Title | Size | Downloads |
H3C S7500 LS81FT48E Card Manual(V1.01).pdf | 88 KB |
- H3C S7500 LS81GT8UE Card Manual(V1.01)
- H3C S7500 LS81GP8UB Card Manual(V1.01)
- H3C S7502 Ethernet Switch Installation Manual-(V1.02)
- H3C S7500 Series Ethernet Switches Compliance and Safety Manual-(V1.03)
- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
48端口10Base-T/100Base-TX快速以太网业务板-LS81FT48E
BOM: 3123A05Y
1 单板标识
前面板右上角标有丝印:LS81FT48E,用来标识该单板。
2 单板简介
属性 | LS81FT48E |
接口连接器类型 | RJ-45 |
接口数量 | 48 |
接口传输速率 | 10/100 Mbps半/全双工 MDI/MDI-X自适应 |
可选用线缆及最大传输距离 | 5类双绞线,传输距离100m |
单板适用的机型 | S7502/S7503/S7506/S7506R以太网交换机 |
单板适用的主机软件版本 | Release 3000系列/Release 3100系列 |
3 注意事项
l 如主机软件版本不匹配,可以联系该设备的销售商或集成商获取相应的主机软件版本。
l 单板安装说明及主机软件版本的升级方法请参见《H3C S7500系列以太网交换机 安装手册》或《H3C S7502以太网交换机 安装手册》相关章节。
l 单板种类或规格可能随产品版本的变更而改变,请从公司网站http://www.h3c.com.cn主页上的“文档中心”获取最新资料。
杭州华三通信技术有限公司
48-Port 10Base-T/100Base-TX Fast Ethernet Card-LS81FT48E
1 Card Identifier
The silkscreen LS81FT48E is printed at the upper right corner of the front panel, and is used to identify the card.
2 Specifications
Table1 LS81FT48E specifications
Item | LS81FT48E |
Connector | RJ-45 |
Port quantity | 48 |
Transmission rate | 10/100 Mbps half/full duplex MDI/MDI-X auto-sensing |
Cable | Category-5 twisted pair |
Maximum transmission distance | 100m (328 ft) |
Applied to | S7502/S7503/S7506/S7506R Ethernet Switch |
Host software version | Release 3000 Series/Release 3100 Series |
3 Note
l If the host software version does not match the one applicable to the card, contact the vendor or the integrator for the right version.
l For the introduction of card installation and host software upgrade, see the related part in H3C S7500 Series Ethernet Switches Installation Manual and H3C S7502 Ethernet Switch Installation Manual.
l As board types or specifications might change with product versions, you may need to obtain the latest documents from Technical Support & Document link on H3C website http://www.h3c.com.
Hangzhou H3C Technologies Co., Ltd
