H3C S10500 Switch Series Installation Guide-6W208
HomeSupportSwitchesS10500 SeriesInstall & UpgradeInstallation GuidesH3C S10500 Switch Series Installation Guide-6W208
06-Chapter 6 Troubleshooting
06-Chapter 6 Troubleshooting 90.04 KB
6 Troubleshooting
This chapter describes how to troubleshoot your switch.
TIP
TIP:
Noncompliant operating environments might cause switch failures. To ensure correct operation of the switch, regularly clean the switch and check the ambient operating environment against the requirements in "Preparing for installation." For the spare switches in storage, regularly perform power-on tests.
Troubleshooting methods
When your switch fails, you can use the following methods to troubleshoot the switch:
·     You can use related commands at the CLI to display device information, and locate the failures. If any configuration error is found, re-configure the switch or restore the factory-default settings.
·     The MPU provides LEDs for the fans and modules. You can locate the failures according to the LED status on the MPU. For more information about the LED status on the MPU, see "MPU LEDs."
·     The MPU or service module of the switch provides port status LEDs, with which you can detect port failures. For more information about the LED status on the service module, see "Service module LEDs."
If you cannot locate failures by following the guidelines in this chapter, contact the local agents or technical support engineers. For more information, see "Technical support."
General guidelines
IMPORTANT
IMPORTANT:
To prevent an issue from causing loss of configuration, save the configuration each time you finish configuring a feature. For configuration recovery, regularly back up the configuration to a remote server.
When you troubleshoot the switch, follow these general guidelines:
·     To help identify the cause of the issue, collect system and configuration information, including:
¡     Symptom, time of failure, and configuration.
¡     Network topology information, including the network diagram, port connections, and points of failure.
¡     Log messages and diagnostic information.
¡     Physical evidence of failure:
-     Photos of the hardware.
-     Status of the LEDs.
¡     Steps you have taken, such as reconfiguration, cable swapping, and reboot.
¡     Output from the commands executed during the troubleshooting process.
·     To ensure safety, wear an ESD wrist strap when you replace or maintain a hardware component.
Configuration terminal display issues
No display on the configuration terminal
Symptom
The configuration terminal has no display when the switch is powered on.
Solution
To resolve the issue:
1.     Verify that the power system is operating correctly.
2.     Verify that the MPU is operating correctly.
3.     Verify that the console cable is connected correctly to the console port on the MPU.
4.     Verify that the console cable is connected to the serial port that has been specified and set on the terminal.
5.     Verify that the console cable is in good condition.
6.     If the issue persists, contact H3C Support.
Garbled display on the configuration terminal
Symptom
The configuration terminal has a garbled display.
Solution
1.     Verify that the configuration terminal settings match those of the console port on the MPU, as follows:
¡     Baud rate—9,600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Flow control—None.
If you modify the settings for the console port, modify the terminal settings accordingly.
2.     If the issue persists, contact H3C Support.
Power module failure
Symptom
One or both LEDs on a power module are off or not green. (On the MPU, the PWR OK LED is off and the PWR FAIL LED is on.)
Solution
1.     Use the LED indications to assess the power module status and resolve the issues accordingly.
See "Power module LEDs" for the LED descriptions.
·     If the AC or INP OK LED is off, the power module has transitioned to a self-protection state due to no or low power input voltage.
·     If the DC LED is orange, the power module has transitioned to the overtemperature protection state. Maintain adequate ventilation and compliant environment for the switch.
·     If the DC LED is red, the power module has transitioned to a self-protection state because of a power output issue. Examine the power module for output short circuit, output overcurrent, output overvoltage, input undervoltage, or remote power disconnection.
·     The DC LED is also red if the input of the power module is disconnected while the other power module is operating correctly. You can connect the input or keep the input disconnected as needed.
After a power module is disconnected from its power source, it is normal that the power module LEDs stay on for several seconds.
2.     Examine the power module.
¡     Verify that the power module is compatible with the switch.
¡     Verify that the power module is operating correctly.
Use the display power command to display the power module status. If the state is Absent, no power module is present or the power module is not securely installed in the slot. If the state is Fault, the power module cannot provide power input.
3.     Verify that the power cord is connected correctly and is in good condition.
4.     Verify that the power source is operating correctly and provides a voltage in the acceptable range.
5.     If the switch has empty power module slots, remove the power module, and install it in an empty power module slot after all its LEDs are off. Verify that the power module can operate correctly.
6.     Install a new power module of the same model in the same slot, and connect it to the same power source. If the new power module can operate correctly, the old power module is faulty. Replace the old power module.
7.     If the issue persists, collect the operating information of the switch, and contact H3C Support.
Fan tray failure
Symptom
The OK LED of a fan tray is off and the FAIL LED is on. (On the MPU, the FAN OK LED is off and the FAN FAIL LED is on.)
If both the OK and FAIL LED are off, no power is present on the fan tray. Verify that the power modules are operating correctly. For more information, see "Power module failure."
Solution
1.     Execute the display fan command to display the operating state of the fan tray.
¡     If the state is Absent, no fan tray is present or the fan tray is not securely installed. Reinstall the fan tray to be sure the fan tray is installed securely.
¡     If the state is Fault, go to the next steps.
2.     Verify that the ambient temperature is in the acceptable range.
3.     Ensure adequate ventilation for the switch.
¡     Make sure no objects block the air inlet and outlet vents.
¡     If the switch has air filters, remove and clean the air filters.
¡     Verify that filler panels are installed in empty slots.
4.     If the issue persists, collect the operating information of the switch, and contact H3C Support.
MPU failure
Symptom
The RUN and ALM LEDs for the MPU indicate a failure.
For the LED descriptions, see "MPU LEDs."
Solution
1.     Use the LED indications to access the MPU status and resolve the issues accordingly.
2.     Verify that the power modules operate correctly. For more information, see "Power module failure."
3.     Verify that the system software image is present and correct.
Log in to the MPU through the console port and restart the MPU. If BootWare reports that a CRC error has occurred or that no system software image is available, reload the system software image.
4.     Examine the MPU.
a.     Verify that the MPU is compatible with the switch.
b.     Verify that the MPU is installed securely on the switch. You can remove and reinstall the MPU to make sure the MPU is installed securely.
c.     Press the RESET button on the MPU to reset the MPU.
5.     If the switch has an empty MPU slot, install the MPU in the slot to verify that the MPU can operate correctly.
6.     If the issue persists, collect the operating information of the switch, and contact H3C Support.
Service module or switching fabric module failure
Symptom
On the MPU, the RUN and ALM LEDs for the service module or switching fabric module indicate a failure.
Solution
1.     Use the LED indications to access the service module or switching fabric module status and resolve the issues accordingly.
2.     Verify that the MPU is operating correctly. For more information, see "MPU failure."
3.     Examine the service module or switching fabric module.
a.     Verify that the service module or switching fabric module is compatible with the switch.
b.     Verify that the service module or switching fabric module is installed securely.
You can remove and reinstall the service module or switching fabric module to make sure the service module or switching fabric module is installed securely in the slot.
4.     Verify that the software version supports the module. If the software version does not support the module, upgrade the software to a compatible version.
5.     Examine the power system of the switch.
a.     Verify that the power modules operate correctly. For more information, see "Power module failure."
b.     Calculate the total power consumption to verify that the power modules can provide enough power to support the switch. For more information, see "Power modules."
6.     If the switch has an empty slot, install the service module or switching fabric module in an empty slot, and verify that it can operate correctly.
Interface failure
Symptom
The LED for an interface connected to the network is off.
A management Ethernet interface and XFP interface each has two LEDs, LINK and ACT. The LED mentioned in this section for such an interface refers to the LINK LED. Each interface of any other type has only one LED.
Solution
1.     Verify that the MPU or the service module where the interface resides is operating correctly. For more information, see "MPU failure" or "Service module or switching fabric module failure."
2.     Examine the cable.
a.     Verify that the cable is connected correctly.
For the cable connection procedure, see "Connecting the switch to the network."
b.     Verify that the cable is in good condition.
Use the cable to connect two interfaces of the same type that operate correctly. If the LEDs for the two interfaces are on, the cable is normal. If the LEDs for the two interfaces are off, the cable is faulty. Use a compliant cable to connect the interface. For more information about the compliant cables, see "Appendix D Cables."
3.     Examine the interface.
a.     Verify that the interface and its peer are the same in speed and duplex settings.
b.     If the interface uses a transceiver module, verify that the transceiver module type is compatible with the interface and the cable. You can also replace the transceiver module to be sure a correctly operating transceiver module is used.
c.     If the interface is a combo interface, make sure the port used for connection is activated.
·     A combo interface is a logical interface that contains one fiber port (Gigabit/100-Mbps SFP port) and one copper port (10/100/1000BASE-T GE port). The two ports share one interface view and cannot work simultaneously. You can use the combo enable { copper | fiber } command to activate one port. The other port is disabled automatically.
·     If the interface is brought down by the shutdown command, use the undo shutdown command to bring up the interface.
·     If the interface is found to be faulty, you can connect the cable to an idle interface of the same type, if any.
Technical support
If the failures still exist, contact the agents or technical support engineers. Before contacting the customer service, prepare the following information to help the agents solve the problem as quickly as possible:
·     Arrival time of the switch
·     Serial number of the chassis (located on a label on the right of the rear panel)
·     Software version (Which you can view by using the display version command.)
·     Maintenance agreement or warranty card
·     Brief problem description
·     Brief explanation of the troubleshooting measures that have been taken
You can contact the customer service through the H3C website, or email.
Website: http://www.h3c.com
E-mail: [email protected]
