07-System
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70007-System
06-Basic log settings
06-Basic log settings 156.21 KB
Basic log settings
This help contains the following topics:
·     Introduction
¡     Syslog
¡     Flow log
¡     Fast log
¡     Storage space settings
¡     Log severity levels
¡     Security management and audit
·     Restrictions and guidelines
·     Configure basic log settings
¡     Configure syslog
¡     Configure flow log
¡     Configure fast log output
¡     Configure storage space settings
¡     Configure security management and audit
Introduction
The device generates various types of logs for service modules based on the packets processed by the service modules. These logs help network administrators monitor network performance, troubleshoot network problems, as well as track, record, analyze, and audit network access behaviors of users.
The device supports outputting logs by using the following methods:
·     Syslog.
·     Flow log.
·     Fast log output.
Syslog
Syslog entries are in ASCII format.
The information center on the device receives syslog messages generated by source modules and outputs the logs to the following destinations:
·     Console.
·     Monitor terminal.
·     Log buffer.
·     Log host.
·     Log file.
Flow log
About flow log
Flow log records users' access to external networks based on flows. Each flow is identified by a 5-tuple of the source IP address, destination IP address, source port, destination port, and protocol number.
Flow log creates entries based on NAT sessions.
Flow log versions
Flow log has three versions: version 1.0, version 3.0, and version 5.0. Table 1, Table 2, and Table 3 show the fields available in the versions. The fields displayed on your device might differ from those listed in the tables depending the log analysis tool you have used.
Table 1 Flow log 1.0 fields
SrcIP
Source IP address before NAT.
DestIP
Destination IP address before NAT.
SrcPort
Source TCP/UDP port number before NAT.
DestPort
Destination TCP/UDP port number before NAT.
StartTime
Start time of the flow, in seconds.
EndTime
End time of the flow, in seconds.
This field is 0 if the Operator field is 6 (regular connectivity check record for the active flow).
Protocol
Protocol number.
Operator
Reasons why a flow log entry was generated:
·     0—Reserved.
·     1—Flow was ended normally.
·     2—Flow was aged out because of aging timer expiration.
·     3—Flow was aged out because of configuration change or manual deletion.
·     4—Flow was aged out because of insufficient resources.
·     5—Reserved.
·     6—Regular connectivity check record for the active flow.
·     7—Flow was deleted because a new flow was created when the flow table was full.
·     8—Flow was created.
·     FE—Other reasons.
·     10-FE-1—Reserved for future use.
Reserved
Table 2 Flow log 3.0 fields
Protocol
Protocol number.
Operator
Reasons why a flow log was generated:
·     0—Reserved.
·     3—Flow was aged out because of configuration change.
·     5—Reserved.
·     FE—Other reasons.
IPVersion
IP packet version.
TosIPv4
ToS field of the IPv4 packet.
SourceIP
SrcNatIP
Source IP address after NAT.
DestIP
DestNatIP
Destination IP address after NAT.
SrcPort
SrcNatPort
Source TCP/UDP port number after NAT.
DestPort
DestNatPort
Destination TCP/UDP port number after NAT.
StartTime
EndTime
This field is 0 when the Operator field is 6 (regular connectivity check record for the active flow).
InTotalPkg
Number of packets received for the session.
InTotalByte
Number of bytes received for the session.
OutTotalPkg
Number of packets sent for the session.
OutTotalByte
Number of bytes sent for the session.
InVPNID
ID of the source VPN instance.
OutVPNID
ID of the destination VPN instance.
Reserved1
Reserved field.
AppID
Application protocol ID.
Reserved3
Reserved field.
Table 3 Flow log 5.0 fields
Protocol
Protocol number.
Operator
·     Reasons why a flow log was generated:
·     0—Reserved.
·     5—Reserved.
·     FE—Other reasons.
IPVersion
IP packet version.
TosIPv4
SourceIP
SrcNatIP
DestIP
DestNatIP
SrcPort
SrcNatPort
DestPort
DestNatPort
StartTime
EndTime
InTotalPkg
InTotalByte
OutTotalPkg
OutTotalByte
InVPNID
OutVPNID
AppID
UserName
Username.
Reserved1
Reserved2
Reserved3
Reserved fields.
Fast log
The fast log output feature enables fast output of logs to log hosts.
Typically, logs generated by a service module are first sent to the information center, which then outputs the logs to the specified destination (such as to log hosts). When fast log output is configured, logs of service modules are sent directly to log hosts instead of to the information center. Compared to outputting logs to the information center, fast log output saves system resources.
The device collects log data from service modules for central analysis and reporting.
The collected log data are preferably stored in a hard disk. If a hard disk is not present, the data are stored in a U disk. If a U disk is not present either, the data are stored in the memory. A new hard disk or U disk must be partitioned and formatted before it can be used to store the log data. Support for storing the log data in a U disk depends on the device model.
When the data is stored in the memory, if the stored data reaches the maximum size supported, the system will automatically delete the oldest log data to save new data. When the data is stored in a hard disk or USB disk, if the stored data reaches the storage space limit configured, the system will process the data according to the specified action. If the action is Delete, the system will delete the oldest log data to save new data.
Before you remove a storage device, complete the following to avoid damaging the storage device or the stored data:
·     From the Web interface, click Unload to remove the occupation of the service log processes on the file systems of the storage device.
·     From the CLI, execute the umount command in user view to unmount all the file systems on the storage device.
The storage space settings feature allows you to set the storage time limit, storage space limit, and the storage limit-violated action for the traffic service and DPI services.
Support for storage space settings depends on the device model.
Storage time limit
The storage time limit specifies the maximum number of days that the log data can be kept.
Processing of expired log data varies by the specified action:
·     If the action is Delete, the system will delete the expired log data and generate a log message to record the event.
·     If the action is Log-only, the system will generate a log message, but it does not delete the expired data.
Storage space limit
The storage space limit specifies the percentage of the total storage space the log data of a service can occupy.
Processing of the log data for a service whose storage space limit is exceeded varies by the specified action:
·     If the action is Delete, the system will delete the oldest log data to save new data. A log message will be generated to record the event.
·     If the action is Log-only, the system will generate a log message, but it does not delete old log data to save new data.
Action
The action specified for a storage limit of a service determines how the system processes the log data of the service when the storage limit is exceeded.
Supported actions are:
·     Delete—Deletes data collected on the oldest dates and generates a log message. The data of the current day cannot be deleted.
·     Log-only—Generates a log message only. When a storage limit is exceeded, old data are not deleted and new data cannot be saved. To view the log data, go to Monitor > Device Logs > System Logs.
Log severity levels
Logs are classified into eight severity levels from 0 through 7 in descending order. If you specify a severity level for log output, logs with a severity level that is higher than or equal to the specified level will be output. For example, if you specify a severity level of 6 (informational), logs that have a severity level from 0 to 6 are output.
Table 4 Log severity levels
Severity value
Level
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debugging
Debugging message.
The security management feature enables the security management service process on the device. If this feature is disabled, you cannot manage or audit the security services on the device through the security management server.
The security audit log feature enables the device to log security-related configurations and report the log messages to the security audit server. The log messages mainly include the syslog messages generated for operations on the administrator, system, and security-related policies.
Support for the security management and audit features depends on the device model.
The device supports the following methods (in descending order of priority) for outputting logs of a module to designated log hosts:
·     Fast log output.
·     Flow log output.
·     Syslog output.
If you configure multiple log output methods for a module, only the method with the highest priority takes effect.
Configure syslog
1.     Click the System tab.
2.     In the navigation pane, select Log Settings > Basic Settings.
3.     Click the Syslog tab.
4.     Configure the basic syslog settings.
Table 5 Syslog configuration items
Item
Output to log buffer
Select this item to enable system log output to the log buffer.
This item enables system log output to log buffers based on the log source modules.
·     Logs generated by modules that have separate log buffers are saved to their respective log buffers.
For example, session logs and attack defense logs are saved to the session log buffer and the attack defense log buffer, respectively.
·     Logs generated by other modules are saved to the general log buffer.
Log buffer size
Enter the maximum number of logs that can be buffered.
When the log buffer is full, the system will overwrite the oldest logs with new logs.
This item specifies the size of the general log buffer.
Max logging rate
Specify the maximum log rate. This limit specifies the maximum number of logs that all the supported security services can generate at a time. When the log rate of the security services exceeds the limit, the system drops the exceeding logs.
5.     Click Apply.
6.     Click Create.
The Create Log Host window opens.
7.     Create a log host.
Table 6 Log host configuration items
Item
Log host address
Enter the IP address or host name of the log host.
Port number
Enter the port number of the log host.
VRF
Select the VRF (VPN instance) to which the log host belongs. If the log host belongs to the public network, select Public network.
8.     Click OK.
The new log host is displayed on the log host list of the Syslog tab.
Configure flow log
3.     Click the Flow Log tab.
4.     Configure the basic flow log settings.
Table 7 Flow log configuration items
Item
Log version
Select a flow log version. Options are 1.0, 3.0, and 5.0.
Make sure the specified flow log version is supported on the log hosts specified for flow log export.
Load balancing
Select this item to enable load balancing for flow log entries.
By default, load balancing is disabled. The device sends a copy of each flow log entry to all available log hosts.
In load balancing mode, flow log entries are distributed among log hosts based on the source IP addresses (before NAT) that are recorded in the entries. The flow log entries generated for the same source IP address are sent to the same log host. If a log host goes down, the flow logs sent to it will be lost.
Source IP for log packets
Specify the source IP address for the flow log packets.
By default, the source IP address of flow log packets is the IP address of their outgoing interface.
Configure this item when you need to filter flow logs by source IP address on the log host.
As a best practice, use a Loopback interface's address as the source IP address for flow log packets. A Loopback interface is always up. The setting avoids export failure on interfaces that might go down.
5.     Click Apply.
6.     Click Create.
Table 8 Log host configuration items
Item
Log host address
Port number
VRF
Select the VPN instance to which the log host belongs. If the log host belongs to the public network, select Public network.
7.     Click OK.
The new log host is displayed on the log host list of the Flow Log tab.
3.     Click the Fast Log Output tab.
4.     Configure the fast log output settings.
Table 9 Fast log output configuration items
Item
Log timestamp
Select the time zone to use in the log timestamp. Options are:
·     Greenwich Mean Time (GMT)—Standard Greenwich Mean Time (GMT).
·     Local time—Standard GMT plus or minus the time zone offset.
Select a source interface for fast log output. The primary IP address of the specified interface is used as the source IP address of fast output logs regardless of the outgoing interface.
By default, the source IP address of fast output logs is the primary IP address of the outgoing interface.
Configure this item when you need to filter logs by source IP address on the log host.
As a best practice, use a Loopback interface's address as the source IP address for fast log output. A Loopback interface is always up. The setting avoids export failure on interfaces that might go down.
5.     Click Apply.
6.     Click Create.
Table 10 Log host configuration items
Item
Log host address
Port number
VRF
Session logs
Select this item to enable fast output of session logs to the log host.
NAT logs
Select this item to enable fast output of NAT logs to the log host.
Log format
This item is available only when the NAT logs item is selected.
Select a log output format. Options are China Unicom, China Telecom, and CMCC.
NAT session logs
Select this item to enable fast output of NAT session logs to the log host.
NAT444 user logs
Select this item to enable fast output of NAT444 user logs to the log host.
AFT logs
Select this item to enable fast output of AFT port block logs to the log host.
Application audit logs
Select this item to enable fast output of application audit logs to the log host.
URL filtering logs
Select this item to enable fast output of URL filtering logs to the log host.
Data filtering logs
Select this item to enable fast output of data filtering logs to the log host.
Attack defense logs
Select this item to enable output of attack defense logs to the log host.
Netshare logs
Select this item to enable fast output of netshare control logs to the log host.
Security policy configuration logs
Select this item to enable fast output of security policy configuration logs to the log host.
Packet filtering logs
Select this item to enable fast output of matching packet filter, object policy, and security policy logs to the log host.
Heartbeat logs
Select this item to enable fast output of heartbeat logs to the log host.
IPS logs
Select this item to enable fast output of IPS logs to the log host.
Bandwidth management logs
Select this item to enable fast output of bandwidth management logs to the log host.
Sandbox logs
Select this item to enable fast output of sandbox logs to the log host.
WAF logs
Select this item to enable fast output of WAF logs to the log host.
LB logs
Select this item to enable fast output of load balancing logs to the log host. LB logs include SLB logs, inbound link LB logs, outbound link LB logs, and transparent DNS proxy logs.
File filtering logs
Select this item to enable fast output of file filtering logs to the log host.
Terminal identification logs
Select this item to enable fast output of terminal identification logs to the log host.
Anti-virus logs
Select this item to enable fast output of anti-virus logs to the log host.
IP reputation logs
Select this item to enable fast output of IP reputation logs to the log host.
External authentication logs
Select this item to enable fast output of external authentication logs to the log host.
Notification logs
Select this item to enable fast output of policy notification logs to the log host.
Zero trust policy logs
Select this item to enable fast output of zero trust policy logs to the log host.
Content moderation logs
Select this item to enable fast output of content moderation logs to the log host.
vSystem logs
Select this item to enable fast output of vSystem logs to the log host.
7.     Click OK.
The new log host is displayed on the log host list of the Fast Log Output tab.
3.     Click the Storage Space Settings tab.
4.     Click the Edit icon for a service, and then configure the storage space settings for the service.
Table 11 Storage space configuration items
Item
Service
Name of the service for which you can configure storage space limit settings.
Max storage days
Specify the maximum number of days that the log data can be kept.
This item is available only when a hard disk or U disk is present.
Max storage space
Specify the percentage of the total storage space the log data of the service can occupy.
Action
Specify the action to take when the storage time limit or storage space limit of the service is exceeded.
Enable
Enable logging for the service.
The subfile match logging and frame match logging for the content moderation service depend on the file hit logging status. If file hit logging is disabled, the subfile and frame match logging features do not take effect.
5.     Click OK.
3.     Click the Security Management&Audit tab.
Table 12 Security management and audit configuration items
Item
Security management
After this feature is enabled, the device opens the security management service process.
Send security audit logs
After this feature is enabled, the device records security audit related log messages and reports the log messages to the security audit server.
Security audit server IP
Specify the IPv4 address of the security audit server.
Security audit server port
Specify the port number on which the security audit server receives security audit log messages.
4.     Click Apply.
5.     To export the device's security management service configuration file to the local device, click Export.
