H3C WA Series Access Points Web Configuration Guide(R1507P09)-6W101
HomeSupportConfigure & DeployUser ManualsH3C WA Series Access Points Web Configuration Guide(R1507P09)-6W101
00-Preface
00-Preface 119.86 KB
Preface
The H3C Access Points Web-Based Configuration Guide describes the web functions of the H3C Access Points, such as quick start, web overview, wireless service configuration, security and authentication related configurations, QoS configuration, and advanced settings.
The interface types and output information might vary by device model.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C Access Points
Conventions
This section describes the conventions used in the documentation.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card.
We appreciate your comments.
