- 08-IP Multicast Command Reference
- 01-IGMP Snooping Commands
- 02-PIM Snooping Commands
- 03-Multicast VLAN Commands
- 04-Multicast Routing and Forwarding Commands
- 05-IGMP Commands
- 06-PIM Commands
- 07-MSDP Commands
- 08-MBGP Commands
- 09-Multicast VPN Commands
- 10-MLD Snooping Commands
- 11-IPv6 PIM Snooping Commands
- 12-IPv6 Multicast VLAN Commands
- 13-IPv6 Multicast Routing and Forwarding Commands
- 14-MLD Commands
- 15-IPv6 PIM Commands
- 16-IPv6 MBGP Commands
| 06-PIM Commands | 336.07 KB |
bsm-fragment enable (PIM view)
c-rp advertisement-interval (PIM view)
display pim control-message counters
hello-option dr-priority (PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (PIM view)
holdtime join-prune (PIM view)
pim hello-option neighbor-tracking
pim hello-option override-interval
register-suppression-timeout (PIM view)
register-whole-checksum (PIM view)
reset pim control-message counters
spt-switch-threshold (PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (PIM view)
NOTE: The term router in this document refers to both routers and Layer 3 switches. |
auto-rp enable
auto-rp enable
undo auto-rp enable
View
Public network PIM view, VPN instance PIM view
Default level
2: System level
None
Use the auto-rp enable command to enable auto-RP.
Use the undo auto-rp enable command to disable auto-RP.
By default, auto-RP is disabled.
Related commands: static-rp.
# Enable auto-RP in the public network.
[Sysname] pim
[Sysname-pim] auto-rp enable
# Enable auto-RP in VPN instance mvpn.
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn] auto-rp enable
bidir-pim enable (PIM view)
bidir-pim enable
undo bidir-pim enable
View
Default level
2: System level
None
Use the bidir-pim enable command to enable BIDIR-PIM.
Use the undo bidir-pim enable command to disable BIDIR-PIM.
By default, BIDIR-PIM is disabled.
This command is effective only after multicast routing is enabled.
Related commands: pim and multicast routing-enable.
# Enable multicast routing in the public network, enter PIM view, and enable BIDIR-PIM.
[Sysname] multicast routing-enable
[Sysname] pim
[Sysname-pim] bidir-pim enable
# Enable multicast routing in VPN instance mvpn, enter VPN instance PIM view, and enable BIDIR-PIM.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname-pim-mvpn] bidir-pim enable
bsm-fragment enable
undo bsm-fragment enable
View
Default level
2: System level
None
Use the bsm-fragment enable command to enable bootstrap message (BSM) semantic fragmentation.
Use the undo bsm-fragment enable command to disable BSM semantic fragmentation.
By default, BSM semantic fragmentation is enabled.
Disable the BSM semantic fragmentation function if devices not supporting this function exist in the PIM-SM domain.
Related commands: c-bsr admin-scope.
# Disable BSM semantic fragmentation in the public network.
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
# Disable BSM semantic fragmentation in VPN instance mvpn.
[Sysname-pim-mvpn] undo bsm-fragment enable
bsr-policy (PIM view)
bsr-policy acl-number
undo bsr-policy
View
Default level
2: System level
acl-number: Basic ACL number, in the range of 2000 to 2999. When an ACL is defined, the source keyword in the rule command specifies a legal BSR source address range.
Use the bsr-policy command to configure a legal BSR address range to guard against BSR spoofing.
Use the undo bsr-policy command to remove the restriction of the BSR address range.
By default, no restrictions are defined for the BSR address range. Namely, the bootstrap messages from any source are regarded to be valid.
# Configure a legal BSR address range in the public network so that only devices on the segment 10.1.1.0/24 can become the BSR.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] bsr-policy 2000
# Configure a legal BSR address range in VPN instance mvpn so that only devices on the segment 10.1.1.0/24 can become the BSR.
[Sysname-pim-mvpn] bsr-policy 2000
c-bsr (PIM view)
c-bsr interface-type interface-number [ hash-length [ priority ] ]
undo c-bsr
View
Default level
2: System level
hash-length: Hash mask length, in the range of 0 to 32. If you do not specify this argument, the corresponding global setting is used.
priority: Priority of the C-BSR, in the range of 0 to 255. A larger value of this argument means a higher priority. If you do not specify this argument, the corresponding global setting is used.
Use the c-bsr command to configure the specified interface as a C-BSR.
Use the undo c-bsr command to remove the related C-BSR configuration.
No C-BSR is configured by default.
PIM-SM must be enabled on the interface to be configured as a C-BSR.
Related commands: c-bsr hash-length, c-bsr priority, c-rp, and pim sm.
# Configure VLAN-interface 100 in the public network to be a C-BSR.
[Sysname] pim
[Sysname-pim] c-bsr vlan-interface 100
# Configure VLAN-interface 100 in VPN instance mvpn to be a C-BSR.
[Sysname-pim-mvpn] c-bsr vlan-interface 100
c-bsr admin-scope (PIM view)
c-bsr admin-scope
undo c-bsr admin-scope
View
Default level
2: System level
None
Use the c-bsr admin-scope command to enable administrative scoping.
Use the undo c-bsr admin-scope command to disable administrative scoping.
By default, BSR administrative scoping is disabled. Namely, only one BSR exists in a PIM-SM domain.
Related commands: c-bsr, c-bsr global, and c-bsr group.
# Enable administrative scoping in the public network.
[Sysname] pim
[Sysname-pim] c-bsr admin-scope
# Enable administrative scoping in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr admin-scope
c-bsr global
c-bsr global [ hash-length hash-length | priority priority ] *
undo c-bsr global
View
Default level
2: System level
hash-length: Hash mask length in the global scope zone, in the range of 0 to 32. If you do not specify this argument, the corresponding global setting is used.
priority: Priority of the C-BSR in the global scope zone, in the range of 0 to 255. A larger value of this argument means a higher priority. If you do not specify this argument, the corresponding global setting is used.
Use the c-bsr global command to configure a C-BSR for the global scope zone.
Use the undo c-bsr global command to remove the C-BSR configuration for the global scope zone.
By default, no C-BSRs are configured for the global scope zone.
Related commands: c-bsr group, c-bsr hash-length, and c-bsr priority.
# Configure the device to be a C-BSR for the global scope zone in the public network, with the priority of 1.
[Sysname] pim
[Sysname-pim] c-bsr global priority 1
# Configure the device to be a C-BSR for the global scope zone in VPN instance mvpn, with the priority of 1.
[Sysname-pim-mvpn] c-bsr global priority 1
c-bsr group
c-bsr group group-address { mask | mask-length } [ hash-length hash-length | priority priority ] *
undo c-bsr group group-address
View
Default level
2: System level
group-address: Multicast group address, in the range of 239.0.0.0 to 239.255.255.255.
mask: Mask of the multicast group address.
mask-length: Mask length of the multicast group address, in the range of 8 to 32.
hash-length: Hash mask length in the admin-scope region corresponding to the specified multicast group, in the range of 0 to 32. If you do not specify this argument, the corresponding global setting is used.
priority: Priority of the C-BSR in the admin-scope region corresponding to a multicast group, in the range of 0 to 255.A larger value of this argument means a higher priority. If you do not specify this argument, the corresponding global setting is used.
Use the c-bsr group command to configure a C-BSR for the admin-scope region associated with the specified group.
Use the undo c-bsr group command to remove the C-BSR configuration for the admin-scope region associated with the specified group.
By default, no C-BSRs are configured for admin-scope regions.
Related commands: c-bsr admin-scope, c-bsr global, c-bsr hash-length, and c-bsr priority.
# In the public network, configure the device to be a C-BSR in the admin-scope region associated with the multicast group address 239.0.0.0/8, with the priority of 10.
[Sysname] pim
[Sysname-pim] c-bsr group 239.0.0.0 255.0.0.0 priority 10
# In VPN instance mvpn, configure the device to be a C-BSR in the admin-scope region associated with the multicast group address 239.0.0.0/8, with the priority of 10.
[Sysname-pim-mvpn] c-bsr group 239.0.0.0 255.0.0.0 priority 10
c-bsr hash-length (PIM view)
c-bsr hash-length hash-length
undo c-bsr hash-length
View
Default level
2: System level
Use the c-bsr hash-length command to configure the global hash mask length.
Use the undo c-bsr hash-length command to restore the default.
By default, the hash mask length is 30.
# Set the global hash mask length to 16 in the public network.
[Sysname] pim
[Sysname-pim] c-bsr hash-length 16
# Set the global hash mask length to 16 in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr hash-length 16
c-bsr holdtime (PIM view)
c-bsr holdtime interval
undo c-bsr holdtime
View
Default level
2: System level
interval: BS timeout in seconds, in the range of 1 to 2,147,483,647.
Use the c-bsr holdtime command to configure the BS timeout, namely, the length of time that a C-BSR waits before it must receive a bootstrap message from the BSR.
Use the undo c-bsr holdtime command to restore the default.
By default, the bootstrap timeout value is determined by this formula: BS timeout = BS period × 2 + 10.
NOTE: The default BS period is 60 seconds, so the default BS timeout = 60 × 2 + 10 = 130 (seconds). |
Related commands: c-bsr and c-bsr interval.
# Set the BS timeout time to 150 seconds in the public network.
[Sysname] pim
[Sysname-pim] c-bsr holdtime 150
# Set the BS timeout time to 150 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr holdtime 150
c-bsr interval (PIM view)
c-bsr interval interval
undo c-bsr interval
View
Default level
2: System level
interval: BS period in seconds, in the range of 10 to 2,147,483,647.
Use the c-bsr interval command to configure the BS period, namely, the interval at which the BSR sends bootstrap messages.
Use the undo c-bsr interval command to restore the default.
By default, the BS period value is determined by this formula: BS period = (BS timeout – 10) ÷ 2.
NOTE: The default BS timeout is 130 seconds, so the default BS period = (130 – 10) ÷ 2 = 60 (seconds). |
Related commands: c-bsr and c-bsr holdtime.
# Set the BS period to 30 seconds in the public network.
[Sysname] pim
[Sysname-pim] c-bsr interval 30
# Set the BS period to 30 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr interval 30
c-bsr priority (PIM view)
c-bsr priority priority
undo c-bsr priority
View
Default level
2: System level
Use the c-bsr priority command to configure the global C-BSR priority.
Use the undo c-bsr priority command to restore the default.
By default, the C-BSR priority is 64.
# Set the global C-BSR priority to 5 in the public network.
[Sysname] pim
[Sysname-pim] c-bsr priority 5
# Set the global C-BSR priority to 5 in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr priority 5
c-rp (PIM view)
c-rp interface-type interface-number [ group-policy acl-number | priority priority | holdtime hold-interval | advertisement-interval adv-interval ] * [ bidir ]
undo c-rp interface-type interface-number
View
Default level
2: System level
acl-number: Basic ACL number, in the range of 2000 to 2999. This ACL defines a range of multicast groups the C-RP is going to serve, rather than defining a filtering rule. Any group range matching the permit statement in the ACL will be advertised as an RP served group, but the configuration matching other statements like deny will not take effect.
priority: Priority of the C-RP, in the range of 0 to 255 and defaulting to 192. A larger value of this argument means a lower priority.
hold-interval: C-RP timeout time, in seconds. The value ranges from 1 to 65,535. If you do not provide this argument in your command, the corresponding global setting is used.
adv-interval: C-RP-Adv interval in seconds, in the range of 1 to 65,535. If you do not provide this argument in your command, the corresponding global setting is used.
bidir: Configures the C-RP to serve multicast groups in BIDIR-PIM. Without this argument, the C-RP serves groups in PIM-SM.
Use the c-rp command to configure the specified interface as a C-RP.
Use the undo c-rp command to remove the related C-RP configuration.
No C-RPs are configured by default.
PIM-SM must be enabled on the interface to be configured as a C-RP.
If you do not specify a group range for the C-RP, the C-RP will serve all multicast groups.
If you want a device to be a C-RP for multiple group ranges, you need to include these multiple group ranges in multiple rules in the ACL corresponding to the group-policy keyword.
If you execute this command repeatedly on the same interface, the last configuration will take effect.
Related commands: c-bsr.
# Configure VLAN-interface 100 in the public network to be a C-RP for multicast groups 225.1.0.0/16 and 226.2.0.0/16, with a priority of 10.
[Sysname-acl-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp vlan-interface 100 group-policy 2000 priority 10
# Configure VLAN-interface 100 in VPN instance mvpn to be a C-RP for multicast groups 225.1.0.0/16 and 226.2.0.0/16, with a priority of 10.
[Sysname-pim-mvpn] c-rp vlan-interface 100 group-policy 2000 priority 10
c-rp advertisement-interval interval
undo c-rp advertisement-interval
View
Default level
2: System level
Use the c-rp advertisement-interval command to configure the interval at which C-RP-Adv messages are sent.
Use the undo c-rp advertisement-interval command to restore the default.
By default, the C-RP-Adv interval is 60 seconds.
Related commands: c-rp.
# Set the global C-RP-Adv interval to 30 seconds in the public network.
[Sysname] pim
[Sysname-pim] c-rp advertisement-interval 30
# Set the global C-RP-Adv interval to 30 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-rp advertisement-interval 30
c-rp holdtime (PIM view)
c-rp holdtime interval
undo c-rp holdtime
View
Default level
2: System level
interval: C-RP timeout in seconds, in the range of 1 to 65,535.
Use the c-rp holdtime command to configure the global C-RP timeout time, namely, the length of time that the BSR waits before it must receive a C-RP-Adv message.
Use the undo c-rp holdtime command to restore the default.
By default, the C-RP timeout time is 150 seconds.
Because a non-BSR router refreshes its C-RP timeout time through BSR bootstrap messages, to prevent loss of C-RP information in BSR bootstrap messages, make sure that the C-RP timeout time is not smaller than the interval at which the BSR sends bootstrap messages. The recommended C-RP timeout setting is 2.5 times the BS period or longer.
Related commands: c-bsr interval and c-rp.
# Set the global C-RP timeout time to 200 seconds in the public network.
[Sysname] pim
[Sysname-pim] c-rp holdtime 200
# Set the global C-RP timeout time to 200 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-rp holdtime 200
crp-policy (PIM view)
crp-policy acl-number
undo crp-policy
View
Default level
2: System level
acl-number: Advanced ACL number, in the range of 3000 to 3999. When the ACL is defined, the source keyword in the rule command specifies the address of a C-RP and the destination keyword specifies the address range of the multicast groups that the C-RP will serve.
Use the crp-policy command to configure a legal C-RP address range and the range of served multicast groups, so as to guard against C-RP spoofing.
Use the undo crp-policy command to remove the restrictions in C-RP address ranges and the ranges of served multicast groups.
By default, no restrictions are defined for C-RP address ranges and the address ranges of served groups. Namely, all received C-RP messages are accepted.
The crp-policy command filters the multicast group ranges advertised by C-RPs based on the group prefixes. For example, if the multicast group range advertised by a C-RP is 224.1.0.0/16 and the legal group range defined by the crp-policy command is 224.1.0.0/30, the multicast groups in the range of 224.1.0.0/16 are allowed to pass.
# In the public network, configure a C-RP policy so that only devices in the address range of 1.1.1.1/24 can be C-RPs that serve multicast groups in the address range of 225.1.1.0/24.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname-acl-adv-3000] quit
[Sysname] pim
[Sysname-pim] crp-policy 3000
# In VPN instance mvpn, configure a C-RP policy, so that only devices in the address range of 1.1.1.1/24 can be C-RPs that serve multicast groups in the address range of 225.1.1.0/24.
[Sysname-pim-mvpn] crp-policy 3000
display pim bsr-info
display pim [ all-instance | vpn-instance vpn-instance-name ] bsr-info [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where vpn-instance-name is a case-sensitive string of 1 to 31 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display pim bsr-info command to view the BSR information in the PIM domain and the locally configured C-RP information in effect.
If neither all-instance nor vpn-instance is specified, this command will display the information in the public network.
Related commands: c-bsr and c-rp.
# Display the BSR information of the PIM-SM domain in the public network and the locally configured C-RP information in effect.
<Sysname> display pim bsr-info
VPN-Instance: public net
Elected BSR Address: 12.12.12.9
Priority: 64
Hash mask length: 30
State: Elected
Scope: Global
Uptime: 00:00:56
Next BSR message scheduled at: 00:01:14
Candidate BSR Address: 12.12.12.9
Priority: 64
State: Elected
Scope: Global
Candidate RP: 12.12.12.9(LoopBack1)
Priority: 192
HoldTime: 150
Advertisement Interval: 60
Next advertisement scheduled at: 00:00:48
Candidate RP: 3.3.3.3(Vlan-interface100)
Priority: 200
HoldTime: 90
Advertisement Interval: 50
Next advertisement scheduled at: 00:00:28
Candidate RP: 5.5.5.5(Vlan-interface101)
Priority: 192
HoldTime: 80
Table 1 Output description
VPN-Instance: public net |
Public network |
Elected BSR Address |
Address of the elected BSR |
Candidate BSR Address |
Address of the candidate BSR |
Priority |
BSR priority |
Hash mask length |
Hash mask length |
State |
BSR state |
Scope |
Scope of the BSR |
Uptime |
Length of time for which this BSR has been up, in hh:mm:ss |
Next BSR message scheduled at |
Length of time in which the BSR will expire, in hh:mm:ss |
Candidate RP |
Address of the C-RP |
Priority |
Priority of the C-RP |
HoldTime |
Timeout time of the C-RP |
Advertisement Interval |
Interval at which the C-RP sends advertisement messages |
Next advertisement scheduled at |
Length of time in which the C-RP will send the next advertisement message, in hh:mm:ss |
display pim claimed-route
display pim [ all-instance | vpn-instance vpn-instance-name ] claimed-route [ source-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Displays the information of the unicast route to a particular multicast source. If you do not provide this argument, this command will display the information about all unicast routes used by PIM.
Use the display pim claimed-route command to view the information of unicast routes used by PIM.
If an (S, G) is marked SPT, this (S, G) entry uses a unicast route.
# Display the information of all unicast routes used by PIM in the public network.
<Sysname> display pim claimed-route
RPF information about: 172.168.0.0
RPF interface: Vlan-interface100, RPF neighbor: 172.168.0.2
Referenced route/mask: 172.168.0.0/24
Referenced route type: unicast (direct)
RPF-route selecting rule: preference-preferred
The (S,G) or (*,G) list dependent on this route entry
(172.168.0.12, 227.0.0.1)
Table 2 Output description
Public network |
RPF information about: 172.168.0.0 |
Information of the route to the multicast source 172.168.0.0 |
RPF interface |
RPF interface type and number |
RPF neighbor |
IP address of the RPF neighbor |
Referenced route/mask |
Address/mask of the referenced route |
Referenced route type |
Type of the referenced route: · igp: IGP unicast route · egp: EGP unicast route · unicast (direct): Direct unicast route · unicast: Other unicast route (such as static unicast route) · mbgp: MBGP route · multicast static: Static multicast route |
RPF-route selecting rule |
Rule of RPF route selection |
The (S,G) or (*,G) list dependent on this route entry |
(S,G) or (*, G) entry list dependent on this RPF route |
display pim [ all-instance | vpn-instance vpn-instance-name ] control-message counters [ message-type { probe | register | register-stop } | [ interface interface-type interface-number | message-type { assert | bsr | crp | graft | graft-ack | hello | join-prune | state-refresh } ] * ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
probe: Displays the number of null register messages.
register: Displays the number of register messages.
register-stop: Displays the number of register-stop messages.
interface interface-type interface-number: Displays the number of PIM control messages on the specified interface.
assert: Displays the number of assert messages.
bsr: Displays the number of Bootstrap messages.
crp: Displays the number of C-RP-Adv messages.
graft: Displays the number of Graft messages.
graft-ack: Displays the number of Graft-ack messages.
hello: Displays the number of Hello messages.
join-prune: Displays the number of Join/prune messages.
state-refresh: Displays the number of state refresh messages.
Use the display pim control-message counters command to display the statistics for PIM control messages.
# Display the statistics for all PIM control messages on all interfaces in the public network.
<Sysname> display pim control-message counters
PIM global control-message counters:
Received Sent Invalid
Register 20 37 2
Register-Stop 25 20 1
Probe 10 5 0
PIM control-message counters for interface: Vlan-interface100
Assert 10 5 0
Graft 20 37 2
Graft-Ack 25 20 1
Hello 1232 453 0
Join/Prune 15 30 21
State-Refresh 8 7 1
BSR 3243 589 1
C-RP 53 32 0
Table 3 Output description
Public network |
PIM global control-message counters |
Statistics of PIM global control messages |
PIM control-message counters for interface |
Interface for which PIM control messages were counted |
Received |
Number of messages received |
Sent |
Number of messages sent |
Invalid |
Number of invalid messages |
Register |
Register messages |
Register-Stop |
Register-stop messages |
Probe |
Null register messages |
Assert |
Assert messages |
Graft |
Graft messages |
Graft-Ack |
Graft-ack messages |
Hello |
Hello messages |
Join/Prune |
Join/prune messages |
State Refresh |
State refresh messages |
BSR |
Bootstrap messages |
C-RP |
C-RP-Adv messages |
display pim df-info
display pim [ all-instance | vpn-instance vpn-instance-name ] df-info [ rp-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all instances.
vpn-instance vpn-instance-name: Specifies a VPN instance. A VPN instance name is a case-sensitive string of up to 31 characters and must not contain any space.
rp-address: Specifies the RP address of BIDIR-PIM.
exclude: Displays the lines that do not match the specified regular expression.
Use the display pim df-info command to display the DF information of BIDIR-PIM.
If neither all-instance nor vpn-instance is specified, this command displays the DF information of BIDIR-PIM in the public network.
# Display the DF information of BIDIR-PIM in the public network.
<Sysname> display pim df-info
RP Address: 1.1.1.1
Interface State DF-Pref DF-Metric DF-Uptime DF-Address
Loop0 Win 150 1 00:32:59 4.4.4.4 (local)
Vlan106 Win 150 1 00:32:59 6.0.0.1 (local)
Table 4 Output description
Public network |
RP Address |
BIDIR-PIM RP address |
Interface type and number |
State |
DF election state, Win or Lose |
DF-Pref |
Route priority of DF |
DF-Metric |
Route metric of DF |
DF-Uptime |
Existence duration of DF |
DF-Address |
IP address of DF, where local indicates a local address |
display pim grafts
display pim [ all-instance | vpn-instance vpn-instance-name ] grafts [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display pim grafts command to display information about unacknowledged PIM-DM graft messages.
# Display information about unacknowledged PIM-DM graft messages in the public network.
<Sysname> display pim grafts
Source Group Age RetransmitIn
192.168.10.1 224.1.1.1 00:00:24 00:00:02
Table 5 Output description
Public network |
Source |
Multicast source address in the graft message |
Group |
Multicast group address in the graft message |
Age |
Time in which the graft message will get aged out, in hh:mm:ss |
RetransmitIn |
Time in which the graft message will be retransmitted, in hh:mm:ss |
display pim interface
display pim [ all-instance | vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays the PIM information on a particular interface.
verbose: Displays the detailed PIM information.
Use the display pim interface command to view the PIM information on the specified interface or all interfaces.
# Display the PIM information on all interfaces in the public network.
<Sysname> display pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
Vlan100 1 30 1 10.1.1.2
Vlan101 0 30 1 172.168.0.2 (local)
Vlan102 1 30 1 20.1.1.2
Table 6 Output description
Public network |
Interface name |
NbrCnt |
Number of PIM neighbors |
HelloInt |
Hello interval |
DR-Pri |
Priority for DR election |
DR-Address |
DR IP address, where “local” indicates a local address |
# Display the detailed PIM information on VLAN-interface 100 in the public network.
<Sysname> display pim interface Vlan-interface100 verbose
Interface: Vlan-interface100, 10.1.1.1
PIM version: 2
PIM mode: Sparse
PIM DR: 10.1.1.2
PIM DR Priority (configured): 1
PIM neighbor count: 1
PIM hello interval: 30 s
PIM LAN delay (negotiated): 500 ms
PIM LAN delay (configured): 500 ms
PIM override interval (negotiated): 2500 ms
PIM override interval (configured): 2500 ms
PIM neighbor tracking (negotiated): disabled
PIM neighbor tracking (configured): disabled
PIM generation ID: 0xF5712241
PIM require generation ID: disabled
PIM hello hold interval: 105 s
PIM assert hold interval: 180 s
PIM triggered hello delay: 5 s
PIM J/P interval: 60 s
PIM J/P hold interval: 210 s
PIM BSR domain border: disabled
Number of routers on network not using DR priority: 0
Number of routers on network not using LAN delay: 0
Number of routers on network not using neighbor tracking: 2
Table 7 Output description
Public network |
Interface name and its IP address |
PIM version |
Running PIM version |
PIM mode |
PIM mode, dense or sparse |
PIM DR |
DR IP address |
PIM DR Priority (configured) |
Configured priority for DR election |
PIM neighbor count |
Total number of PIM neighbors |
PIM hello interval |
Hello interval |
PIM LAN delay (negotiated) |
Negotiated prune message delay |
PIM LAN delay (configured) |
Configured prune message delay |
PIM override interval (negotiated) |
Negotiated prune override interval |
PIM override interval (configured) |
Configured prune override interval |
PIM neighbor tracking (negotiated) |
Negotiated neighbor tracking status (enabled/disabled) |
PIM neighbor tracking (configured) |
Configured neighbor tracking status (enabled/disabled) |
PIM generation ID |
Generation_ID value |
PIM require generation ID |
Rejection of Hello messages without Generation_ID (enabled/disabled) |
PIM hello hold interval |
PIM neighbor timeout time |
PIM assert hold interval |
Assert timeout time |
PIM triggered hello delay |
Maximum delay of sending hello messages |
PIM J/P interval |
Join/prune interval |
PIM J/P hold interval |
Join/prune timeout time |
PIM BSR domain border |
Status of PIM domain border configuration (enabled/disabled) |
Number of routers on network not using DR priority |
Number of routers not using the DR priority field on the subnet where the interface resides |
Number of routers on network not using LAN delay |
Number of routers not using the LAN delay field on the subnet where the interface resides |
Number of routers on network not using neighbor tracking |
Number of routers not using neighbor tracking on the subnet where the interface resides |
display pim join-prune
display pim [ all-instance | vpn-instance vpn-instance-name ] join-prune mode { sm [ flags flag-value ] | ssm } [ interface interface-type interface-number | neighbor neighbor-address ] * [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mode: Displays the information of join/prune messages to send in the specified PIM mode. PIM modes include sm and ssm, which represent PIM-SM and PIM-SSM respectively.
flags flag-value: Displays routing entries containing the specified flag. Values and meanings of flag-value are as follows:
· rpt: Specifies routing entries on the RPT.
· spt: Specifies routing entries on the SPT.
· wc: Specifies wildcard routing entries.
interface-type interface-number: Displays the information of join/prune messages to send on the specified interface.
neighbor-address: Displays the information of join/prune messages to send to the specified PIM neighbor.
verbose: Displays the detailed information of join/prune messages to send.
Use the display pim join-prune command to view the information about the join/prune messages to send.
# In the public network view the information of join/prune messages to send in the PIM-SM mode.
<Sysname> display pim join-prune mode sm
Expiry Time: 50 sec
Upstream nbr: 10.1.1.1 (Vlan-interface100)
1 (*, G) join(s), 0 (S, G) join(s), 1 (S, G, rpt) prune(s)
Total (*, G) join(s): 1, (S, G) join(s): 0, (S, G, rpt) prune(s): 1
Table 8 Output description
Public network |
Expiry Time: |
Expiry time of sending join/prune messages |
Upstream nbr: |
IP address of the upstream PIM neighbor and the interface connecting to it |
(*, G) join(s) |
Number of (*, G) joins to send |
(S, G) join(s) |
Number of (S, G) joins to send |
(S, G, rpt) prune(s) |
Number of (S, G, rpt) prunes |
display pim neighbor
display pim [ all-instance | vpn-instance vpn-instance-name ] neighbor [ interface interface-type interface-number | neighbor-address | verbose ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays the PIM neighbor information on a particular interface.
neighbor-address: Displays the information of a particular PIM neighbor.
verbose: Displays the detailed PIM neighbor information.
Use the display pim neighbor command to view the PIM neighbor information.
# Display the information of all PIM neighbors in the public network.
<Sysname> display pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires Dr-Priority Mode
10.1.1.2 Vlan100 02:50:49 00:01:31 1 B
20.1.1.2 Vlan101 02:49:39 00:01:42 1 B
# In the public network, view the detailed information of the PIM neighbor whose IP address is 11.110.0.20.
<Sysname> display pim neighbor 11.110.0.20 verbose
Neighbor: 11.110.0.20
Uptime: 00:00:10
Expiry time: 00:00:30
DR Priority: 1
Generation ID: 0x2ACEFE15
Holdtime: 105 s
LAN delay: 500 ms
Override interval: 2500 ms
State refresh interval: 60 s
Neighbor tracking: Disabled
Bidirectional PIM: Enabled
Table 9 Output description
Public network. |
Total Number of Neighbors |
Total number of PIM neighbors. |
Neighbor |
IP address of the PIM neighbor. |
Interface connecting the PIM neighbor. |
Uptime |
Length of time for which the PIM neighbor has been up, in hh:mm:ss. |
Expires/Expiry time |
Remaining time of the PIM neighbor, in hh:mm:ss; “never” means that the PIM neighbor is always up and reachable. |
Dr-Priority/DR Priority |
Priority of the PIM neighbor. |
Mode |
Mode of the PIM neighbor. The value “B” means the BIDIR-PIM mode. If nothing is displayed, it means the non-BIDIR-PIM mode. |
Generation ID |
Generation ID of the PIM neighbor (a random value indicating a status change of the PIM neighbor). |
Holdtime |
Holdtime of the PIM neighbor; “forever” means that the PIM neighbor is always up and reachable. |
LAN delay |
Prune message delay. |
Override interval |
Prune override interval. |
State refresh interval |
Interval for sending state refresh messages. Displayed only when the PIM neighbor works in PIM-DM mode and the state refresh capability is enabled. |
Neighbor tracking |
Neighbor tracking status (enabled/disabled). |
Bidirectional PIM |
BIDIR-PIM status (enabled/disabled). |
display pim routing-table
display pim [ all-instance | vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface [ interface-type interface-number | register ] | outgoing-interface { include | exclude | match } { interface-type interface-number | register } | mode mode-type | flags flag-value | fsm ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
source-address: Multicast source address.
mask: Mask of the multicast group/source address, 255.255.255.255 by default.
mask-length: Mask length of the multicast group/source address, in the range of 0 to 32. The system default is 32.
incoming-interface: Displays PIM routing entries that contain the specified interface as the incoming interface.
register: Specifies the register interface. This keyword is valid only if mode-type is not specified or is sm.
outgoing-interface: Displays PIM routing entries of which the outgoing interface is the specified interface.
include: Displays PIM routing entries of which the outgoing interface list includes the specified interface.
exclude: Displays PIM routing entries of which the outgoing interface list excludes the specified interface.
match: Displays PIM routing entries of which the outgoing interface list includes only the specified interface.
mode mode-type: Specifies a PIM mode, where mode-type can have the following values:
· dm: Specifies PIM-DM.
· sm: Specifies PIM-SM.
· ssm: Specifies PIM-SSM.
flags flag-value: Displays PIM routing entries containing the specified flag or flags. The values of flag-value and their meanings are as follows:
· 2msdp: Specifies PIM routing entries to be contained in the next SA message to notify an MSDP peer.
· act: Specifies PIM routing entries that have been used for routing data.
· bidir: Specifies PIM routing entries created by BIDIR-PIM.
· del: Specifies PIM routing entries scheduled to be deleted.
· exprune: Specifies PIM routing entries containing outgoing interfaces pruned by other multicast routing protocols.
· ext: Specifies PIM routing entries containing outgoing interfaces provided by other multicast routing protocols.
· loc: Specifies PIM routing entries on the devices that directly connect to the same subnet as the multicast source.
· msdp: Specifies PIM routing entries learned from MSDP SA messages.
· niif: Specifies PIM routing entries containing unknown incoming interfaces.
· nonbr: Specifies PIM routing entries with PIM neighbor searching failure.
· rpt: Specifies PIM routing entries on RPT branches where (S, G) prunes have been sent to the RP.
· rq: Specifies PIM routing entries of the receiving side of the switch-MDT switchover.
· spt: Specifies PIM routing entries on the SPT.
· sq: Specifies PIM routing entries of the originator side of switch-MDT switchover.
· swt: Specifies PIM routing entries in the process of RPT-to-SPT switchover.
fsm: Displays the information of the state machine.
Use the display pim routing-table command to view PIM routing table information.
Related commands: display multicast routing-table.
# Display the content of the PIM routing table in the public network.
<Sysname> display pim routing-table
RP: 2.2.2.2
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Vlan-interface100
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: Vlan-interface101
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# Display the state machine information in the PIM routing table in the public network.
<Sysname> display pim routing-table fsm
Abbreviations for FSM states:
NI - no info, J - joined, NJ - not joined, P - pruned,
NP - not pruned, PP - prune pending, W - winner, L - loser,
F - forwarding, AP - ack pending, DR - designated router,
NDR - non-designated router, RCV - downstream receivers
RP: 2.2.2.2
UpTime: 02:54:43
Upstream interface: GigabitEthernet3/0/1
Join/Prune FSM: [SPT: J] [RPT: NP]
1: GigabitEthernet3/0/2
DR state: [DR]
Join/Prune FSM: [NI]
Assert FSM: [NI]
FSM information for non-downstream interfaces: None
Table 10 Output description
Public network |
Total 0 (*, G) entry; 1 (S, G) entry |
Number of (S,G) and (*, G) entries in the PIM routing table |
(172.168.0.2, 227.0.0.1) |
An (S, G) entry in the PIM routing table |
RP |
IP address of the RP |
Protocol |
PIM mode |
Flag |
Flag of the (S, G) or (*, G) entry in the PIM routing table: · 2MSDP: Indicates that the entry is contained in the next SA message to notify an MSDP peer. · ACT: Indicates that the entry has been used for routing data. · BIDIR: Indicates that the entry was created by BIDIR-PIM. · DEL: Indicates that the entry will be removed. · EXPRUNE: Indicates that some outgoing interfaces are pruned by other multicast routing protocols. · EXT: Indicates that the entry contains outgoing interfaces provided by other multicast routing protocols. · LOC: Indicates that the entry is on a router directly connected to the same subnet with the multicast source. · MSDP: Indicates that the entry is learnt from MSDP SA messages. · NIIF: Indicates that the entry contains unknown incoming interfaces. · NONBR: Indicates that the entry has a PIM neighbor searching failure. · RPT: Indicates that the entry is on a RPT branch where (S, G) prunes have been sent to the RP. · RQ: Indicates that the entry is on the receiving side of the switch-MDT switchover. · SPT: Indicates that the entry is on the SPT. · SQ: Indicates that the entry is on the originator side of switch-MDT switchover. · SWT: Indicates that the entry is in the process of RPT-to-SPT switchover. · WC: Indicates a wildcard routing entry. |
Uptime |
Length of time for which the (S, G) or (*, G) entry has been existing |
Upstream interface |
Upstream (incoming) interface of the (S, G) or (*, G) entry |
Upstream neighbor |
Upstream neighbor of the (S, G) or (*, G) entry |
RPF prime neighbor |
RPF neighbor of the (S, G) or (*, G) entry · For a (*, G) entry, if this router is the RP, the RPF neighbor of this (*, G) entry is NULL. · For a (S, G) entry, if this router directly connects to the multicast source, the RPF neighbor of this (S, G) entry is NULL. |
Downstream interface(s) information |
Information of the downstream interfaces, including: · Number of downstream interfaces · Downstream interface name · Protocol type on the downstream interfaces · Uptime of the downstream interfaces · Expiry time of the downstream interfaces |
display pim rp-info
display pim [ all-instance | vpn-instance vpn-instance-name ] rp-info [ group-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Address of the multicast group of which the RP information will be displayed, in the range of 224.0.1.0 to 239.255.255.255. If you do not provide a group address, this command will display the RP information corresponding to all multicast groups.
Use the display pim rp-info command to view the RP information.
The RP information includes the information of RPs dynamically found by the BSR mechanism and static RPs.
# Display the RP information corresponding to the multicast group 224.0.1.1 in the public network.
<Sysname> display pim rp-info 224.0.1.1
BSR RP Address is: 2.2.2.2
Priority: 192
HoldTime: 150
Uptime: 03:01:10
Expires: 00:02:30
RP mapping for this group is: 2.2.2.2
# Display the RP information corresponding to all multicast groups in the public network.
PIM-SM BSR RP information:
Group/MaskLen: 224.0.0.0/4 [B]
RP: 2.2.2.2
Priority: 192
HoldTime: 150
Uptime: 03:01:36
Expires: 00:02:29
Table 11 Output description
Public network. |
BSR RP Address is |
IP address of the RP. |
Group/MaskLen |
The multicast group served by the RP. |
[B] |
The RP serves multicast groups in BIDIR-PIM. If this field is not displayed, it means that the RP serves groups in PIM-SM. |
RP |
Priority |
RP priority. |
HoldTime |
RP timeout time. |
Uptime |
Length of time for which the RP has been up, in hh:mm:ss. |
Expires |
Length of time in which the RP will expire, in hh:mm:ss. |
RP mapping for this group |
IP address of the RP serving the current multicast group. |
undo hello-option dr-priority
View
Default level
2: System level
priority: Router priority for DR election, in the range of 0 to 4294967295. A larger value of this argument means a higher priority.
Use the hello-option dr-priority command to configure the global value of the router priority for DR election.
Use the undo hello-option dr-priority command to restore the default.
By default, the router priority for DR election is 1.
Related commands: pim hello-option dr-priority.
# Set the router priority for DR election to 3 in the public network.
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
# Set the router priority for DR election to 3 in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option dr-priority 3
hello-option holdtime interval
undo hello-option holdtime
View
Default level
2: System level
interval: PIM neighbor timeout time in seconds, in the range of 1 to 65,535. 65,535 makes the PIM neighbor always reachable.
Use the hello-option holdtime command to configure the PIM neighbor timeout time.
Use the undo hello-option holdtime command to restore the default.
By default, the PIM neighbor timeout time is 105 seconds.
Related commands: pim hello-option holdtime.
# Set the global value of the PIM neighbor timeout time to 120 seconds in the public network.
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
# Set the global value of the PIM neighbor timeout time to 120 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option holdtime 120
hello-option lan-delay interval
undo hello-option lan-delay
View
Default level
2: System level
interval: LAN-delay time in milliseconds, in the range of 1 to 32,767.
Use the hello-option lan-delay command to configure the global value of the LAN-delay time, namely, the period of time that the device waits before forwarding a received prune message.
Use the undo hello-option lan-delay command to restore the default.
By default, the LAN-delay time is 500 milliseconds.
This command is effective for both PIM-DM and PIM-SM.
Related commands: hello-option override-interval, pim hello-option lan-delay, and pim hello-option override-interval.
# Set the LAN-delay time to 200 milliseconds globally in the public network.
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
# Set the LAN-delay time to 200 milliseconds globally in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option lan-delay 200
undo hello-option neighbor-tracking
View
Default level
2: System level
None
Use the hello-option neighbor-tracking command to disable join suppression globally, namely, enable neighbor tracking.
Use the undo hello-option neighbor-tracking command to enable join suppression.
By default, join suppression is enabled. Namely, neighbor tracking is disabled.
Related commands: pim hello-option neighbor-tracking.
# Disable join suppression globally in the public network.
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
# Disable join suppression globally in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option neighbor-tracking
undo hello-option override-interval
View
Default level
2: System level
interval: Prune override interval in milliseconds, in the range of 1 to 65,535.
Use the hello-option override-interval command to configure the global value of the prune override interval.
Use the undo hello-option override-interval command to restore the default.
By default, the prune override interval is 2,500 milliseconds.
Related commands: hello-option lan-delay, pim hello-option lan-delay, and pim hello-option override-interval.
# Set the prune override interval to 2000 milliseconds globally in the public network.
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
# Set the prune override interval to 2000 milliseconds globally in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option override-interval 2000
holdtime assert (PIM view)
holdtime assert interval
undo holdtime assert
View
Default level
2: System level
interval: Assert timeout time in seconds, in the range of 7 to 2,147,483,647.
Use the holdtime assert command to configure the global value of the assert timeout time.
Use the undo holdtime assert command to restore the default.
By default, the assert timeout time is 180 seconds.
Related commands: holdtime join-prune, pim holdtime assert, and pim holdtime join-prune.
# Set the global value of the assert timeout time to 100 seconds in the public network.
[Sysname] pim
[Sysname-pim] holdtime assert 100
# Set the global value of the assert timeout time to 100 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] holdtime assert 100
holdtime join-prune interval
undo holdtime join-prune
View
Default level
2: System level
interval: Join/prune timeout time in seconds, in the range of 1 to 65,535.
Use the holdtime join-prune command to configure the global value of the join/prune timeout time.
Use the undo holdtime join-prune command to restore the default.
By default, the join/prune timeout time is 210 seconds.
Related commands: holdtime assert, pim holdtime assert, and pim holdtime join-prune.
# Set the global value of the join/prune timeout time to 280 seconds in the public network.
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
# Set the global value of the join/prune timeout time to 280 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] holdtime join-prune 280
jp-pkt-size (PIM view)
jp-pkt-size packet-size
undo jp-pkt-size
View
Default level
2: System level
packet-size: Maximum size of join/prune messages in bytes, in the range of 100 to 8,100.
Use the jp-pkt-size command to configure the maximum size of join/prune messages.
Use the undo jp-pkt-size command to restore the default.
By default, the maximum size of join/prune messages is 8,100 bytes.
Related commands: jp-queue-size.
# Set the maximum size of join/prune messages to 1500 bytes in the public network.
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
# Set the maximum size of join/prune messages to 1500 bytes in VPN instance mvpn.
[Sysname-pim-mvpn] jp-pkt-size 1500
jp-queue-size (PIM view)
jp-queue-size queue-size
undo jp-queue-size
View
Default level
2: System level
queue-size: Maximum number of (S, G) entries in a join/prune message, in the range of 1 to 4,096.
Use the jp-queue-size command to configure the maximum number of (S, G) entries in a join/prune message.
Use the undo jp-queue-size command to restore the default.
By default, a join/prune messages contains a maximum of 1,020 (S, G) entries.
When you use this command, take the following into account:
· The size of the forwarding table. In a network that does not support packet fragmentation, if you configure a large queue-size, a join/prune message might contain a large number of groups, causing the message length to exceed the MTU of the network. As a result, the products that do not support fragmentation will drop the join/prune message.
· The (S, G) join/prune timeout time on the upstream device. If you configure a small queue size, the outgoing interface of the corresponding entry might have been pruned due to timeout before the last join/prune message in a queue reaches the upstream device.
Related commands: holdtime join-prune, jp-pkt-size, and pim holdtime join-prune.
# Configure a join/prune messages to contain a maximum of 2000 (S, G) entries in the public network.
[Sysname] pim
[Sysname-pim] jp-queue-size 2000
# Configure a join/prune messages to contain a maximum of 2000 (S, G) entries in VPN instance mvpn.
[Sysname-pim-mvpn] jp-queue-size 2000
pim
pim [ vpn-instance vpn-instance-name ]
undo pim [ vpn-instance vpn-instance-name ]
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If this option is not specified, the command applies to the public network.
Use the pim command to enter public network PIM view or VPN instance PIM view.
Use the undo pim command to remove all configurations in public network PIM view or VPN instance PIM view.
IP multicast routing must be enabled in the corresponding instance before this command can take effect.
Related commands: multicast routing-enable.
# Enable IP multicast routing in the public network and enter public network PIM view.
[Sysname] pim
[Sysname-pim]
# Enable IP multicast routing in VPN instance mvpn and enter PIM view of VPN instance mvpn.
[Sysname-pim-mvpn]
pim bfd enable
pim bfd enable
undo pim bfd enable
View
Interface view
Default level
2: System level
None
Use the pim bfd enable command to enable PIM to work with Bidirectional Forwarding Detection (BFD).
Use the undo pim bfd enable command to disable this feature.
You must enable PIM-DM or PIM-SM on an interface before you configure this feature on the interface. Otherwise, this feature is not effective.
Related commands: pim dm and pim sm.
# Enable IP multicast routing in the public network, enable PIM-SM on interface VLAN-interface 100, and enable PIM to work with BFD on the interface.
[Sysname-Vlan-interface100] pim sm
[Sysname-Vlan-interface100] pim bfd enable
pim bsr-boundary
pim bsr-boundary
undo pim bsr-boundary
View
Interface view
Default level
2: System level
None
Use the pim bsr-boundary command to configure a PIM domain border, namely, a bootstrap message boundary.
Use the undo pim bsr-boundary command to remove the configured PIM domain border.
By default, no PIM domain border is configured.
Related commands: c-bsr and multicast boundary.
# Configure VLAN-interface 100 as a PIM domain border.
[Sysname-Vlan-interface100] pim bsr-boundary
pim dm
pim dm
undo pim dm
View
Interface view
Default level
2: System level
None
Use the pim dm command to enable PIM-DM.
Use the undo pim dm command to disable PIM-DM.
By default, PIM-DM is disabled.
This command can take effect only after IP multicast routing is enabled in the corresponding instance.
PIM-DM cannot be used for multicast groups in the SSM group range.
Related commands: multicast routing-enable, pim sm, and ssm-policy.
# Enable IP multicast routing in the public network, and enable PIM-DM on VLAN-interface 100.
[Sysname-Vlan-interface100] pim dm
pim hello-option dr-priority priority
undo pim hello-option dr-priority
View
Interface view
Default level
2: System level
Use the pim hello-option dr-priority command to configure the router priority for DR election on the current interface.
Use the undo pim hello-option dr-priority command to restore the default.
Related commands: hello-option dr-priority.
# Set the router priority for DR election to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option dr-priority 3
pim hello-option holdtime interval
undo pim hello-option holdtime
View
Interface view
Default level
2: System level
Use the pim hello-option holdtime command to configure the PIM neighbor timeout time on the current interface.
Use the undo pim hello-option holdtime command to restore the default.
Related commands: hello-option holdtime.
# Set the PIM neighbor timeout time to 120 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option holdtime 120
pim hello-option lan-delay interval
undo pim hello-option lan-delay
View
Interface view
Default level
2: System level
Use the pim hello-option lan-delay command to configure the LAN-delay time, namely, the length of time that the device waits before forwarding a received prune message, on the current interface.
Use the undo pim hello-option lan-delay command to restore the default.
By default, the LAN-delay time to 500 milliseconds.
Related commands: hello-option lan-delay, hello-option override-interval, and pim hello-option override-interval.
# Set the LAN-delay time to 200 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option lan-delay 200
undo pim hello-option neighbor-tracking
View
Interface view
Default level
2: System level
None
Use the pim hello-option neighbor-tracking command to disable join suppression, namely, enable neighbor tracking, on the current interface.
Use the undo pim hello-option neighbor-tracking command to enable join suppression.
Related commands: hello-option neighbor-tracking.
# Disable join suppression on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option neighbor-tracking
pim hello-option override-interval interval
undo pim hello-option override-interval
View
Interface view
Default level
2: System level
Use the pim hello-option override-interval command to configure the prune override interval on the current interface.
Use the undo pim hello-option override-interval command to restore the default.
Related commands: hello-option lan-delay, hello-option override-interval, and pim hello-option lan-delay.
# Set the prune override interval to 2,000 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option override-interval 2000
pim holdtime assert
pim holdtime assert interval
undo pim holdtime assert
View
Interface view
Default level
2: System level
Use the pim holdtime assert command to configure the assert timeout time on the current interface.
Use the undo pim holdtime assert command to restore the default.
Related commands: holdtime assert, holdtime join-prune, and pim holdtime join-prune.
# Set the assert timeout time to 100 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim holdtime assert 100
pim holdtime join-prune interval
undo pim holdtime join-prune
View
Interface view
Default level
2: System level
Use the pim holdtime join-prune command to configure the join/prune timeout time on the interface.
Use the undo pim holdtime join-prune command to restore the default.
Related commands: holdtime assert, holdtime join-prune, and pim holdtime assert.
# Set the join/prune timeout time to 280 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim holdtime join-prune 280
pim neighbor-policy
pim neighbor-policy acl-number
undo pim neighbor-policy
View
Interface view
Default level
2: System level
acl-number: Basic ACL number, in the range of 2000 to 2999. When the ACL is defined, the source keyword in the rule command specifies a legal source address range for hello messages.
Use the pim neighbor-policy command to configure a legal source address range for hello messages to guard against hello message spoofing.
Use the undo pim neighbor-policy command to restore the default.
By default, no source address range for hello messages is configured. That is, all the received hello messages are considered legal.
# Configure a legal source address range for hello messages on VLAN-interface 100 so that only the devices on the 10.1.1.0/24 subnet can become PIM neighbors of this switch.
[Sysname-Vlan-interface100] pim neighbor-policy 2000
pim require-genid
pim require-genid
undo pim require-genid
View
Interface view
Default level
2: System level
None
Use the pim require-genid command to enable rejection of hello messages without Generation_ID.
Use the undo pim require-genid command to restore the default.
By default, hello messages without Generation_ID are accepted.
# Enable VLAN-interface 100 to reject hello messages without Generation_ID.
[Sysname-Vlan-interface100] pim require-genid
pim sm
pim sm
undo pim sm
View
Interface view
Default level
2: System level
None
Use the pim sm command to enable PIM-SM.
Use the undo pim sm command to disable PIM-SM.
By default, PIM-SM is disabled.
Related commands: multicast routing-enable and pim dm.
# Enable IP multicast routing in the public network, and enable PIM-SM on VLAN-interface 100.
pim state-refresh-capable
undo pim state-refresh-capable
View
Interface view
Default level
2: System level
None
Use the pim state-refresh-capable command to enable the state fresh feature on the interface.
Use the undo pim state-refresh-capable command to disable the state fresh feature.
By default, the state refresh feature is enabled.
Related commands: state-refresh-interval, state-refresh-rate-limit, and state-refresh-ttl.
# Disable state refresh on VLAN-interface 100.
[Sysname-Vlan-interface100] undo pim state-refresh-capable
pim timer graft-retry
pim timer graft-retry interval
undo pim timer graft-retry
View
Interface view
Default level
2: System level
interval: Graft retry period in seconds, in the range of 1 to 65,535.
Use the pim timer graft-retry command to configure the graft retry period.
Use the undo pim timer graft-retry command to restore the default.
By default, the graft retry period is 3 seconds.
# Set the graft retry period to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer graft-retry 80
pim timer hello
pim timer hello interval
undo pim timer hello
View
Interface view
Default level
2: System level
interval: Hello interval in seconds, in the range of 1 to 2,147,483,647.
Use the pim timer hello command to configure on the current interface the interval at which hello messages are sent.
Use the undo pim timer hello command to restore the default.
By default, hello messages are sent at the interval of 30 seconds.
Related commands: timer hello.
# Set the hello interval to 40 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer hello 40
pim timer join-prune
pim timer join-prune interval
undo pim timer join-prune
View
Interface view
Default level
2: System level
interval: Join/prune interval in seconds, in the range of 1 to 2,147,483,647.
Use the pim timer join-prune command to configure on the current interface the interval at which join/prune messages are sent.
Use the undo pim timer join-prune command to restore the default.
By default, the join/prune interval is 60 seconds.
Related commands: timer join-prune.
# Set the join/prune interval to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer join-prune 80
pim triggered-hello-delay
pim triggered-hello-delay interval
undo pim triggred-hello-delay
View
Interface view
Default level
2: System level
interval: Maximum delay in seconds between hello messages, in the range of 1 to 60.
Use the pim triggered-hello-delay command to configure the maximum delay between hello messages.
Use the undo pim triggered-hello-delay command to restore the default.
By default, the maximum delay between hello messages is 5 seconds.
# Set the maximum delay between hello messages to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim triggered-hello-delay 3
probe-interval (PIM view)
probe-interval interval
undo probe-interval
View
Public network PIM view, VPN instance PIM view
Default level
2: System level
interval: Register probe time in seconds, in the range of 1 to 1799.
Use the probe-interval command to configure the register probe time.
Use the undo probe-interval command to restore the default.
By default, the register probe time is 5 seconds.
Related commands: register-suppression-timeout.
# Set the register probe time to 6 seconds in the public network.
[Sysname] pim
[Sysname-pim] probe-interval 6
# Set the register probe time to 6 seconds in VPN instance mvpn.
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn] probe-interval 6
prune delay (PIM view)
prune delay interval
undo prune delay
View
Default level
2: System level
interval: Prune delay time in the range 1 to 128 seconds.
Use the prune delay command to configure the prune delay time, namely, the length of time that the device waits between receiving a prune message and taking a prune action.
Use the undo prune delay command to restore the default.
By default, the prune delay time is 3 seconds, which equals the prune pending time.
# Set the prune delay time to 75 seconds in the public network.
[Sysname] pim
[Sysname-pim] prune delay 75
# Set the prune delay time to 75 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] prune delay 75
register-policy (PIM view)
register-policy acl-number
undo register-policy
View
Default level
2: System level
acl-number: Advanced ACL number, in the range of 3000 to 3999. Only register messages that match the permit statement of the ACL can be accepted by the RP.
Use the register-policy command to configure an ACL rule to filter register messages.
Use the undo register-policy command to remove the configured register filtering rule.
By default, no register filtering rule is configured.
# In the public network, configure the RP to accept only those register messages from multicast sources on the subnet of 10.10.0.0/16 for multicast groups on the subnet of 225.1.0.0/16.
[Sysname-acl-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
# In VPN instance mvpn, configure the RP to accept only those register messages from multicast sources on the subnet of 10.10.0.0/16 for multicast groups on the subnet of 225.1.0.0/16.
[Sysname-pim-mvpn] register-policy 3000
register-suppression-timeout (PIM view)
undo register-suppression-timeout
View
Default level
2: System level
interval: Register suppression time in seconds, in the range of 1 to 65535.
Use the register-suppression-timeout command to configure the register suppression time.
Use the undo register-suppression-timeout command to restore the default.
By default, the register suppression time is 60 seconds.
Related commands: probe-interval and register-policy.
# Set the register suppression time to 70 seconds in the public network.
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
# Set the register suppression time to 70 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] register-suppression-timeout 70
register-whole-checksum (PIM view)
undo register-whole-checksum
View
Default level
2: System level
None
Use the register-whole-checksum command to configure the router to calculate the checksum based on the entire register message.
Use the undo register-whole-checksum command to restore the default.
By default, the checksum is calculated based on the header in the register message.
Related commands: register-policy and register-suppression-timeout.
# Configure the router to calculate the checksum based on the entire register message in the public network.
[Sysname] pim
[Sysname-pim] register-whole-checksum
[Sysname-pim-mvpn] register-whole-checksum
reset pim control-message counters
reset pim [ all-instance | vpn-instance vpn-instance-name ] control-message counters [ interface interface-type interface-number ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies to reset the PIM control message counter on a particular interface. If no interface is specified, this command reset PIM control message couters on all interfaces.
Use the reset pim control-message counters command to reset PIM control message counters.
If neither all-instance nor vpn-instance is specified, this command resets PIM control message counters in the public network.
# Reset PIM control message counters on all interfaces in the public network.
<Sysname> reset pim control-message counters
source-lifetime (PIM view)
source-lifetime interval
undo source-lifetime
View
Default level
2: System level
interval: Multicast source lifetime in seconds, in the range of 1 to 31,536,000.
Use the source-lifetime command to configure the multicast source lifetime.
Use the undo source-lifetime command to restore the default.
By default, the lifetime of a multicast source is 210 seconds.
# Set the multicast source lifetime to 200 seconds in the public network.
[Sysname] pim
[Sysname-pim] source-lifetime 200
# Set the multicast source lifetime to 200 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] source-lifetime 200
source-policy (PIM view)
source-policy acl-number
undo source-policy
View
Default level
2: System level
acl-number: Basic or advanced ACL number, in the range of 2000 to 3999.
Use the source-policy command to configure a multicast data filter.
Use the undo source-policy command to remove the configured multicast data filter.
By default, no multicast data filter is configured.
If you specify a basic ACL, the device filters all the received multicast packets based on the source address, and discards packets that fail the source address match. If you specify an advanced ACL, the device filters all the received multicast packets based on the source and group addresses, and discards packets that fail the match.
If this command is executed repeatedly, the last configuration will take effect.
# In the public network, configure the router to accept multicast packets originated from 10.10.1.2 and discard multicast packets originated from 10.10.1.1.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-basic-2000] rule deny source 10.10.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] source-policy 2000
# In VPN instance mvpn, configure the router to accept multicast packets originated from 10.10.1.2 and discard multicast packets originated from 10.10.1.1.
[Sysname-pim-mvpn] source-policy 2000
spt-switch-threshold (PIM view)
spt-switch-threshold infinity [ group-policy acl-number [ order order-value ] ]
undo spt-switch-threshold [ group-policy acl-number ]
View
Default level
2: System level
infinity: Disables SPT switchover.
group-policy acl-number: Specifies a basic ACL, in the range of 2000 to 2999. If you do not include this option in your command, the configuration will apply on all multicast groups.
order order-value: Specifies the order of the ACL in the group-policy list, where order-value has an effective range of 1 to (the largest order value in the existing group-policy list + 1), but the value range should not include the original order value of the ACL in the group-policy list. If you have assigned an order-value to a certain ACL, do not specify the same order-value for another ACL. Otherwise the system will give error information. If you do not specify an order-value, the order value of the ACL will remain the same in the group-policy list.
Use the spt-switch-threshold command to configure the SPT switchover parameters.
Use the undo spt-switch-threshold command to restore the default.
By default, the device switches to the SPT immediately after it receives the first multicast packet.
To adjust the order of an existing ACL in the group-policy list, you can use the acl-number argument to specify this ACL and set its order-value. This will insert the ACL to the position of order-value in the group-policy list. The order of the other existing ACLs in the group-policy list will remain unchanged.
To use an ACL that does not exist in the group-policy list, you can use the acl-number argument to specify an ACL and set its order-value. This will insert the ACL to the position of order-value in the group-policy list. If you do not include the order order-value option in your command, the ACL will be appended to the end of the group-policy list.
If you use this command multiple times on the same multicast group, the first traffic rate configuration matched in sequence will take effect.
Once a multicast forwarding entry is created, subsequent multicast data will not be encapsulated in register messages before being forwarded even if a register outgoing interface is available. Therefore, to avoid forwarding failure, do not include the infinity keyword in the spt-switch-threshold command on a switch or a multi-core device that might become an RP (namely, a static RP or a C-RP).
# In the public network, disable the SPT switchover on a switch that will never become an RP.
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
# In VPN instance mvpn, disable the SPT switchover on a switch that will never become an RP.
[Sysname-pim-mvpn] spt-switch-threshold infinity
ssm-policy (PIM view)
ssm-policy acl-number
undo ssm-policy
View
Default level
2: System level
Use the ssm-policy command to configure the SSM multicast group range.
Use the undo ssm-policy command to restore the default.
By default, the SSM group range is 232.0.0.0/8.
This command allows you to define an address range of permitted or denied multicast groups. If the match succeeds, the multicast mode will be PIM-SSM. Otherwise the multicast mode will be PIM-SM.
# Configure the SSM group range to be 232.1.0.0/16 in the public network.
[Sysname-acl-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
# Configure the SSM group range to be 232.1.0.0/16 in VPN instance mvpn.
[Sysname-pim-mvpn] ssm-policy 2000
state-refresh-interval (PIM view)
undo state-refresh-interval
View
Default level
2: System level
interval: State refresh interval in seconds, in the range of 1 to 255.
Use the state-refresh-interval command to configure the interval between state refresh messages.
Use the undo state-refresh-interval command to restore the default.
By default, the state refresh interval is 60 seconds.
Related commands: pim state-refresh-capable, state-refresh-rate-limit, and state-refresh-ttl.
# Set the state refresh interval to 70 seconds in the public network.
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
# Set the state refresh interval to 70 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] state-refresh-interval 70
state-refresh-rate-limit (PIM view)
state-refresh-rate-limit interval
undo state-refresh-rate-limit
View
Default level
2: System level
interval: Time to wait before receiving a new refresh message, in seconds and in the range of 1 to 65535.
Use the state-refresh-rate-limit command to configure the time the router must wait before receiving a new state refresh message.
Use the undo state-refresh-rate-limit command to restore the default.
By default, the device waits 30 seconds before receiving a new state refresh message.
Related commands: pim state-refresh-capable, state-refresh-interval, and state-refresh-ttl.
# In the public network, configure the device to wait 45 seconds before receiving a new state refresh message.
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
# In VPN instance mvpn, configure the device to wait 45 seconds before receiving a new state refresh message.
[Sysname-pim-mvpn] state-refresh-rate-limit 45
state-refresh-ttl
state-refresh-ttl ttl-value
undo state-refresh-ttl
View
Default level
2: System level
ttl-value: TTL value of state refresh messages, in the range of 1 to 255.
Use the state-refresh-ttl command to configure the TTL value of state refresh messages.
Use the undo state-refresh-ttl command to restore the default.
By default, the TTL value of state refresh messages is 255.
Related commands: pim state-refresh-capable, state-refresh-interval, and state-refresh-rate-limit.
# In the public network, configure the device to send PIM state refresh messages with a TTL of 45.
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
# In VPN instance mvpn, configure the device to send PIM state refresh messages with a TTL of 45.
[Sysname-pim-mvpn] state-refresh-ttl 45
static-rp (PIM view)
static-rp rp-address [ acl-number ] [ preferred ] [ bidir ]
undo static-rp rp-address
View
Default level
2: System level
rp-address: IP address of the static RP to be configured. This address must be a real, valid unicast IP address, rather than an address on the 127.0.0.0/8 segment. For a static RP serving BIDIR-PIM, you can specify a virtual IP address.
acl-number: Basic ACL number, in the range of 2000 to 2999. If you provide this argument, the configured static RP will serve only those groups that pass the ACL filtering. Otherwise, the configured static RP will serve the all-system group 224.0.0.0/4.
preferred: Specifies to give priority to the static RP if the static RP conflicts with the dynamic RP. If you do not include the preferred keyword in your command, the dynamic RP will be given priority, and the static RP takes effect only if no dynamic RP exists in the network or when the dynamic RP fails.
bidir: Configures the static RP to serve multicast groups in BIDIR-PIM. Without this argument, the static RP serves groups in PIM-SM.
Use the static-rp command to configure a static RP.
Use the undo static-rp command to configure a static RP.
By default, no static RP is configured.
PIM-SM or PIM-DM cannot be enabled on an interface that serves as a static RP.
When the ACL rule applied on a static RP changes, a new RP must be elected for all the multicast groups.
You can configure multiple static RPs by using this command repeatedly. However, if you execute this command multiple times and specify the same static RP address or reference the same ACL rule, the last configuration will override the previous one. If multiple static RPs have been configured for the same multicast group, the one with the highest IP address will be chosen to serve the multicast group.
You can configure up to 50 static RPs on the same device.
Related commands: auto-rp enable and display pim rp-info.
# In the public network, configure the interface with the IP address 11.110.0.6 to be a static RP that serves the multicast groups in the address range of 225.1.1.0/24 defined in basic ACL 2001, and give priority to this static RP in the case of static/dynamic RP conflict.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
# In VPN instance mvpn, configure the interface with the IP address 11.110.0.6 to be a static RP that serves the multicast groups in the address range of 225.1.1.0/24 defined in basic ACL 2001, and give priority to this static RP in the case of static/dynamic RP conflict.
[Sysname-pim-mvpn] static-rp 11.110.0.6 2001 preferred
timer hello (PIM view)
undo timer hello
View
Default level
2: System level
Use the timer hello command to configure the hello interval globally.
Use the undo timer hello command to restore the default.
Related commands: pim timer hello.
# Set the global hello interval to 40 seconds in the public network.
[Sysname] pim
[Sysname-pim] timer hello 40
# Set the global hello interval to 40 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] timer hello 40
timer join-prune (PIM view)
undo timer join-prune
View
Default level
2: System level
Use the timer join-prune command to configure the join/prune interval globally.
Use the undo timer join-prune command to restore the default.
Related commands: pim timer join-prune.
# Set the global join/prune interval to 80 seconds in the public network.
[Sysname] pim
[Sysname-pim] timer join-prune 80
# Set the global join/prune interval to 80 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] timer join-prune 80
