ip-address in system view |
MST region view |
Configure MST region parameters |
[H3C-mst-region] |
Key in stp region-configuration in system view |
PIM view |
Configure PIM parameters |
[H3C-PIM] |
Key in pim in system view |
MSDP view |
Configure MSDP parameters |
[H3C-msdp] |
Key in msdp in system view |
IPv4 multicast sub-address family view |
Enter the IPv4 multicast sub-address family view to configure MBGP multicast extension parameters |
[H3C-bgp-af-mul] |
Key in ipv4-family multicast in BGP view |
Use quit to return to BGP view Use return to return to user view |
RIP view |
Configure RIP parameters |
[H3C-rip] |
Key in rip in system view |
OSPF view |
Configure OSPF parameters |
[H3C-ospf-1] |
Key in ospf in system view |
OSPF area view |
Configure OSPF area parameters |
[H3C-ospf- 1-area-0.0.0.1] |
Key in area 1 in OSPF view |
Use quit to return to OSPF view Use return to return to user view |
BGP view |
Configure BGP parameters |
[H3C-bgp] |
Key in bgp 100 in system view |
IS-IS view |
Configure IS-IS parameters |
[H3C-isis] |
Key in isis in system view |
Route policy view |
Configure route policy parameters |
[H3C-route-policy] |
Key in route-policy policy1 permit node 10 in system view |
Basic ACL view |
Define the rule of basic ACL |
[H3C-acl- basic-2000] |
Key in acl number 2000 in system view |
Advanced ACL view |
Define the rule of advanced ACL |
[H3C-acl-adv-3000] |
Key in acl number 3000 in system view |
Layer-2 ACL view |
Define the rule of layer-2 ACL |
[H3C-acl-link-4000] |
Key in acl number 4000 in system view |
Conform-level view |
Configure the "DSCP + Conform-level Service group" mapping table and ”EXP + Conform-level- >service parameters” mapping table and "Local-precedence + Conform-level 802.1p priority" mapping table |
[H3C-conform-level-0] |
Key in qos conform-level 0 in system view |
WRED index view |
Configure WRED parameters |
[H3C-wred-0] |
Key in wred 0 in system view |
RADIUS server group view |
Configure radius parameters |
[H3C-radius-1] |
Key in radius scheme 1 in system view |
ISP domain view |
Configure ISP domain parameters |
[H3C-isp-h3c163.net] |
Key in domain h3c163.net in system view |
Use to return to system view Use return to return to user view |
MPLS view |
Configure MPLS parameters |
[H3C-mpls] |
Key in mpls in system view |
VPNv4 sub-address family view |
Configure VPNv4 address family parameters |
[H3C-bgp-af-vpn] |
Key in ipv4-family vpnv4 in BGP view |
VPN-instance sub-address family view |
Configure VPN instance sub-address family parameters |
[H3C-bgp-af-vpn-instance] |
Key in ipv4-family vpn-instance vpna in BGP/RIP view |
BGP-VPNv4 sub-address family view |
Configure BGP-VPNv4 sub-address family parameters |
[H3C-bgp-af-vpn] |
Key in ipv4-family vpn-instance in BGP/RIP view |
MPLS L2VPN view |
Configure MPLS L2VPN service parameters |
[H3C-mpls-l2vpn-vpna] |
Key in mpls l2vpn vpna encapsulation Ethernet in system view |
L2VPN address family view |
Configure L2VPN service parameters |
[H3C-bgp-af-l2vpn] |
Key in l2vpn-family in BGP view |
Route-Policy view |
Configure Route-Policy service parameters |
Key in route-policy route-policy-name { permit | deny } node node-number in system view |
vpn-instance view |
Configure vpn-instance parameters |
[H3C-vpn-vpn-instance_blue] |
Key in ip vpn-instance vpn-instance_ vpna in system view |
OSPF protocol view |
Configure OSPF protocol parameters |
[H3C-ospf-100] |
Key in ospf process-id [ router-id router-id-number ] [ vpn-instance vpn-instance-name ] in system view |
Remote-peer view |
Configure MPLS peer group parameters |
[H3C-mpls-remote1] |
Key in mpls remote1 |
VSI-LDP view |
Configure some VPLS features |
[9500-vsi-H3C-ldp] |
Key in vsi H3C in system view Key in pwsignal ldp in vsi view |
Use quit to return to vsi view Use return to return to user view |
VSI view |
Specify VPLS mode |
[9500-vsi-H3C] |
Key in vsi H3C in system view |
HWTACACS view |
Configure HWTACACS protocol parameters |
[9500-hwtacacs-H3C] |
Key in hwtacacs scheme H3C in system view |
Port group view |
Combine the ports with the same configuration, omitting repeated configuration procedure |
[9500-port-group X] |
Key in port-group X in system view |
HGMP view |
Configure some HGMP features |
[H3C-hgmp] |
Key in hgmpserver enable in system view |
Lanswitch view |
Enter lanswitch view. After entering the specified lanswitch view, you can use the specified S9500 series switch. |
[H3C-lanswitchX/X/X-/] |
Key in lanswitch X/X/X-/ in HGMP view |
Use quit to return to HGMP view Use return to return to user view |
NQA test group view |
Create a NQA test group, and enter NQA test group view |
[H3C-administrator-icmp] |
Key in NQA administrator-name test-tag in system view |
The command line interface provides the following online help modes.
l Full help
l Partial help
You can get the help information through these online help commands, which are described as follows.
1) Input “?” in any view to get all the commands in it and corresponding descriptions.
<H3C> ?
User view commands:
language-mode Specify the language environment
ping Ping function
quit Exit from current command view
super Privilege current user a specified priority level
telnet Establish one TELNET connection
tracert Trace route function
2) Input a command with a “?” separated by a space. If this position is for keywords, all the keywords and the corresponding brief descriptions will be listed.
<H3C> language-mode ?
chinese Chinese environment
english English environment
3) Input a command with a “?” separated by a space. If this position is for parameters, all the parameters and their brief descriptions will be listed.
[H3C] garp timer leaveall ?
INTEGER<65-32765> Value of timer in centiseconds
(LeaveAllTime > (LeaveTime [On all ports]))
Time must be multiple of 5 centiseconds
[H3C] garp timer leaveall 300 ?
<cr>
<cr> indicates no parameter in this position. The next command line repeats the command, you can press <Enter> to execute it directly.
4) Input a character string followed by a “?”, then all the commands beginning with this character string will be listed.
<H3C> p?
ping pwd
5) Enter a command followed by a character string and a “?”. All the keywords starting with this string are listed.
<H3C> display ver?
version
6) Press <Tab> after entering the first several letters of a keyword to display the complete keyword, provided these letters can uniquely identify the keyword in this command.
For the information to be displayed exceeding one screen, pausing function is provided. In this case, users can have three choices, as shown in the table below.
Table 1-2 Functions of displaying
Key or Command |
Function |
Press <Ctrl+C> when the display pauses |
Stop displaying and executing command. |
Enter a space when the display pauses |
Continue to display the next screen of information. |
Press <Enter> when the display pauses |
Continue to display the next line of information. |
Command line interface provides the function similar to that of DosKey. The commands entered by users can be automatically saved by the command line interface and you can invoke and execute them at any time later. History command buffer defaults to 10. The operations are shown in the table below.
Table 1-3 Retrieve history command
Operation |
Key |
Result |
Display history command |
display history-command [ command-number ] [ | { begin | include | exclude } Match-string ] |
Display history command by user inputting |
Retrieve the previous history command |
Up cursor key <↑> or <Ctrl+P> |
Retrieve the previous history command, if there is any. |
Retrieve the next history command |
Down cursor key <↓> or <Ctrl+N> |
Retrieve the next history command, if there is any. |
& Note:
Cursor keys can be used to retrieve the history commands in Windows 3.X Terminal and Telnet. However, in Windows 9X HyperTerminal, the cursor keys ↑ and ↓ do not work, because Windows 9X HyperTerminal defines the two keys differently. In this case, use the combination keys <Ctrl+P> and <Ctrl+N> instead for the same purpose.
All the commands input by users can be correctly executed, if they have passed the grammar check. Otherwise, error messages will appear. The common error messages are listed in the following table.
Table 1-4 Common command line error messages
Error messages |
Causes |
Unrecognized command |
Cannot find the command. |
Cannot find the keyword. |
Wrong parameter type. |
The value of the parameter exceeds the range. |
Incomplete command |
The input command is incomplete. |
Too many parameters |
Enter too many parameters. |
Ambiguous command |
The parameters entered are not specific. |
Command line interface provides the basic command editing function and supports to edit multiple lines. A command cannot be longer than 256 characters. See the table below.
Key |
Function |
Common keys |
Insert from the cursor position and the cursor moves to the right, if the edition buffer still has free space. |
Backspace |
Delete the character preceding the cursor and the cursor moves backward. |
Leftwards cursor key <←> or <Ctrl+B> |
Move the cursor a character backward |
Rightwards cursor key <→> or <Ctrl+F> |
Move the cursor a character forward |
Up cursor key <↑> or <Ctrl+P> Down cursor key <↓> or <Ctrl+N> |
Retrieve the history command. |
<Tab> |
Pressing <Tab> after entering part of a keyword enables the fuzzy help function. If finding a unique match, the system substitutes the complete keyword for the incomplete one and displays it in the next line. If there are several matches or no match at all, the system does not modify the incomplete keyword and displays it again in the next line. |
