- H3C MSR Routers Configuration Examples-6W100
- 01-H3C MSR Routers RBAC Configuration Examples (Comware V7)
- 02-H3C MSR Routers Ethernet Link Aggregation Configuration Examples (Comware V7)
- 03-H3C MSR Routers Port Isolation Configuration Examples (Comware V7)
- 04-H3C MSR Routers VLAN Configuration Examples (Comware V7)
- 05-H3C MSR Routers QinQ Configuration Examples (Comware V7)
- 06-H3C MSR Routers PPP Configuration Examples (Comware V7)
- 07-H3C MSR Routers OSPF Configuration Examples (Comware V7)
- 08-H3C MSR Routers OSPFv3 Configuration Examples (Comware V7)
- 09-H3C MSR Routers IPv6 IS-IS Configuration Examples (Comware V7)
- 10-H3C MSR Routers BGP Configuration Examples (Comware V7)
| 06-H3C MSR Routers PPP Configuration Examples (Comware V7) | 83.23 KB |
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides PPP configuration examples.
This document applies to Comware V7-based MSR routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of PPP, MP, and PPPoE.
Example: Configuring MP and CHAP
Network requirements
As shown in Figure 1, bind Serial 2/0 and Serial 2/1 into an MP bundle on an MP-group interface. Specify CHAP as the authentication mode for each PPP link.
Software version used
This configuration example was created and verified on R0106.
When you configure MP and CHAP, follow these restrictions and guidelines:
· The username and password on each end must be the same for CHAP authentication.
· To bring up the configured serial interfaces, use the shutdown and then undo shutdown commands.
· Make sure you create a network access user.
Configuration procedures
Configuring Device A
# Create a user account for Device B.
[DeviceA] local-user userb class network
# Set a password for the user account.
[DeviceA-luser-network-userb] password simple hello
# Set the service type of the user account to PPP.
[DeviceA-luser-network-userb] service-type ppp
[DeviceA-luser-network-userb] quit
# Enable PPP encapsulation on Serial 2/0.
[DeviceA] interface serial 2/0
[DeviceA-Serial2/0] link-protocol ppp
# Set the authentication mode to CHAP.
[DeviceA-Serial2/0] ppp authentication-mode chap domain system
[DeviceA-Serial2/0] quit
# Enable PPP encapsulation on Serial 2/1.
[DeviceA] interface serial 2/1
# Configure local authentication for the PPP user in the default ISP domain system.
[DeviceA] domain system
[DeviceA-isp-system] authentication ppp local
# Create an MP-group interface, and assign an IP address to it.
[DeviceA] interface mp-group 1
[DeviceA-MP-group1] ip address 1.1.1.1 24
[DeviceA-MP-group1] quit
# Configure interface Serial 2/0.
[DeviceA-Serial2/0] ppp mp mp-group 1
[DeviceA-Serial2/0] shutdown
[DeviceA-Serial2/0] undo shutdown
# Configure interface Serial 2/1.
[DeviceA-Serial2/1] ppp mp mp-group 1
[DeviceA-Serial2/1] shutdown
[DeviceA-Serial2/1] undo shutdown
[DeviceA-Serial2/1] quit
Configuring Device B
[DeviceB] interface serial 2/0
[DeviceB-Serial2/0] link-protocol ppp
# Configure the username and password for CHAP authentication.
[DeviceB-Serial2/0] ppp chap user userb
[DeviceB-Serial2/0] ppp chap password simple hello
[DeviceB-Serial2/0] quit
[DeviceB] interface serial 2/1
[DeviceB-Serial2/1] link-protocol ppp
[DeviceB-Serial2/1] ppp chap user userb
[DeviceB-Serial2/1] ppp chap password simple hello
[DeviceB-Serial2/1] quit
[DeviceB] interface mp-group 1
[DeviceB-Mp-group1] ip address 1.1.1.2 24
[DeviceB-Mp-group1] quit
# Add interface Serial 2/0 to MP-group 1, and bring up the interface.
[DeviceB-Serial2/0] ppp mp mp-group 1
[DeviceB-Serial2/0] shutdown
[DeviceB-Serial2/0] undo shutdown
# Add interface Serial 2/1 to MP-group 1, and bring up the interface.
[DeviceB-Serial2/1] ppp mp mp-group 1
[DeviceB-Serial2/1] shutdown
[DeviceB-Serial2/1] undo shutdown
# Display MP information on Device A.
Template: MP-group1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: MP-group1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group1
Sequence format: long (rcv)/long (sent)
Bundle Up Time: 2014/07/22 16:51:40:835
0 lost fragments, 5 reordered, 0 unassigned, 0 interleaved
Sequence: 4 (rcv)/5 (sent)
Active member channels: 2 members
Serial2/0 Up-Time:2014/07/22 16:51:40:836
Serial2/1 Up-Time:2014/07/22 16:51:53:542
# Display information about interface MP-group 1 on Device A.
[DeviceA] display interface mp-group 1
MP-group1
Current state: UP
Line protocol state: UP
Description: MP-group1 Interface
Bandwidth: 128kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds
Internet Address is 1.1.1.1/24 Primary
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 128000 bps
Last 300 seconds input rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Last 300 seconds output rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Input: 8 packets, 466 bytes, 0 drops
Output: 8 packets, 456 bytes, 0 drops
# Ping Device B from Device A.
Ping 1.1.1.2 (1.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 1.1.1.2: icmp_seq=0 ttl=255 time=25.749 ms
56 bytes from 1.1.1.2: icmp_seq=1 ttl=255 time=25.751 ms
56 bytes from 1.1.1.2: icmp_seq=2 ttl=255 time=25.521 ms
56 bytes from 1.1.1.2: icmp_seq=3 ttl=255 time=25.512 ms
56 bytes from 1.1.1.2: icmp_seq=4 ttl=255 time=25.599 ms
--- Ping statistics for 1.1.1.2 ---
round-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms
<DeviceA>%Jul 22 17:08:22:460 2014 DeviceA PING/6/PING_STATISTICS: Ping statisti
cs for 1.1.1.2: 5 packets transmitted, 5 packets received, 0.0% packet loss, rou
nd-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms.
Configuration files
interface Serial2/0
ppp mp MP-group1
interface Serial2/1
ppp mp MP-group1
interface MP-group1
ip address 1.1.1.1 255.255.255.0
local-user 123 class network
password cipher $c$3$5ulb/vg58eiBIm5EnilnsZ2cS2Cmwg==
service-type ppp
· Device B:
interface Serial2/0
ppp chap password cipher $c$3$4kD4T3bLZ/lngijhEKIS70/oTbNSkw==
ppp chap user 123
ppp mp MP-group1
interface Serial2/1
ppp chap password cipher $c$3$mVlcV3W+YQBgmxKePKpZV9tTcaFhXg==
ppp chap user 123
ppp mp MP-group1
interface MP-group1
ip address 1.1.1.2 255.255.255.0
Related documentation
· H3C MSR Series Routers Layer 2—WAN Access Command Reference(V7)
· H3C MSR Series Routers Layer 2—WAN Access Configuration Guide(V7)
