07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath IPS Comware 7 Web-Based Configuration Guide(R8X60)-6W60007-System
04-BFD
04-BFD 15.82 KB
BFD
Introduction
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of forwarding paths to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
BFD sessions use echo packets to implement detection. Echo packets are encapsulated into UDP packets with port number 3785.
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end. If the local end does not receive echo packets from the peer end within the detection time, it considers the session to be down.
Configure BFD
1.     Select System > High Availability > BFD.
2.     Configure BFD.
Table 1 BFD configuration items
Item
Echo packet source IPv4
Specify a source IPv4 address for echo packets.
As a best practice, specify an IPv4 address that is not on the same network segment as any local interface's IP address. This behavior prevents the peer from sending a large number of ICMP redirect packets, which will result in link congestion.
Echo packet source IPv6
Specify a source IPv6 address for echo packets.
As a best practice, specify an IPv6 address that is not on the same network segment as any local interface's IP address. This behavior prevents the peer from sending a large number of ICMPv6 redirect packets, which will result in link congestion.
