07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath IPS Comware 7 Web-Based Configuration Guide(R8X60)-6W60007-System
12-URL filtering log settings
12-URL filtering log settings 18.19 KB
This help contains the following topics:
·     Introduction
Introduction
URL filtering logs record the website access behaviors of users.
URL filtering logs can be output as system logs or fast logs. By default, URL filtering logs are output as system logs.
When you select the Fast log output option, the Non-standard format option is displayed, which allows you to specify a carrier-customized format (Unicom) for fast log output. By default, fast logs are output in the standard format.
