- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 34-FTP and TFTP Commands | 137 KB |
Chapter 1 FTP and TFTP Configuration Commands
1.1 FTP Server Configuration Commands
1.2 FTP Client Configuration Commands
1.3 TFTP Configuration Commands
1.1.1 display ftp-server
display ftp-server
View
None
Use the display ftp-server command to display the FTP server-related settings of a switch when it functions as an FTP server.
You can use this command to verify FTP server-related configurations.
# Display the FTP server-related settings of the switch (assuming that the switch is functioning as an FTP server).
FTP server is running
Max user number 1
User count 0
Timeout value(in minute) 30
Table 1-1 Description on the fields of the display ftp-server command
FTP server is running |
The FTP server is started. |
Max user number |
Maximum number of simultaneous login users supported |
User count |
Current login user quantity |
Timeout value (in minute) |
Connection idle time |
1.1.2 display ftp-user
display ftp-user
View
None
Use the display ftp-user command to display the settings of the current FTP user, including the user name, host IP address, port number, connection idle time, and work directory.
# Display FTP user settings.
<H3C> display ftp-user
Username Host IP Port Idle Homedir
H3C 10.110.3.5 1074 2 flash:/H3C
# If the user name exceeds ten characters in length, characters behind the tenth will be displayed in a new line in the flush-left mode. Take username username@test for example, the result is:
username@t 10.110.3.5 1074 2 flash:/H3C
est
1.1.3 ftp server enable
ftp sever enable
undo ftp sever
View
None
Use the ftp server enable command to enable the FTP server for users to log in.
Use the undo ftp server command to disable the FTP server.
By default, the FTP server is disabled to avoid potential security risks.
# Enable the FTP server.
[H3C] ftp server enable
% Start FTP server
1.1.4 ftp timeout
ftp timeout minutes
undo ftp timeout
View
minutes: Connection idle time (in minutes) ranging from 1 to 35,791.
Use the ftp timeout command to set the connection idle time.
Use the undo ftp timeout command to restore the default connection idle time.
The default connection idle time is 30 minutes.
If an FTP connection between an FTP server and an FTP client breaks down abnormally and the FTP server is not informed of this timely, the FTP server keeps the connection as usual.
You can set a connection idle time, so that the FTP server considers an FTP connection to be invalid and terminates it if no data exchange occurs on it within the connection idle time.
# Set the connection idle time to 36 minutes.
[H3C] ftp timeout 36
1.2.1 ascii
ascii
View
FTP client view
None
Use the ascii command to specify that files be transferred in the ASCII mode.
By default, files are transferred in the ASCII mode.
# Enter FTP client view.
<H3C> ftp 2.2.2.2
Trying ...
Press CTRL+K to abort
Connected.
User(none):switch
Password:
230 Logged in successfully
[ftp]
# Set the mode of data transfer to the ASCII mode.
200 Type set to A.
1.2.2 binary
binary
View
FTP client view
None
Use the binary command to specify that files be transferred in the binary mode.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Set the binary mode for file transfer.
200 Type set to I.
1.2.3 bye
bye
View
FTP client view
None
Use the bye command to terminate the control connection and data connection with the remote FTP server and return to user view.
This command has the same effect as the quit command.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the connections with the remote FTP server and return to user view.
221 Server closing.
<H3C>
1.2.4 cd
cd pathname
View
FTP client view
pathname: Path name
Use the cd command to change the work directory on the remote FTP server.
Note that you can use this command to enter the authorized directories only.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Change the work directory to flash:/temp.
[ftp] cd flash:/temp
250 CWD command successful.
# Display the current work directory.
257 "flash:/temp" is current directory.
1.2.5 cdup
cdup
View
FTP client view
None
Use the cdup command to go to the upper-level directory of the current directory.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Change the work directory to the upper-level directory.
[ftp] cdup
200 CDUP command successful.
# Display the current directory.
257 "flash:" is current directory.
1.2.6 close
close
View
FTP client view
None
Use the close command to terminate an FTP connection without quitting FTP client view.
This command has the same effect as the disconnect command.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the FTP connection without quitting FTP client view.
221 Server closing.
[ftp]
1.2.7 debugging
debugging
undo debugging
View
FTP client view
None
Use the debugging command to enable system debugging.
Use the undo debugging command to disable system debugging.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Enable system debugging.
% Debug is on
1.2.8 delete
delete remotefile
View
FTP client view
remotefile: Name of the file to be deleted.
Use the delete command to delete a specified remote file.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Delete the file named temp.c.
250 DELE command successful.
1.2.9 dir
dir [ filename [ localfile ] ]
View
FTP client view
filename: Name of the file to be queried.
localfile: Name of the local file where the query result is to be saved.
Use the dir command to query specified files on a remote FTP server, or to display file information in the current directory. The output information, which includes the name, size and creation time of files, will be saved in a local file.
If you do not specify the filename argument, the information about all the files in the current directory is displayed.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the information about all the files in the current directory on the remote FTP server.
[ftp] dir
200 PORT command okay
150 File Listing Follows in ASCII mode
-rwxrwxrwx 1 noone nogroup 430585 Dec 21 2005 4.app
-rwxrwxrwx 1 noone nogroup 430585 Dec 21 2005 5.app
-rwxrwxrwx 1 noone nogroup 430585 Dec 23 2005 6. app
-rwxrwxrwx 1 noone nogroup 430585 Dec 21 2005 6. app.bak
-rwxrwxrwx 1 noone nogroup 638912 Nov 15 2005 abc.BTM
drwxrwxrwx 1 noone nogroup 0 Dec 15 2005 TEST
-rwxrwxrwx 1 noone nogroup 3212176 Jul 14 2005 21.bin
226 Transfer finished successfully.
FTP: 5346 byte(s) received in 6.782 second(s) 788.00 byte(s)/sec.
# Display the information about the file named 4.app and save the output information in the file named temp1.
-rwxrwxrwx 1 noone nogroup 430585 Dec 21 2004 4. app
FTP: 70 byte(s) received in 0.122 second(s) 573.00 byte(s)/sec.
1.2.10 disconnect
disconnect
View
FTP client view
None
Use the disconnect command to terminate an FTP connection without quitting FTP client view.
This command has the same effect as the close command.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
221 Server closing.
[ftp]
1.2.11 ftp
ftp [ cluster | ftp-server [ port-number ] ]
View
cluster: Specifies to connect to a cluster FTP server.
ftp-server: Host name or IP address of an FTP server. Note that the host name can be a string comprising 1 to 20 characters.
port-number: Port number of the FTP server, ranging from 0 to 65,535. The default is 21.
Use the ftp command to establish a control connection with an FTP server and enter FTP client view.
# Connect to the FTP server whose IP address is 2.2.2.2.
Trying ...
Connected.
User(none):switch
Password:
[ftp]
1.2.12 get
get remotefile [ localfile ]
View
FTP client view
remotefile: Name of a file on an FTP server.
localfile: Name of a local file.
Use the get command to download a remote file and save it as a local file.
If you do not specify the localfile argument, the downloaded file is saved using its original name.
Caution:
When using the get command to download files from a remote FTP server, make sure the number of the characters contained in the path and file name is within the system-acceptable range.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Download the file named temp.c.
200 Port command okay.
150 Opening ASCII mode data connection for temp.c.
...226 Transfer complete.
FTP: 2162 byte(s) received in 4.163 second(s) 519.33 byte(s)/sec.
1.2.13 lcd
lcd
View
FTP client view
None
Use the lcd command to display the local work directory on the FTP client.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the local work directory.
% Local directory now flash:/temp
1.2.14 ls
ls [ remotefile [ localfile ] ]
View
FTP client view
remotefile: Name of the remote file to be queried.
localfile: Name of the local file where the querying result is to be saved.
Use the ls command to display the name of a specified file on a remote FTP server.
If you do not specify the remotefile argument, the names of all the files in the current remote directory are displayed.
Caution:
The ls command can only be used to display file names, while the dir command can be used to display file information in detail, including file size, and creation date.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the names of all the files in the current directory on the remote FTP server.
150 Opening ASCII mode data connection for *.
s7500.app
test.cfg
s7500-1.app
another.bat
test
default.diag
FTP: 189 byte(s) received in 0.011 second(s) 17.18Kbyte(s)/sec.
1.2.15 mkdir
mkdir pathname
View
FTP client view
Pathname: Name of the directory to be created.
Use the mkdir command to create a directory on an FTP server.
This command is available only to the FTP clients that are authorized to create directories on FTP servers.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Create the directory flash:/lanswitch on the FTP server.
257 "flash:/ lanswitch" new directory created.
1.2.16 open
open { ip-address | server-name } [ port ]
View
FTP client view
ip-address: IP address of an FTP server.
server-name: Host name of the FTP server, a string comprising 1 to 20 characters.
port: Port number on the remote FTP server, ranging from 0 to 65,535. The default value is 21.
Use the open command to establish a control connection with an FTP server.
Related commands: close.
<H3C> ftp
[ftp]
# Establish a control connection with the FTP server whose IP address is 1.1.1.1.
Trying ...
Connected.
220-
User(none):abc
Password:
1.2.17 passive
passive
undo passive
View
FTP client view
None
Use the passive command to set the data transfer mode to the passive mode.
Use the undo passive command to set the data transfer mode to the active mode.
By default, the passive mode is adopted.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Set the data transfer mode to the passive mode.
% Passive is on
1.2.18 put
put localfile [ remotefile ]
View
FTP client view
localfile: Name of a local file to be uploaded.
remotefile: File name which the local file is to be saved as.
Use the put command to upload a local file to an FTP server.
If you do not specify the remotefile argument, the local file is saved on the FTP server using the original name.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Upload the local file named temp.c to the FTP server.
150 Opening ASCII mode data connection for config.cfg.
Operation may take a long time, please wait...
FTP: 2162 byte(s) sent in 12.115 second(s) 178.45byte(s)/sec.
1.2.19 pwd
pwd
View
FTP client view
None
Use the pwd command to display the work directory on an FTP server.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the work directory on the FTP server.
1.2.20 quit
View
FTP client view
None
Use the quit command to terminate an FTP connection and return to user view.
This command has the same effect as the bye command.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the FTP connection and return to user view.
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye
<H3C>
1.2.21 remotehelp
remotehelp [ protocol-command ]
View
FTP client view
protocol-command: FTP protocol command.
Use the remotehelp command to display the on-line help of an FTP protocol command.
This command works only when the FTP server provides the on-line help information about FTP protocol commands.
Caution:
l This command is always valid when a H3C switch functions as an FTP server.
l If you use other FTP server software, refer to related instructions to see whether it provides on-line help information about FTP protocol commands.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the syntax of the user command.
214 Syntax: USER <sp> <username>
1.2.22 rmdir
rmdir pathname
View
FTP client view
pathname: Name of a directory on an FTP server.
Use the rmdir command to remove a specified directory on an FTP server.
Note that you can only use this command to remove directories that are empty.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Remove the directory flash:/temp1 on the FTP server (Assume that the directory is empty).
200 RMD command successful.
1.2.23 user
user username [ password ]
View
FTP client view
username: Name of the login user.
password: Password corresponding to the user.
Use the user command to switch to a specified user.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Switch to the user named tom, assuming that the corresponding password is 111.
1.2.24 verbose
verbose
undo verbose
View
FTP client view
None
Use the verbose command to enable the verbose function, which displays the execution and response information of a command.
Use the undo verbose command to disable the verbose function.
The verbose function is enabled by default.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Enable the verbose function.
% Verbose is on
1.3.1 tftp get
tftp { cluster | tftp-server } get source-file [ dest-file ]
View
tftp-server: IP address or host name of a TFTP server.
source-file: Name of the file to be downloaded from the TFTP server.
dest-file: File name which the downloaded file is to be saved as.
Use the tftp get command to download a file from a TFTP server to the local switch.
Related commands: tftp put.
# Download the file named abc.txt from the TFTP server whose IP address is 1.1.1.1 and save it as efg.txt.
<H3C> tftp 1.1.1.1 get abc.txt efg.txt
File will be transferred in binary mode.
Downloading file from remote tftp server, please wait......
TFTP: 35 bytes received in 0 second(s).
File downloaded successfully.
1.3.2 tftp put
tftp { cluster | tftp-server } put source-file [ dest-file ]
View
source-file: Name of the file to be uploaded to the TFTP server.
dest-file: File name which the uploaded file is to be saved as.
Use the tftp put command to upload a file from an Ethernet switch to a specified directory on a TFTP server.
Related commands: tftp get.
# Upload the file named config.cfg to the TFTP server whose IP address is 1.1.1.1 and save it as temp.cfg.
<H3C> tftp 1.1.1.1 put config.cfg temp.cfg
Copying file to remote tftp server. Please wait... /
TFTP: 962 bytes sent in 0 second(s).
File uploaded successfully.
1.3.3 tftp-server acl
tftp-server acl acl-number
undo tftp-server acl
View
acl-number: Basic ACL number ranging from 2,000 to 2,999.
Use the tftp-server acl command to specify the ACL adopted for the connection between a TFTP client and a TFTP server.
Use the undo tftp-server acl command to cancel all the ACLs adopted.
# Adopt ACL 2000 on the TFTP client.
<H3C> system-view
[H3C] tftp-server acl 2000
