H3C WA Series Access Points Web Configuration Guide(R1507P09)-6W101
HomeSupportConfigure & DeployUser ManualsH3C WA Series Access Points Web Configuration Guide(R1507P09)-6W101
03-Summary
03-Summary 1.46 MB
The interface types and output information vary by device model and radio type.
Device information
The device info page displays the following information:
·          Device information
·          System resource state
·          Device interface information
·          Recent system logs  (at most five)
When you are logged in to the Web interface, you are placed on the Summary > Device Info page.
Figure 1 Device info page
The information displayed on the device info page varies with devices.
Select a refresh mode in the Refresh Period list.
·          If you select a specific refresh period (for example, 1 minute), the system periodically refreshes the Device Info page according to the selected refresh period.
·          If you select Manual, click Refresh to refresh the page.
Device info
Table 1 Field description
Device Name
Device model.
Product Information
Product information.
Device Location
Location of the device.
To configure the device location information, select Device > SNMP > Setup; for more information, see "Configuring SNMP."
Contact Information
Contact information for device maintenance.
To configure the contact information, select Device > SNMP > Setup; for more information, see "Configuring SNMP."
SerialNum
Serial number of the device.
Software Version
Software version of the device.
Hardware Version
Hardware version of the device.
Bootrom Version
Boot ROM version of the device.
Running Time
Running time after the latest boot of the device.
Table 2 Field description
CPU Usage
Real-time CPU usage.
Memory Usage
Real-time memory usage and the total memory size.
Support for the display of the total memory size depends on the device model.
Temperature
Temperature of the device.
Table 3 Field description
Interface name and interface number.
IP Address/Mask
IP address and mask of an interface.
Status
Interface status.
·         —The interface is up and is connected.
·         —The interface is up, but not connected.
·         —The interface is down.
To know more information about device interfaces, click the More hyperlink under the Device Interface Information area to enter the Device > Interface page to view and operate the interfaces. For more information, see "Configuring interface management."
Recent system logs
Table 4 Field description
Time
Time when the system logs are generated.
Level
Level of the system logs.
Contents of the system logs.
To know more information about system logs, click the More hyperlink under the Recent System Operation Logs area to enter the Device > Syslog > Loglist page to view the logs. For more information, see "Configuring log management."
Displaying WLAN service
Select Summary > WLAN Service from the navigation tree and click the name of the specified WLAN service to view the detailed information, statistics, or connection history.
Displaying detailed information about WLAN services
Figure 2 shows the page that displays detailed information about clear-type WLAN services. Table 5 describes the fields on the page.
Figure 2 Displaying detailed information about clear-type WLAN services
Table 5 Field description
Service Template Number
Service template number.
SSID
Service set identifier (SSID) for the ESS.
Description for the service template. If no description is configured, this field displays Not Configured.
Service Template Type
Service template type.
Authentication Method
Type of authentication used.
WLAN service of the clear type only uses open system authentication.
Beacon-measurement
Enable—Enables beacon measurement.
Beacon-measurement Interval
Intervals (in seconds) at which beacon measurement requests are sent.
Beacon-measurement Type
Beacon measurement type: Passive, Active, or Beacon-table.
SSID-hide
·         Disable—The SSID is advertised in beacon frames.
·         Enable—Disable the advertisement of the SSID in beacon frames.
Service Template Status
Status of service template:
·         Enable—Enable WLAN service.
·         Disable—Disable WLAN service.
Maximum clients per BSS
Maximum number of associated clients per BSS.
Figure 3 shows the page that displays detailed information about crypto-type WLAN services. Table 6 describes the fields on the page.
Figure 3 Displaying detailed information about crypto-type WLAN services
Table 6 Field description
SSID
SSID provided by the AP.
Security IE
Security IE: WPA or WPA2(RSN).
Authentication method: open system or shared key.
Beacon-measurement
SSID-hide
WEP Key Index
Key index to encrypt or decrypt frames.
WEP Key Mode
WEP key format:
·         HEX—Hexadecimal string.
·         ASCII—ASCII character string.
WEP Key
WEP key.
Cipher Suite
Cipher suite: AES-CCMP, TKIP, WEP40, WEP104, or WEP128.
TKIP Countermeasure Time(s)
TKIP countermeasure time in seconds.
PTK Life Time(s)
PTK lifetime in seconds.
GTK Rekey
GTK rekey configured.
GTK Rekey Method
GTK rekey method configured: packet based or time based.
GTK Rekey Time(s)
Time for GTK rekey in seconds.
·         If Time is selected, the GTK is refreshed after a specified period of time.
·         If Packet is selected, the GTK is refreshed after a specified number of packets are transmitted.
PMF Status
Status of management frame protection:
·         Disable—Management frame protection is disabled.
·         Optional—Management frame protection is enabled and all clients can associate with the AP.
·         Mandatory—Management frame protection is enabled and only clients supporting management frame protection can associate with the AP.
Displaying statistics of WLAN service
Figure 4 Displaying WLAN service statistics
Displaying connection history information of WLAN service
Figure 5 Displaying the connection history information of WLAN service
Displaying radio
Displaying WLAN services bound to a radio
Select Summary > Radio from the navigation tree, click the specified radio unit, and select the Wireless Service tab to view the WLAN services bound to the radio.
Figure 6 Displaying WLAN services bound to the radio
The Noise Floor item in the table indicates various random electromagnetic waves during the wireless communication. For the environment with a high noise floor, you can improve the signal-to-noise ratio (SNR) by increasing the transmit power or reducing the noise floor.
The Service Type item in the table has three options: None, Access, and Mesh.
Res Using Ratio represents the resource utilization of a radio within a certain period. For example, in a period of 10 seconds, if a radio has occupied the channel for five seconds, the resource utilization of the radio is 5 seconds divided by 10 seconds: 50%.
Displaying detailed radio information
Select Summary > Radio from the navigation tree, click the specified radio unit, and select the Detail Info tab to view the corresponding detailed information.
Figure 7 Displaying detailed radio information
Displaying WDS
Select Summary > WDS from the navigation tree to enter the WDS page.
Figure 8 Displaying WDS
The AP can operate in two modes:
·          Bridge mode—The AP operates in the network as a Layer 2 device.
·          Route mode—The AP operates in the network as a Layer 3 device.
At present, the AP operates in bridge mode only.
Table 7 Field description
Neighbor MAC Address
MAC address of the radio interface of the neighbor.
Local MAC Address
MAC address of the local radio interface.
Link State
Link state, which can be up, down, or processing.
Link Uptime
Up time of the current WDS link.
Signal Quality
—If the signal strength indicator is represented by no signal bar, it indicates that RSSI=0.
—If the signal strength indicator is represented by one signal bar at the leftmost, it indicates that 0<RSSI<=15.
—If the signal strength indicator is represented by two signal bars from the left, it indicates that 15<RSSI<=25.
—If the signal strength indicator is represented by three signal bars from the left, it indicates that 25<RSSI<=35.
—If the signal strength indicator is represented by four signal bars, it indicates that 35<RSSI<=45.
—If the signal strength indicator is represented by five signal bars, it indicates that RSSI>45.
Displaying client
Displaying client detailed information
Select Summary > Client from the navigation tree to enter the Client page, click the Detail Information tab on the page, and click the name of the specified client to view the detailed information of the client.
The detailed information about a client is as shown in Figure 9. For the description of the fields in the client detailed information, see Table 8. For the description of the buttons on this page, see Table 9.
Figure 9 Displaying client
Table 8 Field description
MAC Address
MAC address of the client.
User Name
Username of the client:
·         The field is displayed as -NA- if the client adopts plain-text authentication or cipher-text authentication with no username.
·         The field is irrelevant to the portal authentication method. If the client uses the portal authentication method, the field does not display the portal username of the client.
IP address
IP address of the client.
AID
Association ID of the client.
Radio Interface
Radio interface associated with the client.
Service template number of the client.
SSID
SSID associated with the client.
BSSID
Basic SSID.
Port
WLAN-DBSS interface associated with the client.
VLAN
Number of the VLAN interface to which the client belongs.
State of the client such as running.
Power Save Mode
Client’s power save mode: active or sleep.
Wireless Mode
Wireless mode such as 802.11a, 802.11b, 802.11g, 802.11an, 802.11gn, and 802.11ac.
Channel Band-width
Channel bandwidth, 20 MHz, 40 MHz, or 80 MHz.
SM Power Save Enable
SM Power Save enables a client to have one antenna in the active state, and others in sleep state to save power.
·         Enabled—SM Power Save is supported.
·         Disabled—SM Power Save is not supported.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz.
Short GI for 80MHz
Whether the client supports short GI when its channel bandwidth is 80 MHz.
Short GI for 160/80+80MHz
Whether the client supports short GI when its channel bandwidth is 160/80+80 MHz.
LDPC
Whether LDPC is supported:
·         Not Supported.
·         Supported.
STBC Tx Capability
STBC transmission capability:
·         Not Supported.
·         Supported.
The AP and a client negotiate the STBC transmission capability. The negotiation can succeed only when both the AP and client have STBC transmission capability.
STBC Rx Capability
STBC receive capability:
·         Not Supported.
·         Supported.
The AP and a client negotiate the STBC receive capability. The negotiation can succeed only when both the AP and client have STBC receive capability.
Support MCS Set
MCS supported by the client.
Support VHT-MCS and Nss Set
VHT-MCS and NSS supported by the client.
BLOCK ACK-TID
BLOCK ACK is negotiated based on QoS priority ID:
·         OUT—Outbound direction.
·         IN—Inbound direction.
·         BOTH—Both directions.
QoS Mode
Whether the AP supports the WMM function.
Listen Interval (Beacon Interval)
How often the client wakes up to receive frames saved in the AP and is expressed in units of beacon interval.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx Rate
Transmission/reception rate of packets (including data, management and control packets).
Client Type
Client type such as RSN, WPA, or Pre-RSN.
Authentication method such as open system or shared key.
AKM Method
AKM suite used such as Dot1X or PSK.
Key Derivation
Key derivation type:
·         SHA1—Uses the HMAC-SHA1 hash algorithm.
·         SHA256—Uses the HMAC-SHA256 hash algorithm.
·         -NA-—No key derivation algorithm is involved for the authentication type.
4-Way Handshake State
Four-way handshake state:
·         IDLE—Displayed in initial state.
·         PTKSTART—Displayed when the 4–way handshake is initialized.
·         PTKNEGOTIATING—Displayed after the third message was sent.
·         PTKINITDONE—Displayed when the 4-way handshake is successful.
Group Key State
Group key state:
·         REKEYNEGOTIATE—Displayed after the initial message is sent to the client.
·         REKEYESTABLISHED—Displayed when re-keying is successful.
Encryption Cipher
Encryption cipher: clear or crypto.
PMF Status
Management frame protection state:
·         Active.
·         Inactive.
·         -NA-—No PMF is involved for the authentication type.
Roam Status
Roaming status: Normal.
Roam Count
Roaming count of the client.
Up Time
Time for which the client has been associated with the AP.
Table 9 Field description
Refresh
Refresh the current page.
Add to Blacklist
Add the selected client to the static blacklist, which you can display by selecting Security > Filter from the navigation tree.
Reset Statistic
Clear statistics of the specified client.
Disconnect
Log off the selected client.
Displaying client statistics
Select Summary > Client from the navigation tree to enter the Client page, click the Statistic Information tab on the page, and click the name of the specified client to view the statistics of the client.
Figure 10 Displaying client statistics
To view the IP address of the client, enable the ARP snooping function in system view at the CLI. By default, the ARP snooping function is disabled, and NA is displayed in the IP Address column.
Table 10 Field description
AP Name
Name of the associated AP.
Radio Id
ID of the radio interface associated with the client.
SSID
BSSID
Basic SSID.
MAC Address
MAC Address of the client.
RSSI
Transmitted Frames
Number of transmitted frames.
Back Ground(Frames/Bytes)
Statistics of background traffic, in frames or in bytes.
Best Effort(Frames/Bytes)
Statistics of best effort traffic, in frames or in bytes.
Video(Frames/Bytes)
Statistics of video traffic, in frames or in bytes.
Voice(Frames/Bytes)
Statistics of voice traffic, in frames or in bytes.
Received Frames
Number of received frames.
Discarded Frames
Number of discarded frames.
Displaying RF ping information
Radio Frequency Ping (RF Ping) is a ping function performed on wireless links. This function enables you to get the connection information between the AP and its associated clients, such as signal strength, packet re-transmission attempts, and Round-trip Time (RTT).
Select Summary > Client from the navigation tree to enter the Client page, click the Link Test Information tab on the page, and click the name of the specified client to view the link test information of the client. For the description of the fields in the client link test information, see Table 11.
Figure 11 Viewing link test information
Table 11 Field description
No./MCS
·         Rate number for a non-802.11n client.
·         MCS value for an 802.11n client.
Rate(Mbps)
Rate at which the radio interface sends wireless ping frames.
TxCnt
Number of wireless ping frames that the radio interface sent.
RxCnt
Number of wireless ping frames that the radio interface received from the client.
RSSI
Retries
Total number of retransmitted ping frames.
RTT(ms)
Round trip time.
Displaying beacon measurement reports
1.        Select Summary > Client from the navigation tree.
2.        Click the Beacon Measurement Report tab.
3.        Click the name of the specified client to view the beacon measurement reports of the client.
Figure 12 Displaying beacon measurement reports
Table 12 Field description
MAC Address
Total Number of Reports
Number of beacon measurement reports.
Channel
Channel number.
BSSID
Basic service set identifier.
Regulatory Class
Regulatory class: 12 or 5.
For more information, see the 802.11k protocols.
Antenna ID
Antenna identifier.
SSID
Service set identifier.
