- 07-System
- 01-High availability group
- 02-VRRP
- 03-Track
- 04-BFD
- 05-NQA
- 06-Basic log settings
- 07-Email server
- 08-Session log settings
- 09-Sandbox log settings
- 10-Heartbeat log settings
- 10-Threat log settings
- 11-Application audit log settings
- 12-URL filtering log settings
- 13-Attack defense log settings
- 14-Reputation log settings
- 15-Bandwidth alarm logs
- 16-Configuration log settings
- 17-Security policy log
- 18-Terminal identification logging
- 20-WAF log settings
- 21-IP access logs
- 22-MAC access log
- 23-Bandwidth management logs
- 24-Context rate limit logging
- 25-Report settings
- 26-Session settings
- 27-Signature upgrade
- 28-Software upgrade
- 29-License management
- 30-IRF
- 31-IRF advanced settings
- 32-Contexts
- 33-Administrators
- 34-Date and time
- 35-MAC address learning through a Layer 3 device
- 36-SNMP
- 37-Configuration management
- 38-Reboot
- 39-About
- 40-Ping
- 41-Tracert
- 42-Packet capture
- 43-Webpage Diagnosis
- 44-Diagnostic Info
- 45-Packet trace
- 46-Fast Internet Access
| 07-Email server | 23.36 KB |
Email server
This help contains the following topics:
Introduction
Configure the email server
1. Click the System tab.
2. In the navigation pane, select Log Settings > Email Server.
3. Click Create.
4. Configure the email server settings.
Table 1 Email server configuration items
Item |
Email server name |
Enter the name of the email server. |
Email server address |
Enter the IP address or host name of the email server. |
Sender address |
Enter the email sender address. |
Recipient addresses |
· Enter a colon-separated list of email recipient addresses. |
DNS server address |
Enter the IP address of the DNS server. |
Identity authentication |
Select Enable to enable email client authentication. Enable this function if identity authentication is required by the email server. |
Secure user info transmission |
Select this item to enable secure transmission of user authentication credentials. |
Username |
Enter the username for logging in to the email server. |
Password |
Enter the password for logging in to the email server. |
Email sending interval |
Enter an interval for sending emails. The device caches the emails to be sent and sends them only when the interval expires. |
Max. emails per interval |
Specify the maximum number of emails to be sent per interval. If the maximum number is reached within the sending interval and more emails are generated to send, the device compares the severity levels of the new emails and the existing emails. If the severity level of a new email is higher than that of an existing cached email, the new one overwrites the most recent email with the lowest severity level. The severity level of an email is the severity level of the matching IPS signature of the log. When multiple service modules are operating concurrently, this setting takes effect separately on each service module. |
5. Click OK.
