- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 05-Extended VLAN Application Commands | 120 KB |
Chapter 1 Voice VLAN Configuration Commands
1.1 Voice VLAN Configuration Commands
1.1.2 display voice vlan status
1.1.9 voice vlan security enable
Chapter 2 Isolate-User-VLAN Configuration Commands
2.1 Isolate-User-VLAN Configuration Commands
2.1.1 display isolate-user-vlan
2.1.3 isolate-user-vlan enable
Chapter 3 Super VLAN Configuration Commands
3.1 Super VLAN Configuration Commands
1.1.1 display voice vlan oui
View
None
Use the display voice vlan oui command to display the currently supported OUI addresses and the related information.
Related commands: voice vlan, voice vlan enable.
# Display the OUI addresses of the voice VLAN.
<H3C> display voice vlan oui
Oui Address Mask Description
00e0-bb00-0000 ffff-ff00-0000 3com phone
0003-6b00-0000 ffff-ff00-0000 Cisco phone
00e0-7500-0000 ffff-ff00-0000 Polycom phone
00d0-1e00-0000 ffff-ff00-0000 Pingtel phone
000f-e200-0000 ffff-ff00-0000 H3C Aolynk phone
00aa-bb00-0000 ffff-ff00-0000 ABC
View
None
Use the display voice vlan status command to display voice VLAN-related information, including voice VLAN status (disabled/enabled), security mode, aging time, port voice VLAN mode (manual mode or automatic mode), and so on.
# Display information about the voice VLAN.
<H3C> display voice vlan status
Voice Vlan status: ENABLE
Voice Vlan ID: 2
Voice Vlan security mode: Security
Voice Vlan aging time: 1440 minutes
Current voice vlan enabled port mode:
PORT MODE
Ethernet1/0/2 MANUAL
Ethernet1/0/5 AUTO
Table 1-1 Description on the fields of the display voice vlan status command
Voice Vlan status |
The status of global voice VLAN function: enabled/disabled |
Voice Vlan ID |
The VLAN which is currently enabled with voice VLAN function. |
Voice Vlan security mode |
The status of voice VLAN security mode: enabled/disabled. |
Voice Vlan aging time |
The voice VLAN aging time |
Current voice vlan enabled port mode |
The operation mode of ports with the voice VLAN function enabled |
Ethernet1/0/2 MANUAL |
Port Ethernet 1/0/2 is in manual mode. |
Ethernet1/0/5 AUTO |
Port Ethernet 1/0/5 is in automatic mode. |
Caution:
The “Current voice vlan enable port mode” field lists the ports with the voice VLAN function enabled. Note that a port listed in this field may not currently operate in a voice VLAN. To check the ports operating in the current voice VLAN, use the display vlan command, which is described in section display vlan.
1.1.3 display vlan
display vlan vlan-id
View
vlan-id: Voice VLAN ID in the range of 1 to 4,094.
Use the display vlan command to display the automatic/manual ports in the current voice VLAN.
Related commands: voice vlan.
# Display the ports included in the current voice VLAN (the current voice VLAN is VLAN 6).
<H3C> display vlan 6
VLAN ID: 6
VLAN Type: static
Route Interface: not configured
Description: VLAN 0006
Tagged Ports:
GigabitEthernet1/0/5
Untagged Ports:
GigabitEthernet1/0/6
The output indicates that GigabitEthernet 1/0/5 and GigabitEthernet 1/0/6 ports are in the current voice VLAN.
1.1.4 voice vlan
voice vlan vlan-id enable
undo voice vlan enable
View
vlan-id: ID of the VLAN that needs to be enabled with the voice VLAN function, ranging from 2 to 4,094.
Use the voice vlan command to enable the voice VLAN function globally.
Use the undo voice vlan enable command to disable the voice VLAN function globally.
Caution:
l When you are enabling the voice VLAN function for a specified VLAN, the specified VLAN must exist; otherwise, your configuration will be failed.
l Before you can delete a VLAN with voice VLAN enabled, you must disable the voice VLAN function first.
l There can be only one voice VLAN at a time.
Related commands: display voice vlan status.
# Enable the voice VLAN function for VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] quit
[H3C] voice vlan 2 enable
# After VLAN 2 is configured as the voice VLAN, if you enable the voice VLAN function for other VLANs, the system will prompt that your configuration fails.
[H3C] voice vlan 4 enable
Can't change voice vlan configuration when other voice vlan is running
1.1.5 voice vlan aging
voice vlan aging minutes
undo voice vlan aging
View
minutes: Aging time (in minutes) to be set for the voice VLAN. This argument ranges from 5 to 43,200 and defaults to 1,440.
Use the voice vlan aging command to set the aging time for the voice VLAN.
Use the undo voice vlan aging command to restore the default aging time for the voice VLAN.
# Set the aging time of the voice VLAN to 100 minutes.
<H3C> system-view
[H3C] voice vlan aging 100
1.1.6 voice vlan enable
voice vlan enable
View
Ethernet port view
None
Use the voice vlan enable command to enable voice VLAN for a port.
Use the undo voice vlan enable command to disable voice VLAN for a port.
l The voice VLAN function takes effect on a port only when it is enabled in both system view and port view.
l An access port whose voice VLAN mode is automatic does not support the voice vlan enable command.
# Enable the voice VLAN function for Ethernet 1/0/2.
<H3C> system-view
[H3C] interface Ethernet 1/0/2
[H3C-Ethernet1/0/2] voice vlan enable
1.1.7 voice vlan mac-address
voice vlan mac-address oui mask oui-mask [ description text ]
undo voice vlan mac-address oui
View
oui: MAC address to be set. You need to provide this argument in the format of H-H-H.
& Note:
Organizationally unique identifier (OUI) is the first 24 bits of a MAC address. It is the globally unique identifier assigned by IEEE for different device suppliers.
oui-mask: MAC address mask in the format of H-H-H. This argument specifies the valid bits of the MAC address.
text: Description string of the MAC address. This argument can contain 1 to 30 characters.
Use the voice vlan mac-address command to set a MAC address used for a voice VLAN to identify voice devices.
Use the undo voice vlan mac-address command to disable a MAC address from being used to identify voice devices.
A switch can use up to 16 MAC addresses to identify voice devices, including the five default OUI addresses (as listed in Table 1-2). When the number of MAC addresses reaches to 16, you will fail to add new MAC addresses.
Table 1-2 Default OUI addresses of a switch
Number |
OUI Address |
Vendor |
1 |
00e0-bb00-0000 |
3com phone |
2 |
0003-6b00-0000 |
Cisco phone |
3 |
00e0-7500-0000 |
Polycom phone |
4 |
00d0-1e00-0000 |
Pingtel phone |
5 |
000f-e200-0000 |
H3C Aolynk phone |
Related commands: display voice vlan oui.
# Specify 00aa-bb00-0000 as the OUI address that can be identified by the device, with the description string being ABC.
<H3C> system-view
[H3C] voice vlan mac-address 00aa-bb00-0000 mask ffff-ff00-0000 description ABC
1.1.8 voice vlan mode
voice vlan mode auto
undo voice vlan mode auto
View
Ethernet port view
None
Use the voice vlan mode auto command to set the voice VLAN mode of the port to automatic.
Use the undo voice vlan mode auto command to restore the voice VLAN mode of the port to manual mode.
By default, the voice VLAN mode of the port is automatic mode.
# Set the voice VLAN mode of GigabitEthernet 3/0/2 to manual.
<H3C> system-view
[H3C] interface GigabitEthernet 3/0/2
[H3C-GigabitEthernet3/0/2] undo voice vlan mode auto
undo voice vlan security enable
View
None
Use the voice vlan security enable command to enable the voice VLAN security mode.
Use the undo voice vlan security enable command to disable the voice VLAN security mode.
In the voice VLAN security mode, the voice device access port in the voice VLAN can only transmit voice data. Packets with their MAC addresses not among the OUI addresses that can be identified by the system will be dropped. This mode has no effect on other VLANs.
When the voice VLAN security mode is disabled, the voice VLAN can transmit both voice and service data.
By default, the voice VLAN security mode is enabled.
# Disable the voice VLAN security mode.
<H3C> system-view
[H3C] undo voice vlan security enable
& Note:
You need to configure the hybrid attribute for a port in the process of configuring an isolate-user-VLAN. For hybrid port-related commands, refer to the Port Basic Configuration part of the H3C S7500 Series Ethernet Switches Command Manual.
display isolate-user-vlan [ vlan-id ]
View
vlan-id: VLAN ID of the configured isolate-user-VLAN, ranging from 1 to 4,094.
Use the display isolate-user-vlan command to display the mapping between the isolate-user-VLAN and the secondary VLANs, and the current status and port information of the isolate-user-VLAN and the secondary VLANs.
Related commands: isolate-user-vlan enable, isolate-user-vlan.
# Display the mapping between the isolate-user-VLAN and the secondary VLANs.
<H3C> display isolate-user-vlan
Isolate-user-VLAN Vlan ID : 3
Secondary Vlan ID : 4-5
Vlan ID: 3
Vlan Type: static
Isolate-user-VLAN type : isolate-user-VLAN
Description: VLAN 0003
Tagged Ports: none
Untagged Ports:
Ethernet1/0/4 Ethernet1/0/8 Ethernet1/0/18
Vlan ID: 4
Vlan Type: static
Private-vlan Type : Secondary
Description: VLAN 0004
Tagged Ports: none
Untagged Ports:
Vlan ID: 5
Vlan Type: static
Tagged Ports: none
Untagged Ports:
Ethernet1/0/4 Ethernet1/0/18
2.1.2 isolate-user-vlan
isolate-user-vlan vlan-id secondary vlan-list
undo isolate-user-vlan vlan-id [ secondary vlan-list ]
View
vlan-id: VLAN ID of an isolate-user-VLAN, ranging from 1 to 4,094.
vlan-list: List of the secondary VLANs that need to establish mapping with the isolate-user-VLAN, provided in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-4093>, where the vlan-id is the VLAN ID of the secondary VLAN. VLAN ID after to must not be less than that before to. You can input this argument repeatedly to establish the mapping between the isolate-user-VLAN and all other VLANs.
Use the isolate-user-vlan command to establish the mapping between the isolate-user-VLAN and the secondary VLANs.
Use the undo isolate-user-vlan command to cancel the mapping between the isolate-user-VLAN and the secondary VLANs.
Without secondary vlan-list, the undo isolate-user-vlan command cancels the mapping between all the secondary VLANs and the specified isolate-user-VLAN. With secondary vlan-list specified, the command cancels the mapping between the specified secondary VLANs and the specified isolate-user-VLAN.
Note that, establishing or canceling the mapping between the isolate-user-VLAN and the secondary VLANs does not affect the port status in each VLAN.
By default, the user-created isolate-user-VLAN and secondary VLANs have no mapping relationship.
Related commands: display isolate-user-vlan.
# Map isolate-user-VLAN 10 with secondary VLAN 2, 3, 4, 5, and 9.
<H3C> system-view
[H3C] isolate-user-vlan 10 secondary 2 to 5 9
undo isolate-user-vlan enable
View
VLAN view
None
Use the isolate-user-vlan enable command to configure a VLAN as an isolate-user-VLAN.
Use the undo isolate-user-vlan enable command to cancel the configuration.
By default, no VLAN is enabled with the isolate-user-VLAN function.
Caution:
l Multiple isolate-user-VLANs can be configured for a switch.
l You cannot configure isolate-user-VLAN for a switch that is enabled with GVRP.
l You cannot enable both isolate-user-VLAN and super VLAN functions for one VLAN. If a VLAN is configured as an isolate-user-VLAN or a secondary VLAN, you cannot configure it as a super VLAN or a sub VLAN.
# Configure VLAN 5 as an isolate-user-VLAN.
<H3C> system-view
[H3C] vlan 5
[H3C-vlan5] isolate-user-vlan enable
& Note:
Only Salience III series engines support this feature.
3.1.1 dhcp-server
dhcp-server groupNo
undo dhcp-server
View
groupNo: DHCP server number, ranging from 0 to 19.
Use the dhcp-server command to map the VLAN interface to a DHCP server group.
Use the undo dhcp-server command to cancel this mapping.
# Map VLAN-interface1 to DHCP server group 1.
<H3C> system-view
[H3C] interface Vlan-interface 1
[H3C-Vlan-interface1] dhcp-server 1
3.1.2 display supervlan
display supervlan [ supervlan-id ]
View
supervlan-id: ID of Super VLAN, range from 1 to 4,094.
Use the display supervlan command to display the mapping between a Super VLAN and Sub VLANs, and the ports included in the sub VLANs.
Related commands: supervlan, subvlan.
# Display the mapping relationship between Super VLAN 100 and the sub VLANs.
<H3C> display supervlan 100
Supervlan ID : 100
Subvlan ID : 101-102
VLAN ID: 100
VLAN Type: static
It is a Super VLAN.
Description: VLAN 0100
Broadcast MAX-ratio: 100
Tagged Ports: none
Untagged Ports: none
VLAN ID: 101
VLAN Type: static
It is a Sub VLAN. And the Super VLAN is VLAN 100
ARP proxy disabled.
Description: VLAN 0101
Tagged Ports: none
Untagged Ports:
Ethernet3/0/3
VLAN ID: 102
VLAN Type: static
ARP proxy disabled.
Description: VLAN 0102
Tagged Ports: none
Untagged Ports:
Ethernet3/0/4
3.1.3 subvlan
subvlan vlan-list
undo subvlan [ vlan-list ]
View
VLAN view of the super VLAN
vlan-list: List of sub VLANs, provided in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is the VLAN ID of a sub VLAN, and the &<1-10> means you can specify ten sub VLANs or sub VLAN lists.
Use the subvlan commmand to establish the mapping relationship between sub VLANs and the super VLAN.
Use the undo subvlan commmand to cancel the mapping relationship between sub VLANs and the super VLAN.
Without the vlan-list argument, the undo subvlan command cancels the mapping between all sub VLANs and the super VLAN. With this argument, the command cancels the mapping between the specified sub VLANs and the super VLAN.
Caution:
l The sub VLANs must exist before you create mapping between the sub VLANs and the super VLAN.
l After establishing the mapping between the sub VLANs and the super VLAN, you can still add (or remove) ports to (from) the sub VLANs.
l The system allows for up to 1024 sub VLANs.
Related commands: display supervlan.
# Establish the mapping relationship between sub VLAN 3, 4, 5, 9 and super VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] supervlan
[H3C-vlan10] subvlan 3 to 5 9
3.1.4 supervlan
supervlan
undo supervlan
View
VLAN view
None
Use the supervlan commmand to configure the current VLAN to be a super VLAN.
Use the undo supervlan commmand to restore the current VLAN type to ordinary VLAN.
Note that:
l You can not configure a VLAN which includes Ethernet ports as a super VLAN; and after you configure a super VLAN, you cannot add any Ethernet port to it.
l When a VLAN is configured as a super VLAN, proxy ARP function is automatically enabled on the VLAN interface.
l When a super VLAN exists, the proxy ARP function cannot be disabled on the corresponding VLAN interface.
# Configure VLAN 2 to be a super VLAN.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] supervlan
