07-System
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70007-System
15-URL filtering log settings
15-URL filtering log settings 18.18 KB
This help contains the following topics:
·     Introduction
Introduction
URL filtering logs record the website access behaviors of users.
URL filtering logs can be output as system logs or fast logs. By default, URL filtering logs are output as system logs.
When you select the Fast log output option, the Non-standard format option is displayed, which allows you to specify a carrier-customized format (Unicom) for fast log output. By default, fast logs are output in the standard format.
