- 08-IP Multicast Command Reference
- 01-IGMP Snooping Commands
- 02-PIM Snooping Commands
- 03-Multicast VLAN Commands
- 04-Multicast Routing and Forwarding Commands
- 05-IGMP Commands
- 06-PIM Commands
- 07-MSDP Commands
- 08-MBGP Commands
- 09-Multicast VPN Commands
- 10-MLD Snooping Commands
- 11-IPv6 PIM Snooping Commands
- 12-IPv6 Multicast VLAN Commands
- 13-IPv6 Multicast Routing and Forwarding Commands
- 14-MLD Commands
- 15-IPv6 PIM Commands
- 16-IPv6 MBGP Commands
| 11-IPv6 PIM Snooping Commands | 86.77 KB |
IPv6 PIM snooping configuration commands
display pim-snooping ipv6 neighbor
display pim-snooping ipv6 routing-table
display pim-snooping ipv6 statistics
reset pim-snooping ipv6 statistics
NOTE: The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide. |
In standalone mode:
display pim-snooping ipv6 neighbor [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display pim-snooping ipv6 neighbor [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the IPv6 PIM snooping neighbor information of the specified VLAN. vlan-id is in the range of 1 to 4094.
slot slot-number: Displays the IPv6 PIM snooping neighbor information of the card specified by its slot number. If no slot is specified, the command displays the IPv6 PIM snooping neighbor information of all cards. (In standalone mode)
chassis chassis-number slot slot-number: Displays the IPv6 PIM snooping neighbor information on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, the command displays the IPv6 PIM snooping neighbor information of all cards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode)
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display pim-snooping ipv6 neighbor command to display IPv6 PIM snooping neighbor information. If you do not specify a VLAN, this command displays the IPv6 PIM snooping neighbor information in all VLANs.
# Display the IPv6 PIM snooping neighbor information of VLAN 2.
<Sysname> display pim-snooping ipv6 neighbor vlan 2
Total number of neighbors: 2
VLAN ID: 2
Neighbor Port Expires Option Flags
FE80::6401:101 GE3/0/1 02:02:23 LAN Prune Delay(T)
FE80::C801:101 GE3/0/2 03:00:05 LAN Prune Delay
Table 1 Output description
Total number of neighbors |
Total number of IPv6 PIM snooping neighbors. |
Neighbor |
IP address of the IPv6 PIM snooping neighbor. |
Port |
Name of the port that connects to the IPv6 PIM snooping neighbor. |
Expires |
Remaining time before the IPv6 PIM snooping neighbor expires. Never means the IPv6 PIM snooping neighbor never expires. |
Option Flags |
Possible values includes the following items: · LAN Prune Delay—Indicates that the IPv6 PIM hello messages received from the neighbor carry the LAN_Prune_Delay option.. · LAN Prune Delay(T)—Indicates that the IPv6 PIM hello messages received from the neighbor carry the LAN_Prune_Delay option, and the join suppression function has been disabled. |
In standalone mode:
display pim-snooping ipv6 routing-table [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display pim-snooping ipv6 routing-table [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the IPv6 PIM snooping routing entries of the specified VLAN. vlan-id is in the range of 1 to 4094.
slot slot-number: Displays the IPv6 PIM snooping routing entries of the card specified by its slot number. If no slot is specified, the command displays information about the IPv6 PIM snooping routing entries on the main board. (In standalone mode)
chassis chassis-number slot slot-number: Displays the IPv6 PIM snooping routing entries on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, this command displays the IPv6 PIM snooping routing entries on all active main boards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode)
Use the display pim-snooping ipv6 routing-table command to display the IPv6 PIM snooping routing table. If you do not specify a VLAN, this command displays the IPv6 PIM snooping routing entries in all VLANs.
# Display the IPv6 PIM snooping routing entries of VLAN 2.
<Sysname> display pim-snooping ipv6 routing-table vlan 2
Total 1 entry(ies)
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN ID: 2
Total 1 entry(ies)
(2000::1, FF1E::1)
Upstream neighbor: FE80::101
Upstream port: GE3/0/1
Total number of downstream ports: 2
1: GE3/0/3
2: GE3/0/4
Upstream neighbor: FE80::102
Upstream port: GE3/0/2
Total number of downstream ports: 1
1: GE 3/0/5
NOTE: · In standalone mode, if you want to determine the Upstream port field of an upstream interface that is not on the main board, you must specify the slot number of the card that the interface belongs to. · In IRF mode, if you want to determine the Upstream port field of an upstream interface that is not on the main board, you must specify the chassis number and slot number of the card that the interface belongs to. · In standalone mode, if you want to determine the Expires and FSM fields of a non-aggregate interface that is not on the main board, you must specify the slot number of the card that the interface belongs to. For aggregate interfaces, the Expires and FSM fields are displayed, whether the slot number is specified or not. · In IRF mode, if you want to determine the Expires and FSM fields of a non-aggregate interface that is not on the main board, you must specify the chassis number and slot number of the card that the interface belongs to. For aggregate interfaces, the Expires and FSM fields are displayed, whether the chassis number and slot number are specified or not. |
Total 1 entry(ies) |
Total number of (S, G) entries and (*, G) entries in the IPv6 PIM snooping routing table |
FSM Flag: NI-no info, J-join, PP-prune pending |
State machine flag of the downstream port. Possible values include: · NI—Initial state · J—Join · PP—Prune pending |
(2000::1, FF1E::1) |
An (S, G) entry |
Upstream neighbor |
Upstream neighbor of the (S, G) or (*, G) entry |
Upstream port |
Upstream port of the (S, G) entry or (*, G) entry) |
Total number of downstream ports |
Total number of downstream ports contained in the upstream neighbor of the (S, G) or (*, G) entry |
FSM |
State machine of the downstream port |
display pim-snooping ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display pim-snooping ipv6 statistics command to display the statistics for IPv6 PIM messages learned by IPv6 PIM snooping.
# Display the statistics for IPv6 PIM messages learned by IPv6 PIM snooping.
<Sysname> display pim-snooping ipv6 statistics
Received IPv6 PIM IPv6 hello: 100
Received IPv6 PIM IPv6 join/prune: 100
Received IPv6 PIM IPv6 error: 0
Received IPv6 PIM IPv6 messages in total: 200
Table 3 Output description
Received IPv6 PIM IPv6 hello |
Number of received IPv6 PIM hello messages |
Received IPv6 PIM IPv6 join/prune |
Number of received IPv6 PIM join/prune messages |
Received IPv6 PIM IPv6 error |
Number of received IPv6 PIM messages with errors |
Received IPv6 PIM IPv6 messages in total |
Total number of received IPv6 PIM messages |
pim-snooping ipv6 enable
undo pim-snooping ipv6 enable
View
VLAN view
Default level
2: System level
None
Use the pim-snooping ipv6 enable command to enable IPv6 PIM snooping in a VLAN.
Use the undo pim-snooping ipv6 enable command to disable IPv6 PIM snooping in a VLAN.
By default, IPv6 PIM snooping is disabled.
Before you enable IPv6 PIM snooping in a VLAN, be sure to enable MLD snooping globally and specially in the VLAN.
IPv6 PIM snooping does not work in a sub-VLAN of a multicast VLAN.
Related commands: mld-snooping enable.
# Enable MLD snooping globally, and enable MLD snooping and IPv6 PIM snooping in VLAN 2.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] pim-snooping ipv6 enable
View
Default level
2: System level
None
Use the reset pim-snooping ipv6 statistics command to clear the statistics of IPv6 PIM messages learned by IPv6 PIM snooping.
# Clear the statistics of IPv6 PIM messages learned by IPv6 PIM snooping.
<Sysname> reset pim-snooping ipv6 statistics
