- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 16-Routing Protocol Commands | 721 KB |
Table of Contents
Chapter 1 Static Route Configuration Commands
1.1 Routing Table Monitoring Commands
1.1.1 display ip routing-table
1.1.2 display ip routing-table acl
1.1.3 display ip routing-table ip-address
1.1.4 display ip routing-table ip-address1 ip-address2
1.1.5 display ip routing-table ip-prefix
1.1.6 display ip routing-table protocol
1.1.7 display ip routing-table radix
1.1.8 display ip routing-table statistics
1.1.9 display ip routing-table verbose
1.2 Static Route Configuration Commands
1.2.1 delete static-routes all
1.2.3 ip route-static default-preference
Chapter 2 RIP Configuration Commands
2.1 RIP Configuration Commands
2.1.14 rip authentication-mode
2.1.24 traffic-share-across-interface
Chapter 3 OSPF Configuration Commands
3.1 OSPF Configuration Commands
3.1.11 default-route-advertise
3.1.13 display ospf asbr-summary
3.1.15 display ospf cumulative
3.1.21 display ospf request-queue
3.1.22 display ospf retrans-queue
3.1.31 ospf authentication-mode
3.1.44 protocol multicast-mac enable
3.1.48 snmp-agent trap enable ospf
Chapter 4 Integrated IS-IS Configuration Commands
4.1 Integrated IS-IS Configuration Commands
4.1.1 area-authentication-mode
4.1.11 domain-authentication-mode
4.1.14 ignore-lsp-checksum-error
4.1.16 import-route isis level-2 into level-1
4.1.18 isis authentication-mode
4.1.26 isis timer holding-multiplier
Chapter 5 BGP Configuration Commands
5.1 BGP Configuration Commands
5.1.4 compare-different-as-med
5.1.6 confederation nonstandard
5.1.9 default local-preference
5.1.15 display bgp routing-table
5.1.16 display bgp routing-table as-path-acl
5.1.17 display bgp routing-table cidr
5.1.18 display bgp routing-table community
5.1.19 display bgp routing-table community-list
5.1.20 display bgp routing-table dampened
5.1.21 display bgp routing-table different-origin-as
5.1.22 display bgp routing-table flap-info
5.1.23 display bgp routing-table peer
5.1.24 display bgp routing-table regular-expression
5.1.25 display bgp routing-table statistic
5.1.31 peer advertise-community
5.1.34 peer as-path-acl export
5.1.35 peer as-path-acl import
5.1.37 peer default-route-advertise
5.1.41 peer filter-policy export
5.1.42 peer filter-policy import
5.1.50 peer route-policy export
5.1.51 peer route-policy import
5.1.52 peer route-update-interval
5.1.55 reflect between-clients
Chapter 6 IP Routing Policy Configuration Commands
6.1 IP Routing Policy Configuration Commands
6.1.12 if-match { acl | ip-prefix }
Chapter 7 Route Capacity Configuration Commands
7.1 Route Capacity Configuration Commands
7.1.3 memory auto-establish disable
7.1.4 memory auto-establish enable
7.1.5 memory { safety | limit }*
& Note:
The term “router” in this document refers to a router in a generic sense or an Ethernet switch running routing protocols.
View
None
Use the display ip routing-table command to display the summary of a routing table.
This command is used to display the summary of a routing table. Each line represents one route, containing the destination address/mask length, protocol, preference, cost, next hop, and output interface.
This command is only used to display the currently used routes, that is, the optimal routes.
# Display the summary of the current routing table.
<H3C> display ip routing-table
Destination/Mask Protocol Pre Cost Nexthop Interface
1.1.1.0/24 DIRECT 0 0 1.1.1.1 Vlan-interface1
1.1.1.1/32 DIRECT 0 0 127.0.0.1 InLoopBack0
2.2.2.0/24 DIRECT 0 0 2.2.2.1 Vlan-interface2
2.2.2.1/32 DIRECT 0 0 127.0.0.1 InLoopBack0
127.0.0.0/8 DIRECT 0 0 127.0.0.1 InLoopBack0
127.0.0.1/32 DIRECT 0 0 127.0.0.1 InLoopBack0
Table 1-1 Description on the fields of the display ip routing-table command
Destination/Mask |
Destination address/mask length |
Protocol |
Routing protocol |
Pre |
Route preference |
Cost |
Route cost |
Nexthop |
Next hop address |
Output interface, through which the data packets sent to the destination network segment are sent |
display ip routing-table acl { acl-number | acl-name } [ verbose ]
View
acl-number: Number of the number-identified ACL, in the range 2,000 to 2,999.
acl-name: Name of the basic name-identified ACL.
verbose: Specifies to display the detailed information about active and inactive routes filtered through the ACL rules if this keyword is provided; specifies to display the brief information about the active routes filtered through the ACL rules.
Use the display ip routing-table acl command to display the routes filtering through the basic ACL rules.
This command is used to trace and display routing policies, that is, to display the routes filtering through the rules based on the input basic ACL numbers.
# Display the brief information about the active routes filtering through basic ACL 2000.
<H3C>system-view
[H3C] acl number 2000
[H3C-acl-basic-2000] rule permit source 10.1.1.1 0.0.0.255
[H3C-acl-basic-2000] rule deny source any
[H3C-acl-basic-2000] display ip routing-table acl 2000
Routes matched by access-list 2000:
Summary count: 2
10.1.1.0/24 DIRECT 0 0 10.1.1.2 Vlan-interface1
10.1.1.2/32 DIRECT 0 0 127.0.0.1 InLoopBack0
Refer to Table 1-1 for the description on the displayed information above.
# Display the detailed information about the active and inactive routes filtered through basic ACL 2000.
<H3C> display ip routing-table acl 2000 verbose
Generate Default: no
+ = Active Route, - = Last Active, # = Both * = Next hop in use
Summary count: 2
**Destination: 10.1.1.0 Mask: 255.255.255.0
Protocol: #DIRECT Preference: 0
*NextHop: 10.1.1.2 Interface: 10.1.1.2(Vlan-interface1)
Vlinkindex: 0
State: <Int ActiveU Retain Unicast>
Age: 7:24 Cost: 0/0 Tag: 0
**Destination: 10.1.1.2 Mask: 255.255.255.255
*NextHop: 127.0.0.1 Interface: 127.0.0.1(InLoopBack0)
Vlinkindex: 0
State: <NoAdvise Int ActiveU Retain Gateway Unicast>
Table 1-2 Description on the fields of the display ip routing-table acl command
Destination |
Destination address |
Mask |
Mask |
Protocol |
Routing protocol that detects this route |
Preference |
Preference of the route |
Nexthop |
Address of the next hop |
Output interface where packets to the destination network segment are forwarded. |
Vlinkindex |
Virtual link index |
State |
Route state: |
ActiveU |
Active unicast routes |
Blackhole |
Blackhole routes, which are similar to Reject routes except that blackhole routes do not send ICMP unreachable messages to the source end of the packet. |
Delete |
The route is deleted. |
Gateway |
Indirect routes |
Hidden |
If you do not want to remove some routes that are not available temporarily for some reasons (such as the configured polices, the port being down), you can hide the route so as to restore it later. |
Holddown |
Holddown is a route redistribution policy adopted by some distance-vector (D-V) routing protocols such as RIP. Through Holddown, a routing protocol can avoid the flooding of error routes and deliver route unreachable messages accurately. It redistributes a certain route at regular intervals regardless of whether the actually found routes leading to the same destination change. For more details, refer to the specific routing protocols. |
Int |
The route is discovered by the interior gateway protocol (IGP). |
NoAdvise |
NoAdvise routes are nor advertised when the routing protocol ad |
NotInstall |
Generally, the route with the highest preference in a routing table is added to the core routing table and advertised. Comparatively, NotInstall routes cannot be added to the core routing table, however, they may be advertised. |
Reject |
Reject routes do not distribute packets like normal routes. Instead, the packet that selects a reject route will be dropped, and ICMP unreachable messages will be sent to the source end of the packet. Reject routes are generally used in network tests. |
Retain |
When the routes read by the core routing table are removed, the routes with the “retain” tag will not be removed. You can set some static routes as retain routes so that they can continue to exist in the core routing table. |
Static |
The static routes manually configured on the router are tagged as static routes, which will not be removed from the routing table if the router is restarted after the save command is executed. |
Unicast |
Unicast routes |
Age |
The time during which a route exists in the routing table, expressed in the form of hh:mm:ss. |
Cost |
Route cost |
Tag |
Route tag |
display ip routing-table ip-address [ mask ] [ longer-match ] [ verbose ]
View
ip-address: Destination IP address, in dotted decimal notation.
mask: IP address mask, length in dotted decimal notation or expressed as an integer. It ranges from 0 to 32 when expressed as an integer.
longer-match: Specifies to display all the routes that lead to the destination address and match the specified mask. If you do not specify the mask argument, those that match the natural mask will be displayed.
verbose: With the verbose argument specified, this command is used to display the verbose information of both active and inactive routes. Without the argument specified, this command is only used to display the summary of active routes.
Use the display ip routing-table ip-address command to display the routing information of the specified destination address.
With different arguments provided, the output information is different from one another. The following is the command output with different arguments provided:
l display ip routing-table ip-address
If the destination address specified by ip-address corresponds to a route in the natural mask range, this command is used to display all its subnet routes. Otherwise, this command is used to display the longest matching route based on the destination address specified by ip-address.
l display ip routing-table ip-address mask
This command is only used to display the routes exactly matching the specified destination address and mask.
l display ip routing-table ip-address longer-match
This command is used to display all the matched routes leading to the destination address in the natural mask range.
l display ip routing-table ip-address mask longer-match
This command is used to display all the matched routes leading to the destination address in the specified mask range.
# There is a corresponding route in the natural mask range. Display the summary.
<H3C> display ip routing-table 169.0.0.0
169.0.0.0/16 Static 60 0 2.1.1.1 LoopBack1
For detailed description of the output information, refer to Table 1-1.
# There is no corresponding route (only the longest matched route is displayed) in the natural mask range. Display the summary.
<H3C> display ip routing-table 169.253.0.0
169.0.0.0/8 Static 60 0 2.1.1.1 LoopBack1
# There are corresponding routes in the natural mask range. Display detailed information.
<H3C> display ip routing-table 169.0.0.0 verbose
Routing Tables:
Summary count:2
**Destination: 169.0.0.0 Mask: 255.0.0.0
Protocol: #Static Preference: 60
*NextHop: 2.1.1.1 Interface: 2.1.1.1(LoopBack1)
Vlinkindex: 0
State: <Int ActiveU Static Unicast>
Age: 3:47 Cost: 0/0 Tag: 0
**Destination: 169.0.0.0 Mask: 255.254.0.0
Vlinkindex: 0
# There is no corresponding route in the natural mask range (only the longest matched route is displayed). Display the detailed information.
<H3C> display ip routing-table 169.253.0.0 verbose
Routing Tables:
Summary count:1
Vlinkindex: 0
For detailed description of the output information, refer to Table 1-2.
display ip routing-table ip-address1 mask1 ip-address2 mask2 [ verbose ]
View
ip-address1, ip-address2: Destination IP address in dotted decimal notation. ip-address1, mask1 and ip-address2, mask2 determine one address range together. ip-address1 ANDed with mask1 specifies the start of the range, and ip-address2 ANDed with mask2 specifies the end of the range. This command is used to display the route in this address range.
mask1, mask2: IP address mask, length in dotted decimal notation or expressed as an integer. It ranges from 0 to 32 when expressed as an integer.
verbose: With the verbose argument provided, this command is used to display the verbose information of both active and inactive routes. Without this argument provided, this command is used to display the summary of active routes only.
Use the display ip routing-table ip-address1 ip-address2 command to display the route information in the specified destination address range.
# Display the routing information of destination addresses ranging from 1.1.1.0 to 2.2.2.0.
<H3C>display ip routing-table 1.1.1.0 24 2.2.2.0 24
Routing tables:
Summary count: 3
display ip routing-table ip-prefix ip-prefix-name [ verbose ]
View
ip-prefix-name: Name of the IP address prefix list, containing 1 to 19 characters.
Use the display ip routing-table ip-prefix command to display the routes filtered through the specified ip-prefix list.
This command is used to track and display the routing policy. It is used to display the routes filtering through the rules based on the input ip-prefix list name.
If the specified ip-prefix list does not exist, with the verbose keyword provided, this command is used to display the detailed information about all active and inactive routes; without the verbose argument keyword, this command is used to display the brief information about all active routes only.
# Display the brief information about the active routes filtered through the IP-prefix list named abc2, which permits the route with a prefix of 10.1.1.0 and a mask length of 24 to 32.
<H3C>system-view
[H3C] ip ip-prefix abc2 permit 10.1.1.0 24 less-equal 32
[H3C] display ip routing-table ip-prefix abc2
Routes matched by ip-prefix abc2:
Summary count: 2
For detailed information about the displayed information above, refer to Table 1-1.
# Display the detailed information about the active and inactive routes filtered through the ip-prefix list named abc2.
[H3C] display ip routing-table ip-prefix abc2 verbose
Summary count: 2
Vlinkindex: 0
Age: 3:23:44 Cost: 0/0 Tag: 0
Vlinkindex: 0
For detailed description on the displayed information above, refer to Table 1-2.
display ip routing-table protocol protocol [ inactive | verbose ]
View
protocol: You can provide one of the following values for this argument.
l direct: Specifies to display direct-connect route information
l static: Specifies to display static route information.
l bgp: Specifies to display BGP route information
l isis: Specifies to display IS-IS route information.
l ospf: Specifies to display OSPF route information.
l ospf-ase: Specifies to display OSPF ASE route information.
l ospf-nssa: Specifies to display OSPF NSSA route information.
l rip: Specifies to display RIP route information.
inactive: With this argument provided, this command is used to display the inactive route information. Without this argument provided, this command is used to display the information of both active and inactive routes.
verbose: With this argument provided, this command is used to display the verbose route information. Without this argument provided, this command is used to display route summary only.
Use the display ip routing-table protocol command to display the route information of a specific protocol.
# Display the summary of all direct-connect routes.
<H3C> display ip routing-table protocol direct
DIRECT Routing tables:
Summary count: 8
DIRECT Routing table status:<active>:
Summary count: 7
10.5.1.0/24 DIRECT 0 0 10.5.1.5 Vlan-interface105
10.5.1.5/32 DIRECT 0 0 127.0.0.1 InLoopBack0
100.100.1.1/32 DIRECT 0 0 127.0.0.1 InLoopBack0
102.1.1.0/24 DIRECT 0 0 102.1.1.1 LoopBack1
102.1.1.1/32 DIRECT 0 0 127.0.0.1 InLoopBack0
DIRECT Routing table status:<inactive>:
Summary count: 1
100.100.1.1/32 DIRECT 0 0 100.100.1.1 LoopBack0
# Display the static routing table.
<H3C> display ip routing-table protocol static
STATIC Routing tables:
Summary count: 1
STATIC Routing tables status:<active>:
Summary count: 0
STATIC Routing tables status:<inactive>:
Summary count: 1
1.2.3.0/24 STATIC 60 0 1.2.4.5 Vlan-interface10
For detailed description of the output information, see Table 1-1.
View
None
Use the display ip routing-table radix command to display the route information in a tree mode.
<H3C> display ip routing-table radix
Radix tree for INET (2) inodes 14 routes 10:
+--8+--{169.0.0.0
| +-32+--{169.1.1.1
+--0+
| | +--8+--{127.0.0.0
| | | +-32+--{127.0.0.1
| +--1+
| | +--8+--{2.0.0.0
| | | +-24+--{2.2.2.0
| | | | +-32+--{2.2.2.2
| | | +-22+
| | | +-32+--{2.2.1.1
| +--6+
| +--8+--{1.0.0.0
| +-32+--{1.1.1.1
Table 1-3 Description on the fields of the display ip routing-table radix command
INET |
Address suite |
inodes |
Number of nodes |
routes |
Number of routes |
View
None
Use the display ip routing-table statistics command to display the statistics information about routes.
The statistics information about routes includes the total number of routes, the number of routes added by protocols, the number of routes deleted by the protocols, the number of routes which are not deleted though they have the deleted tag, the number of active routes, and the number of inactive routes.
# Display the statistics information about routes.
<H3C> display ip routing-table statistics
Routing tables:
Proto route active added deleted
DIRECT 24 4 25 1
STATIC 4 1 4 0
BGP 0 0 0 0
RIP 0 0 0 0
IS-IS 0 0 0 0
OSPF 0 0 0 0
O_ASE 0 0 0 0
O_NSSA 0 0 0 0
AGGRE 0 0 0 0
Total 28 5 29 1
Table 1-4 Description on the fields of the display ip routing-table statistics command
Proto |
Routing protocol. O_ASE stands for OSPF_ASE routes; O_NSSA stands for OSPF NSSA routes; AGGRE stands for aggregated routes. |
route |
Number of routes |
active |
Number of active routes |
added |
Number of routes added after the router is rebooted or the routing table is cleared last time. |
deleted |
Number of routes deleted (Such routes will be freed in a period of time) |
Total |
Total number of different kinds of routes. |
View
None
Use the display ip routing-table verbose command to display the verbose routing table information.
With the verbose argument provided, this command is used to display the verbose routing table information. The descriptor describing the route state will be displayed first. Then, the statistics of the entire routing table will be output. Finally, the verbose description of each route will be output.
The display ip routing-table verbose command can be executed to display all current routes, including inactive routes and invalid routes.
# Display the verbose routing table information.
<H3C> display ip routing-table verbose
Routing Tables:
Destinations: 3 Routes: 3
Holddown: 0 Delete: 62 Hidden: 0
**Destination: 1.1.1.0 Mask: 255.255.255.0
*NextHop: 1.1.1.1 Interface: 1.1.1.1(Vlan-interface1)
Age: 20:17:41 Cost: 0/0
**Destination: 1.1.1.1 Mask: 255.255.255.255
Age: 20:17:42 Cost: 0/0
**Destination: 2.2.2.0 Mask: 255.255.255.0
*NextHop: 2.2.2.1 Interface: 2.2.2.1(Vlan-interface2)
Age: 20:08:05 Cost: 0/0
Table 1-2 describes the meaning of route status and Table 1-5 shows the statistics information about the routing table.
Table 1-5 Description on the fields of the display ip routing-table verbose command
Holddown |
Number of held-down routes |
Delete |
Number of deleted routes |
Hidden |
Number of hidden routes |
View
None
Use the delete static-routes all command to delete all static routes.
The system will request your confirmation before it deletes all the configured static routes.
Related commands: ip route-static, display ip routing-table.
# Delete all the static routes in the router.
<H3C> system-view
[H3C] delete static-routes all
Are you sure to delete all the unicast static routes?[Y/N]y
1.2.2 ip route-static
ip route-static ip-address { mask | mask-length } { interface-type interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ]
undo ip route-static ip-address { mask | mask-length } [ interface-type interface-number | next-hop ] [ preference preference-value ] [ reject | blackhole ]
View
mask: Mask.
mask-length: Mask length. Because 1s in a 32-bit mask must be consecutive, a mask in dotted decimal notation can be replaced by mask-length, which is the number of the consecutive 1s in the mask.
interface-type interface-number: Next-hop outgoing interface. At present, the next-hop outgoing interface can be NULL 0 only. The packets sent to a null interface, which is a virtual interface, will be discarded immediately. This can reduce system load.
next-hop: Next hop IP address of the route, in dotted decimal notation.
preference-value: Preference level of the route, in the range 1 to 255. The default preference is 60.
reject: Indicates an unreachable route. If a static route to a destination has the "reject" attribute, all the IP packets sent to this destination will be discarded.
blackhole: Indicates a blackhole route. If a static route to a destination has the “blackhole” attribute, the outgoing interface of this route is the Null 0 interface regardless of the next hop address, and all the IP packet addresses sent to this destination are dropped.
Use the ip route-static command to configure a static route.
Use the undo ip route-static command to delete a configured static route.
By default, the system can obtain the subnet route directly connected to the router. If you do not specify the preference for a static route to be configured, the preference defaults to 60. If you do not specify reject or blackhole for the route, the route will be a reachable route by default.
& Note:
l If the destination IP address and the mask of a route are both 0.0.0.0, the route is the default route. Any packet for which the router fails to find a matching entry in the routing table will be forwarded through the default route.
l Do not configure the next hop address of a static route as the IP address of an interface on the local switch.
l You can configure different preference values to implement flexible route management policy.
Related commands: display ip routing-table, ip route-static default-preference, ip route-static default-preference.
Example
# Configure the next hop of the default route as 129.102.0.2.
<H3C> system-view
[H3C] ip route-static 0.0.0.0 0.0.0.0 129.102.0.2
ip route-static default-preference default-preference-value
undo ip route-static default-preference
View
default-preference-value: Default precedence of static routes, in the range 1 to 255. It is 60 by default.
Use the ip route-static default-preference command to set the default precedence of static routes.
Use the undo ip route-static default-preference command to restore the default precedence.
If a static route is configured without the specified precedence, its precedence is set to the default precedence value.
Related commands: display ip routing-table, ip route-static.
# Set the default precedence of static routes to 120.
<H3C>system-view
[H3C] ip route-static default-preference 120
& Note:
2.1.1 checkzero
checkzero
undo checkzero
View
RIP view
None
Use the checkzero command to enable zero field check on RIP-1 packets.
Use the undo checkzero command to disable zero field check.
By default, RIP-1 performs zero field check.
According to the protocol (RFC 1058) specifications, some fields in RIP-1 packets must be zero and these fields are called zero fields. You can use the checkzero command to enable or disable zero field check on RIP-1 packets. When zero field check is enabled, if an incoming RIP-1 packet has a non-zero zero field, the packet will be rejected.
This command does not apply to RIP-2 packets that have no zero fields.
# Disable zero field check on RIP-1 packets.
<H3C> system-view
[H3C] rip
[H3C-rip] undo checkzero
2.1.2 default cost
default cost value
undo default cost
View
RIP view
value: Default routing cost, ranging from 1 to 16. It is 1 by default.
Use the default cost command to set the default routing cost for redistributed routes.
Use the undo default cost command to restore the default value.
If no routing cost is specified when you use the import-route command to redistribute routes from another routing protocol, the default routing cost specified with the default cost command applies.
Related command: import-route.
# Set the default routing cost for the redistributed routes to 3.
<H3C> system-view
[H3C] rip
[H3C-rip] default cost 3
2.1.3 display rip
display rip
View
None
Use the display rip command to display the current RIP operation status and RIP configuration.
# Display the current RIP operation status and configuration.
<H3C> display rip
RIP is running
Checkzero is on Default cost : 1
Summary is on Preference : 100
Traffic-share-across-interface is off
Period update timer : 30
Timeout timer : 180
Garbage-collection timer : 120
No peer router
Network :
10.0.0.0
Table 2-1 Description on the fields of the display rip command
RIP is running |
RIP is active |
Checkzero is on |
Zero field check is enabled |
Default cost : 1 |
The default route cost is 1 |
Summary is on |
Routes are aggregated automatically |
Preference : 100 |
The preference of RIP is 100 |
Traffic-share-across-interface is off |
Traffic sharing is enabled or disabled among equivalent routes |
Period update timer : 30 Timeout timer : 180 Garbage-collection timer : 120 |
Settings of the three timers of RIP |
No peer router |
No destination address of a transmission is specified |
Network :10.0.0.0 |
RIP is enabled on network segment 10.0.0.0 |
2.1.4 display rip routing
display rip routing
View
None
Use the display rip routing command to display RIP routing information.
# Display RIP routing table information.
<H3C> display rip routing
RIP routing table: public net
A = Active I = Inactive G=Garbage collection
Destination/Mask Cost NextHop Age SourceGateway Att
6.0.0.0/8 1 10.153.25.22 4s 10.153.25.22 A
Table 2-2 Description on the fields of the display rip routing command
Destination/Mask |
Destination address/Mask |
Cost |
Cost |
NextHop |
Net hop address |
Age |
The time that a route exists in the routing table, namely, the aging time |
SourceGateway |
Gateway originating the route |
Att |
Attribute value, which may be one of the three following values: |
A |
Active routes |
I |
Inactive routes |
G |
Unreachable route in the state of garbage collection. If garbage collection times out, and the unreachable route does not receive updates from the same neighbor, the route will be removed from the routing table completely. |
2.1.5 filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface interface-type interface-number ]
filter-policy route-policy route-policy-name export
undo filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface interface-type interface-number ]
undo filter-policy route-policy route-policy-name export
View
RIP view
acl-number: Number of the basic or advanced ACL used to filter routing information by destination address, in the range of 2,000 to 3,999.
ip-prefix-name: Name of the address ip-prefix list used to filter routing information by destination address, containing 1 to 19 characters.
route-policy-name: Name of the routing policy used to filter routing information, containing 1 to 19 characters. A routing policy can enable RIP to determine which routes are to be sent/received based on such fields as acl/cost/interface/ip/ip-prefix/tag.
protocol: Routing protocol whose routing information is to be filtered. Currently, this can be bgp, direct, isis, ospf, ospf-ase, ospf-nssa or static.
process-id: Routing protocol process ID, in the range of 1 to 65535. This argument is valid only when the protocol is ospf.
interface: Specifies an interface where the routes to be advertised will be filtered.
interface-type interface-number: Interface type and interface number.
Use the filter-policy export command to enable RIP to filter the routing information to be advertised.
Use the undo filter-policy export command to cancel the filtering of the routing information to be advertised.
By default, RIP does not filter routing information before advertising.
Related commands: acl, filter-policy import, ip ip-prefix.
# Configure to filter route information by ACL 2000 before the information is advertised.
<H3C> system-view
[H3C] rip
[H3C-rip] filter-policy 2000 export
2.1.6 filter-policy import
filter-policy { acl-number | [ ip-prefix ip-prefix-name ] [ gateway ip-prefix-name ] } import [ interface interface-type interface-number ]
undo filter-policy { acl-number | [ ip-prefix ip-prefix-name ] [ gateway ip-prefix-name ] } import [ interface-type interface-number ]
filter-policy route-policy route-policy-name import
undo filter-policy route-policy route-policy-name import
View
RIP view
acl-number: Number of the ACL used to filter routing information by destination address, in the range of 2,000 to 3,999.
ip-prefix-name: Name of the address prefix list used to filter routing information by destination address, containing 1 to 19 characters.
gateway ip-prefix-name: Name of the address prefix list used to filter routing information by the address of the neighbor router advertising the information, containing 1 to 19 characters.
Use the filter-policy gateway import command to enable RIP to filter received routing information by a specified address.
Use the undo filter-policy gateway import command to disable the above filtering.
Use the filter-policy import command to filter the received routing information.
Use the undo filter-policy import command to disable the above filtering.
By default, RIP does not filter received routing information.
You can control the range of routes received by RIP by specifying an ACL, ip-prefix list and routing policies.
Related commands: acl, filter-policy export, ip ip-prefix.
# Configure to filter incoming routing information by ACL 2000.
<H3C>system-view
[H3C] rip
[H3C-rip] filter-policy 2000 import
2.1.7 host-route
host-route
undo host-route
View
RIP view
None
Use the host-route command to enable RIP to receive host routes.
Use the undo host-route command to reject host routes.
By default, receiving host routes is enabled.
In some special cases, RIP receives a great number of host routes from the same network segment. These routes are of little help to routing and occupy a large amount of resources. In this case, the undo host-route command can be used to reject host routes.
# Enable RIP to reject host routes.
<H3C> system-view
[H3C] rip
[H3C-rip] undo host-route
2.1.8 import-route
import-route protocol [ process-id | allow-ibgp ] [ cost value | route-policy route-policy-name ]*
undo import-route protocol [ process-id ]
View
RIP view
protocol: Source routing protocol whose routes will be redistributed by RIP. At present, RIP can redistribute the following types of routes: direct, ospf, ospf-ase, ospf-nssa, static, isis and bgp.
allow-ibgp: Allows the redistribution of IBGP routes when redistributing routes from BGP.
value: Cost value of the routes to be redistributed, in the range of 1 to 16.
route-policy route-policy-name: Specifies a routing policy, which contains 1 to 19 characters. Only the routes matching the conditions of the specified routing policy will be redistributed.
Use the import-route command to redistribute the routes of another protocol into RIP.
Use the undo import-route command to cancel the routes redistributed from another protocol.
By default, RIP does not redistribute routes from other protocols.
The import-route command is used to redistribute the routes of another protocol with a specified cost. RIP regards the redistributed routes as its own routes and transmits them with the specified cost. This command can greatly enhance the capability of RIP to obtain routes, thereby improving RIP performance.
If the cost value is not specified, routes will be redistributed with the default routing cost (set by the default cost command, ranging from 1 to 16). If the cost of an redistributed route is 16, RIP marks the route as HOLD DOWN (however, the route can still be used to forward packets), and continues to announce the route with this cost to other routers running RIP until the garbage collection timer times out (the timeout time defaults to 120 seconds).
Related commands: default cost.
Note that:
l The import-route bgp command redistributes EBGP routes only.
l The import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes.
l Use the import-route bgp allow-ibgp command with care, because it redistributes IBGP routes without keeping the AS_PATH attribute, which may lead to routing loops between ASs.
& Note:
Use the import-route bgp allow-ibgp command with care!
# Redistribute static routes with the cost of 4.
<H3C> system-view
[H3C] rip
[H3C-rip] import-route static cost 4
# Set the default cost and redistribute OSPF routes with the default cost.
<H3C> system-view
[H3C] rip
[H3C-rip] import-route ospf
2.1.9 network
network network-address
undo network network-address
View
RIP view
network-address: Address of the network for which RIP is enabled/disabled. It can be the IP network address of any interface.
Use the network command to enable RIP on a specified interface.
Use the undo network command to disable RIP on the interface.
By default, RIP is disabled on any interface.
After a RIP routing process is started, it is disabled on any interface. To enable RIP routing on an interface, you need to use the network command.
When the network command is used on an address, the effect is that the interface on the network segment at this address is enabled. For example, the results of viewing the network 129.102.1.1 with both the display current-configuration command and the display rip command are shown as network 129.102.0.0.
Related commands: rip work.
# Enable RIP on the interface with the network address 129.102.0.0.
<H3C> system-view
[H3C] rip
[H3C-rip] network 129.102.0.0
2.1.10 peer
peer ip-address
undo peer ip-address
View
RIP view
ip-address: IP address of the interface on the peer router with which routing information needs to be exchanged. It is in dotted decimal notation.
Use the peer command to specify the IP address of the peer device with which routing information should be exchanged in unicast mode.
Use the undo peer command to remove the IP address.
By default, RIP does not send packets to any address in unicast mode.
This command is used to for non-broadcast networks to which protocol packets cannot be sent in broadcast mode. And you are not recommended to use this command in normal situation.
# Specify a unicast destination address of 202.38.165.1.
<H3C> system-view
[H3C] rip
[H3C-rip] peer 202.38.165.1
2.1.11 preference
preference value
undo preference
View
RIP view
value: Preference level, ranging from 1 to 255. By default, the value is 100.
Use the preference command to configure the RIP route preference.
Use the undo preference command to restore the default preference.
Every routing protocol has its own preference. Its default value is determined by the specific routing policy. The preferences of routing protocols will finally determine which routing algorithm's routes will be selected as the optimal routes in the IP routing table. You can use this command to modify the RIP preference manually.
# Specify the RIP preference as 20.
<H3C> system-view
[H3C] rip
[H3C-rip] preference 20
2.1.12 reset
reset
View
RIP view
None
Use the reset command to reset the system configuration parameters of RIP.
When you need to re-configure the parameters of RIP, you can use this command to restore the default setting.
# Reset the RIP system configuration.
<H3C> system-view
[H3C] rip
[H3C-rip] reset
2.1.13 rip
rip
undo rip
View
None
Use the rip command to enable RIP and enter RIP view.
Use the undo rip command to disable RIP.
By default, the system does not run RIP.
RIP must be enabled before you can enter the RIP view and configure various RIP global parameters. You can, however, configure the interface-based parameters regardless of whether RIP is enabled.
& Note:
Note that the interface parameters configured previously would be invalid when RIP is disabled.
# Enable RIP and enter RIP view.
<H3C> system-view
[H3C] rip
[H3C-rip]
rip authentication-mode { simple password | md5 { rfc2453 key-string | rfc2082 key-string key-id } }
undo rip authentication-mode
View
Interface view
simple: Specifies to use simple text authentication mode.
password: Simple text authentication key, containing 1 to 16 characters.
md5: Specifies to use MD5 cipher text authentication mode.
rfc2453: Specifies that MD5 cipher text authentication packets will use the packet format (IETF standard) stipulated by RFC2453.
rfc2082: Specifies that MD5 cipher text authentication packets will use the packet format stipulated by RFC2082.
key-string: MD5 cipher text authentication key. If input in simple text, the character string of MD5 key cannot exceed 16 characters. And it will be displayed in a cipher text form in a length of 24 characters when you use the display current-configuration command. You can also input the MD5 key in cipher text format with a length of 24 characters.
key-id: MD5 cipher text authentication identifier, ranging from 1 to 255.
Use the rip authentication-mode command to configure RIP-2 authentication mode and parameters.
Use the undo rip authentication-mode command to cancel the authentication.
RIP-1 does not authenticate packets. Generally RIP authenticates packets in two modes: plain text authentication and MD5 ciphertext authentication. There are two packet formats in the MD5 ciphertext authentication: one format conforms to RFC 2453 and the other format is described in RFC 2082. Routers support both formats. You can select any format as required.
Related commands: rip version.
# Specify the interface VLAN-interface 10 to use the simple authentication with the authentication key of aaa.
<H3C> system-view
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] rip version 2
[H3C-Vlan-interface10] rip authentication-mode simple aaa
# Specify VLAN-interface 10 to use the MD5 cipher text authentication, with the authentication key of aaa and the packet format of rfc2453.
<H3C> system-view
[H3C-Vlan-interface10] rip authentication-mode md5 rfc2453 aaa
2.1.15 rip input
rip input
undo rip input
View
Interface view
None
Use the rip input command to enable an interface to receive RIP packets.
Use the undo rip input command to disable an interface from receiving RIP packets.
By default, all interfaces, except loopback interfaces, can receive RIP packets.
This command is used in cooperation with another two commands: rip output and rip work. Functionally, rip work is equivalent to rip input&rip output. The latter two commands control the receipt and the transmission of RIP packets respectively on an interface. The former command equals the functional combination of the latter two commands.
Related commands: rip output, rip work.
# Configure the interface VLAN-interface 10 not to receive RIP packets.
<H3C> system-view
[H3C]interface Vlan-interface 10
[H3C-Vlan-interface10] undo rip input
2.1.16 rip metricin
rip metricin value
undo rip metricin
View
Interface view
value: Additional route metric added when receiving a RIP route, which ranges from 0 to 16. By default, the value is 0.
Use the rip metricin command to configure the additional route metric added to the RIP routes received on an interface.
Use the undo rip metricin command to restore the default value of this additional route metric.
Related commands: rip metricout.
# Set the additional route metric added to RIP routes received on VLAN-interface 10 to 2.
<H3C> system-view
[H3C-Vlan-interface10] rip metricin 2
2.1.17 rip metricout
rip metricout value
undo rip metricout
View
Interface view
value: Additional route metric added when transmitting a RIP route, which ranges from 1 to 16. By default, the value is 1.
Use the rip metricout command to configure the additional route metric added to the RIP routes to be transmitted on an interface.
Use the undo rip metricout command to restore the default value of this additional route metric.
& Note:
The metricout configuration only applies to the RIP routes learnt by the router and those generated by the router itself. It does not apply to any route redistributed to RIP from any other routing protocol.
Related commands: rip metricin.
# Set the additional route metric added to the RIP routes to be transmitted on VLAN-interface 10 to 2.
<H3C> system-view
[H3C-Vlan-interface10] rip metricout 2
2.1.18 rip output
rip output
undo rip output
View
Interface view
None
Use the rip output command to enable an interface to transmit RIP packets.
Use the undo rip output command to disable an interface from transmitting RIP packets.
By default, all interfaces, except loopback interfaces, are enabled to transmit RIP packets.
This command is used in cooperation with another two commands: rip input and rip work. Functionally, rip work is equivalent to rip input&rip output. The latter two commands control the receipt and the transmission of RIP packets respectively on an interface. The former command equals the functional combination of the latter two commands.
Related commands: rip input, rip work.
# Disable the interface VLAN-interface 10 from transmitting RIP packets.
<H3C> system-view
[H3C-Vlan-interface10] undo rip output
2.1.19 rip split-horizon
rip split-horizon
undo rip split-horizon
View
Interface view
None
Use the rip split-horizon command to enable the split horizon function on an interface when transmitting RIP packets.
Use the undo rip split-horizon command to disable the split horizon function on the interface when transmitting RIP packets.
By default, the split horizon is enabled.
Generally, split horizon is necessary for avoiding routing loops. Only in some special cases does split horizon need to be disabled to ensure the correct execution of the protocol. So, disable split horizon only when necessary.
# Disable the split horizon function on interface VLAN-interface 10 when processing RIP packets.
<H3C> system-view
[H3C-Vlan-interface10] undo rip split-horizon
2.1.20 rip version
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
View
Interface view
1: Specifies the version of RIP packets on the interface to RIP-1.
2: Specifies the version of RIP packets on the interface to RIP-2.
broadcast: Sends RIP-2 packets in broadcast mode.
multicast: Sends RIP-2 packets in multicast mode.
Use the rip version command to specify the version of RIP packets on an interface.
Use the undo rip version command to restore the default RIP packet version on the interface.
By default, the interface RIP version is RIP-1. RIP-1 transmits packets in broadcast mode, while RIP-2 transmits packets in multicast mode by default.
When running RIP-1, the interface only receives and transmits RIP-1 broadcast packets, and receives RIP-2 broadcast packets, but does not receive RIP-2 multicast packets. When running RIP-2 in broadcast mode, the interface receives and transmits RIP-2 broadcast packets, receives RIP-1 broadcast packets and RIP-2 multicast packets. When running RIP-2 in multicast mode, the interface only receives and transmits RIP-2 multicast packets, receives RIP-2 broadcast packets, but does not receive RIP-1 broadcast packets.
# Configure the interface VLAN-interface 10 to run in RIP-2 broadcast mode.
<H3C> system-view
[H3C-Vlan-interface10] rip version 2 broadcast
2.1.21 rip work
rip work
undo rip work
View
Interface view
None
Use the rip work command to enable RIP on an interface.
Use the undo rip work command to disable RIP on an interface.
By default, RIP is enabled on an interface.
This command is used in cooperation with rip input, rip output and network commands.
Related commands: network, rip input, rip output.
# Disable RIP on interface VLAN-interface 10.
<H3C> system-view
[H3C-Vlan-interface10] undo rip work
2.1.22 summary
summary
undo summary
View
RIP view
None
Use the summary command to enable RIP-2 automatic route summarization.
Use the undo summary command to disable RIP-2 automatic route summarization.
By default, automatic RIP-2 route summarization is enabled.
Route summarization can be used to reduce the routing traffic on the network as well as to reduce the size of the routing table. If RIP-2 is used, route summarization function can be disabled with the undo summary command when it is necessary to broadcast subnet routes.
RIP-1 does not support subnet mask. Forwarding subnet routes may cause ambiguity. Therefore, RIP-1 always uses route summarization.
# Set RIP version on the interface VLAN-interface 10 to RIP-2 and disable route summarization.
<H3C> system-view
[H3C-Vlan-interface10] quit
[H3C] rip
[H3C-rip] undo summary
2.1.23 timers
timers { update update-timer | timeout timeout-timer } *
undo timers { update | timeout } *
View
RIP view
update-timer: Value of the Period update timer, ranging from 1 to 3,600 seconds. By default, it is 30 seconds.
timeout-timer: Value of the Timeout timer, ranging from 1 to 3,600 seconds. By default, it is 180 seconds.
Use the timers command to modify the values of the three RIP timers: Period update, Timeout, and Garbage-collection.
Use the undo timers command to restore the default settings.
By default, the Period update, Timeout, and Garbage-collection timers are 30 seconds, 180 seconds, and 120 seconds, respectively.
Generally, it is regarded that the value of the Garbage-collection timer is fixed at four times that of the Period update timer. Adjusting the Period update timer will affect the Garbage-collection timer.
The modification of RIP timers is validated immediately.
Related commands: display rip.
# Set the values of the Period update timer and the Timeout timer of RIP to 10 seconds and 30 seconds respectively.
<H3C> system-view
[H3C] rip
[H3C-rip] timers update 10 timeout 30
undo traffic-share-across-interface
View
RIP view
None
Use the traffic-share-across-interface command to enable traffic to be forwarded along multiple equivalent RIP routes.
Use the undo traffic-share-across-interface command to disable this function.
By default, this function is disabled.
When the number of equivalent routes reaches the upper limit:
If this function is enabled, the newly learned equivalent route replaces the existing equivalent route in the routing table.
If this function is disabled, the first aged route entry is replaced by the newly learned route. If no route entry is aged, the newly learned equivalent route will be dropped.
# Enable traffic to be forwarded along multiple equivalent RIP routes.
<H3C> system-view
[H3C] rip
[H3C-rip] traffic-share-across-interface
& Note:
3.1.1 abr-summary
abr-summary ip-address mask [ advertise | not-advertise ]
undo abr-summary ip-address mask
View
OSPF area view
ip-address: Network segment address.
mask: Network mask.
advertise: Specifies to advertise the aggregated route that match a specific IP address and mask.
not-advertise: Specifies not to advertise the aggregated route that match a specific IP address and mask.
Use the abr-summary command to enable route aggregation on an area border router (ABR).
Use the undo abr-summary command to disable route aggregation on an ABR.
By default, an ABR does not aggregate routes.
This command is applicable to ABRs only and is used for route aggregation in an area. It allows the ABR to transmit an aggregated route to other areas.
Route aggregation means that routing information is processed by an ABR, which transmits only one route to other areas for each network segment configured with route aggregation. You can configure multiple aggregation routes in an area so that OSPF can aggregate multiple network segments.
# Aggregate the routes in the network segments 36.42.10.0 and 36.42.110.0 in OSPF area 1 into one summary route 36.42.0.0 and transmit it to other areas.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 1
[H3C-ospf-1-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[H3C-ospf-1-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[H3C-ospf-1-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
3.1.2 area
area area-id
undo area area-id
View
OSPF view
area-id: ID of an OSPF area, which can be a decimal integer (ranging from 0 to 4294967295) or in the form of an IP address.
Use the area command to enter OSPF area view.
Use the undo area command to remove the specified area.
# Enter OSPF area 0 view.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 0
[H3C-ospf-1-area-0.0.0.0]
3.1.3 asbr-summary
asbr-summary ip-address mask [ not-advertise | tag value ]
undo asbr-summary ip-address mask
View
OSPF view
ip-address: IP address to be matched, in dotted decimal notation.
mask: IP address mask, in dotted decimal notation.
not-advertise: Specifies not to advertise the aggregated route matching the specified IP address and mask. If this keyword is not provided, the aggregated route will be advertised.
tag value: Tag value, which is mainly used to control route advertisement through route-policy. It ranges from 0 to 4294967295 and defaults to 1.
Use the asbr-summary command to configure the aggregation of imported routes by OSPF.
Use the undo asbr-summary command to cancel the aggregation.
By default, imported routes are not aggregated.
After the aggregation of imported routes is configured, if the local router is an autonomous system border router (ASBR), this command aggregates the imported Type-5 LSAs in the aggregation address range. If an NSSA is configured, this command also aggregates the imported Type-7 LSAs in the summary address range.
If the local router acts as both an ABR and a transit router in the NSSA, this command aggregates Type-5 LSAs transformed from Type-7 LSAs. If the router is not the router in the NSSA, the aggregation is disabled.
Related commands: display ospf asbr-summary.
# Set aggregation of routes imported by the router H3C.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] asbr-summary 10.2.0.0 255.255.0.0 not-advertise
3.1.4 authentication-mode
authentication-mode { simple | md5 }
undo authentication-mode
View
OSPF area view
simple: Uses plain text authentication mode.
md5: Uses MD5 cipher text authentication mode.
Use the authentication-mode command to configure an OSPF area to support the authentication attribute.
Use the undo authentication-mode command to cancel the authentication attribute of this area.
By default, an area does not support authentication attribute.
Routers in one area must use the same authentication mode (no authentication, plain text authentication, or MD5 cipher text authentication). And routers on the same segment must use the same authentication key.
Use the ospf authentication-mode simple command to configure a plain text authentication key.
Use the ospf authentication-mode md5 command to configure the MD5 cipher text authentication key if the area is configured to support MD5 cipher text authentication mode.
Related commands: ospf authentication-mode.
# Enter area 0 view.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 0
# Specify the OSPF area 0 to support MD5 cipher text authentication.
[H3C-ospf-1-area-0.0.0.0] authentication-mode md5
3.1.5 default cost
default cost value
undo default cost
View
OSPF view
value: Default cost of external routes imported by OSPF, in the range 0 to 16777214. By default, its value is 1.
Use the default cost command to configure the default cost for OSPF imported external routes.
Since OSPF can import external routing information and propagate the information to the entire autonomous system, routing cost of external routes can influence route selection and calculation. Therefore, it is necessary to specify the default routing cost for the protocol to import external routes.
# Specify the default cost for OSPF imported external routes as 10.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] default cost 10
3.1.6 default interval
default interval seconds
undo default interval
View
OSPF view
seconds: Interval to import external routes in seconds, in the range 1 to 2147483647, with the default of 1.
Use the default interval command to configure the default interval for OSPF to import external routes.
Use the undo default interval command to restore the default interval.
OSPF can import external routing information and propagate it to the entire autonomous system. However, importing routes too often greatly affects the performance of the device. Therefore, it is necessary to specify the default interval for the protocol to import external routes.
# Specify the default interval for OSPF to import external routes as 10 seconds.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] default interval 10
3.1.7 default limit
default limit routes
undo default limit
View
OSPF view
routes: Number of external routes that can be imported in a unit time. The value ranges from 200 to 2,147,483,647 and defaults to 1,000.
Use the default limit command to configure the number of routes that can be imported by OSPF in a unit time.
Use the undo default limit command to restore the default value.
OSPF can import external routing information and advertise them to the whole AS. However, importing too many external routes at a time greatly affects the performance of the device. Therefore, it is necessary to set number of external routes that can be imported during each import interval.
Related commands: default interval.
# Specify the number of external routes that can be imported by OSPF in each import interval as 200.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] default limit 200
3.1.8 default tag
default tag tag
undo default tag
View
OSPF view
tag: Default tag, in the range 0 to 4294967295, with the default being 1.
Use the default tag command to configure the default tag of OSPF imported external routes.
Use the undo default tag command to restore the default tag.
When OSPF uses imported routes as the external routing information of its own autonomous system, some additional parameters are required, including the default cost and the default tag of the route.
Related commands: default type.
# Set the default tag of OSPF imported external routes of the autonomous system as 10.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] default tag 10
3.1.9 default type
default type { 1 | 2 }
undo default type
View
OSPF view
type 1: External routes of type 1.
type 2: External routes of type 2.
Use the default type command to configure the default routing information type when OSPF imports external routes.
Use the undo default type command to restore the default setting.
OSPF defines two types of external routing information.
By default, the external routes of type 2 are imported.
Related commands: default tag.
# Configure OSPF to import external routes of type 1 by default.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] default type 1
3.1.10 default-cost
default-cost value
undo default-cost
View
OSPF area view
value: Cost of the default route transmitted by OSPF to the Stub or NSSA area. The value ranges from 0 to 16777214 and defaults to 1.
Use the default-cost command to configure the cost of the default route transmitted by OSPF to the Stub or NSSA area.
Use the undo default-cost command to restore the default value.
This command only applies to an ABR in a Stub area or NSSA area.
To configure a Stub area, you need to use the stub and default-cost commands.
You must use the stub command on all the routers connected to a STUB area to configure the area with the STUB attribute. And use the default-cost command to configure the cost of the default route transmitted by an ABR to the STUB area or NSSA area.
Related commands: stub, nssa.
# Set area 1 as the Stub area and the cost of the default route transmitted to this Stub area to 60.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 1
[H3C-ospf-1-area-0.0.0.1] network 20.0.0.0 0.255.255.255
[H3C-ospf-1-area-0.0.0.1] stub
[H3C-ospf-1-area-0.0.0.1] default-cost 60
default-route-advertise [ always | cost value | type type-value | route-policy route-policy-name ]*
undo default-route-advertise [ always | cost | type | route-policy ]*
View
OSPF view
always: Generates and advertises an ase lsa describing the default route if the local router is not configured with the default route. If this keyword is not provided, the local router must be configured with the default route before it can import the ase lsa, which generates the default route.
cost value: Specifies the cost value of this ase lsa. The value ranges from 0 to 16777214 and defaults to 1.
type type-value: Specifies the cost type of this ase lsa. The value of type-value ranges from 1 to 2 and defaults 2.
route-policy route-policy-name: Specifies a route policy by name, a string of 1 to 19 characters. If you specify the default route name here, the values in ase lsa will be affected.
Use the default-route-advertise command to import the default route to OSPF route area.
Use the undo default-route-advertise command to cancel the setting.
By default, OSPF does not import the default route.
The import-route command cannot import the default route. To import the default route to the route area, you must use the default-route-advertise command. If the local router is not configured with the default route, the keyword always should be specified so that ase lsa of the default route is generated.
Related commands: import-route.
# The ase lsa of the default route is generated only if the local router has the default route.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] default-route-advertise
# The ase lsa of default route will be generated and advertised to OSPF route area even the local router has no default route.
[H3C-ospf-1] default-route-advertise always
3.1.12 display ospf abr-asbr
display ospf [ process-id ] abr-asbr
View
process-id: OSPF process ID, in the range 1 to 65535. If you do not specify a process ID, this command applies to all current OSPF processes.
Use the display ospf abr-asbr command to display the information about the ABR and ASBR of OSPF.
# Display the information about the OSPF ABRs and ASBRs.
<H3C> display ospf abr-asbr
Routing Table to ABR and ASBR
I = Intra i = Inter A = ASBR B = ABR S = SumASBR
Destination Area Cost Nexthop Interface
IA 2.2.2.2 0.0.0.0 10 10.153.17.89 Vlan-interface1
Table 3-1 Description on the fields of the display ospf abr-asbr command
Destination |
Router ID of the ABR or ASBR |
Area |
Area where the router is connected to the ASBR |
Cost |
overhead the route |
Nexthop |
Nexthop address |
Local output interface |
display ospf [ process-id ] asbr-summary [ ip-address mask ]
View
ip-address: Matched IP address, in dotted decimal notation.
Use the display ospf asbr-summary command to display the summary information of OSPF imported routes.
If you do not specify an IP address or mask, the summary information of all OSPF imported routes will be displayed.
Related commands: asbr-summary
# Display the summary information of all OSPF imported routes.
<H3C> display ospf asbr-summary
OSPF Process 1 with Router ID 10.1.1.1
Summary Addresses
Total summary address count: 2
Summary Address
net : 168.10.0.0
mask : 255.254.0.0
tag : 1
status : Advertise
The Count of Route is 0
Summary Address
net : 1.1.0.0
mask : 255.255.0.0
tag : 100
status : DoNotAdvertise
Table 3-2 Description on the fields of the display ospf asbr-summary command.
net |
Destination network segment |
mask |
Mask |
tag |
Tag |
status |
Status information, in one of the following two values: |
DoNotAdvertise |
The summary routing information to the network segment will not be advertised. |
Advertise |
The summary routing information to the network segment will be advertised. |
3.1.14 display ospf brief
display ospf [ process-id ] brief
View
Use the display ospf brief command to display brief OSPF information.
# Display brief OSPF information.
<H3C> display ospf brief
OSPF Protocol Information
RouterID: 10.1.1.1
Spf-schedule-interval: 5
Routing preference: Inter/Intra: 10 External: 150
SPF computation count: 163
Area Count: 1 Nssa Area Count: 0
Area 0.0.0.0:
Authtype: none Flags: <>
SPF scheduled: <Router Net Intra>
Interface: 110.1.1.1 (Vlan-interface110)
Cost: 11 State: DR Type: Broadcast
Priority: 11
Designated Router: 110.1.1.1
Backup Designated Router: 110.1.1.2
Timers: Hello 10, Dead 40, Poll 40, Retransmit 5, Transmit Delay 1
Table 3-3 Description on the fields of the display ospf brief command
RouterID |
ID of the router |
spf-schedule-interval |
Interval of SPF schedule |
Authtype |
Authentication type of OSPF |
Routing preference |
Routing preference of OSPF. The internal route of OSPF includes intra/inter area route, and its default routing preference is 10, while that of the external route of OSPF is 150. |
Default ASE parameters |
Default ASE parameters of OSPF, including metric, type and tag |
SPF computation count |
SPF computation count since OSPF is enabled |
Area Count |
Areas for connection to this router |
Nssa Area Count |
Number of NSSA areas |
SPF scheduled |
SPF scheduled (flag) |
Name of interface belonging to this area |
Cost |
Cost of routes |
State |
State information |
Type |
Network type of OSPF interface/the first type is the type of the imported external routes |
Priority |
Priority |
Designated Router |
IP address of designated router (DR) |
Backup Designated Router |
IP address of backup designated router (BDR) |
Timers |
OSPF timers, defined as follows: |
Hello |
Interval of hello packet |
Dead |
Interval of dead neighbors |
Poll |
Polling interval |
Retransmit |
Interval of retransmitting LSA |
Transmit Delay |
Delay time of transmitting LSA |
3.1.15 display ospf cumulative
display ospf [ process-id ] cumulative
View
Use the display ospf cumulative command to display cumulative OSPF statistics.
# Display cumulative OSPF statistics.
<H3C> display ospf cumulative
Cumulations
IO Statistics
Type Input Output
Hello 6271 9241
DB Description 9659 9915
Link-State Req 419 1426
Link-State Update 30190 51723
Link-State Ack 13642 22262
ASE: 6231 Checksum Sum: C3D40E0
LSAs originated by this router
Router: 141 Net: 5
LSAs Originated: 146 LSAs Received: 161905
Area 0.0.0.0:
Neighbors: 4 Interfaces: 5
Spf: 163 Checksum Sum 3C60A5F8
rtr: 105 net: 187 sumasb: 0 sumnet: 30500
Routing Table:
Intra Area: 8 Inter Area: 0 ASE: 5
Table 3-4 Description on the fields of the display ospf cumulative command
IO Statistics |
Type |
Type of input/output OSPF packet |
Input |
Number of received packets |
Output |
Number of transmitted packets |
ASE |
Number of all ASE LSAs |
checksum sum |
Checksum of ASE LSA |
LSAs |
originated |
Number of originated LSAs |
received |
Number of received LSAs generated by other routers |
Router |
Number of all Router LSAs |
SumNet |
Number of all Sumnet LSAs |
SumASB |
Number of all SumASB LSAs |
Area |
Neighbors |
Number of neighbors in this area |
Interfaces |
Number of interfaces in this area |
Spf |
Number of SPF computations in this area |
rtr, net, sumasb, sumnet |
Number of all LSAs in this area |
Routing Table |
Intra Area |
Number of intra-area routes |
Inter Area |
Number of inter-area routes |
ASE |
Number of external routes |
3.1.16 display ospf error
display ospf [ process-id ] error
View
Use the display ospf error command to display OSPF error information.
# Display the OSPF error information.
<H3C> display ospf error
OSPF packet error statistics:
0: IP: received my own packet 0: OSPF: wrong packet type
0: OSPF: wrong version 0: OSPF: wrong checksum
0: OSPF: wrong area id 0: OSPF: area mismatch
0: OSPF: wrong virtual link 0: OSPF: wrong authentication type
0: OSPF: wrong authentication key 0: OSPF: too small packet
0: OSPF: packet size > ip length 0: OSPF: transmit error
0: OSPF: interface down 0: OSPF: unknown neighbor
0: HELLO: netmask mismatch 0: HELLO: hello timer mismatch
0: HELLO: dead timer mismatch 0: HELLO: extern option mismatch
0: HELLO: router id confusion 0: HELLO: virtual neighbor unknown
0: HELLO: NBMA neighbor unknown 0: DD: neighbor state low
0: DD: router id confusion 0: DD: extern option mismatch
0: DD: unknown LSA type 0: LS ACK: neighbor state low
0: LS ACK: wrong ack 0: LS ACK: duplicate ack
0: LS ACK: unknown LSA type 0: LS REQ: neighbor state low
0: LS REQ: empty request 0: LS REQ: wrong request
0: LS UPD: neighbor state low 0: LS UPD: newer self-generate LSA
0: LS UPD: LSA checksum wrong 0: LS UPD: received less recent LSA
0: LS UPD: unknown LSA type 0: OSPF routing: next hop not exist
0: DD: MTU option mismatch 0: ROUTETYPE: wrong type value
0: LS UPD: LSA length wrong
Table 3-5 Description on the fields of the display ospf error command
IP: received my own packet |
Received my own packet |
OSPF: wrong packet type |
OSPF packet type error |
OSPF: wrong version |
OSPF version error |
OSPF: wrong checksum |
OSPF checksum error |
OSPF: wrong area id |
OSPF area ID error |
OSPF: area mismatch |
OSPF area mismatch |
OSPF: wrong virtual link |
OSPF virtual link error |
OSPF: wrong authentication type |
OSPF authentication type error |
OSPF: wrong authentication key |
OSPF authentication key error |
OSPF: too small packet |
OSPF packet too small |
OSPF: packet size > ip length |
OSPF packet size exceeds IP packet length |
OSPF: transmit error |
OSPF transmission error |
OSPF: interface down |
OSPF interface is down |
OSPF: unknown neighbor |
OSPF neighbors are unknown |
HELLO: netmask mismatch |
Network mask mismatch |
HELLO: hello timer mismatch |
Interval of HELLO packet is mismatched |
HELLO: dead timer mismatch |
Interval of dead neighbor packet is mismatched |
HELLO: extern option mismatch |
Extern option of Hello packet is mismatched |
HELLO: router id confusion |
Hello packet: Router ID confusion |
HELLO: virtual neighbor unknown |
Hello packet: unknown virtual neighbor |
HELLO: NBMA neighbor unknown |
Hello packet: unknown NBMA neighbor |
DD: neighbor state low |
Database description (DD) packet: asynchronous neighbor state |
DD: unknown LSA type |
DD packet: unknown LSA type |
DD: router id confusion |
DD packet: router id unidentifiable |
DD: extern option mismatch |
DD packet: external route flag error |
LS ACK: neighbor state low |
Link state acknowledgment (LS ACK) packet: asynchronous neighbor state |
LS ACK: wrong ack |
Link state acknowledgment packet: ack error |
LS ACK: duplicate ack |
Link state acknowledgment packet: ack duplication |
LS ACK: unknown LSA type |
Link state acknowledgment packet: unknown LSA type |
LS REQ: neighbor state low |
Link state request (LS REQ) packet: asynchronous neighbor state |
LS REQ: empty request |
Link state request packet: empty request |
LS REQ: wrong request |
Link state request packet: erroneous request |
LS UPD: neighbor state low |
Link state update packet: asynchronous neighbor state |
LS UPD: newer self-generate LSA |
Link state update packet: newer LSA generated by itself |
LS UPD: LSA checksum wrong |
Link state update packet: LSA checksum error |
LS UPD:received less recent LSA |
Link state update packet: received less recent LSA |
LS UPD: unknown LSA type |
Link state update packet: unknown LSA type |
OSPF routing: next hop not exist |
Next hop of OSPF routing does not exist |
DD: MTU option mismatch |
MTU option of DD packet is mismatched |
ROUTETYPE: wrong type value |
Route type: the value of the type is wrong |
LS UPD: LSA length wrong |
LSA length error |
3.1.17 display ospf interface
display ospf [ process-id ] interface [ interface-type interface-number ]
View
Use the display ospf interface command to display the OSPF interface information.
# Display the OSPF interface information of VLAN-interface 1.
<H3C> display ospf interface vlan-interface 1
Interfaces
Interface: 10.110.10.2 (Vlan-interface1)
Cost: 1 State: BackupDR Type: Broadcast
Priority: 1
Designated Router: 10.110.10.1
Backup Designated Router: 10.110.10.2
Table 3-6 Description on the fields of the display ospf interface command
Cost |
Cost of the interface |
State |
State of the interface state machine |
Type |
Network type of OSPF |
Priority |
Priority of DR for interface election |
Designated Router |
DR in the network where the interface resides |
BDR in the network where the interface resides |
Timers |
Hello |
Dead |
Poll |
Interval of poll |
Retransmit |
Transmit Delay |
3.1.18 display ospf lsdb
display ospf [ process-id [ area-id ] ] lsdb [ brief | [ asbr | ase | network | nssa | router | summary ] [ ip-address ] [ originate-router ip-address | self-originate ] ]
View
area-id: OSPF area ID, which can be a decimal integer (ranging from 0 to 4294967295) or in the form of an IP address.
brief: Displays brief database information.
asbr: Displays the database information about Type-4 LSAs (summary-Asbr-LSAs) advertised by ASBR routers.
ase: Displays the database information about the Type-5 LSAs (AS-external-LSAs). This argument is unavailable if you have provided a value for area-id.
network: Displays the database information about the Type-2 LSAs (network-LSAs).
nssa: Displays the database information about the Type-7 LSAs (NSSA-external-LSAs).
router: Displays the database information about the Type-1 LSAs (router-LSAs).
summary: Displays the database information about the Type-3 LSAs (summary-net-LSAs).
ip-address: Link state identifier (in the form of an IP address).
originate-router ip-address: Specifies the ID of the router advertising the LSAs.
self-originate: Displays the database information about the LSAs generated by the local router (self-originate LSAs).
Use the display ospf lsdb command to display the database information about OSPF connecting state.
# Display the database information about OSPF connection state.
<H3C> display ospf lsdb
Link State Database
Area: 0.0.0.0
Type LinkState ID AdvRouter Age Len Sequence Metric Where
Rtr 2.2.2.2 2.2.2.2 465 36 8000000c 0 SpfTree
Rtr 1.1.1.1 1.1.1.1 449 36 80000004 0 SpfTree
Net 10.153.17.89 2.2.2.2 465 32 80000004 0 SpfTree
SNet 10.153.18.0 1.1.1.1 355 28 80000003 10 Inter List
Area: 0.0.0.1
Rtr 3.3.3.3 3.3.3.3 429 36 8000000a 0 Clist
Net 10.153.18.89 3.3.3.3 429 32 80000003 0 SpfTree
SNet 10.153.17.0 1.1.1.1 355 28 80000003 10 Inter List
ASB 2.2.2.2 1.1.1.1 355 28 80000003 10 SumAsb List
AS External Database:
ASE 10.153.18.0 1.1.1.1 1006 36 80000002 1 Ase List
ASE 10.153.16.0 2.2.2.2 798 36 80000002 1 Uninitialized
ASE 10.153.17.0 2.2.2.2 623 36 80000003 1 Uninitialized
ASE 10.153.17.0 1.1.1.1 1188 36 80000002 1 Ase List
Table 3-7 Description on the fields of the display ospf lsdb command
Type |
Type of the LSA |
LinkStateID |
Link state ID of the LSA |
AdvRouter |
Router ID of the router that advertises the LSA |
Age |
Age of the LSA |
Len |
Length of the LSA |
Sequence |
Sequence number of the LSA |
Metric |
Cost from the router that advertises the LSA to LSA destination |
Where |
Location of the LSA |
<H3C> display ospf lsdb ase
Link State Data Base
type: ASE
ls id : 2.2.0.0
adv rtr: 1.1.1.1
ls age: 349
len: 36
seq#: 80000001
chksum: 0xfcaf
Options: (DC)
Net mask:255.255.0.0
Tos 0 metric: 1
E type : 2
Forwarding Address: 0.0.0.0
Tag: 1
Table 3-8 Description on the fields of the display ospf lsdb ase command
type |
Type of the LSA |
ls id |
adv rtr |
ls age |
Age of the LSA |
len |
Length of the LSA |
seq# |
chksum |
Checksum of the LSA |
Options |
Options of the LSA |
Net mask |
Network mask |
E type |
Type of external route |
Forwarding Address |
Forwarding address |
Tag |
Tag |
3.1.19 display ospf nexthop
View
Use the display ospf nexthop command to display the OSPF next-hop information.
# Display the OSPF next-hop information.
<H3C> display ospf nexthop
Next hops:
Address Type Refcount Intf Addr Intf Name
202.38.160.1 Direct 3 202.38.160.1 Vlan-interface2
202.38.160.2 Neighbor 1 202.38.160.1 Vlan-interface2
Table 3-9 Description on the fields of the display ospf nexthop command
Address |
Address of next hop |
Type |
Type of next hop |
Refcount |
Reference count of the next hop, namely, number of routes using the next hop |
Intf Addr |
IP address of the interface to the next hop |
Intf Name |
Interface to the next hop |
nexthop |
Next hop |
3.1.20 display ospf peer
display ospf [ process-id ] peer [ brief | statistics ]
View
Use the display ospf peer command to display the information about OSPF peer.
Use the display ospf peer brief command to display the brief information about each OSPF peer.
Use the display ospf peer statistics command to display the statistics of each OSPF peer.
# Display the information about OSPF peer.
<H3C> display ospf peer
Neighbors
Area 0.0.0.0 interface 10.153.17.88(Vlan-interface1)'s neighbor(s)
RouterID: 2.2.2.2 Address: 10.153.17.89
State: Full Mode: Nbr is Master Priority: 1
DR: 10.153.17.89 BDR: 10.153.17.88
Dead timer expires in 31s
Neighbor has been up for 01:14:14
Table 3-10 Description on the fields of the display ospf peer command
RouterID |
Router ID of neighbor router |
Address |
Address of the interface, through which neighbor router communicates with the router |
State |
State of adjacency relation |
Mode |
Master/Slave mode formed by negotiation in exchanging DD packet |
Priority |
Priority of DR/BDR for neighbor election |
DR |
IP address of the interface of the elected DR |
BDR |
IP address of the interface of the elected BDR |
Dead timer expires in 31s |
If no hello packet is received from the peer within this interval, the peer will be considered invalid. |
Neighbor has been up for 01:14:14 |
Time of neighbor connection |
# Display OSPF peer statistics.
<H3C> display ospf peer statistics
Neighbor Statistics
Area ID Down Attempt Init 2-Way ExStart Exchange Loading Full Total
0.0.0.0 0 0 0 0 0 0 0 1 1
0.0.0.1 0 0 0 0 0 0 0 1 1
Total 0 0 0 0 0 0 0 2 2
Table 3-11 Description on the fields of the display ospf peer statistics command
Area ID |
Area ID |
Down |
Initial state for OSPF to establish neighbor relation, which indicates that OSPF router does not receive the message from a certain neighbor router within a period of time |
Attempt |
This state is enabled in an NBMA environment, such as Frame Relay, X.25 or ATM. The state indicates that OSPF router does not receive the message from a certain neighbor router within a period of time, but still attempts to send Hello packets to the adjacent routers for communications in a lower frequency. |
Init |
Indicates that OSPF router has received Hello packet from a neighbor router, but its IP address is not contained in the Hello packet. Therefore, a two-way communication between them has not been established. |
2-Way |
Indicates that a two-way communication between OSPF router and neighbor router has been established. DR and BDR can be selected in this state (or higher state). |
ExStart |
In this state, the router determines the sequence number of initial database description (DD) packet used for data exchange, so that it can obtain the latest link state information |
Exchange |
Indicates that OSPF router sends DD packet to its neighbor routers to exchange link state information |
Loading |
In this state, OSPF router requests neighbor routers based on the updated link state information from neighbor routers and its expired information, and waits for response from neighbor routers |
Full |
Indicates that database synchronization between the routers that have established neighbor relation has been completed, and their link state databases have been consistent |
3.1.21 display ospf request-queue
display ospf [ process-id ] request-queue
View
Use the display ospf request-queue command to display the information about the OSPF request-queue.
# Display the information about the OSPF request-queue.
<H3C> display ospf request-queue
Request List
The Router's Neighbor is
RouterID: 10.1.1.1 Address: 120.1.1.1
Interface: 120.1.1.2 Area: 0.0.0.0
Request list:
LSID:151.14.83.0 AdvRouter:5.4.0.0 Sequence:8000002a Age:545
LSID:151.10.91.0 AdvRouter:5.4.0.0 Sequence:8000002a Age:545
Table 3-12 Description on the fields of the display ospf request-queue command
RouterID |
Address |
Address of the interface, through which neighbor routers communicate with the router |
Address of the interface on the network segment |
Area |
Area number of OSPF |
LSID |
Link State ID of the LSA |
AdvRouter |
Router ID of the router that advertised the LSA |
Sequence |
Sequence number of the LSA, used to discover old and repeated LSAs |
Age |
Age of the LSA |
3.1.22 display ospf retrans-queue
display ospf [ process-id ] retrans-queue
View
process-id: OSPF process ID. If you do not specify a process ID, this command applies to all current OSPF processes.
Use the display ospf retrans-queue command to display the information about the OSPF retransmission queue.
# Display the information about the OSPF retransmission queue.
<H3C> display ospf retrans-queue
OSPF Process 200 with Router ID 103.160.1.1
Retransmit List
The Router's Neighbors is
RouterID: 162.162.162.162 Address: 103.169.2.2
Interface: 103.169.2.5 Area: 0.0.0.1
Retrans list:
Type: ASE LSID:129.11.77.0 AdvRouter:103.160.1.1
Type: ASE LSID:129.11.108.0 AdvRouter:103.160.1.1
Table 3-13 Description on the fields of the display ospf retrans-queue command
RouterID |
Address |
Area |
Type |
Type of the LSA |
LSID |
AdvRouter |
3.1.23 display ospf routing
display ospf [ process-id ] routing
View
Use the display ospf routing command to display the information about OSPF routing table.
# Display OSPF routing information.
<H3C> display ospf routing
Routing Tables
Routing for Network
Destination Cost Type NextHop AdvRouter Area
10.110.0.0/16 1 Net 10.110.10.1 1.1.1.1 0.0.0.0
10.10.0.0/16 1 Stub 10.10.0.1 3.3.3.3 0.0.0.0
Total Nets: 2
Intra Area: 2 Inter Area: 0 ASE: 0 NSSA: 0
Table 3-14 Description on the fields of the display ospf routing command
Destination |
Cost |
Cost of route |
Type |
Type of route |
NextHop |
Next hop of route |
AdvRouter |
ID of the router that advertises the route |
Area |
Area ID |
Intra Area |
Inter Area |
ASE |
NSSA |
Number of NSSA routes |
3.1.24 display ospf vlink
View
Use the display ospf vlink command to display the information about OSPF virtual links.
# Display OSPF virtual link information.
<H3C> display ospf vlink
Virtual Links
Virtual-link Neighbor-id -> 2.2.2.2, State: Full
Cost: 0 State: Full Type: Virtual
Transit Area: 0.0.0.2
Timers: Hello 10, Dead 40, Poll 0, Retransmit 5, Transmit Delay 1
Table 3-15 Description on the fields of the display ospf vlink command
Virtual-link Neighbor-id |
Router ID of virtual-link neighbor router |
State |
State |
IP address of the interface on the virtual link |
Cost |
Route cost of the interface |
Type |
Type: virtual link |
Transit Area |
ID of transit area that the virtual link passes, and it cannot be backbone area, STUB area, or NSSA area |
Timers |
Hello |
Dead |
Poll |
Interval of poll |
Retransmit |
Transmit Delay |
3.1.25 filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ]
undo filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ]
View
OSPF view
acl-number: Basic or advanced ACL number, in the range 2000 to 3999.
ip-prefix-name: Name of the address prefix list, a string of 1 to 19 characters.
protocol: Routing protocol advertising the routing information. At present, it can be direct, rip, bgp, isis or static.
Use the filter-policy export command to enable the ASBR routers to filter the external routes imported to OSPF. This command is applicable to ASBR routers only.
Use the undo filter-policy export command to cancel the filtering rule configured.
By default, OSPF does not receive routes advertised by the other routing protocols.
& Note:
l The filter-policy export command only takes effect on routes imported to the local device through the import-route command. The command does not take effect if it is executed before the import-route command.
l If the protocol argument is not specified in the filter-policy export command, this command takes effect on all the routes imported to the local device through the import-route command.
Related commands: acl, ip ip-prefix.
# Configure OSPF to advertise only the routing information permitted by acl 2000.
<H3C> system-view
[H3C] acl number 2000
[H3C-acl-basic-2000] rule permit source 11.0.0.0 0.255.255.255
[H3C-acl-basic-2000] rule deny source any
[H3C-ospf-1] filter-policy 2000 export
3.1.26 filter-policy import
filter-policy { acl-number | ip-prefix ip-prefix-name | gateway ip-prefix-name } import
undo filter-policy { acl-number | ip-prefix ip-prefix-name | gateway ip-prefix-name } import
View
OSPF view
acl-number: Basic or advanced access control list used for routing information filtering based on destination addresses.
ip-prefix-name: Name of the address prefix list used for routing information filtering based on destination addresses, a string of 1 to 19 characters.
gateway ip-prefix-name: Specifies the name of the address prefix list used for filtering the addresses of the neighbor routers advertising the routing information.
Use the filter-policy import command to configure the OSPF rules for filtering the routing information received.
Use the undo filter-policy import command to cancel the filtering of the routing information received.
By default, no filtering of the received routing information is performed.
In some situations, it may be required that only the routing information meeting some conditions can be received. You can use the filter-policy command to set the filtering conditions for the routing information to be received. Only the routing information passing the filter can be received.
The filter-policy import command filters the routes calculated by OSPF. Only the routes passing the filter can be added to the routing table. The routes can be filtered based on next hop and destination address.
OSPF is a dynamic routing protocol based on link state, with routing information hidden in LSAs. Therefore, OSPF cannot filter any advertised or received LSA. This command is used much less in OSPF than in distance-vector routing protocols.
# Filter the received routing information according to the rule defined by ACL 2000.
<H3C> system-view
[H3C-acl-basic-2000] rule permit source 20.0.0.0 0.255.255.255
[H3C-ospf-1] filter-policy 2000 import
3.1.27 import-route
import-route protocol [ process-id | allow-ibgp ] [ cost value | type value | tag value | route-policy route-policy-name ]*
View
OSPF view
protocol: Redistributes routes from the routing protocol. At present, it can be direct, rip, bgp, isis, static, ospf, ospf-ase and ospf-nssa.
process-id: OSPF process ID, in the range 1 to 65535. It is for route redistribution from another OSPF process.
cost value: Specifies the cost of imported external routes, in the range 0 to 16777214.
type value: Specifies the cost type of imported external routes. The value ranges from 1 to 2.
tag value: Specifies the tag of imported external routes.
route-policy route-policy-name: Imports only the routes matching the specified route-policy. The route-policy-name argument is a string of 1 to 19 characters.
Use the import-route command to import external routes.
Use the undo import-route command to cancel the importing of external routes.
& Note:
You are recommended to configure the route type, cost and tag together in one command. When you configure them individually, the new configuration will overwrite the old one.
By default, the routing information of other protocols is not imported.
Note that:
l It is recommended to configure parameters such as type, cost and tag for redistributed routes with one command line because reconfiguring the command overwrites the previous configuration.
& Note:
# Import RIP routes as type-2 routes, with the route tag of 33 and the route cost of 50.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] import-route rip type 2 tag 33 cost 50
3.1.28 network
network ip-address ip-mask
undo network ip-address ip-mask
View
OSPF area view
ip-address: Address of the network segment where the interface resides.
ip-mask: IP address wildcard shielded text (similar to the complement of the IP address mask).
Use the network command to enable an interface to run the OSPF protocol.
Use the undo network command to disable an interface from running OSPF.
By default, the interface does not belong to any area.
To run OSPF on an interface, the master IP address of this interface must be in the network segment specified by this command. If only the slave IP address of the interface is in the network segment specified by this command, this interface will not run OSPF.
Related commands: ospf.
# Specify the interfaces whose master IP addresses are in the segment of 10.110.36.0 to run OSPF and specify the number of the OSPF area (where these interfaces reside) as 6.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 6
[H3C-ospf-1-area-0.0.0.6] network 10.110.36.0 0.0.0.255
3.1.29 nssa
nssa [ default-route-advertise | no-import-route | no-summary ]*
undo nssa
View
OSPF area view
default-route-advertise: Imports the default route to the NSSA area.
no-import-route: Specifies not to import route to the NSSA area.
no-summary: An ABR is disabled from transmitting summary_net LSAs to the NSSA area.
Use the nssa command to configure an OSPF area as an NSSA area.
Use the undo nssa command to cancel the function.
By default, no NSSA area is configured.
For all the routers connected to the NSSA area, the nssa command must be used to configure the area as the NSSA attribute.
The default-route-advertise keyword is used to generate the default type-7 LSA. Whether or not the route 0.0.0.0 exists in the routing table on the ABR, the type-7 LSA default route will always be generated. The type-7 LSA default route is generated only when the route 0.0.0.0 exists in the routing table on the ASBR.
On the ASBR, if the no-import-route keyword is provided, the external route imported by OSPF with the import-route command will not be advertised to NSSA area.
# Configure area 1 as NSSA area.
[H3C] ospf 1
[H3C-ospf-1] area 1
[H3C-ospf-1-area-0.0.0.1] network 36.0.0.0 0.255.255.255
[H3C-ospf-1-area-0.0.0.1] nssa
3.1.30 ospf
ospf [ process-id [ router-id router-id ] ]
undo ospf [ process-id ]
View
process-id: OSPF process ID, in the range 1 to 65535. By default, the process ID is 1. The ID is locally significant.
router-id: Router ID used by an OSPF process, in dotted decimal notation.
Use the ospf command to enable OSPF.
Use the undo ospf command to disable OSPF.
After OSPF is enabled, you can perform the related configuration in OSPF view.
By default, the system does not run OSPF.
Related commands: network.
# Enable OSPF.
<H3C> system-view
[H3C] router id 10.110.1.8
[H3C] ospf 1
[H3C-ospf-1]
# Enable and run OSPF with the process ID of 120.
<H3C> system-view
[H3C] ospf 120
[H3C-ospf-120]
3.1.31 ospf authentication-mode
ospf authentication-mode { simple password | md5 key-id key }
undo ospf authentication-mode { simple | md5 }
View
Interface view
simple password: Uses plain text authentication. The password argument is a string of up to eight characters.
key-id: ID of the authentication key in MD5 authentication mode, in the range 1 to 255.
key: MD5 authentication key. You can either input the key in plain text (a string of 1 to 16 characters) or in a cipher text (exactly 24 characters). However, the key is displayed in a cipher text of 24 characters with the display current-configuration command.
Use the ospf authentication-mode command to configure the authentication mode and key ID for adjacent routers.
Use the undo ospf authentication-mode command to remove specified configuration.
By default, no authentication is available on an interface.
Interfaces attached to the same network segment must have the same authentication password and mode.
In addition, you need to use the authentication-mode command to set the authentication type of the area, so as to validate the configuration.
Related commands: authentication-mode.
# Configure area 1 where the network segment 131.119.0.0 of interface VLAN-interface 10 resides to support MD5 cipher text authentication. Set the authentication key identifier to 15 and the authentication key to abc.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 1
[H3C-ospf-1-area-0.0.0.1] network 131.119.0.0 0.0.255.255
[H3C-ospf-1-area-0.0.0.1] authentication-mode md5
[H3C-Vlan-interface10] ospf authentication-mode md5 15 abc
3.1.32 ospf cost
ospf cost value
undo ospf cost
View
Interface view
value: Value of OSPF cost, in the range 1 to 65535.
Use the ospf cost command to configure the cost for running OSPF on the interface.
Use the undo ospf cost command to restore the default cost.
For the switch, the default cost for running OSPF protocol on a VLAN interface is 1.
# Set the current OSPF interface cost to 33.
<H3C> system-view
[H3C-Vlan-interface10] ospf cost 33
3.1.33 ospf dr-priority
ospf dr-priority value
undo ospf dr-priority
View
Interface view
value: DR priority of the interface, in the range 0 to 255. The default value is 1.
Use the ospf dr-priority command to configure the priority for DR election on an interface.
Use the undo ospf dr-priority command to restore the default value.
The priority determines the qualification of the interface in DR election. The interface with higher priority is preferred in case an election conflict occurs.
# Set the priority of the interface VLAN-interface 10 to 8.
<H3C> system-view
[H3C-Vlan-interface10] ospf dr-priority 8
3.1.34 ospf mib-binding
ospf mib-binding process-id
undo ospf mib-binding
View
process-id: OSPF process ID. It ranges from 1 to 65535 and defaults to 1.
Use the ospf mib-binding command to bind MIB operation to a specified OSPF process.
Use the undo ospf mib-binding command to restore the default setting.
By default, MIB operation is bound to the first OSPF process.
With this command, you can bind MIB operation to other OSPF processes.
To cancel the binding, use the undo ospf mib-binding command. The default binding relationship will be established automatically.
# Bind MIB operation to OSPF process 100.
<H3C> system-view
[H3C] ospf mib-binding 100
# Bind MIB operation to OSPF process 200.
<H3C> system-view
[H3C] ospf mib-binding 200
# Cancel the binding of MIB operation.
<H3C> system-view
[H3C] undo ospf mib-binding
3.1.35 ospf mtu-enable
ospf mtu-enable
undo ospf mtu-enable
View
Interface view
None
Use the ospf mtu-enable command to enable an interface to add real MTU into database description (DD) packets.
Use the undo ospf mtu-enable command to restore the default.
By default, an interface adds the MTU value of 0 into DD packets, that is, no real MTU is added.
DD packets are used to describe its own LSDB when the router running OSPF protocol is synchronizing the database.
The default MTU value of DD packet is 0. You can use this command to let the specified interface add the real MTU value into DD packets.
# Enable interface VLAN-interface 3 to add real MTU value into DD packets.
<H3C> system-view
[H3C] interface Vlan-interface 3
[H3C-Vlan-interface3] ospf mtu-enable
3.1.36 ospf network-type
ospf network-type { broadcast | nbma | p2mp | p2p }
undo ospf network-type
View
Interface view
broadcast: Specifies the network type as broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as point-to-multipoint.
p2p: Specifies the network type as to point-to-point.
Use the ospf network-type command to configure the network type for an OSPF interface.
Use the undo ospf network-type command to restore the default network type for an OSPF interface.
OSPF divides networks into four types based on link layer protocol:
l Broadcast: If Ethernet or FDDI is adopted, OSPF defaults the network type to broadcast.
l Non-Broadcast Multi-access (nbma): If Frame Relay, ATM, HDLC or X.25 is adopted, OSPF defaults the network type to NBMA.
l Point-to-Multipoint (p2mp): OSPF will not default the network type of any link layer protocol to p2mp. The general undertaking is to change a partially connected NBMA network to p2mp network if the NBMA network is not fully-meshed.
l Point-to-point (p2p): If PPP, LAPB or POS is adopted, OSPF defaults the network type to p2p.
If there is any router not supporting multicast addresses on a broadcast network, the network type of the interface can be changed to NBMA. Alternatively, the network type of the interface can be changed from NBMA to broadcast.
For a non-broadcast multi-accessible network to be of NBMA type, any two routers in the network must be directly reachable to each other through a virtual circuit. In other words, the network must be fully-meshed.
For a network not meeting this condition, the network type of the interface must be changed to point-to-multipoint. In this way, routing information can be exchanged between two routers not directly reachable to each other through another router that is directly reachable to the two routers.
If only two routers run OSPF in the same network segment, the network type of the interface can also be changed to point-to-point.
Note that you must use the peer command to configure the peer if the network type of the interface is NBMA or manually changed to NBMA with the ospf network-type command.
Related commands: ospf dr-priority.
# Set the network type for interface VLAN-interface 10 to NBMA.
<H3C> system-view
[H3C-Vlan-interface10] ospf network-type nbma
3.1.37 ospf timer dead
ospf timer dead seconds
undo ospf timer dead
View
Interface view
seconds: Dead interval of the OSPF neighbor in seconds, in the range 1 to 65535.
Use the ospf timer dead command to configure the dead interval of the OSPF peer.
Use the undo ospf timer dead command to restore the default.
By default, the dead interval is 40 seconds for p2p and broadcast interfaces and is 120 seconds for p2mp and nbma interfaces.
If an interface receives no Hello packet from the neighbor after the dead interval elapsed, the interface considers the neighbor as dead. The dead interval on an interface is at least four times the hello interval. Any two routers attached to the same segment must have the same dead interval.
Related commands: ospf timer hello.
# Set the dead interval on the interface VLAN-interface 10 to 80 seconds.
<H3C> system-view
[H3C-Vlan-interface10] ospf timer dead 80
3.1.38 ospf timer hello
ospf timer hello seconds
undo ospf timer hello
View
Interface view
seconds: Hello interval in seconds, in the range 1 to 255.
Use the ospf timer hello command to configure the hello interval (interval for transmitting Hello messages) on an interface.
Use the undo ospf timer hello command to restore the default hello interval on an interface.
By default, the hello interval is 10 seconds for p2p or broadcast interfaces and 30 seconds for p2mp or nbma interfaces.
Related commands: ospf timer dead.
# Configure the hello interval on the interface VLAN-interface 10 as 20 seconds.
<H3C> system-view
[H3C-Vlan-interface10] ospf timer hello 20
3.1.39 ospf timer poll
ospf timer poll seconds
undo ospf timer poll
View
Interface view
seconds: Poll interval in seconds. The value ranges from 1 to 65,535 and defaults to 40.
Use the ospf timer poll command to configure the poll interval on an NBMA and p2mp interface.
Use the undo ospf timer poll command to restore the default value.
When an NBMA or P2MP interface finds its neighbor is dead, it will send hello packets at the poll interval. The poll interval is at least three times the hello interval.
# Set the poll timer interval on interface VLAN-interface 20 to 120 seconds.
<H3C> system-view
[H3C] interface Vlan-interface 20
[H3C-Vlan-interface20] ospf timer poll 120
3.1.40 ospf timer retransmit
ospf timer retransmit interval
undo ospf timer retransmit
View
Interface view
interval: LSA retransmit timer interval in seconds, in the range 1 to 3600. The default is 5.
Use the ospf timer retransmit command to set the LSA retransmit interval on an interface.
Use the undo ospf timer retransmit command to restore the default.
After sending a LSA, an interface waits for an acknowledgement packet. If the interface receives no acknowledgement when the retransmit interval elapses, it will retransmit the LSA.
The retransmit interval should not be too small to avoid unnecessary retransmissions (See RFC 2328).
# Set the LSA retransmit interval on the interface VLAN-interface 10 to 12 seconds.
<H3C> system-view
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] ospf timer retransmit 12
3.1.41 ospf trans-delay
ospf trans-delay seconds
undo ospf trans-delay
View
Interface view
seconds: LSA transmission delay time in seconds. in the range 1 to 3,600. The default is 1.
Use the ospf trans-delay command to configure the LSA transmission delay time on an interface.
Use the undo ospf trans-delay command to restore the default.
Each LSA in the LSDB has an age (incremented 1 by a second), but a LSA is not aged out on transmission. It is necessary to add a transmit delay into its age time, which is important for transmission on low speed networks.
# Set the LSA transmit delay time on the interface VLAN-interface 10 to 3 seconds.
<H3C> system-view
[H3C-Vlan-interface10] ospf trans-delay 3
3.1.42 peer
peer ip-address [ dr-priority dr-priority-value ]
undo peer ip-address
View
OSPF view
ip-address: IP address of the peer.
dr-priority-value: Value of the corresponding priority of a neighbor in the NBMA network. It ranges from 0 to 255 and defaults to 1.
Use the peer command to specify the IP address of an NBMA neighbor, and the DR priority of the neighbor.
Use the undo peer command to cancel this configuration.
# Configure the IP address of the neighbor router as 10.1.1.1.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] peer 10.1.1.1
3.1.43 preference
preference [ ase ] value
undo preference [ ase ]
View
OSPF view
value: Priority value, in the range 1 to 255.
ase: Specifies the priority of imported external routes of the AS.
Use the preference command to configure the priority of an OSPF routes.
Use the undo preference command to restore the default.
By default, the priority is 10 for OSPF internal routes and 150 external routes.
Since a router may run multiple dynamic routing protocols, it has to decide on routes found by these protocols. Every protocol has a priority to help the router determine which route to use especially when multiple routes to the same destination are found by several routing protocols. The route found by the protocol with the highest priority will be used.
# Specify the priority of an imported external route of the AS as 160.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] preference ase 160
3.1.44 protocol multicast-mac enable
undo protocol multicast-mac enable
View
None
Use the protocol multicast-mac enable command to enable the sending of protocol multicast MAC addresses.
Use the undo protocol multicast-mac enable command to disable the sending of protocol multicast MAC addresses.
By default, protocol multicast MAC address sending is enabled.
If OSPF is configured when Layer-2/Layer-3 multicast function is enabled, the system will multicast the broadcast routing protocol packets because the broadcast MAC address and multicast MAC address used by OSPF are the same. This makes broadcast packets unable to reach the destination host and adversely affects the operation of the routing protocol.
You can disable the protocol multicast MAC address sending function so that the system correctly forwards OSPF multicast packets, thus ensuring the normal operation of the routing protocol.
& Note:
l To enable OSPF when Layer-2/Layer-3 multicast function is enabled in the system, make sure you use the undo protocol multicast-mac enable command to disable protocol multicast MAC address sending.
l You do not need to disable protocol multicast MAC address sending if the system is enabled with OSPF only.
# Disable protocol multicast MAC address sending.
<H3C>system-view
[H3C]undo protocol multicast-mac enable
3.1.45 reset ospf
reset ospf [ statistics ] { all | process-id }
View
all: Resets all OSPF processes.
process-id: OSPF process ID, in the range 1 to 65535. If this argument is not specified, all OSPF processes will be reset.
statistics: Resets OSPF statistics.
Use the reset ospf all command to reset all OSPF processes.
Use the reset ospf process-id command to reset the specified OSPF process and clear the statistics.
After you use this command to reset an OSPF process:
l Invalid LSA is cleared immediately before LSA times out.
l A new Router ID takes effect if the Router ID changes.
l DR and BDR are re-elected conveniently.
l OSPF configuration before the restart will not lose.
After this command is issued, the system will prompt you to confirm whether to re-enable OSPF.
# Reset all the OSPF processes.
<H3C> reset ospf all
# Reset OSPF process 200.
<H3C> reset ospf 200
3.1.46 router id
router id router-id
undo router id
View
router-id: Router ID, in dotted decimal notation, in the range 0 to 255.
Use the router id command to configure the ID of an OSPF router.
Use the undo router id command to cancel the router ID that has been set.
# Set the router ID to 10.1.1.3.
<H3C> system-view
[H3C] router id 10.1.1.3
3.1.47 silent-interface
silent-interface interface-type interface-number
undo silent-interface interface-type interface-number
View
OSPF view
Use the silent-interface command to disable an interface from transmitting OSPF packets.
Use the undo silent-interface command to restore the default setting.
By default, an interface can transmit OSPF packets.
To make no routing information obtained by other routers on a network segment, you can use this command to disable the interface from sending OSPF packets.
On a switch, this command can be used to enable/disable OSPF packet transmission through the specified VLAN interface.
# Disable interface VLAN-interface 20 from transmitting OSPF packets.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] silent-interface Vlan-interface 20
3.1.48 snmp-agent trap enable ospf
snmp-agent trap enable ospf [ process-id ] [ ifstatechange | iftxretransmit | ifrxbadpkt | ifcfgerror | virifstatechange | nbrstatechange | virnbrstatechange | virifcfgerror | ifauthfail | virifauthfail | virifrxbadpkt | viriftxretransmit | originatelsa | maxagelsa | lsdboverflow | lsdbapproachoverflow ]*
undo snmp-agent trap enable ospf [ process-id ] [ ifstatechange | iftxretransmit | ifcfgerror |virifstatechange | nbrstatechange | virnbrstatechange | virifcfgerror | ifauthfail | virifauthfail | ifrxbadpkt | virifrxbadpkt | viriftxretransmit | originatelsa | maxagelsa | lsdboverflow | lsdbapproachoverflow ]*
View
ifstatechange, virifstatechange, nbrstatechange, virnbrstatechange, ifcfgerror, virifcfgerror, ifauthfail, virifauthfail, ifrxbadpkt, iftxretransmit, virifrxbadpkt, viriftxretransmit, originatelsa, maxagelsa, lsdboverflow, and lsdbapproachoverflow: Types of TRAP packets that the switch produces when OSPF fails to work normally.
Use the snmp-agent trap enable ospf command to enable the OSPF TRAP function.
Use the undo snmp-agent trap enable ospf command to disable the OSPF TRAP function.
This command does not apply to the OSPF processes that are started after the command is executed.
By default, a switch does not send TRAP packets when OSPF fails to work normally.
For details about SNMP TRAP configuration, refer to section System Management in this manual.
# Enable the TRAP function for OSPF process 100.
<H3C> system-view
[H3C] snmp-agent trap enable ospf 100
3.1.49 spf-schedule-interval
spf-schedule-interval interval
undo spf-schedule-interval
View
OSPF view
interval: SPF calculation interval in seconds, in the range 1 to 10. The default is 5.
Use the spf-schedule-interval command to configure the OSPF route calculation interval.
Use the undo spf-schedule-interval command to restore the default setting.
Based on its LSDB, an OSPF router calculates the shortest route tree with itself being the root, using which to determine the next hop to a destination. Through adjusting SPF calculation interval, you can protect bandwidth and router resources from being over-consumed due to frequent network changes.
# Set the OSPF route calculation interval to 6 seconds.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] spf-schedule-interval 6
3.1.50 stub
stub [ no-summary ]
undo stub
View
OSPF area view
no-summary: Disables an ABR from transmitting Summary LSAs to the Stub area.
Use the stub command to configure an OSPF area as a stub area.
Use the undo stub command to remove the configuration.
By default, no area is stub area.
If the router is an ABR, it will send a default route to the connected stub area. Use the default-cost command to configure the default route cost. In addition, you can specify the no-summary keyword in the stub command to disable the receiving of type-3 LSAs by the stub area connected to the ABR.
Related commands: default-cost.
# Configure OSPF area 1 as a stub area.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 1
3.1.51 vlink-peer
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | simple password | md5 keyid key ]*
undo vlink-peer router-id
View
OSPF area view
route-id: Router ID of virtual link peer.
hello seconds: Specifies the interval, in seconds, at which the router transmits hello packets. The value ranges from 1 to 8192 and defaults to 10. This value must equal to the hello seconds value of the router virtually linked to the interface.
retransmit seconds: Specifies the interval, in seconds, for retransmitting the LSA packets on an interface. It ranges from 1 to 3600 and defaults to 5.
trans-delay seconds: Specifies the delay, in seconds, for transmitting LSA packets on an interface. It ranges from 1 to 3600 and defaults to 1.
dead seconds: Specifies the interval, in seconds, of death timer. It ranges from 1 to 8192 and defaults to 40. This value must equal the dead seconds of the router virtually linked to it and must be at least four times of the hello seconds.
simple password: Specifies the simple text authentication password, which contains up to eight characters, of the interface. This value must equal the authentication key of the virtually linked peer.
keyid: MD5 authentication key ID. It ranges from 1 to 255. It must be equal to the authentication key ID of the virtually linked peer.
key: MD5 authentication key. If you use simple text authentication key, you can input a string containing 1 to 16 characters. When you use the display current-configuration command to display system information, the MD5 authentication key is displayed in the form of cipher text with a length of 24 characters. Inputting the key in the form of cipher text with a length of 24 characters is also supported.
Use the vlink-peer command to create and configure a virtual link.
Use the undo vlink-peer command to cancel an existing virtual link.
According to RFC 2328, an OSPF area must be connected to the backbone network. You can use the vlink-peer command to keep the connectivity. Virtual link can be regarded as a common interface that uses OSPF because the principle for configuring the parameters such as hello, retransmit, and trans-delay on it is similar.
Note that, when configuring virtual link authentication, you use the authentication-mode command to specify the authentication mode as MD5 cipher text or simple text on the backbone network.
Related commands: authentication-mode, display ospf.
# Create a virtual link to 10.110.0.3 and use the MD5 cipher authentication mode.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 10.0.0.0
[H3C-ospf-1-area-10.0.0.0] vlink-peer 10.110.0.3 md5 3 345
Chapter 4 Integrated IS-IS Configuration Commands
& Note:
The term “router” in this document refers to a router in a generic sense or an Ethernet switch running routing protocols.
4.1 Integrated IS-IS Configuration Commands
4.1.1 area-authentication-mode
area-authentication-mode { simple | md5 } password [ ip | osi ]
undo area-authentication-mode { simple | md5 } [ ip | osi ]
View
IS-IS view
simple: Specifies to send the password in plain text.
md5: Specifies to send the password encrypted with MD5.
password: Specifies the password to be set. For the simple authentication mode, the password must be plain text. For the md5 authentication mode, the password can be either plain text or ciphertext, and the result depends on the input. A plain password can be a string less than 16 digits, such as abc918. A cipher password must be a ciphertext of 24 digits, such as (TT8F]Y\5SQ=^Q`MAF4<1!!.
ip: Specifies the system to check the configuration for the corresponding field of IP in LSP.
osi: Specifies the system to check the configuration for the corresponding field of OSI in LSP.
Use the area-authentication-mode command to configure IS-IS to authenticate the packets (LSP, CSNP and PSNP) received from level-1 route using the predefined mode and password.
Use the undo area-authentication-mode command to disable IS-IS from authenticating the received packets.
The system will neither authenticate the packets received from level-1 route nor check its password by default.
We can use this command to clear all level-1 routing packets not compatible with the area authentication password set by the command. And at the same time, we also instruct the system to follow a specific mode to insert the area authentication password in all the level-1 routing packets sent from the local node.
Related commands: reset isis all, domain-authentication-mode, isis authentication-mode.
# Set the area authentication password to hello, and the authentication mode to simple.
<H3C> system-view
[H3C] isis
[H3C-isis] area-authentication-mode simple hello
4.1.2 cost-style
undo cost-style
View
narrow: Specifies to receive and send narrow packets only.
wide: Specifies to receive and send wide packets only.
compatible: Specifies to receive or send both wide and narrow packets.
narrow-compatible: Specifies to receive both narrow and wide packets, but send only narrow packets.
wide-compatible: Specifies to receive both narrow and wide packets, but send only wide packets.
relax-spf-metric: Specifies to allow receiving routes with cost bigger than 1,024. If this keyword is not configured, any route with cost larger than 1,024 will be dropped. This configuration is only available when the compatible keyword or when the narrow-compatible keyword is provided.
Use the cost-style command to set the cost style of packets received or sent by the IS-IS router.
Use the undo cost-style command to restore the default cost style.
Only narrow packets can be received and sent by default.
Related commands: isis cost.
# Set the router to send only narrow packets, but receive both narrow and wide ones.
<H3C> system-view
System View: return to User View with Ctrl+Z..
[H3C] isis
[H3C-isis] cost-style narrow-compatible
4.1.3 default-route-advertise
default-route-advertise [ route-policy route-policy-name ]
undo default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
route-policy-name: Name of the specified route-policy, which is a string containing 1 to 19 characters.
Use the default-route-advertise command to enable the L1 and L2 routers to generate default routes.
Use the undo default-route-advertise command to disable the function.
By default, L2 routers generate default routes.
This command can be executed on L1 routers or L2 routers. Default routes are generated in L2 LSP by default. Carrying out the apply isis level-1 command in routing policy view will generate default routes in L1 LSP. Carrying out the apply isis level-2 command in routing policy view will generate default routes in L2 LSP. Carrying out the apply isis level-1-2 command in routing policy will generate default routes in L1 LSP and L2 LSP respectively.
# Configure the current router to generate default route in the corresponding LSP.
<H3C> system-view
[H3C-isis] default-route-advertise
4.1.4 display isis brief
display isis brief
View
None
Use the display isis brief command to display the brief information about IS-IS.
# Display the brief information about IS-IS.
<H3C> display isis brief
ISIS Protocol Brief Information:
System protocol supported by IS-IS: none
Is-level: level-1-2
Cost-style: narrow
Preference: 15
CLNS Preference: 15
Timers:
spf-delay-interval: 5000
spf-slice-size: 0
lsp-max-age: 1200
lsp-refresh: 900
interval between SPFs: level-1 10
level-2 10
4.1.5 display isis interface
display isis interface [ verbose ]
View
verbose: Displays the detailed information about the interface.
Use the display isis interface command to view the information about the IS-IS-enabled interfaces.
The information displayed by this command includes the interface name, interface IP address, interface link state, and so on. Besides all the information displayed by the display isis interface command, the display isis interface verbose command will display the IS-IS configuration information related to the interface, such as CSNP packet broadcast intervals, Hello packet broadcast intervals and the number of invalid Hello packets.
# Display the information about the IS-IS-enabled interface.
<H3C> display isis interface
Interface IP Address Id Link.Sta IP.Sta MTU Type DIS
Vlan-interface1 172.16.1.2 001 Up Up 1497 L1 No/No
# Display the detailed information about the IS-IS-enabled interface.
<H3C> display isis interface verbose
Secondary IP Address :
Csnp Interval : L1 10 L2 10
Hello Interval : L1 10 L2 10
Hold Time : L1 30 L2 30
Lsp Interval : 33
Cost : L1 10 L2 10
Priority : L1 64 L2 64
4.1.6 display isis lsdb
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ [ lsp-id | local ] | verbose ]* ]*
View
l1, level-1: Specifies level-1 routing connection state database.
l2, level-2: Specifies level-2 routing connection state database.
lsp-id: LSP ID of the network-entity-title.
local: Specifies to display LSP information generated locally.
verbose: Specifies to display the detailed information of link state database.
Use the display isis lsdb command to display IS-IS link state database.
# Display a piece of LSP information.
<H3C> display isis lsdb 0050.0500.5005.00-00
IS-IS Level-1 Link State Database
Lsp ID Sequence Holdtime A_P_O Checksum
>0050.0500.5005.00-00 0x00000328 780 0_0_0 0xf211
4.1.7 display isis mesh-group
View
None
Use the display isis mesh-group command to display the mesh-group of IS-IS.
You can use this command to view the mesh-group configuration of the current routing interface.
# Configure the IS-IS-enabled VLAN-interface 10 and VLAN-interface 20 of the router to belong to mesh group 100.
<H3C> system-view
[H3C-Vlan-interface10] isis mesh-group 100
[H3C-Vlan-interface10] interface Vlan-interface 20
[H3C-Vlan-interface20] isis mesh-group 100
# Display the configuration information of the IS-IS mesh group.
<H3C> system-view
[H3C-Vlan-interface20] display isis mesh-group
Interface Mesh-group/Blocked
Vlan-interface 10 100
Vlan-interface 20 100
4.1.8 display isis peer
display isis peer [ verbose ]
View
verbose: Displays the area address advertised in a neighbor’s Hello packet when this keyword is provided; displays only the brief information if this keyword is not specified.
Use the display isis peer command to display the information of the IS-IS neighbor.
# Display the detailed information about IS-IS neighbors.
<H3C> display isis peer verbose
System ID Interface Circuit ID State HoldTime Type Pri
0000.0000.7502 Vlan-interface1000 0000.0000.7502.02 Up 8s L1 64
Area Address: 01 IP Address: 7.7.7.7 Period: 01:51:13
0000.0000.7502 Vlan-interface1001 0001.0000.7506.02 Up 24s L1 64
Area Address: 01 IP Address: 6.6.6.6 Period: 00:53:50
# Display the information about IS-IS neighbors.
0000.0000.7502 Vlan-interface1000 0000.0000.7502.02 Up 9s L1 64
4.1.9 display isis route
display isis route { clns | ip }
View
ip: Displays IP-based IS-IS routing information.
clns: Displays OSI-based IS-IS routing information.
Use the display isis route command to display the IS-IS routing information.
# Display the output information of the display isis ip route command.
<H3C> display isis route ip
ISIS IP Level - 2 Routing Table :
Type - D -Direct, C -Connected, I -ISIS, S -Static, O -OSPF
B -BGP, R -RIP
Flags: R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
Destination/Mask In.Met Ex.Met NextHop Interface Flags
D 111.1.0.0/16 10 Direct Vlan-interface111 R/L/-
D 170.1.1.0/24 10 Direct Vlan-interface170 R/L/-
I 131.1.0.0/16 20 111.1.1.1 Vlan-interface111 R/-/-
I 133.1.0.0/16 20 111.1.1.1 Vlan-interface111 R/-/-
I 135.1.0.0/16 20 111.1.1.1 Vlan-interface111 R/-/-
D 145.1.0.0/16 10 Direct Vlan-interface145 R/L/-
4.1.10 display isis spf-log
View
None
Use the display isis spf-log command to display the log record of IS-IS SPF calculation.
# Display the log record of IS-IS SPF calculation.
<H3C> display isis spf-log
Details of Level 2 SPF Run:
Trig.Event No.Of Nodes Duration(ms) StartTime
IS_SPFTRIG_NEWADJ 2 74 0:10:55
IS_SPFTRIG_NEWADJ 2 670 0:10:24
IS_SPFTRIG_NEWADJ 2 23 0:10:2
IS_SPFTRIG_NEWADJ 2 30 0:9:32
IS_SPFTRIG_NEWADJ 2 34 0:9:1
IS_SPFTRIG_NEWADJ 2 111 0:7:59
IS_SPFTRIG_NEWADJ 2 302 0:25:1
IS_SPFTRIG_NEWADJ 2 60 0:24:30
IS_SPFTRIG_NEWADJ 2 232 0:20:31
IS_SPFTRIG_NEWADJ 2 42 0:19:58
IS_SPFTRIG_NEWADJ 2 37 0:19:32
IS_SPFTRIG_NEWADJ 2 34 0:19:0
IS_SPFTRIG_CIRC_UP 2 633 0:18:51
IS_SPFTRIG_NEWADJ 2 78 0:17:59
IS_SPFTRIG_ADJDOWN 0 -59863 0:15:7
IS_SPFTRIG_NEWADJ 2 30 0:15:3
IS_SPFTRIG_NEWADJ 2 32 0:14:2
IS_SPFTRIG_NEWADJ 2 202 0:13:34
IS_SPFTRIG_CIRC_DOWN 2 215 0:12:17
IS_SPFTRIG_CIRC_UP 2 27 0:12:7
4.1.11 domain-authentication-mode
domain-authentication-mode { simple | md5 } password [ ip | osi ]
undo domain-authentication-mode { simple | md5 } [ ip | osi ]
View
IS-IS view
password: Specifies the password to be set. For the simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or ciphertext, and the result depends on the input. A plain password can be a string less than 16 digits, such as abc918. A cipher password must be a ciphertext of 24 digits, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Whether a password should use the ip keyword or the osi keyword is not affected by the actual network environment.
Use the domain-authentication-mode command to configure IS-IS routing domain to authenticate the received level-2 packets (LSP, CSNP and PSNP) using the predefined mode and password.
Use the undo domain-authentication-mode command to disable IS-IS from authenticating the received packets mentioned above.
The system will neither authenticate the received level-2 routing packet nor check its password by default.
You can use this command to clear all level-2 routing packets not matching the domain-authentication password set by the command. At the same time, we also instruct the system to follow a specific mode to insert the area-authentication password in all the level-2 routing packets sent from the local node.
Related commands: area-authentication-mode, isis authentication-mode.
# Use the simple mode and set the password to abc to authenticate level-2 routing packets.
<H3C> system-view
[H3C] isis
[H3C-isis] domain-authentication-mode simple abc
4.1.12 filter-policy export
filter-policy acl-number export [ protocol ]
undo filter-policy acl-number export [ protocol ]
View
IS-IS view
acl-number: ACL number in the range of 2,000 to 3,999.
protocol: Protocol used to advertise routing information, including direct, static, rip, bgp, ospf, ospf-ase, and ospf-nssa currently.
Use the filter-policy export command to enable IS-IS to filter the routes advertised by other routing protocols.
Use the undo filter-policy export command to disable the configured filter rules.
IS-IS does not filter the routes advertised by other routing protocols by default.
& Note:
l The filter-policy export command takes effect only on the routes imported through the import-route command. If the filter-policy export command is configured while the import-route command is not configured to import other non-IS-IS routes, the filter-policy export command does not take effect.
l If the protocol argument is not provided in the filter-policy export command, the command takes effect on all the routes imported to the local device using the import-route command.
Related commands: filter-policy import.
# Use ACL 2000 to filter the routes imported through IS-IS.
<H3C> system-view
[H3C] isis
[H3C-isis] filter-policy 2000 export
4.1.13 filter-policy import
filter-policy acl-number import
undo filter-policy acl-number import
View
IS-IS view
Use the filter-policy import command to enable IS-IS to filter the received routes.
Use the undo filter-policy import command to disable IS-IS from filtering the received routes.
IS-IS does not filter the received routes by default.
In some circumstances, only the routing information satisfying certain conditions will be received. You can configure the filtering condition by setting the filter-policy parameters.
Related commands: filter-policy export.
# Use ACL 2000 to filter the received routes.
<H3C> system-view
[H3C] isis
[H3C-isis] filter-policy 2000 import
4.1.14 ignore-lsp-checksum-error
undo ignore-lsp-checksum-error
View
IS-IS view
None
Use the ignore-lsp-checksum-error command to set IS-IS to drop the LSP when it detects LSP checksum errors.
Use the undo ignore-lsp-checksum-error command to set IS-IS to ignore LSP checksum errors.
IS-IS ignores LSP checksum errors by default.
When the local IS-IS receives a LSP packet, it will check the LSP packet and compare the checksum calculated with that in the LSP packet. By default, the LSP packets will not be dropped even if the checksum is wrong. You can use the ignore-lsp-checksum-error command to configure IS-IS to drop the LSP packet in case of checksum error.
# Configure IS-IS to drop the LSP packet in case of checksum error.
<H3C> system-view
[H3C] isis
[H3C-isis] ignore-lsp-checksum-error
4.1.15 import-route
import-route protocol [ allow-ibgp ] [ cost value | type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name ]*
undo import-route protocol [ cost value | type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name ]*
View
IS-IS view
protocol: Source routing protocol that can be imported, including direct, static, rip, bgp, ospf, ospf-ase, and ospf-nssa.
allow-ibgp: Allows the redistribution of IBGP routes when redistributing routes from BGP.
value: Cost of the imported route, in the range of 0 to 63.
type: Specifies the type of the routing cost. If it is internal, then it is a route within an area; if it is external, it is a route between areas. The type is internal by default.
level-1: Specifies to import routes to Level-1 routing table.
level-2: Specifies to import routes to Level-2 routing table. If no level is specified, the routes are imported to level-2 routing table by default.
level-1-2: Specifies to import routes to Level-1 and level-2 routing tables.
route-policy route-policy-name: Specifies to import only those routes satisfying the matching condition of the designated route-policy. The route-policy-name argument is a string containing 1 to 19 characters.
Use the import-route command to enable IS-IS to filter the imported routes.
Use the undo import-route command to disable IS-IS from importing other protocols' routing information.
IS-IS does not import other protocols’ routing information by default.
IS-IS takes all the routes imported to the routing domain as external routes, which describe how to select a route to a destination outside of the routing domain.
Note that:
l The import-route bgp command redistributes EBGP routes only.
l The import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes.
l Use the import-route bgp allow-ibgp command with care, because it redistributes IBGP routes without keeping the AS_PATH attribute, which may lead to routing loops between ASs.
& Note:
Use the import-route bgp allow-ibgp command with care!
Related commands: import-route isis level-2 into level-1.
# Import a static route with the cost of 15.
<H3C> system-view
[H3C] isis
[H3C-isis] import-route static cost 15
4.1.16 import-route isis level-2 into level-1
import-route isis level-2 into level-1 [ acl acl-number ]
undo import-route isis level-2 into level-1
View
IS-IS view
acl-number: ACL number in the range of 2,000 to 3,999. It can be either basic ACLs or advanced ACLs.
Use the import-route isis level-2 into level-1 command to import the routing information of Level-2 area to Level-1 area.
Use the undo import-route isis level-2 into level-1 command to disable this function.
By using the filter policy to filter the routes during the route penetration from Level-2 to Level-1, you can advertise those routes that have passed the filter to Level-1 area.
The routing information in Level-2 area will not be advertised in Level-1 area by default.
Related commands: import-route.
# Set the router to penetrate routes from Level-2 to Level-1 through ACL.
<H3C> system-view
[H3C] isis
[H3C-isis] import-route isis level-2 into level-1 acl 2100
4.1.17 isis
isis [ tag ]
undo isis [ tag ]
View
tag: Name of an IS-IS routing process, consisting of no more than 128 characters. Its length can be 0, that is, the tag argument can be null.
Use the isis command to start a corresponding IS-IS routing process and enter the IS-IS view.
Use the undo isis command to delete the specified IS-IS routing process.
IS-IS routing processes are disabled by default.
Before running IS-IS protocol normally, you must first use the isis command to enable an IS-IS process, then use the network-entity command to configure a network entity title (NET) for the router, and then use the isis enable command to enable each interface that needs to run the IS-IS process.
& Note:
Only one IS-IS routing process can be enabled on a router.
Related commands: isis enable, network-entity.
# Start the IS-IS routing process, with the system ID 0000.0000.0002, and area ID 01.0001.
<H3C> system-view
[H3C] isis
[H3C-isis] network-entity 01.0001.0000.0000.0002.00
4.1.18 isis authentication-mode
isis authentication-mode { simple | md5 } password [ { level-1 | level-2 } [ ip | osi ] ]
undo isis authentication-mode { simple | md5 } password [ { level-1 | level-2 } [ ip | osi ] ]
View
Interface view
md5: Specifies to send the password in ciphertext.
password: Specifies a password. For simple authentication mode, the password must be plain text. For md5 authentication mode, the password can be either plain text or ciphertext, and the result depends on the input. A plain password can be a string less than 16 digits, such as abc918. A cipher password must be a ciphertext of 24 digits, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
level-1: Specifies to set a password for L1.
level-2: Specifies to set a password for L2.
Use the isis authentication-mode command to authenticate the IS-IS hello packets of the specified level using the specified authentication mode and password on the IS-IS interface.
Use the undo isis authentication-mode command to disable the authentication and remove the password.
There is no password or authentication by default.
If there is no other parameter but the password, then only level-1 and osi are available.
Related commands: area-authentication-mode, domain authentication-mode.
# Set the plain password as tangshi for Level-1 adjacency on VLAN-interface 10.
<H3C> system-view
[H3C-Vlan-interface10] isis authentication-mode simple tangshi level-1
4.1.19 isis circuit-level
isis circuit-level [ level-1 | level-1-2 | level-2 ]
undo isis circuit-level
View
Interface view
level-1: Specifies to set up only level-1 adjacency for the interface.
level-1-2: Specifies to set up level-1-2 adjacency for the interface.
level-2: Specifies to set up only level-2 adjacency for the interface.
Use the isis circuit-level command to set link adjacency for the level-1-2 router.
Use the undo isis circuit-level command to resume the default configuration of link adjacency for the level-1-2 router.
Level-1-2 adjacency can be configured for an interface by default.
This command is only available for a level-1-2 router. If the local host is a level-1-2 router and it needs to set up some adjacency (level-1 or level-2) with a peer router, then you can use this command to prescribe the local interface to receive and send only the hello packets. An interface can receive and send only one type of hello packets on a point-to-point link. You can use this command to reduce the router’s processing time to save bandwidth.
Related commands: is-level.
# Set the level-1 attributes for VLAN-interface 10 to prohibit sending and receiving level-2 Hello packets when the interface is connected to a non-backbone router within the same area.
<H3C> system-view
[H3C-Vlan-interface10] isis enable
[H3C-Vlan-interface10] isis circuit-level level-1
4.1.20 isis cost
isis cost value [ level-1 | level-2 ]
undo isis cost [ level-1 | level-2 ]
View
Interface view
value: Specifies the link cost value for corresponding SPF calculation, in the range of 0 to 63. It is 10 by default.
level-1: Indicates the link cost corresponding to Level-1 layer.
level-2: Indicates the link cost corresponding to Level-2 layer.
Use the isis cost command to set the interface link cost for SPF calculation.
Use the undo isis cost command to resume the default link cost value.
If neither level-1 nor level-2 is assigned in the configuration, both level-1 and level-2 are configured by default.
You are recommended to configure a proper link cost for each interface; otherwise, the link cost for IS-IS route calculation may not reflect the correct cost.
# Set the Level-2 link cost to 5 for VLAN-interface10.
<H3C> system-view
[H3C-Vlan-interface10] isis cost 5 level-2
4.1.21 isis dis-priority
isis dis-priority value [ level-1 | level-2 ]
undo isis dis-priority [ level-1 | level-2 ]
View
Interface view
value: Specifies the priority for selecting DIS, ranging from 0 to 127, with the default as 64.
level-1: Specifies the priority for selecting level-1 DIS.
level-2: Specifies the priority for selecting level-2 DIS.
If neither level-1 nor level-2 is specified in this command, both level-1 and level-2 priorities are configured by default.
Use the isis dis-priority command to specify the priority for selecting corresponding DIS.
Use the undo isis dis-priority command to resume the default priority.
Unlike DR of OSPF, there is no backup DIS for IS-IS and the router with priority 0 can also be selected as DIS.
# Configure the priority as 127 for VLAN-interface 10.
<H3C> system-view
[H3C-Vlan-interface10] isis dis-priority 127 level-2
4.1.22 isis enable
isis enable [ tag ]
undo isis enable [ tag ]
View
Interface view
tag: Name assigned to the IS-IS routing process when the isis command is executed in system view. If this argument is not specified, it is null.
Use the isis enable command to enable the corresponding IS-IS routing process for the interface.
Use the undo isis enable command to disable this configuration.
The interface does not enable the IS-IS routing process by default.
Before running IS-IS protocol normally, you must use the isis command to enable IS-IS process, and use the network-entity command to configure a network entity title (NET) for the router, and then use the isis enable command to enable each interface that need to run the IS-IS process.
Related commands: isis, network-entity.
# Enable the IS-IS routing process on VLAN-interface 10.
<H3C> system-view
[H3C] isis abc
[H3C-isis] network-entity 10.0001.1010.1020.1030.00
[H3C-Vlan-interface10] isis enable abc
4.1.23 isis mesh-group
isis mesh-group { mesh-group-number | mesh-blocked }
undo isis mesh-group
View
Interface view
mesh-group-number: Mesh group number, ranging from 1 to 4,294,967,295.
mesh-blocked: After this parameter is configured, the interface will be blocked and does not flood the received LSP to other interfaces.
Use the isis mesh-group command to add an interface to a specified mesh group.
Use the undo isis mesh-group command to delete an interface from a mesh group.
An interface is not in any mesh group and can flood LSP normally by default.
For an interface not in a mesh group, it follows the normal process to flood the received LSP to other interfaces. For the NBMA network with high connectivity and multiple point-to-point links, this will cause repeated LSP flooding and bandwidth waste.
After an interface is added to a mesh group, it will only flood a received LSP to interfaces that do not belong to the same mesh group.
When you add an interface to a mesh group or block the interface, make sure to retain some redundancy so that a link failure will not affect the normal LSP packet flooding.
# Add the IS-IS-enabled VLAN-interface 20 to mesh-group 3.
<H3C> system-view
[H3C-Vlan-interface20] isis mesh-group 3
4.1.24 isis timer csnp
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ level-1 | level-2 ]
View
Interface view
seconds: Interval of sending CSNP packets over broadcast network in seconds, ranging from 1 to 65,535, with the default as 10 seconds.
level-1: Specifies the Level-1 time interval for sending CSNP packets.
level-2: Specifies the Level-2 time interval for sending CSNP packets.
If neither the level-1 keyword nor the level-2 keyword is specified, both the level-1 interval and the level-2 interval are set.
Use the isis timer csnp command to specify the time interval for sending CSNP packets over a broadcast network.
Use the undo isis timer csnp command to resume the default value of 10 seconds.
This command only applies to the DIS router, which sends CSNP packets periodically. Besides, DIS is separated to Level-1 and Level-2, and their time intervals should be configured respectively.
# Configure Level-2 CSNP packets to be sent every 15 seconds over VLAN-interface 10.
<H3C> system-view
[H3C-Vlan-interface10] isis timer csnp 15 level-2
4.1.25 isis timer hello
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ level-1 | level-2 ]
View
Interface view
seconds: Interval for sending Hello packets, ranging from 3 to 255, in seconds, with the default as 10 seconds.
level-1: Specifies the time interval for sending Level-1 Hello packets.
level-2: Specifies the time interval for sending Level-2 Hello packets.
Use the isis timer hello command to specify the time interval for sending the corresponding Hello packets.
Use the undo isis timer hello command to resume the default value of 10 seconds.
The hello time interval must be configured respectively for the Level-1 and Level-2 packets on a broadcast network, because these two types of hello packets are sent separately. A point-to-point link does not require this. The shorter the time interval is, the more system resources will be occupied to send Hello packets, so you should configure a proper time interval depending on the specific requirements.
Related commands: isis timer holding-multiplier.
# Configure Level-2 Hello packets to be sent every 20 seconds over VLAN-interface 10.
<H3C> system-view
[H3C-Vlan-interface10] isis timer hello 20 level-2
4.1.26 isis timer holding-multiplier
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ level-1 | level-2 ]
View
Interface view
value: Number of invalid Hello packets of an IS-IS neighbor, in the range of 3 to 1,000.
level-1: Specifies the number of invalid Hello packets of a Level-1 IS-IS neighbor.
level-2: Specifies the number of invalid Hello packets of a Level-2 IS-IS neighbor.
If neither the level-1 keyword nor the level-2 keyword is specified, the command takes effect on both level-1 and level-2 IS-IS neighbors.
Use the isis timer holding-multiplier command to configure the number of invalid Hello packets for an IS-IS neighbor. When a specified number of Hello packets are not received from a neighbor, the neighbor will be considered as invalid.
Use the undo isis timer holding-multiplier command to resume the default configuration.
The number of invalid Hello packets is three by default.
You can configure the time intervals of Hello packets separately for Level-1 and Level-2 peers. But for a point-to-point link, since there is only one kind of Hello packet, you need not to specify Level-1 or Level-2.
In fact, the number of invalid Hello packets is used to configure Holddown time. If a router receives no Hello packet from the peer router within Holddown time, it will take the peer router as invalid. Depending on the interface configuration, the Holddown time can be configured differently for different routers within an area. You can adjust the Holddown time by changing either the time interval for sending Hello packets or the number of invalid Hello packets.
Related commands: isis timer hello.
# Configure the number of Level-2 Hello packets signifying a peer invalid as 5 for VLAN-interface 10, that is, if no Hello packet is received from the interface within 5 Hello packet time intervals, the IS-IS peer is considered as invalid.
<H3C> system-view
[H3C-Vlan-interface10] isis timer holding-multiplier 5
4.1.27 isis timer lsp
isis timer lsp time
undo isis timer lsp
View
Interface view
time: Interval for sending link-state packets, in milliseconds, ranging from 1 to 1000, with the default as 33 milliseconds.
Use the isis timer lsp command to configure the time interval for sending link-state packets over an interface.
Use the undo isis timer lsp command to resume the default configuration.
Related commands: isis timer retransmit.
# Configure the time interval as 500 milliseconds for VLAN-interface 10 to send LSP packets.
<H3C> system-view
[H3C-Vlan-interface10] isis timer lsp 500
4.1.28 isis timer retransmit
isis timer retransmit seconds
undo isis timer retransmit
View
Interface view
seconds: Interval for retransmitting LSP packets, in seconds, ranging from 1 to 300, with the default as 5 seconds.
Use the isis timer retransmit command to configure the time interval for retransmitting LSP packets over a point-to-point link.
Use the undo isis timer retransmit command to resume the default configuration.
You should be careful when configuring this parameter to avoid unnecessary retransmission.
You need not use this command over a broadcast link, because an LSP packet requires response from the peer only over a point-to-point link, but not over a broadcast link.
Related commands: isis timer lsp.
# Configure the time interval as 10 seconds for VLAN-interface 10 to retransmit LSP.
<H3C> system-view
[H3C-Vlan-interface10] isis timer retransmit 10
4.1.29 is-level
is-level { level-1 | level-1-2 | level-2 }
undo is-level
View
IS-IS view
level-1: Indicates the router works in Level-1, which means it only calculates routes within the area, and maintains L1 LSDB.
level-1-2: Indicates the router works in Level-1-2, which means it calculates routes and maintains LSDB for both L1 and L2.
level-2: Indicates the router works in Level-2, which means it calculates LSP switching and routes and maintains LSDB for L2 only.
Use the is-level command to configure IS-IS router type.
Use the undo is-level command to resume the default configuration.
The configuration is level-1-2 by default.
It is recommended to configure system level when you configure IS-IS.
Related commands: isis circuit-level.
# Configure the current router to work in Level-1.
<H3C> system-view
[H3C] isis
[H3C-isis] is-level level-1
4.1.30 log-peer-change
log-peer-change
undo log-peer-change
View
IS-IS view
None
Use the log-peer-change command to enable the IS-IS adjacency state change output.
Use the undo log-peer-change command to disable the output.
The output is disabled by default.
When the adjacency state output is enabled, the IS-IS adjacency state change will be sent to the configuration terminal.
# Enable the IS-IS adjacency state change output on the current router.
<H3C> system-view
[H3C] isis
[H3C-isis] log-peer-change
4.1.31 md5-compatible
md5-compatible
undo md5-compatible
View
IS-IS view
None
Use the md5-compatible command to specify IS-IS to adopt the MD5 algorithm compatible with other manufacturers.
Use the undo md5-compatible command to specify IS-IS to adopt the default MD5 algorithm.
By default, IS-IS adopts the MD5 algorithm compatible with Huawei.
This command must be configured when the switch needs to perform IS-IS MD5 authentication with the devices of manufacturers except Huawei.
# Specify IS-IS to adopt the MD5 algorithm compatible with other manufacturers.
<H3C> system-view
[H3C] isis
[H3C-isis] md5-compatible
4.1.32 network-entity
network-entity network-entity-title
undo network-entity network-entity-title
View
IS-IS view
Use the network-entity command to configure the network entity title (NET) for an IS-IS routing process.
Use the undo network-entity command to delete a NET.
There is no NET by default.
A NET is a network service access point (NSAP), and it is in the range of 8 to 20 digits for IS-IS.
A NET has three parts: The first part is an area ID, which ranges from 1 to 13 digits. The routes of the same area have the same area ID. The second part is the router’s system ID of 6 digits, which is unique within the whole area and backbone area. The third part is SEL, the ending digit with the value of 00. You need to configure only 1 NET for a router. When repartitioning an area, such as merging or splitting, you can reconfigure the router to ensure correct and continuous routing.
Related commands: isis, isis enable.
# Specify the NET as 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
<H3C> system-view
[H3C] isis
4.1.33 preference
preference value [ clns | ip ]
undo preference [ clns | ip ]
View
IS-IS view
value: Preference value in the range of 1 to 255. It is 15 by default.
clns: IS-IS routing preference based on OSI protocol stack, in the range of 1 to 255. It is IP-based preference by default.
ip: IS-IS routing preference based on IP protocol stack, in the range of 1 to 255.
Use the preference command to configure IS-IS protocol preference.
Use the undo preference command to resume the default IS-IS protocol preference.
When a router runs multiple dynamic routing protocols at the same time, the system will configure a preference for each routing protocol. If several protocols find routes to the same destination, the one with the highest preference dominates.
# Configure the preference of IS-IS protocol as 25.
<H3C> system-view
[H3C] isis
[H3C-isis] preference 25
4.1.34 reset isis all
reset isis all
View
None
Use the reset isis all command to clear all ISIS data structure information.
The IS-IS data information will not be cleared by default.
# Clear all IS-IS data structure.
<H3C> reset isis all
4.1.35 reset isis peer
reset isis peer system-id
View
system-id: System ID for an IS-IS peer, in the range of one bit to 128 bits.
Use the reset isis peer command to clear the data information of a specific IS-IS peer.
The IS-IS peer is not cleared by default.
This command is used when you need to re-establish a specific peer.
# Clear the IS-IS peer with the system ID as 0000.0c11.1111.
<H3C> reset isis peer 0000.0c11.1111
4.1.36 set-overload
set-overload
undo set-overload
View
IS-IS view
None
Use the set-overload command to set an overload flag for the current router.
Use the undo set-overload command to clear an overload flag.
No overload flag is set by default.
When the overload flag is set for a router, other routers will not transmit the packets that should be forwarded by the router.
# Set an overload flag on the current router.
<H3C> system-view
[H3C] isis
[H3C-isis] set-overload
4.1.37 silent-interface
View
IS-IS view
interface-type interface-number: Interface index.
Use the silent-interface command to prohibit IS-IS packet sending on the specified interface.
Use the undo silent-interface command to permit IS-IS packet sending on the specified interface.
By default, IS-IS packet sending is permitted on all interfaces.
The silent-interface command just suppresses IS-IS packet sending on this interface. However, these IS-IS packets can still be sent on other interfaces.
# Prohibit IS-IS packet sending on VLAN-interface 3.
<H3C>system-view
[H3C] isis
[H3C-isis] silent-interface Vlan-interface 3
4.1.38 spf-delay-interval
spf-delay-interval number
undo spf-delay-interval
View
IS-IS view
number: Interval of releasing CPU during route calculation, in the range of 1,000 routes to 50,000 routes. It is 5,000 routes by default.
Use the spf-delay-interval command to set the interval of releasing CPU during SPF calculation.
Use the undo spf-delay-interval command to restore the default value.
When there are too many routes in the routing table, you can use this command to release CPU automatically after a certain number of routes are processed in order to prevent the SPF calculation from occupying the system resources for a long time, thus affecting the response of the console. The unprocessed routes are to be processed in one second.
You can adjust the number argument according to the size of the routing table. If the spf-slice-size command is configured at the same time, the SPF calculation will be paused if the SPF calculation matches any of the setting.
By default, CPU is released when every 5,000 routes are processed.
Related commands: spf-slice-size.
# Set IS-IS to release CPU when every 3,000 routes are processed.
<H3C> system-view
[H3C] isis
[H3C-isis] spf-delay-interval 3000
4.1.39 spf-slice-size
spf-slice-size seconds
undo spf-slice-size
View
IS-IS view
seconds: Duration time during SPF calculation, in milliseconds, ranging from 0 to 120. A calculation is ended when the duration time is reached or exceeded. If the second argument is set to 0, the SPF calculation will continue until it finishes. It is 0 by default.
Use the spf-slice-size command to configure whether the SPF routing calculation is fragmented and configure the duration time for each fragment.
Use the undo spf-slice-size command to resume the default configuration.
When there are too many routes in the routing table, you can use this command to fragment the SPF calculation to avoid taking up the system resources for a long time. You are not recommended to change the default configuration.
If the spf-delay-interval command is configured at the same time, the SPF calculation will be paused if the SPF calculation matches any of the setting.
Related commands: spf-delay-interval.
# Set SPF duration time to one second.
<H3C> system-view
[H3C] isis
[H3C-isis] spf-slice-size 1
4.1.40 summary
summary ip-address mask [ level-1 | level-1-2 | level-2 ]
undo summary ip-address mask [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
ip-address: Address range to generate summarized routes.
mask: Mask of an aggregate route.
level-1: Specifies to summarize only the routes imported to level-1 area.
level-1-2: Specifies to summarize all the routes imported to level-1 area and backbone area.
level-2: Specifies to summarize only the routes imported to backbone area.
If none of the level-1 keyword, level-2 keyword, and level-1-2 keyword is specified, the routes imported to backbone area are summarized.
Use the summary command to configure IS-IS to generate summarized routes.
Use the undo summary command to disable summary.
No route is summarized by default.
You can summarize the routes having the same next hop into one route to reduce the routing table size, as well as the LSP and LSDB generated by the router. It is possible to summarize native IS-IS routes and imported routes. After summarization, the route cost is the minimum cost of those summarized routes.
# Set a summarized route 202.0.0.0/8.
<H3C> system-view
[H3C] isis
[H3C-isis] summary 202.0.0.0 255.0.0.0
4.1.41 timer lsp-max-age
timer lsp-max-age seconds
undo timer lsp-max-age
View
IS-IS view
seconds: Maximum valid time of a LSP, in the range of 1 to 65,535 in seconds. It is 1,200 seconds by default.
Use the timer lsp-max-age command to set the maximum valid time of the LSPs generated on the current router.
Use the undo timer lsp-max-age command to restore the default setting.
When the router generates system LSPs, the LSPs are generated with the maximum valid time in them. When an LSP is received by other routers, the maximum valid time will be smaller and smaller. If the maximum valid time decreases to 0, this LSP will be removed from LSDB.
Related commands: timer lsp-refresh.
# Set the maximum valid time of the LSPs generated by the current system to 25 minutes, namely, 1,500 seconds.
<H3C> system-view
[H3C] isis
[H3C-isis] timer lsp-max-age 1500
4.1.42 timer lsp-refresh
timer lsp-refresh seconds
undo timer lsp-refresh
View
IS-IS view
seconds: LSP updating period, in seconds, ranging from 1 to 65,535. It is 900 seconds by default.
Use the timer lsp-refresh command to set an LSP updating period.
Use the undo timer lsp-refresh command to resume the default configuration.
You can keep LSP in synchronization for the whole area with this mechanism.
Related commands: timer lsp-max-age.
# Set the updating period to 1,500 seconds for the current system LSP.
<H3C> system-view
[H3C] isis
[H3C-isis] timer lsp-refresh 1500
4.1.43 timer spf
timer spf seconds [ level-1 | level-2 ]
undo timer spf [ level-1 | level-2 ]
View
IS-IS view
seconds: Maximum time interval (in seconds) for SPF calculation, ranging from 1 to 120, with the default as 10.
level-1: Specifies to set the time interval for only Level-1 SPF calculation.
level-2: Specifies to set the time interval for only Level-2 SPF calculation.
If neither the level-1 keyword nor the level-2 keyword is specified, the interval of both level-1 SPF calculation and the level-2 SPF calculation are set.
Use the timer spf command to set the time interval for SPF calculation.
Use the undo timer spf command to resume the default configuration.
In the IS-IS protocol, the short path must be calculated again when the LSDB changes. If the SPF calculation is performed frequently, plenty of system resources will be occupied and the router efficiency will be affected. Comparatively, performing SPF calculation periodically can improve the efficiency. You can set the time interval of performing SPF calculation as required.
# Set the time interval of performing SPF calculation to three seconds.
<H3C> system-view
[H3C] isis
[H3C-isis] timer spf 3
Chapter 5 BGP Configuration Commands
& Note:
5.1 BGP Configuration Commands
& Note:
For the commands defining routing policies in BGP, refer to the next chapter “IP Routing Policy Configuration Commands".
5.1.1 aggregate
aggregate ip-address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
undo aggregate ip-address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
View
BGP view
ip-address: Address of the aggregated route, in dotted decimal notation.
mask: Network mask of the aggregated route, in dotted decimal notation.
as-set: Creates a route with segment of AS_SET.
detail-suppressed: Only advertises the aggregated route.
suppress-policy route-policy-name: Suppresses the specific route selected.
origin-policy route-policy-name: Selects the original routes used for aggregation.
attribute-policy route-policy-name: Sets the attributes of the aggregated route.
Use the aggregate command to establish an aggregated record in the BGP routing table.
Use the undo aggregate command to disable the function.
By default, there is no route aggregation.
The keywords are explained as follows:
Table 5-1 Description on the keywords of the aggregate command
Keywords |
as-set |
Used to produce an aggregated route whose AS path information includes detailed routes. Use this keyword with caution when many AS paths need to be aggregated because frequent changes of routes may lead to route flaps. |
detail-suppressed |
This keyword does not establish any aggregated route, but it restrains the advertisement of all the specific routes. If only some specific routes are to be restrained, use the peer filter-policy command. |
suppress-policy |
Create an aggregated route with this keyword; at the same time, the advertisement of the specified route is restrained. If you want to restrain some specific routes selectively and leaves other routes still being advertised, use the if-match clause of the route-policy command. |
origin-policy |
This keyword is used to select only the specific routes in accordance with the route-policy to create an aggregated route. |
attribute-policy |
This keyword is used to set attributes of the aggregated route. The same work can be done by using peer route-policy, and so on. |
# Create an aggregated route in BGP routing table.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] aggregate 192.213.0.0 255.255.0.0
5.1.2 bgp
bgp as-number
undo bgp [ as-number ]
View
as-number: Specified local AS number, in the range of 1 to 65535.
Use the bgp command to enable BGP and enter BGP view.
Use the undo bgp command to disable BGP.
By default, BGP is disabled.
This command is used to enable/disable BGP and specify the local AS number of BGP.
# Enable BGP.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp]
5.1.3 balance
balance num
undo balance
View
BGP view
num: Number of BGP routes used for load balance. This argument ranges from 1 to 4. A value of 1 means the system does not adopt load balance.
Use the balance command to configure BGP load balance.
Use the undo balance command to cancel the load balance configuration.
By default, the system does not adopt BGP load balance.
# Configure BGP load balance.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] balance 2
5.1.4 compare-different-as-med
undo compare-different-as-med
View
BGP view
None
Use the compare-different-as-med command to enable comparison of MED values from different AS neighboring routes when determining the best route.
Use the undo compare-different-as-med command to disable the comparison.
By default, it is not allowed to compare the MED attribute values from the routing paths of different AS peers.
If there are several routes available to one destination address, the route with a smaller MED can be selected as the final route.
Do not use this command unless it is determined that the same IGP and routing selection mode are adopted by different autonomous systems.
# Enable comparison of MED values from different AS neighboring routes.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] compare-different-as-med
5.1.5 confederation id
confederation id as-number
undo confederation id
View
BGP view
as-number: The ID of BGP AS confederation. It is equal to the AS number which contains the AS numbers of multiple sub-ASs. The range is 1 to 65535.
Use the confederation id command to configure confederation identifier.
Use the undo confederation id command to cancel the BGP confederation specified by the as-number argument.
By default, no confederation ID is configured.
Confederation can be adopted to solve the problem of too many IBGP fully-meshed connections in a large AS domain. The solution is by first dividing the AS domain into several smaller sub-ASs, and each sub-ASs remains fully-meshed. These sub-ASs form a confederation. Key BGP attributes of the route, such as next hop, MED, and local preference, are not discarded across each sub-ASs. The sub-ASs still look integral from the point of view of a confederation although these sub-ASs have EBGP relations. This can assure the integrality of the former AS domain, and ease the problem of too many connections in the domain
Related commands: confederation nonstandard, confederation peer-as.
# Confederation 9 consists of four sub-ASs, namely, 38, 39, 40, and 41. Here, the peer 10.1.1.1 is an internal member of the AS confederation while the peer 200.1.1.1 is an external member of the AS confederation. For external members, Confederation 9 is a unified AS domain.
<H3C> system-view
[H3C] bgp 41
[H3C-bgp] confederation id 9
[H3C-bgp] confederation peer-as 38 39 40
[H3C-bgp] group Confed38 external
[H3C-bgp] peer Confed38 as-number 38
[H3C-bgp] peer 10.1.1.1 group Confed 38
[H3C-bgp] group Remote98 external
[H3C-bgp] peer Remote98 as-number 98
[H3C-bgp] peer 200.1.1.1 group Remote98
5.1.6 confederation nonstandard
confederation { nonstandard | standard1965 | standard3065 }
undo confederation { nonstandard | standard1965 | standard3065 }
View
BGP view
nonstandard: Configures nonstandard confederation.
standard1965: Configures the confederation to be compliant with RFC 1965.
standard3065: Configures the confederation to be compliant with RFC 3065.
Use the confederation { nonstandard | standard1965 | standard3065 } command to configure the standard type of confederation.
Use the undo confederation { nonstandard | standard1965 | standard3065 } command to cancel the configuration.
By default, the configured confederations are in compliance with RFC1965.
For the communication with nonstandard devices, you must execute the confederation nonstandard command on all the H3C routers in the confederation.
Related commands: confederation id confederation peer-as.
# AS100 contains routers following nonstandard, which is composed of two sub-ASs, 64000 and 65000.
<H3C> system-view
[H3C] bgp 64000
[H3C-bgp] confederation id 100
[H3C-bgp] confederation peer-as 65000
[H3C-bgp] confederation nonstandard
5.1.7 confederation peer-as
undo confederation peer-as [ as-number-list ]
View
BGP view
as-number-list: List of sub-AS numbers. Up to 32 sub-ASs can be configured for a confederation in the command.
Use the confederation peer-as command to configure a confederation to consist of which Sub-ASs.
Use the undo confederation peer-as command to delete the specified Sub-AS in the confederation.
By default, no autonomous system is configured as a member of the confederation.
The configured ASs in this command are inside the confederation and each AS uses fully meshed network. Before this command is executed, the confederation ID should be configured by using the confederation id command. Otherwise this configuration is invalid.
Related commands: confederation nonstandard, confederation id.
# Configure the confederation to contain AS 2000 and 2001.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] confederation peer-as 2000 2001
5.1.8 dampening
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling ] [ route-policy route-policy-name ]
undo dampening
View
BGP view
half-life-reachable: Semi-dampening of a reachable route, in minutes, in the range of 1 to 45. The default value is 15.
half-life-unreachable: Semi-dampening of an unreachable, in minutes, in the range of 1 to 45. The default value is 15.
reuse: Threshold for disabling route suppression, in seconds. When the penalty value is below this threshold, the route will be reused. The range is 1 to 20,000. The default value is 750.
suppress: Threshold for enabling route suppression, in seconds. When the penalty value is above the threshold, the route is suppressed. The range is 1 to 20,000. The default value is 2,000.
ceiling: Upper penalty threshold in seconds, that is, the penalty value stops increasing when it reaches the upper threshold. The range is 1,001 to 20,000. The default value is 16,000.
route-policy-name: Name of a route policy, in the range of 1 to 19 characters.
If no value is specified for the arguments, their default values will take effect. The half-life-reachable, half-life-unreachable, reuse, suppress, and ceiling arguments are independent of each other. Therefore, if you specify a value for any of these arguments, you must specify a value for all the others.
Use the dampening command to make BGP route attenuation valid or modify various BGP route attenuation parameters.
Use the undo dampening command to make the characteristics invalid.
By default, no route attenuation is configured.
Related commands: reset bgp dampening, reset bgp flap-info, display bgp routing-table dampened, display bgp routing-table flap-info.
# Configure BGP route dampening parameters.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] dampening 15 15 1000 2000 10000
5.1.9 default local-preference
undo default local-preference
View
BGP view
value: Default local preference to be configured. The range is 0 to 4294967295. A higher value represents a higher preference. By default, its value is 100.
Use the default local-preference command to configure the default local preference.
Use the undo default local-preference command to restore the default value.
Configuring different local preferences will affect BGP routing selection.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] default local-preference 180
5.1.10 default med
default med med-value
undo default med
View
BGP view/BGP multicast address family view
med-value: Specified MED value, in the range of 0 to 4294967295. The default med-value is 0.
Use the default med command to configure the default MED value of the system.
Use the undo default med command to restore the default MED value of the system.
The multi-exit discriminator (MED) is an external route metric. Different from the local preference, the MED is exchanged between autonomous systems. After the MED enters an autonomous system, it will not be sent out of this autonomous system. The MED attribute is used to select the optimal route, that is, the route with a smaller MED value is selected. When a router running the BGP obtains routes with the same destination address but different next hops through different external peers, the route selection will be based on the MED value. In the case that all other conditions are the same, the system first selects the route with the smaller MED value as an external route of the autonomous system.
# Set the MED value to 25.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] default med 25
5.1.11 display bgp group
display bgp [ multicast ] group [ group-name ]
View
multicast: Specifies multicast address family.
group-name: Name of a peer group, a string of 1 to 47 alphanumeric characters.
Use the display bgp group command to display the information of peer groups.
# Display the information of the peer group aaa.
<H3C> display bgp group aaa
Group : aaa type : external
as-number : 200
members in this group :
10.1.1.1 11.1.1.1
configuration within the group :
no export policy route-policy
no export policy filter-policy
no export policy acl
no export policy ip-prefix
no import policy route-policy
no import policy filter-policy
no import policy acl
no import policy ip-prefix
no default route produce
Table 5-2 Description on fields of the display bgp group command
Group |
Name of peer group |
type |
Type of peer group: internal (IBGP) or external (EBGP) |
as-number |
AS number of peer group |
members in this group |
Members in this peer group |
route-policy |
Name of configured route policy |
filter-policy |
Configured export and import route filter for BGP |
acl |
Configured access control list |
ip-prefix |
Configured IP address prefix list |
default route produce |
Whether or not to advertise default routing information |
5.1.12 display bgp network
display bgp [ multicast ] network
View
Use the display bgp network command to view the routing information that has been configured.
# Display the routing information that has been configured.
<H3C> display bgp network
Network Mask Route-policy
168.10.24.0 255.255.255.0 None
10.0.0.0 255.0.0.0 None
Table 5-3 Description on fields of the display bgp network command
Network |
Network address |
Mask |
Mask |
Route-policy |
Configured route policy |
5.1.13 display bgp paths
display bgp paths as-regular-expression
View
as-regular-expression: Matched AS path regular expression, a string of 1 to 79 characters.
Use the display bgp paths command to view the information about AS paths
# Display the information about the AS paths.
<H3C> display bgp paths 500
Id Hash-index References Aggregator Origin As-Path
153 80 100 <null> IGP 500 {500,400,600}
Table 5-4 Description on fields of the display bgp paths command
Id |
Value of sequence number |
Hash-Index |
Value of Hash-index |
References |
Number of routes with reference |
Aggregator |
Mask length of aggregate route |
Origin |
Origin attribute of route, which indicates that the route updates its origin relative to the route originating it from AS. It has three optional values: |
IGP |
The route belongs to inside of AS. BGP treats aggregate route and the route defined by the command network as inside of AS, and origin type as IGP. |
EGP |
The route is learned from exterior gateway protocol (EGP). |
INC |
Short for INCOMPLETE: indicates that the original source of the route information is unknown (learned by other methods). BGP sets the origin of the route imported through other IGP protocols as INCOMPLETE |
As-path |
AS-path attribute of route, which records all AS areas that the route passes. With it, route loop can be avoided. |
5.1.14 display bgp peer
display bgp [ multicast ] peer [ ip-address [ verbose ] ]
display bgp [ multicast ] peer [ verbose ]
View
ip-address: IP address of the peer to be displayed.
verbose: Displays detailed information of the specified peer.
Use the display bgp peer command to display the information about the specified BGP peer.
# Display detailed information of the peer 10.110.25.20.
<H3C> display bgp peer 10.110.25.20 verbose
Peer: 10.110.25.20 Local: Unspecified
Type: External
State: Idle Flags: <Idled>
Last State: NoState Last Event: NoEvent
Last Error: None
Options: <>
Configuration within the peer :
Table 5-5 Description on fields of the display bgp peer command
Peer |
IP address of peer and port number used by the peer to establish TCP connection |
Local |
IP address and port number used to establish TCP connection of local end |
Type |
Type of peer: Internal for IBGP, and External for EBGP |
State |
State of peer |
Flags |
Flags of peer |
Last State |
Last state before entering current state |
Last Event |
Last event of neighbor state machine |
Last Error |
Last error of neighbor state machine |
Options |
Options |
5.1.15 display bgp routing-table
display bgp [ multicast ] routing-table [ ip-address [ mask ] ]
View
ip-address: Destination of the network.
mask: Mask of the network.
Use the display bgp routing-table command to display all the BGP routing information.
# Display all the BGP routing information.
<H3C> display bgp routing-table
Flags: # - valid ^ - active I - internal
D - damped H - history S - aggregate suppressed
Dest/Mask Next-hop Med Local-pref Origin As-path
#^ 129.1.1.0/24 5.5.5.5 IGP 600
#^ 129.1.2.0/24 5.5.5.5 IGP 600
#^ 129.1.3.0/24 5.5.5.5 IGP 600
#^ 129.1.4.0/24 5.5.5.5 IGP 600
#^ 129.1.5.0/24 5.5.5.5 IGP 600
#^ 129.1.6.0/24 5.5.5.5 IGP 600
#^ 129.1.7.0/24 5.5.5.5 IGP 600
#^ 129.1.8.0/24 5.5.5.5 IGP 600
#^ 129.1.9.0/24 5.5.5.5 IGP 600
#^ 129.1.10.0/24 5.5.5.5 IGP 600
Routes total: 10
Table 5-6 Description on fields of the display bgp routing-table command
Flags |
Status code: # – valid (valid route) ^ – active (selected optimal route) I – internal (IBGP route) D – damped (attenuation dampened) H – history (history record) S – aggregate suppressed (aggregation suppressed) |
Dest/Mask |
Destination address/mask |
Next Hop |
IP address of the next hop |
Med |
Value of the MULTI_EXIT_DISC attribute, which ranges from 0 to 4294967295 |
Local-Pref |
Local preference, which ranges from 0 to 4294967295 |
Origin |
Origin attribute of a route, which indicates that the route updates its origin relative to the route originating it from the AS. It has three optional values: |
IGP |
The route is inside the AS. BGP treats the aggregation route and the route defined by the network command inside AS, and the origin type as IGP. |
EGP |
INC |
As-path |
AS-path attribute of a route, which records all AS areas that the route passes to avoid route loop. |
5.1.16 display bgp routing-table as-path-acl
display bgp [ multicast ] routing-table as-path-acl acl-number
View
acl-number: Matched AS path list number, in the range of 1 to 199.
Use the display bgp routing-table as-path-acl command to view routes that match an as-path acl.
# Display routes that match as-path-acl 1.
<H3C> display bgp routing-table as-path-acl 1
Dest/Mask Next-Hop Med Local-pref Origin As-path
#^ 1.1.1.0/24 10.10.10.1 0 IGP 200
#^ 1.1.2.0/24 10.10.10.1 0 IGP 200
#^ 1.1.3.0/24 10.10.10.1 0 IGP 200
#^ 2.2.3.0/24 10.10.10.1 0 INC 200
#^ 4.4.4.0/24 10.10.10.1 0 INC 200
#^ 9.9.9.0/24 10.10.10.1 0 INC 200
#^ 10.10.10.0/24 10.10.10.1 0 IGP 200
#^ 22.1.0.0/16 200.1.7.2 100 INC 200
Table 5-7 Description on fields of the display bgp routing-table as-path-acl command
Dest/Mask |
Destination address/Mask |
Pref |
Preference |
Nexthop |
IP address of next hop |
Med |
MULTI_EXIT_DISC attribute value |
Local-pref |
Local preference |
Origin |
IGP |
EGP |
INC |
As-path |
AS-path attribute of route, which records all AS areas that the route passes. With it, route loop can be avoided |
5.1.17 display bgp routing-table cidr
display bgp [ multicast ] routing-table cidr
View
Use the display bgp routing-table cidr command to view the routing information about the non-natural mask (namely the classless inter-domain routing, CIDR).
# Display BGP CIDR routing information.
<H3C> display bgp routing-table cidr
#^ 22.1.0.0/16 200.1.7.2 30 100 INC 200
# 88.1.0.0/16 0.0.0.0 30 IGP
For detailed description of the fields in the output information, see Table 5-6.
5.1.18 display bgp routing-table community
display bgp [ multicast ] routing-table community [ aa:nn | no-export-subconfed | no-advertise | no-export ]* [ whole-match ]
View
aa:nn: Community number.
no-export-subconfed: Specifies not to export a route to the outside of the local AS or to other sub-ASs in the confederation after the route is received.
no-advertise: Specifies not to advertise a route to other BGP peers after the route is received.
no-export: Specifies not to export a route to the outside of the local AS after the route is received. If the confederation is used, the router cannot be exported to the outside of the confederation, but can be exported to other sub-ASs in the confederation.
whole-match: Displays the exactly matched routes.
Use the display bgp routing-table community command to view the routing information related to the specified BGP community number in the routing table.
# Display the routing information matching BGP community number 11:22.
<H3C> display bgp routing-table community 11:22
#^ 1.0.0.0/8 172.10.0.2 100 IGP
#^ 2.0.0.0/8 172.10.0.2 100 IGP
5.1.19 display bgp routing-table community-list
display bgp [ multicast ] routing-table community-list community-list-number [ whole-match ]
View
community-list-number: Community list number, in the range of 1 to 999.
Use the display bgp routing-table community-list command to view the routing information matching the specified BGP community list.
# Display the routing information matching BGP community list 1.
<H3C> display bgp routing-table community-list 1
Destination/Mask Next-hop Med Local-Pref Origin As-Path
10.10.10.0/24 10.10.10.2 0 IGP
5.1.20 display bgp routing-table dampened
View
None
Use the display bgp routing-table dampened command to display BGP dampened routes.
# Display BGP dampened routes.
<H3C> display bgp routing-table dampened
Dest/Mask Source Damping-limit Origin As-path
#D 11.1.0.0 133.1.1.2 1:20:00 IGP 200
Table 5-8 Description on the fields of the display bgp routing-table dampened command
Flags |
Status code: # – valid (valid route) ^ – active (selected optimal route) I – internal (IBGP route) D – damped (attenuation dampened) H – history (history record) S – aggregate suppressed (aggregation suppressed) B – balance (load balance) |
#D |
Valid and dampened route |
Dest/Mask |
The route to this network segment is dampened. |
Source |
Next hop of the route |
Damping-limit |
The time before dampening turns invalid and the route can be reused. |
Origin |
IGP |
EGP |
INC |
As-path |
5.1.21 display bgp routing-table different-origin-as
display bgp [ multicast ] routing-table different-origin-as
View
Use the display bgp routing-table different-origin-as command to display routes that have different source autonomous systems.
# Display the routes that have different source ASs.
<H3C> display bgp routing-table different-origin-as
5.1.22 display bgp routing-table flap-info
display bgp routing-table flap-info [ regular-expression as-regular-expression | as-path-acl acl-number | network-address [ mask [ longer-match ] ] ]
View
as-regular-expression: Route flap-info matching AS path regular expression.
acl-number: Number of the specified AS path to be matched, in the range of 1 to 199.
network-address: Network IP address related to the dampening information to be shown
mask: Network mask.
longer-match: Displays the flap-info of the route that has a mask longer than that specified by the network-address mask argument.
Use the display bgp routing-table flap-info command to view BGP flap-info.
# Display BGP flap-info.
<H3C> display bgp routing-table flap-info
Dest/Mask Source Keepup Damping Flap Origin As-path
time limit times
#D 11.1.0.0/16 133.1.1.2 48 1:20:30 4 IGP 200
Table 5-9 Description on fields of the display bgp routing-table flap-info command
Flags |
State flags: # – valid (valid route) ^ – active (selected optimal route) D – damped (attenuation dampened) H – history (history record) I – internal (interior gateway protocol) S – aggregate suppressed (aggregation suppressed) B – balance (load balance) |
#D |
Valid and damped route |
Dest/Mask |
Source |
The next hop of the route |
Keepup-time |
The time that route damping has continued |
Damping-limit |
Flap-times |
The times of the route flap |
Origin |
IGP |
EGP |
INC |
As-path |
5.1.23 display bgp routing-table peer
display bgp [ multicast ] routing-table peer ip-address { advertised | received } [ network-address [ mask ] | statistic ]
View
ip -address: Specifies the peer to be displayed.
advertised: Routing information advertised by the specified peer.
received: Routing information the specified peer received.
network-address mask : IP address and address mask of destination network.
statistic: Statistic routing information of peer.
Use the display bgp routing-table peer command to view the routing information that the specified BGP peer advertised or received.
Related commands: display bgp peer
# Display the routing information advertised by BGP peer 1.1.1.2.
<H3C> display bgp routing table peer 1.1.1.2 advertised
Appendant Flags: @ - Queued
1.1.1.0/24 1.1.1.1 0 100 INC
Here, "Appendant Flags" indicates the appended flag, "@" the route to be sent, "!" the reachable route, and "~" to cancel route. For detailed description of the fields in the output information, see Table 5-6.
5.1.24 display bgp routing-table regular-expression
display bgp [ multicast ] routing-table regular-expression as-regular-expression
View
as-regular-expression: Matched AS regular expression.
Use the display bgp routing-table regular-expression command to view the routing information matching the specified AS regular expression
# Display the routing information matched with ^200$.
<H3C> display bgp routing-table regular-expression ^200$
Dest/Mask Next-hop Med Local-Pref Origin AS-Path
4.4.4.0/24 10.10.10.1 0 IGP 200
5.1.25 display bgp routing-table statistic
display bgp [ multicast ] routing-table statistic
View
Use the display bgp routing-table statistic command to view the statistics of BGP routing information.
# Display the statistics of BGP routing information.
<H3C> display bgp routing-table statistic
Routes total: 4
5.1.26 filter-policy export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
undo filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
View
BGP view
acl-number: Number of the ACL used to match the destination address field of the routing information, ranging 2000 to 3999.
ip-prefix-name: Name of the ip prefix list used to match the destination address field of the routing information, containing 1 to 19 characters.
protocol: Routing protocol whose routing information is to be filtered. Currently, routing information obtained using the following methods can be filtered: direct, ospf, ospf-ase, ospf-nssa, rip, isis, and static.
process-id: Routing protocol process ID, in the range of 1 to 65535. This argument is valid only when the protocol is ospf.
Use the filter-policy export command to filter the advertised routes and only the routes passing the filter can be advertised by BGP.
Use the undo filter-policy export command to cancel the filtration to the advertised routes.
By default, filtration to the received routing information is not configured.
If a value is specified for the protocol argument, only the imported route generated by the specified protocol is filtered and the imported routes generated by other protocols are not affected. If no value is specified for the protocol argument, the imported route generated by any protocol will be filtered.
# Use ACL 2000 to filter the routing information advertised by BGP.
[H3C] bgp 100
[H3C-bgp] filter-policy 2000 export
5.1.27 filter-policy import
filter-policy gateway ip-prefix-name import
undo filter-policy gateway ip-prefix-name import
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy { acl-number | ip-prefix ip-prefix-name } import
View
BGP view
ip-prefix ip-prefix-name: Specifies the name of address prefix list used to match the destination address field of the routing information, containing 1 to 19 characters.
gateway ip-prefix-name: Specifies the ip-prefix name of a neighboring router to match against the routing information advertised by the specified neighboring router. ip-prefix-name contains 1 to 19 characters.
Use the filter-policy gateway import command to filter the learned routing information advertised by the peer with the specified address.
Use the undo filter-policy gateway import command to cancel the filtration to the routing information advertised by the peer with specified address.
Use the filter-policy import command to filter the received global routing information. Use the undo filter-policy import command to remove the filtration to the received global routing information.
This command can be used to filter the routes received by BGP and determines whether to add the routes to the BGP routing table.
# Use ACL 2000 to filter all imported BGP routes.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] filter-policy 2000 import
5.1.28 group
group group-name [ internal | external ]
undo group group-name
View
BGP view
group-name: Name of the peer group, an alphanumeric string of 1 to 47 characters. It is significant only locally.
internal: Creates an IBGP peer group.
external: Creates an EBGP peer group, including other sub-ASs in the confederation.
Use the group group-name command to configure a peer group.
Use the undo group group-name command to cancel the configuration.
If no parameter is specified with the group command, an IBGP peer group is created.
The basic configurations of members in a peer group must be the same as those of the peer group. The BGP peer cannot exist independently, and it must belong to a peer group. Therefore, when configuring a BGP peer, create a peer group first and then add the BGP peer to the group.
Routing update policies of peer members must be the same as those of the peer group. However, entry policies can be different.
# Create an IBGP group named test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] group test
5.1.29 import-route
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ]*
undo import-route protocol [ process-id ]
View
BGP view
protocol: Source routing protocols which can be imported, including direct, ospf, ospf-ase, ospf-nssa, rip, isis and static at present.
process-id: Specific process ID, in the range of 1 to 65535. This argument is valid only when the protocol argument is “ospf”.
med med-value: Specifies the MED value loaded by the imported route, in the range of 0 to 4294967295.
route-policy route-policy-name: Specifies a route-policy to filter routes before importing. The route-policy-name argument is an alphanumeric string of 1 to 19 characters.
Use the import-route command to import and advertise routes of other protocols.
Use the undo import-route command to cancel the existing configuration.
By default, BGP does not import and advertise routes of other protocols.
# Import routes of RIP.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] import-route rip
5.1.30 network
network ip-address [ mask ] [ route-policy route-policy-name ]
undo network ip-address [ mask ] [ route-policy route-policy-name ]
View
BGP view
ip-address: IP address of the destination network segment.
mask: Subnet mask.
route-policy-name: Route policy used for the advertised route, containing 1 to 19 characters.
Use the network command to advertise the network segment route to the BGP routing table.
Use the undo network command to cancel the existing configuration.
By default, BGP does not advertise any network segment routes.
# Advertise routes to the network segment 10.0.0.0/16.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] network 10.0.0.0 255.255.0.0
5.1.31 peer advertise-community
peer group-name advertise-community
undo peer group-name advertise-community
View
BGP view
group-name: Name of a peer group, containing 1 to 47 alphanumeric characters.
Use the peer advertise-community command to enable the transmission of the community attribute to a peer group.
Use the undo peer advertise-community command to cancel the existing configuration.
By default, the community attribute is not transmitted to any peer group.
Related commands: if-match community-list, apply community.
# Transmit the community attribute to the peer group named test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test advertise-community
5.1.32 peer allow-as-loop
peer { group-name | ip-address } allow-as-loop [ number ]
undo peer { group-name | ip-address } allow-as-loop
View
BGP view
ip-address: IP address of the peer.
number: Times of repeating the local AS number, in the range of 1 to 10.
Use the peer allow-as-loop command to allow the local AS number to appear in the AS_Path attribute of the received route and configure the repeated times.
Use the undo peer allow-as-loop command to cancel the function.
Related commands: display current-configuration, display bgp routing-table peer, display bgp routing-table group
# Set the times of repeating the local AS that learns routes from 1.1.1.1 to “2”.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer 1.1.1.1 allow-as-loop 2
5.1.33 peer as-number
undo peer group-name as-number
View
BGP view
as-number: AS number of the peer or peer group, in the range of 1 to 65535.
Use the peer as-number command to configure the AS number of a peer group.
Use the undo peer as-number command to delete the AS number of a peer group.
By default, no AS number is configured for a peer group.
# Set the AS number for the peer named test to 100.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test as-number 100
5.1.34 peer as-path-acl export
peer group-name as-path-acl acl-number export
undo peer group-name as-path-acl acl-number export
View
BGP view
group-name: Name of the peer group, containing 1 to 47 alphanumeric characters.
acl-number: AS path ACL number, in the range of 1 to 199.
export: Filters the advertised routes.
Use the peer as-path-acl export command to configure filtering policy of BGP advertised routes based on AS path list.
Use the undo peer as-path-acl command to cancel the existing configuration.
By default, no AS path ACL is configured for a peer group.
You can use the peer as-path-acl export command on a peer group. In the peer as-path-acl export command, the acl-number argument is the AS path list number. It is configured by using the ip as-path-acl command, instead of the acl command.
Related commands: peer as-path-acl import, ip as-path-acl.
# Filter routes exported to the peer group (named test) based on AS path ACL 1.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test as-path-acl 1 export
5.1.35 peer as-path-acl import
peer { group-name | ip-address } as-path-acl acl-number import
undo peer { group-name | ip-address } as-path-acl acl-number import
View
BGP view
ip-address: IP address of the peer, in dotted decimal notation.
acl-number: AS path list number, in the range of 1 to 199.
import: Applies the AS path list in filtering the received routes.
Use the peer as-path-acl import command to configure filtering Policy of BGP received routes based on AS path list.
Use the undo peer as-path-acl import command to cancel the existing configuration.
By default, the peer/peer group has no AS path list.
The priority of the ingress routing policy configured for the peer is higher than that for the peer group.
Related commands: peer as-path-acl export, ip as-path-acl
# Apply AS path ACL 1 in the peer group named test to filter BGP received routes.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test as-path-acl 1 import
5.1.36 peer connect-interface
peer { group-name | ip-address } connect-interface interface-type interface-number
undo peer { group-name | ip-address } connect-interface interface-type interface-number
View
BGP view
interface-type interface- number: Interface type and interface number.
Use the peer connect-interface command to specify the source interface of a route update packet.
Use the undo peer connect-interface command to restore the best source interface.
By default, BGP uses the interface directly connected to the peer as the source interface of route update packets.
Generally, BGP uses the optimal source interface for route update packets. In order for the system to be able to send route update packets in the case that this interface is faulty, you can configure the loopback interface as the source interface of route update packets.
# Specify the source interface that sends route update packets to the peer group named test as Loopback 0.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test connect-interface loopback 0
5.1.37 peer default-route-advertise
peer group-name default-route-advertise
undo peer group-name default-route-advertise
View
BGP view
Use the peer default-route-advertise command to send the default route to the peer group.
Use the undo peer default-route-advertise command to cancel the existing configuration.
By default, the default route is not sent to the peer group.
For this command, no default route needs to exist in the routing table. A default route is sent unconditionally to a peer group with the next hop as itself.
# Configure a peer group named test to generate a default route.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test default-route-advertise
5.1.38 peer description
peer { group-name | ip-address } description description-text
undo peer { group-name | ip-address } description
View
BGP view
description-text: Description information configured, containing up to 79 alphanumeric characters.
Use the peer description command to configure the description information of the peer/peer group.
Use the undo peer description command to cancel the description information of the peer/peer group.
By default, no description information is configured for peers/peer group.
Related commands: display current-configuration, display bgp peer, display bgp routing-table group.
# Configure the description information of an existing peer group named group1 as beijing1.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer group1 description beijing1
5.1.39 peer ebgp-max-hop
peer group-name ebgp-max-hop [ hop-count ]
undo peer group-name ebgp-max-hop
View
BGP view
group-name: Name of the peer group, containing 1 to 47 characters.
hop-count: Maximum hop value, in the range of 1 to 255. By default, the value is 64.
Use the peer ebgp-max-hop command to establish EBGP connection with the peer on indirectly connected network.
Use the undo peer ebgp-max-hop command to cancel the existing configuration.
By default, it is not allowed to establish any EBGP connection with a peer on an indirectly connected network.
By setting hop-count, you can also configure the maximum hop value of an EBGP connection.
# Allow to establishing EBGP connection with the peer group named test indirectly connected.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test ebgp-max-hop
5.1.40 peer enable
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
View
BGP view
Use the peer enable command to enable the specified peer/peer group.
Use the undo peer enable command to disable the specified peer/peer group.
By default, a BGP peer/peer group is enabled.
If the specified peer/peer group is disabled, the router will not exchange routing information with the specified peer/peer group.
# Disable the specified peer 18.10.0.9. After the configuration, the local router does not exchange BGP routing information with the peer 18.10.0.9..
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer 18.10.0.9 group group1
[H3C-bgp] undo peer 18.10.0.9 enable
5.1.41 peer filter-policy export
peer group-name filter-policy acl-number export
undo peer group-name filter-policy acl-number export
View
BGP view
acl-number: Basic or advanced ACL number, ranging from 2000 to 3999.
export: Applies a filtering policy on advertised routes. It applies to a peer group only.
Use the peer filter-policy export command to configure the filter-policy list of routes advertised by a peer group.
Use the undo peer filter-policy export command to cancel the existing configuration.
By default, a peer/peer group has no access control list (acl).
You can configure the peer filter-policy export command on a peer group only.
Related commands: acl, peer filter-policy import.
# Configure to filter the routes advertised by the peer group named test by using ACL 2000.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test filter-policy 2000 export
5.1.42 peer filter-policy import
peer { group-name | ip-address } filter-policy acl-number import
undo peer { group-name | ip-address } filter-policy acl-number import
View
BGP view
ip-address: IP address of the peer, in dotted decimal format.
Use the peer filter-policy import command to configure the filter-policy list of the routes received by a peer/peer group.
Use the undo peer filter-policy import command to cancel the existing configuration.
Related commands: peer filter-policy export, ip as-path-acl, peer as-path-acl export, peer as-path-acl import.
# Set the filter-policy list of a peer group test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test filter-policy 2000 import
5.1.43 peer group
peer ip-address group group-name [ as-number as-number ]
undo peer ip-address
View
BGP view
as-number: Peer AS number of the peer/peer group, in the range of 1 to 65535.
Use the peer group command to add a peer to the existing peer group.
Use the undo peer ip-address command to delete a peer.
When adding a peer to an EBGP peer group without AS number, you should also specify the peer’s AS number. While adding a peer to an IBGP peer group or to a EBGP peer group with AS number, you need not specify the AS number for the peer.
# Add a peer to the peer group test.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp] group test external
[H3C-bgp] peer test as-number 2004
[H3C-bgp] peer 10.1.1.1 group test
5.1.44 peer ip-prefix export
peer group-name ip-prefix ip-prefix-name export
undo peer group-name ip-prefix ip-prefix-name export
View
BGP view
group-name: Name of peer group, containing 1 to 47 characters.
ip-prefix-name: Name of the specified ip-prefix, a string containing 1 to 19 characters.
Use the peer ip-prefix export command to configure the route filtering policy of routes advertised by the peer group based on the ip-prefix.
Use the undo peer ip-prefix export command to cancel the route filtering policy of the peer group based on the ip-prefix.
By default, the route filtering policy of the peer group is not specified.
You can use the peer ip-prefix export command on peer groups only.
Related commands: peer ip-prefix import
# Configure the route filtering policy of the peer group based on the ip-prefix 1.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer group1 ip-prefix list1 export
5.1.45 peer ip-prefix import
peer { group-name | ip-address } ip-prefix ip-prefix-name import
undo peer { group-name | ip-address } ip-prefix ip-prefix-name import
View
BGP view
ip-prefix-name: Name of the specified ip-prefix, containing 1 to 19 characters.
Use the peer ip-prefix import command to configure the route filtering policy of routes received by the peer/peer group based on the ip-prefix.
Use the undo peer ip-prefix import command to cancel the route filtering policy of the peer/peer group based on the ip-prefix.
By default, the route filtering policy of the peer/peer group is not specified.
Related commands: peer ip-prefix export
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer group1 ip-prefix list1 import
5.1.46 peer next-hop-local
peer group-name next-hop-local
undo peer group-name next-hop-local
View
BGP view
Use the peer next-hop-local command to configure the peer group to take its own address as the next hop when routes are advertised to the peer group.
Use the undo peer next-hop-local command to cancel the existing configuration.
# When BGP distributes the routes to the peer group test, it will take its own address as the next hop.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test next-hop-local
5.1.47 peer password
peer { group-name | ip-address } password { cipher | simple } password
undo peer { group-name | ip-address } password
View
BGP view
cipher: Displays the configured password in cipher text mode.
simple: Displays the configured password in simple text mode.
password: Password in character string form with 1 to 16 characters when the simple keyword is specified in the command or in the event of inputting the password in simple text mode but the cipher keyword is specified in the command; with 24 characters in the event of inputting the password in cipher text mode when the cipher keyword is specified in the command.
Use the peer password command to configure MD5 authentication for BGP during TCP connection setup.
Use the undo peer password command to cancel the configuration.
By default, BGP does not perform MD5 authentication when TCP connection is set up.
Once MD5 authentication is enabled, both parties involved in the authentication must be configured with identical authentication modes and passwords. Otherwise, TCP connection will not be set up because of the failed authentication.
This command is used to configure MD5 authentication for the specific peer only when the peer group to which the peer belongs is not configured with MD5 authentication. Otherwise, the peer should be consistent with the peer group.
# Adopt MD5 authentication on the TCP connection set up between the local router at 10.1.100.1 and the peer router at 10.1.100.2.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer 10.1.100.2 password simple abc
# Perform the similar configuration on the peer.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer 10.1.100.1 password simple abc
5.1.48 peer public-as-only
peer group-name public-as-only
undo peer group-name public-as-only
View
BGP view
group-name: Name of a peer group, containing 1 to 47 characters.
Use the peer public-as-only command to configure not to carry the AS number when transmitting BGP update packets.
Use the undo peer public-as-only command to configure to carry the AS number when transmitting BGP update packets.
By default, private AS number is carried when transmitting BGP update packets.
Generally, BGP transmits BGP update packets with the AS number (either public AS number or private AS number). To enable some outbound routers to ignore the AS number when transmitting update packets, you can configure not to carry the AS number when transmitting BGP update packets.
# Configure not to carry the private AS number when transmitting BGP update packets to the peer group named test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test public-as-only
5.1.49 peer reflect-client
peer group-name reflect-client
undo peer group-name reflect-client
View
BGP view
Use the peer reflect-client command to configure the local device as a route reflector and configure a peer/peer group as the route reflector client.
Use the undo peer reflect-client command to cancel the existing configuration.
By default, no route reflector or client is configured.
This command only applies to IBGP peer groups.
Related commands: reflect between-clients, reflector cluster-id.
# Configure the peer group test as the route reflector client.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test reflect-client
5.1.50 peer route-policy export
peer group-name route-policy route-policy-name export
undo peer group-name route-policy route-policy-name export
View
BGP view
route-policy-name: The specified Route-policy. The length of route-policy-name argument ranges from 1 to 19 character string.
Use the peer route-policy export command to assign the Route-policy to the routes advertised to the peer group.
Use the undo peer route-policy export command to delete the specified Route-policy.
By default, the peer group has no Route-policy association.
The peer route-policy export command applies to peer groups only.
Related commands: peer route-policy import
# Apply the Route-policy named test-policy to the route advertised from the peer group named test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test route-policy test-policy export
5.1.51 peer route-policy import
peer { group-name | ip-address } route-policy route-policy-name import
undo peer { group-name | ip-address } route-policy route-policy-name import
View
BGP view
route-policy-name: Specified Route-policy, a string of 1 to 19 characters.
Use the peer route-policy import command to assign the Route-policy to the route coming from the peer/peer group.
Use the undo peer route-policy import command to delete the specified Route-policy.
By default, the peer/peer group has no Route-policy association.
Related commands: peer route-policy export.
# Apply the Route-policy named test-policy to the route coming from the peer/peer group test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test route-policy test-policy import
5.1.52 peer route-update-interval
peer group-name route-update-interval seconds
undo peer group-name route-update-interval
View
BGP view
group-name: Peer group name, containing 1 to 47 characters.
seconds: Minimum interval at which UPDATE packets are sent. It is in the range of 0 to 600 seconds. By default, the advertisement interval is 5 seconds for internal peer group and 30 seconds for external peer group.
Use the peer route-update-interval command to configure the interval at which the same route update packet is sent to the peer group. .
Use the undo peer route-update-interval command to restore the default interval.
# Configure the interval of the BGP peer group test sending the route update packet as 10 seconds.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test route-update-interval 10
5.1.53 peer timer
peer { group-name | ip-address } timer keep-alive keepalive-interval hold holdtime-interval
undo peer { group-name | ip-address } timer
View
BGP view
keepalive-interval: Keepalive timer in seconds. It is in the range of 1 to 65535 and defaults to 60.
holdtime-interval: Holdtime timer in seconds. It is in the range of 3 to 65535 and defaults to 180.
Use the peer timer command to configure the Keepalive and holdtime timers for a peer/peer group.
Use the undo peer timer command to restore the default value of the timer.
The timer configured by using this command has a higher priority than the one configured by using the timer command.
# Configure Keepalive and Holdtime intervals of the peer group test.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] peer test timer keep-alive 60 hold 180
5.1.54 preference
preference ebgp-value ibgp-value local-value
undo preference
View
BGP view
ebgp-value: Preference value for EBGP. It is in the range of 1 to 256 and defaults to 256.
ibgp-value: Preference value for IBGP routes. It is in the range of 1 to 256 and defaults to 256.
local-value: Preference value for locally-originated routes. It is in the range of 1 to 256 and defaults to 130.
Use the preference command to set preference values for the routes learned from external peers, routes learned from internal peers, and local-originated routes.
Use the undo preference command to restore the default preference values.
You can configure preferences for different types of routes of BGP.
# Set the preferences of EBGP, IBGP and locally generated routes to 170.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] preference 170 170 170
5.1.55 reflect between-clients
undo reflect between-clients
View
BGP view
None
Use the reflect between-clients command to configure the between-client reflection of a route.
Use the undo reflect between-clients command to disable this function.
After a route reflector is configured, it reflects the route of a client to another client.
By default, the clients of a route reflector are not fully interconnected and the route is reflected from a client to another client by default via the route reflector. If the clients are fully interconnected, you do not need to configure route reflection.
Related commands: reflector cluster-id, peer reflect-client.
# Disable the reflection between clients.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] undo reflect between-clients
5.1.56 reflector cluster-id
reflector cluster-id cluster-id
undo reflector cluster-id
View
BGP view
cluster-id: Cluster ID of the route reflector, an integer number ranging from 1 to 4294967295, or an IP address in dotted decimal notation.
Use the reflector cluster-id command to configure the cluster ID of the route reflector.
Use the undo reflector cluster-id command to delete the cluster ID of the route reflector.
By default, each route reflector uses its Router ID as the cluster ID.
Generally, there is only one route reflector in a cluster. In this case, Router ID of the route reflector is used to identify the cluster. Setting multiple route reflectors enhances network stability. If multiple route reflectors are in a cluster, use this command to configure the same cluster ID for all the route reflectors to prevent route loop.
Related commands: reflect between-clients, peer reflect-client.
# A local router is one of the route reflectors in a cluster. Set the cluster ID of the route reflector to 80.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] reflector cluster-id 80
5.1.57 refresh bgp
refresh bgp { all | ip-address | group group-name } [ multicast ] { import | export }
View
all: Refreshes all peers.
ip-address: Refreshes connection with a specified BGP peer.
import: Sends a ROUTE-REFRESH packet to the peer, requesting the peer to refresh the routes.
export: Refreshes routes advertised to the peers.
Use the refresh bgp command to request the peer to resend routes or resend routes to the peer.
After a BGP connection is created, only incremental routes are sent. However, in some cases, such as when BGP routing policy changes, the peer needs to re-advertise routes or to be resent routes so that the routes are filtered again according to the new policy.
# Refresh all BGP connections.
<H3C> refresh bgp all import
5.1.58 reset bgp
reset bgp { all | ip-address | group group-name }
View
all: Resets all the BGP connections.
ip-address: Resets connection with a specified BGP peer.
group group-name: Resets the connection with a specified peer group.
Use the reset bgp ip-address command to reset the connection of BGP with a specified BGP peer.
Use the reset bgp all command to reset all the connections with BGP.
Use the reset bgp group group-name command to reset the BGP connection with a specified peer group.
After a BGP routing policy or protocol configuration changes, resetting the BGP connection will make the new configured policy take effect immediately.
# After using the timer command to configure new Keepalive and Holdtime intervals, you can reset all BGP connections for the new configuration to take effects immediately.
<H3C> reset bgp all
5.1.59 reset bgp dampening
reset bgp dampening [ network-address [ mask ] ]
View
network-address: IP address of the network segment, in dotted decimal notation.
mask: Network mask.
Use the reset bgp dampening command to reset the flapping attenuation information of a route and release the suppression of a suppressed route.
Related commands: dampening, display bgp routing-table dampened.
# Reset the route attenuation information of the specified route.
<H3C> reset bgp dampening 20.1.0.0 255.255.0.0
5.1.60 reset bgp flap-info
reset bgp flap-info [ regular-expression as-regular-expression | as-path-acl acl-number | ip-address [ mask ] ]
View
regular-expression as-regular-expression: Resets the flap-info matching the AS path regular expression.
as-path-acl acl-number: Resets the flap-info in consistency with a specified filter list. The range of the parameter acl-number is 1 to 199.
ip-address: Resets the flap-info of a record at this IP address.
mask: Network mask.
Use the reset bgp flap-info command to reset the flap info of a route.
If no value is specified, the flap info of all routes will be reset.
Related commands: dampening.
# Reset the flap-info of all the routes that go through filter list 1.
<H3C> reset bgp flap-info as-path-acl 1
5.1.61 reset bgp group
View
group-name: Name of the peer group, a string of 1 to 47 characters.
Use the reset bgp group command to reset the connections between the BGP and all the members of a group.
Related commands: peer group.
# Reset BGP connections of all members from group1.
<H3C> reset bgp group group1
5.1.62 router id
router id router-id
undo router id
View
router-id: Router ID, in dotted decimal notation.
Use the router id command to configure the ID of a BGP router.
Use the undo router id command to cancel the router ID that has been set.
# Set the router ID to 10.1.1.3.
<H3C> system-view
[H3C] router id 10.1.1.3
5.1.63 summary
summary
undo summary
View
BGP view
None
Use the summary command to configure auto aggregation of sub-network routes.
Use the undo summary command to disable it.
By default, no auto aggregation of sub-network routes is executed.
After the summary command is used, BGP cannot receive the sub-network routes imported from the IGP, so the amount of the routing information can be reduced.
# Perform auto aggregation of the sub-network routes.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] summary
5.1.64 timer
undo timer
View
BGP view
keepalive-interval: Interval time value for keepalive time. The range is 1 to 65535. By default, its value is 60 seconds.
holdtime-interval: Interval time value for hold time. The range is 3 to 65535. By default, its value is 180 seconds.
Use the timer command to configure the Keep-alive and Hold-time timer of BGP.
Use undo timer command to restore the default value of the Keep-alive and Hold-time of the timer.
# Configure the Keep-alive timer as 120 seconds and Hold-time timer as 360 seconds.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] timer keepalive 120 hold 360
5.1.65 undo synchronization
View
BGP view
None
Use the undo synchronization command to cancel the synchronization of BGP and IGP.
By default, BGP does not synchronize with IGP.
This command means BGP does not synchronize with IGP in current system. You need not configure it because the S7500 series do not support synchronization of BGP and IGP at present.
# Cancel the synchronization of BGP and IGP.
<H3C>system-view
[H3C] bgp 100
[H3C-bgp] undo synchronization
Chapter 6 IP Routing Policy Configuration Commands
& Note:
The term “router” in this document refers to a router in a generic sense or an Ethernet switch running routing protocols.
6.1 IP Routing Policy Configuration Commands
6.1.1 apply as-path
undo apply as-path
View
Route policy view
as-number-list: AS number list, in the form of as-number&<1-10>. Here, as-number is an AS number, which ranges from 1 to 65535, and &<1-10> means you can input 1 to 10 AS numbers in one command.
Use the apply as-path command to add an AS number before the original AS path in a route-policy.
Use the undo apply as-path command to remove the added AS number.
By default, AS number is not set.
If the route-policy matching conditions are met, AS attributes of the routes to be advertised will be changed by the apply as-path command. A maximum of ten AS numbers can be added.
# Add AS number 200 before the original AS path
<H3C> system-view
[H3C] route-policy 10 permit node 10
[H3C-route-policy] apply as-path 200
6.1.2 apply community
apply community { none | [ aa:nn | no-export-subconfed | no-export | no-advertise ]* [ additive ] }
undo apply community
View
Route policy view
none: Specifies no community attribute.
aa:nn: Community number. The value ranges of aa and nn are both from 1 to 65535.
no-export-subconfed: Specifies not to advertise matched routes out of the specified sub AS.
no-advertise: Specifies not to advertise matched routes to any peer entities.
no-export: Specifies not to advertise routes out of the specified sub AS or federation, but to send to other sub ASs in the federation.
additive: Specifies community attributes of additional routes.
Use the apply community command to set BGP community attributes in a route-policy.
Use the undo apply community command to remove the setting.
By default, BGP community attributes are not set.
If the route-policy matching conditions are met, BGP community attributes will be changed by the apply community command.
Related commands: ip community-list, if-match community-list, route-policy, display bgp routing-table community.
# Create a route-policy named setcommunity and set its node sequence number as 16 and match mode as permit. Enter route policy view and set matching conditions and the actions to be executed after the matching conditions are met.
<H3C> system-view
[H3C] route-policy setcommunity permit node 16
[H3C-route-policy] if-match as-path 8
[H3C-route-policy] apply community no-export
6.1.3 apply cost
apply cost value
undo apply cost
View
Route policy view
value: Cost value of a route. The value ranges from 0 to 4,294,967,295.
Use the apply cost command to configure the cost of a route.
Use the undo apply cost command to cancel the apply clause.
By default, no apply clause is defined.
This command is one of the apply clauses of a route-policy used to set the cost of the route passing the filtering.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip next-hop, apply local-preference, apply origin, apply tag.
# Define an apply clause to set the cost of a route to 120.
<H3C> system-view
[H3C] route-policy policy_10 permit node 12
%New sequence of this list
[H3C-route-policy] apply cost 120
6.1.4 apply cost-type
apply cost-type [ internal | external ]
undo apply cost-type
View
Route policy view
internal: In BGP, specifies to use IGP cost as BGP MED when BGP peer entity advertises routes to EBGP peer entity; in IS-IS, specifies to use only for IS-IS as an internal cost.
External: Specifies to use only for IS-IS as an external cost.
Use the apply cost-type command to set the cost type for a route.
Use the undo apply cost-type command to cancel the apply clause.
By default, cost is not set.
# Set IGP cost as BGP MED.
<H3C> system-view
[H3C-route-policy] apply cost-type internal
6.1.5 apply ip next-hop
apply ip next-hop ip-address
undo apply ip next-hop
View
Route policy view
ip-address: IP address of next hop.
Use the apply ip next-hop command to set the next hop for a route .
Use the undo apply ip next-hop command to cancel the apply clause.
By default, no next hop is defined.
This clause is one of the apply clauses of the route-policy used to set the next hop of the route passing the filtering.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply local-preference, apply cost, apply origin and apply tag.
# Define an apply clause to set the next hop of the route to 193.1.1.8.
<H3C> system-view
[H3C-route-policy] apply ip next-hop 193.1.1.8
6.1.6 apply isis
apply isis [ level-1 | level-2 | level-1-2 ]
undo apply isis
View
Route-policy view
level-1: Imports routes to level-1 area.
level-2: Imports routes to level-2 area.
level-1-2: Imports routes to both level-1 area and level-2 area.
Use the apply isis command to set the IS-IS area(s) at specified level(s) that routes will be imported to.
Use the undo apply isis command to cancel the apply clause.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply cost, apply origin, apply tag.
# Define an apply clause to import routes to level-2 area.
<H3C> system-view
[H3C-route-policy] apply isis level-2
6.1.7 apply local-preference
apply local-preference local-preference
undo apply local-preference
View
Route policy view
local-preference: local preference, ranging from 0 to 4,294,967,295.
Use the apply local-preference command to set local preference for routing information.
Use the undo apply local-preference command to cancel the apply clause.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip next-hop, apply local-preference, apply origin and apply tag.
# Define an apply clause to set local preference for routing information to 130.
<H3C> system-view
[H3C-route-policy] apply local-preference 130
6.1.8 apply origin
apply origin { igp | egp as-number | incomplete }
undo apply origin
View
Route policy view
igp: Specifies that BGP routing information source is internal route.
egp: Specifies that BGP routing information source is external route.
as-number: Autonomous system number of an external route. The value ranges from 1 to 65,535.
incomplete: Specifies that BGP routing information source is unknown.
Use the apply origin command to set BGP routing information source.
Use the undo apply origin command to cancel the apply clause.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip next-hop, apply local-preference, apply cost, apply tag.
# Define an apply clause to specify that the BGP routing information source is igp.
<H3C> system-view
[H3C]route-policy 10 permit node 10
[H3C-route-policy] apply origin igp
6.1.9 apply tag
apply tag value
undo apply tag
View
Route policy view
value: Tag value of route information, ranging from 0 to 4,294,967.295.
Use the apply tag command to set the tag area of RIP or OSPF route information.
Use the undo apply tag command to cancel the apply clause.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip next-hop, apply local-preference, apply cost, apply origin.
# Define an apply clause to set the tag area of route information to 100.
[H3C-route-policy] apply tag 100
6.1.10 display ip ip-prefix
display ip ip-prefix [ ip-prefix-name ]
View
ip-prefix-name: Name of the IP address prefix list to be displayed, a string of 1 to 19 characters.
Use the display ip ip-prefix command to display information about the specified IP address prefix list.
If ip-prefix-name is not specified, this command displays information about all IP address prefix lists.
Related commands: ip ip-prefix.
# Display information about the address prefix list named p1.
<H3C> display ip ip-prefix p1
name index conditions ip-prefix / mask GE LE
p1 10 permit 10.1.0.0/16 17 18
Table 6-1 Description on the fields of the display ip ip-prefix command
name |
Name of ip-prefix |
index |
Internal sequence number of ip-prefix |
conditions |
Mode: permit or deny |
ip-prefix / mask |
Address and mask of ip-prefix |
GE |
Threshold that ip-prefix mask is greater than or equal to |
LE |
Threshold that ip-prefix mask is less than or equal to |
6.1.11 display route-policy
display route-policy [ route-policy-name ]
View
route-policy-name: Name of the route-policy to be displayed, a string of 1 to 19 characters.
Use the display route-policy command to display information about the specified route policy.
If route-policy-name is not specified, this command displays information about all route policies.
Related commands: route-policy.
# Display information about route-policy policy1.
<H3C> display route-policy policy1
Route-policy : policy1
Permit 10 : if-match (prefixlist) p1
apply cost 100
matched : 0 denied : 0
Table 6-2 Description on the fields of the display route-policy command
Route-policy |
Name of the route policy |
Permit 10 |
Information about the route-policy with the mode configured as permit and the node as 10: |
if-match (prefixlist) p1 |
Matching conditions |
apply cost 100 |
Apply the cost of 100 to routes meeting the matching conditions set by the if-match clause |
matched |
Number of routes matching the conditions set by the if-match clause |
denied |
Number of routes not matching the conditions set by the if-match statement |
6.1.12 if-match { acl | ip-prefix }
if-match { acl acl-number | ip-prefix ip-prefix-name }
undo if-match { acl | ip-prefix }
View
Route policy view
acl-number: Number of the ACL used for filtering.
ip-prefix-name: Name of the address prefix list used for filtering, a string of to 19 characters.
Use the if-match { acl | ip-prefix } command to configure a matching rule for the route- policy and specify an IP address range.
Use the undo if-match { acl | ip-prefix } command to remove the setting.
The if-match { acl | ip-prefix } command references an ACL or a address prefix list for filtering.
Related commands: if-match interface, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip next-hop, apply cost, apply local-preference, apply origin, apply tag.
# Define an if-match clause, allowing route information filtered by route destination address through the address prefix list p1 to pass the if-match clause.
<H3C> system-view
[H3C-route-policy] if-match ip-prefix p1
6.1.13 if-match as-path
if-match as-path as-path-number
undo if-match as-path
View
Route policy view
as-path-number: AS path number, ranging from 1 to 199.
Use the if-match as-path command to match the AS path field of BGP routing information.
Use the undo if-match as-path command to remove the configuration.
By default, AS regular expression is not set for matching in the route-policy.
This clause is one of the if-match clauses of the route policy used to set AS path attributes as matching conditions to filter BGP routing information.
# Create an AS path named 2, which permits the routing information of AS 200 and AS 300. Then create a route-policy named test, and define an if-match clause quoting the definitions of AS path 2 for node 10 of the route-policy.
<H3C> system-view
[H3C] ip as-path-acl 2 permit 200:300
[H3C] route-policy test permit node 10
[H3C-route-policy] if-match as-path 2
6.1.14 if-match community
if-match community { basic-community-list-number [ whole-match ] | adv-community-list-number }
undo if-match community
View
Route policy view
basic-community-list-number: Basic community list number, ranging from 1 to 99.
adv-community-list-number: Advanced community list number, ranging from 100 to 199.
whole-match: Exact match, which means that all communities must be displayed.
Use the if-match community command to match community attributes of BGP routing information.
Use the undo if-match community command to remove the configuration.
Be default, community attributes are not set for matching.
This clause is one of the if-match clauses of the route policy used to set community attributes as matching conditions to filter BGP routing information.
Related commands: route-policy, ip community-list.
# Create a community list named 1, which permits routing information of AS 100 and AS 200. Then create a route-policy named test and define an if-match clause quoting the definitions of community list 1 for node 10 of the route-policy.
<H3C> system-view
[H3C] ip community-list 1 permit 100:200
[H3C-route-policy] if-match community 1
6.1.15 if-match cost
if-match cost value
undo if-match cost
View
Route policy view
value: Route cost value, ranging from 0 to 4,294,967,295.
Use the if-match cost command to configure a match rule for the route-policy to match the cost of routing information.
Use the undo if-match cost command to remove the configuration.
By default, no if-match clause is defined.
This clause is one of the if-match clauses of the route-policy used to specify the route cost of the routing information meeting the matching conditions.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match tag, route-policy, apply ip next-hop, apply cost, apply local-preference, apply origin, apply tag.
# Define an if-match clause, allowing the routing information with the routing cost of 8 to pass this if-match clause.
<H3C> system-view
[H3C] route-policy policy permit node 1
[H3C-route-policy] if-match cost 8
6.1.16 if-match interface
if-match interface { interface-type interface-number }
undo if-match interface
View
Route policy view
interface-type: Interface type.
interface-number: Interface number.
Use the if-match interface command to match the route whose next hop is the designated interface.
Use the undo if-match interface command to remove the configuration.
This clause is one of the if-match clauses of the route-policy used to match the interface corresponding to the next hop of the route.
Related commands: if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply ip next-hop, apply cost, apply local-preference, apply origin, apply tag.
# Define an if-match clause to match the route whose next hop interface is VLAN-interface 1.
<H3C> system-view
[H3C-route-policy] if-match interface Vlan-interface 1
6.1.17 if-match ip next-hop
if-match ip next-hop { acl acl-number | ip-prefix ip-prefix-name }
undo if-match ip next-hop [ ip-prefix ]
View
Route policy view
acl-number: Number of the ACL used for filtering, ranging from 2,000 to 2,999.
ip-prefix-name: Name of the prefix address list used for filtering.
Use the if-match ip next-hop command to configure a match rule for the route-policy to match the next hop address of routing information.
Use the undo if-match ip next-hop command to remove the configuration of using an ACL to match the next hop address of routing information.
Use the undo if-match ip next-hop ip-prefix command to remove the configuration of using an ip-prefix list to match the next hop address of routing information.
This clause is one of the if-match clauses of the route-policy used to specify the next hop address matching the routing information. It performs filter by referencing an ACL or an ip-prefix list.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match cost, if-match tag, route-policy, apply ip next-hop, apply cost, apply local-preference, apply origin, apply tag.
# Define an if-match clause. It permits the routing information whose next hop address filtered through ip-prefix list p1 to pass this if-match clause.
<H3C> system-view
[H3C-route-policy] if-match ip next-hop ip-prefix p1
6.1.18 if-match tag
if-match tag value
undo if-match tag
View
Route policy view
value: Tag field value, ranging from 0 to 4,294,967,295.
Use the if-match tag command to match the tag field of routing information.
Use the undo if-match tag command to remove the matching rule.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, route-policy, apply ip next-hop, apply cost, apply local-preference, apply origin, apply tag.
# Define an if-match clause. It permits the OSPF route information whose tag value is 8 to pass the if-match clause.
<H3C> system-view
[H3C-route-policy] if-match tag 8
6.1.19 ip as-path-acl
ip as-path-acl acl-number { permit | deny } as-regular-expression
undo ip as-path-acl acl-number
View
acl-number: AS path list number, ranging from 1 to 199.
as-regular-expression: AS path regular expression.
Use the ip as-path-acl command to configure an AS regular expression.
Use the undo ip as-path-acl command to remove the configuration.
The defined AS path list can be used in BGP policy.
Related commands: peer as-path-acl, display bgp routing-table as-path-acl.
# Configure an AS path list
<H3C> system-view
[H3C] ip as-path-acl 10 permit 200,300
6.1.20 ip community-list
ip community-list basic-comm-list-number { permit | deny } [ aa:nn | internet | no-export-subconfed | no-advertise | no-export ]*
ip community-list adv-comm-list-number { permit | deny } comm-regular-expression
undo ip community-list { basic-comm-list-number | adv-comm-list-number }
View
basic-comm-list-number: Basic community list number, ranging from 1 to 99.
adv-comm-list-number: Advanced community list number, ranging from 100 to 199.
permit: Specifies to allow access to matching conditions.
deny: Specifies to deny access to matching conditions.
aa:nn: Community number. The value ranges of aa and nn are both from 1 to 65,535.
internet: Specifies to advertise all routes.
no-export-subconfed: Specifies not to send matched routes out of the specified sub AS.
no-advertise: Specifies not to send matched routes to any peer entities.
no-export: Specifies not to send routes out of the specified sub AS or a federation but to send to the other sub ASs in the federation.
comm-regular-expression: Community attribute in regular expression form.
Use the ip community-list command to set a BGP community list.
Use the undo ip community-list command to remove the configuration.
The defined community list can be used in BGP policy.
Related commands: apply community, display bgp routing-table community-list.
# Define a community list, and specify not to send the routes with the community attributes out of the local autonomous system.
<H3C> system-view
[H3C] ip community-list 6 permit no-export-subconfed
6.1.21 ip ip-prefix
ip ip-prefix ip-prefix-name [ index index-number ] { permit | deny } network len [ greater-equal greater-equal | less-equal less-equal ] *
undo ip ip-prefix ip-prefix-name [ index index-number | permit | deny ]
View
ip-prefix-name: Name of the ip-prefix list, a string of 1 to 19 characters. It identifies an ip-prefix list uniquely.
index-number: Identifier of an item in the ip-prefix list. The item with a smaller index-number will be tested first.
permit: Specifies the match mode of the defined ip-prefix list items as permit mode. If the permit mode is specified and the IP address to be filtered is in the ip-prefix range specified by the item, the item is filtered through and the next item is not tested. If the IP address to be filtered is not in the ip-prefix range specified by the item, the next item is tested
deny: Specifies the match mode of the defined ip-prefix list items as deny mode. If the deny mode is specified and the IP address to be filtered is in the ip-prefix range specified by the item, the item is not filtered through and the next item is not tested; otherwise, the next item is tested.
network: IP address prefix range (IP address). 0.0.0.0 0 means all IP addresses are matched.
len: IP address prefix range (mask length). 0.0.0.0 0 means all IP addresses are matched.
greater-equal, less-equal: Address prefix range [greater-equal, less-equal] to be matched after the network len has been matched. The meaning of greater-equal is "greater than and equal to" , and the meaning of less-equal is "less than and equal to". The range is len <= greater-equal <= less-equal <= 32. When only greater-equal is used, it denotes the prefix range [greater-equal, 32]. When only less-equal is used, it denotes the prefix range [len, less-equal].
Use the ip ip-prefix command to configure an ip-prefix list or one of its items.
Use the undo ip ip-prefix command to remove an ip-prefix list or one of its items.
An ip-prefix list is used for IP address filtering. An ip-prefix list may contain several items, and each item specifies one address prefix range. The inter-item filtering relation is "OR". That is, passing an item means filtering through this ip-prefix list. Passing no item means not filtering through this ip-prefix list.
The address prefix range may contain two parts, which are determined by len and [greater-equal, less-equal], respectively. If the prefix ranges of these two parts are both specified, the IP address to be filtered must match the prefix ranges of these two parts.
If you specify network len as 0.0.0.0 0, this command matches the default route only.
# Define an ip-prefix named p1 to permit only the routes whose mask lengths are 17 or 18 on network segment 10.0.192.0 8 to pass.
<H3C> system-view
[H3C] ip ip-prefix p1 permit 10.0.192.0 8 greater-equal 17 less-equal 18
6.1.22 route-policy
route-policy route-policy-name { permit | deny } node { node-number }
undo route-policy route-policy-name [ permit | deny | node node-number ]
View
route-policy-name: Name of the route-policy, a string of 1 to 19 characters. It identifies a route-policy uniquely.
permit: Specifies the match mode of the nodes in the defined route-policy as permit mode. When a route meets all the if-match clauses of a node, the system executes the apply clauses of the node but does not perform the match test of the next node. If not, the system goes on the match test against the next node.
deny: Specifies the match mode of the nodes in the defined route-policy as deny mode. When a route meets all the if-match clauses of a node, the system considers that the route fails to pass through the node and does not take the match test of the next node.
node: Specifies a node of the route-policy.
node-number: Index of the node in the route-policy. When this route-policy is used for filtering routing information, the node with smaller node-number will be tested first.
Use the route-policy command to create a route-policy and enter route-policy view.
Use the undo route-policy command to delete the created route-policy.
By default, no route-policy is defined.
Route policies are used for route information filtering or policy routing. A route-policy comprises multiple nodes and each node comprises some if-match clauses and apply clauses.
An if-match clause defines match rules of a node. An apply clause defines the actions to be taken after a route passes the match test of a node. The filtering relationship between the if-match clauses of the node is "and". That is, all if-match clauses of a node must be met.
The filtering relation between nodes of a route-policy is "OR". That is, passing the filter of one node means passing the filter of the route-policy.
Related commands: if-match interface, if-match acl, if-match ip-prefix, if-match ip next-hop, if-match cost, if-match tag, apply ip next-hop, apply local-preference, apply cost, apply origin, apply tag.
# Configure a route-policy named policy_10, with the node number of 12 and the match mode of permit, and enter route-policy view.
<H3C>system-view
[H3C]route-policy policy_10 permit node 12
[H3C-route-policy]
Chapter 7 Route Capacity Configuration Commands
& Note:
7.1 Route Capacity Configuration Commands
7.1.1 display memory
display memory [ slot slotnumber ]
View
slotnumber: Number of the slot whose route capacity information is displayed.
Use the display memory command to display the memory setting.
# Display the current memory setting of the switch.
<H3C> display memory
System Total Memory(bytes): 203563008
Total Used Memory(bytes): 77852012
Used Rate: 38%
The following table shows describes the fields of the command:
Table 7-1 Description on the fields of the display memory command
System Total Memory(bytes) |
Total memory size (in bytes) of the switch |
Total Used Memory(bytes) |
Occupied memory size (in bytes) of the switch |
Used Rate |
Memory occupation rate |
7.1.2 display memory limit
View
None
Use the display memory limit command to display the memory setting and status information related to route capacity.
This command displays the current configuration information, free memory, and status information about connections, such as times of disconnection, times of reconnection, and whether the current status is emergent.
# Display the current memory setting and status information.
<H3C> display memory limit
Current memory limit configuration information:
system memory safety: 40 (MBytes)
system memory limit: 30 (MBytes)
auto-establish enabled
Free Memory: 125705152 (Bytes)
The state information about connection:
The times of disconnect: 0
The times of reconnect: 0
The current state: Normal
The information displayed above includes Ethernet switch memory limit, size of free memory, times of disconnection, times of reconnection, and the current status.
The following table describes the fields of the command:
Table 7-2 Description on the fields of the display memory limit command
system memory safety |
system memory limit |
Lower limit of the switch memory |
auto-establish enabled |
Automatic connection recovery is enabled (If automatic connection recovery is disabled, "auto-establish disabled" is displayed) |
Free Memory |
Size of the current free memory in bytes |
The times of disconnect: 0 |
The times of disconnection of the routing protocol is 0. |
The times of reconnect: 0 |
The times of reconnection of the routing protocol is 0. |
The current state: Normal |
The current status is normal (If the current status is emergent, "Exigence" is displayed). |
7.1.3 memory auto-establish disable
View
None
Use the memory auto-establish disable command to disable the automatic recovery of routing protocol connections (even if the free memory recovers to the safety value).
By default, when the free memory of a switch recovers to the safety value, connections of all the routing protocols will always recover (when the free memory of the switch decreases to a lower limit, the connections will be disconnected forcibly).
After this command is used, connections of all the routing protocols will not recover when the free memory of the switch recovers to a safety value. In this case, you need to restart the routing protocol to recover the connections.
Use this command with caution.
Related commands: memory auto-establish enable, memory { safety | limit }, display memory limit.
# Disable automatic recovery of the routing protocol connections when the free memory of the current switch recovers.
<H3C> system-view
[H3C] memory auto-establish disable
7.1.4 memory auto-establish enable
View
None
Use the memory auto-establish enable command to enable automatic recovery of routing protocol connections when the free memory of the switch recovers to the specified value.
You can use the memory auto-establish disable command to disable the automatic recovery function, and use the memory auto-establish enable command to re-enable the function.
By default, this function is enabled.
Related commands: memory auto-establish disable, memory { safety | limit }, display memory limit.
# Enable automatic recovery of the connections of all the routing protocols when the free memory of the current switch recovers.
<H3C> system-view
[H3C] memory auto-establish enable
7.1.5 memory { safety | limit }*
memory { safety safety-value | limit limit-value }*
undo memory [ safety | limit ]
View
safety-value: Safety value of the switch free memory, in Mbytes. Its value range depends on the free memory of the current switch.
limit-value: Lower limit of the switch free memory, in Mbytes. Its value range depends on the free memory of the current switch.
Use the memory limit limit-value command to configure the lower limit of the switch free memory.
When the free memory of a switch is less than the specified value, all the routing protocol connections will be disconnected forcibly. The limit-value argument in the command must be less than the current free memory safety value; otherwise, the configuration fails.
Use the memory safety safety-value command to configure the safety value of the switch free memory.
If you use the memory auto-establish enable command (the default configuration), the routing protocol connection that has been forcibly disconnected automatically recovers when the free memory of the switch reaches this value. The safety-value argument in the command must be greater than the current free memory lower limit; otherwise, the configuration fails.
Use the memory safety safety-value limit limit-value command to change both the safety value and lower limit of the switch free memory. The value of safety-value must be greater than that of limit-value; otherwise, the configuration fails.
Use the undo memory command to restore the default safety value and lower limit of the switch free memory.
Related commands: memory auto-establish disable, memory auto-establish enable, display memory limit.
# Set the lower limit of the switch free memory to 2 MB and the safety value to 4 MB.
<H3C> system-view
[H3C] memory safety 4 limit 2
