- 07-System
- 01-Hot backup
- 02-VRRP
- 03-Track
- 04-BFD
- 05-NQA
- 06-Basic log settings
- 07-Email server
- 08-Session log settings
- 09-NAT log settings
- 10-AFT log settings
- 11-Sandbox log settings
- 12-Threat log settings
- 13-Application audit log settings
- 14-NetShare log settings
- 15-URL filtering log settings
- 16-Data filtering log settings
- 17-Attack defense log settings
- 18-Reputation log settings
- 19-Bandwidth alarm logs
- 20-Configuration log settings
- 21-Security policy log
- 22-File filtering log settings
- 23-Terminal identification logging
- 24-Heartbeat log settings
- 25-WAF log settings
- 26-IP access logs
- 27-MAC access log
- 28-Load balancing logging
- 29-Bandwidth management logs
- 30-Context rate limit logging
- 31-Zero trust logs
- 32-Report settings
- 33-Session settings
- 34-Signature upgrade
- 35-Software upgrade
- 36-License management
- 37-IRF
- 38-IRF advanced settings
- 39-Contexts
- 40-vSystems
- 41-Administrators
- 42-Date and time
- 43-MAC address learning through a Layer 3 device
- 44-SNMP
- 45-Configuration management
- 46-Reboot
- 47-About
- 48-Fast Internet Access
- 49-Content moderation log settings
- 50-Drop statistics
- 51-License server
| 43-MAC address learning through a Layer 3 device | 27.44 KB |
Introduction
This feature enables the device to learn the MAC address of a terminal (a PC for example) when a Layer 3 device (typically a gateway) exists between the device and the terminal for network traffic control.
Figure 1 MAC address learning through a Layer 3 device workflow
As shown in Figure 1, MAC address learning through a Layer 3 device proceeds as follows:
2. The Layer 3 device learns the IP-MAC binding of the terminal, and then generates an ARP entry.
3. The device sends SNMP requests to the Layer 3 device at the specified intervals to request the ARP entry.
4. The Layer 3 device sends a response that contains the ARP entry.
5. Upon receiving the response, the device saves the ARP entry in the memory. Then it can learn the MAC address of the terminal.
· Make sure the Layer 3 device supports SNMPv2c or SNMPv3, has SNMP agent enabled, and has a community name configured.
· Only MAC addresses mapped from IPv4 addresses can be learned.
· Make sure no NAT devices exist between the device and the Layer 3 device.
· This feature is not applicable to a VRF network.
Configure MAC address learning through a Layer 3 device
1. Select System > Maintenance > MAC Learning Through L3 Device > L3 Device Access Setting.
2. Click Enable to enable MAC address learning through a Layer 3 device.
3. (Optional.) Set the polling interval and idle timeout
Table 1 Configuration items for MAC address learning through a Layer 3 device
Item |
Polling interval |
Interval for sending SNMP requests, in seconds |
Idle timeout |
Idle timeout for SNMP responses, in seconds |
4. Click Apply.
5. Add a Layer 3 device:
a. Click Add.
b. Configure the following settings:
Item |
SNMP version |
SNMP version. Options include v2c and v3. |
IP address |
IP address of the target Layer 3 device, typically the gateway of the terminal network. Only IPv4 addresses are supported. |
Community name (SNMPv2c) |
Devices in a community use a community name for authentication. The device can communicate with the Layer 3 device only if it has the same community name as the SNMP agent on the Layer 3 device. |
Username (SNMPv3) |
Authentication can be performed only if the device and the SNMP agent on the Layer 3 device have the same username. |
Authentication algorithm |
For a successful authentication, make sure these settings are the same as those on the SNMP agent of the Layer 3 device. |
Authentication password |
Encryption algorithm |
Encryption password |
6. Click OK.
