H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesReference GuidesCommand ReferencesH3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
35-Information Center Commands
35-Information Center Commands 173 KB
Chapter 1  Information Center Commands
1.1  Information Center Commands
1.1.1  display channel
display channel [ channel-number | channel-name ]
View
channel-number: Channel number, ranging from 0 to 9, that is, the system has ten channels.
channel-name: Channel name. By default, the names of channel 0 to channel 9 are console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, and channel9.
Use the display channel command to display the settings of an information channel.
If no argument is provided, the settings of all channels are displayed.
# Show details about information channel 0.
<H3C> display channel 0
channel number:0, channel name:console
MODU_ID   NAME     ENABLE   LOG_LEVEL     ENABLE   TRAP_LEVEL    ENABLE    DEBUG_LEVEL
ffff0000 default  Y      warning       Y      debugging     Y      debugging
1.1.2  display info-center
display info-center
View
None
Use the display info-center command to display the operation status of the information center, the configuration of information channels, and the format of time stamp.
If the number of the messages in the current log/trap buffer is less than the buffer size specified by a user, this command is used to display the actual log/trap information.
Related commands: info-center enable, info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel, info-center trapbuffer, info-center snmp channel, info-center timestamp.
# Display information about the information center.
<H3C> display info-center
Information Center:enabled
Log host:
Console:
Monitor:
        channel number:1, channel name:monitor
SNMP Agent:
        channel number:5, channel name:snmpagent
Log buffer:
        enabled, max buffer size:1024, current buffer size:256
        current messages:2, channel number:4, channel name:logbuffer
        dropped messages:0, overwritten messages:0
Trap buffer:
        current messages:0, channel number:3, channel name:trapbuffer
Information timestamp setting:
        log - date, trap - date, debug – boot
Table 1-1 Description on the fields of the display info-center command
Information Center:
Log host:
Information about the log host, including its IP address, name and number of information channel, language and level
Console:
Information about the console port, including name and number of its information channel
Monitor:
Information about the monitor port, including name and number of its information channel
SNMP Agent:
Information about SNMP Agent, including name and number of its information channel
Log buffer:
Information about the log buffer, including its state (enabled/disabled), maximum size, current size, number of current messages, information channel name and number, number of dropped messages, and number of overwritten messages
Trap buffer:
Information about the trap buffer, including its state (enabled/disabled), maximum size, current size, number of current messages, channel number and name, number of dropped messages, and number of overwritten messages
Information about time stamp, describing the time stamp formats of log information, trap information, and debugging information
1.1.3  display logbuffer
display logbuffer [ level severity | size buffersize ]* [ | { begin | exclude | include } regular-expression ]
View
level severity: Specifies an information severity level. The severity argument ranges from 1 to 8.
Table 1-2 Severity definitions made on the information center
Severity
Value
emergencies
1
Emergent errors
alerts
2
Errors that need to be corrected immediately
critical
3
Critical errors
errors
4
Errors that need to be considered but are not critical
warnings
5
Warnings that prompt possible errors
notifications
6
Information that needs to be noticed
informational
7
Normal prompting information
debugging
8
Debugging information
size buffersize: Specifies the size of the log buffer (number of messages the log buffer holds) you want to display. The buffersize argument ranges from 1 to 1,024 and defaults to 512.
|: Specifies to filter output log information with a regular expression.
begin: Specifies to display the log information beginning with the specified characters.
exclude: Specifies to display the log information excluding the specified characters.
include: Specifies to display the log information including the specified characters.
regular-expression: Regular expression.
Table 1-3 Special characters in regular expression.
Special characters
Usage restrictions
_
The underscore, functions like a wildcard, and can represent the following characters:
^ –– Caret
$ –– Dollar sign
| –– Alternation sign
[ –– Left bracket
, –– Comma
( ) –– Left/right parenthesis
{ } –– Left/right brace
] –– Right bracket
Space
Start/stop character
If the first character of a regular expression is not ‘_’, the number of ‘_’ used in the expression is not restricted, but is restricted by the length of a command line.
If the first character is ‘_’, the number of consecutive “_” should be less than 5;
If the ‘_’ characters are not consecutive, the output information will be filtered by the first group of ‘_’, and the remaining ‘_’ characters will not be processed.
The left parenthesis, the push-onto-the-stack flag in programming
You are recommended not to use this character to establish a regular expression.
Use the display logbuffer command to display the state of logbuffer and the information recorded in logbuffer.
# Display the state of logbuffer and the log information recorded in the logbuffer.
<H3C> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 0
Current messages : 91
...... (Omitted)
1.1.4  display logbuffer summary
display logbuffer summary [ level severity ]
View
Level severity: Specifies an information severity level. The severity argument ranges from 1 to 8.
Use the display logbuffer summary command to display the statistics of the log buffer.
# Display summary information recorded in logbuffer.
<H3C> display logbuffer summary
SLOT EMERG ALERT  CRIT ERROR  WARN NOTIF  INFO DEBUG
     0     0     0     0     0     0     0     0     0
     1     0     0     0     0     0     0     0     0
1.1.5  display trapbuffer
display trapbuffer [ size buffersize ]
View
size buffersize: Specifies the size of the trap buffer (number of messages the buffer holds) you want to display. The buffersize argument ranges from 1 to 1,024 and defaults to 256.
Use the display trapbuffer command to display the status of the trap buffer and the trap information recorded in the trap buffer.
Executing the command with the size buffersize parameters will display the latest trap records.
# Display the trapbuffer status and the trap information in trapbuffer.
<H3C> display trapbuffer
Trapping Buffer Configuration and contents:enabled
allowed max buffer size : 1024
actual buffer size : 256
channel number : 3 , channel name : trapbuffer
dropped messages : 0
overwritten messages : 0
current messages : 6
#Dec 31 14:01:25 2004 H3C DEV/2/LOAD FINISHED:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.20: frameIndex is 0, slotIndex 0.4
#Dec 31 14:01:33 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.11: frameIndex is 0, slotIndex 0.2
#Dec 31 14:01:40 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
…(Omitted)
1.1.6  info-center channel
info-center channel channel-number name channel-name
undo info-center channel channel-number
View
channel-name: Channel name, a string of up to 30 characters, excluding "-", "/" or "\". And the first character must not be a number.
Use info-center channel name command to name a channel specified by channel-number as channel-name.
Use undo info-center channel command to restore the default channel name.
By default, the names of channels 0 to channel 9 are console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, and channel9.
Note that channel names must not be the same as each other.
# Name the channel 0 as execconsole.
<H3C> system-view
[H3C] info-center channel 0 name execconsole
1.1.7  info-center console channel
info-center console channel { channel-number | channel-name }
undo info-center console channel
View
channel-name: Channel name, by default, the names of channels 0 to channel 9 are console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, and channel9.
Use the info-center console channel command to configure the channel through which the log information is output to the console.
Use the undo info-center console channel command to restore the default channel through which the log information is output to the console.
By default, Ethernet switches output log information to the console through channel 0.
This command takes effect only after the information center function is enabled.
Related commands: info-center enable, display info-center.
# Configure to output log information to the console through channel 7.
<H3C> system-view
[H3C] info-center console channel 7
1.1.8  info-center enable
info-center enable
undo info-center enable
View
none
Use the info-center enable command to enable the information center function.
Use the info-center enable command to disable the information center function.
The switch can output system information to the log host, the console, and other destinations only when the information center function is enabled.
By default, the information center function is enabled.
Related commands: display info-center, info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel, info-center trapbuffer, info-center snmp channel.
# Enable the information center function.
<H3C> system-view
[H3C] info-center enable
% information center is enabled
1.1.9  info-center logbuffer
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ]* [ | exclude regular-expression ]
undo info-center logbuffer [ channel | size | | exclude regular-expression ]
View
channel: Configures the channel whereby to output information to the buffer.
channel-name: Channel name, by default, the names of channels 0 to channel 9 are (in turn) console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, and channel9.
size buffersize: Specifies the size of the log buffer (number of messages the buffer holds). The buffersize argument ranges from 0 to 1,024 and defaults to 512.
|: Specifies to filter output log information using a regular expression.
exclude: Specifies to output the log information excluding the specified characters.
For special characters used in the regular expression, refer to Table 1-3.
Use the info-center logbuffer command to configure information output to the log buffer.
Use the undo info-center logbuffer command to cancel the configuration.
By default, the system outputs information to the log buffer, which can hold 512 messages.
This command takes effect only when the information center function is enabled for the system.
# Send log information to the log buffer and set the size of log buffer to 50.
<H3C> system-view
[H3C] info-center logbuffer size 50
# Send log information not containing the command character to the log buffer.
<H3C> system-view
[H3C] info-center logbuffer | exclude command
1.1.10  info-center loghost
info-center loghost host-ip-addr [ channel { channel-number | channel-name } | facility local-number | language { chinese | english } ]*
undo info-center loghost host-ip-addr
View
host-ip-addr: IP address of info-center loghost.
channel: Configures information channel of the info-center loghost.
facility: Configures the recording tool of info-center loghost.
local-number: Record tool of info-center loghost, ranging from local0 to local7.
language: Sets the logging language.
chinese,english: Switches language used in log file between Chinese and English.
Use the info-center loghost command to enable information output to the loghost.
Use the undo info-center loghost command to cancel the configuration.
By default, the system does not output information to the loghost.
This command works only when the information center function is enabled for the system.
&  Note:
Be sure to set a correct IP address in the info-center loghost command. A loopback IP address will cause an error message prompting an invalid address.
# Configure the Ethernet switch to send information to the workstation Unix whose IP address is 202.38.160.1.
<H3C> system-view
[H3C] info-center loghost 202.38.160.1
1.1.11  info-center loghost source
undo info-center loghost source
View
interface-type: Interface type.
interface-number: Interface number.
Use the info-center loghost source command to configure the source interface through which log information is sent to the loghost.
Use the undo info-center loghost source command to cancel the source interface configuration.
# Specify the source address of the packets sent to the loghost as the address of the VLAN 1 interface.
<H3C> system-view
[H3C] info-center loghost  source Vlan-interface 1
1.1.12  info-center monitor channel
info-center monitor channel { channel-number | channel-name }
undo info-center monitor channel
View
Use the info-center monitor channel command to set the channel through which information is output to user terminals.
Use the undo info-center monitor channel command to restore the default channel through which the information is output to user terminals.
By default, the system outputs information to user terminals.
This command takes effect only when the information center function is enabled.
# Configure channel 0 for outputting log information to user terminals.
<H3C> system-view
[H3C] info-center monitor channel 0
1.1.13  info-center snmp channel
info-center snmp channel { channel-number | channel-name }
undo info-center snmp channel
View
Use the info-center snmp channel command to set the channel through which information is output to the SNMP agent.
Use the undo info-center snmp channel command to restore the default channel through which information is output to the SNMP agent.
By default, the system outputs information to SNMP Agent through channel 5.
Related commands: snmp-agent, display info-center.
# Configure the system to output information to the SNMP agent through channel 6.
<H3C> system-view
[H3C] info-center snmp channel 6
1.1.14  info-center source
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state }* | log { level severity | state state }* | trap { level severity | state state }* ]*
undo info-center source { module-name | default } channel { channel-number | channel-name }
View
modu-name: Module name. Refer to Table 1-4 for the detail.
Table 1-4 Modules generating the information
Module name
8021X
802.1x module
ACCOUNT
L3+ real time accounting module
ACL
Access control list module
ADBM
Address base module
AM_USERB
Access management module
ARP
Address resolution protocol module
BGP
Border gateway protocol module
CFAX
Configuration agent module
CFM
Configuration file management module
CLNP
Connectionless network protocol module
CLNSECHO
Connectionless network protocol echo module
CLST
Cluster management module
CMD
Command line module
DEV
Device management module
DHCP
Dynamic host configuration protocol module
DHCPS
DHCP server module
DHCPSNP
DHCP snooping module
DIAG
Diagnosis module
DLDP
Device link detection protocol module
DNS
Domain name system module
ENTEXMIB
Entity extended MIB module
ENTITY
ENTITY module
ESIS
End system to intermediate system routing protocol module
ETH
Ethernet module
FIB
Forwarding information base module
FTPS
FTP server module
HA
High availability module
HABP
Huawei authentication bypass protocol module
HTTPD
HTTP server module
HWCM
Huawei Configuration Management proprietary MIB module
HWP
HWPing module
IFNET
Interface management module
IGSP
IGMP snooping module
IP
Internet protocol module
IPX
IPX protocol module
ISIS
Intermediate system-to-intermediate system intra-domain routing information exchange protocol module
L2INF
Layer 2 interface management module
LACL
Lanswitch access control list module
LARP
LETH
Ethernet debugging module
LQOS
Lanswitch quality of service module
LS
Local server module
MIX
Dual main control network management module
MODEM
MODEM module
MPM
Multicast port management module
MSDP
Multicast source discovery protocol module
MSTP
Multiple spanning tree protocol module
NAT
Network address translation module
NDP
Neighbor discovery protocol module
NETSTREA
Traffic statistic module
NTDP
Network topology discovery protocol module
NTP
Network time protocol module
OSPF
Open shortest path first module
RDS
Radius module
RM
Routing management module
RMON
Remote monitor module
RMX
IPX routing module
RRPP
Rapid ring protection protocol module
RSA
Revest, Shamir and Adleman encryption module
RTA
L3+ plug-in card traffic accounting module
RTPRO
Routing protocol module
SC
Server control module
SHELL
User interface module
SNMP
Simple network management protocol module
SOCKET
Socket module
SSH
Secure shell module
SYSM
System management module
SYSMIB
System MIB module
TAC
Terminal access controller module
TELNET
Telnet module
TFTPC
TFTP client module
TUNNEL
Packets transparent transmission module
UDPH
UDP helper module
USERLOG
User log module
VFS
Virtual file system module
VLAN
Virtual local area network module
VRRP
VRRP (virtual router redundancy protocol) module
VTY
VTY (virtual type terminal) module
default
Default settings of all modules
default: Defaults the settings of all modules.
channel-number: Number of information channel to be used.
log: Specifies to output log information.
trap: Specifies to output trap information.
debug: Specifies to output debugging information.
level: Specifies an information severity level.
severity: Information severity. The information below this severity will not be output.
Information at different levels is as follows:
emergencies: Level 1 information, indicates that the system is not available.
alerts: Level 2 information, requiring immediate reaction.
critical: Level 3 information, critical information.
errors: Level 4 information, error information.
warnings: level 5 information, warning information.
notifications: Level 6 information, normal but important information.
informational: Level 7 information, notice to be recorded.
debugging: Level 8 information, generated during the debugging process.
The default information level of each channel is shown in the following table.
Table 1-5 Default information level of each channel
channel
Log information level
Trap information level
Debugging information level
Console
warning
debugging
debugging
Terminal
warning
debugging
debugging
Log host
informational
debugging
debugging
Trapbuffer
informational
warning
debugging
Logbuffer
warning
debugging
debugging
SNMPagent
debugging
warning
debugging
Channel6
debugging
debugging
debugging
Channel7
debugging
debugging
debugging
Channel8
debugging
debugging
debugging
Channel9
debugging
debugging
debugging
The default state of each channel is shown in the following table.
Table 1-6 Default state of each channel for different types of information
Channel
Log information
Trap information
Debug information
Console
Enable
Enable
Enable
Terminal
Enable
Enable
Enable
Log host
Enable
Enable
Disable
Trapbuffer
Disable
Enable
Disable
Logbuffer
Enable
Disable
Disable
SNMPagent
Disable
Enable
Disable
Channel6
Enable
Enable
Disable
Channel7
Enable
Enable
Disable
Channel8
Enable
Enable
Disable
Channel9
Enable
Enable
Disable
state: State of information.
state: on or off.
Use the info-center source command to specify the information source in the information center and the output direction.
Use the undo info-center source command to cancel the configured information source and output direction.
This command can be used for filtering log, trap or debugging information. For example, it can control information output from the IP module to a self-defined direction. You can configure to output information with a severity higher than “warning” to the log host, and information with a severity higher than “informational” to the log buffer. You can also configure to output trap information to the log host at the same time.
The info-center source command determines the output direction according to a channel name or channel number. Each output direction is assigned a default information channel at present, as shown in the following table.
Table 1-7 Default information channel in each output direction
Output direction
Information channel name
Console
console
Monitor
monitor
Info-center loghost
loghost
Log buffer
logbuffer
Trap buffer
trapbuffer
Snmpagent
snmpagent
In addition, each information channel has a default record with a module name of “default” and a module number of 0xffff0000. However, for different information channels, the default log, trap and debugging settings in the records may be different from one another. Use the default configuration record if a module does not have any explicit configuration record in the channel.
# Enable the output of log information of the VLAN module in SNMP channel and allow the output of the information with a severity higher than or equal to “emergencies”.
<H3C>system-view
[H3C] info-center source vlan channel snmp log level emergencies
1.1.15  info-center timestamp
info-center timestamp { log | trap | debugging } { boot | date | none }
undo info-center timestamp { log | trap | debugging }
View
log: Specifies log information.
trap: Specifies trap information.
debugging: Specifies debugging information.
boot: Time elapsed since system boot, which is in the format of “xxxxxx.yyyyyy”. “xxxxxx” is the most significant 32 bits and “yyyyyy” is the least significant 32 bits of the elapsed milliseconds.
date: Current system date and time, which is in the format “yyyy/mm/dd-hh:mm:ss:ms” for Chinese environment and “Mmm dd hh:mm:ss:ms yyyy” for English environment.
none: Specifies not to include time stamp in output information.
Use the info-center timestamp command to configure the timestamp output format in debugging/trap information.
Use the undo info-center timestamp command to restore the default settings.
By default, the date time stamp is adopted for all types of information.
# Configure the debugging information timestamp format as boot.
<H3C> system-view
[H3C] info-center timestamp debugging boot
1.1.16  info-center trapbuffer
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ]*
undo info-center trapbuffer [ channel | size ]
View
size: Configures the size of the trap buffer.
buffersize: Size of trap buffer (numbers of messages). This argument ranges from 0 to 1,024 and defaults to 256.
channel: Sets the channel through which information is sent to the trap buffer.
channel-name: Channel name. By default, the names of channels 0 to channel 9 are console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, and channel9.
Use the info-center trapbuffer command to enable information output to the trap buffer.
Use the undo info-center trapbuffer command to disable information output to the trap buffer.
By default, the system outputs information to the trap buffer, and the size of the trap buffer is 256.
You can configure the system to output information to the trap buffer by setting the size of the trap buffer.
# Send information to the trap buffer and set the size of buffer to 30.
<H3C>system-view
[H3C] info-center trapbuffer size 30
1.1.17  reset logbuffer
reset logbuffer
View
none
Use the reset logbuffer command to remove information in log buffer.
# Clear information in log buffer.
<H3C> reset logbuffer
1.1.18  reset trapbuffer
reset trapbuffer
View
none
Use the reset trapbuffer command to remove information in trap buffer.
# Clear information in trap buffer.
<H3C> reset trapbuffer
1.1.19  terminal debugging
terminal debugging
undo terminal debugging
View
none
Use the terminal debugging command to configure to display the debugging information on the terminal.
Use the undo terminal debugging command to configure not to display the debugging information on the terminal.
By default, the displaying function is disabled for the terminal.
Related commands: debugging commands in the “System Maintaining and Debugging” part of the manual.
# Enable the terminal debugging display function.
<H3C> terminal debugging
% Current terminal debugging is on
1.1.20  terminal logging
terminal logging
undo terminal logging
View
none
Use the terminal logging command to enable terminal log information display.
Use the undo terminal logging command to disable terminal log information display.
By default, this function is enabled for console users and terminal users.
# Disable the terminal log display function.
<H3C> undo terminal logging
% Current terminal logging is off
1.1.21  terminal monitor
terminal monitor
undo terminal monitor
View
none
Use the terminal monitor command to enable the debugging/log/trap information terminal display function.
Use the undo terminal monitor command to disable these functions.
By default, these functions are enabled for console users and terminal users.
This command only takes effect on the current terminal where the command is input. The debugging/log/trap information can be output to the current terminal only when you execute this command in user view. When the terminal monitor is disabled, no debugging/log/trap information will be displayed in local terminal, which is equal to having performed undo terminal debugging, undo terminal logging, and undo terminal trapping commands. When the terminal monitor is enabled, you can use terminal debugging / undo terminal debugging, terminal logging / undo terminal logging and terminal trapping / undo terminal trapping respectively to enable or disable the corresponding functions.
# Disable the terminal monitor function.
<H3C> undo terminal monitor
% Current terminal monitor is off
1.1.22  terminal trapping
terminal trapping
View
None
Use the terminal trapping command to enable terminal trap information display.
Use the undo terminal trapping command to disable this function.
By default, this function is enabled.
# Enable trap information display.
<H3C> terminal trapping
% Current terminal trapping is on
