- 05-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-M-LAG configuration
- 04-VLAN configuration
- 05-MVRP configuration
- 06-VLAN mapping configuration
- 07-VLAN termination configuration
- 08-Loop detection configuration
- 09-Spanning tree configuration
- 10-LLDP configuration
- 11-PFC configuration
- 12-Service loopback group configuration
- 13-Layer 2 forwarding configuration
| 12-Service loopback group configuration | 50.96 KB |
Configuring service loopback groups
Restrictions and guidelines: Service loopback group configuration
Configuring a service loopback group
Verifying and maintaining service loopback groups
Service loopback group configuration examples
Example: Configuring a service loopback group
About service loopback groups
A service loopback group provides both unicast and multicast tunnel services.
When you add member ports to a service loopback group, follow these restrictions and guidelines:
· Make sure the ports support the service type of the service loopback group and are not members of any other service loopback group.
When you apply service loopback groups to features, follow these restrictions and guidelines:
· One service loopback group can be used by multiple features.
· Do not delete a service loopback group that is being used by a feature.
1. Enter system view.
2. Create a service loopback group and specify its service type.
service-loopback group group-id type { multicast-tunnel | tunnel } *
3. Enter Layer 2 Ethernet interface view.
4. Assign the port to the service loopback group.
port service-loopback group group-id
By default, a port does not belong to a service loopback group.
You can add a maximum of 256 ports to a service loopback group.
CAUTION: · The configuration on a port is removed when it is assigned to a service loopback group. Make sure you fully understand the impact on your network when you assign a port to a service loopback group. · For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature. |
To display information about service loopback groups, execute the following command in any view:
display service-loopback group [ group-id ]
All Ethernet ports on the device support the tunnel service. Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
# Create service loopback group 1, and specify its service type as tunnel.
[Sysname] service-loopback group 1 type tunnel
# Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to service loopback group 1.
[Sysname-HundredGigE1/0/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/0/1] quit
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/0/2] quit
[Sysname] interface hundredgige 1/0/3
[Sysname-HundredGigE1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/0/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
