- H3C SecPath M9000 Multi Service Security Gateway Series Installation Guides-6W106
- 01-Chapter 1 Chassis views
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Gateway
- 03-Chapter 3 Logging in to the Gateway and Configuring Basic Settings
- 04-Chapter 4 Troubleshooting
- 06-Chapter 6 Replacing FRUs
- 07-Appendix A FRUs and Compatibility Matrixes
- 08-Appendix B Technical Specifications
- 09-Appendix C LEDs
- 10-Appendix D Slot arrangement and interface numbering
- 11-Appendix E Cables
- 12-Appendix F Cabling Recommendations
- 13-Appendix G Repackaging the Gateway
08-Appendix B Technical Specifications | 130.97 KB |
Appendix B Technical specifications
Weights and dimensions
Chassis
The gateway uses modular design. Its weight includes the chassis and its removable components.
Table 1 Chassis weights and dimensions
Model |
Max weight |
Height |
Width |
Depth |
M9006 |
< 85 kg (187.39 lb) |
352.8 mm (13.89 in, 8 RU) |
440 mm (17.32 in) |
660 mm (25.98 in) |
M9010/M9010-GM/M9016-V |
< 145 kg (319.66 lb) |
886.2 mm (34.89 in, 20 RU) |
440 mm (17.32 in) |
660 mm (25.98 in) |
M9014 |
< 165 kg (363.76 lb) |
797 mm (31.38 in, 18 RU) |
440 mm (17.32 in) |
660 mm (25.98 in) |
NOTE: · Rack height is measured in RUs. One RU is 44.45 mm (1.75 in). · The dimensions listed in Table 1 are for gateway chassis, excluding mounting brackets, cable management brackets, cards, and power supplies. |
Cards
Table 2 MPU weights and dimensions
MPU model |
Weight |
Height |
Width |
Depth |
NSQ1SUPB0 |
2.97 kg (6.55 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1SUPD0 |
2.97 kg (6.55 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
Table 3 Switching fabric module weights and dimensions
Switching fabric module model |
Weight |
Height |
Width |
Depth |
NSQ1FAB04B0 |
1.71 kg (3.77 lb) |
40.1 mm (1.58 in) |
255.5 mm (10.06 in) |
298.2 mm (11.74 in) |
NSQ1FAB08D0 |
2.77 kg (6.11 lb) |
40.1 mm (1.58 in) |
425 mm (16.73 in) |
298 mm (11.73 in) |
NSQ1FAB12D0 |
4.51 kg (9.94 lb) |
40.1 mm (1.58 in) |
602 mm (23.70 in) |
NSQM1FAB08E0 |
2.77 kg (6.11 lb) |
40.1 mm (1.58 in) |
425 mm (16.73 in) |
299 mm (11.77 in) |
Table 4 Service module weights and dimensions
Service module model |
Weight |
Height |
Width |
Depth |
NSQM1FWEFGA0 |
5.46 kg (12.04 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQ1FWCEA0 |
3.9 kg (8.60 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFGA1 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFGB0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFGB1 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFGC1 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFGC0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFGD1 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1FWDFG0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
352 mm (13.86 in) |
NSQM1NATDFGA0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQM1NATDFGB0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQM1ADEDFGA0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQM1SSICASK1 |
6.0 kg (13.23 lb) |
80.7 mm (3.18 in) |
399 mm (15.71 in) |
362 mm (14.25 in) |
NSQM1AIASKA1 |
6.0 kg (13.23 lb) |
80.7 mm (3.18 in) |
399 mm (15.71 in) |
362 mm (14.25 in) |
NSQM1AFC2000GDFGA0 |
4.8 kg (10.58 lb) |
40.1 mm (1.58 in) |
399.2 mm (15.72 in) |
376.8 mm (14.83 in) |
NSQM1GMDSCA1 |
3.62 kg (7.98 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
Table 5 Interface module weights and dimensions
Interface module model |
Weight |
Height |
Width |
Depth |
NSQ1TGS8EA0 |
3.43 kg (7.56 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQ1GT48EA0 |
3.31 kg (7.30 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQ1GP24TXEA0 |
3.08 kg (6.79 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQ1TGX4EA0 |
2.93 kg (6.46 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQ1GP48EB0 |
3.25 kg (7.16 lb) |
40.1 mm (1.58 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NSQ1TGS32SF0 |
3.45 kg (7.61 lb) |
40.1 mm (1.58 in) |
354.8 mm (13.97 in) |
NSQ1QGS4SF0 |
3.14 kg (6.92 lb) |
40.1 mm (1.58 in) |
NSQ1CGC2SE0 |
3.97 kg (8.75 lb) |
40.1 mm (1.58 in) |
NSQM1TGS32QSSG0 |
3.5 kg (7.72 lb) |
40.1 mm (1.58 in) |
NSQM1CGQ4TG24SHA0 |
3.58 kg (7.89 lb) |
40.1 mm (1.58 in) |
NSQM1CGQ6SH0 |
3.1 kg (6.83 lb) |
40.1 mm (1.58 in) |
Table 6 Interface switch module weights and dimensions
Interface switch module model |
Weight |
Height |
Width |
Depth |
NSQM1MBFEA0 |
2.9 kg (6.39 lb) |
40.1 mm (1.58 in) |
Table 7 Interface subcard weights and dimensions
Interface subcard model |
Weight |
Height |
Width |
Depth |
NSQM2TG16GP40 |
1.0 kg (2.20 lb) |
37.4 mm (1.47 in) |
173.5 mm (6.83 in) |
191.9 mm (7.56 in) |
NSQM1CGQ20 |
0.66 kg (1.46 lb) |
37.4 mm (1.47 in) |
NSQM2QG2TG8GP40 |
0.8 kg (1.76 lb) |
37.4 mm (1.47 in) |
NSQM2QG2GP40 |
0.7 kg (1.54 lb) |
37.4 mm (1.47 in) |
NSQM2TG8GP40 |
0.8 kg (1.76 lb) |
37.4 mm (1.47 in) |
NSQM2QG4GP40 |
0.7 kg (1.54 lb) |
37.4 mm (1.47 in) |
NOTE: Card dimensions are expressed as H x W x D: · H—Height of the front panel of the card. · W—Width of the front panel of the card. · D—Depth from the front panel of the card to the connector. |
Power supplies
Table 8 Power supply weights and dimensions
Power supply model |
Weight |
Height |
Width |
Depth |
NSQM1AC2500 |
2.5 kg (5.51 lb) |
41 mm (1.61 in) |
102 mm (4.02 in) |
410 mm (16.14 in) |
NSQM1DC2400 |
2.4 kg (5.29 lb) |
41 mm (1.61 in) |
102 mm (4.02 in) |
410 mm (16.14 in) |
Fan trays
Table 9 Fan tray weights and dimensions
Fan tray |
Weight |
Height |
Width |
Depth |
M9006 fan tray |
4.7 kg (10.36 lb) |
106.3 mm (4.19 in) |
642.8 mm (25.31 in) |
M9010/M9010-GM/M9016-V fan tray |
8.3 kg (18.30 lb) |
80 mm (3.15 in) |
440 mm (17.32 in) |
653.5 mm (25.73 in) |
M9014 upper fan tray |
4.49 kg (9.90 lb) |
84.2 mm (3.32 in) |
300.2 mm (11.82 in) |
645.8 mm (25.43 in) |
M9014 lower fan tray |
3.61 kg (7.96 lb) |
84.2 mm (3.32 in) |
299.2 mm (11.78 in) |
Module power consumption and system power consumption
Card power consumption
The power consumption of the cards depends on the card model and state. Table 10 shows the power consumption for different card models.
· The static power consumption of a card refers to the power consumed by the card when the card is running but all ports on the card are down and when no transceiver module is available on the optical interface of the card.
· The dynamic power consumption of a card refers to the power consumed by the card when all the ports on the card are link up and send broadcasts.
Table 10 MPU power consumption
MPU model |
Minimum static power consumption |
Maximum dynamic power consumption |
NSQ1SUPB0 |
45 W |
50 W |
NSQM1SUPD0 |
45 W |
50 W |
Table 11 Switching fabric module power consumption
NSQ1FAB04B0 |
48 W |
65 W |
NSQ1FAB08D0 |
101 W |
135 W |
NSQ1FAB12D0 |
195 W |
255 W |
NSQM1FAB08E0 |
101 W |
135 W |
Table 12 Service module power consumption
NSQM1FWEFGA0 |
194 W |
293 W |
NSQ1FWCEA0 |
109 W |
157 W |
NSQM1FWDFGA1 |
180 W |
260 W |
NSQM1FWDFGB0 |
180 W |
260 W |
NSQM1FWDFGB1 |
180 W |
260 W |
NSQM1FWDFGC1 |
180 W |
260 W |
NSQM1FWDFGC0 |
180 W |
260 W |
NSQM1FWDFGD1 |
180 W |
260 W |
NSQM1FWDFG0 |
180 W |
260 W |
NSQM1NATDFGA0 |
180 W |
260 W |
NSQM1NATDFGB0 |
180 W |
260 W |
NSQM1ADEDFGA0 |
180 W |
260 W |
NSQM1SSICASK1 |
128 W |
210 W |
NSQM1AIASKA1 |
128 W |
210 W |
180 W |
260 W |
NSQM1GMDSCA1 |
60 W |
66 W |
Table 13 Interface module power consumption
NSQ1TGS8EA0 |
111 W |
140 W |
NSQ1GT48EA0 |
67 W |
95 W |
NSQ1GP24TXEA0 |
54 W |
95 W |
NSQ1TGX4EA0 |
53 W |
80 W |
NSQ1GP48EB0 |
43 W |
110 W |
NSQ1TGS32SF0 |
126 W |
170 W |
NSQ1QGS4SF0 |
82 W |
100 W |
NSQ1CGC2SE0 |
163 W |
220 W |
NSQM1TGS32QSSG0 |
60 W |
147 W |
NSQM1CGQ4TG24SHA0 |
68 W |
161 W |
NSQM1CGQ6SH0 |
58 W |
138 W |
Table 14 Interface switch module power consumption
NSQM1MBFEA0 |
41 W |
62 W |
Table 15 Interface subcard power consumption
NSQM2TG16GP40 |
5 W |
15 W |
NSQM1CGQ20 |
15 W |
16 W |
NSQM2QG2TG8GP40 |
4 W |
19 W |
NSQM2QG2GP40 |
2 W |
10 W |
NSQM2TG8GP40 |
3 W |
10 W |
NSQM2QG4GP40 |
4 W |
16 W |
NOTE: The card model is printed on the card front panel. |
Fan tray power consumption
The gateway uses fans with the automatic speed adjustment function. The fan speed is automatically adjusted based on the heat dissipation condition of the gateway. The power consumed by a fan tray depends on the fan speed. Table 16 shows the power consumption of different fan trays.
Table 16 Fan tray power consumption
Model |
Minimum fan tray power consumption |
Maximum fan tray power consumption |
M9006 |
12 W |
240 W |
13 W |
329 W |
M9014 (upper fan tray) |
9 W |
200 W |
M9014 (lower fan tray) |
7 W |
124 W |
System power consumption
The system power consumption of the gateway depends on the type and number of cards and the fan tray power consumption.
· The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption.
· The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption.
For example, for an M9006 gateway that has two NSQ1SUPB0 MPUs, one NSQ1FWCEA0 service module, two NSQ1FAB04B0 switching fabric modules, and one fan tray, the minimum system power consumption of the gateway is 2 x 45 + 1 x 109 + 2 x 48 + 12=307 W, and the maximum system power consumption of the gateway is 2 × 50 + 1 × 157 + 2 × 65 + 240 = 627 W.
Cards
MPUs
You can install one MPU, or two MPUs for redundancy for the gateway. The NSQ1SUPB0 and NSQM1SUPD0 MPUs are available for the gateway. Table 17 describes the MPU specifications.
MPU model |
Item |
NSQ1SUPB0 |
Ports |
· One console port, for local or remote dialup configuration and management · One management Ethernet copper port |
Port transmission rate |
· Console port: ≤ 115200 bps (default: 9600 bps) · Management Ethernet copper port: 10/100/1000 Mbps |
Cables and max transmission distance |
· Console port: ≤ 15 m (49.21 ft) over an asynchronous serial interface cable · Management Ethernet copper port: 100 m (328.08 ft) over a Category-5 twisted pair cable |
NSQM1SUPD0 |
Ports |
Switching fabric modules
The switching fabric modules available for the gateway are described in Table 18.
Table 18 Switching fabric module specifications
Port |
Connector |
NSQM1FAB08E0 |
One console port |
RJ-45 |
NSQ1FAB04B0 |
One console port |
RJ-45 |
NSQ1FAB08D0 |
One console port |
RJ-45 |
NSQ1FAB12D0 |
One console port |
RJ-45 |
Service modules
The services modules available for the gateway are described in Table 19.
Table 19 Service module specifications
Model |
Port |
Connector |
NSQ1FWCEA0 |
Firewall module |
One console port |
RJ-45 |
Two Gigabit combo interfaces |
GE copper port |
RJ-45 |
GE fiber port |
LC |
NSQM1FWDFGA1 |
Firewall module |
One console port |
RJ-45 |
One GE copper port |
RJ-45 |
NSQM1FWDFGB0 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NSQM1FWDFGB1 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NSQM1FWDFGC1 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NSQM1FWDFGC0 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NSQM1FWDFGD1 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NSQM1FWDFG0 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NSQM1FWEFGA0 |
Firewall module |
One console port |
RJ-45 |
RJ-45 |
NAT module |
One console port |
RJ-45 |
RJ-45 |
NSQM1NATDFGB0 |
NAT module |
One console port |
RJ-45 |
RJ-45 |
Application delivery engine |
One console port |
RJ-45 |
RJ-45 |
NSQM1SSICASK1 |
Security situation intelligent computer node module |
One console port |
RJ-45 |
Three USB ports |
USB |
One VGA connector |
VGA |
One BMC port |
RJ-45 |
NSQM1AIASKA1 |
Security engine module |
One console port |
RJ-45 |
Three USB ports |
USB |
One VGA connector |
VGA |
One BMC port |
RJ-45 |
Anomaly flow cleaner module |
One console port |
RJ-45 |
RJ-45 |
NSQM1GMDSCA1 |
Network data encryption module |
One console port |
RJ-45 |
Two USB ports |
USB |
Two Gigabit combo ports (Only copper combo port 5 supports Bootware upgrade.) |
RJ-45 |
Interface modules
The interface modules available for the gateway are described in Table 20.
Table 20 Interface module specifications
Connector |
Number of ports |
Available transceiver modules |
NSQM1CGQ4TG24SHA0 |
4-port 100G Ethernet optical interface + 24-port 10G Ethernet optical Interface module |
LC |
24 |
10 Gbps |
10-Gigabit SFP+ optical transceiver module |
1000 Mbps |
Gigabit SFP optical transceiver module |
RJ-45 |
1000 Mbps |
Gigabit SFP copper transceiver module |
LC/MPO |
4 |
100/40 Gbps |
· QSFP28 optical transceiver module · QSFP+ optical transceiver module |
NSQ1TGS8EA0 |
8-port 10-Gigabit optical Ethernet interface module |
LC |
8 |
10 Gbps |
NSQ1GT48EA0 |
48-port Gigabit electrical Ethernet interface module |
RJ-45 |
48 |
10/100/1000 Mbps |
N/A |
NSQ1GP24TXEA0 |
16-port Gigabit + 8-port combo + 2-port 10-Gigabit optical Ethernet interface module |
LC |
24 |
100/1000 Mbps |
· Gigabit SFP optical transceiver module · 100-Mbps SFP optical transceiver module |
LC |
2 |
10 Gbps |
10-Gigabit XFP optical transceiver module |
RJ-45 |
8 |
10/100/1000 Mbps |
N/A |
NSQ1TGX4EA0 |
4-port 10-Gigabit optical Ethernet interface module |
LC |
4 |
10 Gbps |
NSQ1GP48EB0 |
48-port Gigabit optical Ethernet interface module |
LC |
48 |
100/1000 Mbps |
RJ-45 |
1000 Mbps |
NSQ1TGS32SF0 |
32-port 10-Gigabit optical Ethernet interface module |
LC |
32 |
10 Gbps |
NSQ1QGS4SF0 |
4-port 40-Gigabit optical Ethernet interface module |
LC/MPO |
4 |
40 Gbps |
NSQ1CGC2SE0 |
2-port 100-Gigabit CFP optical Ethernet interface module |
LC |
2 |
100/40 Gbps |
· 100-Gigabit CFP optical transceiver module · QSFP+ optical transceiver module |
32-port 10-Gigabit + 4-port 40-Gigabit optical Ethernet interface module |
LC |
32 |
10 Gbps |
LC/MPO |
4 |
40 Gbps |
NSQM1CGQ6SH0 |
6-port 100G Ethernet optical interface module |
LC/MPO |
6 |
100/40 Gbps |
NOTE: · A combo interface is a logical interface that contains one fiber port and one copper port. The two ports share one interface view and cannot work simultaneously. You can use the combo enable { copper | fiber } command to activate the fiber or copper port as needed. When you enable one of the two ports, the other port is automatically disabled. The default operating port is the copper port. · The 100G fiber ports on the gateway support 100/40 Gbps autosensing. |
Interface subcards
The subcards are installed on the subslots of the interface switch modules. The subcards available for the gateway are described in Table 21.
Table 21 Interface subcard specifications
Connector |
Number of ports |
NSQM2TG16GP40 |
16-port 10G Ethernet optical + 4-port GE optical interface module |
LC |
4 |
1 Gbps |
16 |
10 Gbps |
NSQM1CGQ20 |
2-port 100G Ethernet optical interface module |
LC/MPO |
2 |
100 Gbps |
QSFP28 optical transceiver module |
NSQM2QG4GP40 |
4-port 40G Ethernet optical + 4-port GE optical interface module |
LC |
4 |
1 Gbps |
LC/MPO |
4 |
40 Gbps |
NSQM2QG2TG8GP40 |
2-port 40G Ethernet optical + 8-port 10G Ethernet optical + 4-port GE optical interface module |
LC |
4 |
1 Gbps |
8 |
10 Gbps |
LC/MPO |
2 |
40 Gbps |
NSQM2QG2GP40 |
2-port 40G Ethernet optical + 4-port GE optical interface module |
LC |
4 |
1 Gbps |
LC/MPO |
2 |
40 Gbps |
NSQM2TG8GP40 |
LC |
4 |
1 Gbps |
8 |
10 Gbps |
Interface switch modules
The interface switch modules provide slots for interface subcards. Table 22 describes the interface switch modules available for the gateway and interface subcards supported by the interface switch modules.
Table 22 Interface switch module specifications
Number of slots |
Available subcards |
NSQM1MBFEA0 |
2 |
· NSQM2TG16GP40 · NSQM1CGQ20 (supported only in slot 2) · NSQM2QG2TG8GP40 · NSQM2QG2GP40 · NSQM2TG8GP40 · NSQM2QG4GP40 |
Power supplies
The gateway supports multiple power supplies.
· A PSR2500-12A-A power supply is an AC-input and DC-output power supply that provides a maximum DC output power of 2500 W.
· A PSR2400-12D-A power supply is a DC-input and DC-output power supply that provides a maximum DC output power of 2400 W.
· A PSR2500B-12AHD-F power supply provides a maximum output power of 2500 W. It supports 220 VAC single-phase AC input and 240 VDC or 380 VDC HVDC input.
Table 23 Power supply specifications
Item |
PSR2500-12A-A |
PSR2400-12D-A |
PSR2500B-12AHD-F |
Rated input voltage range |
100 VAC to 240 VAC @ 50/60 Hz |
–48 VDC to –60 VDC |
100 VAC to 240 VAC @ 50/60 Hz 240 VDC to 380 VDC |
Rated output voltage |
12 VDC |
12 VDC |
12 VDC |
Maximum input current |
16 A |
60 A |
16 A |
Maximum output current |
· 100 A (110 VAC) · 208 A (220 VAC) |
200 A |
100 A (90 VAC to 180 V AC) 208 A (180 VAC to 290 VAC, 180 VDC to 400 VDC) |
Maximum output power |
· 1200 W (110 VAC) · 2500 W (220 VAC) |
2400 W |
1200W (90 VAC to 180 VAC) 2500W (180 VAC to 290 VAC, 180 VDC to 400 VDC) |
Operating temperature |
–10°C to +50°C (14°F to 122°F) |
Storage temperature |
–40°C to +85°C (–40°F to +185°F) |
You can select a certain number of power supplies based on the actual power consumption requirements. Make sure the total maximum output power of the ordered power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
NOTE: · Do not install different models of power supplies on the same gateway. · When the temperature of a power supply exceeds the normal operating temperature, the power supply is automatically powered off. When the temperature recovers to the normal temperature, the power supply is automatically powered on. |
Fan trays
Table 24 Fan tray specifications
Fan tray |
Number of fans |
Fan diameter |
Maximum fan speed |
Maximum air flow rate |
M9006 fan tray |
8 |
92 mm (3.62 in) |
6000 RPM |
960 CFM (27.18 m3/min) |
12 |
120 mm (4.72 in) |
5200 RPM |
1152 CFM (32.62 m3/min) |
8 |
120 mm (4.72 in) |
5200 RPM |
1040 CFM (29.45 m3/min) |
4 |
120 mm (4.72 in) |
5200 RPM |
720 CFM (20.39 m3/min) |
NOTE: The gateway is shipped with fan trays installed. To replace a fan tray, make sure the new fan tray is compatible with the gateway. |
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121BTU/h.
The heat dissipation of a gateway depends on its power consumption. To calculate heat dissipation of the gateway, assume 90% power consumption is converted to heat, and the efficiency of the power supply is 90%. Heat dissipation/hour of the gateway is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
For the power consumption of the cards and fan trays of the gateway, see "Module power consumption and system power consumption."
Noise
The gateway uses fans with the automatic speed adjustment function, so the sound pressure levels are different when the fan speeds are different. For more information, see Table 25.
Table 25 Sound pressure levels
Model |
Sound pressure level under normal temperature |
Sound pressure level when the fan tray operates at full speed |
M9006 |
62.3 dBA |
75.5 dBA |
61.6 dBA |
72.6 dBA |
M9014 |
66 dBA |
79 dBA |
