07-System
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70007-System
28-Load balancing logging
28-Load balancing logging 12.76 KB
Introduction
After you enable LB scheduled logging, the device can generate logs about forwarded traffic.
After you enable fast log output for LB, the device outputs the specified LB-related content to the log host by using the fast log output feature. The device supports fast log output for server load balancing, inbound link load balancing, outbound link load balancing, and transparent DNS proxies.
You can configure the content to be output for server load balancing on the HTTP virtual server page.
