- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 20-Traffic Accounting Commands | 56 KB |
Chapter 1 Traffic Accounting Configuration Commands
1.1 Traffic Accounting Configuration Commands
1.1.3 debugging traffic-accounting event
1.1.4 display traffic-accounting accounting-slot
1.1.5 display traffic-accounting statistics
1.1.6 display traffic-accounting traffic-group
1.1.8 traffic-accounting accounting-slot
1.1.9 traffic-accounting traffic-group
1.1.1 accounting enable
accounting enable
undo accounting enable
View
Traffic accounting view
None
Use the accounting enable command to enable the traffic accounting function on the traffic accounting card.
Use the undo accounting enable command to disable the traffic accounting function on the traffic accounting card.
The traffic accounting card starts traffic accounting immediately after the traffic accounting function is enabled.
By default, the traffic accounting function is disabled on the traffic accounting card.
# Enable the traffic accounting function.
<H3C> system-view
[H3C] traffic-accounting accounting-slot 3
[H3C-accounting-slot-3] accounting enable
# Disable the traffic accounting function.
[H3C-accounting-slot-3] undo accounting enable
1.1.2 accounting-mode traffic
View
ISP domain view
None
Use the accounting-mode traffic command to set the accounting mode to traffic accounting.
Use the undo accounting-mode traffic command to restore the default accounting mode.
By default, the system adopts the time-based accounting mode.
# Set the accounting mode to traffic accounting.
<H3C> system-view
[H3C] domain cams
[H3C-isp-cams] accounting-mode traffic
# Restore the default accounting mode.
[H3C-isp-cams] undo accounting-mode traffic
View
None
Use the debugging traffic-accounting event command to turn on debugging for traffic accounting.
Use the undo debugging traffic-accounting event command to turn off debugging for traffic accounting.
By default, debugging is turned off for traffic accounting.
# Turn on debugging for traffic accounting.
<H3C> debugging traffic-accounting event
display traffic-accounting accounting-slot [ slot-num ]
View
slot-num: Traffic accounting slot.
Use the display traffic-accounting-slot command to display the configuration information of the traffic accounting slots.
If you specify the slot-num argument, the command is executed to display the configuration information of the specified traffic accounting slot. Otherwise, the command is executed to display the configuration information of all traffic accounting slots.
& Note:
At present, the system supports only one traffic accounting slot. Therefore the same configuration information is displayed regardless of whether you specify the traffic accounting slot.
# Display the configuration information of traffic accounting slot 3.
<H3C> display traffic-accounting accounting-slot 3
Accounting slot number : 2
traffic-slot 3
traffic accounting is enabled
display traffic-accounting statistics [ ip-address ]
View
ip-address: IP address.
Use the display traffic-accounting statistics command to display the traffic accounting statistics of one or all online users.
If you specify the ip-address argument, the command is executed to display the traffic accounting statistics of the specified online IP address. Otherwise, this command is executed to display the traffic accounting statistics of all the online IP addresses.
# Display the traffic accounting statistics of all online users.
<H3C> display traffic-accounting statistics
User IP: 10.0.0.1
group name :somegroup
output octets low-32: 1920 output octets high-32: 0
input octets low-32 : 480 input octets high-32 : 0
User IP: 10.0.0.2
display traffic-accounting traffic-group [ group-name ]
View
group-name: Name of a traffic group.
Use the display traffic-accounting traffic-group command to display the configuration information of one or all traffic groups.
If you specify the group-name argument, this command is executed to display the configuration information of the specified traffic group. Otherwise, it is executed to display the configuration information of all traffic groups.
# Display the configuration information of the traffic group named somegroup.
<H3C> display traffic-accounting traffic-group somegroup
Traffic group : somegroup
1.1.1.0/255.255.255.0
not used
# Display the configuration information of all traffic groups.
Traffic group : default-group
0.0.0.0/0.0.0.0
not used
used
1.1.7 network
network ip-address { mask | mask-len }
undo network ip-address { mask | mask-len }
View
Traffic group view
mask: Subnet mask.
Mask-len: Mask length.
Use the network command to configure a network address for the traffic group, so as to add a destination network segment to the traffic group.
Use the undo network command to remove a network address from the traffic group, so as to remove a destination network segment from the traffic group.
& Note:
The address range of the network segment to be set for a traffic group can neither overlap the existing address range of this traffic group nor be identical with the address range of any other traffic group.
# Add a network segment to the traffic group named somegroup.
<H3C> system-view
[H3C] traffic-accounting traffic-group somegroup
[H3C-traffic-group-somegroup] network 10.0.0.0 16
# Remove the network segment from the traffic group.
[H3C-traffic-group-somegroup] undo network 10.0.0.0 16
traffic-accounting accounting-slot slot-num
undo traffic-accounting accounting-slot slot-num
View
slot-num: Slot number.
Use the traffic-accounting accounting-slot command to specify a traffic accounting slot.
Use the undo traffic-accounting accounting-slot command to remove the specified traffic accounting slot.
By default, no slot is specified as a traffic accounting slot.
Related commands: display traffic-accounting accounting-slot.
# Specify slot 2 as the traffic accounting slot.
<H3C> system-view
[H3C] traffic-accounting accounting-slot 2
# Remove the specified traffic accounting slot 2.
[H3C] undo traffic-accounting accounting-slot 2
traffic-accounting traffic-group group-name
undo traffic-accounting traffic-group group-name
View
group-name: Name of a traffic group, a string of up to 32 characters.
Use the traffic-accounting traffic-group command to create a traffic group or enter the view of an existing traffic group.
Use the undo traffic-accounting traffic-group command to delete an existing traffic group.
The system allows you to configure up to 15 traffic groups. In addition, there is a default traffic group that you are not allowed to configure.
By default, there is a default traffic group.
Related commands: display traffic-accounting traffic-group.
# Create a traffic group test-group.
<H3C> system-view
[H3C] traffic-accounting traffic-group test-group
# Delete the created traffic group test-group.
[H3C] undo traffic-accounting traffic-group test-group
1.1.10 traffic-group
traffic-group group-name rate id-num
View
Domain view
id-num: Charging rate ID, in the range 1 to 255, used to identify different charging rates. This argument is ignored in the current command, and it is reserved for future use.
Use the traffic-group command to configure the domain to use a traffic group.
Use the undo traffic-group command to cancel the configuration.
If a domain is configured to use a traffic group, the generated traffic is measured when a user belonging to the domain accesses an address in the traffic group and the user is charged for the traffic.
By default, no traffic group is used by a domain.
# Configure the domain CAMS to use the traffic group test-group, with the charge rate of 1.
<H3C> system-view
[H3C] domain cams
[H3C-isp-cams] traffic-group test-group rate 1
1.1.11 traffic-slot
traffic-slot slot-num
undo traffic-slot slot-num
View
Use the traffic-slot command to specify a traffic collection card.
Use the undo traffic-slot command to cancel the specified traffic collection card.
By default, no traffic collection card is specified.
Related commands: traffic-accounting accounting-slot.
# Specify slot 2 as the traffic accounting slot and slot 3 as the traffic collection slot.
<H3C> system-view
[H3C-accounting-slot-2] traffic-slot 3
