- 08-IP Multicast Command Reference
- 01-IGMP Snooping Commands
- 02-PIM Snooping Commands
- 03-Multicast VLAN Commands
- 04-Multicast Routing and Forwarding Commands
- 05-IGMP Commands
- 06-PIM Commands
- 07-MSDP Commands
- 08-MBGP Commands
- 09-Multicast VPN Commands
- 10-MLD Snooping Commands
- 11-IPv6 PIM Snooping Commands
- 12-IPv6 Multicast VLAN Commands
- 13-IPv6 Multicast Routing and Forwarding Commands
- 14-MLD Commands
- 15-IPv6 PIM Commands
- 16-IPv6 MBGP Commands
| 03-Multicast VLAN Commands | 60.47 KB |
Multicast VLAN configuration commands····································································································································· 1
display multicast-vlan······················································································································································ 1
multicast-vlan······································································································································································ 2
multicast-vlan entry-limit··················································································································································· 2
subvlan (multicast VLAN view)······································································································································ 3
display multicast-vlan [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id: VLAN ID of a multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all multicast VLANs will be displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display multicast-vlan command to display the information about the specified multicast VLAN.
# Display the information about all multicast VLANs.
<Sysname> display multicast-vlan
Total 1 multicast-vlan(s)
Multicast vlan 10
subvlan list:
vlan 2-4
Table 1 Output description
Total 1 multicast-vlan(s) |
Total number of multicast VLANs |
Multicast vlan |
A multicast VLAN |
subvlan list |
List of sub-VLANs of the multicast VLAN |
multicast-vlan
multicast-vlan vlan-id
undo multicast-vlan { all | vlan-id }
View
Default level
2: System level
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
all: Deletes all multicast VLANs.
Use the multicast-vlan command to configure the specified VLAN as a multicast VLAN and enter multicast VLAN view.
Use the undo multicast-vlan command to remove the specified VLAN as a multicast VLAN.
The VLAN to be configured is not a multicast VLAN by default.
The specified VLAN to be configured as a multicast VLAN must exist.
The multicast VLAN feature cannot be enabled on a device with IP multicast routing enabled.
You need to enable IGMP snooping only in the multicast VLAN.
Related commands: igmp-snooping enable and multicast routing-enable.
# Enable IGMP snooping in VLAN 100. Configure it as a multicast VLAN and enter multicast VLAN view.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] igmp-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan 100
[Sysname-mvlan-100]
multicast-vlan entry-limit limit
undo multicast-vlan entry-limit
View
Default level
2: System level
limit: Maximum number of entries in the IGMP snooping forwarding table of multicast VLANs. The value range depends on the system working mode. For more information about system working modes, see Fundamentals Configuration Guide.
Use the multicast-vlan entry-limit command to configure the maximum number of IGMP snooping forwarding entries of multicast VLANs.
Use the undo multicast-vlan entry-limit command to restore the default.
The default upper limit depends on the system working mode. For more information about system working modes, see Fundamentals Configuration Guide.
Related commands: entry-limit.
# Configure the IGMP snooping forwarding table of multicast VLANs to contain 512 entries at most.
[Sysname] multicast-vlan entry-limit 512
subvlan vlan-list
undo subvlan { all | vlan-list }
View
Multicast VLAN view
Default level
2: System level
vlan-list: Specifies a VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094.
all: Deletes all the sub-VLANs of the current multicast VLAN.
Use the subvlan command to configure sub-VLAN or sub-VLANs for the current multicast VLAN.
Use the undo subvlan command to remove the specified sub-VLAN or sub-VLANs or all sub-VLANs from the current multicast VLAN.
A multicast VLAN has no sub-VLANs by default.
The VLANs to be configured as sub-VLANs of the multicast VLAN must have existed.
The number of sub-VLANs of the multicast VLAN must not exceed 1024.
# Configure VLAN 10 through VLAN 15 as sub-VLANs of multicast VLAN 100.
[Sysname-mvlan-100] subvlan 10 to 15
