- H3C MSR Routers Configuration Examples-6W100
- 01-H3C MSR Routers RBAC Configuration Examples (Comware V7)
- 02-H3C MSR Routers Ethernet Link Aggregation Configuration Examples (Comware V7)
- 03-H3C MSR Routers Port Isolation Configuration Examples (Comware V7)
- 04-H3C MSR Routers VLAN Configuration Examples (Comware V7)
- 05-H3C MSR Routers QinQ Configuration Examples (Comware V7)
- 06-H3C MSR Routers PPP Configuration Examples (Comware V7)
- 07-H3C MSR Routers OSPF Configuration Examples (Comware V7)
- 08-H3C MSR Routers OSPFv3 Configuration Examples (Comware V7)
- 09-H3C MSR Routers IPv6 IS-IS Configuration Examples (Comware V7)
- 10-H3C MSR Routers BGP Configuration Examples (Comware V7)
| 02-H3C MSR Routers Ethernet Link Aggregation Configuration Examples (Comware V7) | 67.27 KB |
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides Ethernet link aggregation configuration examples.
This document applies to Comware V7-based MSR routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring Layer 3 link aggregation
Network requirements
On the network as shown in Figure 1, perform the following tasks:
· Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
· Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Software version used
This configuration example was created and verified on R0106.
In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, H3C recommends using dynamic aggregation.
Configuration procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡ Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡ Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign ports Ten-GigabitEthernet 2/1/1 through Ten-GigabitEthernet 2/1/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 2/1/1 to gigabitethernet 2/1/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
2. Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
· Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port Status: S -- Selected, U -- Unselected
G -- Defaulted, H -- Expired
Aggregation Mode: Static
Port Status Priority Oper-Key
GE2/1/1 S 32768 1
GE2/1/2 S 32768 1
GE2/1/3 S 32768 1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
· Link aggregation configuration information when the dynamic aggregation mode is used:
Aggregation Mode: Dynamic
Local:
Port Status Priority Oper-Key Flag
GE2/1/1 S 32768 1 {ACDEF}
GE2/1/2 S 32768 1 {ACDEF}
GE2/1/3 S 32768 1 {ACDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE2/1/1 1 32768 1 0x8000, 000f-e267-57ad {ACDEF}
GE2/1/2 2 32768 1 0x8000, 000f-e267-57ad {ACDEF}
GE2/1/3 3 32768 1 0x8000, 000f-e267-57ad {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
· Device A:
¡ In the static aggregation mode:
interface route-aggregation1
¡ In the dynamic aggregation mode:
interface GigabitEthernet2/1/1
port link-mode route
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
· Device B:
The configuration file on Device B is similar as the configuration file on Device A.
Related documentation
· H3C MSR Series Routers Layer 2—LAN Switching Command Reference (V7)
· H3C MSR Series Routers Layer 2—LAN Switching Configuration Guide (V7)
