H3C MSR Routers Configuration Examples-6W100
HomeSupportResource CenterConfigure & DeployConfiguration ExamplesH3C MSR Routers Configuration Examples-6W100
10-H3C MSR Routers BGP Configuration Examples (Comware V7)
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides BGP configuration examples.
This document applies to Comware V7-based MSR routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of BGP.
Example: Configuring basic BGP
Network requirements
As shown in Figure 1, run EBGP between Router A and Router B, and run IBGP between Router B and Router C to allow Router C to access network 8.1.1.0/24.
Figure 1 Network diagram
Requirements analysis
To enable Router B to communicate with Router C through loopback interfaces, enable OSPF in AS 65009.
By default, BGP does not advertise local networks. To enable Router C to access network 8.1.1.0/24 directly connected to Router A, perform the following tasks:
·     Add network 8.1.1.0/24 to the BGP routing table of Router A.
·     Add networks 3.1.1.0/24 and 9.1.1.0/24 to the BGP routing table of Router B.
Software version used
This configuration example was created and verified on R0106.
When you configure basic BGP, follow these restrictions and guidelines:
·     Use loopback interfaces to establish IBGP connections to prevent route flapping caused by port state changes.
·     Loopback interfaces are virtual interfaces. Use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections.
·     The EBGP peers, Router A and Router B, are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so the routers use directly connected interfaces to establish EBGP sessions.
Configuration procedures
1.     Configure IP addresses for interfaces:
# Configure IP addresses for interfaces on Router A.
[RouterA-LoopBack0] ip address 1.1.1.1 255.255.255.255
[RouterA-LoopBack0] quit
[RouterA] interface gigabitethernet 0/1
[RouterA-GigabitEthernet0/1] port link-mode route
[RouterA-GigabitEthernet0/1] ip address 3.1.1.2 255.255.255.0
[RouterA-GigabitEthernet0/1] quit
[RouterA] interface gigabitethernet 0/2
[RouterA-GigabitEthernet0/2] port link-mode route
[RouterA-GigabitEthernet0/2] ip address 8.1.1.1 255.255.255.0
[RouterA-GigabitEthernet0/2] quit
# Configure IP addresses for interfaces on Router B.
<RouterB> system-view
[RouterB-LoopBack0] ip address 2.2.2.2 255.255.255.255
[RouterB-LoopBack0] quit
[RouterB] interface gigabitethernet 0/1
[RouterB-GigabitEthernet0/1] port link-mode route
[RouterB-GigabitEthernet0/1] ip address 3.1.1.1 255.255.255.0
[RouterB-GigabitEthernet0/1] quit
[RouterB] interface gigabitethernet 0/2
[RouterB-GigabitEthernet0/2] port link-mode route
[RouterB-GigabitEthernet0/2] ip address 9.1.1.1 255.255.255.0
[RouterB-GigabitEthernet0/2] quit
# Configure IP addresses for interfaces on Router C.
<RouterC> system-view
[RouterC] interface loopback 0
[RouterC-LoopBack0] ip address 3.3.3.3 255.255.255.255
[RouterC-LoopBack0] quit
[RouterC] interface gigabitethernet 0/2
[RouterC-GigabitEthernet0/2] port link-mode route
[RouterC-GigabitEthernet0/2] ip address 9.1.1.2 255.255.255.0
[RouterC-GigabitEthernet0/2] quit
2.     Configure IBGP:
# On Router B, configure the router ID as 2.2.2.2.
[RouterB] bgp 65009
[RouterB-bgp] router-id 2.2.2.2
# On Router B, create IBGP peer 3.3.3.3 and specify interface Loopback 0 as the source interface for TCP connections to the peer.
[RouterB-bgp] peer 3.3.3.3 as-number 65009
[RouterB-bgp] peer 3.3.3.3 connect-interface loopback 0
# On Router B, enable BGP to exchange IPv4 unicast routing information with the peer.
[RouterB-bgp] address-family ipv4 unicast
[RouterB-bgp-ipv4] peer 3.3.3.3 enable
[RouterB-bgp-ipv4] quit
[RouterB-bgp] quit
# On Router B, configure OSPF.
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# On Router C, configure the router ID as 3.3.3.3.
[RouterC] bgp 65009
[RouterC-bgp] router-id 3.3.3.3
# On Router C, create IBGP peer 2.2.2.2 and specify interface Loopback 0 as the source interface for TCP connections to the peer.
[RouterC-bgp] peer 2.2.2.2 as-number 65009
[RouterC-bgp] peer 2.2.2.2 connect-interface loopback 0
# On Router C, enable BGP to exchange IPv4 unicast routing information with the peer.
[RouterC-bgp] address-family ipv4 unicast
[RouterC-bgp-ipv4] peer 2.2.2.2 enable
[RouterC-bgp-ipv4] quit
[RouterC-bgp] quit
# On Router C, configure OSPF.
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
# Display brief information about all BGP IPv4 unicast peers. The following shows the output on Router C. The output shows that Router C has established an IBGP peer relationship with Router B.
[RouterC] display bgp peer ipv4
 BGP local router ID : 3.3.3.3
 Local AS number : 65009
 Total number of peers : 1                 Peers in established state : 1
  2.2.2.2              65009        2        2    0       0 00:00:13 Established
3.     Configure EBGP:
# On Router A, configure the router ID as 1.1.1.1.
[RouterA] bgp 65008
[RouterA-bgp] router-id 1.1.1.1
# On Router A, create EBGP peer 3.1.1.1 and specify its AS number as 65009.
[RouterA-bgp] peer 3.1.1.1 as-number 65009
# On Router A, enable BGP to exchange IPv4 unicast routing information with the peer.
[RouterA-bgp] address-family ipv4 unicast
[RouterA-bgp-ipv4] peer 3.1.1.1 enable
# On Router A, add local network 8.1.1.0/24 to the BGP routing table.
[RouterA-bgp-ipv4] network 8.1.1.0 24
[RouterA-bgp-ipv4] quit
[RouterA-bgp] quit
# On Router B, create EBGP peer 3.1.1.2 and specify its AS number as 65008.
[RouterB] bgp 65009
[RouterB-bgp] peer 3.1.1.2 as-number 65008
[RouterB-bgp-ipv4] peer 3.1.1.2 enable
[RouterB-bgp] quit
# Display BGP peer information on Router B.
[RouterB] display bgp peer ipv4
 BGP local router ID : 2.2.2.2
 Total number of peers : 2                 Peers in established state : 2
  3.3.3.3              65009        4        4    0       0 00:02:49 Established
  3.1.1.2              65008        2        2    0       0 00:00:05 Established
The output shows that Router B has established an IBGP peer relationship with Router C and an EBGP peer relationship with Router A.
# Display the BGP routing table on Router A.
[RouterA] display bgp routing-table ipv4
 Total number of routes: 1
* >  8.1.1.0/24         8.1.1.1         0                     32768   i
# Display the BGP routing table on Router B.
[RouterB] display bgp routing-table ipv4
* >e 8.1.1.0/24         3.1.1.2         0                     0       65008i
# Display the BGP routing table on Router C.
[RouterC] display bgp routing-table ipv4
   i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
The outputs show that Router A has learned no route to AS 65009, and Router C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
4.     Configure BGP route redistribution:
# Create the BGP IPv4 unicast address family and enter its view.
[RouterB] bgp 65009
# Configure BGP to redistribute direct routes on Router B.
[RouterB-bgp-ipv4] network 3.1.1.0 24
[RouterB-bgp-ipv4] network 9.1.1.0 24
[RouterB-bgp] quit
 Total number of routes: 3
* >e 3.1.1.0/24         3.1.1.1         0                     0       65009?
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009i
The output shows that route 9.1.1.0/24 has been added into the routing table of Router A.
* >i 3.1.1.0/24         2.2.2.2         0          100        0       ?
* >i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
* >i 9.1.1.0/24         2.2.2.2         0          100        0       i
The output shows that route 8.1.1.0 has become valid and the next hop is Router A.
# Verify that Router C can ping 8.1.1.1.
[RouterC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL_C to break
Configuration files
·     Router A:
interface Loopback0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
bgp 65008
 router-id 1.1.1.1
  network 8.1.1.0 255.255.255.0
  peer 3.1.1.1 enable
·     Router B:
interface Loopback0
bgp 65009
 router-id 2.2.2.2
 peer 3.3.3.3 connect-interface Loopback0
  network 3.1.1.0 24
  network 9.1.1.0 24
  peer 3.1.1.2 enable
  peer 3.3.3.3 enable
ospf 1
 area 0.0.0.0
·     Router C:
interface Loopback0
bgp 65009
 router-id 3.3.3.3
 peer 2.2.2.2 connect-interface Loopback0
  peer 2.2.2.2 enable
ospf 1
 area 0.0.0.0
Example: Configuring BGP and IGP route redistribution
As shown in Figure 2, run EBGP between Router A and Router B, and run OSPF between Router B and Router C to allow communication between networks 9.1.2.0/24 and 8.1.1.0/24.
Figure 2 Network diagram
To enable Router A to obtain the route to 9.1.2.0/24, configure BGP to redistribute routes from OSPF on Router B. To enable Router C to obtain the route to 8.1.1.0/24, configure OSPF to redistribute routes from BGP on Router B.
When you configure BGP and IGP route redistribution, follow these restrictions and guidelines:
[RouterA] interface gigabitethernet 0/0
[RouterA-GigabitEthernet0/0] port link-mode route
[RouterA-GigabitEthernet0/0] ip address 8.1.1.1 255.255.255.0
[RouterA-GigabitEthernet0/0] quit
[RouterA-GigabitEthernet0/2] ip address 8.1.2.1 255.255.255.0
[RouterC] interface gigabitethernet 0/0
[RouterC-GigabitEthernet0/0] port link-mode route
[RouterC-GigabitEthernet0/0] ip address 9.1.2.1 255.255.255.0
[RouterC-GigabitEthernet0/0] quit
[RouterC] interface gigabitethernet 0/1
[RouterC-GigabitEthernet0/1] port link-mode route
[RouterC-GigabitEthernet0/1] ip address 9.1.3.1 255.255.255.0
[RouterC-GigabitEthernet0/1] quit
2.     Configure OSPF:
# Configure Router B.
[RouterB] ospf 1
# Configure Router C.
[RouterC] ospf 1
[RouterC-ospf-1-area-0.0.0.0] network 9.1.2.0 0.0.0.255
3.     Configure the EBGP connection:
[RouterA] bgp 65008
# On Router A, add network 8.1.1.0/24 to the BGP routing table.
[RouterA-bgp] quit
[RouterB] bgp 65009
[RouterB-bgp] quit
4.     Configure BGP and IGP route redistribution:
# In BGP IPv4 unicast address family view, configure BGP to redistribute OSPF routes.
[RouterB] bgp 65009
[RouterB-bgp-ipv4] import-route ospf 1
[RouterB-bgp] quit
# In OSPF view, configure OSPF to redistribute BGP routes.
[RouterB] ospf 1
[RouterB-ospf-1] import-route bgp
* >e 9.1.2.0/24         3.1.1.1         1                     0       65009?
The output shows that Router A has obtained the route to 9.1.2.0/24.
# Display the OSPF routing table on Router C.
[RouterC] display ospf routing
                   Routing Tables
 Routing for Network
 9.1.1.0/24         1        Transit 9.1.1.2         3.3.3.3         0.0.0.0
9.1.2.0/24         1        Stub    9.1.2.1         192.168.0.63    0.0.0.0
 2.2.2.2/32         1        Stub    9.1.1.1         2.2.2.2         0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 8.1.1.0/24         1        Type2   1           9.1.1.1         2.2.2.2
 Total Nets: 3
 Intra Area: 2  Inter Area: 0  ASE: 1  NSSA: 0
The output shows that Router C has obtained the route to 8.1.1.0/24.
# Verify that 8.1.1.1 on Router A can ping 9.1.2.1 on Router C.
[RouterA] ping -a 8.1.1.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL_C to break
# Verify that 9.1.2.1 on Router C can ping 8.1.1.1 on Router A.
[RouterC] ping -a 9.1.2.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL_C to break
# Verify that 8.1.2.1 on Router A cannot ping 9.1.2.1 and 9.1.3.1 on Router C.
[RouterA] ping –a 8.1.2.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
[RouterA] ping –a 8.1.2.1 9.1.3.1
Ping 9.1.3.1 (9.1.3.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 9.1.3.1 ---
# Verify that 9.1.3.1 on Router C cannot ping 8.1.1.1 and 8.1.2.1 on Router A.
[RouterC] ping –a 9.1.3.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
[RouterC] ping –a 9.1.3.1 8.1.2.1
Ping 8.1.2.1 (8.1.2.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 8.1.2.1 ---
Configuration files
·     Router A:
interface Loopback0
interface GigabitEthernet0/0
bgp 65008
 router-id 1.1.1.1
  peer 3.1.1.1 enable
·     Router B:
interface Loopback0
bgp 65009
 router-id 2.2.2.2
  import-route ospf 1
  peer 3.1.1.2 enable
ospf 1
 import-route bgp
 area 0.0.0.0
·     Router C:
interface Loopback0
ospf 1
 area 0.0.0.0
Related documentation
·     H3C MSR Series Routers Layer 3—IP Routing Command Reference(V7)
·     H3C MSR Series Routers Layer 3—IP Routing Configuration Guide(V7)
  • Become a Partner
  • Partner Resources
