H3C SecPath M9000 Multi Service Security Gateway Series Installation Guides-6W106
HomeSupportSecurityH3C SecPath M9000Install & UpgradeInstallation GuidesH3C SecPath M9000 Multi Service Security Gateway Series Installation Guides-6W106
07-Appendix A FRUs and Compatibility Matrixes
07-Appendix A FRUs and Compatibility Matrixes 66.66 KB
Appendix A  FRUs and compatibility matrixes
For compatibility between the gateway and the cards and transceiver modules, see the release notes.
MPUs
MPU is the core of the control management plane for the gateway. You can install one MPU, or two MPUs in 1+1 redundancy for the gateway. Table 1 shows the MPUs available for the M9000 gateway series.
Table 1 MPU and gateway compatibility
MPU model
Applicable gateways
NSQ1SUPB0
M9006/M9010/M9010-GM/M9014
NSQM1SUPD0
M9016-V
For more information about the MPUs, see the card manuals that come with the MPUs..
Switching fabric modules
The switching fabric modules are the core of the switching plane of the gateway. Table 2 describes the compatibility matrix between the M9000 gateways and switching fabric module models.
Table 2 Switching fabric module and gateway compatibility
Switching fabric module model
Applicable gateways
NSQ1FAB04B0
M9006
NSQ1FAB08D0
M9010
M9010-GM
M9016-V (supported in R9153P34 and later versions)
NSQ1FAB12D0
M9014
NSQM1FAB08E0
M9016-V
Service modules
The gateway supports SC service modules, FG service modules, and security situation intelligent computer node modules. The services modules available for the gateway are described in Table 3, Table 4, and Table 5.
Table 3 SC service module and gateway compatibility
SC service module model
Applicable gateways
NSQM1GMDSCA1
Network data encryption module
M9010-GM
NSQ1FWCEA0
Firewall module
M9006/M9010/M9014
Table 4 FG service module and gateway compatibility
FG service module model
Applicable gateways
NSQM1FWEFGA0
Firewall module
M9006/M9010/M9014/M9016-V
NSQM1FWDFGB0
Firewall module
NSQM1FWDFG0
Firewall module
NSQM1FWDFGA1
Firewall module
M9006/M9010/M9014
NSQM1FWDFGB1
Firewall module
NSQM1FWDFGC1
Firewall module
NSQM1FWDFGC0
Firewall module
NSQM1FWDFGD1
Firewall module
NSQM1NATDFGA0
NAT module
NSQM1NATDFGB0
NAT module
NSQM1ADEDFGA0
Application delivery engine
NSQM1AFC2000GDFGA0
Anomaly flow cleaner module
Table 5 Compatibility between other service modules and the gateway
Service module model
Applicable gateways
NSQM1SSICASK1
Security situation intelligent computer node module
M9006/M9010/M9014
NSQM1AIASKA1
Security engine module
For more information about the service modules, see the card manuals that come with the service modules.
Interface modules and interface subcards
The interface modules available for the gateway are described in Table 6.
Table 6 Interface module and gateway compatibility
Interface module model
Applicable gateways
NSQ1TGS8EA0
NSQ1GT48EA0
NSQ1GP24TXEA0
NSQ1TGX4EA0
NSQ1GP48EB0
NSQ1TGS32SF0
M9006/M9010/M9010-GM/M9014/M9016-V
NSQ1QGS4SF0
NSQ1CGC2SE0
NSQM1TGS32QSSG0
NSQM1CGQ6SH0
NSQM1CGQ4TG24SHA0
The interface subcards are installed in the slots of interface switch modules. Table 7 describes the compatibility between interface switch modules and interface subcards.
Table 7 Compatibility matrix between interface switch modules and interface subcards
Interface subcard model
Applicable interface switch modules
NSQM2TG16GP40
NSQM1MBFEA0
NSQM1CGQ20
NSQM2QG2TG8GP40
NSQM2QG2GP40
NSQM2TG8GP40
NSQM2QG4GP40
For more information about the interface modules and interface subcards, see the card manuals that come with the interface modules and interface subcards.
Interface switch modules
An interface switch module provides two subslots for installing interface subcards. Table 8 describes the compatibility between interface switch modules and interface subcards.
Table 8 Compatibility matrix between interface switch modules and subcards
Number of slots
Available subcards
Applicable gateways
NSQM1MBFEA0
2
·     NSQM2TG16GP40
·     NSQM1CGQ20 (supported only in slot 2)
·     NSQM2QG2TG8GP40
·     NSQM2QG2GP40
·     NSQM2TG8GP40
·     NSQM2QG4GP40
Air filters
CAUTION
CAUTION:
Clean air filters periodically (at least once every three months) to guarantee adequate ventilation and avoid over-temperature.
To prevent dusts from entering the chassis, you can configure air filters for the gateway as needed and install the air filters at the air inlet vents.
The gateway air filters include the M9006 air filter, the M9010 air filter, the M9010-GM air filter, the M9014 air filter, and the M9016-V air filter. Order air filters compatible with your gateway.
Transceiver modules
The gateway supports multiple types of transceiver modules. For the transceiver modules available for the ports on a card, see the card manuals.
Power supplies
The power supplies available for the gateway are described in Table 9.
Table 9 Power supply and gateway compatibility
Power supply model
Applicable gateways
PSR2500-12A-A
PSR2400-12D-A
PSR2500B-12AHD-F
M9016-V
Power cords
DC power cord
DC power cords are used for connecting the DC power supplies to the external DC power supply system.
Table 10 DC power cord specifications
DC power cord
Cable length
Cross-sectional area
0404A0E1
3 m (9.84 ft)
13 mm2(0.02 in2)
Used on the NSQM1DC2400 power supply
0404A0E2
15 m (49.21 ft)
13 mm2(0.02 in2)
AC power cord
AC power cords are used for connecting the AC power supplies to the external AC power supply system.
·     Select AC power cords according to the power of the power supply.
·     The connector type varies by country or region. Select a compliant connector type as needed.
·     For the connector types of different countries or regions, see H3C Power Cords & Cables.
Table 11 AC power cord specifications
AC power cord
Cable length
04043396
3 m (9.84 ft)
3*1.5 mm2 (0.002 in2)
Used on the NSQM1AC2500 power supply
HVDC power cord
The M9016-V gateway supports the PSR2500B-12AHD-F power supply. Table 12 describes the available power cords for the power supply.
Table 12 HVDC power cord specifications
HVDC power cord
Cable length
Cable type
0404A0RL
3 m (9.84 ft)
HVDC power cord
Used for HVDC or AC power supply
0404A0RP
3 m (9.84 ft)
PDU AC power cord
Used for AC power supply
0404A0RQ
3 m (9.84 ft)
AC power cord
