- H3C Campus Switches M-LAG Configuration Guide-6W100
- 00-M-LAG network planning for campus networks
- 01-M-LAG and VRRP Configuration Example (Campus)
- 02-M-LAG + Spanning Tree Configuration Example (Campus)
- 03-Dual-Active VLAN Gateway Configuration Example (Campus)
- 04-M-LAG and Loop Detection Configuration Example (Campus)
- 05-Multi-Tier M-LAG and VRRP Configuration Example (Campus)
- 06-M-LAG + VXLAN Distributed Gateway Network Configuration Example (Ethernet Aggregate Link as Peer Link) (Campus)
- 07-M-LAG + EVPN VXLAN Centralized Gateway Network Configuration Example (Ethernet Aggregate Link as Peer Link) (Campus)
- 08-M-LAG and MPLS L3VPN Configuraion Example (Campus)
- 09-M-LAG and Mirroring Configuration Example (Campus)
| 03-Dual-Active VLAN Gateway Configuration Example (Campus) | 306.59 KB |
Example: Configuring dual-active VLAN gateways (campus)
Configuring interconnect links between the M-LAG device and Server A
Configuring Layer 3 interconnect links between the M-LAG member devices
Configuring dual-active gateways
Configuring the interconnect links between the M-LAG system and upstream Device C
Configuring the interfaces facing singlehomed devices
Configuring the interconnect links between upstream Device C and the M-LAG system
Configuring the interconnect links between upstream Device C and Network
Overlay traffic characteristics
Testing network convergence upon single points of failure
Replacing a switching fabric module
As shown in Figure 1:
· Set up an M-LAG system with Device A and Device B, and attach Server A to M-LAG interfaces on the M-LAG system.
· Configure dual-active gateways on Device A and Device B for Server A.
· Configure ECMP routes between the M-LAG system and upstream Device C.
· Attach singlehomed servers Server B and Server C to the M-LAG system. Server B is in the same subnet as Server A, and Server C is in a different subnet than Server A.
Establish network connections to meet the following requirements:
· Server A, Server B, and Server C have both IPv4 and IPv6 connectivity among them.
· Server A, Server B, and Server C have both IPv4 and IPv6 connectivity with Network.
· Service traffic is not interrupted when link failures occur on the M-LAG member devices.
IP address |
Peer device and interface |
Device A |
Loopback 0 |
3.3.3.3/32 2000::3:3:3:3/128 |
IP address of a loopback interface Router ID |
XGE 3/0/8 |
Server B |
XGE 3/0/5 |
Server A M-LAG group member interface |
XGE 3/0/4 |
32.1.1.1/24 32::1/64 |
Device C: XGE 3/0/4 |
XGE 3/0/1 |
21.1.1.1/24 |
Device B: XGE 3/0/1 Keepalive interface |
XGE 3/0/2 |
Device B: XGE 3/0/2 Member port of the peer-link interface |
XGE 3/0/3 |
Device B: XGE 3/0/3 Member port of the peer-link interface |
VLAN 100 |
100.1.1.1/24 100::1/64 |
Dual-active VLAN interface |
VLAN 101 |
101.1.1.1/24 101::1/64 |
Used for setting up a Layer 3 link between the M-LAG member devices to forward east-west traffic or south-north failover traffic. |
Device B |
Loopback 0 |
4.4.4.4/32 2000::4:4:4:4/128 |
XGE 3/0/8 |
200.1.1.1/24 200::1/64 |
Server C |
XGE 3/0/5 |
XGE 3/0/4 |
33.1.1.1/24 33::1/64 |
Device C: XGE 3/0/5 |
XGE 3/0/1 |
21.1.1.2/24 |
Device A: XGE 3/0/1 Keepalive interface |
XGE 3/0/2 |
Device A: XGE 3/0/2 Member port of the peer-link interface |
XGE 3/0/3 |
Device A: XGE 3/0/3 Member port of the peer-link interface |
VLAN 100 |
VLAN 101 |
101.1.1.2/24 101::2/64 |
Device C |
XGE 3/0/1 |
22.1.1.1/24 22::1/64 |
Network 1 |
XGE 3/0/4 |
32.1.1.2/24 32::2/64 |
Device A: XGE 3/0/4 |
XGE 3/0/5 |
33.1.1.2/24 33::2/64 |
Device B: XGE 3/0/4 |
Server A |
100.1.1.11/24 100::11/64 |
Device A: XGE 3/0/5 Device B: XGE 3/0/5 |
Server B |
100.1.1.12/24 100::12/64 |
Device A XGE 3/0/8 |
Server C |
200.1.1.11/24 200::11/64 |
Device B: XGE 3/0/8 |
Network 1 |
22.1.1.11/24 22::11/64 |
Device C: XGE 3/0/1 |
Applicable product matrix
IMPORTANT: In addition to running an applicable software version, you must also install the most recent patch, if any. |
Device |
Software version |
S10500, S10500X, S7600, S7600-X, S7600E-X, S7500X, S7500E |
R7625 and higher versions |
S12500G-AF |
S6550XE-HI, S6525XE-HI |
E8106 and higher versions |
S6520X-EI, S6520X-HI |
F6628P11 and higher versions |
S5590-HI, S5590-EI |
E8106P15 and higher versions |
S5560X-HI |
S5560X-EI |
Analysis
· Configure VLAN interfaces on Device A and Device B to provide dual-active gateway services for Server A.
· Attach Server A with two links to the M-LAG system, and specify the IP address of VLAN-interface 100 as the gateway on Server A.
· Attach Server B with one link to the M-LAG system, and specify the IP address of VLAN-interface 100 as the gateway on Server B.
· Attach Server C with one link to the M-LAG system, and specify the IP address of VLAN-interface 200 as the gateway on Server C.
· Configure ECMP routes to Device C on Device A and Device B.
· Configure Device A and Device B as OSPF and OSPFv3 neighbors to each other for them to forward traffic of singlehomed servers and back up each other.
· Configure IPv4 and IPv6 dual stack.
All parameters of the device are set to the factory default settings. If you have already configured the device, verify that the existing configuration does not conflict with the following settings.
Configuring the M-LAG system
Procedure summary
· Configuring interconnect links between the M-LAG device and Server A
· Configuring Layer 3 interconnect links between the M-LAG member devices
· Configuring dual-active gateways
· Configuring the interconnect links between the M-LAG system and upstream Device C
· Configuring the interfaces facing singlehomed devices
Setting up the M-LAG system
Device A |
Device B |
Remarks |
m-lag system-mac 2-2-2 |
Set the M-LAG system MAC address. |
You must set the same M-LAG system MAC address for devices in the same M-LAG system. |
m-lag system-number 1 |
m-lag system-number 2
Set the M-LAG system number. |
You must set different M-LAG system numbers for devices in the same M-LAG system. |
m-lag system-priority 123 |
Set the M-LAG system priority. |
You must set the same M-LAG system priority for devices in the same M-LAG system. |
m-lag standalone enable |
Enable M-LAG standalone mode. |
The M-LAG member devices might both operate with the primary role to forward traffic after the M-LAG system splits. M-LAG standalone mode helps avoid traffic forwarding issues in this multi-active situation. |
m-lag keepalive ip destination 21.1.1.2 source 21.1.1.1 |
m-lag keepalive ip destination 21.1.1.1 source 21.1.1.2 |
Configure the destination and source IP addresses of keepalive packets. |
N/A |
interface Ten-gigabitethernetE3/0/1 |
Enter the view of the keepalive interface. |
N/A |
port link-mode route |
Configure the keepalive interface to operate in Layer 3 mode. |
N/A |
ip address 21.1.1.1 24 |
ip address 21.1.1.2 24 |
Assign source IPv4 address of keepalive packets to the keepalive interface. |
N/A |
quit |
quit |
Return to system view. |
N/A |
m-lag mad exclude interface Ten-gigabitethernetE3/0/1 |
Exclude the interface used for M-LAG keepalive detection from the shutdown action by M-LAG MAD. |
N/A |
interface bridge-aggregation 1 |
Create the Layer 2 aggregate interface to be used as the peer-link interface and enter interface view. |
N/A |
link-aggregation mode dynamic |
Configure the aggregate interface to operate in dynamic mode. |
N/A |
quit |
quit |
N/A |
interface range Ten-gigabitethernetE 3/0/2 Ten-gigabitethernetE 3/0/3 |
Enter the view of physical interfaces on the peer link. |
N/A |
port link-aggregation group 1 |
Assign the physical interfaces on the peer link to the aggregation group for the peer link. |
N/A |
quit |
quit |
N/A |
Enter aggregate interface view. |
N/A |
port m-lag peer-link 1 |
Specify Bridge-Aggregation 1 as the peer-link interface. |
N/A |
undo mac-address static source-check enable |
Disable the static source check feature to avoid inter-peer link Layer 3 traffic forwarding failures. |
N/A |
quit |
quit |
N/A |
Device A |
Device B |
interface bridge-aggregation 2 |
Create an aggregate interface to connect to Server A. |
Configure the aggregation group to operate in dynamic mode. |
port m-lag group 1 |
Assign Bridge-Aggregation 2 to M-LAG group 1. |
port lacp system-priority 100 |
port lacp system-priority 101 |
Set the LACP system priority for the high-priority member port to be selected upon split brain. |
quit |
quit |
interface Ten-gigabitethernetE 3/0/5 |
Enter the view of the physical interface facing Server A. |
port link-aggregation group 2 |
Assign the interface to an aggregation group. |
quit |
quit |
Device A |
Device B |
Remarks |
router id 3.3.3.3 |
router id 4.4.4.4 |
Configure a router ID. |
N/A |
ospf 1 |
ospf 1 |
Enable OSPF. |
N/A |
import-route direct |
Redistribute direct routes.. |
N/A |
area 0 |
area 0 |
Configure area 0. |
N/A |
quit |
quit |
Return to OSPF view. |
N/A |
quit |
quit |
N/A |
ospfv3 1 |
ospfv3 1 |
Enable OSPFv3. |
N/A |
router-id 3.3.3.3 |
router-id 4.4.4.4 |
N/A |
N/A |
area 0 |
area 0 |
Configure area 0. |
N/A |
quit |
quit |
Return to OSPFv3 view. |
N/A |
quit |
quit |
N/A |
interface Loopback 0 |
Create a loopback interface. |
N/A |
ip address 3.3.3.3 255.255.255.255 |
ip address 4.4.4.4 255.255.255.255 |
Assign an IPv4 address to the loopback interface. |
N/A |
ospf 1 area 0.0.0.0 |
Enable OSPF on the loopback interface. |
N/A |
ipv6 address 2000::3:3:3:3/128 |
ipv6 address 2000::4:4:4:4/128 |
Assign an IPv6 address to the loopback interface. |
N/A |
ospfv3 1 area 0.0.0.0 |
Enable OSPFv3 on the loopback interface. |
N/A |
quit |
quit |
N/A |
vlan 101 |
vlan 101 |
Create VLAN 101. |
N/A |
quit |
quit |
N/A |
interface vlan-interface 101 |
Create VLAN-interface 101. |
ip address 101.1.1.1 255.255.255.0 |
ip address 101.1.1.2 255.255.255.0 |
Assign an IPv4 address to VLAN-interface 101. |
N/A |
Enable OSPF on the interface. |
N/A |
ipv6 address 101::1 64 |
ipv6 address 101::2 64 |
Assign an IPv6 address to VLAN-interface 101. |
N/A |
Enable OSPFv3 on the interface. |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface Vlan-interface 101 |
Exclude the VLAN interface from the shutdown action by M-LAG MAD. |
N/A |
Device A |
Device B |
Remarks |
vlan 100 |
vlan 100 |
Create VLAN 100. |
N/A |
quit |
quit |
N/A |
N/A |
port link-type trunk |
Configure Bridge-Aggregation 2 as a trunk port. |
N/A |
port trunk permit vlan 100 |
Assign the interface to VLAN 100. |
N/A |
undo port trunk permit vlan 1 |
Remove the interface from VLAN 1. |
N/A |
quit |
quit |
N/A |
interface vlan-interface 100 |
Create VLAN-interface 100. |
N/A |
ip address 100.1.1.1 24 |
Assign an IPv4 address to VLAN-interface 100. |
The IP address is used as the IPv4 dual-active gateway. |
ipv6 address 100::1 64 |
Assign an IPv6 address to VLAN-interface 100. |
The IP address is used as the IPv6 dual-active gateway. |
mac-address 0002-2222-2222 |
Assign a MAC address to VLAN-interface 100. |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface Vlan-interface100 |
Exclude VLAN-interface 100 from the shutdown action by M-LAG MAD. |
Excluded the VLAN interface of the VLAN accommodating M-LAG interfaces from the shutdown action by M-LAG MAD. This ensures correct ARP and ND entry synchronization via the VLAN interface. |
Device A |
Device B |
vlan 32 |
vlan 33 |
Create VLAN 33. |
quit |
quit |
interface Ten-gigabitethernetE 3/0/4 |
Enter Ethernet interface view. |
port access vlan 32 |
port access vlan 33 |
Assign the interface to VLAN 33. |
quit |
quit |
interface vlan-interface 32 |
interface vlan-interface 33 |
Create VLAN-interface 33. |
ip address 32.1.1.1 24 |
ip address 33.1.1.1 24 |
Assign an IPv4 address to the VLAN interface. |
ospf 1 area 0 |
ospf 1 area 0 |
ipv6 address 32::1 64 |
ipv6 address 33::1 64 |
Assign an IPv6 address to the VLAN interface. |
ospfv3 1 area 0 |
ospfv3 1 area 0 |
quit |
quit |
Device A |
Device B |
vlan 200 |
Create VLAN 200. |
quit |
interface ten-gigabitethernet 3/0/8 |
Configure the interface to which Server B and Server C are singlehomed. |
port access vlan 100 |
port access vlan 200 |
Assign the interface to VLAN 200. |
quit |
quit |
interface vlan-interface 200 |
Create VLAN-interface 200. |
ip address 200.1.1.1 24 |
ipv6 address 200::1 64 |
quit |
Configuring upstream Device C
Procedure summary
· Configuring the interconnect links between upstream Device C and the M-LAG system
· Configuring the interconnect links between upstream Device C and Network
Device C |
undo stp global enable |
Disable the spanning tree protocol globally. |
vlan 32 33 |
Create VLANs. |
Assign the interface facing Device A to VLAN 32. |
quit |
Assign the interface facing Device B to VLAN 33. |
quit |
router id 5.5.5.5 |
Configure a route ID. |
ospf 1 |
Configure OSPF to establish IPv4 connectivity between the M-LAG member devices. |
area 0 |
Configure area 0. |
quit |
quit |
ospfv3 1 |
Enable OSPFv3. |
router-id 5.5.5.5 |
Configure area 0. |
area 0 |
Configure area 0. |
quit |
quit |
interface loopback 0 |
ip address 5.5.5.5 255.255.255.255 |
ospf 1 area 0 |
ipv6 address 2000::5:5:5:5/128 |
ospfv3 1 area 0 |
quit |
Create VLAN-interface 32. |
ip address 32.1.1.2 24 |
ospf 1 area 0 |
Enable OSPF on the VLAN interface. |
ipv6 address 32::2 64 |
ospfv3 1 area 0 |
Enable OSPFv3 on the VLAN interface. |
quit |
ip address 33.1.1.2 24 |
ospf 1 area 0 |
ipv6 address 33::2 64 |
ospfv3 1 area 0 |
quit |
Device C |
vlan 22 |
Create VLAN 22. |
quit |
interface Ten-gigabitethernetE 3/0/1 |
port access vlan 22 |
Assign the interface facing the external network to VLAN 22. |
quit |
interface vlan-interface 22 |
Create VLAN-interface 22. |
ip address 22.1.1.1 24 |
ipv6 address 22::1 64 |
quit |
Traffic forwarding models
The forwarding model matrix provides the following characteristics of overlay traffic:
· No.—Traffic number in the O-X-XXX format:
¡ O—Overlay traffic.
¡ X—Protocol number, which can be 4 (IPv4) or 6 (IPv6).
¡ XXX—Traffic sequence number starting from 001.
· Traffic type—Type of overlay traffic, which can be IPv4 known unicast or IPv6 known unicast.
· Direction—Direction of overlay traffic. The value is south-north or east-west.
· Forwarding path—Nodes that overlay traffic traverses.
· Traffic simulation—Traffic simulation method. Typically, a tester is used to simulate server traffic.
· Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
· Traffic direction to firewalls/LB—Configuration used to direct traffic to firewalls and load balancers, such as PBR, M-LAG, VRRP, static routes.
Forwarding models
No. |
Traffic type |
Direction |
Forwarding path |
Traffic simulation |
Load |
Traffic direction to firewalls/LB |
Remarks |
O-4-001 |
IPv4 known unicast |
South-north |
Server A > Device A&B > Device C > Network 1 |
Tester |
Light |
N/A |
Traffic fails over via the Layer 3 link between the M-LAG member devices upon failure of an uplink interface. |
O-4-002 |
South-north |
Server B > Device A > Device C > Network 1 |
Tester |
Light |
N/A |
O-4-003 |
South-north |
Server C > Device B > Device C > Network 1 |
Tester |
Light |
N/A |
O-4-004 |
East-west |
Server A > Device A&B > Device A > Server B |
Tester |
Light |
N/A |
N/A |
O-4-005 |
East-west |
Server A > Device A&B > Device B > Server C |
Tester |
Light |
N/A |
N/A |
O-4-006 |
East-west |
Server B > Device A > Device B > Server C |
Tester |
Light |
N/A |
N/A |
O-6-001 |
IPv6 known unicast |
South-north |
Tester |
Light |
N/A |
O-6-002 |
South-north |
Server B > Device A&B > Device C > |
Tester |
Light |
N/A |
O-6-003 |
South-north |
Server C > Device A&B > Device C > |
Tester |
Light |
N/A |
O-6-004 |
East-west |
Tester |
Light |
N/A |
N/A |
O-6-005 |
East-west |
Tester |
Light |
N/A |
N/A |
O-6-006 |
East-west |
Tester |
Light |
N/A |
N/A |
Table 1 Network convergence upon single points of failure
Device |
Failure type |
Traffic interruption time |
Remarks |
Device A |
Single point of failure on M-LAG member links |
≤ 400 ms |
N/A |
Single point of failure restored on M-LAG member links |
≤ 100 ms |
N/A |
Single point of failure on uplinks |
≤ 400 ms |
N/A |
Single point of failure restored on uplinks |
≤ 100 ms |
N/A |
Peer link failure |
≤ 400 ms |
Only M-LAG interfaces are paid attention. Availability of interfaces facing single-homed devices are not ensured. |
Peer link failure restored |
≤ 400 ms |
Keepalive link failure |
0 ms |
N/A |
Keepalive link failure restored |
0 ms |
N/A |
Keepalive link and peer link failure |
≤ 4000 ms |
Keepalive link and peer link restored |
≤ 4000 ms |
M-LAG member device restart |
≤ 100 ms |
M-LAG member device restored after restart |
≤ 100 ms |
Switching fabric module failure |
≤ 100 ms |
N/A |
Switching fabric module failure restored |
≤ 100 ms |
N/A |
Commands
Verification commands
Device A |
Device B |
display m-lag summary |
Displays summary information about the peer-link interface and M-LAG interfaces. |
display m-lag keepalive |
Displays packet statistics about the M-LAG keepalive link. |
display m-lag role |
Displays M-LAG role information. |
display m-lag verbose |
Displays detailed information about the peer-link interface and M-LAG interfaces. |
Verifying that the M-LAG system is operating correctly
# Display M-LAG keepalive packet statistics and verify that the keepalive packet receive and send status is successful.
[DeviceA]disp m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 244023 s 640 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 21.1.1.2
Time: 2020/05/12 10:21:12
Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 21.1.1.2
Source IP address: 21.1.1.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
[DeviceA]
[DeviceB]display m-lag keepalive
Neighbor is alive for: 244177 s 621 ms
Sent: Successful
Time: 2020/05/11 10:23:47
Action: Accept
Destination IP address: 21.1.1.1
# Display M-LAG role information.
[DeviceA]display m-lag role
Effective role information
Factors Local Peer
Effective role Primary Secondary
Initial role None None
MAD DOWN state Yes Yes
Health level 0 0
Role priority 32768 32768
Bridge MAC b0f9-63b6-4c00 b0f9-63b6-4c09
Effective role trigger: IPL calculation
Effective role reason: Bridge MAC
Configured role information
Factors Local Peer
Configured role Primary Secondary
[DeviceA]
[DeviceB]display m-lag role
Factors Local Peer
Effective role Secondary Primary
Health level 0 0
Bridge MAC b0f9-63b6-4c09 b0f9-63b6-4c00
Factors Local Peer
Configured role Secondary Primary
# Display detailed information about the peer-link interface and M-LAG interfaces.
[DeviceA]display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
PeerLink: BAGG1
PeerLink state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG interface M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG2 1 UP UP -
[DeviceA]
[DeviceA]display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): TE3/0/2 (2), TE3/0/3 (3)
Peer Selected ports indexes: 99, 100
Peer-link interface/Peer-link interface: BAGG2/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining m-lag DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Local M-LAG interface LACP priority: Config=32768, Effective=123
Peer M-LAG interface LACP priority: Config=32768, Effective=123
Local Selected ports (index): TE3/0/5 (5)
Peer Selected ports indexes: 102
[DeviceB]display m-lag summary
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
M-LAG IF M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG2 1 UP UP -
[DeviceB]
[DeviceB]display m-lag verbose
PeerLink interface/PeerLink interface ID: BAGG1/1
State: UP
Cause: -
Local Selected ports (index): TE3/0/2 (99), TE3/0/3 (100)
Peer Selected ports indexes: 2, 3
PeerLink interface/PeerLink interface group ID: BAGG2/1
Remaining M-LAG DOWN time: -
Local Selected ports (index): TE3/0/5 (102)
Peer Selected ports indexes: 5
Verifying the routing protocols
# Display the OSPF neighbors of Device A.
[DeviceA]display ospf peer
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time State Interface
4.4.4.4 101.1.1.2 1 32 Full/BDR Vlan101
5.5.5.5 32.1.1.2 1 38 Full/DR Vlan32
# Display the OSPFv3 neighbors of Device A.
[DeviceA]display ospfv3 peer
OSPFv3 Process 1 with Router ID 3.3.3.3
Area: 0.0.0.0
Router ID Pri State Dead-Time InstID Interface
4.4.4.4 1 Full/BDR 00:00:39 0 Vlan101
5.5.5.5 1 Full/BDR 00:00:40 0 Vlan32
# Display the OSPF neighbors of Device B.
[DeviceB]display ospf peer
OSPF Process 1 with Router ID 4.4.4.4
Area: 0.0.0.0
3.3.3.3 101.1.1.1 1 33 Full/DR Vlan101
5.5.5.5 33.1.1.2 1 31 Full/DR Vlan33
# Display the OSPFv3 neighbors of Device B.
[DeviceB]display ospfv3 peer
OSPFv3 Process 1 with Router ID 4.4.4.4
Area: 0.0.0.0
3.3.3.3 1 Full/DR 00:00:36 0 Vlan101
5.5.5.5 1 Full/BDR 00:00:39 0 Vlan33
# Display the OSPF neighbors of Device C.
[DeviceC]display ospf peer
OSPF Process 1 with Router ID 5.5.5.5
Area: 0.0.0.0
3.3.3.3 32.1.1.1 1 35 Full/BDR Vlan32
4.4.4.4 33.1.1.1 1 35 Full/BDR Vlan33
# Display the OSPFv3 neighbors of Device C.
[DeviceC]display ospfv3 peer
OSPFv3 Process 1 with Router ID 5.5.5.5
Area: 0.0.0.0
3.3.3.3 1 Full/DR 00:00:38 0 Vlan32
4.4.4.4 1 Full/DR 00:00:35 0 Vlan33
Verifying connectivity among the servers and between the servers and Network
Verify that Server A and Server B have IPv4 and IPv6 connectivity between them.
Verify that Server A and Server C have IPv4 and IPv6 connectivity between them.
Verify that Server A, Server B, and Server C have IPv4 and IPv6 connectivity with Network.
Verifying connectivity among the servers and between the servers and Network in case of downlink failure on Device A or Device B
Verify that Server A, Server B, and Server C have connectivity among them and with Network after the Device A is disconnected from Server A. Transient traffic loss occurs during traffic failover.
Verify that Server A, Server B, and Server C have connectivity among them and with Network after the Device B is disconnected from Server A. Transient traffic loss occurs during traffic failover.
Verifying connectivity among the servers and between the servers and Network in case of uplink failure on Device A or Device B
Verify that Server A, Server B, and Server C have connectivity among them and with Network after the Device A is disconnected from Device C. Transient traffic loss occurs during traffic failover.
Verify that Server A, Server B, and Server C have connectivity among them and with Network after the Device B is disconnected from Device C. Transient traffic loss occurs during traffic failover.
Upgrading the devices
Checking the environment
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are available for an upgrade.
Device A |
Device B |
display device |
display device |
Displays device information. |
display boot-loader |
Displays current software images and startup software images. |
display version |
display version |
Displays system version information. |
Before you upgrade the device software, perform the following tasks:
1. Execute the display version command to view the current BootWare version and startup software version.
2. Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡ Software and hardware compatibility.
¡ Version and size of the upgrade software.
¡ Compatibility of the upgrade software with the current BootWare image and startup software image.
3. Use the release notes to verify whether the upgrade software images require a license. If licenses are required, check the system for availability of valid licenses. If no license exists on the device, first install a license. If you do not install a license, the software package will fail to be installed.
4. Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. Make sure that all MPUs in the system have sufficient storage space.
5. After Device A and Device B form an M-LAG system, perform the following tasks:
a. Check the LLDP neighbors of Device A to obtain the LLDP state information of all interfaces on Device A.
b. Manually shut down all interfaces connecting to the other devices (except the peer-link and keepalive interfaces) on Device A.
c. Switch all incoming and outgoing traffic of Device A to Device B.
6. Save the configuration on Device A, and use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. Upgrade Device A and reboot it.
7. When Device A is being rebooted, manually shut down the interfaces connecting Device B to Device A, typically the peer-link and keepalive interfaces.
8. After Device A is rebooted, bring up the interfaces that have been shut down on Device B. Wait for M-LAG to restore between Device A and Device B.
9. After Device A and Device B form a new M-LAG system again, bring up the interfaces connecting to the other devices. Wait for the traffic to restore.
For the detailed upgrade guide, see H3C Switches M-LAG System Upgrade Guide.
No special requirements are imposed on the upgrade method. Upgrade the devices based on the environment.
Estimating upgrade downtime
See "Testing network convergence upon single points of failure." The upgrade downtime of each device contains the traffic downtime for restart of one M-LAG member device and recovery from M-LAG member device restart.
Verifying the upgrade result
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are upgraded successfully.
Device A |
Device B |
display device |
display device |
display version |
display version |
Expanding the network
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are available for an expansion.
Device A |
Device B |
display device |
display device |
display version |
display version |
Adding a device to the network
1. Disconnect the device from network management systems.
2. Upgrade the software of the device as needed.
3. Preconfigure the device.
4. Connect the device to network management systems.
Estimating expansion downtime
N/A
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
Device A |
Device B |
display device |
display device |
display version |
display version |
Replacing hardware
Replacing a service module
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for a replacement.
Device A |
Device B |
display device |
display device |
display version |
display version |
Replacing hardware
Before you replace a service module, make sure the service and management traffic has switched over to other service modules that are operating correctly.
Replace the service modules online while the system is operating or power off the system before you do the replacement, depending on the evaluation of the conditions.
Estimating replacement downtime
See "Testing network convergence upon single points of failure." The replacement downtime of each device contains the downtime for single point of failure on M-LAG member links, single point of failure on uplinks, recovery from single point of failure on M-LAG member links, and recovery from single point of failure on uplinks.
Verifying the replacement result
See the commands used for environment check before the replacement.
Device A |
Device B |
display device |
display device |
display version |
display version |
Replacing hardware
Replace the switching fabric modules online while the system is operating or power off the system before you do the replacement, depending on the evaluation of the conditions.
See "Testing network convergence upon single points of failure." The replacement downtime of each device contains the downtime for switching fabric module failure and recovery from switching fabric module failure.
