- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 00-1Cover | 87 KB |
H3C S7500 Series Ethernet Switches |
Command Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08193F-20070720-C-1.04 Product Version: Release 3100 Series |
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S7500 Series Ethernet Switches documentation set includes the following:
Manual |
H3C S7500 Series Ethernet Switches Operation Manual |
It is used for assisting the users in data configurations and typical applications. |
H3C S7500 Series Ethernet Switches Installation Manual |
It provides information for the system installation. |
Organization
H3C S7500 Series Ethernet Switches Command Manual is organized as follows:
Part |
Contents |
1 CLI |
Introduces the commands used for switching between the command levels and command level setting. |
2 Login |
Introduces the commands used for logging into the Ethernet switch. |
3 Configuration File Management |
Introduces the commands used for configuration file management. |
4 VLAN |
Introduces the commands used for configuring VLAN. |
5 Extended VLAN Application |
Introduces the commands used for configuring voice VLAN, isolate-user-VLAN, and super VLAN. |
6 IP Address-IP Performance-IPX |
Introduces the commands used for IP address configuration, IP performance configuration, and IPX configuration. |
7 GVRP |
Introduces the commands used for GVRP configuration. |
8 QinQ |
Introduces the commands used for QinQ and selective QinQ configuration. |
9 Port Basic Configuration |
Introduces the commands used for basic port configuration. |
10 Link Aggregation |
Introduces the commands used for link aggregation. |
11 Port Isolation |
Introduces the commands used for port isolation. |
12 Port Binding |
Introduces the commands used for port binding. |
13 DLDP |
Introduces the commands used for DLDP configuration. |
14 MAC Address Table |
Introduces the commands used for MAC address forwarding table management. |
15 MSTP |
Introduces the STP-related commands and VLAN-VPN tunnel-related commands. |
16 Routing Protocol |
Introduces the commands used for routing protocol configuration. |
17 Multicast |
Introduces the commands used for multicast configuration. |
18 802.1x |
Introduces the commands used for 802.1x and HABP configuration. |
19 AAA-RADIUS-HWTACACS-EAD |
Introduces the commands used for AAA, RADIUS, HWTACACS, and EAD configuration. |
20 Traffic Accounting |
Introduces the commands used for traffic accounting. |
21 VRRP-HA |
Introduces the commands used for VRRP and HA configuration. |
22 ARP |
Introduces the ARP-related commands. |
23 DHCP |
Introduces the DHCP-related commands. |
24 ACL |
Introduces the ACL-related commands. |
25 QoS |
Introduces the commands used for QoS configuration. |
26 Mirroring |
Introduces the commands used for port mirroring. |
27 Cluster |
Introduces the commands used for cluster management. |
28 PoE |
Introduces the commands used for PoE configuration. |
29 UDP-Helper |
Introduces the commands used for UDP Helper configuration. |
30 SNMP-RMON |
Introduces the commands used for SNMP and RMON configuration. |
31 NTP |
Introduces the NTP-related commands. |
32 SSH Terminal Service |
Introduces the commands used for SSH and SFTP configuration. |
33 File System Management |
Introduces the commands used for file system management. |
34 FTP and TFTP |
Introduces the FTP-/TFTP-related commands. |
35 Information Center |
Introduces the commands used for information center configuration. |
36 DNS |
Introduces the DNS-related commands. |
37 System Maintenance and Debugging |
Introduces the commands used for system maintenance and debugging. |
38 HWPing |
Introduces the commands used for HWPing configuration. |
39 RRPP |
Introduces the RRPP-related commands. |
40 NAT-Netstream-Policy Routing |
Introduces the commands used for NAT, Netstream, and policy-based routing. |
41 Telnet Protection |
Introduces the commands used for Telnet securing. |
42 Hardware-Dependent Software Configuration |
Introduces the commands concerning hardware-dependent software. |
43 Appendix |
Lists all the commands described in this manual in alphabetic order. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
