- H3C S10500X-G Switch Series Installation Guide-6W100
- 01-Installation Precautions
- 02-Preparing for Installation
- 03-Installing the Switch
- 04-Installing FRUs
- 05-Connecting Your Switch to the Network
- 06-Troubleshooting
- 07-Replacement Procedures
- 08-Appendix A Engineering Labels
- 09-Appendix B Cabling Recommendations
- 10-Appendix C Repackaging the Switch
| 00-Preface | 100.87 KB |
Preface
This installation guides you through installation of your S10500X-G switch. It covers the following topics:
· Preparing for installation.
· Installing the switch.
· Installing FRUs.
· Setting up an IRF fabric.
· Connecting your switch to the network.
· Troubleshooting.
· Replacement procedures.
· Engineering labels.
· Cabling recommendations.
· Repackaging the switch.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S10500X-G switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
