- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 01-CLI Commands | 37 KB |
Chapter 1 CLI Configuration Commands
1.1 CLI Configuration Commands
1.1.1 command-privilege level
command-privilege level level view view command
undo command-privilege view view command
View
level: Command Level. This argument ranges from 0 to 3.
view: Command view. This argument can be any command view the switch supports.
command: Command to be specified.
Use the command-privilege level command to set the level of the specified command in a specified view.
Use the undo command-privilege view command to restore the level of the specified command in the specified view to the default.
Commands fall into four command levels: visit, monitor, system, and manage, which are identified as 0, 1, 2, and 3 respectively. The administrator can change the level of a command to enable users of the specific level to utilize the command.
By default, the ping, tracert, and telnet commands are at the visit level (level 0); the display and debugging commands are at the monitor level (level 1); all configuration commands are at the system level (level 2); and FTP/TFTP/XModem and file system related commands are at the manage level (level 3).
# Specify the interface command in system view to be of level 0.
<H3C> system-view
[H3C] command-privilege level 0 view system interface
1.1.2 display history-command
View
None
Use the display history-command command to display history commands. All the history commands are saved in the history command cache. When the history command cache is full, the old information in it will be overwritten.
Related commands: history-command max-size.
# Display history commands.
<H3C> display history-command
1.1.3 super
super [ level ]
View
level: User level. This argument ranges from 0 to 3 and defaults to 3. If you execute this command with the level argument not provided, this command switches the current user level to level 3.
Use the super command to switch the current user level to the one identified by the level argument. If a password is previously set by using the super password [ level level ] { simple | cipher } password command, you need to provide the password as well to switch to the higher user level. You will remain in the original user level if you fail to provide the correct password.
Note that:
l Users logging into a switch also fall into four levels, each of which corresponds to one of the command levels. Users at a specific level can only use the commands at the same level and the commands at the lower levels.
l You can specify an AUX user to provide a password when he switches from a lower user level to a higher user level and specify the password by using the super password [ level level ] { simple | cipher } password command. With a password configured, an AUX user remains in the original user level if the password provided is incorrect when the AUX user attempts to switch to a higher user level. If the password is not configured, an AUX user can switch to a higher user level directly.
l A password is necessary for a VTY user to switch to a higher user level. You can use the super password [ level level ] { simple | cipher } password command to set the password. With the password not configured, a VTY user is prompted the message reading Password is not set and remains in the previous level.
l An AUX user or a VTY user can switch to a lower user level directly regardless of the password.
Related commands: super password.
# Switch to user level 3.
<H3C> super 3
Password:
1.1.4 super password
undo super password [ level level ]
View
level: User level. This argument ranges from 1 to 3 and defaults to 3. If you execute this command with the level argument not provided, this command sets the password for switching to level 3.
simple: Specifies to provide the password in plain text.
cipher: Specifies to provide the password in encrypted text.
password: Password to be set. If you specify the simple keyword, you can provide this argument in plain text. If you specify the cipher keyword, you can provide this argument in either encrypted text or plain text. In this case, a password containing no more than 16 characters (such as 123) is regarded to be in plain text and is converted to the corresponding 24-character encrypted form (such as 7-CZB#/YX]KQ=^Q`MAF4<1!!) automatically. You can also provide a 24-character encrypted password directly (such as 7-CZB#/YX]KQ=^Q`MAF4<1!!). In this case, you must know its corresponding plain-text password is 123.
Use the super password command to set the password for users to switch to a higher user level. To prevent unauthorized accesses, you can use this command to require users to provide the password when they switch to a higher user level. For security purposes, the password a user enters when switching to a higher user level is not displayed. A user will remain at the original user level if the user has tried three times to enter the correct password but fails to do this.
Use the undo super password command to cancel the configuration.
Note that no matter what form of the password (plain text or encrypted text) is in, the password entered for verification must be in plain text.
# Set the password for switching from the current user level to user level 3 to zbr.
<H3C> system-view
[H3C] super password level 3 simple zbr
