- H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Extended VLAN Application Commands
- 06-IP Address-IP Performance-IPX Commands
- 07-GVRP Commands
- 08-QinQ Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Commands
- 15-MSTP Commands
- 16-Routing Protocol Commands
- 17-Multicast Commands
- 18-802.1x Commands
- 19-AAA-RADIUS-HWTACACS-EAD Commands
- 20-Traffic Accounting Commands
- 21-VRRP-HA Commands
- 22-ARP Commands
- 23-DHCP Commands
- 24-ACL Commands
- 25-QoS Commands
- 26-Mirroring Commands
- 27-Cluster Commands
- 28-PoE Commands
- 29-UDP-Helper Commands
- 30-SNMP-RMON Commands
- 31-NTP Commands
- 32-SSH Terminal Service Commands
- 33-File System Management Commands
- 34-FTP and TFTP Commands
- 35-Information Center Commands
- 36-DNS Commands
- 37-System Maintenance and Debugging Commands
- 38-HWPing Commands
- 39-RRPP Commands
- 40-NAT-Netstream-Policy Routing Commands
- 41-Telnet Protection Commands
- 42-Hardware-Dependent Software Configuration Commands
- 43-Appendix
| 42-Hardware-Dependent Software Configuration Commands | 40 KB |
Chapter 1 Hardware-Dependent Software Configuration Commands
1.1 Commands for Boot ROM Upgrade with App File
1.1.3 boot boot-loader primary
1.2 Inter-Card Link State Adjustment Configuration Commands
1.3 Internal Channel Monitor Commands
1.4 Switch Chip Auto-reset Configuration Commands
1.1.1 boot bootrom default
boot bootrom default [ slot slot-number-list ]
View
slot-number-list: Specifies a slot number list of the switch. slot-number-list = { slot-number [ to slot-number ] }&<1-N>. &<1-N> means you can enter the previous parameters up to N times. For the S7506 and S7506R, N is 7; and for the S7503, N is 4.
Use the boot bootrom default command to use the current startup file to upgrade the Boot ROMs.
# Use the current startup file to upgrade the Boot ROMs of all normal service cards in position.
<H3C> boot bootrom default
1.1.2 boot bootrom file-url
boot bootrom file-url [ slot slot-number-list ]
View
file-url: Specifies the Boot ROM file path and file name in the Flash memory.
Use the boot bootrom file-url command to use the specified App file to upgrade the Boot ROMs.
# Use the specified App file (abcd.app) to upgrade the Boot ROMs of all normal service cards in position.
<H3C> boot bootrom abcd.app
boot boot-loader primary file-url
View
Use the boot boot-loader primary command to specify the primary startup file for next booting and use it to upgrade the Boot ROMs.
# Specify the App file abcd.app as the primary startup file for next booting and use it to upgrade the Boot ROMs.
<H3C> boot boot-loader primary abcd.app
1.2.1 set inlink
set inlink { auto | fix }
View
auto: Sets the inter-card links are established in the auto negotiation mode.
fix: Sets the inter-card links are established the fix mode.
Use the set inlink command to set the mode in which inter-card links are established. By default, inter-card links are established in the auto negotiation mode.
# Configure the inter-card links to be established in the fix mode.
<H3C> system-view
[H3C] set inlink fix
1.3.1 monitor inner-channel
monitor inner-channel [ reboot-lpu | reboot-switch ]
undo monitor inner-channel [ reboot-lpu | reboot-switch ]
View
reboot-lpu: Restarts a service card.
reboot-switch: Restarts a switch.
Use the monitor inner-channel command to enable the function of monitoring internal channels.
Use the undo monitor inner-channel command to disable the function of monitoring internal channels.
By default, the function of monitoring internal channels is enabled.
An internal channel refers to the interface channel between the SRPU and the service cards. The SRPU sends handshake packets to each service card every second. After receiving the handshake packets, the service cards report the result to the SRPU. In this case, the SRPU knows that the service cards are operating normally. Through this process, the SRPU can judge whether each service card in the device operates normally.
S7500 Ethernet switches support this feature. Through this feature, you can monitor internal channels.
You can also set the maximum number of times the SRPU fails to receive handshake packets. If the number of times the SRPU fails to receive handshake packets exceeds the upper limit, the switch resets the processing chip automatically. When the SRPU receives handshake packets, it resets the counter automatically.
You can also set whether to restart the service card or the switch when the number of times the SRPU fails to receive handshake packets exceeds the upper limit.
# Enable the function of monitoring internal channels
<H3C> system-view
[H3C] monitor inner-channel
1.3.2 monitor inner-channel
monitor inner-channel upper-limit upper-timers
View
upper-times: Specifies the upper limit.
Use the monitor inner-channel upper-limit command to set the maximum number of times of monitoring internal channels.
Use the undo monitor inner-channel command to disable the function of setting the maximum number of times of monitoring internal channels.
The default value is 10.
# Set the upper limit to 50.
<H3C> system-view
[H3C] monitor inner-channel upper-limit 50
1.4.1 monitor slot
monitor slot slot-id enable
monitor slot slot-id disable
View
slot-id: Slot ID. The value range depends on the products (S7502: 0 to 2; S7503: 0 to 3; S7506: 0 to 6; S7506R: 0 to 7).
Use the monitor slot enable command to enable switch chip auto-reset.
Use the monitor slot disable command to disable switch chip auto-reset.
By default, switch chips cannot be reset automatically when the internal channel handshake fails.
In actual application, a switch may fail to process services normally due to internal channel block or because the switch chip is busy.
The S7500 series switches support the function of resetting switch chips automatically. In case that the function of monitoring internal channels is enabled, when the internal channel handshake between a card and the backplane fails, the switch resets the switch chip automatically to resume the corresponding card.
When the function of resetting switch chips is disabled, even if the switch finds that the internal channel handshake fails, it cannot reset the switch chip automatically.
# Enable switch chip auto-reset for the card in slot 2.
<H3C> system-view
[H3C] monitor slot 2 enable
