- 07-System
- 01-Hot backup
- 02-VRRP
- 03-Track
- 04-BFD
- 05-NQA
- 06-Basic log settings
- 07-Email server
- 08-Session log settings
- 09-NAT log settings
- 10-AFT log settings
- 11-Sandbox log settings
- 12-Threat log settings
- 13-Application audit log settings
- 14-NetShare log settings
- 15-URL filtering log settings
- 16-Data filtering log settings
- 17-Attack defense log settings
- 18-Reputation log settings
- 19-Bandwidth alarm logs
- 20-Configuration log settings
- 21-Security policy log
- 22-File filtering log settings
- 23-Terminal identification logging
- 24-Heartbeat log settings
- 25-WAF log settings
- 26-IP access logs
- 27-MAC access log
- 28-Load balancing logging
- 29-Bandwidth management logs
- 30-Context rate limit logging
- 31-Zero trust logs
- 32-Report settings
- 33-Session settings
- 34-Signature upgrade
- 35-Software upgrade
- 36-License management
- 37-IRF
- 38-IRF advanced settings
- 39-Contexts
- 40-vSystems
- 41-Administrators
- 42-Date and time
- 43-MAC address learning through a Layer 3 device
- 44-SNMP
- 45-Configuration management
- 46-Reboot
- 47-About
- 48-Fast Internet Access
- 49-Content moderation log settings
- 50-Drop statistics
- 51-License server
| 40-vSystems | 35.90 KB |
vSystems
This help contains the following topics:
¡ Default and non-default vSystems
¡ Restrictions and guidelines: VLAN assignment
¡ Restrictions and guidelines: Interface assignment
Introduction
A device supporting vSystems is considered to be a vSystem. This vSystem is called the default vSystem. The default vSystem always uses the name Admin and the ID 1. You cannot delete it or change its name or ID.
When you log in to the physical device, you are logged in to the default vSystem. On the default vSystem, you can perform the following tasks:
· Manage the entire physical device.
· Create and delete non-default vSystems.
· Assign non-default vSystems resources, including interface and VLAN resources.
You cannot create vSystems on a non-default vSystem.
A non-default vSystem can use only resources assigned to it. Resources that are not assigned to non-default vSystems belong to the default vSystem.
Unless otherwise stated, the term "vSystem" on webpages refers to a non-default vSystem.
· VLANs to be shared must already exist. Before assigning VLANs to vSystems, you must create the VLANs on the default vSystem.
· After a VLAN is assigned to a vSystem, the VLAN cannot be assigned to other vSystems.
· After a VLAN is assigned to a vSystem, the vSystem can use Layer 2 interfaces in the VLAN.
· After assigning a VLAN to a vSystem, the associated VLAN interfaces will be assigned to the vSystem automatically.
· After an interface is assigned to a vSystem, the interface cannot be assigned to other vSystems.
· The following interfaces can be assigned to vSystems:
¡ Layer 3 physical interfaces.
¡ Layer 3 physical subinterfaces.
¡ Layer 3 aggregate interfaces.
¡ Layer 3 aggregate subinterfaces.
¡ Layer 3 Reth interfaces.
¡ Layer 3 Reth subinterfaces.
¡ Tunnel interfaces.
¡ Loopback interfaces.
Manage vSystems
Configure a vSystem
Before assigning interfaces and VLANs to a vSystem, understand the actual service requirements and view assignment and configuration information about interfaces,
1. Click the System tab.
2. In the navigation pane, select Virtualization > vSystems > vSystems.
3. Click Create.
4. Configure parameters for the vSystem.
Table 1 vSystem configuration items
Item |
Name |
Enter the name of the vSystem. When a vSystem is created, a VRF of the same name will be created. To view the VRF, click the Network tab and then click VRF. |
Enter a description for the vSystem. |
VLAN |
Enter VLANs assigned to the vSystem. |
Interface list |
Select interfaces assigned to the vSystem. |
Max concurrent sessions |
Enter the maximum number of concurrent sessions. |
Max session establishment rate |
Enter the maximum session establishment rate. |
Max security policies |
Enter the maximum number of security policies. |
Throughput |
Enter the throughput threshold. |
5. Click OK.
Switch vSystems
1. Click the drop-down menu icon to the right of the current logged-in vSystem account at the upper right corner of the page.
2. On the menu that opens, click Switch vSystem.
3. On the dialog box that opens, specify a vSystem and click OK.
