- 08-IP Multicast Command Reference
 - 01-IGMP Snooping Commands
 - 02-PIM Snooping Commands
 - 03-Multicast VLAN Commands
 - 04-Multicast Routing and Forwarding Commands
 - 05-IGMP Commands
 - 06-PIM Commands
 - 07-MSDP Commands
 - 08-MBGP Commands
 - 09-Multicast VPN Commands
 - 10-MLD Snooping Commands
 - 11-IPv6 PIM Snooping Commands
 - 12-IPv6 Multicast VLAN Commands
 - 13-IPv6 Multicast Routing and Forwarding Commands
 - 14-MLD Commands
 - 15-IPv6 PIM Commands
 - 16-IPv6 MBGP Commands
| 02-PIM Snooping Commands | 85.83 KB |
PIM snooping configuration commands
display pim-snooping routing-table
display pim-snooping statistics
   NOTE: The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide.  |
display pim-snooping neighbor
In standalone mode:
display pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display pim-snooping neighbor [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the PIM snooping neighbor information of the specified VLAN. vlan-id is in the range of 1 to 4094.
slot slot-number: Displays the PIM snooping neighbor information of the card specified by its slot number. If no slot is specified, the command displays the PIM snooping neighbor information of all cards. (In standalone mode)
chassis chassis-number slot slot-number: Displays the PIM snooping neighbor information of a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, the command displays the PIM snooping neighbor information of all cards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode)
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display pim-snooping neighbor command to display PIM snooping neighbor information. If you do not specify a VLAN, this command displays PIM snooping neighbor information on all VLANs.
# Display the PIM snooping neighbor information of VLAN 2.
<Sysname> display pim-snooping neighbor vlan 2
Total number of neighbors: 2
VLAN ID: 2
Neighbor Port Expires Option Flags
10.1.1.2 GE3/0/1 02:02:23 LAN Prune Delay(T)
20.1.1.2 GE3/0/2 03:00:05 LAN Prune Delay
Table 1 Output description
    Field  |
    Description  |
   Total number of neighbors  |
   Total number of PIM snooping neighbors.  |
   Neighbor  |
   IP address of the PIM snooping neighbor.  |
   Port  |
   Name of the port that connects to the PIM snooping neighbor.  |
   Expires  |
   Remaining time before the PIM snooping neighbor expires. Never means the PIM snooping neighbor never expires.  |
   Option Flags  |
   Possible values includes the following items: · LAN Prune Delay—Indicates that the PIM hello messages received from the neighbor carry the LAN_Prune_Delay option. · LAN Prune Delay(T)—Indicates that the PIM hello messages received from the neighbor carry the LAN_Prune_Delay option, and the join suppression function has been disabled  |
In standalone mode:
display pim-snooping routing-table [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display pim-snooping routing-table [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the PIM snooping routing entries of the specified VLAN. vlan-id is in the range of 1 to 4094.
slot slot-number: Displays the PIM snooping routing entries on the card specified by its slot number. If no slot is specified, the command displays information about the PIM snooping routing entries on the main board. (In standalone mode)
chassis chassis-number slot slot-number: Displays the PIM snooping routing entries on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, the command displays the PIM snooping routing entries on all active main boards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode)
Use the display pim-snooping routing-table command to display the PIM snooping routing entries. If you do not specify a VLAN, this command displays the PIM snooping routing entries in all VLANs.
# Display the PIM snooping routing entries of VLAN 2.
<Sysname> display pim-snooping routing-table vlan 2
Total 1 entry(ies)
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN ID: 2
Total 1 entry(ies)
(172.10.10.1, 225.1.1.1)
Upstream neighbor: 20.1.1.1
Upstream port: GE3/0/1
Total number of downstream ports: 2
1: GE3/0/3
2: GE3/0/4
Upstream neighbor: 10.1.1.1
Upstream port: GE3/0/2
Total number of downstream ports: 1
1: GE3/0/5
   NOTE: · In standalone mode, to determine the Upstream port field of an upstream interface that is not on the main board, you must specify the slot number of the card that the interface belongs to. · In IRF mode, to determine the Upstream port field of an upstream interface that is not on the main board, you must specify the chassis number and slot number of the card that the interface belongs to. · In standalone mode, to determine the Expires and FSM fields of a non-aggregate interface that is not on the main board, you must specify the slot number of the card that the interface belongs to. For aggregate interfaces, the Expires and FSM fields are displayed, whether the slot number is specified or not. · In IRF mode, to determine the Expires and FSM fields of a non-aggregate interface that is not on the main board, you must specify the chassis number and slot number of the card that the interface belongs to. For aggregate interfaces, the Expires and FSM fields are displayed, whether the chassis number and slot number are specified or not.  |
Table 2 Output description
    Field  |
    Description  |
   Total 1 entry(ies)  |
   Total number of (S, G) entries and (*, G) entries in the PIM snooping routing table  |
   FSM Flag: NI-no info, J-join, PP-prune pending  |
   State machine flag of the downstream port. Possible values include: · NI—Initial state · J—Join · PP—Prune pending  |
   (172.10.10.1, 225.1.1.1)  |
   An (S, G) entry  |
   Upstream neighbor  |
   Upstream neighbor of the (S, G) or (*, G) entry  |
   Upstream port  |
   Upstream port of the (S, G) entry or (*, G) entry)  |
   Total number of downstream ports  |
   Total number of downstream ports contained in the upstream neighbor of the (S, G) or (*, G) entry  |
   FSM  |
   State machine flag of the downstream port  |
display pim-snooping statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display pim-snooping statistics command to display the statistics for PIM messages learned through PIM snooping.
# Display the statistics for PIM messages learned through PIM snooping.
<Sysname> display pim-snooping statistics
Received PIMv2 hello: 100
Received PIMv2 join/prune: 100
Received PIMv2 error: 0
Received PIMv2 messages in total: 200
Received PIMv1 messages in total: 0
Table 3 Output description
    Field  |
    Description  |
   Received PIMv2 hello  |
   Number of received PIMv2 hello messages  |
   Received PIMv2 join/prune  |
   Number of received PIMv2 join/prune messages  |
   Received PIMv2 error  |
   Number of received PIMv2 messages with errors  |
   Received PIMv2 messages in total  |
   Total number of received PIMv2 messages  |
   Received PIMv1 messages in total  |
   Total number of received PIMv1 messages  |
pim-snooping enable
pim-snooping enable
undo pim-snooping enable
View
VLAN view
Default level
2: System level
None
Use the pim-snooping enable command to enable PIM snooping in a VLAN.
Use the undo pim-snooping enable command to disable PIM snooping in a VLAN.
By default, PIM snooping is disabled.
Before you enable PIM snooping in a VLAN, be sure to enable IGMP snooping globally and specifically in the VLAN.
PIM snooping does not work in a sub-VLAN of a multicast VLAN.
Related commands: igmp-snooping enable.
# Enable IGMP snooping globally, and enable IGMP snooping and PIM snooping in VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] pim-snooping enable
reset pim-snooping statistics
View
Default level
2: System level
None
Use the reset pim-snooping statistics command to clear the statistics for PIM messages learned through PIM snooping.
# Clear the statistics for PIM messages learned through PIM snooping.
<Sysname> reset pim-snooping statistics
