H3C WA Series Access Points Web Configuration Guide(R1507P09)-6W101
HomeSupportConfigure & DeployUser ManualsH3C WA Series Access Points Web Configuration Guide(R1507P09)-6W101
01-Web Overview
01-Web Overview 281.37 KB
Web overview
The interface types and output information vary by device model and radio type.
The device provides Web-based configuration interfaces for visual device management and maintenance.
Figure 1 Web-based network management operating environment
Logging in to the Web interface
Follow these guidelines when you log in to the Web interface:
·          The default Web login information depends on the device model.
·          The PC where you configure the device is not necessarily the Web-based network management terminal. A Web-based network management terminal is a PC (or another terminal) used to log in to the Web interface and is required to be reachable to the device.
·          If you click the verification code displayed on the Web login page, you can get a new verification code.
·          If you have configured a fix verification code by using the web captcha command, you can also use the fixed verification code to log in to the device. For more information, see Fundamentals Configuration Guide.
·          Up to 5 users can concurrently log in to the device through the Web interface.
·          You can also log in to the Web interface through HTTPS, but you must enable HTTPS on the device, and the address you input in the address bar must start with https://. For more information, see "Configuring service management."
·          If you have configured the auto authentication mode for an HTTPS login user by using the web https-authorization mode command, the user is automatically authenticated by the PKI certificate, without inputting any username and password. For more information, see Fundamentals Configuration Guide.
You can use the following default settings to log in to the Web interface through HTTP:
·          Username—admin
·          Password—h3capadmin
·          IP address of VLAN-interface 1 on the device—192.168.0.50.
To log in to the Web interface of the device from a PC:
1.        Connect the Ethernet port of the device to the PC by using a crossover Ethernet cable.
By default, all ports belong to VLAN 1.
2.        Configure an IP address for the PC and make sure the PC and the device can reach each other.
For example, assign the PC an IP address (for example, 192.168.0.2) on the same subnet as 192.168.0.50.
3.        Open the browser and input the login information:
a.    Type the IP address http://192.168.0.50 in the address bar and press Enter.
The login page of the Web interface (see Figure 2) appears.
b.    Enter the username admin and the password h3capadmin, and the verification code, select the language (English and Chinese are supported at present), and click Login.
Figure 2 Login page of the Web interface
Logging out of the Web interface
CAUTION
CAUTION:
A logged-in user cannot automatically log out by directly closing the browser.
As shown in Figure 3, click Logout in the upper-right corner of the Web interface to quit Web-based network management.
The system does not save the current configuration before you log out of the Web interface. H3C recommends you to save the current configuration before logout.
Introduction to the Web interface
The Web interface is composed of three parts: navigation tree, title area, and body area, as shown in Figure 3.
Figure 3 Web-based configuration interface
(1) Navigation area
(2) Body area
(3) Title area
·          Navigation area—Organizes the Web-based NM function menus in the form of a navigation tree, where you can select function menus as needed. The result is displayed in the body area.
·          Body area—The area where you can configure and display a function.
·          Title area—On the left, displays the path of the current configuration interface in the navigation area; on the right, provides the Save button to quickly save the current configuration, the Help button to display the Web related help information, and the Logout button to log out of the Web interface.
Web user level
Web user levels, ranging from low to high, are visitor, monitor, configure, and management. A user with a higher level has all the operating rights of a user with a lower level.
·          Visitor—Users of this level can perform the ping and traceroute operations, but they can neither access the device data nor configure the device.
·          Monitor—Users of this level can only access the device data but cannot configure the device.
·          Configure—Users of this level can access data from the device and configure the device, but they cannot upgrade the host software, add/delete/modify users, or backup/restore the application file.
·          Management—Users of this level can perform any operations for the device.
Introduction to the Web-based NM functions
User level in Table 1 indicates that users of this level or users of a higher level can perform the corresponding operations.
Table 1 Description for Web-based NM functions
Function menu
User level
Quick Start
Perform quick configuration of the device.
Configure
Summary
Device
Display and refresh system resource state, device information, device interface information, and recent system operation logs.
Monitor
Wlan Service
Display the information of the queried WLAN service, including the detailed information, statistics, and connection history.
Monitor
Radio
Display related information of a radio, including the wireless service related to the radio and the radio interface statistics.
Monitor
WDS
Display related information of WDS, including state and neighbor information.
Monitor
Client
Display the detailed information and statistics of the client.
Monitor
Clear statistics of the client, disconnect the connection, and add the client into the blacklist.
Configure
Device
Basic
Set sysname
Display and configure the system name.
Configure
Set idle timeout
Display and configure the idle timeout period for a logged-in user.
Configure
Device Maintenance
Software Upgrade
Upload the file to be upgraded from the local host to upgrade the system software.
Management
Reboot
Reboot the device.
Management
Diagnostic Information
Generate a diagnostic information file, view the file, or save the file to the local host.
Management
System Time
System Time
Display the system date and time.
Monitor
Set the system time.
Configure
Time Zone
Display the system time zone and daylight saving time settings.
Monitor
Configure the system time zone and daylight saving time.
Configure
System Time
System Time
Display and set the system time.
Configure
Time Zone
Display and set the time zone of the system.
Configure
Syslog
Loglist
Display and refresh system logs.
Monitor
Clear system logs.
Configure
Loghost
Display and configure the loghost.
Configure
Logset
Display and configure the buffer capacity, and refresh interval for displaying system logs.
Configure
Configuration management
Backup
Back up the configuration file for the next startup to the host of the current user.
Management
Restore
Upgrade the configuration file on the host of the current user to the device for the next startup.
Management
Save
Save the current configuration to the configuration file for the next startup.
Configure
Initialize
Restore the system to factory defaults.
Management
File management
Manage files on the device, including displaying file list, downloading a file, uploading a file, removing a file, and setting the main boot file.
Management
Interface Management
Display interface information and statistics.
Monitor
Create, modify, and delete an interface, and clear interface statistics.
Configure
TR-069
Display TR-069 configuration.
Monitor
Congfigure TR-069.
Configure
User Management
Summary
Display brief information about FTP and Telnet users.
Monitor
Super Password
Configure the password for a lower-level user to switch from the current access level to the management level.
Management
Create
Create an FTP or Telnet user.
Management
Modify
Modify FTP or Telnet user information.
Management
Remove
Remove an FTP or a Telnet user.
Management
Switch To Management
Switch the current user level to the management level.
Monitor
SNMP
Display SNMP configuration information.
Monitor
Configure SNMP.
Management
Loopback Test
Perform the loopback test on Ethernet interfaces.
Configure
Network
MAC
MAC
Display MAC address information.
Monitor
Create or remove MAC addresses.
Configure
Config
Display and configure MAC address aging time.
Configure
VLAN
VLAN
Display all VLANs on the device and information about their member ports.
Monitor
Create, modify, and delete VLANs.
Configure
Port
Display VLANs to which a port on the device belongs.
Monitor
Modify the VLANs to which a port belongs.
Configure
ARP Management
ARP Table
Display ARP table information.
Monitor
Add, modify, or delete an ARP entry.
Configure
Gratuitous ARP
Display configuration information of gratuitous ARP.
Monitor
Configure gratuitous ARP.
Configure
IGMP Snooping
Basic
Display global IGMP Snooping configuration information and the IGMP Snooping configuration information in a VLAN, and the IGMP Snooping multicast entry information.
Monitor
Configure IGMP Snooping globally and in a VLAN.
Configure
Advance
Display the IGMP Snooping configuration information on a port.
Monitor
Configure IGMP Snooping on a port.
Configure
IPv4 Routing
Summary
Display the IPv4 active route table.
Monitor
Create
Create an IPv4 static route.
Configure
Remove
Delete the selected IPv4 static routes.
Configure
IPv6 Routing
Summary
Display the IPv6 active route table.
Monitor
Create
Create an IPv6 static route.
Configure
Remove
Delete the selected IPv6 static routes.
Configure
DHCP
DHCP Server
Display the DHCP service status, the DHCP address pool information, the DHCP server status on an interface, and information about an address assigned from a DHCP address pool.
Monitor
Set the DHCP service status, add, modify, or delete a DHCP address pool, and modify the DHCP server status on an interface.
Configure
DNS
Static Domain Name Resolution
Display, create, modify, or delete a static host name-to-IP address mapping.
Configure
Dynamic Domain Name Resolution
Display and configure related parameters for dynamic domain name resolution. Display, create, or delete an IP address and the domain name suffix.
Configure
PPPoE
Client
Display PPPoE client information.
Monitor
Create, modify, or delete a PPPoE client.
Configure
Session
Display the summary and statistics of a PPPoE session.
Monitor
Service Management
Display the states of the services: enabled or disabled.
Configure
Specify whether to enable various services, and sets related parameters.
Management
Diagnostic Tools
IPv4 Ping
Ping an IPv4 address or host and display the result.
Visitor
IPv6 Ping
Ping an IPv6 address or host and display the result.
Visitor
Trace Route
Perform trace route operations and display the result.
Visitor
WLAN Service
Access Service
Display an access service.
Monitor
Create and configure an access service, and add a MAC authentication list.
Configure
WDS
WDS Setup
Display a WDS service.
Monitor
Configure a WDS service.
Configure
WDS Global Setup
Display WDS global configuration.
Monitor
Configure WDS global parameters.
Configure
Radio
Radio
Display radio status, including radio mode and radio status.
Monitor
Configure radio parameters, including 802.11n settings.
Configure
Rate
Display rate settings.
Monitor
Configure 802.11n rates, including MCS index.
Configure
Scan
Display channel scanning, including scanning mode, scanning type and scanning interval; view the AP operating mode (normal, monitor, and hybrid).
Monitor
Configure channel scanning, including scanning mode and scanning type; allows you to set the AP operating mode (normal, monitor, and hybrid).
Configure
Calibration
Channel Information
Display or refresh AP status, including the channel where an AP is operating, and power.
Monitor
Parameter Setting
Display radio parameters.
Monitor
Configure radio parameters.
Configure
Channel Detection
Display detection records and history records.
Monitor
Display and refresh detection records and history records.
Configure
Antenna
Configure the antenna of an AP.
Configure
Authentication
AAA
Domain Setup
Display ISP domain configuration information.
Monitor
Add and remove ISP domains.
Management
Authentication
Display the authentication method configuration information of an ISP domain.
Monitor
Specify authentication methods for an ISP domain.
Management
Authorization
Display the authorization method configuration information of an ISP domain.
Monitor
Specify authorization methods for an ISP domain.
Management
Accounting
Display the accounting method configuration information of an ISP domain.
Monitor
Specify accounting methods for an ISP domain.
Management
RADIUS
Display and add, modify, and delete a RADIUS scheme.
Management
HWTACACS
Server Configuration
Display and modify HWTACACS server configuration.
Management
Parameter Configuration
Display and modify HWTACACS parameter configuration.
Management
Users
Local User
Display local users’ configuration information.
Monitor
Add, modify, and remove local users.
Management
User Group
Display user groups’ configuration information.
Monitor
Add, modify, and remove user groups.
Management
Guest
Display guest users’ configuration information.
Monitor
Add, modify, and remove guest users.
Management
PKI
Entity
.Display information about PKI entities.
Monitor
Add, modify, and delete a PKI entity.
Configure
Domain
Display information about PKI domains.
Monitor
Add, modify, and delete a PKI domain.
Configure
Certificate
Display the certificate information of PKI domains and the contents of a certificate.
Monitor
Generate a key pair, destroy a key pair, retrieve a certificate, request a certificate, and delete a certificate.
Configure
CRL
Display the contents of the CRL.
Monitor
Receive the CRL of a domain.
Configure
WIDS
WIDS Setup
Display IDS configuration.
Monitor
Configure IDS detection, including flood attack detection, spoofing attack detection, and weak IV detection.
Configure
History Record
Display IDS attack detection history.
Monitor
Clear history record of IDS attack detection and add the detected devices that initiate attacks to blacklist.
Configure
Statistics
Display statistics of IDS attack detection.
Monitor
Clear the statistics.
Configure
Blacklist and White list
Blacklist
Display dynamic and static blacklists.
Monitor
Clear dynamic blacklist and static blacklist; enable dynamic blacklist; add entries to the static blacklist.
Configure
White List
Display white list.
Monitor
Clear white list, and add entries to the white list.
Configure
User Isolation
Enable or disable user isolation.
Configure
QoS
Time Range
Display
Display time range configuration information.
Monitor
Add
Create a time range.
Configure
Delete
Delete a time range.
Configure
ACL IPv4
Display
Display IPv4 ACL configuration information.
Monitor
Add
Create an IPv4 ACL.
Configure
Basic Setup
Configure a rule for a basic IPv4 ACL.
Configure
Advanced Setup
Configure a rule for an advanced IPv4 ACL.
Configure
Link Setup
Create a rule for an Ethernet frame header ACL.
Configure
Wlan Setup
Create a rule for a WLAN-AP ACL.
Configure
Delete
Delete an IPv4 ACL or its rules.
Configure
ACL IPv6
Display
Display IPv6 ACL configuration information.
Monitor
Add
Create an IPv6 ACL.
Configure
Basic Setup
Configure a rule for a basic IPv6 ACL.
Configure
Advanced Setup
Configure a rule for an advanced IPv6 ACL.
Configure
Delete
Delete an IPv6 ACL or its rules.
Configure
Wireless QoS
Wireless QoS
Display wireless QoS, including SVP mapping, CAC admission policy, radio EDCA and client EDCA.
Monitor
Configure wireless QoS, including SVP mapping, CAC admission policy, radio EDCA and client EDCA.
Configure
Radio Statistics
Display radio statistics, including WMM status and detailed radio information.
Monitor
Display radio statistics, including WMM status and detailed radio information, and clear the radio statistics.
Configure
Client Statistics
Display client statistics, including WMM status and detailed client information.
Monitor
Display client statistics, including WMM status and detailed client information, and clear the client statistics.
Configure
Client Rate Limit
Display the configured client rate limit information.
Monitor
Configure and modify client rate limiting mode, direction and rate.
Configure
Bandwidth Guarantee
Display bandwidth guarantee configuration and bandwidth information.
Monitor
Configure bandwidth guarantee.
Configure
Trust Mode
Display priority trust mode configuration information.
Management
Configure the priority trust mode.
Management
Classifier
Display
Display classifier configuration information.
Monitor
Add
Create a class.
Configure
Setup
Configure the classification rules for a class.
Configure
Delete
Delete a class or its classification rules.
Configure
Behavior
Display
Display traffic behavior configuration information.
Monitor
Add
Create a traffic behavior.
Configure
Setup
Configure actions for a traffic behavior.
Configure
Delete
Delete a traffic behavior.
Configure
QoS Policy
Display
Display QoS policy configuration information.
Monitor
Add
Create a QoS policy.
Configure
Setup
Configure the classifier-behavior associations for a QoS policy.
Configure
Delete
Delete a QoS policy or its classifier-behavior associations.
Configure
Port Policy
Display
Display the QoS policy applied to a port.
Monitor
Setup
Apply a QoS policy to a port.
Configure
Delete
Remove the QoS policy from the port.
Configure
Service Policy
Display the QoS policy applied to a WLAN-ESS port.
Monitor
Configure the QoS policy applied to a WLAN-ESS port.
Configure
Advanced Settings
District code
Display the district code.
Monitor
Modify the district code.
Configure
Switch to AP
Display the AP working mode switching information.
Monitor
Switch the working mode of an AP.
Configure
Continuous Transmit
Display the continuous transmitting mode of an AP.
Monitor
Switch the continuous transmitting mode of an AP.
Configure
Uplink Monitor
Display uplink interfaces.
Monitor
Configure an uplink interface.
Configure
Channel usage rate
Display channel usage rate.
Monitor
Evaluate the channel usage rate
Configure
Band Navigation
Display band navigation settings.
Monitor
Set band navigation parameters.
Configure
Multicast optimization
Set Multicast optimization parameters.
Configure
Common Web interface elements
Common buttons and icons
Table 2 Common buttons and icons
Button and icon
Bring the configuration on the current page into effect.
Cancel the configuration on the current page, and go to the corresponding display page or device information page.
Refresh the information on the current page.
Clear all statistics or items in a list.
Enter the page for adding an entry.
Delete entries on a list.
Select all the entries on a list or all ports on a device panel.
Clear all the entries on a list or all ports on a device panel.
Restore the values of all the entries on the current page to the default.
Typically located on a configuration procedure page of the configuration wizard, it allows you to save the configuration of the current configuration procedure (not bring it into effect) and go to the page of the next configuration procedure.
Typically located on a configuration procedure page of the configuration wizard, it allows you to save the configuration of the current configuration procedure (not bring it into effect) and return to the page of the previous configuration procedure.
Typically located on a configuration procedure page of the configuration wizard, it allows you to bring all configurations into effect.
icon_mdf
Typically located on the Operation column of a display page, it allows you to enter the modify page of a corresponding entry so as to display or modify the configurations of the entry.
icon_del
Typically located on the Operation column of a display page, it allows you to remove an entry.
Content display by pages
The Web interface can display contents by pages, as shown in Figure 4. You can set the number of entries displayed per page, and view the contents on the first, previous, next, and last pages, or go to any page that you want to check.
Figure 4 Content display by pages
Searching function
The Web interface provides you with the basic and advanced searching functions to display only the entries that match specific searching criteria.
Basic search
As shown in Figure 4, input the keyword in the text box above the list, select a search item from the drop-down list and click the Search button to display the entries that match the criteria. Figure 5 shows an example of searching for entries with 00e0 included in the MAC address.
Figure 5 Basic search function example
Advanced search
Advanced search function: As shown in Figure 4, you can click the Advanced Search link to open the advanced search page, as shown in Figure 6. Specify the search criteria, and click Apply to display the entries that match the criteria.
Figure 6 Advanced search
Take the ARP table shown in Figure 4 as an example. If you want to search for the ARP entries with 000f at the beginning of the MAC address, and IP address range being 192.168.1.50 to 192.168.1.59, follow these steps:
1.        Click the Advanced Search link.
2.        Specify the search criteria on the advanced search page as shown in Figure 7.
Figure 7 Advanced search function example (I)
3.        Click Apply. The ARP entries with 000f at the beginning of the MAC address are displayed
4.        Click the Advanced Search link.
5.        Specify the search criteria on the advanced search page as shown in Figure 8.
Figure 8 Advanced search function example (II)
6.        Click Apply. The ARP entries with 000f at the beginning of the MAC address and IP address range 192.168.1.50 to 192.168.1.59 are displayed as shown in Figure 9.
Figure 9 Advanced search function example (III)
Basic sorting function
The Web interface provides you with the basic sorting function to display entries in certain orders.
On a list page, you can click the blue heading item of each column to sort the entries based on the heading item you selected. After your clicking, the heading item is displayed with an arrow beside it as shown in Figure 10. The upward arrow indicates the ascending order, and the downward arrow indicates the descending order.
Figure 10 Basic sorting function example (based on IP address in the descending order)
Configuration guidelines
·          The Web-based configuration interface supports the operating systems of Windows XP, Windows 2000, Windows Server 2003 Enterprise Edition, Windows Server 2003 Standard Edition, Windows Vista, Windows 7, Windows 8, Linux, and MAC OS.
·          The Web-based configuration interface supports the browsers of Microsoft Internet Explorer 6.0 SP2 and higher, Mozilla Firefox 3.0 and higher, Google Chrome 2.0.174.0 and higher.
·          The Web-based configuration interface does not support the Back, Next, Refresh buttons provided by the browser. Using these buttons may result in abnormal display of Web pages.
·          The Windows firewall limits the number of TCP connections, so when you use IE to log in to the Web interface, sometimes you may be unable to open the Web interface. To avoid this problem, turn off the Windows firewall before login.
·          If the software version of the device changes, clear the cache data on the browser before logging in to the device through the Web interface; otherwise, the Web page content may not be displayed correctly.
·          You can display at most 20,000 entries that support content display by pages.
Troubleshooting Web browser
Failure to access the device through the Web interface
Symptom
You can ping the device successfully, and log in to the device through Telnet. HTTP is enabled and the operating system and browser version meet the Web interface requirements. However, you cannot access the Web interface of the device.
Analysis
·          If you use the Microsoft Internet Explorer, you can access the Web interface only when these functions are enabled: Run ActiveX controls and plug-ins, script ActiveX controls marked safe for scripting and active scripting.
·          If you use the Mozilla Firefox, you can access the Web interface only when JavaScript is enabled.
Configuring the Internet Explorer settings
1.        Open the Internet Explorer, and then select Tools > Internet Options.
2.        Click the Security tab, and then select a Web content zone to specify its security settings.
Figure 11 Internet Explorer setting (I)
3.        Click Custom Level.
The dialog box Security Settings appears.
4.        Set the enable these functions: Run ActiveX controls and plug-ins, script ActiveX controls marked safe for scripting and active scripting.
Figure 12 Internet Explorer Setting (II)
5.        Click OK in the Security Settings dialog box.
Configuring Firefox Web browser settings
1.        Open the Firefox Web browser, and then select Tools > Options.
2.        Click the Content tab, select the Enable JavaScript box, and click OK.
Figure 13 Firefox Web browser setting
