- H3C MSR Routers Configuration Examples-6W100
- 01-H3C MSR Routers RBAC Configuration Examples (Comware V7)
- 02-H3C MSR Routers Ethernet Link Aggregation Configuration Examples (Comware V7)
- 03-H3C MSR Routers Port Isolation Configuration Examples (Comware V7)
- 04-H3C MSR Routers VLAN Configuration Examples (Comware V7)
- 05-H3C MSR Routers QinQ Configuration Examples (Comware V7)
- 06-H3C MSR Routers PPP Configuration Examples (Comware V7)
- 07-H3C MSR Routers OSPF Configuration Examples (Comware V7)
- 08-H3C MSR Routers OSPFv3 Configuration Examples (Comware V7)
- 09-H3C MSR Routers IPv6 IS-IS Configuration Examples (Comware V7)
- 10-H3C MSR Routers BGP Configuration Examples (Comware V7)
| 08-H3C MSR Routers OSPFv3 Configuration Examples (Comware V7) | 96.38 KB |
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring OSPFv3 route filtering
Configuring route redistribution
Introduction
This document provides OSPFv3 route filtering configuration examples.
This document applies to Comware V7-based MSR routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of OSPFv3 route filtering.
Network requirements
As shown in Figure 1, the devices of an enterprise reside in OSPFv3 and RIPng domains.
Configure route redistribution between OSPFv3 and RIPng to interconnect the devices.
Configure route filtering on Device E, Device C, and Device D to meet the following requirements:
· The route destined for R&D department 2 is not redistributed to OSPFv3.
· Marketing department 1 cannot reach R&D department 1.
· R&D department 1 and the After-sale service department cannot reach Marketing department 2.
Device |
IP address |
Device |
IP address |
Device A |
GE2/0/1 |
1::1/64 |
Device B |
GE2/0/1 |
1::2/64 |
GE2/0/2 |
2::1/64 |
GE2/0/2 |
3::1/64 |
GE2/0/3 |
4::1/64 |
Device C |
GE2/0/1 |
2::2/64 |
Device D |
GE2/0/1 |
3::2/64 |
Loop0 |
13::1/64 |
Loop0 |
11::1/64 |
Loop1 |
12::1/64 |
Device E |
GE2/0/1 |
4::2/64 |
Device F |
GE2/0/1 |
5::2/64 |
GE2/0/2 |
5::1/64 |
Loop0 |
14::1/64 |
Loop1 |
15::1/64 |
Software version used
This configuration example was created and verified on R0106.
When you configure OSPFv3 route filtering, follow these restrictions and guidelines:
· The filter-policy export command that filters redistributed routes takes effect only on an ASBR.
· OSPFv3 filters routes calculated using received LSAs. It does not filter LSAs.
· IP communication is bidirectional. If a router filters a route destined for Network A, the subnets attached to the router cannot reach Network A, and Network A cannot reach the subnets.
· When you configure route filtering by referencing an ACL, configure the rule permit source any item following multiple rule deny source items to allow unmatched routes to pass.
· Specify a Router ID when you configure OSPFv3.
Configuration procedures
Configuring IPv6 addresses
# Configure an IPv6 address for GigabitEthernet 2/0/1.
[DeviceA] interface GigabitEthernet 2/0/1
[DeviceA-GigabitEthernet2/0/1] ipv6 address 1::1 64
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
Configuring OSPFv3
# Enable OSPFv3 on Device A.
[DeviceA] ospfv3
[DeviceA-ospfv3-1] router-id 6.6.6.6
[DeviceA-ospfv3-1] quit
[DeviceA-GigabitEthernet2/0/1] ospfv3 1 area 0
[DeviceA-GigabitEthernet2/0/1] quit
[DeviceA] interface GigabitEthernet 2/0/2
[DeviceA-GigabitEthernet2/0/2] ospfv3 1 area 2
[DeviceA-GigabitEthernet2/0/2] quit
[DeviceA] interface GigabitEthernet 2/0/3
[DeviceA-GigabitEthernet2/0/3] ospfv3 1 area 1
[DeviceA-GigabitEthernet2/0/3] quit
# Enable OSPFv3 on Device B.
[DeviceB] ospfv3
[DeviceB-ospfv3-1] router-id 5.5.5.5
[DeviceB-ospfv3-1] quit
[DeviceB] interface GigabitEthernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] ospfv3 1 area 0
[DeviceB-GigabitEthernet2/0/1] quit
[DeviceB] interface GigabitEthernet 2/0/2
[DeviceB-GigabitEthernet2/0/2] ospfv3 1 area 3
[DeviceB-GigabitEthernet2/0/2] quit
# Enable OSPFv3 on Device C.
<DeviceC> system-view
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 4.4.4.4
[DeviceC-ospfv3-1] quit
[DeviceC] interface GigabitEthernet 2/0/1
[DeviceC-GigabitEthernet2/0/1] ospfv3 1 area 2
[DeviceC-GigabitEthernet2/0/1] quit
[DeviceC] interface LoopBack 0
[DeviceC-LoopBack0] ospfv3 1 area 2
[DeviceC-LoopBack0] quit
# Enable OSPFv3 on Device D.
<DeviceD> system-view
[DeviceD] ospfv3
[DeviceD-ospfv3-1] router-id 3.3.3.3
[DeviceD-ospfv3-1] quit
[DeviceD] interface GigabitEthernet 2/0/1
[DeviceD-GigabitEthernet2/0/1] ospfv3 1 area 3
[DeviceD-GigabitEthernet2/0/1] quit
[DeviceD] interface LoopBack 0
[DeviceD-LoopBack0] ospfv3 1 area 3
[DeviceD-LoopBack0] quit
[DeviceD] interface LoopBack 1
# Enable OSPFv3 on Device E.
<DeviceE> system-view
[DeviceE] ospfv3
[DeviceE-ospfv3-1] router-id 2.2.2.2
[DeviceE-ospfv3-1] quit
[DeviceE] interface GigabitEthernet 2/0/1
[DeviceE-GigabitEthernet2/0/1] ospfv3 1 area 1
[DeviceE-GigabitEthernet2/0/1] quit
Configure RIPng
# Enable RIPng on Device E.
[DeviceE] ripng
[DeviceE-ripng-1] quit
[DeviceE] interface GigabitEthernet 2/0/2
[DeviceE-GigabitEthernet2/0/1] ripng 1 enable
# Enable RIPng on Device F.
<DeviceF> system-view
[DeviceF] ripng
[DeviceF-ripng-1] quit
[DeviceF] interface GigabitEthernet 2/0/1
[DeviceF-GigabitEthernet2/0/1] ripng 1 enable
[DeviceF-GigabitEthernet2/0/1] quit
[DeviceF] interface LoopBack 0
[DeviceF-LoopBack0] ripng 1 enable
[DeviceF-LoopBack0] quit
[DeviceF] interface LoopBack 1
# Configure Device E to redistribute OSPFv3 and direct routes to RIPng.
[DeviceE] ripng
[DeviceE-ripng-1] import-route direct
[DeviceE-ripng-1] import-route ospfv3
# Configure Device E to redistribute RIPng and direct routes to OSPFv3.
[DeviceE] ospfv3
[DeviceE-ospfv3-1] import-route direct
[DeviceE-ospfv3-1] import-route ripng
# Verify that Device E has routes to all networks.
[DeviceE] display ipv6 routing-table
Destinations : 15 Routes : 15
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 1::/64 Protocol : OSPFv3
NextHop : FE80::2E0:FCFF:FE58:124D Preference: 10
Interface : GE2/0/1 Cost : 2
Destination: 2::/64 Protocol : OSPFv3
Destination: 3::/64 Protocol : OSPFv3
Interface : GE2/0/1 Cost : 3
Destination: 4::/64 Protocol : Direct
NextHop : :: Preference: 0
Interface : GE2/0/1 Cost : 0
Destination: 4::2/128 Protocol : Direct
Destination: 5::/64 Protocol : Direct
Interface : GE2/0/2 Cost : 0
Destination: 5::1/128 Protocol : Direct
Destination: 11::1/128 Protocol : OSPFv3
Destination: 12::1/128 Protocol : OSPFv3
Destination: 13::1/128 Protocol : OSPFv3
Destination: 14::/64 Protocol : RIPng
NextHop : FE80::2E0:FCFF:FE11:19B5 Preference: 100
Interface : GE2/0/2 Cost : 1
Destination: 15::/64 Protocol : RIPng
Destination: FE80::/10 Protocol : Direct
Destination: FF00::/8 Protocol : Direct
Interface : NULL0
# Verify that other devices have routes to all networks. (Details not shown.)
# On Device C, configure IPv6 basic ACL 2000 to deny 12::1/64.
[DeviceC] acl ipv6 number 2000
[DeviceC-acl6-basic-2000] rule 0 deny source 12::1 64
[DeviceC-acl6-basic-2000] rule permit source any
[DeviceC-acl6-basic-2000] quit
# On Device C, use ACL 2000 to filter received routes.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] filter-policy 2000 import
# On Device D, configure IPv6 basic ACL 2000 to deny 15::1/64.
[DeviceD] acl ipv6 number 2000
[DeviceD-acl6-basic-2000] rule 0 deny source 15::1 64
[DeviceD-acl6-basic-2000] rule permit source any
[DeviceD-acl6-basic-2000] quit
# On Device D, use ACL 2000 to filter received routes.
[DeviceD] ospfv3
[DeviceD-ospfv3-1] filter-policy 2000 import
# On Device E, configure IPv6 basic ACL 2000 to deny 14::1/64.
[DeviceE] acl ipv6 number 2000
[DeviceE-acl6-basic-2000] rule 0 deny source 14::1 64
[DeviceE-acl6-basic-2000] rule permit source any
[DeviceE-acl6-basic-2000] quit
# On Device E, use ACL 2000 to filter routes redistributed from RIPng.
[DeviceE] ospfv3
[DeviceE-ospfv3-1] filter-policy 2000 export ripng 1
# Verify that Device C does not have a route to 12::/64.
[DeviceC] display ipv6 routing-table
Destinations : 13 Routes : 13
NextHop : FE80::2E0:FCFF:FE58:1245 Preference: 10
Destination: 2::/64 Protocol : Direct
Destination: 2::2/128 Protocol : Direct
Destination: 4::/64 Protocol : OSPFv3
Destination: 5::/64 Protocol : OSPFv3
NextHop : FE80::2E0:FCFF:FE58:1245 Preference: 150
Interface : GE2/0/1 Cost : 1
Destination: 13::/64 Protocol : Direct
Interface : Loop0 Cost : 0
Destination: 13::1/128 Protocol : Direct
Destination: 15::/64 Protocol : OSPFv3
Interface : NULL0
# Verify that Marketing department 1 cannot reach R&D department 1.
[DeviceC] ping ipv6 -a 13::1 12::1
Ping6(56 data bytes) 13::1 --> 12::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping6 statistics for 12::1 ---
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
# Verify that Device D does not have a route to 15::/64.
[DeviceD] display ipv6 routing-table
Destinations : 14 Routes : 14
NextHop : FE80::2A0:FCFF:FE00:5815 Preference: 10
Destination: 3::/64 Protocol : Direct
Destination: 3::3/128 Protocol : Direct
NextHop : FE80::2A0:FCFF:FE00:5815 Preference: 150
Destination: 11::/64 Protocol : Direct
Destination: 11::1/128 Protocol : Direct
Destination: 12::/64 Protocol : Direct
Interface : Loop1 Cost : 0
Destination: 12::1/128 Protocol : Direct
Interface : NULL0 Cost : 0
Interface : NULL0
# Verify that the After-sale service department cannot reach Marketing department 2.
[DeviceD] ping ipv6 -a 11::1 15::1
Ping6(56 data bytes) 11::1 --> 15::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping6 statistics for 15::1 ---
# Verify that R&D department 1 cannot reach Marketing department 2.
[DeviceD] ping ipv6 -a 12::1 15::1
Ping6(56 data bytes) 12::1 --> 15::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
The output on Device C and Device D shows that Device E has filtered the route destined for R&D development 2.
Configuration files
· Device A:
ospfv3 1
router-id 6.6.6.6
area 0.0.0.0
area 0.0.0.1
area 0.0.0.2
interface GigabitEthernet2/0/1
ospfv3 1 area 0.0.0.0
ipv6 address 1::1/64
interface GigabitEthernet2/0/2
ospfv3 1 area 0.0.0.2
ipv6 address 2::1/64
interface GigabitEthernet2/0/3
ospfv3 1 area 0.0.0.1
ipv6 address 4::1/64
· Device B:
ospfv3 1
router-id 5.5.5.5
area 0.0.0.0
area 0.0.0.2
area 0.0.0.3
ipv6 address 1::2/64
ospfv3 1 area 0.0.0.3
ipv6 address 3::1/64
· Device C:
ospfv3 1
router-id 4.4.4.4
area 0.0.0.2
interface LoopBack0
ipv6 address 13::1/64
ipv6 address 2::2/64
rule 0 deny source 12::/64
rule 5 permit
· Device D:
ospfv3 1
router-id 3.3.3.3
area 0.0.0.3
interface LoopBack0
ipv6 address 11::1/64
interface LoopBack1
ipv6 address 12::1/64
ipv6 address 3::3/64
rule 0 deny source 15::/64
rule 5 permit
· Device E:
ospfv3 1
router-id 2.2.2.2
import-route direct
import-route ripng 1
area 0.0.0.1
ripng 1
import-route direct
import-route ospfv3 1
ipv6 address 4::2/64
ipv6 address 5::1/64
ripng 1 enable
rule 0 deny source 14::/64
rule 5 permit
· Device F:
ripng 1
interface LoopBack0
ipv6 address 14::1/64
ripng 1 enable
interface LoopBack1
ipv6 address 15::1/64
ripng 1 enable
ipv6 address 5::2/64
ripng 1 enable
Related documentation
· H3C MSR Series Routers Layer 3—IP Routing Command Reference(V7)
· H3C MSR Series Routers Layer 3—IP Routing Configuration Guide(V7)
